AS1130
132-LED Cross-Plexing Driver with
Scrolling Function
General Description
The AS1130 is a compact LED driver for 132 single LEDs. The
devices can be programmed via an I²C compatible interface.
The AS1130 offers a 12x11 LED-matrix with 1/12 cycle rate. The
required lines to drive all 132 LEDs are reduced to 12 by using
the cross-plexing feature optimizing space on the PCB. The
whole LED-matrix driving 132 LEDs can be analog dimmed from
0mA to 30mA in 256 steps (8 bit).
Additionally each of the 132 LEDs can be dimmed individually
with 8-bit allowing 256 steps of linear dimming. To reduce CPU
usage up to 6 frames can be stored with individual time delays
between frames to play small animations automatically.
The AS1130 operates from 2.7V to 5.5V and features a very low
shutdown and operational current.
The device offers a programmable IRQ pin. Via a register it can
be set on what event (CP_Request, Interface Timeout,
Error-detection, POR, End of Frame or End of Movie) the IRQ is
triggered.
Also hardware scroll function is implemented in the AS1130.
The device is available in an ultrasmall 20-Pin WL-CSP and an
easy to solder 28-pin SSOP/TSSOP package.
Ordering Information and Content Guide appear at end of
datasheet.
Key Benefits & Features
The benefits and features of AS1130, 132-LED Cross-Plexing
Driver with Scrolling Function are listed below:
Figure 1:
Added Value of Using AS1130
Benefits
Features
• Worlds lowest PCB real estate vs LED count
• Up to 132 LEDs in a 12x11 matrix
• 16.7M full color matrix with white balance
• 8-bit PWM per LED and current control per line
• Reduces MCU load and increases battery
lifetime
• 36 frames of memory with scrolling option
• Identifies defect LEDs and “removes” them
from the matrix
• Error detection and correction
ams Datasheet
[v2-01] 2016-Oct-12
Page 1
Document Feedback
AS1130 − General Description
Applications
The AS1130 is ideal for dot matrix displays in mobile phones,
personal electronics and toys.
Figure 2:
AS1130- Typical Application Diagram
12
12
CS0 .. 11
CS0 .. 11
VDD
2.7V to 5.5V
VDD
CIN
CIN
ADDR
R1
AS1130
SYNC_OUT
ADDR
R1
SYNC_IN
AS1130
GND
GND
VDD
SDA
μP
Page 2
Document Feedback
SDA
SCL
RSTN
IRQ
SCL
RSTN IRQ
SDA
SCL
RSTN IRQ
pull-up
resistors
ams Datasheet
[v2-01] 2016-Oct-12
Block Diagram
The functional blocks of this device are shown below:
Figure 3:
AS1130 Block Diagram
VDD
SYNC_IN
SYNC_OUT
1MHz
SDA
SCL
IRQ
Digital Control
Logic
RSTN
I2C Interface
Control
ADDR
R1
Control
Registers
DPRAM
AS1130
ams Datasheet
[v2-01] 2016-Oct-12
12
CS0 … 11
12
GND
Current Sources
with Error
Detection
Page 3
Document Feedback
AS1130 − Pin Assignment
Pin Assignment
Figure 4:
Pin Diagram (Top View)
28-pin SSOP/TSSOP
20-pin WL-CSP
Figure 5:
Pin Description
Pin Number
20-Pin
WL-CSP
28-Pin
SSOP /
TSSOP
Pin Name
A3
1, 7, 14, 22, 28
GND
Ground
C3
13
RSTN
Reset Input. Pull this pin to logic low to reset all
control registers (set to default values). For
normal operation pull this pin to VDD.
D1
17
ADDR
I²C Address. Connect to external resistor for I²C
address selection. Up to 8 devices can be
connected on one bus. See Figure 30
D2
16
SDA
Serial-Data I/O. Open drain digital I/O I²C data
pin.
D3
15
SCL
Serial-Clock Input
Page 4
Document Feedback
Description
ams Datasheet
[v2-01] 2016-Oct-12
Pin Number
20-Pin
WL-CSP
28-Pin
SSOP /
TSSOP
Pin Name
Description
B3
3, 10, 18, 19, 26
VDD
Positive Supply Voltage. Connect to a +2.7V to
+5.5V supply. Bypass this pin with 10μF
capacitance to GND.
SYNC
Synchronization Clock Input or Output. The
SYNC frequency for Input and Output is 1MHz.
For SYNC_OUT the frequency can be reduced to
32kHz.
Interrupt Request. Programmable Open drain
digital Output. It can be set via an register after
which event (Interface Timeout, POR, CP_
Request, Error Detection, End of Frame or End of
Movie) the pin triggers an Interrupt Request.
D4
12
D5
11
IRQ
A1, A2, A4, A5,
B1, B2, B4, B5,
C1, C2, C4, C5
25, 27, 2, 4,
23, 24, 5, 6,
21, 20, 9, 8
CS0, CS1, CS6, CS7,
CS2, CS3, CS8, CS9,
CS4, CS5, CS10, CS11
ams Datasheet
[v2-01] 2016-Oct-12
Sinks and Sources for 132 LEDs.
Page 5
Document Feedback
AS1130 − Absolute Maximum Ratings
Stresses beyond those listed in Absolute Maximum Ratings may
cause permanent damage to the device. These are stress ratings
only, and functional operation of the device at these or any
other conditions beyond those indicated in Electrical
Characteristics is not implied. Exposure to absolute maximum
rating conditions for extended periods may affect device
reliability.
Figure 6:
Parameter
Min
Max
Units
Comments
Electrical Parameters
VDD to GND
-0.3
7
V
All other pins to GND
-0.3
7 or
VDD + 0.3
V
Sink Current
500
mA
Segment Current
100
mA
100
mA
Input Current (latch-up
immunity)
-100
JEDEC 78
Electrostatic Discharge
(human body model)
±2
kV
MIL 883 E method 3015
Temperature Ranges and Storage Conditions
Junction Temperature
Storage Temperature
Range
150
ºC
-55
125
ºC
For 20-Pin WL-CSP
-55
150
ºC
For 28-pin SSOP/TSSOP
28-pin
SSOP/
TSSOP
IPC/JEDEC J-STD-020(1)The lead
finish for Pb-free leaded packages
is matte tin (100% Sn).
20-Pin
WL-CSP
1
20-Pin
WL-CSP
Represents an unlimited floor life
time
3
28-pin
SSOP/
TSSOP
Represents a max. floor life time of
168h
Package Body
Temperature
Relative Humidity
(non-condensing)
260
5
85
Moisture Sensitivity Level
ºC
Note(s):
1. The reflow peak soldering temperature (body temperature) is specified according IPC/JEDEC J-STD-020 “Moisture/Reflow Sensitivity
Classification for Nonhermetic Solid State Surface Mount Devices”.
Page 6
Document Feedback
ams Datasheet
[v2-01] 2016-Oct-12
AS1130 − Electrical Characteristics
V DD = 2.7V to 5.5V, typ. values are at TAMB = 25ºC (unless otherwise
specified). All limits are guaranteed. The parameters with min
and max values are guaranteed with production tests or SQC
(Statistical Quality Control) methods.
Figure 7:
Symbol
Parameter
TAMB
Operating Temperature Range
TJ
VDD
Conditions
Min
Max
Unit
-40
85
°C
Operating Junction
Temperature Range
-40
125
°C
Operating Supply Voltage
2.7
5.5
V
All current sources
turned ON, @ VDD = 5.5V
IDD
340
Operating Supply Current
mA
All current sources
turned OFF, @ VDD = 5.5V
0.5
7
15
μA
0.1
1
μA
360
mA
32
mA
IDDSSD
Software Shutdown Supply
Current
All digital inputs at VDD or
GND @ VDD = 5.5V
IDDFSD
Full Shutdown Supply Current
Pin RSTN = 0V,
TAMB = 25ºC
IDIGIT
Digit Drive Sink Current
(drive capability of all sources
of one digit(1))
ISEG
Segment Drive Source Current
LED(2)
ΔISEG
Typ
Segment Drive Current
Matching LED
VOUT = 1.8V to
VDD-400mV
28
30
1
Device to Device Current
Matching LED
VOUT = 1.8V, VDD = 3.3V
1
ILEAK
Leakage Output Current
All current sources OFF,
VOUT = 0V, VDD = 5.5V,
TAMB = 25ºC
0.005
ΔILNR
Line Regulation
VOUT = 1.8V
0.25
%/V
ΔILDR
Load Regulation
VOUT = 1.8V to
VDD-400mV
0.25
%/V
VDSSAT
Saturation Voltage
Current = 30mA,
VDD = 3.3V
200
mV
RDSON(N)
Resistance for NMOS
ams Datasheet
[v2-01] 2016-Oct-12
0.3
0.5
1
μA
W
Page 7
Document Feedback
Symbol
Parameter
Conditions
Open Detection Level
Threshold
Min
Typ
VDD0.4
VDD0.1
Short Detection Level
Threshold
fOSC
fREFRESH
tRSTN
Oscillator Frequency
Display Scan Rate
12x11 matrix
Reset Pulse Width Low
Max
Unit
V
770
900
mV
0.9
1
1.1
MHz
0.29
0.33
0.36
kHz
500
ns
Note(s):
1. Guaranteed by design.
2.
