PCN10C-64ACS-2.54DSA(72)
    HRS(广濑)
    CONNDINRCPT64POS
PCN10C-64ACS-2.54DSA(72) 数据手册
Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. PCN10 Series IEC603-2 / DIN41612 Standard Compliant Products Jul.2022 PCN10 Series/IEC603-2 / DIN41612 Standard Compliant Products Features 1. Complies with DIN Standard Complies with IEC603- 2/ DIN41612 standard. 2. Number of Positions Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 14 pin variations available : 16, 20, 24, 30, 32, 44, 48, 50, 64, 90, 96, 100, 128, and 144 3. Two- point Contact Design Double-sided Two-point Contact System Highly reliable double- sided two point contacts. Two- point Contact Design 4. Wide Applications DIN standard types of B, C, R, and Q are available. The easy lock pin type for temporary board installation is available. 5. Stacking Height Variation The PCN10H Series includes 5 stacking height variations : 25, 30, 35, 40 and 45mm. Stacking Connector 2 PCN10 Series/IEC603-2 / DIN41612 Standard Compliant Products 6. Circuit Protection The PCN10MC Series has a sequence design for circuit protection. 7. Cable Connector Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. IDC connectors for ribbon cable are available. Crimp connectors compatible with 26- 30 AWG are also available. Applications Computers, Control Equipment, Switches, Measuring Devices, etc. 3 PCN10 Series/IEC603-2 / DIN41612 Standard Compliant Products Product Specifications Rated Current 2A Operating Temperature (Note 1) -55 to +85℃ Rated Voltage 300V AC Operating Humidity Range 85% Max. Storage Temperature (Note 2) -10 to +60℃ Storage Humidity Range (Note 2) 40 to 70% Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Item Specification Condition Insulation Resistance 106M Ω Min. Measured at 100V DC Withstanding Voltage No flashover or insulation breakdown. 1000V AC for 1 min. (IDC, Crimp Type : 650V AC) Contact Resistance 20m Ω Max. Measured at 0.1A Vibration Resistance No electrical discontinuity of 10μ s Min. Frequency : 10 to 55 Hz, single amplitude of 0.75 mm, 2 hours in each of the 3 directions. Humidity (Steady State) Insulation resistance : 106M Ω Min. 96 hours at temperature of 40 ± 2℃ and humidity of 90% to 95% Temperature Cycle No damage, cracks, or parts looseness. (-65℃ : 30 minutes → 15 to 35℃ : 5 minutes Max. → 125℃ : 30 minutes → 15 to 35℃ : 5 minutes Max.) 5 times Mating Durability Contact resistance : 20m Ω Max. 500 times Soldering Heat Resistance No deformation of components affecting performance. Manual soldering : 350℃ for 3 seconds Note 1 : Includes the temperature rise due to current flow. Note 2 : The term "storage" refers to products stored for long period of time prior to mounting and use. The operating temperature and humidity range applies to the non-energized state after board mounting and temporary storage during transportation. Material / Finish Component Material Insulator Contact Color/Finish Remarks PBT Gray UL94V-0 Pin Header Brass Receptacle Copper Alloy Contact Area: Nickel Underplated+Gold Plated Remaining Areas: Nickel Underplated+Tin Plated - 4 PCN10 Series/IEC603-2 / DIN41612 Standard Compliant Products Product Number Structure ■ PCN10 Series Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. PCN10 A - # P - 2.54 DS Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ❶ ❷ ❸ ❹ ❺ ❻ ❶ Series Name PCN10 ❷ Configuration Blank : Mold Type (as listed below) A : Mold Type (as listed below) B : Mold Type (as listed below) C : 2-row Type EA : 2-row Type (With Lock Pin for Temporary Board Installation) H : 35mm Stacking Height HA : 30mm Stacking Height HB : 25mm Stacking Height HC : 45mm Stacking Height HD : 40mm Stacking Height MC : With Circuit Protection PCN10 (Note) PCN10B ❸ No. of Pos. 2-row : 16,20,24,32,44,50,64,90,100 3-row : 48,96,144 4-row : 128 ❹ Connector Type P : Pin Header S : Receptacle ❺ Contact Pitch 2.54mm ❻ Contact Type DS : Right Angle Through Hole Type DSA : Straight Through Hole Type WA : Wrapping Type (0.5tx0.7W) WB : Wrapping Type (0.5tx0.5W) C : Crimp Type PCN10A PCN10EA PCB Note : However the right angle 2-row receptacle type is PCN10A. 5 PCN10 Series/IEC603-2 / DIN41612 Standard Compliant Products Combination Pin Header Receptacle ●Straight Through Hole Type ●Straight Through Hole Type PCN10-##P-2.54DSA PCN10-##S-2.54DSA PCN10C-##S-2.54DSA PCN10EA-##S-2.54DSA PCN12-##S-2.54DSA PCN12E-##S-2.54DSA PCN13-##S-2.54DSA ●Stacking Through Hole Type Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. PCN10H#-##P-2.54DSA ●Wrapping Type PCN10-##S-2.54W# *Does not mate with PCN10EA-##S-2.54DSA. ●Right Angle Through Hole Type (Mounted on Board Edge) ●Right Angle Through Hole Type (Mounted On The Board Edge) PCN10-##P-2.54DS PCN12-##P-2.54DS PCN12E-##P-2.54DS PCN10B-##S-2.54DS ●Right Angle Through Hole Type (Board Mounted) ●Right Angle Through Hole Type (Mounted On The Board) PCN10A-##P-2.54DS PCN10EA-##P-2.54DS PCN12A-##P-2.54DS PCN12EA-##P-2.54DS PCN10A-##S-2.54DS PCN10C-##S-2.54DS PCN13-##S-2.54DS ●Cable Type PCN10-##S-2.54C + PCN10-####SC# PCN10-##S-2.54R 6 PCN10 Series/IEC603-2 / DIN41612 Standard Compliant Products ■Circuit Protection Type Pin Header Receptacle ●Straight Through Hole Type PCN10MC#-##S-2.54DSA ●Right Angle Through Hole Type PCN10MC#-##P-2.54DS ●Wrapping Type Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. PCN10MC#-##S-2.54W# 7 PCN10 Series/IEC603-2 / DIN41612 Standard Compliant Products Contact Numbers For the mating of DIN Standard type C (Type B) and Type R (Type Q), the contact numbers are No.1-32 and the rows are a, b, and c. ●DIN standard type C and type R represent the 3-row 96 contacts type, including 32 contacts in single-row. ●DIN standard type B and type Q represent the 2-row 64 contacts type, including 32 contacts in single-row. 1. Receptacle Straight Type 2. Pin Header Right Angle Type Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Type C (Type B) Type C (Type B) Row c Row b Row a n← 2・1 Row c Row b Row a n← 2・1 Contact No. Matching Contact No. Inverted Contact No. Inverted Row c Row b Row a n← 2・1 Row c Row b Row a n← 2・1 Contact No. Matching 3. Pin Header Straight Type 4. Receptacle Right Angle Type Type R (Type Q) Type R (Type Q) Note : DIN connectors are standardized based on a combination of straight and right angle types. In the above figure, the contact no. of combination 1-2, 3-4 match, but the contact no. of combination 1-3, 2-4 are inverted. 