IL721-3E
IL721-3E
    NVECORP
    SOIC8_150MIL
    General Purpose Digital Isolator 2500Vrms 2 Channel 110Mbps 30kV/µs CMTI 8-SOIC (0.154", 3.90mm Widt...
IL721-3E 数据手册
IL711/IL712/IL721 High Speed Two-Channel Digital Isolators Functional Diagrams Features • • • • • • • • • • • • • • • • • High speed: 150 Mbps typical (S-Series) High temperature: −40 °C to +125 °C (T-Series and V-Series 6 kVRMS Reinforced Isolation; 1.2 kVRMS Working Voltage (V-Series) 2.7 to 5.5 volt supply range 100 kV/μs Common Mode Transient Immunity No carrier or clock for low EMI emissions and susceptibility 1.2 mA/channel typical quiescent current 300 ps typical pulse width distortion (S-Series) 100 ps pulse jitter 2 ns channel-to-channel skew 10 ns typical propagation delay 44000 year barrier life Excellent magnetic immunity IEC 60747-17 (VDE 0884-17):2021-10 certified; UL 1577 recognized 6 kVRMS Reinforced Isolation; 1.2 kVRMS Working Voltage (V-Series) ATEX / IECEx certified for IS-to-IS intrinsically safe applications MSOP, SOIC, PDIP, and True 8 mm creepage packages Applications • • • • • • Board-to-board communication CANbus Peripheral interfaces Logic level shifting Equipment covered under IEC 61010-1 Edition 3 5 kVRMS rated IEC 60601-1 medical applications Description NVE’s IL700 family of high-speed digital isolators are CMOS devices manufactured with NVE’s patented* spintronic Giant Magnetoresistive (GMR) technology. A unique ceramic/polymer composite barrier provides excellent isolation and virtually unlimited barrier life. The IL711S and IL712S are the world’s fastest two-channel isolators, with a 150 Mbps typical data rate for both channels. Standard and S-Grade parts are specified over a temperature range of −40°C to +100°C; “T” and “V” Grade parts have a maximum operating temperature of 125°C. V- Grade versions offer extremely high isolation voltages of 6 kVRMS for wide-body packages and 2.5 kVRMS for MSOPs. The symmetric magnetic coupling barrier provides a typical propagation delay of only 10 ns and a pulse width distortion as low as 300 ps (0.3 ns), achieving the best specifications of any isolator. Minimum transient immunity of 100 kV/µs is unsurpassed. The IL711 has two transmit channels; the IL712 and IL721 have one transmit and one receive channel. The IL721 has channels reversed to better suit certain board layouts. The IL711 and IL712 are available in 8-pin MSOP, SOIC, and PDIP packages. The IL711 and IL721 are also available in NVE’s unique JEDECcompliant 16 pin package with True 8 mm creepage under IEC 60601. IsoLoop is a registered trademark of NVE Corporation. *U.S. Patent numbers 5,831,426; 6,300,617 and others. NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 Rev. AO (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL711/IL712/IL721 Absolute Maximum Ratings Parameters Storage Temperature Junction Temperature Ambient Operating Temperature(1) Supply Voltage Input Voltage Output Voltage Output Current Drive Lead Solder Temperature ESD Symbol TS TJ TA VDD1, VDD2 VI VO IO Min. −55 −55 −55 −0.5 −0.5 −0.5 Typ. Max. 150 150 130 7 VDD + 0.5 VDD + 0.5 10 260 Units °C °C °C V V V mA °C kV Test Conditions Max. Units Test Conditions 2 10 sec. HBM Recommended Operating Conditions Parameters Ambient Operating Temperature IL711/IL712/IL721/IL711S/IL712S IL711T/IL711VE/IL712T/IL721T/IL721VE Junction Temperature IL711/IL712/IL721/IL711S/IL712S IL711T/IL711VE/IL712T/IL721T/IL721VE Supply Voltage Logic High Input Voltage Logic Low Input Voltage Input Signal Rise and Fall Times Symbol Min. Typ. TA −40 100 125 TJ −40 VDD1, VDD2 VIH VIL tIR, tIF 2.7 2.4 0 110 125 5.5 VDD 0.8 1 °C °C °C °C V V V μs 2 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL711/IL712/IL721 Safety and Approvals IEC 60747-17 (VDE 0884-17):2021-10: “VE” versions (Reinforced Isolation; VDE File Number 5016933-4880-0002) • Working Voltage (VIORM): 1200 VRMS (1700 VPK) with 20% Safety Factor; pollution degree 2 • Isolation voltage (VISO): 6000 VRMS • Surge immunity (VIOSM): 12.8 kVPK • Surge rating: 8000 V • Transient overvoltage (VIOTM): 6000 VPK • Each part tested at 