I max – I min
I SEG = --------------------------- × 100
I max + I min
Figure 8:
Logic Inputs/Outputs Characteristics
Symbol
IIH, IIL
Parameter
Logic Input Current
VIH
CMOS Logic High Input Voltage
VIL
CMOS Logic Low Input Voltage
ΔVI
CMOS Hysteresis Voltage
VIH
Mobile Logic High Input Voltage (1)
VIL
Mobile Logic Low Input Voltage(1)
ΔVI
Hysteresis Voltage (1)
Conditions
Min
VIN = 0V or VDD
-1
Typ
Max
Unit
1
μA
0.7 x VDD
V
0.3 x VDD
0.3
V
V
1.6
V
0.6
0.1
V
V
VOL(SDA)
SDA Output Low Voltage
ISINK = 3mA
0.4
V
VOL(IRQ)
IRQ Output Low Voltage
ISINK = 3mA
0.4
V
Sync Clock Output Low Voltage
ISINK = 1mA
0.4
V
Sync Clock Output High Voltage
ISOURCE = 1mA
VDD-0.4
V
400
pF
VOL(SYNC_
OUT)
VOH(SYNC_
OUT)
Capacitive Load for Each Bus Line
Note(s):
1. Available on request, see Ordering & Contact Information.
Page 8
Document Feedback
ams Datasheet
[v2-01] 2016-Oct-12
Figure 9:
I²C Timing Characteristics
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
1000
kHz
fSCL
SCL Frequency
100
tBUF
Bus Free Time Between STOP and
START Conditions
1.3
μs
Hold Time for Repeated
START Condition
260
ns
tLOW
SCL Low Period
500
ns
tHIGH
SCL High Period
260
ns
tSETUPSTART
Setup Time for Repeated
START Condition
260
ns
tSETUPDATA
Data Setup Time
100
ns
tHOLDSTART
tRISE(SCL)
SCL Rise Time
120
ns
tRISE(SCL1)
SCL Rise Time after Repeated START
Condition and After an ACK Bit
120
ns
tFALL(SCL)
SCL Fall Time
120
ns
tRISE(SDA)
SDA Rise Time
120
ns
tFALL(SDA)
SDA Fall Time
120
ns
tSETUPSTOP
STOP Condition Setup Time
tSPIKESUP
260
ns
Pulse Width of Spike Suppressed
6
ns
Note(s):
1. The Min / Max values of the Timing Characteristics are guaranteed by design.
Figure 10:
Timing Diagram
tBUF
tR
70%
30%
tHOLDDATA
tSETU PDATA
70%
30%
START
STOP
SCL
ams Datasheet
[v2-01] 2016-Oct-12
tLOW
tHIGH
tSETU PSTART
tSPIKESUP
tF
tSETU PSTOP
STOP
tHOLDSTART
Rep START
SDA
Page 9
Document Feedback
AS1130 − Typical Operating Characteristics
Figure 11:
Segment Drive Current vs. Supply Voltage
Segment Drive Source Current (mA)
Typical Operating
Characteristics
32
31.5
31
30.5
30
29.5
29
-45°C
28.5
+25°C
+85°C
28
2.7
3.1
3.5
3.9
4.3
4.7
5.1
5.5
Supply Voltage (V)
Figure 12:
Segment Drive Current vs. Temperature
32
31.5
31
30.5
30
29.5
Vdd = 2.7V
29
Vdd = 3.3V
Vdd = 4.5V
28.5
Vdd = 5.5V
28
-45
-25
-5
15
35
55
75
Temperature (C)
Page 10
Document Feedback
ams Datasheet
[v2-01] 2016-Oct-12
Figure 13:
Segment Drive Current vs. Output Voltage
32
Vdd = 2.7V
31.5
Vdd = 3.3V
Vdd = 4.5V
31
Vdd = 5.5V
30.5
30
29.5
29
28.5
28
1.6
2
2.4 2.8 3.2 3.6
4
4.4 4.8 5.2 5.6
Output Voltage (V)
Figure 14:
RONNMOS vs. Supply Voltage
0.5
-45°C
+25°C
RNMOS (Ω)
0.4
+85°C
0.3
0.2
0.1
3.1
3.5
3.9
4.3
4.7
5.1
5.5
Supply Voltage (V)
ams Datasheet
[v2-01] 2016-Oct-12
Page 11
Document Feedback
Figure 15:
Open Detection Level vs. Supply Voltage
300
Open Detection Level (mV)
-45°C
+25°C
250
+85°C
200
150
100
50
3.1
3.5
3.9
4.3
4.7
5.1
5.5
Supply Voltage (V)
Figure 16:
Short Detection Level vs. Supply Voltage
0.9
Short Detection Level (V)
0.85
0.8
0.75
0.7
-45°C
0.65
+25°C
+85°C
0.6
2.7
3.1
3.5
3.9
4.3
4.7
5.1
5.5
Supply Voltage (V)
Page 12
Document Feedback
ams Datasheet
[v2-01] 2016-Oct-12
Figure 17:
CMOS Logic Input Levels vs. Supply Voltage
Logic Input Voltage Level (V)
4
3.5
3
2.5
2
1.5
1
Logic High
0.5
Logic Low
3.1
3.5
3.9
4.3
4.7
5.1
5.5
Supply Voltage (V)
Figure 18:
CMOS Logic Input Levels vs. Temperature
4
3.5
3
2.5
2
1.5
1
Logic High
0.5
Logic Low
-25
-5
15
35
55
75
Temperature (C)
ams Datasheet
[v2-01] 2016-Oct-12
Page 13
Document Feedback
Figure 19:
MOBILE Logic Input Levels vs. Supply Voltage
2
1.5
1
0.5
Logic High
Logic Low
3.1
3.5
3.9
4.3
4.7
5.1
5.5
Supply Voltage (V)
Figure 20:
MOBILE Logic Input Levels vs. Temperature
2
1.5
1
0.5
Logic High
Logic Low
-25
-5
15
35
55
75
Temperature (C)
Page 14
Document Feedback
ams Datasheet
[v2-01] 2016-Oct-12
Figure 21:
Oscillator Frequency vs. Supply Voltage
1.1
fOSC (kHz)
1.05
1
0.95
- 45°C
+ 25°C
+ 85°C
0.9
2.7
3.1
3.5
3.9
4.3
4.7
5.1
5.5
Supply Voltage (V)
Figure 22:
Oscillator Frequency vs. Temperature
1.1
fOSC (kHz)
1.05
1
0.95
Vdd = 2.7V
Vdd = 3.3V
Vdd = 4.5V
Vdd = 5.5V
0.9
-45
-25
-5
15
35
55
75
Temperature (C)
ams Datasheet
[v2-01] 2016-Oct-12
Page 15
Document Feedback
AS1130 − Detailed Description
Cross-Plexing Theorem
The cross-plexing theorem is using the fact that a LED has a
forward and backward direction. A LED will only glow if there
is a current flowing in forward direction. A parallel LED in
backward direction will block the current flow. This effect is
used in a cross-plexed matrix of LEDs.
Each CSx pin (CS0 to CS11) can be switched to VDD via the
internal current source (“high”), to GND (“low”) or not
connected (“highZ”).
The mode of operation which is controlled by an internal state
machine looks like following. CS0 is switched to GND and all
other CSx pins (CS1 to CS11) are controlled according to the
settings in the On/Off Frame and Blink & PWM registers (see
Figure 31).
Than CS1 is switched to GND and all other CSx pins (CS0 and
CS2 to CS11) are controlled according to the settings in the
On/Off Frame and Blink & PWM registers.
In this manner all LEDs in the matrix are scanned and turned
on/off depending on the register settings.
I²C Interface
The AS1130 supports the I²C serial bus and data transmission
protocol in fast mode at 1MHz. The AS1130 operates as a slave
on the I²C bus. The bus must be controlled by a master device
that generates the serial clock (SCLK), controls the bus access,
and generates the START and STOP conditions. Connections to
the bus are made via the open-drain I/O pins SCLK and SDA.
Figure 23:
I²C Interface Initialization
1
8
9
1
8
9
SCLK
SDA
1
1
AD2 AD1 AD0 R/W
D15 D14 D13 D12 D11 D10
D9
D8
AD2, AD1 and AD0 are defined by the pin ADDR, see I²C Device Address Byte.
Page 16
Document Feedback
ams Datasheet
[v2-01] 2016-Oct-12
Figure 24:
Bus Protocol
MSB
SDI
ACK from
Receiver
Slave Address
R/W
Direction Bit
ACK from
Receiver
1
SCLK
2
6
7
8
9
ACK
START
1
2
3-7
8
9
ACK
Repeat if More Bytes Transferred
STOP or
Repeated
START
The bus protocol (as shown in Figure 24) is defined as:
• Data transfer may be initiated only when the bus is not
busy.
