IL422
Isolated RS422/RS485 Interface
Functional Diagram
DE
Features
ISODE
Y
Z
D
A
B
R
RE
IL422
IL422 Receiver
RE
H
L
L
L
R
Z
H
L
I
3.3 V Input Supply Compatible
25 ns Maximum Propagation Delay
25 Mbps Data Rate
1 ns Pulse Skew (typ.)
±60 mA Driver Output Capability
Thermal Shutdown Protection
Meets or Exceeds ANSI 422-B, EIA 485-A and
ITU Recommended V11
Low EMC Footprint
−40 °C to +85 °C Operating Temperature
PROFIBUS Compliant
2500 Vrms Isolation
IEC 60747-17 (VDE 0884-17):2021-10 certified; UL 1577 recognized
16-pin Wide-Body SOIC Package
IL422 Driver
V(A−B)
X
≥ 200 mV
≤−200 mV
Open
DE
L
H
H
D
X
H
L
V(Y−Z)
Z
≥ 1.5 V
≤−1.5 V
H = High Level, L = Low Level
I = Indeterminate, X = Irrelevant, Z = High Impedance
Applications
Multi-point or multi-drop transmission on long bus lines in noisy
environments.
Description
The IL422 is a galvanically isolated, high-speed differential bus
transceiver, designed for bidirectional data communication on
balanced transmission lines. The devices use NVE’s patented*
spintronic Giant Magnetoresistance (GMR) technology. The IL422
was the first isolated RS-422 interface in a standard
16-pin SOIC package to meet the ANSI Standards EIA/TIA-422-B
and RS-485.
The IL422 has current limiting and thermal shutdown features to
protect against output short circuits and bus contention situations that
could cause excessive power dissipation.
Isoloop is a registered trademark of NVE Corporation.
*U.S. Patent number 5,831,426; 6,300,617 and others.
NVE Corporation
11409 Valley View Road, Eden Prairie, MN 55344-3617
REV. S
Phone: (952) 829-9217
www.nve.com
youtube.com/NveCorporation
iso-apps@nve.com
IL422
Absolute Maximum Ratings(11)
Parameters
Storage Temperature
Junction Temperature
Voltage Range at A or B Bus Pins
Supply Voltage(1)
Digital Input Voltage
Digital Output Voltage
Symbol
TS
TJ
VDD1, VDD2
Min.
−65
−65
−7
−0.5
−0.5
−0.5
Typ.
Continuous Total Power Dissipation
Maximum Output Current
Lead Solder Temperature
ESD
IO
Max.
150
150
12
7
5.5
VDD + 1
725
377
95
260
Units
°C
°C
V
V
V
V
Max.
5.5
5.5
12
−7
Units
VDD1
V
0.8
±12
60
V
V
mA
8
mA
mW
mA
°C
kV
2
Test Conditions
25°C
85°C
10 sec.
HBM
Recommended Operating Conditions
Parameters
Input Voltage at any Bus Terminal
(separately or common mode)
Symbol
VDD1
VDD2
VI
VIC
High-Level Digital Input Voltage
VIH
Low-Level Digital Input Voltage
Differential Input Voltage(2)
High-Level Output Current (Driver)
High-Level Digital Output Current
(Receiver)
Low-Level Output Current (Driver)
Low-Level Digital Output Current
(Receiver)
Ambient Operating Temperature
Transient Immunity
Digital Input Signal
Rise and Fall Times
VIL
VID
IOH
Supply Voltage
Min.
3.0
4.5
Typ.
2.4
3.0
IOH
V
V
IOL
−60
mA
IOL
−8
mA
TA
TJ
−40
−40
100
tIR,tIF
Test Conditions
VDD1 = 3.3 V
VDD1 = 5.0 V
°C
°C
kV/μs
DC Stable
2
NVE Corporation
www.nve.com
iso-apps@nve.com
IL422
Safety and Approvals
IEC 60747-17 (VDE 0884-17):2021-10 (Basic Isolation; VDE File Number 5016933-4880-0001)
• Isolation voltage (VISO): 2500 VRMS
• Transient overvoltage (VIOTM): 4000 VPK
• Surge rating: 4000 V
• Each part tested at 1590 VPK for 1 second, 5 pC partial discharge limit.
• Samples tested at 4000 VPK for 60 sec.; then 1358 VPK for 10 sec. with 5 pC partial discharge limit.