2387 VPK for 1 second, 5 pC partial discharge limit • Samples tested at 6000 VPK for 60 sec.; then 2122 VPK for 10 sec. with 5 pC partial discharge limit Standard versions (Basic Isolation; VDE File Number 5016933-4880-0001) • Isolation voltage (VISO): 2500 VRMS • Transient overvoltage (VIOTM): 4000 VPK • Surge rating: 4000 V • Each part tested at 1590 VPK for 1 second, 5 pC partial discharge limit. • Samples tested at 4000 VPK for 60 sec.; then 1358 VPK for 10 sec. with 5 pC partial discharge limit. • Working Voltage (VIORM; pollution degree 2): Package MSOP8 Narrow-body SOIC16 Wide-body SOIC16/True 8™ PDIP8 Part No. Suffix -1 -3 None -2 Safety-Limiting Values Safety rating ambient temperature Safety rating power (180 °C) Supply current safety rating (total of supplies) Working Voltage 800 VRMS 700 VRMS 600 VRMS 900 VRMS Symbol TS PS IS Value 180 270 54 Units °C mW mA UL 1577 (Component Recognition Program File Number E207481) • 1 kV-rated standard MSOPs tested at 1200 VRMS (1768 VPK) for 1 second; each lot sample tested at 1200 VRMS (1768 VPK) for 1 minute • 2.5 kV-rated parts tested at 3000 VRMS (4240 VPK) for 1 second; each lot sample tested at 2500 VRMS (3530 VPK) for 1 minute • 6 kV-rated VE-version parts tested at 7.2 kVRMS (10.2 kVPK) for 1 second; each lot sample tested at 6 kVRMS (8485 VPK) for 1 minute Intrinsically Safe Certification • ”VE” versions are ATEX / IEC 60079-0 / 60079-11 certified Intrinsically Safe (IS) for use in IS to IS applications. • 500 VRMS rating. Soldering Profile Per JEDEC J-STD-020C, MSL 1 3 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL711/IL712/IL721 IL711-1, -2, and -3 Pin Connections 1 2 3 4 5 6 7 8 VDD1 IN1 IN2 GND1 GND2 OUT2 OUT1 VDD2 Supply voltage Data in, channel 1 Data in, channel 2 Ground return for VDD1 Ground return for VDD2 Data out, channel 2 Data out, channel 1 Supply voltage VDD1 8 VDD2 1 IN1 2 7 OUT1 IN2 3 6 OUT2 GND1 4 5 GND2 IL711-1, -2, and -3 IL711 Pin Connections 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 GND1 VDD1 IN1 IN2 NC GND1 GND2 NC OUT2 OUT1 VDD2 GND2 Ground return for VDD1 (pins 1, 2, 7, and 8 internally connected) Supply voltage Data in, channel 1 Data in, channel 2 No connection Ground return for VDD1 (pins 1, 2, 7, and 8 internally connected) Ground return for VDD2 (pins 9, 10, 15, and 16 internally connected) No connection Data out, channel 2 Data out, channel 1 Supply voltage Ground return for VDD2 (pins 9, 10, 15, and 16 internally connected) IL711 IL712-1, -2, and -3 Pin Connections 1 2 3 4 5 6 7 8 VDD1 IN1 OUT2 GND1 GND2 IN2 OUT1 VDD2 Supply voltage Data in, channel 1 Data out, channel 2 Ground return for VDD1 Ground return for VDD2 Data in, channel 2 Data out, channel 1 Supply voltage VDD1 VDD2 IN1 OUT1 OUT2 IN2 GND1 GND2 IL712-1, -2, and -3 IL721-3 Pin Connections 1 2 3 4 5 6 7 8 VDD1 OUT1 IN2 GND1 GND2 OUT2 IN1 VDD2 Supply voltage Data out, channel 1 Data in, channel 2 Ground return for VDD1 Ground return for VDD2 Data out, channel 2 Data in, channel 1 Supply voltage VDD1 VDD2 OUT1 IN1 IN2 OUT2 GND1 GND2 IL721-3 IL721 Pin Connections 4 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL711/IL712/IL721 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 GND1 VDD1 OUT1 IN2 NC GND1 GND2 NC OUT2 IN1 VDD2 GND2 Ground return for VDD1 (pins 1, 2, 7, and 8 internally connected) Supply voltage Data out, channel 1 Data in, channel 2 No connection Ground return for VDD1 (pins 1, 2, 7, and 8 internally connected) Ground return for VDD2 (pins 9, 10, 15, and 16 internally connected) No connection Data out, channel 2 Data in, channel 1 Supply voltage Ground return for VDD2 (pins 9, 10, 15, and 16 internally connected) IL721 5 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL711/IL712/IL721 Parameters Input Quiescent Supply Current IL711 IL712/IL721 Output Quiescent Supply Current IL711 IL712/IL721 Logic Input Current 3.3 Volt Electrical Specifications (Tmin to Tmax unless otherwise stated) Symbol Min. Typ. Max. Units IDD1 8 1.2 10 1.75 μA mA IDD2 2.4 1.2 3.5 1.75 10 mA mA μA II Logic High Output Voltage VOH Logic Low Output Voltage VOL −10 VDD – 0.1 0.8 x VDD VDD 0.9 x VDD 0 0.5 V 0.1 0.8 V Test Conditions IO = −20 μA, VI = VIH IO = −4 mA, VI = VIH IO = 20 μA, VI = VIL IO = 4 mA, VI = VIL Switching Specifications (VDD = 3.3 V) Maximum Data Rate IL711/IL712/IL721 IL711S/IL712S IL711T/IL712T/IL721T Pulse Width(7) Propagation Delay Input to Output (High to Low) Propagation Delay Input to Output (Low to High) Pulse Width Distortion(2) IL711/IL712/IL721 IL711S/IL712S IL711T/IL712T/IL721T Propagation Delay Skew(3) Output Rise Time (10%–90%) Output Fall Time (10%–90%) Common Mode Transient Immunity (Output Logic High or Logic Low)(4) Channel-to-Channel Skew Dynamic Power Consumption(6) Input side Output side Power Frequency Magnetic Immunity Pulse Magnetic Field Immunity Damped Oscillatory Magnetic Field Cross-axis Immunity Multiplier(9) PW 100 130 100 10 110 140 110 7.5 Mbps Mbps Mbps ns CL = 15 pF CL = 15 pF CL = 15 pF 50% Points, VO tPHL 12 18 ns CL = 15 pF tPLH 12 18 ns CL = 15 pF 2 2 1 4 2 2 3 3 3 6 4 4 ns ns ns ns ns ns CL = 15 pF CL = 15 pF CL = 15 pF CL = 15 pF CL = 15 pF CL = 15 pF PWD tPSK tR tF |CMH|,|CML| 100 150 tCSK kV/µs 2 3 ns 140 20 240 40 μA/Mbps/ch Magnetic Field Immunity(8) (VDD2 = 3.3 V, 2.7 V < VDD1 < 5.5 V) HPF 1500 HPM 2000 HOSC 2000 KX 2.5 A/m A/m A/m Per IEC 60747 CL = 15 pF 50Hz/60Hz tp = 8 µs 0.1Hz – 1MHz Timing Diagram Legend tPLH tPHL tPW tR tF Propagation Delay, Low to High Propagation Delay, High to Low Minimum Pulse Width Rise Time Fall Time 6 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL711/IL712/IL721 Parameters Input Quiescent Supply Current IL711 IL712/IL721 Output Quiescent Supply Current IL711 IL712/IL721 Logic Input Current 5 Volt Electrical Specifications (Tmin to Tmax unless otherwise stated) Symbol Min. Typ. Max. Units IDD1 10 1.8 15 2.5 μA mA IDD2 3.6 1.8 5 2.5 10 mA mA μA II Logic High Output Voltage VOH Logic Low Output Voltage VOL −10 VDD − 0.1 0.8 x VDD VDD 0.9 x VDD 0 0.5 V 0.1 0.8 V Test Conditions IO = −20 μA, VI = VIH IO = −4 mA, VI = VIH IO = 20 μA, VI = VIL IO = 4 mA, VI = VIL Switching Specifications (VDD = 5 V) Maximum Data Rate IL711/IL712/IL721 IL711S/IL712S IL711T/IL712T/IL721T Pulse Width(7) Propagation Delay Input to Output (High to Low) Propagation Delay Input to Output (Low to High) Pulse Width Distortion(2) IL711/IL712/IL721 IL711S/IL712S IL711T/IL712T/IL721T Pulse Jitter(10) Propagation Delay Skew(3) Output Rise Time (10%–90%) Output Fall Time (10%–90%) Common Mode Transient Immunity (Output Logic High or Logic Low)(4) Channel to Channel Skew Dynamic Power Consumption(6) PW 100 130 100 10 110 150 110 7.5 Mbps Mbps Mbps ns CL = 15 pF CL = 15 pF CL = 15 pF 50% Points, VO tPHL 10 15 ns CL = 15 pF tPLH 10 15 ns CL = 15 pF 2 2 0.3 100 4 1 1 3 3 3 ns ns ns ps ns ns ns CL = 15 pF CL = 15 pF CL = 15 pF CL = 15 pF CL = 15 pF CL = 15 pF CL = 15 pF PWD tJ tPSK tR tF |CMH|,|CML| 100 6 3 3 150 tCSK 2 200 kV/µs 3 340 ns μA/Mbps Magnetic Field Immunity(8) (VDD2= 5 V, 2.7 V < VDD1 < 5.5 V) Power Frequency Magnetic Immunity HPF 3500 Pulse Magnetic Field Immunity HPM 4500 Damped Oscillatory Magnetic Field HOSC 4500 Cross-axis Immunity Multiplier(9) KX 2.5 A/m A/m A/m Per IEC 60747 CL = 15 pF per channel 50Hz/60Hz tp = 8 µs 0.1Hz – 1MHz 7 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL711/IL712/IL721 Parameter Creepage Distance (external) MSOP8 SOIC8 PDIP8 True 8™ 0.3" SOIC16 Total Barrier Thickness (internal) Leakage Current(5) Barrier Resistance(5) Barrier Capacitance(5) Comparative Tracking Index High Voltage Endurance AC (Maximum Barrier Voltage for Indefinite Life) DC Surge Immunity (“VE” Versions) Symbol Insulation Specifications Min. Typ. 3.01 4.03 6.8 8.03 0.012 RIO CIO CTI Max. ≥600 1000 mm mm mm mm mm μA Ω pF VRMS VRMS 1500 12.8 VDC kVPK 8.3 0.016 0.2 >1014 2 VIO VIOSM Barrier Life 44000 Parameter Symbol Junction–Ambient Thermal Resistance Junction–Case (Top) Thermal Resistance MSOP8 0.15" SOIC8 0.3" SOIC16 PDIP8 MSOP8 0.15" SOIC8 0.3" SOIC16 PDIP8 Junction–Ambient Thermal Resistance Junction–Case (Top) Thermal Resistance 0.3" SOIC Power Dissipation MSOP8 0.15" SOIC8 0.3" SOIC16 PDIP8 Units θJA θJC Thermal Characteristics Min. Typ. 184 134 67 114 15 10 12 36 θJA 46 θJC 9 Years Max. Per IEC 60601 240 VRMS, 60 Hz 500 V f = 1 MHz Per IEC 60112 At maximum operating temperature Per IEC 61000-4-5 100°C, 1000 VRMS, 60% CL activation energy Units Test Conditions Double-sided PCB in free air °C/W 2s2p PCB in free air per JESD51 500 675 1500 800 PD Test Conditions mW Notes (apply to both 3.3 V and 5 V specifications): 1. Absolute maximum ambient operating temperature means the device will not be damaged if operated under these conditions. It does not guarantee performance. 