• During data transfer, the data line must remain stable
whenever the clock line is HIGH. Changes in the data line
while the clock line is HIGH will be interpreted as control
signals.
The bus conditions are defined as:
• Bus Not Busy. Data and clock lines remain HIGH.
• Start Data Transfer. A change in the state of the data line,
from HIGH to LOW, while the clock is HIGH, defines a START
condition.
• Stop Data Transfer. A change in the state of the data line,
from LOW to HIGH, while the clock line is HIGH, defines
the STOP condition.
• Data Valid. The state of the data line represents valid data,
when, after a START condition, the data line is stable for
the duration of the HIGH period of the clock signal. There
is one clock pulse per bit of data. Each data transfer is
initiated with a START condition and terminated with a
STOP condition. The number of data bytes transferred
between START and STOP conditions is not limited and is
determined by the master device. The information is
transferred byte-wise and each receiver acknowledges
with a ninth-bit. Within the I²C bus specifications a
high-speed mode (3.4MHz clock rate) is defined.
ams Datasheet
[v2-01] 2016-Oct-12
Page 17
Document Feedback
• Acknowledge: Each receiving device, when addressed, is
obliged to generate an acknowledge after the reception
of each byte. The master device must generate an extra
clock pulse that is associated with this acknowledge bit.
A device that acknowledges must pull down the SDA line
during the acknowledge clock pulse in such a way that the
SDA line is stable LOW during the HIGH period of the
acknowledge clock pulse. Of course, setup and hold times
must be taken into account. A master must signal an end
of data to the slave by not generating an acknowledge bit
on the last byte that has been clocked out of the slave. In
this case, the slave must leave the data line HIGH to enable
the master to generate the STOP condition.
• Figure 24 details how data transfer is accomplished on the
I²C bus. Depending upon the state of the R/W bit, two
types of data transfer are possible:
• Master Transmitter to Slave Receiver. The first byte
transmitted by the master is the slave address,
followed by a number of data bytes. The slave returns
an acknowledge bit after the slave address and each
received byte.
• Slave Transmitter to Master Receiver. The first byte,
the slave address, is transmitted by the master. The
slave then returns an acknowledge bit. Next, a
number of data bytes are transmitted by the slave to
the master. The master returns an acknowledge bit
after all received bytes other than the last byte. At the
end of the last received byte, a not-acknowledge is
returned. The master device generates all of the serial
clock pulses and the START and STOP conditions. A
transfer is ended with a STOP condition or a repeated
START condition. Since a repeated START condition is
also the beginning of the next serial transfer, the bus
will not be released.
The AS1130 can operate in the following slave modes:
• Slave Receiver Mode. Serial data and clock are received
through SDA and SCL. After each byte is received, an
acknowledge bit is transmitted. START and STOP
conditions are recognized as the beginning and end of a
serial transfer. Address recognition is performed by
hardware after reception of the slave address and
direction bit.
• Slave Transmitter Mode. The first byte (the slave
address) is received and handled as in the slave receiver
mode. However, in this mode the direction bit will indicate
that the transfer direction is reversed. Serial data is
transmitted on SDA by the AS1130 while the serial clock
is input on SCL. START and STOP conditions are recognized
as the beginning and end of a serial transfer.
Page 18
Document Feedback
ams Datasheet
[v2-01] 2016-Oct-12
Command Byte
The AS1130 operation (see Figure 38) is determined by a
command byte (see Figure 25).
Figure 25:
Command Byte
MSB
6
5
4
3
2
1
LSB
A7
A6
A5
A4
A3
A2
A1
A0
Figure 26:
Command and Single Data Byte Received by AS1130
AS1130 Registers
From Master to Slave
From Slave to Master
S
Slave Address
A7
A6
R/W A
A5
A4
A3
A2
A1
A0
D7
D6
A
Command Byte
D5
D4
D3
D2
D1
D0
A
Data Byte
P
1 Byte
Acknowledge
from AS1130
Acknowledge
from AS1130
Acknowledge
from AS1130
Autoincrement
Memory Word
Address
Figure 27:
Setting the Pointer to a Address Register to Select a Data Register for a Read Operation
AS1130 Registers
S
Slave Address
R/W A
Acknowledge
from AS1130
ams Datasheet
[v2-01] 2016-Oct-12
A7
A6
A5
A4
A3
A2
A1
A0
Command Byte
Acknowledge
from AS1130
A
P
Page 19
Document Feedback
Figure 28:
Reading N Bytes from AS1130
Autoincrement
Memory Word
Address
S
Acknowledge
from AS1130
Acknowledge
from Master
R/W A
Slave Address
D7
D6
D5
D4
D3
D2
Not Acknowledge
from Master
D1
1
n Bytes
A
First Data Byte
1
Stop reading
D0
/A
Second Data Byte
D7
D6
D5
D4
D3
D2
D1
P
D0
Autoincrement
to next address
AS1130 Registers
The address byte (see Figure 29) is the first byte received
following the START condition from the master device.
Figure 29:
address:
MSB
6
5
4
3
2
1
LSB
1
0*
AD2
AD1
AD0
R/W
*) can be factory set to 1
The bit 1, 2 and 3 of the address byte are defined through the
resistor @ the device select pin ADDR (see Figure 30). A
maximum of 8 devices with the same pre-set code can be
connected on the same bus at one time.
• The last bit of the address byte (R/W) define the operation
to be performed. When set to a 1 a read operation is
selected; when set to a 0 a write operation is selected.
• I²C Common address. All devices are responding on the
address “0111111” if the function is enabled in the register
AS1130 Config Register (0x06).
Following the START condition, the AS1130 monitors the I²C
bus, checking the device type identifier being transmitted.
Upon receiving the address code, and the R/W bit, the slave
device outputs an acknowledge signal on the SDA line.
Page 20
Document Feedback
ams Datasheet
[v2-01] 2016-Oct-12
Figure 30:
Device Address
I2C Address
Bit
3:1
Bit Name
i2c_addr
Default
000
Access
Description
R
Defines the I²C address of one device via an external
resistor on pin ADDR
000: 1MΩ or floating
001: 470kΩ
010: 220kΩ
011: 100kΩ
100: 47kΩ
101: 22kΩ
110: 10kΩ
111: 4.7kΩ or GND
The pin ADDR is scanned after start up (POR) and defines the
address for the device. The device reacts to this address until a
hardware reset (low on pin RSTN) is performed or the
power-on-reset (POR) triggers again.
Note(s): The internal address decoder needs 5ms to identify the
address and to set up the device for this address.
ams Datasheet
[v2-01] 2016-Oct-12
Page 21
Document Feedback
Initial Power-Up
On initial power-up, the AS1130 registers are reset to their
default values, the display is blanked, and the device goes into
shutdown mode. At this time, all registers should be
programmed for normal operation. To bring the device into
normal operation the following sequence needs to be
performed.
Start-Up Sequence
• Power-up the AS1130 (connect VDD to a source), the
devices is in shutdown;
• After 5ms the address of the AS1130 is valid and the first
I²C command can be send.
• Define RAM Configuration; bit mem_conf in the AS1130
Config Register (see Figure 45)
• On/Off Frames
• Blink & PWM Sets
• Dot Correction, if specified
• Define Control Register (see Figure 38)
• Current Source
• Display options
• Display picture / play movie
• To light up the LEDs set the shdn bit to ‘1’ for normal
operation mode (see Figure 48).
Shutdown Mode
The AS1130 device features two different shutdown modes. A
software shutdown via shutdown register (see Shutdown &
Open/Short Register (0x09)) and a hardware shutdown via the
RSTN pin.
The software shutdown disables all LEDs and stops the internal
operation of the logic. A shutdown mode via the RSTN pin
additionally powers down the power-on-reset (POR) of the
device. In this shutdown mode the AS1130 consumes only
100nA (typ.).
Page 22
Document Feedback
ams Datasheet
[v2-01] 2016-Oct-12
AS1130 − Register Description
Register Selection
Within this register the access to one of the RAM sections, the
Dot Correction or to the Control register is selected. After one
section is selected this section is valid as long as an other
section is selected.
Figure 31:
Register Selection Address Map
Address
Register
Section
H
E
X
Data
H
E
X
D D D D D D D D
7 6 5 4 3 2 1 0
NOP
0x
00
On/Off Frame 0
0x
01
On/Off Frame 1
0x
02
On/Off Frame 2
0x
03
1
A A A A A A A A
7 6 5 4 3 2 1 0
Description
No operation
On/Off information
for each frame (up
to 36 frames)
On/Off Frame
34
0x
23
1
On/Off Frame
35
0x
24
0x
40
Blink & PWM
Set 1
0x
41
Blink & PWM
Set 2
0x
42
Blink & PWM
Set 3
0x
43
1
Blink & PWM
Set 4
0x
44
Blink & PWM
Set 5
0x
45
Dot Correction
0x
80
1
Selection of Dot
Correction Register
Control
Register
0x
C0
1
1
Selection of
Control Register
Blink & PWM
Set 0
ams Datasheet
[v2-01] 2016-Oct-12
0x
FD
1
1
1
1
1
1
Blink & PWM
Information Sets
(up to 6 sets)
Page 23
Document Feedback
Data Definition of the Single Frames
One frame consists of 2 datasets, the On/Off dataset and the
Blink & PWM dataset. Where more On/Off frames can be linked
to one PWM set. Depending on the used PWM sets more or less
On/Off frames can be stored inside the AS1130 (see Figure 32).
