A Global Leader in the Design, Development, and
Manufacture of Sensor and Magnetic Components
www.standexmeder.com
Series Datasheet – 567 Optocouplers
567 Series
Optocouplers
Features: ATEX Optocoupler for Intrinsically Safe Circuits
Applications: Electronics for Mining, Test & Measurement, Automation Technology
Markets: Oil & Gas Production, Refinery, Mining, Medical, Test and Measurement, and others
567-04-0-i
Part Description:
Customer Options
Coupler Characteristics
Unit
Isolation Voltage Input / Output (min.)
4,000
VDC
50
mA
0.5
μsec
0.5
μsec
Collector Voltage (max.)
15
VDC
Creeping Distance (min.)
14.0
mm
Air Path Input / Output (min.)
14.0
mm
Insulation Distance Ermitter-Detecto (min.)
6.0
mm
Insulation Resistance Input / Output (min.)
1013
Ohm
Transmission Frequencies (typ.)
500
kHz
Output Current Io (max.)
Turn On Time (typ.)
Ton
Turn-Off Time (typ.)
Toff
USA:
Europe:
Asia:
+1.866.782.6339
+49.7731.8399.0
+86.21.37820625
│ salesusa@standexmeder.com
│ info@standexmeder.com
│ salesasia@standexmeder.com
Modifications in the sense of technical progress are reserved.
Version 01
27.01.2015
567 Optocoupler
Housing and Material Specifications
Housing Material
P6 G
Case Color
Black
Sealing Compound
Wevopur 552 FL
Connection Pins
Cu-Alloy, Tinned
Washability
Fully Sealed
Environmental Data
Unit
Shock Resistance (max.)
1/2 sine wave duration 11ms
Vibration Resistance (max.)
Operating Temperature
Storage Temperature
Soldering Temperature (max.)
5 sec. max.
50
g
g
-20 to 85
°C
-40 to 100
°C
260
°C
Test Circuit and Layout
Test Circuit
Handling Instructions
It is advised that normal static precautions be taken in
handling and assembly of this component to prevent damage
and/or degradation which may be induced by ESC.
Transfer Characteristics (IFT)
Layout
USA:
Europe:
Asia:
+1.866.782.6339
+49.7731.8399.0
+86.21.37820625
Version 01
27.01.2015
很抱歉,暂时无法提供与“567-70-1-I”相匹配的价格&库存,您可以联系我们找货
