PCN13-32S-2.54DS
PCN13-32S-2.54DS
    HRS(广濑)
    DINCONNRCPT32POS2ROWRIANGL
PCN13-32S-2.54DS 数据手册
Product Compliant to DIN41612/IEC603-2 Standard PCN Series Pin Header Side ●Straight through hole type Receptacle Side ●Straight through hole Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. PCN10EA- * *P-2.54DSA PCN10EA-* *S-2.54DSA PCN10CA-* *S-2.54DSA PCN10EA-* *S-2.54DSA PCN10DA-* *S-2.54DSA PCN12EA-* *S-2.54DSA PCN12EA-* *S-2.54DSA PCN13EA-* *S-2.54DSA ●Stacking through hole type PCN10H* - * *P-2.54DSA ●Wrapping type PCN10EA-* *S-2.54W* ●Right angle through hole type (mounted on the board edge) PCN10EA-* *P-2.54DS PCN12EA-* *P-2.54DS PCN12EA-* *P-2.54DS ●Right angle through hole type (mounted on the board edge) PCN10BA-* *S-2.54DS ●Right angle through hole type (mounted on the board) PCN10AE-* *P-2.54DS PCN10EA-* *P-2.54DS PCN12AE-* *P-2.54DS PCN12EA-* *P-2.54DS ●Right angle through hole type (mounted on the board) PCN10AE-* *S-2.54DS PCN10CA-* *S-2.54DS PCN13EA-* *S-2.54DS ●Press fit type ●Press fit short pin type PCN11-* *S-2.54PFB-2 PCN11-* *P-2.54W* -2+PCN11-* *P-2.54H-2 ●Press fit long pin type PCN11-* *S-2.54WB-2 ●Cable type PCN10-* *S-2.54C+PCN10-* * * *SC* PCN10-* *S-2.54R A12 PCN Series●Product Compliant to DIN41612/IEC603-2 Standard ■Coaxial Connector and High Current Contact Composite Type Pin Header Side ●Right angle through hole type (mounted on the board edge) Receptacle Side ●Straight through hole type PCN10F-* *P-2.54DS PCN10FA-* *S-2.54DSA Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ●Wrapping type ●Right angle through hole type (mounted on the board) PCN10FA-* *S-2.54W* PCN10FA-* *P-2.54DS ●Right angle through hole type (mounted on the board edge) PCN10FB-* *S-2.54DS ●Right angle through hole type (mounted on the board) PCN10FA-* *S-2.54DS ●Press fit short pin type PCN11F-* *S-2.54PFB-2 ●Press fit long pin type PCN11F-* *S-2.54WB-2 Circuit Protection Function Type Pin Header Side Receptacle Side ●Straight through hole type PCN10MC*-* *S-2.54DSA ●Right angle through hole type PCN10MC*-* *P-2.54DS ●Wrapping type PCN10MC*-* *S-2.54W* A13 PCN Series●Product Compliant to DIN41612/IEC603-2 Standard PCN10, 12, 13 Series (Product Compliant to DIN Standard: through hole,Wrapping Type) Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Double-sided two point Contact System PCN Series ■Features 1. Compliant with DIN Standard Comply with IEC603-2/DIN41612 standard. 2. Variation in number of contacts 10, 16, 20, 24, 28, 30, 32, 44, 48, 50, 64, 90, 96, 100, 128, and 144 contacts are available. 3. Two point contact construction PCN10 and 12 series are constructed with high reliable doublesided two point contacts. PCN13 series pursues after cost performance, and constructed with single sided two point contacts. 4. Broad applications DIN standard types of B, C, R, and Q are available. The flux tight product is available. The easy lock pin type to prefix the board is available. 5. Stacking height variation PCN10H series contains 25, 30, 35, 40 and 45mm stacking height. 6. Circuit protection function available PCN10MC series utilizes a sequence structure for circuit protection function. 7. Cable connector ID connector for ribbon cable is available. The connector is prepared for crimping connection for AWC#26 to 30 cables. ■Application Control equipment, exchange, measuring instruments etc. A14 Single-sided two point Contact System Stacking Connector PCN Series●Product Compliant to DIN41612/IEC603-2 Standard ■Product Specifications Operating Temperature Range: -55 to +85ç (Note 1) Storage Temperature Range: -10 to +60ç (Note 2) Operating Humidity Range: 85% max Storage Humidity Range: 40 to 70% (Note 2) Current rating: 2A Voltage rating: 300V AC Rating Item Specification Condition 1.Insulation Resistance 106M ohms 100V DC 2.Withstanding Voltage No flashover or insulation breakdown. 1000V AC (insulation displacement, crimping type: 650V AC) /1 minute. 0.1A 3.Contact Resistance 20m ohms max. 4.Vibration No electrical discontinuity of 10μs or more Frequency: 10 to 55 Hz, single amplitude of 0.75 mm, 2 hours in each of the 3 directions. 5.Humidity(Steady state) Insulation resistance : 10 M ohms min. 96 hours at temperature of 40ç and humidity of 90% to 95% 6.Temperature Cycle (-65ç : 30 minutes→15 to 35ç: 5 minutes max.