Each On/Off frame needs to define the used Blink & PWM
dataset.
Figure 32:
RAM Configuration
RAM Configuration
Blink & PWM Set
On/Off Frame
On/Off Frame
with Dot Correction
1
34..0
2
1,0
29..0
28..0
3
2,1,0
23..0
22..0
4
3..0
17..0
16..0
5
4..0
11..0
10..0
6
5..0
5..0
4..0
It is necessary to define the RAM configuration before data can
be written to the frame datasets. The RAM configuration is
defined in the AS1130 config register (see Figure 45) via bit 2:0
and bit 4 for Dot Correction.
Note(s): After a first write of data to the frames, the
configuration is locked in the AS1130 config register and can
be changed only after a reset of the device. A change of the
RAM configuration requires to re-write the frame datasets.
Page 24
Document Feedback
ams Datasheet
[v2-01] 2016-Oct-12
12x11 LED Matrix
The AS1130 is configured to control one big LED matrix.
Figure 33:
AS1130 - Dot Matrix Structure
In Figure 34 it is described which databit represents which LED
in the matrix. Per default all databits are ‘0’, meaning no LED is
on. A ‘1’ puts the LED on.
Each Current Segment of the LED Matrix consists of 11 LEDs,
therefore 2 bytes of data are required for one Current Segment.
CS0 is defined by the two bytes with address 0x00 and 0x01 and
also includes the address of the used Blink & PWM dataset for
this frame.
ams Datasheet
[v2-01] 2016-Oct-12
Page 25
Document Feedback
A S 1 1 3 0 − Register Description
Figure 34:
LEDs On/Off Frame Register Format
Address
Data
Segment
HEX
A7
A6
A5
A4
A3
A2
A1
A0
D7
D6
D5
D4
D3
D2
D1
D0
0x00
LED
07
LED
06
LED
05
LED
04
LED
03
LED
02
LED
01
LED
00
0x01
PWM
[2]
PWM
[1]
PWM
[0]
X
X
LED
0A
LED
09
LED
08
0x02
LED
17
LED
16
LED
15
LED
14
LED
13
LED
12
LED
11
LED
10
0x03
1
X
X
X
X
X
LED
1A
LED
19
LED
18
0x04
LED
27
LED
26
LED
25
LED
24
LED
23
LED
22
LED
21
LED
0x05
X
X
X
X
X
LED
2A
LED
29
LED
28
0x06
1
LED
37
LED
36
LED
35
LED
34
LED
33
LED
32
LED
31
LED
30
0x07
1
1
X
X
X
X
X
LED
3A
LED
39
LED
38
0x08
LED
47
LED
46
LED
45
LED
44
LED
43
LED
42
LED
41
LED
40
0x09
X
X
X
X
X
LED
4A
LED
49
LED
48
2
3
4
Page 26
Document Feedback
ams Datasheet
[v2-01] 2016-Oct-12
Address
Data
Segment
HEX
A7
A6
A5
A4
A3
A2
A1
A0
D7
D6
D5
D4
D3
D2
D1
D0
0x0A
LED
57
LED
56
LED
55
LED
54
LED
53
LED
52
LED
51
LED
50
0x0B
1
X
X
X
X
X
LED
5A
LED
59
LED
58
0x0C
1
LED
67
LED
66
LED
65
LED
64
LED
63
LED
62
LED
61
LED
60
0x0D
1
X
X
X
X
X
LED
6A
LED
69
LED
68
0x0E
1
1
LED
77
LED
76
LED
75
LED
74
LED
73
LED
72
LED
71
LED
70
0x0F
1
1
1
X
X
X
X
X
LED
7A
LED
79
LED
78
0x10
LED
87
LED
86
LED
85
LED
84
LED
83
LED
82
LED
81
LED
80
0x11
X
X
X
X
X
LED
8A
LED
89
LED
88
0x12
LED
97
LED
96
LED
95
LED
94
LED
93
LED
92
LED
91
LED
90
0x13
1
X
X
X
X
X
LED
9A
LED
99
LED
98
0x14
LED
A7
LED
A6
LED
A5
LED
A4
LED
A3
LED
A2
LED
A1
LED
A0
0x15
X
X
X
X
X
LED
AA
LED
A9
LED
A8
5
6
7
8
9
A
ams Datasheet
[v2-01] 2016-Oct-12
Page 27
Document Feedback
Address
Data
Segment
HEX
A7
A6
A5
A4
A3
A2
A1
A0
D7
D6
D5
D4
D3
D2
D1
D0
0x16
1
LED
B7
LED
B6
LED
B5
LED
B4
LED
B3
LED
B2
LED
B1
LED
B0
0x17
1
1
X
X
X
X
X
LED
BA
LED
B9
LED
B8
B
The Blink & PWM sets contain blink on/off and the digital PWM information for each LED in the matrix. The number
of PWM datasets is flexible according to the defined RAM configuration (see Figure 32).
In the blink register (see Figure 35) every single LED can be set to blink. The blink period is set in the display option
register (see Display Option Register Format).
Figure 35:
LEDs Blink Frame Register Format
Address
Data
Segment
HEX
A7
A6
A5
A4
A3
A2
A1
A0
D7
D6
D5
D4
D3
D2
D1
D0
0x00
LED
07
LED
06
LED
05
LED
04
LED
03
LED
02
LED
01
LED
00
0x01
X
X
X
X
X
LED
0A
LED
09
LED
08
0x02
LED
17
LED
16
LED
15
LED
14
LED
13
LED
12
LED
11
LED
10
0x03
1
X
X
X
X
X
LED
1A
LED
19
LED
18
Page 28
Document Feedback
ams Datasheet
[v2-01] 2016-Oct-12
Address
Data
Segment
HEX
A7
A6
A5
A4
A3
A2
A1
A0
D7
D6
D5
D4
D3
D2
D1
D0
0x04
LED
27
LED
26
LED
25
LED
24
LED
23
LED
22
LED
21
LED
0x05
X
X
X
X
X
LED
2A
LED
29
LED
28
0x06
1
LED
37
LED
36
LED
35
LED
34
LED
33
LED
32
LED
31
LED
30
0x07
1
1
X
X
X
X
X
LED
3A
LED
39
LED
38
0x08
LED
47
LED
46
LED
45
LED
44
LED
43
LED
42
LED
41
LED
40
0x09
X
X
X
X
X
LED
4A
LED
49
LED
48
0x0A
LED
57
LED
56
LED
55
LED
54
LED
53
LED
52
LED
51
LED
50
0x0B
1
X
X
X
X
X
LED
5A
LED
59
LED
58
0x0C
1
LED
67
LED
66
LED
65
LED
64
LED
63
LED
62
LED
61
LED
60
0x0D
1
X
X
X
X
X
LED
6A
LED
69
LED
68
0x0E
1
1
LED
77
LED
76
LED
75
LED
74
LED
73
LED
72
LED
71
LED
70
0x0F
1
1
1
X
X
X
X
X
LED
7A
LED
79
LED
78
2
3
4
5
6
7
ams Datasheet
[v2-01] 2016-Oct-12
Page 29
Document Feedback
Address
Data
Segment
HEX
A7
A6
A5
A4
A3
A2
A1
A0
D7
D6
D5
D4
D3
D2
D1
D0
0x10
LED
87
LED
86
LED
85
LED
84
LED
83
LED
82
LED
81
LED
80
0x11
X
X
X
X
X
LED
8A
LED
89
LED
88
0x12
LED
97
LED
96
LED
95
LED
94
LED
93
LED
92
LED
91
LED
90
0x13
1
X
X
X
X
X
LED
9A
LED
99
LED
98
0x14
LED
A7
LED
A6
LED
A5
LED
A4
LED
A3
LED
A2
LED
A1
LED
A0
0x15
X
X
X
X
X
LED
AA
LED
A9
LED
A8
0x16
1
LED
B7
LED
B6
LED
B5
LED
B4
LED
B3
LED
B2
LED
B1
LED
B0
0x17
1
1
X
X
X
X
X
LED
BA
LED
B9
LED
B8
8
9
A
B
In the PWM register (see Figure 36) the brightness of every single LED can be set via a 8bit PWM (255 steps).