2. PWD is defined as |tPHL − tPLH|. %PWD is equal to PWD divided by pulse width. 3. tPSK is the magnitude of the worst-case difference in tPHL and/or tPLH between devices at 25°C. 4. CMH and CML are the maximum common mode voltage slew rates that can be applied with the outputs remaining stable and within VOL and VOH specifications. 5. Device is considered a two terminal device: pins 1–4 shorted and pins 5–8 shorted. 6. Dynamic power consumption is calculated per channel and is supplied by the channel’s input side power supply. 7. Minimum pulse width is the minimum value at which specified PWD is guaranteed. 8. The relevant test and measurement methods are given in the Electromagnetic Compatibility section on p. 9. 9. External magnetic field immunity is improved by this factor if the field direction is “end-to-end” rather than to “pin-to-pin” (see diagram on p. 9). 10. 64k-bit pseudo-random binary signal (PRBS) NRZ bit pattern with no more than five consecutive 1s or 0s; 800 ps transition time. 8 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL711/IL712/IL721 Typical Performance Graphs 35 I DD (mA / channel) 30 25 20 V DD V =5 V DD =3 .3 V 15 10 5 0 0 25 50 75 100 Operating Speed (Mbps) 125 150 Figure 1. Supply current (per channel) vs. operating speed. 1 3 V DD - V OH 0.8 V DD = 3. V V DD =5 V 0.6 0.4 0.2 0 0 5 10 15 I OH (mA) 20 25 Figure 2. Typical high output voltage vs. load. 1 .3 V DD 0.8 =3 V DD V =5 V V OL 0.6 0.4 0.2 0 0 5 10 15 I OH (mA) 20 25 Figure 3. Typical low output voltage vs. load 9 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL711/IL712/IL721 Application Information Isolator Operation Data In Isolation Barrier An equivalent circuit is shown below: Data Out Field Figure 4. IL711 / IL712 / IL721 equivalent circuit (each channel). Isolator Signal Path The GMR isolator signal path starts with a buffered input signal that is driven through an ultraminiature coil. This generates a small magnetic field that changes the electron spin polarization of GMR resistors, which are configured as a Wheatstone bridge. The change in spin polarization of the resistors creates a bridge voltage which drives an output comparator to construct an isolated version of the input signal. Small Size, High Speed, and Low EMI The coil, GMR, and circuitry are integrated to allow small packages. GMR is inherently high speed and low distortion, and unlike transformers, does not rely on energy transfer, so power is low and EMI emissions are minimal. High Magnetic Immunity GMR provides large signals which improve magnetic immunity, and the Wheatstone bridge configuration cancels ambient common-mode magnetic fields, further enhancing immunity to external magnetic fields. 10 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL711/IL712/IL721 Electrostatic Discharge Sensitivity Power Supply Decoupling This product has been tested for electrostatic sensitivity to the limits stated in the specifications. However, NVE recommends that all integrated circuits be handled with appropriate care to avoid damage. Damage caused by inappropriate handling or storage could range from performance degradation to complete failure. Both power supplies should be decoupled with 0.1 µF typical (0.047 µF minimum) capacitors as close as possible to the VDD pins. Ground planes for both GND1 and GND2 are highly recommended for data rates above 10 Mbps. Maintaining Creepage Electromagnetic Compatibility IsoLoop Isolators have the lowest EMC footprint of any isolation technology. IsoLoop Isolators’ Wheatstone