QR/P1-PC1B-221(12)
QR/P1-PC1B-221(12)
    HRS(广濑)
    CONNCRIMPTERMMALE
QR/P1-PC1B-221(12) 数据手册
QR/P1 Series Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Small, Rectangular, High Pin Count, Rack and Panel Crimp Connector Feb. 2022 QR/P1 Series/Small, Rectangular, High Pin Count, Rack and Panel Crimp Connector Overview The QR/ P1 Series is a more compact version of the rectangular, multi- pin count and plug- in connection QR/ P Series for racks and panels, which has been well received in the market. The QR/ P1 Series is a compact rack and panel connector that enables even higher density mounting. Five different pin counts are available: 8, 12, 16, 24, and 32. Wire connection is performed using crimp termination for easier workability and high reliability. Features Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 1. Plug- in Design The plug- in design enables a large effective mating length. 2. Floating bushing enables a floating design. 3. UL, CSA, TÜ V certified. Product Specifications Rated Current Rated Voltage Power 13A Max.(When using 14 AWG) Signal 3A Power 250V AC Signal 125V AC Item Operating Temperature Specifications -10 to +60℃ Conditions Contact Resistance Power Contact : 10m Ω Max. Signal Contact : 15m Ω Max. Measured at 1A DC Insulation Resistance 5000M Ω Min. Measured at 500V DC Withstanding Voltage No flashover or insulation breakdown Power : 1000V AC for 1 min. Signal : 500V AC for 1 min. Safety Standard UL CSA Operating Temperature Rated Voltage TÜV -10 to +60℃ Power Signal 14 AWG 16 AWG 120V AC 250V AC 10A 3A 125V AC 10A 8A 250V AC 3A 18 AWG 125V AC, 150V DC 10A 5A 20 AWG Rated Current 250V AC, 300V DC 3A 1A 3A 1A Power 2A 1A 2A 1A Signal 1A 0.5A 1A 0.5A 1A 0.5A 1A 0.5A 2.5A 22 AWG 24 AWG 26 AWG 28 AWG 2 1A - QR/P1 Series/Small, Rectangular, High Pin Count, Rack and Panel Crimp Connector Material / Finish Item Material Color/Finish Remarks Insulator PBT Black UL94V-0 Contact Phosphor Bronze Partial Gold Plating (Nickel Underplating) - Product Number Structure Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. Connector Unit QR/P1 - 12 P - C (21) ❶ ❷ ❸ ❹  Contact QR/P1 - PC 1 A - 1 1 1 ❶ ❺ ❻ ❼ ❽ ❾  ❶ Series Name QR/P1 ❼ Size of Barrel A : For Thin Cable B : For Thick Cable ❷ No. of Pos. 8,12,16,24,32pos. ❽ Contact Type 1 : Loose Piece Contact 2 : Reel Contact ❸ Insulator Gender P : Male Insulation Case S : Female Insulation Case ❾ Applicable Cable ❹ Contact Connection Method C : Crimp Connection ❺ Terminal Shape Symbol PC : Male Crimp Contact SC : Female Crimp Contact  Surface Treatment 1 : Partial Gold Plating (Nickel Underplating) ❻ Contact Type 1 : Power Contact 2 : Signal Contact  Specification (21) : UL, CSA, TÜV 3 (Power Contact) 1 : 18 to 24 AWG 2 : 14 to 16 AWG (Signal Contact) 1 : 24 to 28 AWG 2 : 20 to 24 AWG QR/P1 Series/Small, Rectangular, High Pin Count, Rack and Panel Crimp Connector Housing Male Housing A 4.5 18.5 4.5 θ C B 16.5 14 5 5 1 Unit : mm Part No. HRS No. No. of Pos. A B C θ QR/P1-8P-C(21) CL0221-0124-0-21 8 46.4 36.9 3.0 13.4° QR/P1-12P-C(21) CL0221-0100-2-21 12 51.0 42.0 3.0 12.1° QR/P1-16P-C(21) CL0221-0110-6-21 16 57.6 48.1 3.0 10.6° QR/P1-24P-C(21) CL0221-0112-1-21 24 68.8 59.3 3.0 8.6° QR/P1-32P-C(21) CL0221-0131-6-21 32 85.5 76.0 4.2 6.0° Purchase Unit 50pcs per bag 