→ 125ç : 30 minutes→15 to 35ç: 5 minutes max.) 5 cycles Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 6 No damage, cracks, or parts looseness. 500 cycles 7.Durability (Mating/un-mating) Contact resistance : 20m ohms max. 8.Resistance to Soldering heat No deformation of components affecting performance. Manual soldering: 300ç for 3 seconds Note 1: Includes temperature rise caused by current flow. Note 2: The term "storage" refers to products stored for long period of time prior to mounting and use. Operating Temperature Range and Humidity range covers non conducting condition of installed connectors in storage, shipment or during transportation. Note 3. Information contained in this catalog represents general requirements for this Series. Contact us for the drawings and specifications for a specific part number shown. ■Material Parts Material Finish Remarks Insulator PBT Gray UL94V-0 Pin header Brass Contact area: Gold plated --------------- Receptacle Copper alloy Remainer: Tin plated --------------- Contact ■Ordering Information ●PCN 10 Series PCN10 1 1 2 Series Name Blank A B C : D : EA : H : HA : HB : HC : HD : MC : } A – * P – 2.54 DS 2 3 4 5 6 3 Number of contacts: 2-row : 16, 20, 24, 32, 44, 50, 64, 90, 100 : PCN10 mold type (as listed below) 4 Connector type Flux prevention type (DSA only) Rack installation type With Board prefixed lock pin Stacking height 35mm type Stacking height 30mm type Stacking height 25mm type Stacking height 45mm type Stacking height 40mm type Circuit Protection function type 5 Contact pitch 6 Contact type DS DSA WA WB R C 3-row : 48, 96, 144 4-row : 128 : P : Pin header : S : Receptacle : 2.54mm : Right angle through hole type : Straight through hole type : Wrapping type (0.5tx0.7W) : Wrapping type (0.5tx0.5W) : Insulation displacement type : Crimping type * * A15 PCN Series●Product Compliant to DIN41612/IEC603-2 Standard ●PCN 12 Series (Plug) PCN12 A - * P - 2.54 DS 1 3 q Series name : PCN12 w No symbol : DIN standard type C (96 Contacts) A E-EA Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 2 5 6 e Number of contacts : 2-row: 10, 16, 20, 24, 28, 32, 44, 50, 64, 90, 100 : Original type 3-row: 96 : With board prefixed lock pin type r P : Plug t Contact pitch : 2.54mm y Contact type : DS: Right angle through hole type ●PCN 12E-*S-2.54 DSA(Socket) PCN12 1 E - * S - 2.54 DSA 2 3 4 5 q Series name : PCN12 r w No symbol : Standard type t Contact pitch E S : With board prefixed lock pin type y Contact type 6 : Socket : 2.54mm : DSA: Straight through hole type e Number of contacts : 2-row: 10, 16, 20, 28, 32, 44, 50, 64, 90, 100 3-row: 96 ●PCN 13E-*S-2.54 DSA (Socket) PCN13 1 E - * S - 2.54 DSA 2 3 4 5 6 q Series name : PCN13 r w No symbol : Standard type t Contact pitch : 2.54mm : With board prefixed easy pin type y Contact style : DS: Right angle through hole type E e Number of contacts : 2-row: 10, 16, 20, 30, 32, 44, 50, 64, 90, 100 3-row: 48, 96 *PCN13 series are only socket type. PCN10 and 12 series are mating connectors. A16 4 S : Socket : DSA: Straight through hole type PCN Series●Product Compliant to DIN41612/IEC603-2 Standard BDIN Connector Mating Condition Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. DIN connectors of Hirose should be used under conditions as illustrated below. A17 PCN Series●Product Compliant to DIN41612/IEC603-2 Standard BContact numbers According to the inter-combination with DIN standard type C (type B) and type R (type Q), the contact numbers and row numbers represent contact No. (No.1 to 32) and row No. (a, b, c). ●DIN standard type C and type R represent the 3-row 96 contacts type, including 32 contacts in single-row. ●DIN standard type B and type Q represent the 2-row 64 contacts type, including 32 contacts in single-row. Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 1 Receptacle straight type Type C (Type B) 3 Pin header straight type Type R (Type Q) 2 Pin header right angle type Type C (Type B) 4 Receptacle right angle type Type R (Type Q) Note: The DIN connector is basically standardized in combination with straight and right angle types. As shown above in illustrationss; The contact numbers is matched in combination with (1)-(2) and (3)-(4), while the contact numbers are inverted in combination with (1)-(2) and (3)-(4). A18 PCN Series●Product Compliant to DIN41612/IEC603-2 Standard PCN10 Series Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ■Pin Header: 2-row Right Angle Type (DIN standard type B) Unit:mm PCN10-*P-2.54DS(72) Part Number BPCB mounting pattern CL No. Number of Contacts A B C D RoHS PCN10- 16P-2.54DS(72) CL583-0230-9-72 16 33.04 24.39 17.78 27.94 PCN10- 20P-2.54DS(72) CL583-0077-3-72 20 38.12 29.47 22.86 33.02 PCN10- 32P-2.54DS(72) CL583-0015-6-72 32 53.36 44.71 38.10 48.26 PCN10- 44P-2.54DS(72) CL583-0038-1-72 44 68.60 59.95 53.34 63.50 PCN10- 50P-2.54DS(72) CL583-0016-9-72 50 76.22 67.57 60.96 71.12 PCN10- 64P-2.54DS(72) CL583-0017-1-72 64 94.00 85.35 78.74 88.90 PCN10- 90P-2.54DS(72) CL583-0018-4-72 90 127.02 118.37 111.76 121.92 PCN10-100P-2.54DS(72) CL583-0113-5-72 100 139.72 131.07 124.46 134.62 YES ■Pin Header: 2-row Right Angle Type PCN10A-*P-2.54DS(72) BPCB mounting pattern Unit:mm Part Number CL No. Number of Contacts A B C D PCN10A-116P-2.54DS(72) CL583-0231-1-72 16 33.04 24.39 17.78 27.94 PCN10A-120P-2.54DS(72) CL583-0078-6-72 20 38.12 29.47 22.86 33.02 PCN10A-132P-2.54DS(72) CL583-0011-5-72 32 53.36 44.71 38.10 48.26 PCN10A-144P-2.54DS(72) CL583-0039-4-72 44 68.60 59.95 53.34 63.50 PCN10A-150P-2.54DS(72) CL583-0012-8-72 50 76.22 67.57 60.96 71.12 PCN10A-164P-2.54DS(72) CL583-0013-0-72 64 94.00 85.35 78.74 88.90 PCN10A-190P-2.54DS(72) CL583-0014-3-72 90 127.02 118.37 111.76 121.92 PCN10A-100P-2.54DS(72) CL583-0114-8-72 100 139.72 131.07 124.46 134.62 RoHS YES A19 PCN Series●Product Compliant to DIN41612/IEC603-2 Standard ■Pin Header: 2-row Right Angle Type Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ●With Board prefixed lock pin ●The PCB mounting pattern is equivalent to PCN10A-*P-2.54DS. (Refer to page A19.) Part Number CL No. Number of Contacts A B C D RoHS PCN10EA-116P-2.54DS(72) CL583-0256-2-72 16 33.04 24.39 17.78 27.94 PCN10EA-120P-2.54DS(72) CL583-0181-5-72 20 38.12 29.47 22.86 33.02 PCN10EA-132P-2.54DS(72) CL583-0182-8-72 32 53.36 44.71 38.10 48.26 PCN10EA-144P-2.54DS(72) CL583-0183-0-72 44 68.60 59.95 53.34 63.50 PCN10EA-150P-2.54DS(72) CL583-0184-3-72 50 76.22 67.57 60.96 71.12 PCN10EA-164P-2.54DS(72) CL583-0185-6-72 64 94.00 85.35 78.74 88.90 PCN10EA-190P-2.54DS(72) CL583-0186-9-72 90 127.02 118.37 111.76 121.92 PCN10EA-100P-2.54DS(72) CL583-0187-1-72 100 139.72 131.07 124.46 134.62 YES ■Pin Header: 2-row Straight Type PCN10-*P-2.54DSA(72) BPCB mounting pattern A20 Unit:mm PCN10EA*P-2.54DS(72) *Type Q differs in the outer dimensions and PCB mounting pattern. Unit:mm Part Number CL No. Number of Contacts A B C D RoHS PCN10-120P-2.54DSA(72) CL583-0139-9-72 20 43.30 38.10 29.47 22.86 PCN10-132P-2.54DSA(72) CL583-0007-8-72 32 58.54 53.34 44.71 38.10 PCN10-144P-2.54DSA(72) CL583-0488-8-72 44 73.78 68.58 59.95 53.54 PCN10-150P-2.54DSA(72) CL583-0008-0-72 50 81.40 76.20 67.57 60.96 YES PCN10-164P-2.54DSA(72) CL583-0009-3-72 64 99.18 93.98 85.35 78.74 PCN10-190P-2.54DSA(72) CL583-0010-2-72 90 132.20 127.00 118.37 111.76 PCN10-100P-2.54DSA(72) CL583-0251-9-72 100 144.90 139.70 131.07 124.46 PCN Series●Product Compliant to DIN41612/IEC603-2 Standard Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ■Receptacle: 2-row Right Angle Type PCN10C-*S-2.54DS(72) *Type Q differs in the external size and PCB mounting pattern. Unit:mm BPCB mounting pattern Part Number CL No. Number of Contacts A B C D RoHS PCN10C-120S-2.54DS(72) CL583-0201-0-72 20 43.10 29.12 22.86 38.10 PCN10C-132S-2.54DS(72) CL583-0202-3-72 32 58.34 44.36 38.10 53.34 PCN10C-144S-2.54DS(72) CL583-0052-2-72 44 73.58 59.60 53.34 68.58 PCN10C-150S-2.54DS(72) CL583-0168-7-72 50 81.20 67.22 60.96 76.20 PCN10C-160S-2.54DS(72) CL583-0174-0-72 60 93.90 79.92 73.66 88.90 Note PCN10C-164S-2.54DS(72) CL583-0203-6-72 64 98.98 85.00 78.74 93.98 PCN10C-190S-2.54DS(72) CL583-0204-9-72 90 132.00 118.02 111.76 127.00 PCN10C-100S-2.54DS(72) CL583-0178-0-72 100 144.70 130.72 124.46 139.70 YES Note: DIN standard type Q (Reverse type of type B) indicates PCN10B-64S-2.54DS(72). ■Receptacle: 2-row Straight Type (DIN standard type B) PCN10-*S-2.54DSA(72) BPCB mounting pattern Unit:mm Part Number CL No. Number of Contacts A B C D RoHS PCN10-32S-2.54DSA(72) CL583-0019-7-72 32 54.36 49.36 44.36 38.10 PCN10-50S-2.54DSA(72) CL583-0020-6-72 50 77.22 72.22 67.22 60.96 YES PCN10-64S-2.54DSA(72) CL583-0021-9-72 64 