RE96FW
RE96FW
    VECTOR
    CONN 96PIN DIN FEMALE WIRE-WRAP
RE96FW 数据手册
CATALOG 128_CATALOG 128.qxd 4/25/2014 2:18 PM Page 71 PCB Accessories 96-Pin DIN Connectors Style 2 Style 1 Style 5 RE96FABG For automatic daisy chaining of VME and VXI backplanes. Eliminates the need for manual jumpering. Pin entry acts like a switch which is activated and closed during insertion. No other moving parts required. Same MTBF as other types. Requires special EPT installation tooling. 96-Pin DIN Connectors Specifications: Class 2 (DIN 41612) Insulating Material: Contact Material: Contact Plating:* Contact Tail: Current Rating: Operating Voltage: Test Voltage: Contact Resistance: Insulator Resistance: Temperature Range: Insertion Force: Insertion Cycles: Glass-Filled Polycarbonate or polyesther sulphone Copper Alloy .000010” gold over .000050” nickel Ni/Gold .000010” 2.5A at 20oC; 1A at 70oC 300V AC 1000V AC 30 m Ohms max. @ 100mA DC 1000M Ohms min. @ 500 VDC -55oC to + 125oC
RE96FW 价格&库存
很抱歉,暂时无法提供与“RE96FW”相匹配的价格&库存,您可以联系我们找货