Page 30
Document Feedback
ams Datasheet
[v2-01] 2016-Oct-12
Figure 36:
LEDs PWM Register Format
Address
Segment
Data
HE
X
A
7
A
6
A
5
A
4
A
3
A
2
A
1
A
LED00
0x18
1
LED01
0x19
1
LED02
0x1A
1
LED03
0x1B
1
1
LED04
0x1C
1
1
LED05
0x1D
1
1
LED06
0x1E
1
1
1
LED07
0x1F
1
1
1
1
LED08
0x20
LED09
0x21
LED0A
0x22
LED10
0x23
1
LED11
0x24
LED12
0x25
LED13
0x26
1
LED14
0x27
1
1
LED15
0x28
LED16
0x29
LED17
0x2A
LED18
0x2B
1
LED19
0x2C
1
LED1A
0x2D
1
ams Datasheet
[v2-01] 2016-Oct-12
D
7
D
6
D
5
D
4
D
3
D
2
D
1
D
255 steps for intensity each single
LED
LED
Page 31
Document Feedback
Address
Segment
2
3
Data
HE
X
A
7
A
6
A
5
A
4
A
3
A
2
A
1
A
LED20
0x2E
1
1
LED21
0x2F
1
1
1
LED22
0x30
1
LED23
0x31
1
LED24
0x32
1
LED25
0x33
1
1
LED26
0x34
1
LED27
0x35
1
LED28
0x36
1
1
LED29
0x37
1
1
1
LED2A
0x38
1
1
LED30
0x39
1
1
LED31
0x3A
1
1
LED32
0x3B
1
1
1
LED33
0x3C
1
1
1
LED34
0x3D
1
1
1
LED35
0x3E
1
1
1
1
LED36
0x3F
1
1
1
1
1
LED37
0x40
LED38
0x41
LED39
0x42
LED3A
0x43
1
Page 32
Document Feedback
D
7
D
6
D
5
D
4
D
3
D
2
D
1
D
LED
LED
ams Datasheet
[v2-01] 2016-Oct-12
Address
Segment
4
5
Data
HE
X
A
7
A
6
A
5
A
4
A
3
A
2
A
1
A
LED40
0x44
LED41
0x45
LED42
0x46
1
LED43
0x47
1
1
LED44
0x48
LED45
0x49
LED46
0x4A
LED47
0x4B
1
LED48
0x4C
1
LED49
0x4D
1
LED4A
0x4E
1
1
LED50
0x4F
1
1
1
LED51
0x50
LED52
0x51
LED53
0x52
LED54
0x53
1
LED55
0x54
LED56
0x55
LED57
0x56
1
LED58
0x57
1
1
LED59
0x58
1
LED5A
0x59
1
D
7
D
6
D
5
D
4
D
3
D
2
D
1
D
LED
LED
ams Datasheet
[v2-01] 2016-Oct-12
Page 33
Document Feedback
Address
Segment
A
B
Data
HE
X
A
7
A
6
A
5
A
4
A
3
A
2
A
1
A
LEDA0
0x86
1
1
LEDA1
0x87
1
1
1
LEDA2
0x88
1
LEDA3
0x89
1
LEDA4
0x8A
1
LEDA5
0x8B
1
1
LEDA6
0x8C
1
1
LEDA7
0x8D
1
1
LEDA8
0x8E
1
1
1
LEDA9
0x8F
1
1
1
1
LEDA0
0x90
1
LEDB0
0x91
1
LEDB1
0x92
1
LEDB2
0x93
1
1
LEDB3
0x94
1
LEDB4
0x95
1
LEDB5
0x96
1
1
LEDB6
0x97
1
1
1
LEDB7
0x98
1
1
LEDB8
0x99
1
1
LEDB9
0x9A
1
1
LEDBA
0x9B
1
1
1
Page 34
Document Feedback
D
7
D
6
D
5
D
4
D
3
D
2
D
1
D
LED
LED
ams Datasheet
[v2-01] 2016-Oct-12
Dot Correction Register
The AS1130 offers a feature to define a correction factor for the
analog current for every segment. This correction factor is
called Dot Correction and is defined in the Dot Correction
register (see Figure 37). The Dot Correction Register is selected
via data 128 on addr 253.
Figure 37:
Dot Correction Register Format
Address
Segment
Data
HEX
A
7
A
6
A
5
A
4
A
3
A
2
A
1
A
0x00
8 bit Dot Correction
1
0x01
2
0x02
3
0x03
1
4
0x04
5
0x05
6
0x06
1
7
0x07
1
1
8
0x08
9
0x09
A
0x0A
B
0x0B
1
ams Datasheet
[v2-01] 2016-Oct-12
D
7
D
6
D
5
D
4
D
3
D
2
D
1
D
Page 35
Document Feedback
Control-Registers
The AS1130 device contains 14 control registers which are listed
in Figure 38. All registers are selected using a 8-bit address
word, and communication is done via the serial interface. Select
the Control Register via the Register Selection (see Figure 31).
The Control Register is selected via data 192 on addr 253.
Figure 38:
Control Register Address Map
Register Address
Register Name
Register Data
HEX
A7
A6
A5
A4
A3
A2
A1
A0
D7:D0
0x00
See Figure 39
Movie
0x01
See Figure 40
Movie Mode
0x02
See Figure 41
Frame Time / Scroll
0x03
1
See Figure 42
Display Option
0x04
See Figure 43
Current Source
0x05
See Figure 44
AS1130 Config
0x06
1
See Figure 45
Interrupt Mask
0x07
1
1
See Figure 46
Interrupt Frame
Definition
0x08
See Figure 47
Shutdown &
Open/Short
0x09
See Figure 48
I²C Interface
Monitoring
0x0A
See Figure 49
CLK Synchronization
0x0B
1
See Figure 50
Interrupt Status
0x0E
1
See Figure 51
AS1130 Status
0x0F
1
See Figure 52
0x20
Open LED
0x37
Page 36
Document Feedback
1
See Figure 53
1
1
ams Datasheet
[v2-01] 2016-Oct-12
Picture Register (0x00)
In this register it must be set if a picture is to display on the LED
matrix or not. Also the address of the picture which should be
displayed must be set within this register. The default setting
of this register is 0x00.
Figure 39:
Picture Register Format
0x00 Picture Register
Bit
Bit Name
Default
Access
7
blink_pic
R/W
All LEDs in blink mode during display picture
0: No blink
1: All LEDs blink
6
display_pic
R/W
Display picture
0: No picture
1: Display picture
R/W
Address of picture
000000: Frame 0
000001: Frame 1
000010: Frame 2
000011: Frame 3
000100: Frame 4
000101: Frame 5
100000: Frame 32
100001: Frame 33
100010: Frame 34
100011: Frame 35
5:0
pic_addr
000000
Bit Description
Note(s):
1. The display_pic bit (bit 6 in Picture Register) has lower priority than the display_movie bit (bit 6 in Movie Register).
ams Datasheet
[v2-01] 2016-Oct-12
Page 37
Document Feedback
Movie Register (0x01)
In this register it must be set if a movie is to display on the LED
matrix or not. Also the address of the first frame in the movie
needs be set within this register. The default setting of this
register is 0x00.
Figure 40:
Movie Register Format
0x01 Movie Register
Bit
Bit Name
Default
Access
7
blink_movie
R/W
All LEDs in blink mode during play movie
0: No blink
1: All LEDs blink
6
display_movie
R/W
0: No movie
1: Start movie
R/W
Address of first frame in movie
000000: Frame 0
000001: Frame 1
000010: Frame 2
000011: Frame 3
000100: Frame 4
000101: Frame 5
100000: Frame 32
100001: Frame 33
100010: Frame 34
100011: Frame 35
5:0
movie_addr
000000
Bit Description
Note(s):
1. The display_movie bit (bit 6 in Movie Register) has higher priority than the display_pic bit (bit 6 in Picture Register).
Page 38
Document Feedback
ams Datasheet
[v2-01] 2016-Oct-12
Movie Mode Register (0x02)
Within this register two movie play options can be set. Per
default this register is set to 0x00.
• In scroll mode a movie can stop with the last frame of the
movie or scroll endless
• The number of frames to play in a movie
Figure 41:
Movie Mode Register Format
0x02 Movie Mode Register
Bit
Bit Name
Default
Access
Bit Description
7
blink_en
R/W
LED blink option(1)
0: Enabled
1: Disabled
6
end_last
R/W
Defines at which frame a movie stops in scroll mode
0: Movie ends with 1st frame
1: Movie ends with last frame
R/W
Number of frames played in a movie, starting at movie_
addr defined in Movie Register
000001: Play 2 Frames
000010: Play 3 Frames
000011: Play 4 Frames
000100: Play 5 Frames
000101: Play 6 Frames
100000: Play 33 Frames
100001: Play 34 Frames
100010: Play 35 Frames
100011: Play 36 Frames
5:0
movie_frames
000000
Note(s):
1. Disable blink option overrides any blink definition in PWM data definition or global blink definition in picture register & movie
register bit 7.
ams Datasheet
[v2-01] 2016-Oct-12
Page 39
Document Feedback
Frame Time/Scroll Register (0x03)
Every single frame in a movie is displayed for a certain time
before the next frame is displayed. This time can be set within
this register with 4 bits. The stated values in Figure 42 are typical
values.
