NCT7511YTR
NCT7511YTR
    NUVOTON(新唐)
    WQFN16_EP
    ICH/WMONITOR16QFN
NCT7511YTR 数据手册
NCT7511Y Nuvoton H/W Monitoring IC Date: July/2012 Revision: 1.0 NCT7511Y Table of Content1. GENERAL DESCRIPTION ......................................................................................................... 1 2. FEATURES ................................................................................................................................. 1 2.1 Temperature Measurement ........................................................................................................1 2.2 Fan Speed Monitoring and Control ............................................................................................1 2.3 Event Notification.........................................................................................................................1 2.4 General ........................................................................................................................................1 3. KEY SPECIFICATIONS .............................................................................................................. 2 4. PIN CONFIGURATION ............................................................................................................... 2 5. PIN DESCRIPTION ..................................................................................................................... 3 6. 7. 5.1 PIN TYPE DISCRIPTION ...........................................................................................................3 5.2 PIN DISCRIPTION ......................................................................................................................3 FUNCTION DESCRIPTION ........................................................................................................ 4 6.1 GENERAL DESCRIPTION ........................................................................................................4 6.2 ACCESS INTERFACE ...............................................................................................................4 6.2.1 Data write to the internal register .............................................................................. 4 6.2.2 Data read from the internal register .......................................................................... 4 6.3 ADDRESS SETTING ..................................................................................................................5 6.4 TEMPERATURE MONITOR DATA FORMAT .........................................................................5 6.4.1 The local temperature (on-die) data with 8-bit 2`s complement format ..................... 5 6.4.2 The remote temperature data with 11-bit 2`s complement format ............................ 5 6.5 FAN_IN Count Calculation .........................................................................................................5 6.6 FAN_OUT Duty Cycle Calculation .............................................................................................6 6.7 SMART FAN TM IV Control Parameters ......................................................................................6 6.7.1 Step Up Time / Step Down Time .............................................................................. 6 6.7.2 Fan Output Start-up Value ........................................................................................ 6 6.7.3 Fan Output Nonstop Value ....................................................................................... 6 6.7.4 Fan Output Stop Time .............................................................................................. 6 TM 6.8 SMART FAN IV........................................................................................................................7 6.9 ALERT# Output ...........................................................................................................................8 6.9.1 ALERT# Output Mechanism ..................................................................................... 8 6.9.2 ALERT Response Address ....................................................................................... 9 6.10 T_CRIT# Output ..........................................................................................................................9 6.11 SHDN_SEL ............................................................................................................................... 10 6.12 T_CRIT#_SET .......................................................................................................................... 10 REGISTER DESCRIPTION ...................................................................................................... 13 7.1 REGISTER MAP ...................................................................................................................... 13 7.2 REGISTER DETAIL ................................................................................................................. 16 7.2.1 Remote Diode 1 Temperature Readout Register (MSB) ........................................ 16 Confidential -I- July, 2012 Version: 1.0 NCT7511Y 7.2.2 Remote Diode 2 Temperature Readout Register (MSB) ........................................ 16 7.2.3 Local Diode Temperature Readout Register (MSB) ............................................... 16 7.2.4 Temperature Readout Register (LSB) .................................................................... 16 7.2.5 Fan Count 1 Readout Register (MSB) .................................................................... 17 7.2.6 Fan Count Readout Register (LSB) ........................................................................ 