bridge configuration and differential magnetic field signaling ensure excellent EMC performance against all relevant standards. Creepage distances are often critical in isolated circuits. In addition to meeting JEDEC standards, NVE isolator packages have unique creepage specifications. Standard pad libraries often extend under the package, compromising creepage and clearance. Similarly, ground planes, if used, should be spaced to avoid compromising clearance. Package drawings and recommended pad layouts are included in this datasheet. These isolators are fully compliant with IEC 61000-6-1 and IEC 61000-6-2 standards for immunity, and IEC 61000-6-3, IEC 61000-6-4, CISPR, and FCC Class A standards for emissions. Signal Status on Start-up and Shut Down To minimize power dissipation, input signals are differentiated and then latched on the output side of the isolation barrier to reconstruct the signal. This could result in an ambiguous output state depending on power up, shutdown and power loss sequencing. Unless the circuit connected to the isolator performs its own power- on reset (POR), a start-up initialization circuit should be considered. Initialization consists of toggling the input either high then low, or low then high. Immunity to external magnetic fields is even higher if the field direction is “end-to-end” rather than to “pin-to-pin” as shown in the diagram below: Cross-axis Field Direction In CAN applications, the IL712 or IL721 should be used with CAN transceivers with Dominant Timeout functions for seamless POR. Most CAN transceivers have Dominant Timeout options. Examples include NXP’s TJA 1050 and TJA 1040 transceivers. Data Transmission Rates The reliability of a transmission system is directly related to the accuracy and quality of the transmitted digital information. For a digital system, those parameters which determine the limits of the data transmission are pulse width distortion and propagation delay skew. Dynamic Power Consumption IsoLoop Isolators achieve their low power consumption from the way they transmit data across the isolation barrier. By detecting the edge transitions of the input logic signal and converting these to narrow current pulses, a magnetic field is created around the GMR Wheatstone bridge. Depending on the direction of the magnetic field, the bridge causes the output comparator to switch following the input logic signal. Since the current pulses are narrow, about 2.5 ns, the power consumption is independent of mark-to-space ratio and solely dependent on frequency. This has obvious advantages over optocouplers, which have power consumption heavily dependent on mark-to-space ratio. Propagation delay is the time taken for the signal to travel through the device. This is usually different when sending a low-to-high than when sending a high-to-low signal. This difference, or error, is called pulse width distortion (PWD) and is usually in nanoseconds. It may also be expressed as a percentage: PWD% = Maximum Pulse Width Distortion (ns) x 100% Signal Pulse Width (ns) For example, with data rates of 12.5 Mbps: PWD% = 3 ns x 100% = 3.75% 80 ns This figure is almost three times better than any available optocoupler with the same temperature range, and two times better than any optocoupler regardless of published temperature range. IsoLoop isolators exceed the 10% maximum PWD recommended by PROFIBUS, and will run to nearly 35 Mb within the 10% limit. Propagation delay skew is the signal propagation difference between two or more channels. This becomes significant in clocked systems because it is undesirable for the clock pulse to arrive before the data has settled. Propagation delay skew is especially critical in high data rate parallel systems for establishing and maintaining accuracy and repeatability. Worst-case channel-to-channel skew in an IL700 Isolator is just 3 ns— ten times better than any optocoupler. IL700 Isolators have a maximum propagation delay skew of 6 ns— five times better than any optocoupler. 