8 PCN10 Series/IEC603-2 / DIN41612 Standard Compliant Products Pin Header : 2-row Right Angle Type (DIN Standard Type B) A B C 2.54 2.54 10.1 6.4 5.6 7.1 5.5 1.5 2-φ2.6 0.5×0.5 D 1.65 2.9 6.0 2.54±0.1 φ0.8 +0.1 0 φ2.8 +0.1 0 a 5.3±0.1 2.54±0.1 PCB Mounting Pattern b Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 8.6 2.54 2.54±0.1 C±0.1 D±0.1 Unit : mm Part No. HRS No. No. of Pos. A B C D PCN10-16P-2.54DS(72) CL0583-0230-9-72 16 33.04 24.39 17.78 27.94 PCN10-20P-2.54DS(72) CL0583-0077-3-72 20 38.12 29.47 22.86 33.02 PCN10-32P-2.54DS(72) CL0583-0015-6-72 32 53.36 44.71 38.10 48.26 PCN10-44P-2.54DS(72) CL0583-0038-1-72 44 68.60 59.95 53.34 63.50 PCN10-50P-2.54DS(72) CL0583-0016-9-72 50 76.22 67.57 60.96 71.12 PCN10-64P-2.54DS(72) CL0583-0017-1-72 64 94.00 85.35 78.74 88.90 PCN10-90P-2.54DS(72) CL0583-0018-4-72 90 127.02 118.37 111.76 121.92 PCN10-100P-2.54DS(72) CL0583-0113-5-72 100 139.72 131.07 124.46 134.62 9 RoHS Purchase Unit 40pcs per tray Yes 20pcs per tray 10pcs per tray PCN10 Series/IEC603-2 / DIN41612 Standard Compliant Products Pin Header : 2-row Right Angle Type A B C 2.54 2.54 10.1 6.4 1.5 2-φ2.6 0.5×0.5 D 2.9 (A Type) 7.65 2.54±0.1 φ0.8 +0.1 0 φ2.8 +0.1 0 a 12.6±0.1 2.54±0.1 PCB Mounting Pattern b Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 5.6 7.1 5.5 8.6 2.54 2.54±0.1 C±0.1 D±0.1 Unit : mm Part No. HRS No. No. of Pos. A B C D PCN10A-16P-2.54DS(72) CL0583-0231-1-72 16 33.04 24.39 17.78 27.94 PCN10A-20P-2.54DS(72) CL0583-0078-6-72 20 38.12 29.47 22.86 33.02 PCN10A-32P-2.54DS(72) CL0583-0011-5-72 32 53.36 44.71 38.10 48.26 PCN10A-44P-2.54DS(72) CL0583-0039-4-72 44 68.60 59.95 53.34 63.50 PCN10A-50P-2.54DS(72) CL0583-0012-8-72 50 76.22 67.57 60.96 71.12 PCN10A-64P-2.54DS(72) CL0583-0013-0-72 64 94.00 85.35 78.74 88.90 PCN10A-90P-2.54DS(72) CL0583-0014-3-72 90 127.02 118.37 111.76 121.92 PCN10A-100P-2.54DS(72) CL0583-0114-8-72 100 139.72 131.07 124.46 134.62 10 RoHS Purchase Unit 40pcs per tray Yes 20pcs per tray 10pcs per tray PCN10 Series/IEC603-2 / DIN41612 Standard Compliant Products Pin Header : 2-row Right Angle Type ● With Lock Pin for Temporary Board Installation A B C 2.0 2.54 2.54 10.1 6.4 6.2 5.5 7.1 6.1 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 8.6 2.54 2.54 3.0 0.5×0.5 D 2.9 ●The PCB mounting pattern is equivalent to PCN10A-#P-2.54DS(72). Unit : mm Part No. HRS No. No. of Pos. A B C D PCN10EA-16P-2.54DS(72) CL0583-0256-2-72 16 33.04 24.39 17.78 27.94 PCN10EA-20P-2.54DS(72) CL0583-0181-5-72 20 38.12 29.47 22.86 33.02 PCN10EA-32P-2.54DS(72) CL0583-0182-8-72 32 53.36 44.71 38.10 48.26 PCN10EA-44P-2.54DS(72) CL0583-0183-0-72 44 68.60 59.95 53.34 63.50 PCN10EA-50P-2.54DS(72) CL0583-0184-3-72 50 76.22 67.57 60.96 71.12 PCN10EA-64P-2.54DS(72) CL0583-0185-6-72 64 94.00 85.35 78.74 88.90 PCN10EA-90P-2.54DS(72) CL0583-0186-9-72 90 127.02 118.37 111.76 121.92 PCN10EA-100P-2.54DS(72) CL0583-0187-1-72 100 139.72 131.07 124.46 134.62 11 RoHS Purchase Unit 40pcs per tray Yes 20pcs per tray 10pcs per tray PCN10 Series/IEC603-2 / DIN41612 Standard Compliant Products Pin Header : 2-row Straight Type A B C D 8.6 2.54 6.4 5.2 6.4 3.2 11.6 2.54 0.5×0.5 *Type Q differs in the outer dimensions and PCB mounting pattern. φ2.8 +0.1 0 2.54±0.1 PCB Mounting Pattern φ0.8 +0.1 0 b a Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 2-φ2.6 2.54±0.1 D±0.1 B±0.1 Unit : mm Part No. HRS No. No. of Pos. A B C D RoHS Purchase Unit PCN10-20P-2.54DSA(72) CL0583-0139-9-72 20 43.30 38.10 29.47 22.86 45pcs per tray PCN10-32P-2.54DSA(72) CL0583-0007-8-72 32 58.54 53.34 44.71 38.10 30pcs per tray PCN10-44P-2.54DSA(72) CL0583-0488-8-72 44 73.78 68.58 59.95 53.54 PCN10-50P-2.54DSA(72) CL0583-0008-0-72 50 81.40 76.20 67.57 60.96 PCN10-64P-2.54DSA(72) CL0583-0009-3-72 64 99.18 93.98 85.35 78.74 PCN10-90P-2.54DSA(72) CL0583-0010-2-72 90 132.20 127.00 118.37 111.76 PCN10-100P-2.54DSA(72) CL0583-0251-9-72 100 144.90 139.70 131.07 124.46 12 Yes 15pcs per tray PCN10 Series/IEC603-2 / DIN41612 Standard Compliant Products Receptacle : 2-row Right Angle Type A B C 2.54 R1.3 0.3t×0.7w 2.9 *Type Q differs in the external size and PCB mounting pattern. 6.3±0.1 2.54±0.1 PCB Mounting Pattern D±0.1 C±0.1 φ0.8 +0.1 0 2.54±0.1 2-φ2.8 +0.1 0 2.54±0.1 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. D 2.54 3.88 3.82 8.9 6.3 8.1 6.0 2.9 2.54 Unit : mm Part No. HRS No. No. of Pos. A B C D PCN10C-20S-2.54DS(72) CL0583-0201-0-72 20 43.10 29.12 22.86 38.10 PCN10C-32S-2.54DS(72) CL0583-0202-3-72 32 58.34 44.36 38.10 53.34 PCN10C-44S-2.54DS(72) CL0583-0052-2-72 44 73.58 59.60 53.34 68.58 PCN10C-50S-2.54DS(72) CL0583-0168-7-72 50 81.20 67.22 60.96 76.20 PCN10C-64S-2.54DS(72) CL0583-0203-6-72 64 98.98 85.00 78.74 93.98 PCN10C-90S-2.54DS(72) CL0583-0204-9-72 90 132.00 118.02 111.76 127.00 PCN10C-100S-2.54DS(72) CL0583-0178-0-72 100 144.70 130.72 124.46 139.70 Note : DIN standard type Q (Reverse type of type B) is PCN10B-64S-2.54DS(72). 13 RoHS Purchase Unit 33pcs per tray 22pcs per tray Yes 11pcs per tray PCN10 Series/IEC603-2 / DIN41612 Standard Compliant Products Receptacle : 2-row Straight Type (DIN Standard Type B) C D 2-φ2.8 8.1 0.3 2.54 3.2 5.2 6.3 3.9 11.5 0.25t×0.7w 2.54 φ0.8 +0.1 0 0.3 φ2.8 +0.1 0 2.54±0.1 PCB Mounting Pattern 2.54±0.1 D±0.1 B±0.1 a b Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. B A Unit : mm Part No. HRS No. No. of Pos. A B C D PCN10-32S-2.54DSA(72) CL0583-0019-7-72 32 54.36 49.36 44.36 38.10 PCN10-50S-2.54DSA(72) CL0583-0020-6-72 50 77.22 72.22 67.22 60.96 PCN10-64S-2.54DSA(72) CL0583-0021-9-72 64 95.00 90.00 85.00 78.74 14 RoHS Purchase Unit 50pcs per tray Yes 30pcs per tray PCN10 Series/IEC603-2 / DIN41612 Standard Compliant Products Receptacle : 2-row Wrapping Type (DIN Standard Type B) C D 2-φ2.8 8.1 0.3 2.54 3.2 13.0 WA : 0.5t×0.7w WB : 0.5t×0.5w 2.54 (Note) φ0.8 +0.1 0 0.3 φ2.8 +0.1 0 2.54±0.1 PCB Mounting Pattern 2.54±0.1 D±0.1 B±0.1 a b Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 11.5 5.2 6.3 B A Note : WA type is φ1.0 +0.1 0 Unit : mm Part No. HRS No. No. of Pos. A B C D PCN10-32S-2.54WA(72) CL0583-0107-2-72 32 54.36 49.36 44.36 38.10 PCN10-50S-2.54WB(72) CL0583-0068-2-72 50 77.22 72.22 67.22 60.96 PCN10-64S-2.54WA(72) CL0583-0109-8-72 64 95.00 90.00 85.00 78.74 15 RoHS Purchase Unit Yes 26pcs per tray PCN10 Series/IEC603-2 / DIN41612 Standard Compliant Products Receptacle : 2-row Straight Type (DIN Standard Type B) C D 2-φ2.8 8.1 0.3 2.54 3.2 3.9 11.5 5.2 6.3 0.25t×0.7w 2.54 φ0.8 +0.1 0 0.3 φ2.8 +0.1 0 2.54±0.1 PCB Mounting Pattern a b Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. B A 2.54±0.1 D±0.1 B±0.1 Unit : mm Part No. HRS No. No. of Pos. A B C D PCN10C-16S-2.54DSA(52) CL0583-0226-1-52 16 34.04 29.04 24.04 17.78 80pcs per tray PCN10C-20S-2.54DSA(52) CL0583-0079-9-52 20 39.12 34.12 29.12 22.86 70pcs per tray PCN10C-32S-2.54DSA(52) CL0583-0033-8-52 32 54.36 49.36 44.36 38.10 50pcs per tray PCN10C-44S-2.54DSA(52) CL0583-0034-0-52 44 69.60 64.60 59.60 53.34 PCN10C-50S-2.54DSA(52) CL0583-0035-3-52 50 77.22 72.22 67.22 60.96 PCN10C-64S-2.54DSA(52) CL0583-0036-6-52 64 95.00 90.00 85.00 78.74 PCN10C-90S-2.54DSA(52) CL0583-0037-9-52 90 128.02 123.02 118.02 111.76 PCN10C-100S-2.54DSA(52) CL0583-0112-2-52 100 140.72 135.72 130.72 124.46 16 RoHS Yes Purchase Unit 40pcs per tray 30pcs per tray 20pcs per tray PCN10 Series/IEC603-2 / DIN41612 Standard Compliant Products Receptacle : 2-row Straight Type (DIN Standard Type B) ● With Lock Pin for Temporary Board Installation A B C 0.3 5.2 3.0 5.2 6.3 6.0 11.5 3.9 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 8.1 2.54 D 2.54 0.25t×0.7w 2.54 ●The PCB mounting pattern is equivalent to PCN10-#S-2.54DSA(72) and PCN10C-#S-2.54DSA(52).  Unit : mm Part No. HRS No. No. of Pos. A B C D PCN10EA-20S-2.54DSA(52) CL0583-0188-4-52 20 39.12 34.12 29.12 22.86 70pcs per tray PCN10EA-32S-2.54DSA(52) CL0583-0189-7-52 32 54.36 49.36 44.36 38.10 50pcs per tray PCN10EA-44S-2.54DSA(52) CL0583-0190-6-52 44 69.60 64.60 59.60 53.34 40pcs per tray PCN10EA-50S-2.54DSA(52) CL0583-0191-9-52 50 77.22 72.22 67.22 60.96 PCN10EA-64S-2.54DSA(52) CL0583-0192-1-52 64 95.00 90.00 85.00 78.74 PCN10EA-90S-2.54DSA(52) CL0583-0193-4-52 90 128.02 123.02 118.02 111.76 PCN10EA-100S-2.54DSA(52) CL0583-0194-7-52 100 140.72 135.72 130.72 124.46 17 RoHS Yes Purchase Unit 30pcs per tray 20pcs per tray PCN10 Series/IEC603-2 / DIN41612 Standard Compliant Products Pin Header : 3-row Right Angle Type (DIN Standard Type C) A B C D 11.0 2.54 □0.5 1.5 E 2.54 2.54 2.54 6.4 3.7 12.7 5.6 7.1 5.5 2-φ2.6 6.0 2.9 The 48pos. variation has guide key grooves in 8 locations. 