17 7.2.7 T_CRIT#_SET Point Register................................................................................. 17 7.2.8 Alert Status Register ............................................................................................... 17 7.2.9 Diode Fault Alert Status Register ........................................................................... 18 7.2.10 Low Alert Status Register ....................................................................................... 18 7.2.11 High Alert Status Register ...................................................................................... 18 7.2.12 Fan Alert Status Register........................................................................................ 18 7.2.13 T_CRIT# Alert Status Register ............................................................................... 19 7.2.14 GPIO Alert Status Register ..................................................................................... 19 7.2.15 T_CRIT# Real Time Status Register ...................................................................... 19 7.2.16 Start Register.......................................................................................................... 19 7.2.17 Mode Selection Register......................................................................................... 20 7.2.18 Fan Enable Register ............................................................................................... 20 7.2.19 Conversion Rate Register....................................................................................... 20 7.2.20 Fault Queue Register ............................................................................................. 20 7.2.21 Alert# High Limit Link to T_CRIT# .......................................................................... 21 7.2.22 RTD1 Temperature High Limit Register.................................................................. 21 7.2.23 RTD1 Temperature Low Limit Register .................................................................. 21 7.2.24 RTD2 Temperature High Limit Register.................................................................. 21 7.2.25 RTD2 Temperature Low Limit Register .................................................................. 22 7.2.26 LTD Temperature High Limit Register .................................................................... 22 7.2.27 LTD Temperature Low Limit Register ..................................................................... 22 7.2.28 RTD1 T_CRIT# Threshold Register ....................................................................... 22 7.2.29 RTD2 T_CRIT# Threshold Register ....................................................................... 23 7.2.30 LTD T_CRIT# Threshold Register .......................................................................... 23 7.2.31 FANIN1 Limit Low Byte Register ............................................................................ 23 7.2.32 FANIN1 Limit High Byte Register ........................................................................... 23 7.2.33 ALERT Mask Register Register .............................................................................. 24 7.2.34 ALERT Mask Temperature Channel Register ........................................................ 24 7.2.35 ALERT Mask Fan Channel Register ....................................................................... 24 7.2.36 T_CRIT# Mask Register ......................................................................................... 25 7.2.37 GPIO Alert Mask Register ...................................................................................... 25 7.2.38 GPIO Mode Register .............................................................................................. 25 7.2.39 GPIO Output Type Register.................................................................................... 26 7.2.40 GPIO Input Data Register ....................................................................................... 26 7.2.41 GPIO Output Data Register .................................................................................... 26 7.2.42 Fan Control Output Type Register .......................................................................... 26 7.2.43 Fan Control Output Mode Register ......................................................................... 27 7.2.44 Fan Control 1 Output Value Register ...................................................................... 27 7.2.45 Close-Loop Fan Control RPM mode Register ........................................................ 27 Confidential - II - July, 2012 Version: 1.0 NCT7511Y 8. 7.2.46 Temperature to Fan mapping Relationships Register ............................................ 27 7.2.47 Temperature to Fan mapping Relationships Register ............................................ 28 7.2.48 Fan Control Configuration Register 1 ..................................................................... 28 7.2.49 Fan Control Configuration Register 2 ..................................................................... 29 7.2.50 Fan Control Configuration Register 3 ..................................................................... 29 7.2.51 Fan Control Configuration Register 4 ..................................................................... 29 7.2.52 Fan 1 Target Register ............................................................................................. 29 7.2.53 Close-Loop Fan Control RPM Mode Tolerance Register ....................................... 