• Working Voltage (VIORM) 600 VRMS (848 VPK); basic insulation; pollution degree 2
Safety-Limiting Values
Safety rating ambient temperature
Safety rating power (180 °C)
Supply current safety rating (total of supplies)
Symbol
TS
PS
IS
Value
180
270
54
Units
°C
mW
mA
UL 1577 (Component Recognition Program File Number E207481)
• 2500 V rating
• Each part tested at 3000 VRMS (4243 VPK) for 1 second
• Each lot sample tested at 2500 VRMS (3536 VPK) for 1 minute
Soldering Profile
Per JEDEC J-STD-020C, MSL-1
3
NVE Corporation
www.nve.com
iso-apps@nve.com
IL422
IL422 Pin Connections
1
VDD1
Input Power Supply
2
GND1
Input Power Supply Ground*
3
R
4
RE
Read Data Enable
(if RE is high, R = high impedance)
5
DE
Drive Enable
6
D
7
NC
8
9
Output Data from Bus
VDD1
VDD2
GND1
GND2
R
A
No Internal Connection
RE
B
GND1
DE
Z
GND2
Output Power Supply Ground*
D
Y
10
ISODE
Isolated DE Output for use in Profibus
applications where the state of the isolated
drive enable node needs to be monitored
11
Y
Y Bus (Drive – True)
12
Z
Z Bus (Drive – Inverse)
13
B
B Bus (Receive – Inverse)
14
A
A Bus (Receive – True)
15
GND2
16
VDD2
Output Power Supply
Data Input to Bus
NC
ISODE
GND2
GND1
IL422
*NOTE: Pins 2 and 8 are internally connected, as are pins 9 and 15.
4
NVE Corporation
www.nve.com
iso-apps@nve.com
IL422
Driver Section
Electrical specifications are Tmin to Tmax and VDD = 4.5 V to 5.5 V unless otherwise stated.
Parameters
Symbol
Min.
Typ.(5)
Input Clamp Voltage
VIK
Output voltage
VO
Differential Output Voltage(2)
|VOD1|
1.5
|VOD2|
1.5
2.5
Differential Output Voltage(2)(6)
VOD3
1.5
Change in Magnitude of Differential
Δ|VOD|
Output Voltage(7)
Max.
−1.5
6
6
5
5
Units
V
V
V
V
V
±0.2
V
RL = 54 Ω or 100 Ω
VOC
3
−1
V
RL = 54 Ω or 100 Ω
Change in Magnitude of Common
Mode Output Voltage(7)
Δ|VOC|
±0.2
V
RL = 54 Ω or 100 Ω
Output Current(4) Output Disabled
IO
High Level Input Current
Low Level Input Current
IIH
IIL
Short-circuit Output Current
IOS
Common Mode Output Voltage
Supply Current
VDD1 = +5 V
VDD1 = +3.3 V
Parameters
Maximum Data Rate
Differential Output Prop Delay
Pulse Skew(10)
Differential Output Rise & Fall Time
Output Enable Time to High Level
Output Enable Time to Low Level
Output Disable Time from High Level
Output Disable Time from Low Level
Skew Limit(3)
IDD1
IDD1
Symbol
tD(OD)
tS(P)
tT(OD)
tPZH
tPZL
tPHZ
tPLZ
tSK(LIM)
4
3
Switching Specifications
Min.
Typ.(5)
25
16
1
8
31
22
28
16
2
1
−0.8
10
−10
250
−150
−250
6
3
Max.
25
6
10
65
35
50
32
8
mA
μA
μA
mA
mA
Units
Mbps
ns
ns
ns
ns
ns
ns
ns
ns
Test Conditions
IL = −18 mA
IO = 0
IO = 0
RL = 54 Ω, VDD = 5 V
RL = 54 Ω, VDD = 4.5 V
VO = 12 V
VO = −7 V
VI = 3.5 V
VI = 0.4 V
VO = −6 V
VO = 0 V
VO = 8 V
No Load
(Outputs Enabled)
Test Conditions
RL = 54 Ω, CL = 50 pF
5
NVE Corporation
www.nve.com
iso-apps@nve.com
IL422
Receiver Section
Parameters
Symbol
Min.
Typ.(5)
Positive-going Input
VIT+
Threshold Voltage
Negative-going Input
VIT−0.2
Threshold Voltage
Hysteresis Voltage (VIT+ − VIT-)
VHYS
60
Max.