2.54±0.1 φ0.8 +0.1 0 φ2.8 +0.1 0 2.54±0.1 D±0.1 E±0.1 2.54±0.1 12.6±0.1 5.08±0.1 PCB Mounting Pattern c b a Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 1.65 Unit : mm Part No. HRS No. No. of Pos. A B C D E PCN10-48P-2.54DS(72) CL0583-0063-9-72 48 53.36 47.36 44.61 38.10 48.26 PCN10-96P-2.54DS(72) CL0583-0001-1-72 96 94.00 88.00 85.25 78.74 88.90 18 RoHS Yes Purchase Unit 48pcs per tray 24pcs per tray PCN10 Series/IEC603-2 / DIN41612 Standard Compliant Products Pin Header : 3-row Right Angle Type A B C D 11.0 2.54 □0.5 6.0 3.35 2.54 2.54 2.54 6.4 3.7 5.5 12.7 1.5 2-φ2.6 2.9 The 48pos. variation has guide key grooves in 8 locations. 2.54±0.1 φ0.8 +0.1 0 φ2.8 +0.1 0 2.54±0.1 D±0.1 E±0.1 2.54±0.1 12.6±0.1 5.08±0.1 PCB Mounting Pattern c b a Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 1.65 Unit : mm Part No. HRS No. No. of Pos. A B C D E PCN10A-48P-2.54DS(72) CL0583-0064-1-72 48 53.36 47.36 44.61 38.10 48.26 PCN10A-96P-2.54DS(72) CL0583-0006-5-72 96 94.00 88.00 85.25 78.74 88.90 19 RoHS Yes Purchase Unit 48pcs per tray 24pcs per tray PCN10 Series/IEC603-2 / DIN41612 Standard Compliant Products Pin Header : Right Angle Type 94 88 85.25 78.74 11.0 2.54 □0.5 2.54 3.35 5.08 3.7 6.4 1.5 2-φ2.6 88.9 6.0 2.9 φ0.8 +0.1 0 a φ2.8 +0.1 0 2.54±0.1 2.54±0.1 5.3±0.1 5.08±0.1 PCB Mounting Pattern c Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 12.7 4.9 5.6 7.1 5.5 1.65 78.74±0.1 88.9±0.1 Unit : mm Part No. PCN10-64ACP-2.54DS(72) HRS No. CL0583-0046-0-72 20 No. of Pos. RoHS Purchase Unit 64 Yes 24pcs per tray PCN10 Series/IEC603-2 / DIN41612 Standard Compliant Products Pin Header : Right Angle Type 94 88 85.25 78.74 11.0 2.54 □0.5 5.08 2.54 3.7 6.4 1.5 2-φ2.6 3.35 2.9 88.9 φ0.8 +0.1 0 a φ2.8 +0.1 0 2.54±0.1 2.54±0.1 12.6±0.1 5.08±0.1 PCB Mounting Pattern c Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 12.7 4.9 5.6 7.1 5.5 1.65 6.0 78.74±0.1 88.9±0.1 Unit : mm Part No. PCN10A-64ACP-2.54DS(72) HRS No. CL0583-0032-5-72 21 No. of Pos. RoHS Purchase Unit 64 Yes 24pcs per tray PCN10 Series/IEC603-2 / DIN41612 Standard Compliant Products Pin Header : 3-row Straight Type (DIN Standard Type R) 95 90±0.2 88 85.25 78.74±0.15 2-φ2.8 2.9 6.4 3.2 11.6 5.2 6.4 □0.5 2.54 2.54 2.54±0.1 φ0.8 +0.1 0 0.3 φ2.8 +0.1 0 2.54±0.1 78.74±0.1 5.08±0.1 PCB Mounting Pattern c b a Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 8.7 0.3 2.54±0.1 90±0.1 Unit : mm Part No. PCN10-96P-2.54DSA(72) HRS No. CL0583-0002-4-72 22 No. of Pos. RoHS Purchase Unit 96 Yes 24pcs per tray PCN10 Series/IEC603-2 / DIN41612 Standard Compliant Products Pin Header : 3-row Straight Type 58.54 53.34±0.2 8.7 11.0 0.3 47.36 44.61 38.1±0.15 2.54±0.1 6.4 3.9 7.2 5.5 □0.5 2.54 2.54 0.3±0.05 φ0.8 +0.1 0 5.08±0.1 φ2.8 +0.1 0 2.54±0.1 PCB Mounting Pattern c ba Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 2-φ2.6 2.54±0.1 38.1±0.1 53.34±0.1 Unit : mm Part No. PCN10-48P-2.54DSA(72) HRS No. CL0583-0104-4-72 23 No. of Pos. RoHS Purchase Unit 48 Yes 40pcs per tray PCN10 Series/IEC603-2 / DIN41612 Standard Compliant Products Receptacle : 3-row Right Angle Type 3.18 2.54±0.1 φ0.8 +0.1 0 2.54±0.1 5.3±0.15 5.08±0.1 PCB Mounting Pattern c b a Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 2-φ2.5 88.9±0.2 2.54 2.54 2.54 12.5 10.15 6.3 10.26 8.5 2.54±0.1 94 85 78.74±0.15 φ2.8 +0.1 0 2.54±0.1 78.74±0.1 88.9±0.1 Unit : mm Part No. PCN10A-96S-2.54DS(72) HRS No. CL0583-0027-5-72 24 No. of Pos. RoHS Purchase Unit 96 Yes 24pcs per tray PCN10 Series/IEC603-2 / DIN41612 Standard Compliant Products Receptacle : 3-row Right Angle Type (DIN Standard Type R) 94 85 78.74±0.15 2.54±0.1 2.54 2.54 10.15 6.3 2-φ2.5 5.56 3.18±0.5 1.25 2.54 88.9±0.2 2.54±0.1 φ0.8 +0.1 0 φ2.8 +0.1 0 2.54±0.1 2.54±0.1 5.3±0.15 5.08±0.1 PCB Mounting Pattern c b a Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 12.5 10.26 8.5 0.3t×0.7w 78.74±0.1 88.9±0.1 Unit : mm Part No. PCN10B-96S-2.54DS(72) HRS No. CL0583-0004-0-72 25 No. of Pos. RoHS Purchase Unit 96 Yes 24pcs per tray PCN10 Series/IEC603-2 / DIN41612 Standard Compliant Products Receptacle : 3-row Straight Type (DIN Standard Type C) A B C D 5.2 6.3 2.9 8.5 0.3 2.54±0.1 2.54 2.54 2.54 2.54 WA、WB 13.0 11.5 5.2 6.3 2.9 0.25t×0.7w The 48pos. variation has guide key grooves in 8 locations. WA:0.5t×0.7w WB:0.5t×0.5w φ0.8 +0.1 φ2.8 +0.1 0 (Note) 0 0.3 2.54±0.1 D±0.1 B±0.1 5.08±0.1 2.54±0.1 PCB Mounting Pattern a b c Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. DSA 3.9 11.5 10.5 2-φ2.8 Note : WA type is φ1.0 +0.1 0 Unit : mm Part No. HRS No. No. of Pos. A B C D PCN10-48S-2.54DSA(72) CL0583-0065-4-72 48 54.36 50.00 44.36 38.10 PCN10-96S-2.54DSA(72) CL0583-0003-7-72 96 95.00 90.00 85.00 78.74 PCN10-96S-2.54WA(72) CL0583-0085-1-72 96 95.00 90.00 85.00 78.74 PCN10-96S-2.54WB(72) CL0583-0071-7-72 96 95.00 90.00 85.00 78.74 26 RoHS Purchase Unit 20pcs per tray Yes 15pcs per tray PCN10 Series/IEC603-2 / DIN41612 Standard Compliant Products Receptacle : 3-row Straight Type (DIN Standard Type C) ● With Lock Pin for Temporary Board Installation 3.9 11.5 3.0 5.2 6.3 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 10.5 8.5 0.3 2.54±0.1 A B±0.2 C D±0.15 0.25t×0.7w 2.54 2.54 ●The PCB mounting pattern is equivalent to PCN10-#S-2.54DSA(72). Unit : mm Part No. HRS No. No. of Pos. A B C D PCN10EA-48S-2.54DSA(72) CL0583-0195-0-72 48 54.36 50.00 44.36 38.10 PCN10EA-96S-2.54DSA(72) CL0583-0180-2-72 96 95.00 90.00 85.00 78.74 27 RoHS Yes Purchase Unit 30pcs per tray 15pcs per tray PCN10 Series/IEC603-2 / DIN41612 Standard Compliant Products Receptacle : Straight Type 2.54±0.1 5.2 6.3 3.9 11.5 0.25t×0.7w 5.08 φ0.8 +0.1 0 0.3 c 2.54±0.1 78.74±0.1 90±0.1 5.08±0.1 φ2.8 +0.1 0 2.54±0.1 PCB Mounting Pattern a Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 0.3 10.5 8.5 2-φ2.8 95 90±0.2 85 78.74±0.15 Unit : mm Part No. PCN10-64ACS-2.54DSA(72) HRS No. CL0583-0044-4-72 28 No. of Pos. RoHS Purchase Unit 64 Yes 15pcs per tray PCN10 Series/IEC603-2 / DIN41612 Standard Compliant Products Pin Header : 3-row Right Angle Type 144pos. ● With Lock Pin for Temporary Board Installation 11.6 2.54 11.1 0.5×0.5 2.54 2.54 129.54±0.2 3.78 2.54±0.1 φ0.9 +0.1 0 2.54±0.1 13.6±0.1 5.08±0.1 PCB Mounting Pattern cba Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 1.5 5.5 3.0 15.0 9.7 2.54±0.1 137 130.64 125.94 +0.3 0 119.38±0.15 φ3.3 +0.1 0 2.54±0.1 119.38±0.1 129.38±0.1 Unit : mm Part No. PCN10MA-144P-2.54DS(72) HRS No. CL0583-0131-7-72 29 No. of Pos. RoHS Purchase Unit 144 Yes 20pcs per tray PCN10 Series/IEC603-2 / DIN41612 Standard Compliant Products Receptacle : 3-row Straight Type 144pos. ● With Lock Pin for Temporary Board Installation 3.4 12.74 3.0 5.24 7.5 126 2.54 1.79 2.54 0.75 Sequential contacts in rows a, b and c are located at 27 points between contact no.30-38. φ0.9 +0.1 0 φ3.3 +0.1 0 2.54±0.1 2.54±0.1 5.08±0.1 PCB Mounting Pattern 0.75±0.05 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 14.5 9.5 2.54±0.1 140 134.8±0.15 131.4 125.64 119.38±0.15 119.38±0.1 134.8±0.1 Unit : mm Part No. PCN10MA-144S-2.54DSA(72) HRS No. CL0583-0130-4-72 30 No. of Pos. RoHS Purchase Unit 144 Yes 20pcs per tray PCN10 Series/IEC603-2 / DIN41612 Standard Compliant Products Pin Header : 4-row Right Angle