IL514E
IL514E
    NVECORP
    SOIC16
    DGTL ISO 2.5KV GEN PURP 16SOIC
IL514E 数据手册
IL500-Series Isolators DC-Correct Digital Isolators Functional Diagrams Features IL510 • • • • • • • • • • • • • IL514 IL511 2 Mbps maximum speed DC-correct 3 V to 5 V power supplies 1.3 mA/channel typical quiescent current −40 ºC to 85 ºC operating temperature 50 kV/μs typ.; 30 kV/μs min. common mode transient immunity 44000 year barrier life 10 ns pulse width distortion 25 ns propagation delay Low EMC footprint 2500 VRMS isolation IEC 60747-17 (VDE 0884-17):2021-10 certified; UL 1577 recognized 8-pin MSOP and SOIC; 0.15", 0.3", and True 8™ mm 16-pin SOIC packages Applications IL515 IL521 • • • • • • • • • • • ADCs and DACs Digital Fieldbus RS-485 and RS-422 Multiplexed data transmission Data interfaces Board-to-board communication Digital noise reduction Ground loop elimination Peripheral interfaces Parallel bus Logic level shifting Description IL500-Series isolators are low-cost isolators operating up to 2 Mbps over an operating temperature range of −40 ºC to 85 ºC. IL516 The devices use NVE’s patented* spintronic Giant Magnetoresistive (GMR) technology. A unique ceramic/polymer composite barrier provides excellent isolation and virtually unlimited barrier life. IsoLoop is a registered trademark of NVE Corporation. *U.S. Patent numbers 5,831,426; 6,300,617 and others. NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344 REV. Q (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL500-Series Isolators Absolute Maximum Ratings(1) Parameters Storage Temperature Junction Temperature Supply Voltage Input Voltage Output Voltage Output Current Drive Lead Solder Temperature ESD Symbol TS TJ VDD1, VDD2 VI VO IO Min. −55 −55 −0.5 −0.5 −0.5 Typ. Max. 150 150 7 VDD+0.5 VDD+0.5 10 260 Units °C °C V V V mA °C kV Test Conditions Max. 85 100 5.5 VDD 0.8 Units °C °C V V V Test Conditions 2 10 sec. HBM Recommended Operating Conditions Parameters Operating Ambient Temperature Operating Junction Temperature Supply Voltage Logic High Input Voltage Logic Low Input Voltage Input Signal Rise and Fall Times(10) Symbol TA TJ VDD1, VDD2 VIH VIL tIR, tIF Min. −40 −40 3.0 2.4 0 Typ. DC-Correct 2 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL500-Series Isolators Safety and Approvals IEC 60747-17 (VDE 0884-17):2021-10 (Basic Isolation; VDE File Number 5016933-4880-0001): • Isolation voltage (VISO): 2500 VRMS • Transient overvoltage (VIOTM): 4000 VPK • Surge rating 4000 V • Each part tested at 1590 VPK for 1 second, 5 pC partial discharge limit • Samples tested at 4000 VPK for 60 sec.; then 1358 VPK for 10 sec. with 5 pC partial discharge limit • Working Voltage (VIORM; pollution degree 2): Package MSOP8 SOIC8 Narrow-body SOIC16 Wide-body SOIC16/True 8™ Part No. Suffix -1 -3 -3 None Safety-Limiting Values Safety rating ambient temperature Safety rating power (180°C) Supply current safety rating (total of supplies) Working Voltage 800 VRMS 700 VRMS 700 VRMS 600 VRMS Symbol TS PS IS Value 180 270 54 Units °C mW mA UL 1577 (Component Recognition