Units
0.2
V
V
mV
High Level Digital Output Voltage
VOH
Low Level Digital Output Voltage
VOL
0.2
V
High-impedance-state output current
IOZ
±10
μA
Line Input Current(8)
II
1
−0.8
mA
Input Resistance
rI
Supply Current
IDD2
Parameters
Maximum Data Rate
Propagation Delay(9)
Pulse Skew(10)
Limit(3)
Skew
Output Enable Time To High Level
Output Enable Time To Low Level
Output Disable Time From High Level
Output Disable Time From Low Level
Parameters
Maximum Data Rate
Pulse Skew(10)
Limit(3)
Skew
VDD − 0.2
12
Test Conditions
VO = 2.7 V,
IO = −0.4 mA
VO = 0.5 V,
IO = 8 mA
V
VID = 200 mV
IOH = −20 μA
VID = −200 mV
IOH = 20 μA
VO = 0.4 to (VDD2−0.5) V
VI = 12 V
VI = −7 V
Other Input(11) = 0 V
kΩ
27
Switching Characteristics at 5 V
Symbol
Min.
Typ.(5)
25
34
mA
Max.
Units
Mbps
tPD
24
32
ns
tSK(P)
1
6
ns
8
24
45
45
27
ns
ns
ns
ns
ns
Max.
Units
Mbps
tSK(LIM)
2
tPZH
17
tPZL
30
tPHZ
30
tPLZ
18
Switching Characteristics at 3.3 V
Symbol
Min.
Typ.(5)
25
tPD
27
32
ns
tSK(P)
2
6
ns
tSK(LIM)
tPZH
tPZL
tPHZ
tPLZ
4
33
24
45
45
27
ns
ns
ns
ns
ns
No load
Outputs Enabled
Test Conditions
VO = −1.5 V to 1.5 V,
CL = 15 pF
CL = 15 pF
CL = 15 pF
CL = 15 pF
CL = 15 pF
CL = 15 pF
Test Conditions
CL = 15 pF
CL = 15 pF
CL = 15 pF
CL = 15 pF
CL = 15 pF
CL = 15 pF
Magnetic Field Immunity(11)
Power Frequency Magnetic Immunity
Pulse Magnetic Field Immunity
Damped Oscillatory Magnetic Field
Cross-axis Immunity Multiplier(12)
HPF
HPM
HOSC
KX
HPF
HPM
HOSC
KX
Magnetic Field Immunity at 5 V
3500
4500
4500
2.5
Magnetic Field Immunity at 3.3 V
1500
2000
2000
2.5
A/m
A/m
A/m
50Hz/60Hz
tp = 8µs
0.1Hz – 1MHz
A/m
A/m
A/m
50Hz/60Hz
tp = 8µs
0.1Hz – 1MHz
6
NVE Corporation
www.nve.com
iso-apps@nve.com
IL422
Insulation Specifications
Parameters
Creepage Distance
Barrier Impedance
Leakage Current
Symbol
Min.
8.08
Typ.
Max.
Units
>1014||7
0.2
Test Conditions
mm
Ω || pF
240 VRMS, 60 Hz
μA
Thermal Characteristics
Parameter
Symbol
Junction–Ambient Thermal Resistance
Junction–Case (Top)
Thermal Resistance
Junction–Ambient
Thermal Resistance
Junction–Case (Top)
Thermal Resistance
Power Dissipation
Min.
Typ.
θJA
67
θJC
12
θJA
46
θJC
9
Max.
Units
Test Conditions
Double-sided PCB in
free air
°C/W
2s2p PCB in free air
per JESD51
PD
1500
mW
Notes:
1.
All voltage values are with respect to network ground except differential I/O bus voltages.
2.
Differential input/output voltage is measured at the noninverting terminal A with respect to the inverting terminal B.
3.
Skew limit is the maximum propagation delay difference between any two devices at 25°C.
4.
The power-off measurement in ANSI Standard EIA/TIA-422-B applies to disabled outputs only and
is not applied to combined inputs and outputs.
5.
All typical values are at VDD1= 3.3 V or 5 V and VDD2 = 5 V, and TA = 25°C.
6.
The minimum VOD2 with a 100 Ω load is either ½ VOD1 or 2 V, whichever is greater.
7.
Δ|VOD| and Δ|VOC| are the changes in magnitude of VOD and VOC, respectively,
that occur when the input is changed form one logic state to the other.
8.
This applies for both power on and power off, refer to ANSI standard RS-485 for exact condition.