Type 13.54 11.24 2.54±0.1 93.6 88 85.25 78.74±0.15 2.54 1.5 88.9±0.2 2.54 2.54 2.54 3.7 6.4 PCN10 2-φ2.6 1.65 4.55 6.0 5.89 PCB Mounting Pattern φ0.8 +0.1 0 d c b a φ2.8 +0.1 0 5.3±0.1 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 5.6 7.1 5.5 0.5×0.5 2.54±0.1 2.54±0.1 2.54±0.1 2.54±0.1 2.54±0.05 78.74±0.1 88.9±0.1 Unit : mm Part No. PCN10-128P-2.54DS(72) HRS No. CL0583-0087-7-72 31 No. of Pos. RoHS Purchase Unit 128 Yes 12pcs per tray PCN10 Series/IEC603-2 / DIN41612 Standard Compliant Products Pin Header : 4-row Right Angle Type 93.6 88 85.25 78.74 11.24 13.54 2.54±0.1 0.5×0.5 2.9 2.9 5.89 1.65 PCB Mounting Pattern φ0.8 +0.1 0 d c b a φ2.8 +0.1 0 12.6±0.1 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 1.5 2-φ2.6 88.9±0.2 2.54 2.54 2.54 5.6 7.1 3.7 6.4 5.5 PCN10A 2.54±0.1 2.54±0.1 2.54±0.1 2.54±0.1 2.54±0.05 78.74±0.05 88.9±0.1 Unit : mm Part No. PCN10A-128P-2.54DS(72) HRS No. CL0583-0088-0-72 32 No. of Pos. RoHS Purchase Unit 128 Yes 12pcs per tray PCN10 Series/IEC603-2 / DIN41612 Standard Compliant Products Pin Header : 4-row Straight Type 95 90±0.2 85.25 78.74±0.15 11.24 0.3 2.54±0.1 2.9 6.4 3.2 0.5×0.5 2.54 2.54 2.54 2.54±0.1 2.54±0.1 φ0.8 +0.1 0 2.54±0.1 φ2.8 +0.1 0 78.74±0.1 90.0±0.1 2.54±0.1 PCB Mounting Pattern 0.3±0.05 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 11.6 5.2 6.4 13.54 2-φ2.8 Unit : mm Part No. PCN10-128P-2.54DSA(72) HRS No. CL0583-0215-5-72 33 No. of Pos. RoHS Purchase Unit 128 Yes 15pcs per tray PCN10 Series/IEC603-2 / DIN41612 Standard Compliant Products Receptacle : 4-row Straight Type 93.6 90±0.2 85 R1.4 78.74±0.15 11.04 13.04 2.54±0.1 13.0 WA、 WB DSA 0.25t×0.7w WA 0.5t×0.7w 2.54 2.54 WB □0.5×0.5 2.54 2.54 3.9 11.5 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 5.2 6.3 DSA 2.54 2.54 PCB Mounting Pattern φ2.8 +0.1 0 φ0.8 +0.1 0 (Note) 2.54±0.05 78.74±0.1 90±0.1 Note : WA is φ1 +0.1 0 Unit : mm Part No. HRS No. No. of Pos. PCN10-128S-2.54DSA(72) CL0583-0089-2-72 128 PCN10-128S-2.54WA(72) CL0583-0090-1-72 128 PCN10-128S-2.54WB(72) CL0583-0091-4-72 128 34 RoHS Purchase Unit 12pcs per tray Yes 16pcs per tray PCN10 Series/IEC603-2 / DIN41612 Standard Compliant Products Receptacle : 4-row Right Angle Type 94 85 2.54 2.54 2.54 4.5 5.56 88.9±0.2 4 1.25 3.18 2.54 22.26 12.5 7.62 10.15 .6 2-φ2 .6 2 2-φ 0.3t×0.7w 2.54±0.05 2.54±0.05 2.54±0.05 PCB Mounting Pattern φ 2.54±0.05 5.3±0.1 2.54±0.05 .1 +0 0 8 0. dcba Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 6.3 12.8 11.04 2.54±0.1 78.74±0.15 +0.1 0 4-φ2.8 78.74±0.1 88.9±0.1 Unit : mm Part No. PCN10B-128S-2.54DS(72) HRS No. CL0583-0333-1-72 35 No. of Pos. RoHS Purchase Unit 128 Yes 12pcs per tray PCN10 Series/IEC603-2 / DIN41612 Standard Compliant Products Polarity Key Use of the polarity key prevents connector misinsertion. Insert the polarity key into both the receptacle side and pin header side. Insert the polarity key far enough so that it makes contact with the bottom of the mold. PCN10-GK(A) 28.4 0.7 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 4.5 4.2 3.7 Part No. PCN10-GK(A) HRS No. CL0583-0269-4-00 Material Color RoHS Purchase Unit PBT Black Yes 100pcs per bag (The above diagram include 4 polarity keys.) Crimping Connector Compliant with DIN Standard Ratings Rated Current Crimping IDC 26 AWG 28, 30 AWG 2A 1A Rated Voltage 300V AC 36 1A 200V AC PCN10 Series/IEC603-2 / DIN41612 Standard Compliant Products ● 3-row Type 2-φ2.8 95 90 85 78.74 2.9 Unit : mm Part No. PCN10-96S-2.54C ● 2-row HRS No. No. of Pos. RoHS Purchase Unit 96 Yes 10pcs per bag CL0583-0100-3-00 Type A B±0.2 C D±0.15 8.1 6.0 0.3 2.54±0.1 2-φ2.8 15.2 5.2 6.3 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 15.2 5.2 6.3 10.5 8.5 0.3 P=2.54 Unit : mm Part No. HRS No. No. of Pos. A B C D PCN10-20S-2.54C CL0583-0241-5-00 20 39.12 34.12 29.12 22.86 PCN10-64S-2.54C CL0583-0243-0-00 64 95.00 90.00 85.00 78.74 37 RoHS Purchase Unit Yes 10pcs per bag PCN10 Series/IEC603-2 / DIN41612 Standard Compliant Products Applicable Crimping Tool ● Manual Crimping Tool Crimp Contact Crimping Tool ●PCN10-2630SC (Fully Gold Plated) ●PCN10-TA2630HC (PCN10-2630SC)  CL0583-0102-9-00(RoHS Compliant)  CL0550-0163-2-00 【Purchase Unit】100pcs per bag ●PCN10-TA2226HC (PCN10-2226SC) ●PCN10-2226SC (Partially Gold Plated)  CL0550-0218-2-00  CL0583-0216-8-00(RoHS Compliant) 【Purchase Unit】100pcs per bag 13.2 2.8 (4.9) 1.85 5.5 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 1.85 Applicable Cable ●PCN10-2630SC : 26-30 AWG ●PCN10-2226SC : 22-26 AWG ● Automatic Crimping Tool Item Part Number Crimping Machine Body Applicator ● Contact HRS.No. Applicable Contact CM-105C CL0901-0001-0-00 - AP105-PCN10-2226S CL0901-3506-6-00 PCN10-2226SCF AP105-PCN10-2630S CL0901-3508-1-00 PCN10-2630SCF Extraction Tool Part No. HRS.No. PCN10-PO CL0550-0282-1-00 38 PCN10 Series/IEC603-2 / DIN41612 Standard Compliant Products Circuit Protection Type ● Features 2. The exterior is black to distinguish it from the other PCN10 Series. ( PCN10MC cannot be mated with other series. ) ● Pin Header : 3-row Right Angle Type 94 88 85.25 78.74±0.15 11 8.7 2.54±0.1 8.1 2.54 3.35 3 2.54 5.9 7.4 11.1 6.5 13.7 0.5×0.5 2-φ2.6 2.54 88.9±0.2 3.5 1.65 2.54±0.1 φ0.8 +0.1 0 φ2.8 +0.1 0 2.54±0.1 78.74±0.1 88.9±0.1 2.54±0.1 5.3±0.1 5.08±0.1 PCB Mounting Pattern c b a Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 1. When mated, first the power supply ( ground) is contacted followed by signal. When removed, the signal is disconnected followed by power supply ( ground) . This prevents the circuit from being affected if the board is removed or inserted when the power is on. Unit : mm Part No. PCN10MC-96P-2.54DS(72) HRS No. CL0583-0120-0-72 39 No. of Pos. RoHS Purchase Unit 96 Yes 24pcs per tray PCN10 Series/IEC603-2 / DIN41612 Standard Compliant Products ● Receptacle : 3-row Straight Type 95 2-φ2.8 Sequence 3.9 1.2 0.25t×0.7w 2.54 2.54 The sequential contacts are No.1 and No.32 in row a. 5.08±0.1 φ0.8 +0.1 0 0.3 φ2.8 +0.1 0 2.54±0.1 PCB Mounting Pattern a b c Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 12.5 5.2 7.3 1.7 2.9 10.5 8.5 0.3 2.54±0.1 Sequence 90±0.2 85 78.74±0.15 2.54±0.1 78.74±0.1 90±0.1 Unit : mm Part No. PCN10MC-96S-2.54DSA(72) HRS No. CL0583-0169-0-72 40 No. of Pos. RoHS Purchase Unit 96 Yes 15pcs per tray PCN10 Series/IEC603-2 / DIN41612 Standard Compliant Products Header : 2-row Right Angle Type 2.54±0.1 0.6 2.54 11.1 5.9 7.4 6.5 1.8 D±0.2 0.5×0.5 3.9 3 2.54±0.1 2.54±0.1 D±0.1 C±0.1 φ0.8 +0.1 0 φ2.8 +0.1 0 13.6±0.1 2.54±0.1 PCB Mounting Pattern ba Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 5.6 8.1 8.6 6.2 0.97 2.54±0.1 A B C±0.15 2.54 ● Pin Unit : mm Part No. HRS No. No. of Pos. A B C D PCN10MC-64P-2.54DS(72) CL0583-0211-4-72 64 94.00 85.35 78.74 88.90 PCN10MC-100P-2.54DS(72) CL0583-0212-7-72 100 139.72 131.07 124.46 134.62 41 RoHS Purchase Unit Yes 10pcs per tray PCN10 Series/IEC603-2 / DIN41612 Standard Compliant Products ● Receptacle : 2-row Straight Type A B=0.2 0.3 C 2-φ2.8 3.9 1.2 0.25t×0.7w 2.54 樹脂塗布 Note (64 contacts) : The sequential contacts are located at 22 points from contact No.1-4 and 26-32. (100 contacts) : The sequential contacts are located at 22 points from contact No.1-4 and 44-50. 