11 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL711/IL712/IL721 Illustrative Applications NVE offers a unique line of single-chip isolated RS-485, PROFIBUS, and CAN transceivers, but as illustrated in the circuits below, IL700-Series Isolators can also be used as part of multi-chip designs with non-isolated transceivers: Isolation Boundary 1 8 2 7 3 6 4 5 RS-485 Truth Table D DE 1 0 0 0 1 1 0 1 8 4 IL711 A Z Z 1 0 B Z Z 0 1 R X X 1 0 3 5 4 6 3 7 2 1 8 1 2 6 7 5 IL710 ISL8485 Figure 1. Isolated PROFIBUS / RS-485 circuit. DD2 CAN Controller Rx0 3 1 2 8 7 TxD 1 3 6 RxD 4 4 5 7 CANH 6 CANL 2 IL712 / IL721 AMIS-30660/ TJA1050 2 Figure 2. Isolated CAN circuit. CAN isolation is increasingly necessary to reduce EMI susceptibility, especially in high- speed applications and in hybrid and electrical vehicle networks, where the 12 V battery has been replaced with one of several hundred volts. Operator and equipment safety becomes critical when a high voltage source, such as the battery, needs to be connected to diagnosis systems during routine maintenance procedures. In the application shown above, the microcontroller is isolated from the CAN transceiver by an IL712 or IL721, allowing higher speed and more reliable bus operation by eliminating ground loops and reducing susceptibility to noise and EMI events. The best-in-class 10 ns typical IL712/IL721 propagation delay minimizes CAN loop delay and maximizes data rate over any given bus length. This simple circuit works with any CAN transceiver with a TxD dominant timeout, which includes all of the current-generation transceivers. NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 Phone: (952) 829-9217 Fax: (952) 829-9189 www.IsoLoop.com ©NVE Corporation IL711/IL712/IL721 Package Drawings 8-pin MSOP (-1 suffix) Dimensions in inches (mm); scale = approx. 5X 0.114 (2.90) 0.122 (3.10) 0.016 (0.40) 0.027 (0.70) 0.114 (2.90) 0.122 (3.10) 0.189 (4.80) 0.197 (5.00) 0.032 (0.80) 0.043 (1.10) 0.024 (0.60) 0.028 (0.70) 0.005 (0.13) 0.009 (0.23) 0.010 (0.25) 0.016 (0.40) 0.002 (0.05) 0.006 (0.15) NOTE: Pin spacing is a BASIC dimension; tolerances do not accumulate 8-pin SOIC Package (-3 suffix) Dimensions in inches (mm); scale = approx. 5X 0.188 (4.77) 0.197 (5.00) 0.016 (0.4) 0.050 (1.3) 0.052 (1.32) 0.062 (1.57) 0.054 (1.37) 0.072 (1.83) 0.150 (3.8) 0.157 (4.0) 0.228 (5.8) 0.244 (6.2) 0.004 (0.1) 0.012 (0.3) 0.050 (1.27) NOM NOTE: Pin spacing is a BASIC dimension; tolerances do not accumulate 0.007 (0.2) 0.013 (0.3) 0.013 (0.3) 0.020 (0.5) 8-pin PDIP (-2 suffix) Dimensions in inches (mm); scale = approx. 2.5X 0.28 (7.1) 0.33 (8.4) 0.30 (7.6) 0.38 (9.7) 0.24 (6.1) 0.27 (6.9) 0.13 (3.30) 0.17 (4.32) NOTE: Pin spacing is a BASIC dimension; tolerances do not accumulate 0 10 0.345 (8.76) 0.40 (10.2) 0.055 (1.40) 0.065 (1.65) 0.008 (0.2) 0.015 (0.4) 0.015 (0.38) 0.040 (1.02) 0.030 (0.76) 0.045 (1.14) 0.09 (2.3) 0.11 (2.8) 0.045 (1.14) 0.070 (1.78) 0.014 (0.36) 0.023 (0.58) 13 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL711/IL712/IL721 True 8™ (8 mm creepage) 16-pin SOIC Package (no suffix) Dimensions in inches (mm); scale = approx. 5X 0.033 (0.85)* 0.043 (1.10) 0.260 (6.60)* 0.280 (7.11) 0.013 (0.3) 0.020 (0.5) 0.007 (0.2) 0.013 (0.3) 0.397 (10.08) 0.413 (10.49) 0.017 (0.43)* 0.022 (0.56) 0.016 (0.4) 0.050 (1.3) 0.007 (0.18)* 0.010 (0.25) 0.092 (2.34) 0.105 (2.67) Pin 1 identified by either an indent or a marked dot 0.08 (2.0) 0.10 (2.5) 0.292 (7.42)* 0.299 (7.59) 0.049 (1.24) 0.051 (1.30) 0.394 (10.00) 0.419 (10.64) NOTE: Pin spacing is a BASIC dimension; tolerances do not accumulate *Specified for True 8™ package to guarantee 8 mm creepage per IEC 60601. 0.004 (0.1) 0.012 (0.3) 14 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL711/IL712/IL721 Recommended Pad Layouts 8-pin MSOP Pad Layout Dimensions in inches (mm); scale = approx. 5X 0.120 (3.05) 0.025 (0.65) 0.017 (0.43) 8 PLCS 0.227 (5.77) 8-pin SOIC Pad Layout Dimensions in inches (mm); scale = approx. 5X 0.160 (4.05) 0.050 (1.27) 0.020 (0.51) 8 PLCS 0.275 (6.99) True 8™ 16-pin SOIC Pad Layout Dimensions in inches (mm); scale = approx. 