SF9821-6000
SF9821-6000
    AMPHENOLSVMICROWAVE(安费诺MAO)
    BMZ PIN D38999 CONTACT (SIZE 8)
SF9821-6000 数据手册
ROHS COMPLIANT REVISION HISTORY DESCRIPTION REV PRODUCT DATA DRAWING C .463 11.75 DCN 38472 DATE APPROVED 08/11 STW .416 10.57 .031±.002 0.77±0.05 .3145±.0015 7.99±0.04 +0.03 +.001 .275 6.99 - .002 - 0.05 .2145±.0010 5.45±0.03 .090±.001 2.29±0.03 .180 4.57 .278 7.05 RP .120 3.05 MATERIAL: BODY: STAINLESS STEEL PER AMS-5640, ALLOY UNS S30300, TYPE 1 FERRULE: BRASS PER ASTM B16, ALLOY UNS No. C36000 CONTACT: BERYLLIUM COPPER PER ASTM B196, ALLOY No. UNS C17300, TD04 INSULATOR: PTFE PER ASTM D1710, TYPE I, GRADE 1, CLASS B FINISH: BODY: PASSIVATED PER AMS-2700, TYPE 2. CONTACT & FERRULE: GOLD PER ASTM B488, TYPE II, CODE C, CLASS 1.27; OVER NICKEL PER AMS-QQ-N-290, CLASS 1, .00005" MIN. SIZE 8 PIN CONTACT PERFORMANCE: IMPEDANCE: FREQ. RANGE: VSWR: INSERTION LOSS: DWV: OPERATING TEMP.: 50 OHMS DC TO 18.0 GHz 1.25:1 MAX. MATED PAIR DC TO 18.0 GHz .06 X SQRT(F(F IN GHz)) 1000 VRMS -55 C TO +125 C MATERIAL: FINISH: SEE NOTES SEE NOTES SURFACE AREA: N/A PROPRIETARY THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF SV MICROWAVE, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF SV MICROWAVE, INC IS PROHIBITED. DIMENSIONS ARE IN INCHES TOLERANCES: FRACTIONAL: DECIMAL: .X .XX .XXX 1/64 ANGULAR: X X X' 1 0' 15' .030 .010 .005 INTERPRET DIMENSIONS AND TOLERANCES PER ASME Y14.5M - 1994 THIRD ANGLE PROJECTION SV Microwave, Inc. UNLESS OTHERWISE SPECIFIED 1) ALL DIMENSIONS ARE IN INCHES [MILLIMETERS] 2) ALL DIMENSIONS ARE AFTER PLATING. 3) BREAK CORNERS & EDGES .005 R. MAX. 4) CHAM. 1ST & LAST THREADS. 63 MIL-STD-10. 5) SURFACE ROUGHNESS 6) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC WITHIN .005 T.I.R. 7) REMOVE ALL BURRS DRAWN: JMC 03/15/07 CHECKED: APPROVED: STW 05/07/07 STW 05/07/07 2400 Centrepark West Drive, Suite 100 West Palm Beach, FL 33409 TITLE: 18 GHZ BMZ FEMALE TO TFLEX-405 FOR M38999 SIZE 8 CAVITY SIZE CAGE CODE DWG. NO. B 95077 SCALE: 6:1 SF9821-6000 SHEET 1 OF 1
SF9821-6000 价格&库存
很抱歉,暂时无法提供与“SF9821-6000”相匹配的价格&库存,您可以联系我们找货
