DWR-T010S-V233-01
DWR-T010S-V233-01
    ARDUINO
    CONNHEADER10POSSTRGTPCB
DWR-T010S-V233-01 数据手册
A B C D E G F H REVISIONS 26.09 1.027 REV DESCRIPTION, ECN, EAR NO. DATE APP'D A NEW PROPOSAL DWG (EAR 13783) OCT25/10 K.L. 10.97 .432 1 1 SIGNAL CONTACTS SLOT ACCEPTS PIN CONNECTOR HOUSING BLADE, LOCATED OFF CENTER TO PREVENT IMPROPER MATING SOCKET HOUSING 10.80 .425 2 2 2.74 TYP. .108 8.40 .331 20.32 .800 3 3 P/N DWR-T010S-V233-01 9.02 .355 15.37 .605 REF 6.35 .250 4 4 3.81 .150 0.46 [.018] x 0.76 [.030] SIGNAL CONTACT TAILS (10 PLACES) ORIENTATION PEG PREVENTS ASSEMBLY ERRORS 14.63 .576 5 NOTES: 1. MATERIALS: ALL MATERIALS ARE RoHS COMPLIANT PER EU DIRECTIVE 2002/95/EC AND AMENDMENTS. • HOUSING: HIGH TEMPERATURE RESISTANT NYLON, UL FLAMMABILITY RATING 94V-0, COLOUR BLACK • SIGNAL CONTACTS: PHOSPHOR BRONZE PLATED WITH 0.38µm (15µ”) GOLD OVER 1.27µm (50µ”) NICKEL ON THE MATING AREA AND 2.54µm (100µ”) MATTE TIN OVER NICKEL ON THE TAILS. 2. WHEN MATED WITH PIN CONNECTOR P/N DWR-T010P-V233-01, THE ORDER OF MECHANICAL AND ELECTRICAL ENGAGEMENT IS A) HOUSING BLADES, B) HOUSING SHROUD, C) SIGNAL CONTACTS. 3. RATINGS SUBJECT TO DESIGN QUALIFICATION TESTING • CURRENT RATING: 5A SIGNAL • DIELECTRIC WITHSTANDING VOLTAGE: 1500VDC • INSULATION RESISTANCE: 5000 MEGAOHMS • OPERATING TEMPERATURE: -55C TO +105C UNLESS SPECIFIED OTHERWISE DRAWN PRIMARY UNITS MILLIMETERS CHECKED SECONDARY 6 THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION AND SUCH INFORMATION MAY NOT BE DISCLOSED TO OTHERS FOR ANY PURPOSE OR USED FOR MANUFACTURING PURPOSES WITHOUT WRITTEN PERMISSION FROM AMPHENOL CANADA CORP. A B C D S.CAELERS OCT25/10 K.LAMBIE REFERENCE IN PARENTHESES Q.A. APP'D GENERAL TOLERANCES DWG APPR. ENG. REL. NO. 2 DECIMAL PLACES REF. 3 DECIMAL PLACES THIRD ANGLE PROJECTION E Amphenol Canada Corp. DWR SERIES SLIM DRAWER, 10 SIGNAL SOCKET CONNECTOR, RoHS COMPLIANT 1 DECIMAL PLACE ANGULAR DEGREES OCT25/10 INCHES M.E. APP'D 5 EAR 13783 DWG. NO. REV DO NOT SCALE DRAWING CODE ID NO. F 6 G A P-DWR-T010S-V233-01 03554 DWG SIZE: X SCALE: 5:1 SHEET H 1 OF 2 A B C D E G F H REVISIONS 1 REV DESCRIPTION, ECN, EAR NO. DATE APP'D A NEW PROPOSAL DWG (EAR 13783) OCT25/10 K.L. SLOT & HOLE WILL CLEAR ORIENTATION PEG & MATING PIN HOUSING BLADES. PLATING NOT REQUIRED 1 4.48 .176 R2.06±0.08 .081±.003 10.97 .432 3.85 .152 4.12±0.08 .162±.003 LOCATE HOLES 0.13[.005] DIA POSITION DIMENSIONS ARE BASIC 2 0.83 .033 10 x 3.30 .130 2.74 TYP. .108 1.02±0.05 .040±.002 2 RECOMMENDED PCB LAYOUT COMPONENT SIDE OF BOARD SCALE 4:1 3 3 MATING PIN P/N DWR-T010P-V233-01 4 4 20.58 .810 REF 5 5 SOCKET CONNECTOR P/N DWR-T010S-V233-01 MATED ASSEMBLY SIDE VIEW SCALE 4:1 UNLESS SPECIFIED OTHERWISE DRAWN PRIMARY UNITS MILLIMETERS CHECKED SECONDARY 6 THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION AND SUCH INFORMATION MAY NOT BE DISCLOSED TO OTHERS FOR ANY PURPOSE OR USED FOR MANUFACTURING PURPOSES WITHOUT WRITTEN PERMISSION FROM AMPHENOL CANADA CORP. A B C D S.CAELERS OCT25/10 K.LAMBIE REFERENCE IN PARENTHESES Q.A. APP'D GENERAL TOLERANCES DWG APPR. ENG. REL. NO. 2 DECIMAL PLACES REF. 3 DECIMAL PLACES THIRD ANGLE PROJECTION E Amphenol Canada Corp. DWR SERIES SLIM DRAWER, 10 SIGNAL SOCKET CONNECTOR, RoHS COMPLIANT 1 DECIMAL PLACE ANGULAR DEGREES OCT25/10 INCHES M.E. APP'D EAR 13783 DWG. NO. REV DO NOT SCALE DRAWING CODE ID NO. F 6 G A P-DWR-T010S-V233-01 03554 DWG SIZE: X SCALE: 2:1 SHEET H 2 OF 2
DWR-T010S-V233-01 价格&库存
很抱歉,暂时无法提供与“DWR-T010S-V233-01”相匹配的价格&库存,您可以联系我们找货