5X 0.317 (8.05) 0.050 (1.27) 0.020 (0.51) 16 PLCS 0.449 (11.40) 15 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL711/IL712/IL721 Ordering Information IL 711 T - 3 E TR13 Bulk Packaging Blank = Tube TR7 = 7'' Tape and Reel TR13 = 13'' Tape and Reel Package Blank = 80/20 Tin/Lead Plating E = RoHS Compliant Package Type -1 = MSOP -2 = PDIP -3 = 0.15'' 8-pin SOIC Blank = True 8 (8mm creepage) Grade Blank = S = T = V = Standard High Speed (150 Mbps) High Temperature (125˚C) High Isolation Voltage (6 kV True 8; 2.5 kV MSOP) Base Part Number 711 = 2 Transmit Channels 712 = 1 Transmit Channel 1 Receive Channel 721 = 1 Transmit Channel 1 Receive Channel (reverse pinout) Product Family IL = Isolators 16 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL711/IL712/IL721 Available Parts Available Parts IL711-1E IL711-2 IL711-2E IL711-3 IL711-3E IL711S-1E IL711S-3E IL711T-1E IL711TV-1E IL711T-2 IL711T-2E IL711T-3 IL711T-3E IL711V-1E IL711VE IL712-1E IL712-2 IL712-2E IL712-3 IL712-3E IL712S-1E IL712S-3E IL712T-1E IL712TV-1E IL712T-2 IL712T-2E IL712T-3 IL712T-3E IL712V-1E IL721-3E IL721E IL721T-3E IL721VE Transmit Channels 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Receive Channels 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Maximum Temperature 100°C 100°C 100°C 100°C 100°C 100°C 100°C 125°C 125°C 125°C 125°C 125°C 125°C 100°C 125°C 100°C 100°C 100°C 100°C 100°C 100°C 100°C 125°C 125°C 125°C 125°C 125°C 125°C 100°C 105°C 100°C 125°C 125°C Mbps 110 110 110 110 110 150 150 110 110 110 110 110 110 110 110 110 110 110 110 110 150 150 110 110 110 110 110 110 110 110 110 110 110 Isolation Voltage (RMS) 1 kV 2.5 kV 2.5 kV 2.5 kV 2.5 kV 1 kV 2.5 kV 1 kV 2.5 kV 2.5 kV 2.5 kV 2.5 kV 2.5 kV 2.5 kV 6 kV 1 kV 2.5 kV 2.5 kV 2.5 kV 2.5 kV 1 kV 2.5 kV 1 kV 2.5 kV 2.5 kV 2.5 kV 2.5 kV 2.5 kV 2.5 kV 2.5 kV 2.5 kV 2.5 kV 6 kV Package MSOP-8 PDIP-8 PDIP-8 SOIC-8 SOIC-8 MSOP-8 SOIC-8 MSOP-8 MSOP-8 PDIP-8 PDIP-8 SOIC-8 SOIC-8 MSOP-8 True8 MSOP-8 PDIP-8 PDIP-8 SOIC-8 SOIC-8 MSOP-8 SOIC-8 MSOP-8 MSOP-8 PDIP PDIP SOIC-8 SOIC-8 MSOP SOIC-8 True8 SOIC-8 True8 RoHS Y N Y N Y Y Y Y Y N Y N Y Y Y Y N Y N Y Y Y Y Y N Y N Y Y Y Y Y Y All MSOP and SOIC part types are available on tape and reel. 17 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL711/IL712/IL721 ISB-DS-001-IL711/12-AO August 2022 ISB-DS-001-IL711/12-AN ISB-DS-001-IL711/12-AM ISB-DS-001-IL711/12-AL Changes • Upgraded to IEC 60747-17 (VDE 0884-17):2021-10 (p. 3). • Increased Working Voltage ratings based on latest VDE testing (p. 3). • Added ATEX and IECEx certification for IS-to-IS intrinsically safe applications (p. 3). • Replaced “Valid Part Numbers” with table on p. 17. Changes • Upgraded CMTI specifications. • Added ATEX / IEC 60079 Intrinsic Safety pending (p. 3). Changes • Extended minimum operating power supplies to 2.7 volts. • Explicitly listed part types for max. operating temperatures. • Changed PDIP8 creepage specifications from 7.04 mm to 6.8 mm. • Updated EMC standards. • Deleted minimum magnetic field immunity specifications (not 100% tested). • Revised thermal resistance specifications. • Added Typical Performance Graphs. • More detailed description of operation. Changes • Added IL711TV-1E and IL712TV-1E 125°C, 2.5 kV isolation MSOP configurations. • Eliminated non-RoHS MSOPs. ISB-DS-001-IL711/12-AK Change • Updated SOIC8 package outline drawing. ISB-DS-001-IL711/12-AJ Change • Updated VDE Reinforced Isolation file number and description. ISB-DS-001-IL711/12-AI Changes • Updated VDE certification standard to VDE V 0884-10. ISB-DS-001-IL711/12-AH ISB-DS-001-IL711/12-AG • Upgraded “VE” Version Surge Immunity specification to 12.8 kV. • Upgraded “VE” Version VDE 0884-10 rating to reinforced insulation. Changes • Increased V-Series isolation voltage to 6 kVrms. • Increased typ. Total Barrier Thickness specification to 0.016 mm. • Increased CTI min. specification to ≥600 VRMS. Changes • Added V-Series high isolation voltage versions (5 kV True 8 and 2.5 kV MSOP). • ISB-DS-001-IL711/12-AF More detailed “Available Parts” table. Changes • Added product illustrations to first page. • Revised and added details to thermal characteristic specifications (p. 2). • Added VDE 0884 Safety-Limiting Values (p. 3). 