95.00 90.00 85.00 78.74 A21 PCN Series●Product Compliant to DIN41612/IEC603-2 Standard Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ■Receptacle: 2-row Wrapping Type (DIN standard type B) PCN10-*S-2.54 WA(72) WB(72) Unit:mm BPCB mounting pattern Part Number CL No. Number of Contacts A B C D PCN10-32S-2.54WA(72) CL583-0107-2-72 32 54.36 49.36 44.36 38.10 PCN10-32S-2.54WB(72) CL583-0067-0-72 32 54.36 49.36 44.36 38.10 PCN10-50S-2.54WA(72) CL583-0108-5-72 50 77.22 72.22 67.22 60.96 PCN10-50S-2.54WB(72) CL583-0068-2-72 50 77.22 72.22 67.22 60.96 PCN10-64S-2.54WA(72) CL583-0109-8-72 64 95.00 90.00 85.00 78.74 PCN10-64S-2.54WB(72) CL583-0069-5-72 64 95.00 90.00 85.00 78.74 YES * ■Flux Prevention Type (DIN standard type B) PCN10C-*S-2.54DSA(72) BPCB mounting pattern A22 RoHS Unit:mm Part Number CL No. Number of Contacts A B C D PCN10C-116S-2.54DSA(72) CL583-0226-1-72 16 34.04 29.04 24.04 17.78 PCN10C-120S-2.54DSA(72) CL583-0079-9-72 20 39.12 34.12 29.12 22.86 PCN10C-132S-2.54DSA(72) CL583-0033-8-72 32 54.36 49.36 44.36 38.10 PCN10C-144S-2.54DSA(72) CL583-0034-0-72 44 69.60 64.60 59.60 53.34 PCN10C-150S-2.54DSA(72) CL583-0035-3-72 50 77.22 72.22 67.22 60.96 PCN10C-164S-2.54DSA(72) CL583-0036-6-72 64 95.00 90.00 85.00 78.74 PCN10C-190S-2.54DSA(72) CL583-0037-9-72 90 128.02 123.02 118.02 111.76 PCN10C-100S-2.54DSA(72) CL583-0112-2-72 100 140.72 135.72 130.72 124.46 RoHS YES PCN Series●Product Compliant to DIN41612/IEC603-2 Standard ■Board Prefixed Lock Pin Type (DIN standard type B) Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ●Flux prevention type PCN10EA*S-2.54DSA(72) ●The PCB mounting pattern is equivalent to PCN10-*P-2.54DSA and PCN10C-*P-2.54DSA. (Refer to catalog page A21 and A22.) Unit:mm Part Number CL No. Number of Contacts A B C D RoHS PCN10EA-120S-2.54DSA(72) CL583-0188-4-72 20 39.12 34.12 29.12 22.86 PCN10EA-132S-2.54DSA(72) CL583-0189-7-72 32 54.36 49.36 44.36 38.10 PCN10EA-144S-2.54DSA(72) CL583-0190-6-72 44 69.60 64.60 59.60 53.34 PCN10EA-150S-2.54DSA(72) CL583-0191-9-72 50 77.22 72.22 67.22 60.96 YES PCN10EA-164S-2.54DSA(72) CL583-0192-1-72 64 95.00 90.00 85.00 78.74 PCN10EA-190S-2.54DSA(72) CL583-0193-4-72 90 128.02 123.02 118.02 111.76 PCN10EA-100S-2.54DSA(72) CL583-0194-7-72 100 140.72 135.72 130.72 124.46 ■Receptacle: 2-row Straight Type (Rack installation type) PCN10D*S-2.54DSA(72) BPCB mounting pattern Unit:mm Part Number CL No. Number of Contacts A B C D RoHS PCN10D-50S-2.54DSA(72) CL583-0055-0-72 50 77.22 72.22 67.22 60.96 PCN10D-64S-2.54DSA(72) CL583-0056-3-72 64 95.00 90.22 85.00 78.74 YES PCN10D-90S-2.54DSA(72) CL583-0057-6-72 90 128.02 123.02 118.02 111.76 A23 PCN Series●Product Compliant to DIN41612/IEC603-2 Standard Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ■Pin Header: 3-row Right Angle Type (DIN standard type C) PCN10-*P-2.54DS(72) BPCB mounting pattern The 48 contact type contains guide key grooves at 8 points. Unit:mm Part Number CL No. Number of Contacts A B C D E PCN10-48P-2.54DS(72) CL583-0063-9-72 48 53.36 47.36 44.61 38.10 48.26 PCN10-96P-2.54DS(72) CL583-0001-1-72 96 94.00 88.00 85.25 78.74 88.90 RoHS YES ■Pin Header: 3-row Right Angle Type PCN10A-*P-2.54DS(72) BPCB mounting pattern The 48 contact type contains guide key grooves at 8 points. Unit:mm Part Number A24 CL No. Number of Contacts A B C D E PCN10A-48P-2.54DS(72) CL583-0064-1-72 48 53.36 47.36 44.61 38.10 48.26 PCN10A-96P-2.54DS(72) CL583-0006-5-72 96 94.00 88.00 85.25 78.74 88.90 RoHS YES PCN Series●Product Compliant to DIN41612/IEC603-2 Standard ■Pin Header: Right Angle Type Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. PCN10-64ACP-2.54DS(72) CL583-0046-0-72 RoHS Compliant BPCB mounting pattern ■Pin Header: Right Angle Type PCN10A-64ACP-2.54DS(72) CL583-0032-5-72 RoHS Compliant BPCB mounting pattern A25 PCN Series●Product Compliant to DIN41612/IEC603-2 Standard ■Pin Header: 3-row Straight Type (DIN standard type R) Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. PCN10-96P-2.54DSA(72) CL583-0002-4-72 RoHS Compliant BPCB mounting pattern ■Pin Header: 3-row Straight Type PCN10-48P-2.54DSA(72) CL583-0104-4-72 RoHS Compliant BPCB mounting pattern A26 PCN Series●Product Compliant to DIN41612/IEC603-2 Standard ■Receptacle: 3-row Right Angle Type Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. PCN10A-96S-2.54DS(72) CL583-0027-5-72 