30 7.2.54 FANCTL Step Up Time Register ............................................................................ 30 7.2.55 FANCTL Step Down Time Register ........................................................................ 30 7.2.56 Default Fan Speed Register ................................................................................... 30 7.2.57 FANCTL1 PWM Prescalar Register ....................................................................... 31 7.2.58 Temperature1 Hysteresis Register ......................................................................... 32 7.2.59 Temperature 2 Hysteresis Register ........................................................................ 32 7.2.60 Temperature 3 Hysteresis Register ........................................................................ 32 7.2.61 FANCTL Start Duty Cycle Register ........................................................................ 32 7.2.62 FANCTL Stop Time Register .................................................................................. 33 7.2.63 SMART FAN 7.2.64 TD1 Offset Register ................................................................................................ 34 7.2.65 TD2 Offset Register ................................................................................................ 34 7.2.66 Soft Reset Register ................................................................................................ 34 7.2.67 Vendor ID Register ................................................................................................. 34 7.2.68 Chip ID Register ..................................................................................................... 35 7.2.69 Device ID Register .................................................................................................. 35 TM IV Temperature and PWM Registers Register .............................. 33 ELECTRICAL CHARACTERISTICS ......................................................................................... 36 8.1 Absolute Maximum Ratings ..................................................................................................... 36 8.2 DC Characteristics ................................................................................................................... 36 8.3 AC Characteristics.................................................................................................................... 37 9. ORDERING INFORMATION ..................................................................................................... 38 10. TOP MARKING SPECIFICATION ............................................................................................ 38 11. TAPING SPECIFICATION ........................................................................................................ 39 12. PACKAGE DRAWING AND DIMENSIONS .............................................................................. 40 13. REVISION HISTORY ................................................................................................................ 41 Confidential - III - July, 2012 Version: 1.0 NCT7511Y 1. GENERAL DESCRIPTION The NCT7511Y is a Nuvoton Hardware Monitor IC, which can monitor several critical hardware parameters of the systems, including the temperature and fan speeds, to make the system work stably and efficiently. The NCT7511Y supports one on-die and two remote temperature sensors with SMBus interface. There’s a 10-bit analog-to-digital converter (ADC) is built inside NCT7511Y, to convert the monitored temperature value. Both of the remote temperature inputs can be connected to CPU/GPU thermal diode or any diode sensors and thermistor. TM The NCT7511Y has 1 fan control groups and two GPIO pins. The SMART FAN IV mode of the fan speed control provides 4 sets of temperature setting points, and they can also control the duty cycle of fan outputs. It provides an easy method to implement quiet and cooling solution with maximum safety and flexibility. Meanwhile, there’re two pure hardware event pins ALERT# and T_CRIT# for independent alarm signals, and all threshold values could be set for system protection without timing delay. 2. FEATURES 2.1 Temperature Measurement  Measure the temperature with high accuracy.  One local on-die thermal sensor  Two pairs thermal diode (current mode) temperature channels 2.2 Fan Speed Monitoring and Control TM  SMART FAN  One fan control output multi-function (PWM/DC mode supported)  One fan tachometer input multi-function 2.3 IV mode or Manual mode to control the fan speed Event Notification  Supports 2 alarm outputs: ALERT# and T_CRIT# signals to activate system protection.  ALERT# output supports SMBus  T_CRIT# supports Hardware Power-on setting 2.4 TM 2.0 ARA function General  Two GPIO pins  I C® Compatible System Management bus (SMBus)  3.3V±5% VCC operation  16-pin QFN (Halogen free) 2 Confidential -1- July, 2012 Version: 1.0 NCT7511Y 3. KEY SPECIFICATIONS  Temperature Sensor Accuracy Remote Diode Sensor Accuracy (25~85C)  1C typ. On-chip Temperature Sensor Accuracy (25~70C)  2C typ. Remote Temperature Sensor Resolution 0.125 ℃ Local Temperature Sensor Resolution 1℃  Supply Voltage 3.3V  5%  Operating Supply Current TBD  Operating Temperature Range *1 Guaranteed by design from -40~85 degree C, 100% tested at 85 degree C. -40C ~ 85C *1 SCL 12 11 10 9 GND FANIN1 FANCTL1 4. PIN CONFIGURATION SHDL_SEL 13 T_CRIT#_SET 14 TD2- 15 8 SDA NCT7511Y 3 4 GPIO1 2 VCC 1 TD1+ ‧ 6 ALERT# 5 GPIO2 TD1- TD2+ 16 7 T_CRIT# Confidential -2- July, 2012 Version: 1.0 NCT7511Y 5. PIN DESCRIPTION 5.1 PIN TYPE DISCRIPTION PIN TYPE PIN ATTRIBUTE OD12 Open-drain output pin with 12 mA sink capability INts TTL level input pin and schmitt trigger AIN Input pin (Analog) OUT12 Output pin with 12 mA sink/source capability AOUT Output pin (Analog) P 5.2 Power or Ground Pin PIN DISCRIPTION PIN NO. PIN NAME I/O FUNCTION 1 TD1- AIN Connect to Thermal Diode 1 Cathode. 