BU-31605-2
BU-31605-2
    MUELLERELECTRIC
    BANANAJACK4MMCRIMPTERMRED
BU-31605-2 数据手册
                                          BU‐31605‐@                              (Press‐fit, UL® Listed Banana Jack with Solder Cup Connection)       Mueller’s BU‐31605 is a press fit, front installed UL® Listed 4mm banana  jack with a solder cup connection. The jack accepts shrouded, unshrouded,  and retractable 4mm banana plugs.   Recommended Mounting Hole: 7/16” (11.2mm)   Uses wire up to 18 AWG Wire.   Overall length of 1.25” (31.8mm)   Material:  o Housing – Nylon  o Contacts – Nickel plated Brass   Ratings:  15 Amps, 1000 Volts CAT III   Color:  The “@” in the model number represents color.  Available colors:  ‐0 Black,  ‐2 Red,  ‐4 Yellow,  ‐5 Green,  ‐6 Blue,  ‐9 White   RoHS 3 Compliant,   Certified  Mueller Electric Company 2850 Gilchrist Rd. Bld 5A Akron, OH 44305   www.muellerelectric.com Toll Free: 800.955.2629 Phone: 330.780.2525 Fax: 330.780.2524
BU-31605-2 价格&库存
很抱歉,暂时无法提供与“BU-31605-2”相匹配的价格&库存,您可以联系我们找货