Also the scroll options are set within this register. Per default
Figure 42:
Frame Time/Scroll Register Format
0x03 Frame Time/Scroll Register
Bit
Bit Name
Default
Access
Bit Description
7
frame_fad
R/W
Fade frame option (not available in 5 LED block
configuration)
0: No fading
1: Fading of a frame
6
scroll_dir
R/W
Scroll Direction
0: Scroll to right
1: Scroll to left
5
block_size
R/W
Define block size for scrolling
0: Scroll in full matrix
1: Scroll in 5 LED blocks (current sources split in 2
sections, see Scroll Function)
4
Enable Scrolling
R/W
Scroll digits at play movie
0: No scrolling
1: Scrolling digits at play movie
R/W
Delay between frame change in a movie
0000: Play frame only one time
0001: 32.5ms
0010: 65ms
0011: 97.5ms
0100: 130ms
0101: 162.5ms
0110: 195ms
0111: 227.5ms
1000: 260ms
1001: 292.5ms
1010: 325ms
1011: 357.5ms
1100: 390ms
1101: 422.5ms
1110: 455ms
1111: 487.5ms
3:0
frame_delay
Page 40
Document Feedback
0000
ams Datasheet
[v2-01] 2016-Oct-12
Display Option Register (0x04)
In this register the number of loops in a movie are defined. With
the scan-limit it can be controlled how many digits are
displayed in each matrix. When all 12 digits in the matrix are
displayed, the display scan rate is 430Hz (typ.). If the number of
digits to display is reduced, the update frequency is increased.
Per default this register is set to 0x20.
Figure 43:
0x04 Display Option Register
Bit
Bit Name
Default
Access
Bit Description
7:5
loops
001
R/W
Number of loops played in one movie
000: Not valid
001: 1 loop
010: 2 loops
011: 3 loops
100: 4 loops
101: 5 loops
110: 6 loops
111: play movie endless (needs to be reset to 0-6 to
stop movie); for scroll endless set bit end_last = ‘0’
4
blink_freq
R/W
Blink period
0: 1.5s
1: 3s
R/W
Number of displayed segments in one frame
(scan-limit)
0000: CS0
0001: CS0 to CS1
0010: CS0 to CS2
0011: CS0 to CS3
0100: CS0 to CS4
0101: CS0 to CS5
0110: CS0 to CS6
0111: CS0 to CS7
1000: CS0 to CS8
1001: CS0 to CS9
1010: CS0 to CS10
1011: CS0 to CS11
3:0
scan_limit
0000
Note(s):
1. To stop a movie in play endless mode, bits D7:D5 have to be set to a value between 000 to 110.
ams Datasheet
[v2-01] 2016-Oct-12
Page 41
Document Feedback
Current Source Register (0x05)
Within this registers the current for every single LED can be set
from 0mA to 30mA in 255 steps (8 bits). Per default this register
is set to 0x00.
Figure 44:
Current Source Register Format
0x05 Current Source Register
Bit
Bit Name
Default
Access
7:0
current
00000000
R/W
Bit Description
00000000: 0mA
11111111: 30mA
Per default this register is set to 0x00.
Figure 45:
AS1130 Config Register Format
0x06 AS1130 Config Register
Bit
7
6
5
4
Bit Name
low_vdd_rst
low_vdd_stat
led_error_
correction
dot_corr
Page 42
Document Feedback
Default
Access
Bit Description
R/W
0: At the end of a movie or a display picture the “low_
VDD” flag is not changed
1: At the end of a movie or a display picture, the “low_
VDD” flag is set to “0”
R/W
This bit indicates the supply status
0: If low_VDD is detected, the Interrupt Status
Register will be updated accordingly and pin IRQ is
triggered.
1: The low_VDD bit is directly mapped to the pin IRQ.
This can be used to control an external DC/DC
Converter or Charge Pump. In this case pin IRQ
cannot be used for interrupt functionality, the
Interrupt Status Register will be updated accordingly.
R/W
This bit defines the LED open handling
0: Open LEDs which are detected at LED open test,
are NOT disabled
1: Open LEDs which are detected at LED open test,
are disabled
R/W
Analog current DotCorrection(1)
0: Disabled
1: Enabled
ams Datasheet
[v2-01] 2016-Oct-12
Bit
3
2:0
Bit Name
Default
common_addr
mem_conf
Access
Bit Description
R/W
I²C Common Address
0: Disabled
1: Enabled (all AS1130 are reacting on the same
address “0111111”)
R/W
Define Memory Configuration(1)
(see RAM Configuration)
000: Invalid Configuration (default value)
001: RAM Configuration 1
010: RAM Configuration 2
011: RAM Configuration 3
100: RAM Configuration 4
101: RAM Configuration 5
110: RAM Configuration 6
Note(s):
1. This configuration is locked after the first write access to ON/OFF, PWM od DotCorrection data section. Unlock can be performed
only by a reset of the device.
Interrupt Mask Register (0x07)
Figure 46:
Interrupt Mask Register Format
0x07 Interrupt Mask Register
Bit
Bit Name
Default
Access
Bit Description
7
selected_pic
R/W
IRQ pin triggers if defined frame is displayed (see
Interrupt Frame Definition Register (0x08))
0: Disabled
1: Enabled
6
watchdog
R/W
IRQ pin triggers if the I²C watchdog triggers
0: Disabled
1: Enabled
5
por
1
R/W
IRQ pin triggers if POR is active
0: Disabled
1: Enabled
R/W
IRQ pin triggers if the overtemperature limit is
reached
0: Disabled
1: Enabled
R/W
IRQ pin triggers if VDD is too low for used LEDs
(low_VDD flag)
0: Disabled
1: Enabled
4
3
overtemp
low_vdd
ams Datasheet
[v2-01] 2016-Oct-12
Page 43
Document Feedback
Bit
Bit Name
Default
Access
Bit Description
2
open_err
R/W
IRQ pin triggers if an error on the open test occurs
0: Disabled
1: Enabled
1
short_err
R/W
IRQ pin triggers if an error on the short test occurs
0: Disabled
1: Enabled
movie_fin
R/W
IRQ pin triggers if a movie is finished
0: Disabled
1: Enabled
Per default this register is set to 0x3F.
Figure 47:
Interrupt Frame Definition Register Format
0x08 Interrupt Frame Definition Register
Bit
Bit Name
Default
Access
7:6
00
n/a
5:0
last_frame
Page 44
Document Feedback
111111
R/W
Bit Description
After this frame is displayed the last time
(depending on the number of loops played in a
movie) an interrupt will be triggered.
000000: Frame 0
000001: Frame 1
000010: Frame 2
000011: Frame 3
000100: Frame 4
000101: Frame 5
100000: Frame 32
100001: Frame 33
100010: Frame 34
100011: Frame 35
ams Datasheet
[v2-01] 2016-Oct-12
Shutdown & Open/Short Register (0x09)
Per default this register is set to 0x02.
Figure 48:
Shutdown & Open/Short Register Format
0x09 Shutdown & Open/Short Register
Bit
Bit Name
Default
Access
7:5
000
n/a
4
3
test_all
auto_test
Bit Description
R/W
The LED open/short test is performed on all LED
locations
0: Disabled (unassembled or disabled LEDs will be
detected as open)
1: Enabled (unassembled LEDs will be detected as
open)
R/W
The automatic LED open/short test is started when
bit display_pic (0x00) or bit display_movie (0x01) is set
to “1”
0: Disabled
1: Enabled
2
manual_test
R/W
The manual LED open/short test is started after the
update of Reg0x09
0: Disabled
1: Enabled
1
init
1
R/W
0: Initialise control logic (internal state machine is
reset again)
1: Normal operation
shdn
R/W
0: Device is in shutdown mode (outputs are turned off,
internal state machine stops)
1: Normal operation
The scan limit (0x04) defines also the number of segments for
the open/short detection.
ams Datasheet
[v2-01] 2016-Oct-12
Page 45
Document Feedback
I²C Interface Monitoring Register (0x0A)
This register is used to monitor the activity on the I²C bus. If a
deadlock situation occurs (e.g. the bus SDA pin is pulled to low
and no communication is possible) the chip will reset the I²C
interface and the master is able to start the communication
again.
The time window for the reset of the interface of the AS1130
can be set via 7 bits from 256μs to 33ms. The default setting of
this register is 0xFF.
Figure 49:
I²C Interface Monitoring Register Format
0x0A I²C Interface Monitoring Register
Bit
Bit Name
Default
Access
7
1
n/a
Bit Description
6:1
Timeout window
11111
R/W
Definition of the Timeout window (0 to 127 => 1 to
128 x 256μs)
0000000: 256μs
1111111: 32.7ms
i2c_monitor
1
R/W
0: I²C monitoring off
1: I²C monitoring on
CLK Synchronization Register (0x0B)
The default setting of this register is 0x00.