2 TD1+ AIN Connect to Thermal Diode 1 Anode. 3 VCC P 4 GPIO1 INts / OD12 General purpose I/O function. 5 GPIO2 INts / OD12 General purpose I/O function. 6 ALERT# OD12 Alarm output, for interrupt control 7 T_CRIT# OD12 T_CRIT# alarm output, for interrupt or shutdown control. 8 SDA INts/ OD12 9 SCL INts SMBus Clock. 10 FANIN1 INts Fan tachometer input Power supply, Voltage input 3.3V±5% SMBus bi-directional data. It can be configured to PWM/DC mode by registers. Default is PWM output. 11 FANCTL1 OUT12/ AOUT 12 GND P 13 SHDN_SEL AIN Selects the hardware shutdown channel and operating mode 14 T_CRIT#_SET AIN Voltage input to set the Critical/Thermal Shutdown threshold 15 TD2- AIN Connect to Thermal Diode 2 Cathode. As DC output, 256 steps output voltage scaled to 0~VCC. Power supply ground Confidential -3- July, 2012 Version: 1.0 NCT7511Y PIN NO. PIN NAME I/O 16 TD2+ AIN FUNCTION Connect to Thermal Diode 2 Anode. 6. FUNCTION DESCRIPTION 6.1 GENERAL DESCRIPTION TM The NCT7511Y is a SMBus interface device to provide one on-die temperature sensor, two set of inputs for thermal diode sensors, 1 fan control groups, and two GPIO pins. The NCT7511Y also provides ALERT# and T_CRIT# alarm signals for event notification. 6.2 ACCESS INTERFACE NCT7511Y provides SMBus to access the internal register, supports SMBus byte write and byte read protocols. 6.2.1 Data write to the internal register 6.2.2 Data read from the internal register Confidential -4- July, 2012 Version: 1.0 NCT7511Y 6.3 ADDRESS SETTING NCT7511Y I2C/SMBus address is 0101110xb (x is R/W bit). 6.4 TEMPERATURE MONITOR DATA FORMAT 6.4.1 6.4.2 The local temperature (on-die) data with 8-bit 2`s complement format TEMPERATURE 8-BIT DIGITAL OUTPUT +127°C 0111,1111 +25°C 0001,1001 +2°C 0000,0010 +1°C 0000,0001 +0°C 0000,0000 - 1°C 1111,1111 - 2°C 1111,1110 - 25°C 1110,0111 - 128°C 1000,0000 The remote temperature data with 11-bit 2`s complement format TEMPERATURE 8-BIT DIGITAL OUTPUT HIGH BYTE 3-BIT DIGITAL OUTPUT LOW BYTE +127.875°C 0111,1111 111X,XXXX +25.750°C 0001,1001 110X,XXXX +2.250°C 0000,0010 010X,XXXX +1.125°C 0000,0001 001X,XXXX +0.000°C 0000,0000 000X,XXXX - 1.125°C 1111,1110 111X,XXXX - 2.250°C 1111,1101 110X,XXXX - 25.750°C 1110,0110 010X,XXXX - 127.875°C 1000,0000 001X,XXXX 6.5 FAN_IN Count Calculation The FAN_IN tachometer high byte and low byte are combined to 12-bitCountValue. Real RPM (Rotate per Minute) calculation should follow the formula: FanSpeed ( RPM )  1.35  10 6 (12  bitCountVa lue )  ( FanPoles ) 4 Confidential -5- July, 2012 Version: 1.0 NCT7511Y In this formula, FanPoles stands for the number of NS pole pairs inside the fan. Normally an N-S-N-S Fan (FanPoles=4) generates 2 pulses after completing one rotation. 6.6 FAN_OUT Duty Cycle Calculation The NCT7511Y provides 1 set of PWM for fan speed control. The duty cycle of PWM can be programmed by an 8-bit register. The expression of duty cycle can be represented as follow formula: Duty  cycle(%)  Programmed 8 - bit Register Value 100% 255 SMART FANTM IV Control Parameters 6.7 In SMART FAN 6.7.1 TM IV Mode, there are some Fan control parameters as below descriptions: Step Up Time / Step Down Time TM SMART FAN IV is designed for the smooth operation of the fan. The Up Time / Down Time register defines the time interval between successive duty increases or decreases. If this value is set too small, the fan will not have enough time to speed up after tuning the duty and sometimes may result in unstable fan speed. On the other hand, if Up Time / Down Time is set too large, the fan may not work fast enough to dissipate the heat. This register should never be set to 0, otherwise, the fan duty will be abnormal. 6.7.2 Fan Output Start-up Value From still to rotate, the fan usually needs a higher fan output value to generate enough torque to conquer the restriction force. Thus the Fan Output Start-up Value is used to turn on the fan with the specified output value. 6.7.3 Fan Output Nonstop Value It takes some time to bring a fan from still to working state. Therefore, Nonstop value are designed with a minimum fan output to keep the fan working when the system does not require the fan to help reduce heat but still want to keep the fast response time to speed up the fan. 6.7.4 Fan Output Stop Time A time interval is specified to turn off the fan if SMART FAN the fan which has already reached the Stop time. TM IV continuously requests to slow down UpTime DownTime NonStop Start FanSpeed StopTime Smart Fan Arising Fan Speed Smart Fan Lowering FanSpeed Figure 6-1 SMART FAN TM Control Parameters Confidential -6- July, 2012 Version: 1.0 NCT7511Y 6.8 SMART FANTM IV TM SMART FAN IV supports Fan Duty Outputs Mode and Close Loop Fan Control (RPM) Mode to control the fan speed. There’re 3 slopes can be obtained by setting FanDuty/RPM1~FanDuty/RPM4 and T1~T4 through the registers. When the temperature rises, FAN Output will calculate the target FanDuty/RPM based on the current slope. For example, assuming Tx is the current temperature and FanDuty/RPM is the target, then the slope: X2  FanDuty3 / RPM 3  FanDuty 2 / RPM 2 T 3  T 2 Fan Output: T arg et FanDuty or RPM  FanDuty 2 or RPM 2  Tx  T 2  X 2 Fanduty/RPM (unit RPM = 50 ) Critical Hyst. Operation Hyst. FullSpeed (FF, 100%) Fanduty4/RPM4 Fanduty3/RPM3 Ty Fanduty2/RPM2 X3 X2 X1 Fanduty1/RPM1 