RoHS Compliant BPCB mounting pattern ■Receptacle: 3-row Right Angle Type(DIN standard type R) PCN10B-96S-2.54DS(72) CL583-0004-0-72 RoHS Compliant BPCB mounting pattern A27 PCN Series●Product Compliant to DIN41612/IEC603-2 Standard Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ■Receptacle: 3-row Straight Type(DIN standard type C) A28 PCN10*S-2.54DSA(72) BPCB mounting pattern The 48 contact type contains guide key grooves at 8 points. Unit:mm Part Number * Number of Contacts A B PCN10-48S-2.54DSA(72) CL583-0065-4-72 CL No. 48 54.36 50 44.36 38.10 C D PCN10-96S-2.54DSA(72) CL583-0003-7-72 96 95.00 90 85.00 78.74 PCN10-96S-2.54WA(72) CL583-0085-1-72 96 95.00 90 85.00 78.74 PCN10-96S-2.54WB(72) CL583-0071-7-72 96 95.00 90 85.00 78.74 RoHS YES PCN Series●Product Compliant to DIN41612/IEC603-2 Standard ■Receptacle: 3-row Straight Type(DIN standard type C) Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ●With Board prefixed lock pin PCN10EA*S-2.54DSA(72) Note: The PCB mounting pattern is equivalent to PCN10-*S-2.54DSA(72). Unit:mm (Refer to catalog page A21.) Part Number CL No. Number of Contacts A B C D PCN10EA-48S-2.54DSA(72) CL583-0195-0-72 48 54.36 50 44.36 38.10 Note PCN10EA-96S-2.54DSA(72) CL583-0180-2-72 96 95.00 90 85.00 78.74 RoHS YES Note: Flux prevention type ■Receptacle: Straight Type PCN10-64ACS-2.54DSA(72) CL583-0044-4-72 RoHS Compliant BPCB mounting pattern A29 PCN Series●Product Compliant to DIN41612/IEC603-2 Standard ■Pin Header: 3-row Right Angle Type ●With Board prefixed lock pin Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. PCN10MA-144P-2.54DS(72) CL583-0131-7-72 RoHS Compliant BPCB mounting pattern ■Receptacle: 3-row Straight Type ●Board prefixed lock pin attached PCN10MA-144S-2.54DSA(72) CL583-0130-4-72 RoHS Compliant BPCB mounting pattern A30 Sequential contacts are located at 27 points up to contact No.30~38 in both rows b and c. PCN Series●Product Compliant to DIN41612/IEC603-2 Standard ■Pin Header: 4-row Right Angle Type Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. PCN10-128P-2.54DS(72) CL583-0087-7-72 RoHS Compliant BPCB mounting pattern ■Pin Header: 4-row Right Angle Type PCN10A-128P-2.54DS(72) CL583-0088-0-72 RoHS Compliant BPCB mounting pattern A31 PCN Series●Product Compliant to DIN41612/IEC603-2 Standard ■Pin Header: 4-row Straight Type Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. PCN10-128P-2.54DSA(72) CL583-0215-5-72 RoHS Compliant BPCB mounting pattern ■Receptacle: 4-row Straight Type PCN10-128S-2.54DSA(72) BPCB mounting pattern Unit:mm Part Number * A32 CL No. Number of Contacts RoHS PCN10-128S-2.54DSA(72) CL583-0089-2-72 128 PCN10-128S-2.54WA(72) CL583-0090-1-72 128 PCN10-128S-2.54WB(72) CL583-0091-4-72 128 YES PCN Series●Product Compliant to DIN41612/IEC603-2 Standard ■Receptacle: 4-row Right Angle Type Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. PCN10B-128S-2.54DS(72) CL583-0333-1-72 RoHS Compliant BPCB mounting pattern A33 PCN Series●Product Compliant to DIN41612/IEC603-2 Standard Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ■Polarizing Key A34 Part Number CL No. Material RoHS PCN10-GK(A) 583-0269-4 PBT, black YES Note: Using the polarizing key prevents connector mis-insertion in the board. Insert the polarizing key in both connectors on the receptacle side and header side. Insert the polarizing key so as to hit the mold bottom. PCN Series●Product Compliant to DIN41612/IEC603-2 Standard Ribbon Cable Connector Compliant with DIN Standard ■Cable Insulation displacement Connector Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. PCN10-64S-2.54R(52) CL583-0030-0-52 RoHS Compliant ■Insulation displacement Tool ●Guide plate for insulation displacement + pressing block ●Hi-Flex connection press PCN10-GPB64 CL550-0168-6 Part Number CL No. Hi-Flex connection press HHP502 550-0082-2 Height Width Depth 440mm 160mm 350mm Weight 13kg A35 PCN Series●Product Compliant to DIN41612/IEC603-2 Standard Crimping Connector Compliant with DIN Standard ■3-row Type PCN10-96S-2.54C CL583-0100-3 Current rated Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Voltage rated 2A ( ID type 1A Crimping type AWG#26 2A AWG#28·30 1A ) 300V AC (Crimping type 200V AC) RoHS Compliant ■2-row Type PCN10-*S-2.54C Unit:mm A36 Part Number CL No. Number of Contacts