Figure 50:
CLK Synchronization Register Format
0x0B CLK Synchronization Register
Bit
Bit Name
Default
Access
7:4
0000
n/a
3:2
1
clk_out
sync_out
Page 46
Document Feedback
00
Bit Description
R/W
Adjustable clock out frequency
00: 1MHz
01: 500kHz
10: 125kHz
11: 32kHz
R/W
The internal oscillator is used as system-clk. The
selected clk frequency is available on pin D4 for
synchronization. (Output)(1)
0: Disabled
1: Enabled
ams Datasheet
[v2-01] 2016-Oct-12
Bit
Bit Name
Default
sync_in
Access
Bit Description
R/W
The internal oscillator is disabled. Pin D4 is used as clk
input for system-clk.(1)
0: disabled
1: enabled
Note(s):
1. CLK synchronization is done via the SYNC pin. Only one option can be activated (Input or Output).
Interrupt Status Register (0x0E)
This is a read only register. Within this register the cause of an
interrupt can be read out. After power up or a reset the default
setting of this register is 0x20. A read out command will set this
register to default and the IRQ pin will be released again.
Figure 51:
Interrupt Status Register Format
0x0E Interrupt Status Register
Bit
Bit Name
Default
Access
7
frame_int
R
0: No interrupt
1: Defined Frame is displayed (see Interrupt Frame
6
i2c_int
R
0: No interrupt
1: I²C watchdog reports a deadlock on the interface
5
por_int
1
R
0: No interrupt
1: POR was triggered
4
overtemp_int
R
0: No interrupt
1: Overtemperature limit is reached
3
low_vdd_int
R
0: No interrupt
1: VDD is too low to drive requested current through the
LEDs
2
open_int
R
0: No interrupt
1: Error on open test
1
short_int
R
0: No interrupt
1: Error on short test
movie_int
R
0: No interrupt
1: Play movie is finished
ams Datasheet
[v2-01] 2016-Oct-12
Bit Description
Page 47
Document Feedback
AS1130 Status Register (0x0F)
This is a read only register. From this register the actual status
of the AS1130 can be read out. The default setting of this
register is 0x00.
Figure 52:
AS1130 Status Register Format
0x0F AS1130 Status Register
Bit
Bit Name
Default
Access
Bit Description
7:2
frame_on
000000
R
Actual displayed frame
000000: Frame 0
000001: Frame 1
000010: Frame 2
000011: Frame 3
000100: Frame 4
000101: Frame 5
100000: Frame 32
100001: Frame 33
100010: Frame 34
100011: Frame 35
1
movie_on
R
0: No movie
1: Movie playing
test_on
R
0: No test is running
1: Open/short test ongoing
Page 48
Document Feedback
ams Datasheet
[v2-01] 2016-Oct-12
AS1130 Open LED Register (0x20 to 0x37)
This is a read only register. From this register the LED’s which failed with an open error can be read out. A ‘1’ indicates
LED okay, a ‘0’ stands for LED open. If a LED, which is physically not connected to the device is tested, the Open LED
test will return a ‘0’.
Figure 53:
Open LED Register Format
Address
Data
Segment
HEX
A7
A6
A5
A4
A3
A2
A1
A0
D7
D6
D5
D4
D3
D2
D1
D0
0x20
LED
07
LED
06
LED
05
LED
04
LED
03
LED
02
LED
01
LED
00
0x21
LED
0A
LED
09
LED
08
0x22
LED
17
LED
16
LED
15
LED
14
LED
13
LED
12
LED
11
LED
10
0x23
1
LED
1A
LED
19
LED
18
0x24
LED
27
LED
26
LED
25
LED
24
LED
23
LED
22
LED
21
LED
0x25
LED
2A
LED
29
LED
28
0x26
1
LED
37
LED
36
LED
35
LED
34
LED
33
LED
32
LED
31
LED
30
0x27
1
1
LED
3A
LED
39
LED
38
2
3
ams Datasheet
[v2-01] 2016-Oct-12
Page 49
Document Feedback
Address
Data
Segment
HEX
A7
A6
A5
A4
A3
A2
A1
A0
D7
D6
D5
D4
D3
D2
D1
D0
0x28
LED
47
LED
46
LED
45
LED
44
LED
43
LED
42
LED
41
LED
40
0x29
LED
4A
LED
49
LED
48
0x2A
LED
57
LED
56
LED
55
LED
54
LED
53
LED
52
LED
51
LED
50
0x2B
1
LED
5A
LED
59
LED
58
0x2C
1
LED
67
LED
66
LED
65
LED
64
LED
63
LED
62
LED
61
LED
60
0x2D
1
LED
6A
LED
69
LED
68
0x2E
1
1
LED
77
LED
76
LED
75
LED
74
LED
73
LED
72
LED
71
LED
70
0x2F
1
1
1
LED
7A
LED
79
LED
78
0x30
1
LED
87
LED
86
LED
85
LED
84
LED
83
LED
82
LED
81
LED
80
0x31
1
LED
8A
LED
89
LED
88
0x32
1
LED
97
LED
96
LED
95
LED
94
LED
93
LED
92
LED
91
LED
90
0x33
1
1
LED
9A
LED
99
LED
98
4
5
6
7
8
9
Page 50
Document Feedback
ams Datasheet
[v2-01] 2016-Oct-12
Address
Data
Segment
HEX
A7
A6
A5
A4
A3
A2
A1
A0
D7
D6
D5
D4
D3
D2
D1
D0
0x34
1
LED
A7
LED
A6
LED
A5
LED
A4
LED
A3
LED
A2
LED
A1
LED
A0
0x35
1
LED
AA
LED
A9
LED
A8
0x36
1
1
LED
B7
LED
B6
LED
B5
LED
B4
LED
B3
LED
B2
LED
B1
LED
B0
0x37
1
1
1
LED
BA
LED
B9
LED
B8
A
B
ams Datasheet
[v2-01] 2016-Oct-12
Page 51
Document Feedback
AS1130 − Typical Application
Typical Application
Scroll Function
The AS1130 offers a feature for scrolling a picture through the
matrix without the need of communication via a μP. The
scrolling can be done in the whole matrix (12x11) or optimized
for a ticker in a 5x24 matrix (see Figure 54).
Figure 54:
LED Configuration for 5LED Block Scroll Function
9
8
In the movie display mode the frame is shown in the matrix at
once. On the contrary in the scroll function the frame is shifted
through the matrix segment after segment (CS0 to CS1 to CS2
to CS3...).
Page 52
Document Feedback
ams Datasheet
[v2-01] 2016-Oct-12
Figure 55:
Scrolling
Figure 56:
Ticker Application with 5x96 LED Matrix
CS0 .. 11
SYNC_OUT
VDD
2.7V to 5.5V
CS0 .. 11
2.7V to 5.5V
CIN
SYNC_IN
VDD
CIN
ADDR
AS1130
ADDR
GND
R1
AS1130
GND
R1
SDA
SCL
RSTN
SDA
12
SCL
RSTN
12
12
12
scroll directions
CS0 .. 11
2.7V to 5.5V
SYNC_IN
VDD
CIN
SYNC_IN
VDD
CIN
ADDR
AS1130
ADDR
GND
R1
AS1130
GND
R1
SDA
ams Datasheet
[v2-01] 2016-Oct-12
CS0 .. 11
2.7V to 5.5V
SCL
RSTN
SDA
SCL
RSTN
Page 53
Document Feedback
LED Current Calculation
The current through a LED in the matrix is set via three registers
(Current Source Register, Dot Correction and PWM). The
resulting current through the single LED can be calculated as
shown in the following.
First it is necessary to calculate the time how long one LED will
be ON.
(EQ1)
PWM
t LEDon = --------------f OSC
Where:
t LEDon: Time where the LED is ON
PWM:. Value set in the register (0 - 256), see Figure 36
f OSC: Frequency set in the CLK Synchronization Register, see
Figure 50.
The refresh rate is defined by the scan-limit and f OSC.
(EQ2)
( scanlimit + 1 ) × 256
t REFRESH = -----------------------------------------------------f OSC
Where:
t REFRESH : Time needed to refresh the matrix scan-limit. is set via
the Display Option Register (0 - 11), see Figure 43
f OSC: frequency set in the CLK Synchronization Register, see
Figure 50
With the LED on-time and the refresh rate an average LED ON
factor can be calculated.
(EQ3)
t LEDon
PWM
LEDon avg = ------------------------ = -----------------------------------------------------t REFRESH
The resulting current is then the Segment Current (set in the
Current Source Register) times the average LED ON factor.