The EIA/TIA-422-B limit does not apply for a combined driver and receiver terminal.
9.
Includes 8 ns read enable time. Maximum propagation delay is 25 ns after read assertion.
10. Pulse skew is defined as |tPLH − tPHL| of each channel.
11. The relevant test and measurement methods are given in the Electromagnetic Compatibility section.
12. External magnetic field immunity is improved by this factor if the field direction is “end-to-end” rather than to “pin-to-pin.”
7
NVE Corporation
www.nve.com
iso-apps@nve.com
IL422
Application Information
Electrostatic Discharge Sensitivity
Dynamic Power Consumption
This product has been tested for electrostatic sensitivity to the
limits stated in the specifications. However, NVE recommends that
all integrated circuits be handled with appropriate care to avoid
damage. Damage caused by inappropriate handling or storage could
range from performance degradation to complete failure.
IsoLoop Isolators achieve their low power consumption from the
way they transmit data across the isolation barrier. By detecting the
edge transitions of the input logic signal and converting these to
narrow current pulses, a magnetic field is created around the GMR
Wheatstone bridge. Depending on the direction of the magnetic
field, the bridge causes the output comparator to switch following
the input logic signal. Since the current pulses are narrow, about
2.5 ns, the power consumption is independent of mark-to-space
ratio and solely dependent on frequency. This has obvious
advantages over optocouplers, which have power consumption
heavily dependent on frequency and time.
The IL422 is fully compliant with IEC 61000-6-1 and
IEC 61000-6-2 standards for immunity, and IEC 61000-6-3,
IEC 61000-6-4, CISPR, and FCC Class A standards for emissions.
The approximate power supply current per channel is:
Immunity to external magnetic fields is even higher if the field
direction is “end-to-end” rather than to “pin-to-pin” as shown in the
diagram below:
IIN = 40 x
f x 1
4
fMAX
mA
Where f = operating frequency
fMAX = 50 MHz
Power Supply Decoupling
VDD1 and VDD2 should be bypassed with 0.1 µF typical
(0.047 µF minimum) capacitors as close as possible to the VDD
pins.
Cross-axis Field Direction
8
NVE Corporation
www.nve.com
iso-apps@nve.com
IL422
0.3" 16-pin SOIC Package
Dimensions in inches (mm); scale = approx. 5X
0.033 (0.85)*
0.043 (1.10)
0.260 (6.60)*
0.280 (7.11)
0.013 (0.3)
0.020 (0.5)
0.007 (0.2)
0.013 (0.3)
0.397 (10.08)
0.413 (10.49)
0.017 (0.43)*
0.022 (0.56)
0.016 (0.4)
0.050 (1.3)
0.007 (0.18)*
0.010 (0.25)
0.092 (2.34)
0.105 (2.67)
Pin 1 identified by
either an indent
or a marked dot
0.08 (2.0)
0.10 (2.5)
0.292 (7.42)*
0.299 (7.59)
0.049 (1.24)
0.051 (1.30)
0.394 (10.00)
0.419 (10.64)
NOTE: Pin spacing is a BASIC
dimension; tolerances
do not accumulate
*Specified for True 8™ package to guarantee 8 mm creepage per IEC 60601.
0.004 (0.1)
0.012 (0.3)
Ordering Information and Valid Part Numbers
IL 422 E TR13
Bulk Packaging
Blank = Tube
TR = 13'' Tape and Reel
Valid Part Numbers
IL422
IL422E
Package
Blank = 80/20 Tin/Lead Plating
E = RoHS Compliant
All IL422
part types are
available on
tape and reel.
Base Part Number
422 = RS-422 Transceiver
Product Family
IL = Isolators
RoHS
COMPLIANT
9
NVE Corporation
www.nve.com
iso-apps@nve.com
IL422
ISB-DS-001-IL422-S
October 2022
Changes
ISB-DS-001-IL422-R
Change
ISB-DS-001-IL422-Q
ISB-DS-001-IL422-M
Added magnetic field immunity and electromagnetic compatibility specifications.
Added note on package drawing that pin-spacing tolerances are non-accumulating.
Change
Updated package drawing; misc.
Change
ISB-DS-001-IL422-G
Updated open input state in truth table
Change
ISB-DS-001-IL422-H
Eliminated soldering profile chart
Change
ISB-DS-001-IL422-I
Reorganized supply current specifications; misc. minor changes
Change
ISB-DS-001-IL422-J
Changed ordering information to reflect that devices are now fully RoHS compliant with
no exemptions.