PCN10-20S-2.54C CL583-0241-5 20 39.12 34.12 29.12 22.86 A B C D PCN10-64S-2.54C CL583-0243-0 64 95.00 90.00 85.00 78.74 RoHS YES PCN Series●Product Compliant to DIN41612/IEC603-2 Standard ■Manual Crimping Tool Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ●Crimping Contact ●PCN10-2630SC (Full Gold plated) CL583-0102-9 (RoHS Compliant) ●PCN10-2226SC (Selective Gold plated) CL583-0216-8 (RoHS Compliant) ●Crimping tool ●PCN10-TA2630HC (PCN10-2230SC) CL550-0163-2 ●PCN10-TA2226HC (PCN10-2226SC) CL550-0218-2 Applicable Cable ●PCN10-2630SC: AWG#26 to #30 100pcs per bag ●PCN10-2226SC: AWG#22 to #26 100pcs per bag ■Automatic Crimping Tool Item Part Number CL No. Applicable Contact Crimping tool unit CM-105 901-0005-4 ————————— AP105-PCN10-2226S 901-3506-6 PCN10-2226SCF AP105-PCN10-2630S 901-3508-1 PCN10-2630SCF Applicator ■Contact Extraction Tool Part Number CL No. PCN10-PO 550-0282-1 A37 PCN Series●Product Compliant to DIN41612/IEC603-2 Standard Circuit Protection Function Type ■Pin Header: 3-row Right Angle Type Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. PCN10MC-96P-2.54DS(72) CL583-0120-0-72 RoHS Compliant BPCB mounting pattern ■Receptacle: 3-row Straight Type PCN10MC-96S-2.54DSA(72) CL583-0169-0-72 RoHS Compliant BPCB mounting pattern A38 PCN Series●Product Compliant to DIN41612/IEC603-2 Standard ■Receptacle: 3-row Wrapping Type Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. PCN10MC-96S-2.54WB(72) CL583-0119-1-72 RoHS Compliant BPCB mounting pattern ■Pin Header: 2-row Right Angle Type PCN10MC-*P-2.54DS(72) BPCB mounting pattern Unit:mm Part Number CL No. Number of Contacts PCN10MC-064P-2.54DS(72) CL583-0211-4-72 64 PCN10MC-100P-2.54DS(72) CL583-0212-7-72 100 A 94.0 B C D 85.35 78.74 88.9 139.72 131.07 124.46 134.62 RoHS YES A39 PCN Series●Product Compliant to DIN41612/IEC603-2 Standard ■Receptacle: 2-row Straight Type Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. PCN10MC-*S-2.54DSA(72) A40 BPCB mounting pattern (64 contacts): The sequential contacts are located at 27 points of 1 to 4 and 26 to 32 in both rows a and b. (100 contacts): The sequential contacts are located at 22 points of 1 to 4 and 44 to 50 in both rows a and b. Unit:mm Number of Contacts A B C D PCN10MC-064S-2.54DSA(72) CL583-0213-0-72 Part Number CL No. 64 95.0 90.0 85.0 78.74 PCN10MC-100S-2.54DSA(72) CL583-0214-2-72 100 140.72 135.72 130.72 124.46 RoHS YES PCN Series●Product Compliant to DIN41612/IEC603-2 Standard Stacking Connector Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ■Stacking Plug BPCB mounting pattern BApplication Pattern Unit: mm Part Number CL No. Number of Contacts PCN10H- 16P-2.54DSA(72) PCN10H- 20P-2.54DSA(72) PCN10H- 24P-2.54DSA(72) PCN10H- 32P-2.54DSA(72) PCN10H- 44P-2.54DSA(72) PCN10H- 50P-2.54DSA(72) PCN10HA-16P-2.54DSA(72) PCN10HA-20P-2.54DSA(72) PCN10HA-24P-2.54DSA(72) PCN10HA-32P-2.54DSA(72) PCN10HA-44P-2.54DSA(72) PCN10HA-50P-2.54DSA(72) PCN10HB-16P-2.54DSA(72) PCN10HB-20P-2.54DSA(72) PCN10HB-24P-2.54DSA(72) PCN10HB-32P-2.54DSA(72) PCN10HB-44P-2.54DSA(72) PCN10HB-50P-2.54DSA(72) PCN10HC-16P-2.54DSA(72) PCN10HC-44P-2.54DSA(72) PCN10HC-50P-2.54DSA(72) PCN10HD-16P-2.54DSA(72) PCN10HD-24P-2.54DSA(72) PCN10HD-44P-2.54DSA(72) PCN10HD-50P-2.54DSA(72) CL583-0227-4-72 CL583-0157-0-72 CL583-0425-8-72 CL583-0161-8-72 CL583-0164-6-72 CL583-0401-0-72 CL583-0228-7-72 CL583-0158-3-72 CL583-0426-0-72 CL583-0162-0-72 CL583-0165-9-72 CL583-0402-2-72 CL583-0229-0-72 CL583-0159-6-72 CL583-0427-3-72 CL583-0163-3-72 CL583-0166-1-72 CL583-0403-5-72 CL583-0397-4-72 CL583-0399-0-72 CL583-0404-8-72 CL583-0398-7-72 CL583-0429-9-72 CL583-0400-7-72 CL583-0405-0-72 16 20 24 32 44 50 16 20 24 32 44 50 16 20 24 32 44 50 16 44 50 16 24 44 50 A 37.92 43.00 48.08 58.24 73.48 81.10 37.92 43.00 48.08 58.24 73.48 81.10 37.92 43.00 48.08 58.24 73.48 81.10 37.92 73.48 81.10 37.92 48.08 73.48 81.10 B 33.02 38.10 43.18 53.34 68.58 76.20 33.02 38.10 43.18 53.34 68.58 76.20 33.02 38.10 43.18 53.34 68.58 76.20 33.02 68.58 76.20 33.02 43.18 68.58 76.20 C 24.39 29.47 34.55 44.71 59.95 67.57 24.39 29.47 34.55 44.71 59.95 67.57 24.39 29.47 34.55 44.71 59.95 67.57 24.39 59.95 67.57 24.39 34.55 59.95 67.57 D 17.78 22.86 27.94 38.10 53.34 60.96 17.78 22.86 27.94 38.10 53.34 60.96 17.78 22.86 27.94 38.10 53.34 60.96 17.78 53.34 60.96 17.78 27.94 53.34 60.96 E F G 