Temperature T1 Tx T2 Figure 6-2 SMART FAN TM T3 T4 TRCritical IV Mechanism TM In addition, SMART FAN IV can also set up Critical Temperature and Hysteresis. If the current temperature exceeds Critical Temperature, external fan will be forced by maximum FanDuty to meet the largest target FanDuty or RPM, Which is 0xFF. The target FanDuty & RPM value will be determined in accordance to the slope only when the temperature falls below (TCritical – Criticl Hyst.) NCT7511Y provides 3 temperature source selections to map the fan, the algorithm will make a decision to control the fan as below figure: Confidential -7- July, 2012 Version: 1.0 NCT7511Y Any Temp request faster Fan?? Yes Speed Up Yes Hold current Speed No Any Temp request f hold current speed?? No 6.9 Slow Down ALERT# Output The NCT7511Y ALERT# pin is an active-low open-drain output pin which is triggered when measured temperature exceeds the limitation defined in the limit registers. There are three types of ALERT# output mode: the ALERT# output comparator mode, the ALERT# output interrupt mode, and the ALERT# output SMBus ALERT# mode. 6.9.1 ALERT# Output Mechanism Figure 6-3 shows the mechanism of the ALERT# output. In this mode, the NCT7511Y will set the ALERT mask bit of Configuration Register during a read of the Status Register if any flag in Status Register, except the ADC_Busy flag and Remote Diode Open flag, is set. This prevents further ALERT# triggering until the master has reset the ALERT mask bit (write 0 to Alert_MSK), at the end of the interrupt service routine. The Status Register flags are cleared only upon a read Status Register command from the master and will be re-alerted at the end of the next temperature conversion if the measured temperature still falls outside of the allowed range. Temperature Value Temp Limt Alert# Status Alert Mask Read Mask Read Status register register ARA Figure 6-3 ALERT# Output Mechanism Confidential -8- July, 2012 Version: 1.0 NCT7511Y 6.9.2 ALERT Response Address Figure 6-4 shows the mechanism of the SMBus ALERT Response Address (ARA) support on ALERT# output. In this mode, the ALERT# output of the NCT7511Y is connected to the SMBus alert line which has more than one device connected to it. Through such and implementation, SMBus alert mode can assist the master in resolving which salve generates an interrupt. When the measured temperature falls outside of the allowed range, the ALERT# pin will be pulled low and the corresponding alert flags in Status Register will be set to 1. The ALERT mask bit will just be set if there is a read command for Status Register or when ARA occurs from master (Alert Response Address is 0001100x). Meanwhile, the NCT7511Y will generate and return its own address to the master. If the temperature never falls outside of the allowed range, the latched ALERT# pin can release by the reset ALERT mask bit and the latched corresponding alert flags in Status Register can release by reading command for Status Register. Figure 6-4 SMBus ARA Mechanism 6.10 T_CRIT# Output T_CRIT# output pulls low when the measured temperature exceeds the critical temperature setting. Once the T_CRIT# output pulls low, it will not be set high until the measured temperature is lower than “T_CRIT# – TH”, where TH is Temperature Hysteresis. Status Register will not be reset until it is read and the temperature conversion falls below the T_CRIT# set point. Figure 6-5 shows this mechanism. Figure 6-5 T_CRIT# Output Mechanism Confidential -9- July, 2012 Version: 1.0 NCT7511Y 6.11 SHDN_SEL The NCT7511Y has a strapping input pin (SHDN_SEL) allowing for configuration of the hardware Critical/Thermal Shutdown input channel. The pull-up resistor used on SHDN_SEL pin identifies which configuration setting is used as shown in table. PULL-UP RESISTOR(Ω) MODE / SHUTDOWN CHANNEL 4.7K ~ 10K RTD1 6.12 T_CRIT#_SET The NCT7511Y's T_CRIT#_SET pin is an analog input pin to set the Critical/Thermal shutdown temperature by trapping voltage when system power on. The thermal shutdown temperature is ranging from 65℃ to 127℃ as shown in table. Trapping Temp(HEX) Trapping Temp(DEC) Trapping Volt(V) 41 65 1.112 41 65 1.144 41 65 1.176 42 66 1.207 43 67 1.239 44 68 1.271 45 69 1.303 46 70 1.334 47 71 1.366 48 72 1.398 49 73 1.430 4a 74 1.461 4b 75 1.493 4c 76 1.525 4d 77 1.557 4e 78 1.589 4f 79 1.620 50 80 1.652 51 81 1.684 52 82 1.716 53 83 1.747 54 84 1.779 55 85 1.811 Confidential - 10 - July, 2012 Version: 1.0 NCT7511Y Trapping Temp(HEX) Trapping Temp(DEC) Trapping Volt(V) 56 86 1.843 57 87 1.875 58 88 1.906 59 89 1.938 5a 90 1.970 5b 91 2.002 5c 92 2.033 5d 93 2.065 5e 94 2.097 5f 95 2.129 60 96 2.160 61 97 2.192 62 98 2.224 63 99 2.256 64 100 2.288 65 101 2.319 66 102 2.351 67 103 2.383 68 104 2.415 69 105 2.446 6a 106 2.478 6b 107 2.510 6c 108 2.542 6d 109 2.573 6e 110 2.605 6f 111 2.637 70 112 2.669 71 113 2.701 72 114 2.732 73 115 2.764 74 116 2.796 75 117 2.828 76 118 2.859 77 119 2.891 78 120 2.923 79 121 2.955 Confidential - 11 - July, 2012 Version: 1.0 NCT7511Y Trapping Temp(HEX) Trapping Temp(DEC) Trapping Volt(V) 7a 122 2.986 7b 123 3.018 7c 124 3.050 7d 125 3.082 7e 126 3.114 7f 127 3.145 Confidential - 12 - July, 2012 Version: 1.0 NCT7511Y 7. REGISTER DESCRIPTION 7.1 REGISTER MAP Idx Register Name Att 1 Read RTD1 MSB R MNTRTD1[10:3] 2 Read RTD2 MSB R MNTRTD2[10:3] 4 Read LTD MSB R MNTLTD[10:3] 5 Read Temp LSB R 10 Read Fan Count 1MSB R 13 Read Fan Count 1LSB R 14 R 16 17 T_CRIT#_SET Point Interrupt Alert Status Register Diode Fault Alert Status Df 7 6 5 4 3 MNTTD_Lsb[2:0] 2 1 0 RSV MNTFAN1[12:5] MNTFAN_Lsb[4:0] RSV T_CRIT#_SET Point R RSV TCRIT R GPIO FAN