2.54±0.1 0.3±0.05 PCB Mounting Pattern 2.54±0.1 φ0.8 +0.1 0 B±0.1 D±0.1 φ2.8 +0.1 0 a b Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 2.9 3.2 12.5 5.2 7.3 1.7 8.1 6.0 2.54±0.1 D=0.15 Unit : mm Part No. HRS No. No. of Pos. A B C D PCN10MC-64S-2.54DSA(72) CL0583-0213-0-72 64 95.00 90.00 85.00 78.74 PCN10MC-100S-2.54DSA(72) CL0583-0214-2-72 100 140.72 135.72 130.72 124.46 42 RoHS Yes Purchase Unit 30pcs per tray 20pcs per tray PCN10 Series/IEC603-2 / DIN41612 Standard Compliant Products Stacking Pin Header A 2.54±0.1 B=0.2 F 3 6.5 □0.5 PCB Mounting Pattern B±0.1 D±0.1 2.54±0.1 2.54±0.1 φ0.8 +0.1 0 φ3.3 +0.1 0 Application Pattern PCN10-#S-2.54DSA(72) 0.3 2.54 G Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. E 6.4 9.6 6.2 2.54±0.1 C D=0.15 PCN10H#-#P-2.54DSA(72) 43 2.54 2.54 PCN10 Series/IEC603-2 / DIN41612 Standard Compliant Products Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Unit : mm Part No. HRS No. No. of Pos. A B C D PCN10H-16P-2.54DSA(72) CL0583-0227-4-72 16 37.92 33.02 24.39 17.78 PCN10H-20P-2.54DSA(72) CL0583-0157-0-72 20 43.00 38.10 29.47 22.86 PCN10H-24P-2.54DSA(72) CL0583-0425-8-72 24 48.08 43.18 34.55 27.94 PCN10H-32P-2.54DSA(72) CL0583-0161-8-72 32 58.24 53.34 44.71 38.10 PCN10H-44P-2.54DSA(72) CL0583-0164-6-72 44 73.48 68.58 59.95 53.34 PCN10H-50P-2.54DSA(72) CL0583-0401-0-72 50 81.10 76.20 67.57 60.96 PCN10HA-16P-2.54DSA(72) CL0583-0228-7-72 16 37.92 33.02 24.39 17.78 PCN10HA-20P-2.54DSA(72) CL0583-0158-3-72 20 43.00 38.10 29.47 22.86 PCN10HA-24P-2.54DSA(72) CL0583-0426-0-72 24 48.08 43.18 34.55 27.94 PCN10HA-32P-2.54DSA(72) CL0583-0162-0-72 32 58.24 53.34 44.71 38.10 PCN10HA-44P-2.54DSA(72) CL0583-0165-9-72 44 73.48 68.58 59.95 53.34 PCN10HA-50P-2.54DSA(72) CL0583-0402-2-72 50 81.10 76.20 67.57 60.96 PCN10HB-16P-2.54DSA(72) CL0583-0229-0-72 16 37.92 33.02 24.39 17.78 PCN10HB-20P-2.54DSA(72) CL0583-0159-6-72 20 43.00 38.10 29.47 22.86 PCN10HB-32P-2.54DSA(72) CL0583-0163-3-72 32 58.24 53.34 44.71 38.10 PCN10HB-44P-2.54DSA(72) CL0583-0166-1-72 44 73.48 68.58 59.95 53.34 PCN10HB-50P-2.54DSA(72) CL0583-0403-5-72 50 81.10 76.20 67.57 60.96 PCN10HC-16P-2.54DSA(72) CL0583-0397-4-72 16 37.92 33.02 24.39 17.78 PCN10HC-44P-2.54DSA(72) CL0583-0399-0-72 44 73.48 68.58 59.95 53.34 PCN10HC-50P-2.54DSA(72) CL0583-0404-8-72 50 81.10 76.20 67.57 60.96 PCN10HD-16P-2.54DSA(72) CL0583-0398-7-72 16 37.92 33.02 24.39 17.78 PCN10HD-24P-2.54DSA(72) CL0583-0429-9-72 24 48.08 43.18 34.55 27.94 PCN10HD-44P-2.54DSA(72) CL0583-0400-7-72 44 73.48 68.58 59.95 53.34 PCN10HD-50P-2.54DSA(72) CL0583-0405-0-72 50 81.10 76.20 67.57 60.96 Note: Please note that the above series cannot mate with PCN10EA Series 44 E F G 29.80 3.44 35.00 24.80 3.36 30.00 RoHS Purchase Unit 20pcs per tray Yes 19.80 3.28 25.00 16pcs per tray 39.80 3.30 45.00 20pcs per tray 16pcs per tray 34.80 4.42 40.00 20pcs per tray PCN10 Series/IEC603-2 / DIN41612 Standard Compliant Products Precautions ● DIN Connector Mating Conditions Use Hirose DIN connectors within the following range. The contacts of the PCN10 Series receptacle rattle slightly in order to stabilize the contact installation but this does not represent a performance issue. Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ±4° 1mm ±2° 1mm While Taking in Consideration Specifications mentioned in this catalog are reference values. When considering to order or use this product, please confirm the Drawing and Product Specifications sheets. Use an appropriate cable when using the connector in combination with cables. If considering usage of a non- specified cable, please contact your sales representative. If assembly process is done by jigs & tools which are not identified by Hirose, assurance will not be given. If considering usage for below mentioned applications, please contact your sales representative. In cases where the application will demand a high level of reliability, such as automotive, medical instruments, public infrastructure, aerospace/ defense etc. Hirose must review before assurance of reliability can be given. 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN        https://www.hirose.com ※ The contents of this catalog are current as of date of 7/ 2022. Contents are subject to change without notice for the purpose of improvements. 45 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. PCN12 Series IEC603-2 / DIN41612 Standard Compliant Products Jul.2022 PCN12 Series/IEC603-2 / DIN41612 Standard Compliant Products Features 1. Complies with DIN Standard Complies with IEC603- 2/ DIN41612 standard. 2. Number of Positions Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 12 pin variations available : 10, 16, 20, 24, 28, 32, 44, 50, 64, 90, 96 and 100. 3. Two- point Contact Design Double-sided Two-point Contact System Highly reliable double- sided two point contacts. Two- point Contact Design 4. Wide applications DIN standard types of C is available. The easy lock pin type for temporary board installation is available. Applications Computers, Control Equipment, Switches, Measuring Devices, etc. 2 PCN12 Series/IEC603-2 / DIN41612 Standard Compliant Products Product Specifications Rated Current 2A Operating Temperature (Note 1) -55 to +85℃ Rated Voltage 300V AC Operating Humidity Range 85% Max. Storage Temperature Range (Note 2) -10 to +60℃ Storage Humidity Range (Note 2) 40 to 70% Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Item Specification Condition Insulation Resistance 106M Ω Min. Measured at 100V DC Withstanding Voltage No flashover or insulation breakdown. 1000V AC for 1 min. (IDC, Crimp Type : 650V AC) Contact Resistance 20m Ω Max. Measured at 0.1A Vibration No electrical discontinuity of 10μ s Min. Frequency : 10 to 55 Hz, single amplitude of 0.75 mm, 2 hours in each of the 3 directions. Humidity(Steady State) Insulation resistance : 106M Ω Min. 96 hours at temperature of 40 ± 2℃ and humidity of 90% to 95% Temperature Cycle No damage, cracks, or parts looseness. (-65℃ : 30 minutes → 15 to 35℃ : 5 minutes Max. → 125℃ : 30 minutes → 15 to 35℃ : 5 minutes Max.) 5 times Mating Durability Contact resistance : 20m Ω Max. 500 times Soldering Heat Resistance No deformation of components affecting performance. Manual soldering : 350℃ for 3 seconds Note 1 : Includes temperature rise due to current flow. Note 2 : The term "storage" refers to products stored for long period of time prior to mounting and use. The operating temperature and humidity range applies to the non-energized state after board mounting and temporary storage during transportation. Material / Finish Component Material Insulator Contact Color/Finish Remarks PBT Beige UL94V-0 Pin Header Brass Receptacle Copper Alloy Contact Area: Nickel Underplated+Gold Plated Remaining Areas: Nickel Underplated+Tin Plated - 3 PCN12 Series/IEC603-2 / DIN41612 Standard Compliant Products Product Number Structure ■ PCN12 Series (Pin Header) PCN12 A - # P - 2.54 DS Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ❶ ❷ ❸ ❹ ❺ ❻ ❶ Series Name PCN12 ❸ No. of Pos. ❷ Configuration Blank : DIN Standard Type C (96pos.) A : Original Type E・EA : With Lock Pin for Temporary Board Installation 2 row : 10,16,20,24,28,32,44,50,64,90,100 3 row : 96 ❹ Connector Type P : Pin Header ❺ Contact Pitch 2.54mm ❻ Contact Type DS : Right Angle Through Hole Type ■ PCN12 Series (Receptacle) PCN12 E - # S - 2.54 DSA ❶ ❷ ❸ ❹ ❺ ❻ ❶ Series Name PCN12 ❸ No. of Pos. ❷ Configuration Blank : Standard Type E : With Lock Pin for Temporary Board Installation 2 row : 10,16,20,24,28,32,44,50,64,90,100 3 row : 96 ❹ Connector Type S : Receptacle ❺ Contact Pitch 2.54mm ❻ Contact