29.8 3.44 35 24.8 3.36 30 RoHS YES 19.8 3.28 25 39.8 3.30 45 34.8 4.42 40 Note: Please note that the above series can not mate with PCN10EA series. A41 PCN Series●Product Compliant to DIN41612/IEC603-2 Standard PCN12 Series Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ■Plug: 2-row Right Angle Type Lot No. Merking Unit:mm PCN10-*P-2.54DS(71) BPCB mounting pattern Part Number Number of Contacts A B C D RoHS 10 25.42 16.77 10.16 20.32 PCN12A-120P-2.54DS(71) CL583-2012-9-71 20 38.12 29.47 22.86 33.02 PCN12A-128P-2.54DS(71) CL583-2085-2-71 28 48.26 39.63 33.02 43.18 PCN12A-132P-2.54DS(71) CL583-2013-1-71 32 53.36 44.71 38.10 48.26 YES PCN12A-144P-2.54DS(71) CL583-2014-4-71 44 68.60 59.95 53.34 63.50 PCN12A-150P-2.54DS(71) CL583-2015-7-71 50 76.22 67.57 60.96 71.12 PCN12A-164P-2.54DS(71) CL583-2016-0-71 64 94.00 85.35 78.74 88.90 ■Plug: 2-row Right Angle Type ●With board prefixed lock pin attached Lot No. Merking PCN12EA-*P-2.54DS(71) BPCB mounting pattern A42 CL No. PCN12A-110P-2.54DS(71) CL583-2010-3-71 Unit:mm Part Number CL No. Number of Contacts A B C D PCN12EA-110P-2.54DS(71) CL583-2028-9-71 10 25.42 16.77 10.16 20.32 PCN12EA-116P-2.54DS(71) CL583-2029-1-71 16 33.04 24.39 17.78 27.94 PCN12EA-120P-2.54DS(71) CL583-2030-0-71 20 38.12 29.47 22.86 33.02 PCN12EA-132P-2.54DS(71) CL583-2031-3-71 32 53.36 44.71 38.10 48.26 PCN12EA-144P-2.54DS(71) CL583-2032-6-71 44 68.60 59.95 53.34 63.50 PCN12EA-150P-2.54DS(71) CL583-2033-9-71 50 76.22 67.57 60.96 71.12 PCN12EA-164P-2.54DS(71) CL583-2034-1-71 64 94.00 85.35 78.74 88.90 PCN12EA-190P-2.54DS(71) CL583-2035-4-71 90 127.02 118.37 111.76 121.92 RoHS YES PCN Series●Product Compliant to DIN41612/IEC603-2 Standard Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ■Socket: Straight Type Unit:mm Part Number PCN12-*S-2.54DSA(71) BPCB mounting pattern CL No. Number of Contacts A B C D RoHS PCN12-110S-2.54DSA(71) CL583-2055-1-71 10 26.42 21.42 16.42 10.16 PCN12-116S-2.54DSA(71) CL583-2056-4-71 16 34.04 29.04 24.04 17.78 PCN12-120S-2.54DSA(71) CL583-2057-7-71 20 39.12 34.12 29.12 22.86 PCN12-124S-2.54DSA(71) CL583-2106-0-71 24 44.20 39.20 34.20 27.94 PCN12-128S-2.54DSA(71) CL583-2088-0-71 28 49.28 44.28 39.28 33.02 PCN12-132S-2.54DSA(71) CL583-2058-0-71 32 54.36 49.36 44.36 38.10 YES PCN12-144S-2.54DSA(71) CL583-2059-2-71 44 69.60 64.60 59.60 53.34 PCN12-150S-2.54DSA(71) CL583-2060-1-71 50 77.22 72.22 67.22 60.96 PCN12-164S-2.54DSA(71) CL583-2061-4-71 64 95.00 90.00 85.00 78.74 PCN12-190S-2.54DSA(71) CL583-2062-7-71 90 128.02 123.02 118.02 111.76 PCN12-100S-2.54DSA(71) CL583-2063-0-71 100 140.72 135.72 130.72 124.46 ■Socket: Straight Type ●With Board prefixed lock pin attached PCN12E-*S-2.54DSA(71) BPCB mounting pattern Unit:mm Part Number CL No. Number of Contacts A B C D PCN12E-110S-2.54DSA(71) CL583-2064-2-71 10 26.42 21.42 16.42 10.16 PCN12E-120S-2.54DSA(71) CL583-2066-8-71 20 39.12 34.12 29.12 22.86 PCN12E-132S-2.54DSA(71) CL583-2067-0-71 32 54.36 49.36 44.36 38.10 PCN12E-144S-2.54DSA(71) CL583-2068-3-71 44 69.60 64.60 59.60 53.34 PCN12E-150S-2.54DSA(71) CL583-2069-6-71 50 77.22 72.22 67.22 60.96 PCN12E-164S-2.54DSA(71) CL583-2070-5-71 64 95.00 90.00 85.00 78.74 PCN12E-190S-2.54DSA(71) CL583-2071-8-71 90 128.02 123.02 118.02 111.76 PCN12E-100S-2.54DSA(71) CL583-2072-0-71 100 140.72 135.72 130.72 124.46 RoHS YES A43 PCN Series●Product Compliant to DIN41612/IEC603-2 Standard ■Plug: 3-row Right Angle Type (DIN standard type C) Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. PCN12-96P-2.54DS(71) CL583-2090-2-71 PCN10C-πS-2.54DS RoHS Compliant BPCB mounting pattern ■Plug: 3-row Right Angle Type PCN12A-96P-2.54DS(71) CL583-2091-5-71 RoHS Compliant PCN10-πS-2.54DSA BPCB mounting pattern A44 PCN Series●Product Compliant to DIN41612/IEC603-2 Standard ■Plug: 3-row Right Angle Type (Type C) ●With Board prefixed lock pin Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. PCN12E-96P-2.54DS(71) CL583-2092-8-71 RoHS Compliant BPCB mounting pattern ■Plug: 3-row Right Angle Type ●With Board prefixed lock pin PCN12EA-96P-2.54DS(71) CL583-2093-0-71 RoHS Compliant BPCB mounting pattern A45 PCN Series●Product Compliant to DIN41612/IEC603-2 Standard ■Socket: 3-row Straight Type Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. PCN12-96S-2.54DSA(71) CL583-2096-9-71 RoHS Compliant BPCB mounting pattern ■Socket: 3-row Straight Type PCN12E-96S-2.54DSA(71) CL583-2097-1-71 RoHS Compliant BPCB mounting pattern A46 PCN Series●Product Compliant to DIN41612/IEC603-2 Standard PCN13 Series Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ■Socket: 2-row Straight Type Unit:mm PCN13-*S-2.54DSA(71) BPCB mounting pattern Part Number CL No. Number of Contacts A B C D RoHS PCN13-116S-2.54DSA(71) CL583-3001-8-71 16 34.04 29.04 24.04 17.78 PCN13-120S-2.54DSA(71) CL583-3002-0-71 20 39.12 34.12 29.12 22.86 PCN13-132S-2.54DSA(71) CL583-3004-6-71 32 54.36 49.36 44.36 38.10 PCN13-144S-2.54DSA(71) CL583-3005-9-71 44 69.60 64.60 59.60 53.34 PCN13-150S-2.54DSA(71) CL583-3006-1-71 50 77.22 72.22 67.22 60.96 PCN13-164S-2.54DSA(71) CL583-3007-4-71 64 95.00 90.00 85.00 78.74 PCN13-190S-2.54DSA(71) CL583-3008-7-71 90 128.02 123.02 118.02 111.76 PCN13-100S-2.54DSA(71) CL583-3009-0-71 100 140.72 135.72 130.72 124.46 YES ■Socket: 2-row Right Angle Type PCN13-*S-2.54DS(71) BPCB mounting pattern Unit:mm Part Number CL No. Number of Contacts A B C D PCN13-116S-2.54DS(71) CL583-3031-9-71 16 38.02 24.04 17.78 33.02 PCN13-120S-2.54DS(71) CL583-3032-1-71 20 43.10 29.12 22.86 38.10 PCN13-130S-2.54DS(71) CL583-3033-4-71 30 55.80 41.82 35.56 50.80 PCN13-132S-2.54DS(71) CL583-3034-7-71 32 58.34 44.36 38.10 53.34 PCN13-144S-2.54DS(71) CL583-3035-0-71 44 73.58 59.60 53.34 68.58 PCN13-150S-2.54DS(71) CL583-3036-2-71 50 81.20 67.22 60.96 76.20 PCN13-164S-2.54DS(71) CL583-3037-5-71 64 98.98 85.00 78.74 93.98 PCN13-100S-2.54DS(71) CL583-3039-0-71 100 144.70 130.72 124.46 139.70 RoHS YES A47 PCN Series●Product Compliant to DIN41612/IEC603-2 Standard Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ■Socket: 3-row Straight Type PCN13-48S-2.54DSA(71) 96S BPCB mounting pattern Unit:mm Part Number CL No. Number of Contacts A B C D RoHS PCN13-48S-2.54DSA(71) CL583-3010-9-71 48 54.36 50.00 44.36 38.10 PCN13-96S-2.54DSA(71) CL583-3011-1-71 96 95.00 90.00 85.00 78.74 YES ■Socket: 3-row Right Angle Type PCN13-48S-2.54DS(71) 96S BPCB mounting pattern Unit:mm Part Number A48 CL No. Number of Contacts A B C D PCN13-48S-2.54DS(71) CL583-3040-0-71 48 53.36 44.36 38.10 48.26 PCN13-96S-2.54DS(71) CL583-3041-2-71 96 94.00 85.00 78.74 88.90 RoHS YES PCN Series●Product Compliant to DIN41612/IEC603-2 Standard BApplication Pattern ●Vertical Connection ' : Mounting hole center C.L. : Center line Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ●2-row type A49 A50 48 contacts: 17.9 ●3-row type ' 48 contacts: 19.09 48 contacts: 19.09 Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. PCN Series●Product Compliant to DIN41612/IEC603-2 Standard C.L. : Center line : Mounting hole center PCN Series●Product Compliant to DIN41612/IEC603-2 Standard ' : Mounting hole center ●3-row 144 Contact type 48 contacts: 19.09 Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. C.L. : Center line ●4-row type A51 PCN Series●Product Compliant to DIN41612/IEC603-2 Standard BApplication Pattern ●Horizontal Connection ' Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ●2-row type ●4-row type A52 : Mounting hole center C.L. : Center line PCN Series●Product Compliant to DIN41612/IEC603-2 Standard ' : Mounting hole center C.L. : Center line 48 contacts: 19.09 Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ●3-row type A53 PCN Series●Product Compliant to DIN41612/IEC603-2 Standard BApplication Pattern ●Horizontal Connection ' 48 contacts: 17.9 ●3-row type ●4-row type A54 : Mounting hole center C.L. : Center line 48 contacts: 17.9 Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ●2-row type PCN Series●Product Compliant to DIN41612/IEC603-2 Standard BApplication Pattern ' ■Circuit Protection Function Type Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ●2-row type Powered by TCPDF (www.tcpdf.org) : Mounting hole center C.L. : Center line ●3-row type 64 contacts : The sequential contacts are indicated at 22 points to contact No.1 to 4 and 26 to 32 in both rows a and b. 100 contacts : The sequential contacts are located at 22 points to a1 and a32. The sequential contact is indicated at 22 points to contact No.1 to 4 and 44 to 50 in both rows a and b. ' ■Stacking Connector : Mounting hole center C.L. : Center line *G : 35, 30, 25, 45, 40 A55
PCN13-32S-2.54DS 价格&库存
很抱歉,暂时无法提供与“PCN13-32S-2.54DS”相匹配的价格&库存,您可以联系我们找货