High RSV 18 Low Alert Status R RSV 19 High Alert Status R RSV Fault STS_DF2 STS_DF1 STS_AL4 RSV STS_AL2 STS_AL1 STS_AH4 RSV STS_AH2 STS_AH1 RSV FAN_FC1 RSV STS_TC2 STS_TC1 FAN_TAR 1 1A Fan Alert Status R 1B T_CRIT# Alert Status R 1C GPIO Alert Stuts R 20 T_CRIT# Real Time Status R 21 START R/W 01 Msk_Alert 22 Mode Selection R/W 55 RSV 24 Fan Enable R/W 01 26 Conversion Rate R/W 02 RSV ConvRate[1:0] 27 Fault Queue R/W 03 RSV FaultQueue[1:0] 28 Alert High link to T_CRIT# R/W 00 30 RTD1 Temp High Limit R/W 55 RTD1_HL 31 RTD1 Temp Low Limit R/W 00 RTD1_LL 32 RTD2 Temp High Limit R/W 55 RTD2_HL 33 RTD2 Temp Low Limit R/W 00 RTD2_LL 36 LTD Temp High Limit R/W 55 LTD_HL 37 LTD Temp Low Limit R/W 00 LTD_LL R/W 64 T_CRIT#_RTD1 R/W 64 T_CRIT#_RTD2 R/W 64 T_CRIT#_LTD 49 FANIN1 Limit low Byte R/W FF FANIN1_HL[7:0] 4C FANIN1 Limit high byte R/W F8 3A 3B 3D 4F RTD1 T_CRIT# Threshold RTD2 T_CRIT# Threshold LTD T_CRIT# Threshold Alert Mask function R/W RSV Low RSV STS_TC4 RSV RSV 7F LTD_Texc RSV STS_GPI STS_GPI O2 O1 RTD2_Te RTD1_Te xc xc RSV EnLTD RSV START RTD2_MD RTD1_MD RSV RSV EnFan1 SYS3 FANIN1_HL[12:8] Msk_Alert Msk_TC Msk_GPI Msk_TAR Msk_FC O T Confidential - 13 - SYS2 SYS1 RSV Msk_AH Msk_AL Msk_DF July, 2012 Version: 1.0 NCT7511Y Idx Register Name Att Alert / SMI Mask Temp 50 R/W Channel Alert / SMI Mask FAN 51 R/W Channel Df 7 6 3F 5 4 RSV Msk_LTD 07 T_CRIT# Mask R/W BF 54 GPIO Alert Mask R/W 3F RSV 56 GPIO mode R/W 3F RSV 57 GPIO output type R/W 00 RSV 58 GPIO input data R 59 GPIO output data R/W 00 R/W 00 R/W 00 RW 7F RW 00 RW 00 RW 00 5F 60 63 64 65 66 67 68 69 Fan Control Output Type Fan Control Output Mode Fan Control 1 Output Value Close-Loop Fan Control RPM mode Register Temperature to Fan mapping Relationships Temperature to Fan mapping Relationships Configuration Register 1 Configuration Register 2 Configuration Register 3 Configuration Register 4 1 RSV Msk_ALL RSV Msk_LTD Msk_RTD Msk_RTD 2 1 Msk_GPI Msk_GPI O2 O1 GPIO2 GPIO1 Mode Mode GPIO2 GPIO1 OB OB RSV RSV RW 00 RW 00 RW 00 RW 00 0 Msk_RTD Msk_RTD 2 1 Msk_Fan1 GPIO2 in GPIO1 in GPIO2 out RSV PWM1_P ol RSV GPIO1 out EnDCFAN 1 PWM1_O D RSV RSV FANDuty1 RSV RSV TwoDimen sion RPM_HIG H_EN RSV Temp2FanSelect RSV RSV Temp2_Sh are_En Temp2_Share_Sel RSV RSV RSV Temp1FanSelect Temp3FanSelect Temp2_Sour_Sel Temp1_S hare_En Temp3_S hare_En RSV RSV Temp1_Share_Sel Temp3_Share_Sel Temp1_Sour_Sel Temp3_Sour_Sel 6A Fan1_Target R 6D Close-Loop Fan Control RPM mode Tolerance RW 00 6E Fanctl Step Up Time RW 0A UpTime 6F Fanctl Step Down Time RW 0A DownTime 70 RW 7F DefaultFanSpeed DefaultFanSpeed 2 RSV 53 5E 3 Fan1_Target[7:0] RSV Generic_Tol_RPM 71 PWM1 Prescalar RW FanOutDivi 84 sor1[7] 74 Temp1 Hysteresis RW 53 RSV Criti_HysT1 RSV Oper_HysT1 75 Temp2 Hysteresis RW 53 RSV Criti_HysT2 RSV Oper_HysT2 76 Temp3 Hysteresis RW 53 RSV Criti_HysT3 RSV Oper_HysT3 77 Fanctl1 Start Duty Cycle RW 30 StartDutyCycle 78 Stop Time of Fanctl1 RW FF StopTime RW 00 Temp1Table_TR1 RW 00 Temp1Table_TR2 RW 00 Temp1Table_TR3 RW 00 Temp1Table_TR4 80 81 82 83 Table 1 Transition Point 1 Table 1 Transition Point 2 Table 1 Transition Point 3 Table 1 Transition Point 4 FanOutDivisor1[6:0] Confidential - 14 - July, 2012 Version: 1.0 NCT7511Y Idx Register Name Att Df 84 Table 1 Critical Point RW 00 Temp1Table_TRCritical RW 00 Temp1Table_FL1 RW 00 Temp1Table_FL2 RW 00 Temp1Table_FL3 RW 00 Temp1Table_FL4 RW 00 Temp2Table_TR1 RW 00 Temp2Table_TR2 RW 00 Temp2Table_TR3 RW 00 Temp2Table_TR4 RW 00 Temp2Table_TRCritical RW 00 Temp2Table_FL1 RW 00 Temp2Table_FL2 RW 00 Temp2Table_FL3 RW 00 Temp2Table_FL4 RW 00 Temp3Table_TR1 RW 00 Temp3Table_TR2 RW 00 Temp3Table_TR3 RW 00 Temp3Table_TR4 RW 00 Temp3Table_TRCritical RW 00 Temp3Table_FL1 RW 00 Temp3Table_FL2 RW 00 Temp3Table_FL3 RW 00 Temp3Table_FL4 85 86 87 88 90 91 92 93 94 95 96 97 98 A0 A1 A2 A3 A4 A5 A6 A7 A8 Table 1 Y-axis Transition Point 1 Table 1 Y-axis Transition Point 2 Table 1 Y-axis Transition Point 3 Table 1 Y-axis Transition Point 4 Table 2 Transition Point 1 Table 2 Transition Point 2 Table 2 Transition Point 3 Table 2 Transition Point 4 Table 2 Critical Point Table 2 Y-axis Transition Point 1 Table 2 Y-axis Transition Point 2 Table 2 Y-axis Transition Point 3 Table 2 Y-axis Transition Point 4 Table 3 Transition Point 1 Table 3 Transition Point 2 Table 3 Transition Point 3 Table 3 Transition Point 4 Table 3 Critical Point Table 3 Y-axis Transition Point 1 Table 3 Y-axis Transition Point 2 Table 3 Y-axis Transition Point 3 Table 3 Y-axis Transition Point 4 7 6 5 4 3 2 C1 TD1 Offset R/W 00 RSV Offset_TD1 C2 TD2 Offset R/W 00 RSV Offset_TD2 FC SOFT RESET W FD Vendor ID R Vendor ID FE ChipID R ChipID FF Device ID R Version ID INIT 1 0 RSV Confidential - 15 - July, 2012 Version: 1.0 NCT7511Y 7.2 REGISTER DETAIL 7.2.1 Remote Diode 1 Temperature Readout Register (MSB) Location : Index 01h Type : Read Only Power on default value : 00h BIT 7 6 5 7.2.2 3 2 1 0 2 1 0 2 1 0 2 1 0 MNTRTD1[10:3] NAME FUNC. 4 MNTRTD1[10:3] : Readout of RTD1 MSB. Remote Diode 2 Temperature Readout Register (MSB) Location : Index 02h Type : Read Only Power on default value : 00h BIT 7 6 5 7.2.3 3 MNTRTD2[10:3] NAME FUNC. 4 MNTRTD2[10:3] : Readout of RTD2 MSB. Local Diode Temperature Readout Register (MSB) Location : Index 04h Type : Read Only Power on default value : 00h BIT 7 6 5 7.2.4 3 MNTLTD[10:3] NAME FUNC. 4 MNTLTD[10:3] : Readout of LTD MSB. Temperature Readout Register (LSB) Location : Index 05h Type : Read Only Power on default value : 00h BIT 7 5 4 3 MNTTD_LSB[2:0] NAME FUNC. 6 RSV MNTTD_LSB[2:0] : Readout of RTD and LTD LSB. Confidential - 16 - July, 2012 Version: 1.0 NCT7511Y 7.2.5 Fan Count 1 Readout