Change
ISB-DS-001-IL422-K
Added low EMC footprint.
Changes
ISB-DS-001-IL422-L
Added clarification of internal ground connections.
Change
ISB-DS-001-IL422-N
Update terms and conditions.
Change
ISB-DS-001-IL422-O
Updated MSL, agency approvals, magnetic immunity, and other specifications.
Change
ISB-DS-001-IL422-P
Upgrade to VDE 0884-17 (p. 3).
Updated EMC standards.
Deleted minimum magnetic field immunity specifications (p. 6) since it is not 100% tested.
Added thermal characteristics (p. 7).
Updated UL and IEC approvals
Changes
Revision letter added.
Ordering Information Removed.
IEC 61010-1 Classification: “Reinforced Insulation” added.
Notes added.
IR Soldering Profile added
Ordering Information added.
10
NVE Corporation
www.nve.com
iso-apps@nve.com
IL422
Datasheet Limitations
The information and data provided in datasheets shall define the specification of the product as agreed between NVE and its customer, unless NVE and
customer have explicitly agreed otherwise in writing. All specifications are based on NVE test protocols. In no event however, shall an agreement be
valid in which the NVE product is deemed to offer functions and qualities beyond those described in the datasheet.
Limited Warranty and Liability
Information in this document is believed to be accurate and reliable. However, NVE does not give any representations or warranties, expressed or
implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information.
In no event shall NVE be liable for any indirect, incidental, punitive, special or consequential damages (including, without limitation, lost profits, lost
savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on
tort (including negligence), warranty, breach of contract or any other legal theory.
Right to Make Changes
NVE reserves the right to make changes to information published in this document including, without limitation, specifications and product descriptions
at any time and without notice. This document supersedes and replaces all information supplied prior to its publication.
Use in Life-Critical or Safety-Critical Applications
Unless NVE and a customer explicitly agree otherwise in writing, NVE products are not designed, authorized or warranted to be suitable for use in life
support, life-critical or safety-critical devices or equipment. NVE accepts no liability for inclusion or use of NVE products in such applications and such
inclusion or use is at the customer’s own risk. Should the customer use NVE products for such application whether authorized by NVE or not, the
customer shall indemnify and hold NVE harmless against all claims and damages.
Applications
Applications described in this datasheet are illustrative only. NVE makes no representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Customers are responsible for the design and operation of their applications and products using NVE products, and NVE accepts no liability for any
assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the NVE product is suitable and fit for
the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customers. Customers should
provide appropriate design and operating safeguards to minimize the risks associated with their applications and products.
NVE does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party customers. The customer is responsible for all necessary testing for the
customer’s applications and products using NVE products in order to avoid a default of the applications and the products or of the application or use by
customer’s third party customers. NVE accepts no liability in this respect.
Limiting Values
Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the
device. Limiting values are stress ratings only and operation of the device at these or any other conditions above those given in the recommended
operating conditions of the datasheet is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the
quality and reliability of the device.
Terms and Conditions of Sale
In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. NVE hereby expressly objects to
applying the customer’s general terms and conditions with regard to the purchase of NVE products by customer.
No Offer to Sell or License
Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication
of any license under any copyrights, patents or other industrial or intellectual property rights.
Export Control
This document as well as the items described herein may be subject to export control regulations. Export might require a prior authorization from national authorities.
Automotive Qualified Products
Unless the datasheet expressly states that a specific NVE product is automotive qualified, the product is not suitable for automotive use. It is neither
qualified nor tested in accordance with automotive testing or application requirements. NVE accepts no liability for inclusion or use of non-automotive
qualified products in automotive equipment or applications.
In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall
use the product without NVE’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the
product for automotive applications beyond NVE’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies
NVE for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond NVE’s
standard warranty and NVE’s product specifications.
11
NVE Corporation
www.nve.com
iso-apps@nve.com
IL422
An ISO 9001 Certified Company
NVE Corporation
Eden Prairie, MN 55344-3617 USA
Telephone: (952) 829-9217
www.nve.com
e-mail: iso-apps@nve.com
©NVE Corporation
All rights are reserved. Reproduction in whole or in part is prohibited without the prior written consent of the copyright owner.
ISB-DS-001-IL422-S
October 2022
12
NVE Corporation
www.nve.com
iso-apps@nve.com