Type DSA : Straight Through Hhole Type 4 PCN12 Series/IEC603-2 / DIN41612 Standard Compliant Products Pin Header : 2-row Right Angle Type 2.54 4.9 B C 2.54 2.54 D 0.5×0.5 1.65 2.9 Lot No. Mark 2.54±0.1 PCB Mounting Pattern 12.6±0.1 2.54±0.1 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 10.1 6.4 1.5 5.6 7.1 8.6 6.2 2.54 5.5 A φ0.8 +0.1 0 φ2.8 +0.1 0 2.54±0.1 C±0.1 D±0.1 Unit : mm Part No. HRS No. No. of Pos. A B C D RoHS Purchase Unit PCN12A-10P-2.54DS(71) CL0583-2010-3-71 10 25.42 16.77 10.16 20.32 60pcs per tray PCN12A-20P-2.54DS(71) CL0583-2012-9-71 20 38.12 29.47 22.86 33.02 40pcs per tray PCN12A-28P-2.54DS(71) CL0583-2085-2-71 28 48.26 39.63 33.02 43.18 30pcs per tray PCN12A-32P-2.54DS(71) CL0583-2013-1-71 32 53.36 44.71 38.10 48.26 PCN12A-44P-2.54DS(71) CL0583-2014-4-71 44 68.60 59.95 53.34 63.50 PCN12A-50P-2.54DS(81) CL0583-2015-7-81 50 76.22 67.57 60.96 71.12 PCN12A-64P-2.54DS(71) CL0583-2016-0-71 64 94.00 85.35 78.74 88.90 5 ○ 20pcs per tray 10pcs per tray PCN12 Series/IEC603-2 / DIN41612 Standard Compliant Products Pin Header : 2-row Right Angle Type ● With Lock Pin for Temporary Board Installation A B C 2.54 2.54 6.4 10.1 4.9 5.6 7.1 5.5 1.5 D 0.5×0.5 1.65 2.9 Lot No. Mark 2.54±0.1 PCB Mounting Pattern 12.6±0.1 2.54±0.1 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 8.6 6.2 2.54 2.54 φ0.8 +0.1 0 φ2.8 +0.1 0 2.54±0.1 C±0.1 D±0.1 Unit : mm Part No. HRS No. No. of Pos. A B C D PCN12EA-10P-2.54DS(71) CL0583-2028-9-71 10 25.42 16.77 10.16 20.32 PCN12EA-16P-2.54DS(71) CL0583-2029-1-71 16 33.04 24.39 17.78 27.94 PCN12EA-20P-2.54DS(71) CL0583-2030-0-71 20 38.12 29.47 22.86 33.02 PCN12EA-32P-2.54DS(71) CL0583-2031-3-71 32 53.36 44.71 38.10 48.26 PCN12EA-44P-2.54DS(71) CL0583-2032-6-71 44 68.60 59.95 53.34 63.50 PCN12EA-50P-2.54DS(71) CL0583-2033-9-71 50 76.22 67.57 60.96 71.12 PCN12EA-64P-2.54DS(71) CL0583-2034-1-71 64 94.00 85.35 78.74 88.90 PCN12EA-90P-2.54DS(71) CL0583-2035-4-71 90 127.02 118.37 111.76 121.92 6 RoHS Purchase Unit 60pcs per tray 40pcs per tray ○ 20pcs per tray 10pcs per tray PCN12 Series/IEC603-2 / DIN41612 Standard Compliant Products Receptacle : Straight Type A 0.3 2.54 D 8.1 2.54 B C 3.9 3.2 11.5 5.2 6.3 6.0 2.54 PCB Mounting Pattern φ2.8 +0.1 0 φ0.8 +0.1 0 0.3 2.54±0.1 2.54±0.1 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 0.25t×0.7w D±0.1 B±0.1 Unit : mm Part No. HRS No. No. of Pos. A B C D PCN12-10S-2.54DSA(71) CL0583-2055-1-71 10 26.42 21.42 16.42 10.16 110pcs per tray PCN12-16S-2.54DSA(71) CL0583-2056-4-71 16 34.04 29.04 24.04 17.78 80pcs per tray PCN12-20S-2.54DSA(71) CL0583-2057-7-71 20 39.12 34.12 29.12 22.86 70pcs per tray PCN12-24S-2.54DSA(71) CL0583-2106-0-71 24 44.20 39.20 34.20 27.94 PCN12-28S-2.54DSA(71) CL0583-2088-0-71 28 49.28 44.28 39.28 33.02 PCN12-32S-2.54DSA(71) CL0583-2058-0-71 32 54.36 49.36 44.36 38.10 PCN12-44S-2.54DSA(71) CL0583-2059-2-71 44 69.60 64.60 59.60 53.34 PCN12-50S-2.54DSA(71) CL0583-2060-1-71 50 77.22 72.22 67.22 60.96 PCN12-64S-2.54DSA(71) CL0583-2061-4-71 64 95.00 90.00 85.00 78.74 PCN12-100S-2.54DSA(71) CL0583-2063-0-71 100 140.72 135.72 130.72 124.46 7 RoHS Purchase Unit 60pcs per tray ○ 50pcs per tray 40pcs per tray 30pcs per tray 20pcs per tray PCN12 Series/IEC603-2 / DIN41612 Standard Compliant Products Receptacle : Straight Type ● With Lock Pin for Temporary Board Installation A 0.3 2.54 D 8.1 2.54 B C 11.5 2.9 5.2 6.3 3.9 3.2 2.54 0.25t×0.7w PCB Mounting Pattern φ2.8 +0.1 0 φ0.8 +0.1 0 0.3 2.54±0.1 2.54±0.1 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 6.0 D±0.1 B±0.1 Unit : mm Part No. HRS No. No. of Pos. A B C D PCN12E-10S-2.54DSA(71) CL0583-2064-2-71 10 26.42 21.42 16.42 10.16 110pcs per tray PCN12E-20S-2.54DSA(71) CL0583-2066-8-71 20 39.12 34.12 29.12 22.86 70pcs per tray PCN12E-32S-2.54DSA(71) CL0583-2067-0-71 32 54.36 49.36 44.36 38.10 50pcs per tray PCN12E-44S-2.54DSA(71) CL0583-2068-3-71 44 69.60 64.60 59.60 53.34 PCN12E-50S-2.54DSA(71) CL0583-2069-6-71 50 77.22 72.22 67.22 60.96 PCN12E-64S-2.54DSA(71) CL0583-2070-5-71 64 95.00 90.00 85.00 78.74 PCN12E-90S-2.54DSA(71) CL0583-2071-8-71 90 128.02 123.02 118.02 111.76 PCN12E-100S-2.54DSA(71) CL0583-2072-0-71 100 140.72 135.72 130.72 124.46 8 RoHS ○ Purchase Unit 40pcs per tray 30pcs per tray 20pcs per tray PCN12 Series/IEC603-2 / DIN41612 Standard Compliant Products Pin Header : 3-row Right Angle Type (DIN Standard Type C) 94 88 85.25 78.74 2.54 2.54 2.54 2.54 6.4 10.1 4.9 1.5 2-φ2.6 88.9 1.65 2.9 3.35 6 2.54±0.1 φ0.8 +0.1 0 φ2.8 +0.1 0 2.54±0.1 5.08±0.1 PCB Mounting Pattern 5.3±0.1 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 12.7 5.5 0.5×0.5 2.54 8.7 11 2.54 2.54±0.1 78.74±0.1 88.9±0.1 Unit : mm Part No. PCN12-96P-2.54DS(71) HRS No. CL0583-2090-2-71 9 No. of Pos. RoHS Purchase Unit 96 ○ 24pcs per tray PCN12 Series/IEC603-2 / DIN41612 Standard Compliant Products Pin Header : 3-row Right Angle Type 94 88 85.25 78.74 2.54 2.54 2.54 2.54 6.4 10.1 2-φ2.6 88.9 2.9 1.65 6 3.35 2.54±0.1 φ0.8 +0.1 0 φ2.8 +0.1 0 2.54±0.1 2.54±0.1 5.08±0.1 PCB Mounting Pattern 12.6±0.1 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 1.5 4.9 12.7 5.5 0.5×0.5 2.54 8.7 11 2.54 78.74±0.1 88.9±0.1 Unit : mm Part No. PCN12A-96P-2.54DS(71) HRS No. CL0583-2091-5-71 10 No. of Pos. RoHS Purchase Unit 96 ○ 24pcs per tray PCN12 Series/IEC603-2 / DIN41612 Standard Compliant Products Pin Header: 3-row Right Angle Type (Type C) ● With Lock Pin for Temporary Board Installation 94 88 85.25 78.74 2.54 2.54 2.54 2.54 6.4 88.9 10.1 4.9 12.7 5.5 1.5 1.65 2.9 6 3.35 2.54±0.1 2.54±0.1 5.08±0.1 PCB Mounting Pattern 5.3±0.1 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 0.5×0.5 2.54 8.7 11 2.54 φ0.8 +0.1 0 φ2.8 +0.1 0 2.54±0.1 78.74±0.1 88.9±0.1 Unit : mm Part No. PCN12E-96P-2.54DS(71) HRS No. CL0583-2092-8-71 11 No. of Pos. RoHS Purchase Unit 96 ○ 24pcs per tray PCN12 Series/IEC603-2 / DIN41612 Standard Compliant Products Pin Header : 3-row Right Angle Type ● With Lock Pin for Temporary Board Installation 94 88 85.25 78.74 2.54 2.54 2.54 2.54 6.4 88.9 10.1 4.9 12.7 5.5 1.5 2.9 3.35 6 1.65 5.08±0.1 2.54±0.1 PCB Mounting Pattern φ0.8 +0.1 0 φ2.8 +0.1 0 2.54±0.1 12.6±0.1 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 0.5×0.5 2.54 8.7 11 2.54 2.54±0.1 78.74±0.1 88.9±0.1 Unit : mm Part No. PCN12EA-96P-2.54DS(71) HRS No. CL0583-2093-0-71 12 No. of Pos. RoHS Purchase Unit 96 ○ 24pcs per tray PCN12 Series/IEC603-2 / DIN41612 Standard Compliant Products Receptacle : 3-row Straight Type 95 90 85 78.74 2-φ2.6 0.25t×0.7w 2.54 2.54 PCB Mounting Pattern φ0.8 +0.1 0 φ2.8 +0.1 0 2.54±0.1 2.54±0.1 78.74±0.1 90±0.1 5.08±0.1 0.3 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 3.9 11.5 5.2 6.3 8.5 0.3 2.54 Unit : mm Part No. PCN12-96S-2.54DSA(71) HRS No. CL0583-2096-9-71 13 No. of Pos. RoHS Purchase Unit 96 ○ 15pcs per tray PCN12 Series/IEC603-2 / DIN41612 Standard Compliant Products Receptacle: 3-row Straight Type ● With Lock Pin for Temporary Board Installation 95 90 85 78.74 8.5 0.3 3.9 11.5 2.9 5.2 6.3 0.25t×0.7w 2.54 2.54 PCB Mounting Pattern φ0.8 +0.1 0 φ2.8 +0.1 0 2.54±0.1 2.54±0.1 78.74±0.1 90±0.1 5.08±0.1 0.3 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 10.5 2.54 Unit : mm Part No. PCN12E-96S-2.54DSA(71) HRS No. CL0583-2097-1-71 14 No. of Pos. RoHS Purchase Unit 96 ○ 15pcs per tray PCN12 Series/IEC603-2 / DIN41612 Standard Compliant Products Precautions ● DIN Connector Mating Conditions Use Hirose DIN connectors within the following range. The contacts of the PCN10 Series receptacle rattle slightly in order to stabilize the contact installation but this does not represent a performance issue. Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ±4° 1mm ±2° 1mm While Taking in Consideration Specifications mentioned in this catalog are reference values. When considering to order or use this product, please confirm the Drawing and Product Specifications sheets. Use an appropriate cable when using the connector in combination with cables. If considering usage of a non- specified cable, please contact your sales representative. If assembly process is done by jigs & tools which are not identified by Hirose, assurance will not be given. If considering usage for below mentioned applications, please contact your sales representative. In cases where the application will demand a high level of reliability, such as automotive, medical instruments, public infrastructure, aerospace/ defense etc. Hirose must review before assurance of reliability can be given. 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN        https://www.hirose.com ※ The contents of this catalog are current as of date of 7/ 2022. Contents are subject to change without notice for the purpose of improvements. 15 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. PCN13 Series IEC603-2 / DIN41612 Standard Compliant Products Jul.2022 PCN13 Series/IEC603-2 / DIN41612 Standard Compliant Products Features 1. Complies with DIN Standard Complies with IEC603- 2/ DIN41612 standard. 2. Number of Positions Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 12 pin variations available : 10, 16, 20, 30, 32, 44, 48, 50, 64, 90, 96 and 100. 3. Two- point Contact Design Single-sided Two-point Contact System High cost performance with the single- sided two point contact design. Two- point Contact Design 4. Wide applications The easy lock pin type for temporary board installation is available. Applications Computers, Control Equipment, Switches, Measuring Devices, etc. 2 PCN13 Series/IEC603-2 / DIN41612 Standard Compliant Products Product Specifications Rated Current 2A Operating Temperature (Note 1) -55 to +85℃ Rated Voltage 300V AC Operating Humidity Range 85% Max. Storage Temperature Range (Note 2) -10 to +60℃ Storage Humidity Range (Note 2) 40 to 70% Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Item Specification Condition Insulation Resistance 106M Ω Min. Measured at 100V DC Withstanding Voltage No flashover or insulation breakdown. 1000V AC for 1 min. (IDC, Crimp Type : 650V AC) Contact Resistance 20m Ω Max. Measured at 0.1A Vibration No electrical discontinuity of 10μ s Min. Frequency : 10 to 55 Hz, single amplitude of 0.75 mm, 2 hours in each of the 3 directions. Humidity(Steady State) Insulation resistance : 106M Ω Min. 96 hours at temperature of 40 ± 2℃ and humidity of 90% to 95% Temperature Cycle No damage, cracks, or parts looseness. (-65℃ : 30 minutes → 15 to 35℃ : 5 minutes Max. → 125℃ : 30 minutes → 15 to 35℃ : 5 minutes Max.) 5 times Mating Durability Contact resistance : 20m Ω Max. 500 times Soldering Heat Resistance No deformation of components affecting performance. Manual soldering : 350℃ for 3 seconds Note 1 : Includes temperature rise due to current flow. Note 2 : The term "storage" refers to products stored for long period of time prior to mounting and use. The operating temperature and humidity range applies to the non-energized state after board mounting and temporary storage during transportation. Material / Finish Component Material Insulator Contact Receptacle Color/Finish Remarks PBT Beige UL94V-0 Copper Alloy Contact Area: Nickel Underplated+Gold Plated Remaining Areas: Nickel Underplated+Tin Plated - 3 PCN13 Series/IEC603-2 / DIN41612 Standard Compliant Products Product Number Structure ■ PCN13 Series (Receptacle) PCN13 E - # S - 2.54 DSA Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ❶ ❷ ❶ Series Name ❷ ❸ ❸ ❹ ❺ ❻ ❹ Connector Type S : Receptacle Configuration Blank : Standard Type E : With Lock Pin for Temporary Board Installation ❺ Contact Pitch 2.54mm No. of Pos. ❺ Contact Pitch DS : Right Angle Through Hole Type DSA : Straight Through Hole Type PCN13 2 row : 10,16,20,30,32,44,50,64,90,100 3 row : 48,96 *PCN13 Series only includes socket connectors that mate with the PCN10 and PCN12 Series plugs. 4 PCN13 Series/IEC603-2 / DIN41612 Standard Compliant Products Receptacle : 2-row Straight Type A B C D 8.1 6.0 0.3 2.54 11.5 5.2 6.3 3.2 2-φ2.6 0.25t×0.6w 2.54 PCB Mounting Pattern φ0.8 +0.1 0 φ2.8 +0.1 0 2.54±0.1 2.54±0.1 0.3 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 3.9 C1 Lot No. Mark D±0.1 B±0.1 Unit : mm Part No. HRS No. No. of Pos. A B C D RoHS Purchase Unit PCN13-16S-2.54DSA(71) CL0583-3001-8-71 16 34.04 29.04 24.04 17.78 80pcs per tray PCN13-20S-2.54DSA(71) CL0583-3002-0-71 20 39.12 34.12 29.12 22.86 70pcs per tray PCN13-32S-2.54DSA(71) CL0583-3004-6-71 32 54.36 49.36 44.36 38.10 50pcs per tray PCN13-44S-2.54DSA(71) CL0583-3005-9-71 44 69.60 64.60 59.60 53.34 PCN13-50S-2.54DSA(71) CL0583-3006-1-71 50 77.22 72.22 67.22 60.96 PCN13-64S-2.54DSA(71) CL0583-3007-4-71 64 95.00 90.00 85.00 78.74 PCN13-90S-2.54DSA(71) CL0583-3008-7-71 90 128.02 123.02 118.02 111.76 PCN13-100S-2.54DSA(71) CL0583-3009-0-71 100 140.72 135.72 130.72 124.46 5 ○ 40pcs per tray 30pcs per tray 20pcs per tray PCN13 Series/IEC603-2 / DIN41612 Standard Compliant Products Receptacle : 2-row Right Angle Type A B C 2.54 8.9 6.3 3.82 8.1 6.0 3.2 2.54 3.1 0.3t×0.7w PCB Mounting Pattern 6.3±0.1 2.54±0.1 C 2.54±0.1 2.54±0.1 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. D 2.54 2-φ2.6 Lot No. Mark φ0.8 +0.1 0 2-φ2.8 +0.1 0 D Unit : mm Part No. HRS No. No. of Pos. A B C D RoHS Purchase Unit PCN13-16S-2.54DS(71) CL0583-3031-9-71 16 38.02 24.04 17.78 33.02 44pcs per box PCN13-20S-2.54DS(71) CL0583-3032-1-71 20 43.10 29.12 22.86 38.10 33pcs per tray PCN13-30S-2.54DS(71) CL0583-3033-4-71 30 55.80 41.82 35.56 50.80 PCN13-32S-2.54DS(71) CL0583-3034-7-71 32 58.34 44.36 38.10 53.34 PCN13-44S-2.54DS(71) CL0583-3035-0-71 44 73.58 59.60 53.34 68.58 PCN13-50S-2.54DS(81) CL0583-3036-2-81 50 81.20 67.22 60.96 76.20 PCN13-64S-2.54DS(71) CL0583-3037-5-71 64 98.98 85.00 78.74 93.98 PCN13-90S-2.54DS(81) CL0583-3038-8-81 90 132.00 118.02 111.76 127.00 PCN13-100S-2.54DS(71) CL0583-3039-0-71 100 144.70 130.72 124.46 139.70 6 22pcs per tray ○ 11pcs per tray PCN13 Series/IEC603-2 / DIN41612 Standard Compliant Products Receptacle : 3-row Straight Type 2.54 2.9 3.9 C1 0.25t×0.6w 2.54 2.54 2.54±0.1 φ0.8 +0.1 0 0.3 φ2.8 +0.1 0 2.54±0.1 D±0.1 B±0.1 5.08±0.1 PCB Mounting Pattern a b c Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 11.5 5.2 6.3 8.5 0.3 2-φ2.6 10.5 A B C D Unit : mm Part No. HRS No. No. of Pos. A B C D PCN13-48S-2.54DSA(71) CL0583-3010-9-71 48 54.36 50.00 44.36 38.10 PCN13-96S-2.54DSA(71) CL0583-3011-1-71 96 95.00 90.00 85.00 78.74 7 RoHS ○ Purchase Unit 20pcs per tray 15pcs per tray PCN13 Series/IEC603-2 / DIN41612 Standard Compliant Products Receptacle : 3-row Right Angle Type A B C 8.5 2.54 2.54 10.15 6.3 2.54 2-φ2.6 D Lot No. Mark 6.81 3.18 0.3t×0.7w 2.54±0.1 φ0.8 +0.1 0 2.54±0.1 5.3±0.1 5.08±0.1 PCB Mounting Pattern c b a Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 12.5 10.26 2.54 φ2.8 +0.1 0 2.54±0.1 C±0.1 D±0.1 Unit : mm Part No. HRS No. No. of Pos. A B C D