Register (MSB) Location : Index 10h Type : Read Only Power on default value : 00h BIT 7 6 5 4 7.2.6 2 1 0 2 1 0 MNTFAN1[12:5] NAME FUNC. 3 MNTFAN1[12:5] : Readout of Fan Count 1 MSB. Fan Count Readout Register (LSB) Location : Index 13h Type : Read Only Power on default value : 00h BIT 7 6 7.2.7 4 3 RSV MNTFAN_LSB[4:0] NAME FUNC. 5 MNTFAN_LSB[4:0] : Readout of Fan Count LSB. T_CRIT#_SET Point Register Location : Index 14h Type : Read Only Power on default value : refer to the section 5.12 T_CRIT#_SET BIT 7 6 5 7.2.8 3 2 1 0 T_CRIT#_SET Point NAME FUNC. 4 T_CRIT#_SET Point : Temperature point of T_CRIT#_SET power on strapping. Alert Status Register Location : Index 16h Type : Read Only Power on default value :00h BIT 7 6 RSV NAME 5 4 3 2 1 0 T_CRIT# GPIO FAN High Low Fault T_CRIT# : 1 indicates the T_CRIT# event asserts. GPIO : 1 indicates the GPIO event asserts. FUNC. FAN : 1 indicates the Fan event asserts, corresponds to Index[1Ah]. High : 1 indicates the High event asserts, corresponds to Inex[19h] Low : 1 indicates the Low event asserts, corresponds to Index[18h]. Fault : 1 indicates the Fault event asserts, corresponds to Index[17h]. Confidential - 17 - July, 2012 Version: 1.0 NCT7511Y 7.2.9 Diode Fault Alert Status Register Location : Index 17h Type : Read Only Power on default value :00h BIT 7 6 5 3 2 RSV NAME FUNC. 4 1 0 STS_DF2 STS_DF1 STS_DF2 : 1 indicates the TD2 fault. STS_DF1 : 1 indicates the TD1 fault. 7.2.10 Low Alert Status Register Location : Index 18h Type : Read Only Power on default value :00h BIT 7 6 5 4 RSV NAME 3 2 1 0 STS_AL4 RSV STS_AL2 STS_AL1 3 2 1 0 STS_AH 4 RSV STS_AH 2 STS_AH 1 2 1 0 STS_AL4 : 1 indicates the LTD over low limit. FUNC. STS_AL2 : 1 indicates the RTD2 over low limit. STS_AL1 : 1 indicates the RTD1 over low limit. 7.2.11 High Alert Status Register Location : Index 19h Type : Read Only Power on default value :00h BIT 7 6 5 4 RSV NAME STS_AH4 : 1 indicates the LTD over high limit. FUNC. STS_AH2 : 1 indicates the RTD2 over high limit. STS_AH1 : 1 indicates the RTD1 over high limit. 7.2.12 Fan Alert Status Register Location : Index 1Ah Type : Read Only Power on default value :00h BIT 7 RSV NAME FUNC. 6 5 4 3 FAN_TA R1 RSV FAN_FC 1 FAN_TAR3 : 1 indicates the FAN1 is driven to fully speed over 3 minutes. FAN_FC1 : 1 indicates the FAN1 over limit. Confidential - 18 - July, 2012 Version: 1.0 NCT7511Y 7.2.13 T_CRIT# Alert Status Register Location : Index 1Bh Type : Read Only Power on default value :00h BIT 7 6 5 4 RSV NAME 3 2 1 0 STS_TC4 RSV STS_TC2 STS_TC1 2 1 0 STS_GPI O2 STS_GPI O1 STS_TC4 : 1 indicates the LTD T_CRIT# asserts. FUNC. STS_TC2 : 1 indicates the RTD2 T_CRIT# asserts. STS_TC1 : 1 indicates the RTD1 T_CRIT# asserts. 7.2.14 GPIO Alert Status Register Location : Index 1Ch Type : Read Only Power on default value :00h BIT 7 6 5 3 RSV NAME FUNC. 4 STS_GPIO2 : 1 indicates the GPIO2 event asserts. STS_GPIO1 : 1 indicates the GPIO1 event asserts. 7.2.15 T_CRIT# Real Time Status Register Location : Index 20h Type : Read Only Power on default value :00h BIT 7 6 5 4 RSV NAME 3 2 1 0 LTD_Tex c RSV RTD2_Te xc RTD1_Te xc 1 0 LTD_Texc : 1 indicates the LTD over the shutdown threshold. FUNC. RTD2_Texc : 1 indicates the RTD2 over the shutdown threshold. RTD1_Texc : 1 indicates the RTD1 over the shutdown threshold. 7.2.16 Start Register Location : Index 21h Type : Read/Write Power on default value : 01h BIT 7 NAME MSK_AL ERT FUNC. 6 5 4 3 RSV 2 START MSK_ALERT : 1 indicates the ALERT# output is masked. START : 1 indicates the ADC is operating. Confidential - 19 - July, 2012 Version: 1.0 NCT7511Y 7.2.17 Mode Selection Register Location : Index 22h Type : Read/Write Power on default value : 55h BIT 7 6 NAME RSV EnLTD 5 4 3 RSV 2 1 RTD2_MD 0 RTD1_MD EnLTD : 1 indicates the LTD function enabled. FUNC. RTD2_MD : 00=Closed , 01=Current mode , 10=RSV , 11=RSV RTD1_MD : 00=Closed , 01=Current mode , 10=RSV , 11=RSV 7.2.18 Fan Enable Register Location : Index 24h Type : Read/Write Power on default value : 01h BIT 7 6 5 4 NAME FUNC. 3 2 1 RSV 0 EnFan1 EnFan1 : 1 indicates the FANIN1 enabled. 7.2.19 Conversion Rate Register Location : Index 26h Type : Read/Write Power on default value : 02h BIT 7 6 5 3 2 RSV NAME FUNC. 4 1 0 ConvRate[1:0] ConvRate[1:0] : 00=1Hz , 01=2Hz , 10= 4Hz , 11=Free Run. 7.2.20 Fault Queue Register Location : Index 27h Type : Read/Write Power on default value : 03h BIT 7 5 4 3 RSV NAME FUNC. 6 2 1 0 FaultQueue[1:0] FaultQueue[1:0] : Fault Queue of Thermal Shutdown , 00=1 , 01=2 , 10=3 , 11=4 . Confidential - 20 - July, 2012 Version: 1.0 NCT7511Y 7.2.21 Alert# High Limit Link to T_CRIT# Location : Index 28h Type : Read/Write Power on default value : 00h BIT 7 6 NAME 5 4 3 RSV 2 1 0 SYS3 SYS2 SYS1 SYS3 : 1 indicates the External Diode3 channel high limit will be linked to T_CRIT# FUNC. SYS2 : 1 indicates the External Diode2 channel high limit will be linked to T_CRIT# SYS1 : 1 indicates the External Diode1 channel high limit will be linked to T_CRIT# 7.2.22 RTD1 Temperature High Limit Register Location : Index 30h Type : Read/Write Power on default value : 55h BIT 7 6 5 4 2 1 0 1 0 1 0 RTD1_HL NAME FUNC. 3 RTD1_HL : RTD1 Temperature High Limit setting for ALERT# . 7.2.23 RTD1 Temperature Low Limit Register Location : Index 31h Type : Read/Write Power on default value : 00h BIT 7 6 5 4 2 RTD1_LL NAME FUNC. 3 RTD1_LL : RTD1 Temperature Low Limit setting for ALERT#. 7.2.24 RTD2 Temperature High Limit Register Location : Index 32h Type : Read/Write Power on default value : 55h BIT 7 5 4 3 2 RTD2_HL NAME FUNC. 6 RTD2_HL : RTD2 Temperature High Limit setting for ALERT#. Confidential - 21 - July, 2012 Version: 1.0 NCT7511Y 7.2.25 RTD2 Temperature Low Limit Register Location : Index 33h Type : Read/Write Power on default value : 00h BIT 7 6 5 4 2 1 0 2 1 0 2 1 0 2 1 0 RTD2_LL NAME FUNC. 3 RTD2_LL : RTD2 Temperature Low Limit setting for ALERT#. 