(EQ4)
PWM
I LEDavg = I SEG × LEDon avg = I SEG × -----------------------------------------------------( scanlimit + 1 ) × 256
Where:
I SEG : Segment Current set via register Figure 44
Example:
Assume that following conditions are set in the registers:
PWM = 256, scan-limit = 5 (half filled matrix, 66 LEDs),
I SEG = 30mA
(EQ5)
Page 54
Document Feedback
256
I LEDavg = 30mA × -------------------------------- = 5mA
( 5 + 1 ) × 256
ams Datasheet
[v2-01] 2016-Oct-12
AS1130 − Package Drawings & Markings
Figure 57:
20-Pin WL-CSP Package
RoHS
Green
Note(s):
1. Pin1= A1
2. ccc coplanarity
3. All dimensions are in μm.
ams Datasheet
[v2-01] 2016-Oct-12
Page 55
Document Feedback
AS1130 − Package Drawings & Mark ings
Figure 58:
28-Pin SSOP Package
REF
MIN
NOM
MAX
REF
MIN
A
A1
A2
b
c
D
E
1.73
0.05
1.68
0.22
0.09
9.90
7.40
1.86
0.13
1.73
0.30
0.17
10.20
7.80
1.99
0.21
1.78
0.38
0.25
10.50
8.20
E1
e
L
L1
L2
R
Θ
N
5.00
RoHS
0.55
0.09
0°
NOM
5.30
0.65 BSC
0.75
1.25 REF
0.25 BSC
4°
28
MAX
5.60
0.95
8°
Green
Note(s):
1. Dimensioning and tolerancing conform to ASME Y14.5M-1994.
2. All dimensions are in millimeters, angles in degrees.
3. N is the total number of terminals.
Page 56
Document Feedback
ams Datasheet
[v2-01] 2016-Oct-12
Figure 59:
28-Pin TSSOP Package
REF
MIN
A
A1
A2
b
c
D
E
E1
e
L
L1
0.05
0.80
0.19
0.09
9.60
4.30
0.45
NOM
1.00
9.70
6.40 BSC
4.40
0.65 BSC
0.60
1.00 REF
MAX
REF
MIN
1.20
0.15
1.05
0.30
0.20
9.80
R
R1
S
Θ1
Θ2
Θ3
aaa
bbb
ccc
ddd
N
0.09
0.09
0.20
0°
4.50
0.75
NOM
12 REF
12 REF
0.10
0.10
0.05
0.20
28
RoHS
MAX
8°
Green
Note(s):
ams Datasheet
[v2-01] 2016-Oct-12
Page 57
Document Feedback
Figure 60:
20-Pin WL-CSP Marking
AS1130
XXXX
1130B
XXXX
Figure 61:
Packaging Code XXXX
XXXX
Tracecode
Figure 62:
28-Pin SSOP Marking
AS1130
YYWWRZZ @
Page 58
Document Feedback
AS1130B
YYWWRZZ @
ams Datasheet
[v2-01] 2016-Oct-12
Figure 63:
28-Pin TSSOP Marking
AS1130
YYWWRZZ @
Figure 64:
Packaging Code YYWWRZZ
YY
Last two digits of the
manufacturing year
ams Datasheet
[v2-01] 2016-Oct-12
WW
Manufacturing
week
R
Plant
identifier
ZZ
Free choice / traceability
code
Sublot identifier
Page 59
Document Feedback
AS1130 − Ordering & Contact Information
The devices are available as the standard products shown in
Figure 65.
Figure 65:
Ordering
Code
Marking
Description
Logic
Levels
AS1130
Function
CMOS
AS1130B
Function
Mobile
Tape and Reel
AS1130C
Function
CMOS
Tape and Reel
AS1130D-BSST(1)
AS1130D
Function
Mobile
Tape and Reel
AS1130-BTST
AS1130
Driver with scrolling
Function
CMOS
Tape and Reel
AS1130B
Function
Mobile
Tape and Reel
AS1130C
Function
CMOS
Tape and Reel
AS1130D-BTST(1)
AS1130D
Function
Mobile
Tape and Reel
AS1130-BWLT
AS1130
Function
CMOS
Tape and Reel
AS1130B
Function
Mobile
Tape and Reel
tbd
Function
CMOS
Tape and Reel
tbd
Function
Package
AS1130-BSST
Address
Delivery
Form
Tape and Reel
0x30 - 0x37
AS1130B-BSST(1)
28-pin SSOP
AS1130C-BSST(1)
0x38 - 0x3E
0x30 - 0x37
AS1130B-BTST(1)
28-pin
TSSOP
AS1130C-BTST(1)
0x38 - 0x3E
0x30 - 0x37
AS1130B-BWLT
20-Pin
WL-CSP
AS1130C-BWLT(1)
0x38 - 0x3E
AS1130D-BWLT(1)
Mobile
Tape and Reel
Note(s):
1. On request
Page 60
Document Feedback
ams Datasheet
[v2-01] 2016-Oct-12
Buy our products or get free samples online at:
www.ams.com/ICdirect
Technical Support is available at:
www.ams.com/Technical-Support
Provide feedback about this document at:
www.ams.com/Document-Feedback
For further information and requests, e-mail us at:
ams_sales@ams.com
For sales offices, distributors and representatives, please visit:
www.ams.com/contact
Headquarters
ams AG
Tobelbader Strasse 30
8141 Premstaetten
Austria, Europe
Tel: +43 (0) 3136 500 0
Website: www.ams.com
ams Datasheet
[v2-01] 2016-Oct-12
Page 61
Document Feedback
AS1130 − RoHS Compliant & ams Green Statement
Statement
RoHS: The term RoHS compliant means that ams AG products
fully comply with current RoHS directives. Our semiconductor
products do not contain any chemicals for all 6 substance
categories, including the requirement that lead not exceed
0.1% by weight in homogeneous materials. Where designed to
be soldered at high temperatures, RoHS compliant products are
suitable for use in specified lead-free processes.
ams Green (RoHS compliant and no Sb/Br): ams Green
defines that in addition to RoHS compliance, our products are
free of Bromine (Br) and Antimony (Sb) based flame retardants
(Br or Sb do not exceed 0.1% by weight in homogeneous
material).
Important Information: The information provided in this
statement represents ams AG knowledge and belief as of the
date that it is provided. ams AG bases its knowledge and belief
on information provided by third parties, and makes no
representation or warranty as to the accuracy of such
information. Efforts are underway to better integrate
information from third parties. ams AG has taken and continues
to take reasonable steps to provide representative and accurate
information but may not have conducted destructive testing or
chemical analysis on incoming materials and chemicals. ams AG
and ams AG suppliers consider certain information to be
proprietary, and thus CAS numbers and other limited
information may not be available for release.
Page 62
Document Feedback
ams Datasheet
[v2-01] 2016-Oct-12
AS1130 − Copyrights & Disclaimer
Copyright ams AG, Tobelbader Strasse 30, 8141 Premstaetten,
Austria-Europe. Trademarks Registered. All rights reserved. The
material herein may not be reproduced, adapted, merged,
translated, stored, or used without the prior written consent of
the copyright owner.
Devices sold by ams AG are covered by the warranty and patent
indemnification provisions appearing in its General Terms of
Trade. ams AG makes no warranty, express, statutory, implied,
or by description regarding the information set forth herein.
ams AG reserves the right to change specifications and prices
at any time and without notice. Therefore, prior to designing
this product into a system, it is necessary to check with ams AG
for current information. This product is intended for use in
commercial applications. Applications requiring extended
temperature range, unusual environmental requirements, or
high reliability applications, such as military, medical
life-support or life-sustaining equipment are specifically not
recommended without additional processing by ams AG for
each application. This product is provided by ams AG “AS IS”
and any express or implied warranties, including, but not
limited to the implied warranties of merchantability and fitness
for a particular purpose are disclaimed.
ams AG shall not be liable to recipient or any third party for any
damages, including but not limited to personal injury, property
damage, loss of profits, loss of use, interruption of business or
indirect, special, incidental or consequential damages, of any
kind, in connection with or arising out of the furnishing,
performance or use of the technical data herein. No obligation
or liability to recipient or any third party shall arise or flow out
of ams AG rendering of technical or other services.
ams Datasheet
[v2-01] 2016-Oct-12
Page 63
Document Feedback
AS1130 − Document Status
Document Status
Document Status
Product Preview
Preliminary Datasheet
Datasheet
Datasheet (discontinued)
Page 64
Document Feedback
Product Status
Definition
Pre-Development
Information in this datasheet is based on product ideas in
the planning phase of development. All specifications are
design goals without any warranty and are subject to
change without notice
Pre-Production
Information in this datasheet is based on products in the
design, validation or qualification phase of development.
The performance and parameters shown in this document
are preliminary without any warranty and are subject to
Production
ramp-up to full production or full production which
conform to specifications in accordance with the terms of
ams AG standard warranty as given in the General Terms of
Trade
Discontinued
Information in this datasheet is based on products which
Trade, but these products have been superseded and
should not be used for new designs
ams Datasheet
[v2-01] 2016-Oct-12
AS1130 − Revision Information
Changes from 2-00 (2016-Sep-21) to current revision 2-01 (2016-Oct-12)
Updated Figure 60
Page
58
Note(s):
1. Page and figure numbers for the previous version may differ from page and figure numbers in the current revision.
2. Correction of typographical errors is not explicitly mentioned.
ams Datasheet
[v2-01] 2016-Oct-12
Page 65
Document Feedback
AS1130 − Content Guide
Content Guide
Page 66
Document Feedback
1
1
2
3
General Description
Applications
Block Diagram
4
6
7
10
Pin Assignment
16
16
16
19
22
22
I²C Interface
Command Byte
Initial Power-Up
Start-Up Sequence
Shutdown Mode
23
23
24
25
35
36
37
38
39
40
41
42
42
43
44
45
46
46
47
48
49
Register Selection
12x11 LED Matrix
Control-Registers
52
52
54
Typical Application
Scroll Function
55
60
62
63
64
65
Document Status
ams Datasheet
[v2-01] 2016-Oct-12