PCN13-48S-2.54DS(71) CL0583-3040-0-71 48 53.36 44.36 38.10 48.26 PCN13-96S-2.54DS(71) CL0583-3041-2-71 96 94.00 85.00 78.74 88.90 8 RoHS ○ Purchase Unit 48pcs per tray 24pcs per tray PCN13 Series/IEC603-2 / DIN41612 Standard Compliant Products Application Pattern ● Right Angle Connection ●2-row Type Mounting Hole Center C.L. Center Line C.L. 5.3 2.54 3.62 17.84 17.96 2.54 6.3 PCN10-#P-2.54DSA(72) 2.54 PCN10EA-#S-2.54DSA(52) PCN10C-#S-2.54DSA(52) PCN10-#S-2.54DSA(72) 2.54 0.3 C.L. 2.54 0.3 PCN10A-#P-2.54DS(72) PCN12A-#P-2.54DS(##) 5.27 C.L. 9 17.84 2.54 0.3 C.L. 12.6 17.96 PCN10-#P-2.54DSA(72) 2.54 2.54 PCN13-#S-2.54DSA(71) 2.54 2.54 2.78 17.84 PCN12(E)-#S-2.54DSA(71) 17.84 5.3 2.54 17.84 0.3 2.54 2.54 PCN13-#S-2.54DS(##) 12.6 C.L. 3.62 2.54 PCN10EA-#S-2.54DSA(52) PCN10C-#S-2.54DSA(52) PCN10-#S-2.54DSA(72) 0.3 5.27 12.6 2.54 2.54 C.L. 2.54 PCN12A(EA)-#P-2.54DS(71) PCN10-#P-2.54DS(72) 2.54 C.L. 5.27 6.3 PCN10EA-#P-2.54DS(72) PCN10A-#P-2.54DS(72) 2.54 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 2.54 PCN10C-#S-2.54DS(72) PCN10-#P-2.54DS(72) 2.54 2.78 PCN13-#S-2.54DSA(71) PCN13 Series/IEC603-2 / DIN41612 Standard Compliant Products ●3-row Type Mounting Hole Center C.L. Center Line 2.54 0.3 17.84 0.3 2.54 2.54 0.3 PCN10-#S-2.54DSA(72) C.L. 2.54 2.54 C.L. PCN10-#P-2.54DSA(72) 0.3 2.54 PCN10-#P-2.54DSA(72) 2.54 C.L. 17.99 0.3 2.54 2.54 C.L. 5.2 2.54 PCN10A-#P-2.54DS(72) PCN12A-#P-2.54DS(71) PCN13-#S-2.54DSA(71) PCN13-#S-2.54DSA(71) 0.3 2.54 0.3 2.54 2.54 C.L. 2.54 C.L. 10 17.84 12.6 17.84 2.54 5.3 PCN10-#P-2.54DS(72) PCN12-#P-2.54DS(71) 2.54 2.54 3.55 48pos. : 19.09 5.3 2.54 17.99 48pos. : 19.09 2.54 2.54 2.54 5.3 PCN10B-#S-2.54DS(72) 4.83 PCN10A-#S-2.54DS(72) 2.54 2.54 3.58 2.54 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. PCN10-#P-2.54DSA(72) 2.54 48pos. : 17.9 PCN10A-#P-2.54DS(72) 16.8 PCN10-#S-2.54DSA(72) 12.6 2.54 2.54 5.2 PCN13 Series/IEC603-2 / DIN41612 Standard Compliant Products Mounting Hole Center C.L. Center Line 3.55 2.54 PCN12(E)-#P-2.54DS(71) 2.54 2.54 5.2 0.3 2.54 C.L. 17.84 12.6 2.54 C.L. ●3-row 144pos. Type 2.54 9.0 PCN10MA-144P-2.54DS(72) PCN10-#P-2.54DSA(72) PCN10MA-144S-2.54DSA(72) 2.54 2.54 2.54 1.79 C.L. 0.75 C.L. ●4-row Type 6.77 2.54 PCN10-128P-2.54DS(72) 2.54 5.3 17.84 2.54 12.6 17.84 2.54 PCN10A-128P-2.54DS(72) 2.54 2.54 5.12 PCN10-128S-2.54DSA(72) 2.54 PCN10-128S-2.54DSA(72) 2.54 2.54 C.L. 2.54 C.L. 4.85 PCN10-128P-2.54DSA(72) 17.99 5.3 2.54 2.54 PCN10B-128S-2.54DS(72) 0.3 2.54 2.54 C.L. 2.54 2.54 11 18.88 2.54 17.99 0.3 2.54 13.64 5.3 48pos. : 19.09 2.54 2.54 2.54 4.83 PCN13-#S-2.54DS(71) 0.3 PCN12(E)-#S-2.54DSA(71) 2.54 2.54 2.54 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. PCN12(E)-#S-2.54DSA(71) 2.54 2.54 17.84 5.3 PCN12A(EA)-#P-2.54DS(71) PCN13 Series/IEC603-2 / DIN41612 Standard Compliant Products Connection Mounting Hole Center ●2-row Type C.L. Center Line PCN10C-#S-2.54DS(72) 19.0 2.54 2.65 4.3 2.54 6.3 5.3 2.54 2.54 19.0 19.0 2.54 PCN13-#S-2.54DS(##) PCN10-#P-2.54DS(72) 6.3 2.54 4.05 2.54 C.L. 4.05 C.L. PCN13-#S-2.54DS(##) 12.6 2.54 2.54 5.3 PCN10EA-#P-2.54DS(72) PCN12A-#P-2.54DS(72) 2.54 PCN10-#P-2.54DS(72) PCN10A-#P-2.54DS(72) PCN12A-#P-2.54DS(##) 2.54 2.54 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 19.0 2.54 6.3 2.54 PCN10C-#S-2.54DS(72) 6.3 2.54 4.05 2.54 C.L. 4.05 C.L. 2.65 4.3 12 12.6 ● Coplanar PCN13 Series/IEC603-2 / DIN41612 Standard Compliant Products ●3-row Type Mounting Hole Center C.L. Center Line 3.88 5.3 5.3 2.54 19.03 2.54 19.03 12.6 2.54 5.3 2.54 PCN10B-#S-2.54DS(72) 2.54 PCN10B-#S-2.54DS(72) 2.54 2.54 2.54 3.88 3.85 2.54 5.5 2.54 2.54 2.54 PCN10-#P-2.54DS(72) C.L. C.L. 2.54 2.54 2.54 5.13 PCN10A-#S-2.54DS(72) 5.3 5.3 2.54 19.03 2.54 19.03 2.54 2.54 5.3 PCN10A-#S-2.54DS(72) 12.6 C.L. 5.13 2.54 C.L. 2.54 3.85 2.54 PCN10-#P-2.54DS(72) 2.54 5.5 2.54 PCN10A-#P-2.54DS(72) 2.54 19.03 2.54 19.03 13 2.54 2.54 5.5 2.54 2.54 2.54 5.3 PCN10-#P-2.54DS(72) PCN12-#P-2.54DS(71) PCN10-#P-2.54DS(72) PCN12-#P-2.54DS(71) 3.85 5.3 2.54 2.54 PCN13-#S-2.54DS(71) 5.3 2.54 C.L. 5.13 12.6 5.13 PCN13-#S-2.54DS(71) 2.54 C.L. 2.54 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. PCN10A-#P-2.54DS(72) PCN13 Series/IEC603-2 / DIN41612 Standard Compliant Products ●4-row Type C.L. PCN10B-128S-2.54DS(72) 5.15 2.54 7.62 PCN10-128P-2.54DS(72) 5.12 14 2.54 6.77 2.54 2.54 PCN10A-128P-2.54DS(72) 2.54 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 5.3 2.54 19.03 2.54 5.3 2.54 12.6 2.54 7.62 2.54 2.54 2.54 PCN10B-128S-2.54DS(72) 19.03 5.15 5.3 C.L. PCN13 Series/IEC603-2 / DIN41612 Standard Compliant Products ● Parallel Connection ●2-row Type Mounting Hole Center C.L. Center Line 0.3 0.3 2.54 2.54 PCN13-#S-2.54DSA(71) 16.8 PCN10-#P-2.54DSA(72) 2.54 PCN10-#P-2.54DSA(72) 2.54 C.L. ●3-row Type 2.54 2.54 0.3 16.8 PCN10-#P-2.54DSA(72) 0.3 PCN10-#P-2.54DSA(72) 2.54 2.54 C.L. ●4-row Type C.L. 2.54 2.54 2.54 16.8 PCN10-128P-2.54DSA(72) 0.3 2.54 2.54 C.L. PCN10-128S-2.54DSA(72) 0.3 PCN13-#S-2.54DSA(71) 48pos. : 17.9 PCN10-#S-2.54DSA(72) 2.54 2.54 2.54 2.54 0.3 15 48pos. : 17.9 2.54 16.8 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 16.8 PCN10-#S-2.54DSA(72) PCN13 Series/IEC603-2 / DIN41612 Standard Compliant Products ● Circuit Protection Type Mounting Hole Center C.L. Center Line ●3-row Type 5.27 PCN10MC-#P-2.54DS(72) C.L. 2.54 ●2-row Type 2.54 18.84 13.6 PCN10MC-#S-2.54DSA(72) 0.3 PCN10MC-96S-2.54DSA(72) 64pos. : The sequential contacts are indicated at 22 points from contact No.1 to 4 and 26 to 32 in both rows a and b. 100pos. : The sequential contact is indicated at 22 points from contact No.1 to 4 and 44 to 50 in both rows a and b. ● Stacking The sequential contacts are located at 2 points: a1 and a32. Connector Mounting Hole Center C.L. Center Line PCN10-#S-2.54DSA(72) 0.3 2.54 G Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 2.54 PCN10MC-96P-2.54DS(72) 2.54 PCN10H#-#P-2.54DSA(72) 16 *G…35、30、25、45、40 PCN13 Series/IEC603-2 / DIN41612 Standard Compliant Products Precautions ● DIN Connector Mating Conditions Use Hirose DIN connectors within the following range. The contacts of the PCN10 Series receptacle rattle slightly in order to stabilize the contact installation but this does not represent a performance issue. Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ±4° 1mm ±2° 1mm While Taking in Consideration Specifications mentioned in this catalog are reference values. When considering to order or use this product, please confirm the Drawing and Product Specifications sheets. Use an appropriate cable when using the connector in combination with cables. If considering usage of a non- specified cable, please contact your sales representative. If assembly process is done by jigs & tools which are not identified by Hirose, assurance will not be given. If considering usage for below mentioned applications, please contact your sales representative. In cases where the application will demand a high level of reliability, such as automotive, medical instruments, public infrastructure, aerospace/ defense etc. Hirose must review before assurance of reliability can be given. 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN        https://www.hirose.com ※ The contents of this catalog are current as of date of 7/ 2022. Contents are subject to change without notice for the purpose of improvements. 17
PCN10C-64ACS-2.54DSA(72) 价格&库存
很抱歉,暂时无法提供与“PCN10C-64ACS-2.54DSA(72)”相匹配的价格&库存,您可以联系我们找货