Program File Number E207481) • 2500 V rating for all types other than MSOP • Each part other than MSOP tested at 3000 VRMS (4240 VPK) for 1 second; each lot sample tested at 2500 VRMS (3530 VPK) for 1 minute • MSOP rating 1000 V; tested at 1200 VRMS (1768 VPK) for 1 second; each lot sample tested at 1500 VRMS (2121 VPK) for 1 minute Soldering Profile Per JEDEC J-STD-020C, MSL 1 3 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL500-Series Isolators IL510 Pin Connections 1 2 VDD1 IN 3 SYNC 4 5 6 GND1 GND2 OUT 7 VOE 8 VDD2 Supply voltage Data in Internal refresh clock disable (normally enabled and internally held low with 10 kΩ) Ground return for VDD1 Ground return for VDD2 Data out Output enable (internally held low with 100 kΩ) Supply voltage VDD1 VDD2 IN VOE SYNC OUT GND1 GND2 IL510 IL511 Pin Connections 1 2 3 4 5 6 7 8 VDD1 IN1 IN2 GND1 GND2 OUT2 OUT1 VDD2 Supply voltage Data in, channel 1 Data in, channel 2 Ground return for VDD1 Ground return for VDD2 Data out, channel 2 Data out, channel 1 Supply voltage VDD1 8 VDD2 1 IN1 2 7 OUT1 IN2 3 6 OUT2 GND1 4 5 GND2 IL511 IL514 Pin Connections 1 VDD1 2 GND1 3 4 5 6 IN1 IN2 OUT3 NC 7 VOE 8 GND1 9 GND2 10 11 12 13 14 NC NC IN3 OUT2 OUT1 15 GND2 16 VDD2 Supply voltage 1 Ground return for VDD1 (pin 2 internally connected to pin 8) Data in, channel 1 Data in, channel 2 Data out, channel 3 No connection Output enable, channel 3 (internally held low with 100 kΩ) Ground return for VDD1 (pin 8 internally connected to pin 2) Ground return for VDD2 (pin 9 internally connected to pin 15) No connection No connection Data in, channel 3 Data out, channel 2 Data out, channel 1 Ground return for VDD2 (pin 15 internally connected to pin 9) Supply voltage VDD1 VDD2 GND1 GND2 IN1 OUT1 IN2 OUT2 OUT3 IN3 NC NC VOE NC GND2 GND1 IL514 4 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL500-Series Isolators IL515 Pin Connections 1 VDD1 2 GND1 3 4 5 6 7 IN1 IN2 IN3 IN4 NC 8 GND1 9 GND2 10 11 12 13 14 15 NC OUT4 OUT3 OUT2 OUT1 GND2 16 VDD2 Supply voltage Ground return for VDD1 (pin 2 internally connected to pin 8) Data in, channel 1 Data in, channel 2 Data in, channel 3 Data in, channel 4 No connection Ground return for VDD1 (pin 8 internally connected to pin 2) Ground return for VDD2 (pin 9 internally connected to pin 15) No connection Data out, channel 4 Data out, channel 3 Data out, channel 2 Data out, channel 1 Ground return for VDD2 (pin 15 internally connected to pin 9) Supply voltage VDD1 1 16 VDD2 GND1 2 15 GND2 IN1 3 14 OUT1 IN2 4 13 OUT2 IN3 5 12 OUT3 IN4 6 11 OUT4 NC 7 10 NC GND1 8 9 GND2 IL515 IL516 Pin Connections 1 VDD1 2 GND1 3 4 5 6 7 IN1 IN2 OUT3 OUT4 NC 8 GND1 9 GND2 10 11 12 13 14 NC IN4 IN3 OUT2 OUT1 15 GND2 16 VDD2 Supply voltage Ground return for VDD1 (pin 2 internally connected to pin 8) Data in, channel 1 Data in, channel 2 Data out, channel 3 Data out, channel 4 No connection Ground return for VDD1 (pin 8 internally connected to pin 2) Ground return for VDD2 (pin 9 internally connected to pin 15) No connection Data in, channel 4 Data in, channel 3 Data out, channel 