30pcs per bag Note : When attaching to the panel, make sure that the mated clearance dimensions on the male and females sides are 1.5mm or less. Female Housing A 2-φC 18.5 4.5 B 7.3 14.5 5 Floating Bushing (Floats 0.4mm Max. in Respect to Center) 7 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. φC Unit : mm Part No. HRS No. No. of Pos. A B C QR/P1-8S-C(21) CL0221-0125-3-21 8 46.4 36.9 4.3 QR/P1-12S-C(21) CL0221-0101-5-21 12 51.0 42.0 3.3 QR/P1-16S-C(21) CL0221-0111-9-21 16 57.6 48.1 4.3 QR/P1-24S-C(21) CL0221-0113-4-21 24 68.8 59.3 4.3 QR/P1-32S-C(21) CL0221-0132-9-21 32 85.5 76.0 4.3 Note : When attaching to the panel, make sure that the mated clearance dimensions on the male and females sides are 1.5mm or less. 4 Purchase Unit 50pcs per bag 30pcs per bag QR/P1 Series/Small, Rectangular, High Pin Count, Rack and Panel Crimp Connector Contact Male Power Contact QR/P1-PC1A-211(12) Part No. HRS No. QR/P1-PC1B-121(12) CL0221-0114-7-12 QR/P1-PC1B-221(12) CL0221-0118-8-12 QR/P1-PC1A-111(12) CL0221-0102-8-12 QR/P1-PC1A-211(12) CL0221-0106-9-12 Applicable Cable 14 to 16 AWG 18 to 24 AWG Type of Packing Purchase Unit Loose 100pcs per bag Reel 3,000pcs per reel Loose 100pcs per bag Reel 5,000pcs per reel Type of Packing Purchase Unit Loose 100pcs per bag Reel 3,000pcs per reel Loose 100pcs per bag Reel 3,000pcs per reel 3 Female Power Contact 16.5 3.1 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 2.65 3 16.5 QR/P1-SC1A-211(12) Part No. HRS No. QR/P1-SC1B-121(12) CL0221-0116-2-12 QR/P1-SC1B-221(12) CL0221-0120-0-12 QR/P1-SC1A-111(12) CL0221-0104-3-12 QR/P1-SC1A-211(12) CL0221-0108-4-12 Applicable Cable 14 to 16 AWG 18 to 24 AWG 5 QR/P1 Series/Small, Rectangular, High Pin Count, Rack and Panel Crimp Connector Male Signal Contact 2.25 2 15.3 Part No. HRS No. QR/P1-PC2B-121(12) CL0221-0115-0-12 QR/P1-PC2B-221(12) CL0221-0119-0-12 QR/P1-PC2A-111(12) CL0221-0103-0-12 QR/P1-PC2A-211(12) CL0221-0107-1-12 Applicable Cable 20 to 24 AWG 24 to 28 AWG Type of Packing Purchase Unit Loose 100pcs per bag Reel 5,000pcs per reel Loose 100pcs per bag Reel 5,000pcs per reel Type of Packing Purchase Unit Loose 100pcs per bag Reel 5,000pcs per reel Loose 100pcs per bag Reel 5,000pcs per reel 2 Female Signal Contact 15.3 2.7 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. QR/P1-PC2A-211(12) QR/P1-SC2A-211(12) Part No. HRS No. QR/P1-SC2B-121(12) CL0221-0117-5-12 QR/P1-SC2B-221(12) CL0221-0121-2-12 QR/P1-SC2A-111(12) CL0221-0105-6-12 QR/P1-SC2A-211(12) CL0221-0109-7-12 Applicable Cable 20 to 24 AWG 24 to 28 AWG 6 QR/P1 Series/Small, Rectangular, High Pin Count, Rack and Panel Crimp Connector Panel Mounting Dimensions (For Female Housing) Female Housing(QR/P1-#S-C) 18 9 18 4.5 1 E F A B C 2 R2 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. .5 φ R0 R4 φ .5 D G Attachment from Panel Rear Side Attachment from Panel Front Side Unit : mm Type Rear Mount Front Mount 8pos. 12pos. 16pos. 24pos. 32pos. A 36.9 42.0 48.1 59.3 76.0 B 29.4 34.5 40.6 51.8 68.5 C 28.4 33.5 39.6 50.8 67.5 D 4.3 3.3 4.3 4.3 4.3 E 22.4 27.5 33.6 44.8 61.0 F 36.9 42.0 48.1 59.3 76.0 G 4.3 3.3 4.3 4.3 4.3 Note : The panel mounting dimensions of the male housing are symmetrical to the female housing in respect to the vertical axis. Power Contact Arrangement Male Housing (View from the Connection Side) ■ : Contact hole for power supply QR/P1-8P/C(21) 1 2 3 4 5 6 7 8 QR/P1-12P-C(21) 1 2 3 4 5 6 7 8 9 10 11 12 QR/P1-16P-C(21) 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 QR/P1-24P-C(21) 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 QR/P1-32P-C(21) 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 7 QR/P1 Series/Small, Rectangular, High Pin Count, Rack and Panel Crimp Connector Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Tools Manual Crimp Tool Type Manual Crimp Tool Automatic Crimp Tool Applicator Extraction Tool Automatic Crimp Tool CM-105C Part No. HRS No. Applicable Contact TC-QR/P1-PC1B CL0250-0020-0-00 QR/P1-PC1B-121 TC-QR/P1-PC1A CL0250-0015-0-00 QR/P1-PC1A-111 TC-QR/P1-SC1B CL0250-0022-6-00 QR/P1-SC1B-121 TC-QR/P1-SC1A CL0250-0017-6-00 QR/P1-SC1A-111 TC-QR/P1-PC2B CL0250-0021-3-00 QR/P1-PC2B-121 TC-QR/P1-PC2A CL0250-0016-3-00 QR/P1-PC2A-111 TC-QR/P1-SC2B CL0250-0023-9-00 QR/P1-SC2B-121 TC-QR/P1-SC2A CL0250-0018-9-00 QR/P1-SC2A-111 AP105-QR/P1-1B-2 CL0901-2529-6-00 QR/P1-PC1B-221 QR/P1-SC1B-221 AP105-QR/P1-2B-2 CL0901-2530-5-00 QR/P1-PC2B-221 QR/P1-SC2B-221 AP105-QR/P1-1A-1 CL0901-2527-0-00 QR/P1-PC1A-211 QR/P1-SC1A-211 AP105-QR/P1-2A-1 CL0901-2528-3-00 QR/P1-PC2A-211 QR/P1-SC2A-211 TC-QR/P1-21 CL0250-0019-1-00 - While Taking into Consideration Specifications mentioned in this catalog are reference values. When considering to order or use this product, please confirm the Drawing and Product Specifications sheets. Use an appropriate cable when using the connector in combination with cables. If considering usage of a non- specified cable, please contact your sales representative. If assembly process is done by jigs & tools which are not identified by Hirose, assurance will not be given. If considering usage for below mentioned applications, please contact your sales representative. In cases where the application will demand a high level of reliability, such as automotive, medical instruments, public infrastructure, aerospace/ defense etc. Hirose must review before assurance of reliability can be given. 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN        https://www.hirose.com ※ The contents of this catalog are current as of date of 2/ 2022. Contents are subject to change without notice for the purpose of improvements. 8
QR/P1-PC1B-221(12)
物料型号: - 该系列提供 8、12、16、24 和 32 针不同针数的连接器型号。
器件简介: - QR/P1 系列是矩形、多针数、插件式连接的 QR/P 系列的更紧凑版本,适用于机架和面板,支持更高密度的安装。
引脚分配: - 提供了不同针数的连接器型号,包括 8 针、12 针、16 针、24 针和 32 针。
参数特性: - 额定电流:电源最大 13A(使用 14 AWG 线缆),信号 3A。 - 额定电压:电源 250V AC,信号 125V AC。 - 工作温度范围:-10 至 +60°C。
功能详解: - 插头设计提供了较大的有效连接长度。 - 浮动衬套支持浮动设计。 - 通过 UL、CSA、TÜV 认证。
应用信息: - 该连接器适用于需要高可靠性的应用,如汽车、医疗设备、公共基础设施、航空航天/国防等。
封装信息: - 绝缘体材料为 PBT,颜色/表面处理为黑色 UL94V-0。 - 接触材料为磷青铜,部分镀金(镍底层)。
产品编号结构: - 提供了如何根据产品编号确定产品规格的图表,并在目录中列出了产品编号供订购时选择。
安装尺寸: - 为女性外壳提供了面板安装尺寸,包括从面板后侧和前侧的安装细节。
工具: - 提供了手动压接工具和自动压接工具的型号和适用接触件。
注意事项: - 目录中提到的规格是参考值。在订购或使用产品前,请确认图纸和产品规格表。 - 使用连接器时,请使用适当的电缆。 - 如果使用非指定电缆,请与销售代表联系。 - 如果使用非广濑公司确认的夹具和工具进行组装,将不提供保证。 - 对于高可靠性要求的应用,如汽车、医疗设备、公共基础设施、航空航天/国防等,广濑公司必须在保证可靠性之前进行审查。
QR/P1-PC1B-221(12) 价格&库存
很抱歉,暂时无法提供与“QR/P1-PC1B-221(12)”相匹配的价格&库存,您可以联系我们找货
QR/P1-PC1B-221(12)
  • 3000+4.548003000+0.56420
  • 6000+4.396406000+0.54540
  • 9000+4.163209000+0.51650
  • 24000+4.0699024000+0.50490