18 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL711/IL712/IL721 Datasheet Limitations The information and data provided in datasheets shall define the specification of the product as agreed between NVE and its customer, unless NVE and customer have explicitly agreed otherwise in writing. All specifications are based on NVE test protocols. In no event however, shall an agreement be valid in which the NVE product is deemed to offer functions and qualities beyond those described in the datasheet. Limited Warranty and Liability Information in this document is believed to be accurate and reliable. However, NVE does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. In no event shall NVE be liable for any indirect, incidental, punitive, special or consequential damages (including, without limitation, lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Right to Make Changes NVE reserves the right to make changes to information published in this document including, without limitation, specifications and product descriptions at any time and without notice. This document supersedes and replaces all information supplied prior to its publication. Use in Life-Critical or Safety-Critical Applications Unless NVE and a customer explicitly agree otherwise in writing, NVE products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical devices or equipment. NVE accepts no liability for inclusion or use of NVE products in such applications and such inclusion or use is at the customer’s own risk. Should the customer use NVE products for such application whether authorized by NVE or not, the customer shall indemnify and hold NVE harmless against all claims and damages. Applications Applications described in this datasheet are illustrative only. NVE makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using NVE products, and NVE accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the NVE product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customers. Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. NVE does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customers. The customer is responsible for all necessary testing for the customer’s applications and products using NVE products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customers. NVE accepts no liability in this respect. Limiting Values Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and operation of the device at these or any other conditions above those given in the recommended operating conditions of the datasheet is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and Conditions of Sale In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. NVE hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of NVE products by customer. No Offer to Sell or License Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export Control This document as well as the items described herein may be subject to export control regulations. Export might require a prior authorization from national authorities. Automotive Qualified Products Unless the datasheet expressly states that a specific NVE product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. NVE accepts no liability for inclusion or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without NVE’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond NVE’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies NVE for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond NVE’s standard warranty and NVE’s product specifications. 19 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL711/IL712/IL721 An ISO 9001 Certified Company NVE Corporation 11409 Valley View Road Eden Prairie, MN 55344-3617 USA Telephone: (952) 829-9217 www.nve.com e-mail: iso-info@nve.com ©NVE Corporation All rights are reserved. Reproduction in whole or in part is prohibited without the prior written consent of the copyright owner. ISB-DS-001-IL711/12-AO August 2022 20 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com
IL721-3E 价格&库存
很抱歉,暂时无法提供与“IL721-3E”相匹配的价格&库存,您可以联系我们找货