2 Data out, channel 1 Ground return for VDD2 (pin 15 internally connected to pin 9) Supply voltage VDD1 OUT1 IN2 GND1 GND2 OUT2 IN1 VDD2 VDD2 GND1 GND2 IN1 OUT1 IN2 OUT2 OUT3 IN3 OUT4 IN4 NC NC GND2 GND1 IL516 IL521 Pin Connections 1 2 3 4 5 6 7 8 VDD1 Supply voltage Data out, channel 1 Data in, channel 2 Ground return for VDD1 Ground return for VDD2 Data out, channel 2 Data in, channel 1 Supply voltage VDD1 VDD2 OUT1 IN1 IN2 OUT2 GND1 GND2 IL521 5 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL500-Series Isolators Timing Diagrams Legend tPLH tPHL tPW tPLZ tPZH tPHZ tPZL tR tF Propagation Delay, Low to High Propagation Delay, High to Low Minimum Pulse Width Propagation Delay, Low to High Impedance Propagation Delay, High Impedance to High Propagation Delay, High to High Impedance Propagation Delay, High Impedance to Low Rise Time Fall Time Truth Tables Output Enable VI L H L H VOE L L H H SYNC VO L H Z Z SYNC 0 1 Internal Refresh Clock Enabled Disabled Note: SYNC should be left open or connected to GND to enable the internal refresh clock, or connected to VDD to disable the internal clock. 6 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL500-Series Isolators Parameters Input Quiescent Supply Current IL510 IL511 IL515 IL514, IL521 IL516 Output Quiescent Supply Current IL510, IL521 IL511, IL514, IL516 IL515 Logic Input Current 3.3 Volt Electrical Specifications (Tmin to Tmax unless otherwise stated) Symbol Min. Typ. Max. Units IDD1 0.06 0.09 0.15 1.3 2.6 0.1 0.15 0.25 1.8 3.6 mA mA mA mA mA IDD2 1.3 2.6 5.2 1.8 3.6 7.2 10 mA mA mA µA II Logic High Output Voltage VOH Logic Low Output Voltage VOL Maximum Data Rate Pulse Width(7) −10 VDD − 0.1 0.8 x VDD VDD 0.9 x VDD 0 0.5 V 0.1 0.8 Switching Specifications (VDD = 3.3 V) 2 V Mbps 20 ns 25 ns PW Propagation Delay Input to Output (High to Low) Propagation Delay Input to Output (Low to High) Propagation Delay Enable to Output (High to High Impedance) Propagation Delay Enable to Output (Low to High Impedance) Propagation Delay Enable to Output (High Impedance to High) Propagation Delay Enable to Output (High Impedance to Low) Pulse Width Distortion(2) Propagation Delay Skew(3) Output Rise Time (10%−90%) Output Fall Time (10%−90%) Common Mode Transient Immunity (Output Logic High or Logic Low)(4) Channel-to-Channel Skew SYNC Internal Clock Off Time(11) Dynamic Power Consumption(6) Power Frequency Magnetic Immunity Pulse Magnetic Field Immunity Damped Oscillatory Magnetic Field Cross-axis Immunity Multiplier(9) Test Conditions IO = −20 µA, VI = VIH IO = −4 mA, VI = VIH IO = 20 µA, VI = VIL IO = 4 mA, VI = VIL CL = 15 pF VO 50% points; SYNC=0 VO 50% points; SYNC=1 tPHL 25 ns CL = 15 pF tPLH 25 ns CL = 15 pF tPHZ 5 ns CL = 15 pF tPLZ 5 ns CL = 15 pF tPZH 5 ns CL = 15 pF tPZL 5 ns CL = 15 pF PWD tPSK tR tF 10 10 3 3 ns ns ns ns CL = 15 pF CL = 15 pF CL = 15 pF CL = 15 pF VCM = 1500 VDC tTRANSIENT = 25 ns CL = 15 pF |CMH|,|CML| 1 1 30 50 tCSK tOFF 3 140 kV/µs 5 5 240 Magnetic Field Immunity(8) (VDD2= 3V, 3V
IL514E 价格&库存
很抱歉,暂时无法提供与“IL514E”相匹配的价格&库存,您可以联系我们找货