7.2.26 LTD Temperature High Limit Register Location : Index 36h Type : Read/Write Power on default value : 55h BIT 7 6 5 4 LTD_HL NAME FUNC. 3 LTD_HL : LTD Temperature High Limit setting for ALERT#. 7.2.27 LTD Temperature Low Limit Register Location : Index 37h Type : Read/Write Power on default value : 00h BIT 7 6 5 4 LTD_LL NAME FUNC. 3 LTD_LL : LTD Temperature Low Limit setting for ALERT#. 7.2.28 RTD1 T_CRIT# Threshold Register Location : Index 3Ah Type : Read/Write Power on default value : 64h BIT 7 5 4 3 TCRIT_RTD1 NAME FUNC. 6 TCRIT_RTD1 : RTD1 Temperature Threshold of T_CRIT#. Confidential - 22 - July, 2012 Version: 1.0 NCT7511Y 7.2.29 RTD2 T_CRIT# Threshold Register Location : Index 3Bh Type : Read/Write Power on default value : 64h BIT 7 6 5 4 2 1 0 2 1 0 2 1 0 2 1 0 TCRIT_RTD2 NAME FUNC. 3 TCRIT_RTD2 : RTD2 Temperature Threshold of T_CRIT#. 7.2.30 LTD T_CRIT# Threshold Register Location : Index 3Dh Type : Read/Write Power on default value : 64h BIT 7 6 5 4 TCRIT_LTD NAME FUNC. 3 TCRIT_LTD : LTD Temperature Threshold of T_CRIT#. 7.2.31 FANIN1 Limit Low Byte Register Location : Index 49h Type : Read/Write Power on default value : FFh BIT 7 6 5 3 FANIN1_HL[7:0] NAME FUNC. 4 FANIN1_HL[7:0] : FANIN1 Limit Low Byte. 7.2.32 FANIN1 Limit High Byte Register Location : Index 4Ch Type : Read/Write Power on default value : F8h BIT 7 5 4 3 FANIN1_HL[12:8] NAME FUNC. 6 RSV FANIN1_HL[12:8] : FANIN1 Limit High Byte. Confidential - 23 - July, 2012 Version: 1.0 NCT7511Y 7.2.33 ALERT Mask Register Register Location : Index 4Fh Type : Read/Write Power on default value : 7Fh BIT 7 6 5 4 3 2 1 0 NAME RSV MSK_TC MSK_GP IO MSK_TA RT MSK_FC MSK_AH MSK_AL MSK_DF MSK_TC : 1 indicates the ALERT# from T_CRIT# event will be masked . MSK_GPIO : 1 indicates the ALERT# from GPIO event will be masked . MSK_TART : 1 indicates the ALERT# from TART event will be masked . FUNC. MSK_FC : 1 indicates the ALERT# from FAN event will be masked . MSK_AH : 1 indicates the ALERT# from High ALERT event will be masked . MSK_AL : 1 indicates the ALERT# from Low ALERT event will be masked . MSK_DF : 1 indicates the ALERT# from Diode Fault event will be masked . 7.2.34 ALERT Mask Temperature Channel Register Location : Index 50h Type : Read/Write Power on default value : 3Fh BIT 7 6 5 4 RSV NAME 3 2 1 0 MSK_LT D RSV MSK_RT D2 MSK_RT D1 MSK_LTD : 1 indicates the ALERT# from LTD event will be masked . FUNC. MSK_RTD2 : 1 indicates the ALERT# from RTD2 event will be masked . MSK_RTD1 : 1 indicates the ALERT# from RTD1 event will be masked . 7.2.35 ALERT Mask Fan Channel Register Location : Index 51h Type : Read/Write Power on default value : 07h BIT 7 5 4 3 2 1 RSV NAME FUNC. 6 0 MSK_FA N1 MSK_FAN1 : 1 indicates the ALERT# from FAN1 event will be masked . Confidential - 24 - July, 2012 Version: 1.0 NCT7511Y 7.2.36 T_CRIT# Mask Register Location : Index 53h Type : Read/Write Power on default value : BFh BIT 7 NAME MSK_ALL 6 5 4 RSV 3 2 1 0 MSK_LT D4 RSV MSK_RT D2 MSK_RT D1 MSK_ALL : 1 indicates the T_CRIT# from ALL event will be masked . FUNC. MSK_LTD : 1 indicates the T_CRIT# from LTD event will be masked . MSK_RTD2 : 1 indicates the T_CRIT# from RTD2 event will be masked . MSK_RTD1 : 1 indicates the T_CRIT# from RTD1 event will be masked . 7.2.37 GPIO Alert Mask Register Location : Index 54h Type : Read/Write Power on default value : 3Fh BIT 7 6 5 NAME FUNC. 4 3 2 RSV 1 0 MSK_GP IO2 MSK_GP IO1 MSK_GPIO2 : 1 indicates the ALERT# from GPIO2 event will be masked . MSK_GPIO1 : 1 indicates the ALERT# from GPIO1 event will be masked . 7.2.38 GPIO Mode Register Location : Index 56h Type : Read/Write Power on default value : 3Fh BIT 7 NAME FUNC. 6 5 4 3 RSV 2 1 0 GPIO2 Mode GPIO1 Mode GPIO2 Mode : 0= Input , 1= Output. GPIO1 Mode : 0= Input , 1= Output. Confidential - 25 - July, 2012 Version: 1.0 NCT7511Y 7.2.39 GPIO Output Type Register Location : Index 57h Type : Read/Write Power on default value : 00h BIT 7 6 5 3 2 RSV NAME FUNC. 4 1 0 GPIO2 OB GPIO1 OB 1 0 GPIO2 IN GPIO1 IN 1 0 GPIO2 OUT GPIO1 OUT 1 0 GPIO2 Output Type : 0= Push Pull , 1= Open Drain. GPIO1 Output Type : 0= Push Pull , 1= Open Drain. 7.2.40 GPIO Input Data Register Location : Index 58h Type : Read Only Power on default value :00h BIT 7 6 5 3 2 RSV NAME FUNC. 4 GPIO2 IN : Input data register of GPIO2. GPIO1 IN : Input data register of GPIO1. 7.2.41 GPIO Output Data Register Location : Index 59h Type : Read/Write Power on default value : 00h BIT 7 6 5 NAME FUNC. 4 3 2 RSV GPIO2 OUT : Output data register of GPIO2. GPIO1 OUT : Output data register of GPIO1. 7.2.42 Fan Control Output Type Register Location : Index 5Eh Type : Read/Write Power on default value : 00h BIT 7 5 4 3 RSV NAME FUNC. 6 2 EnDCFA N1 EnDCFAN1 : 0 indicates the FANCTL1 output is PWM type. 1 indicates the FANCTL1 output is DC type. Confidential - 26 - July, 2012 Version: 1.0 NCT7511Y 7.2.43 Fan Control Output Mode Register Location : Index 5Fh Type : Read/Write Power on default value : 00h BIT 7 6 5 RSV NAME 4 3 PWM1_P OL 2 1 0 PWM1_O D RSV PWM1_POL : 1 indicates the FANCTL1 PWM output is inverted. FUNC. PWM1_OD : 0 indicates the FANCTL1 PWM output is push pull. 1 indicates the FANCTL1 PWM output is open drain. 7.2.44 Fan Control 1 Output Value Register Location : Index 60h Type : Read/Write for Manual mode , Read only for Smart Fan control Power on default value :7Fh BIT 7 6 5 4 2 1 0 3 2 1 0 FANDuty1 NAME FUNC. 3 FANDuty1 : FANCTL1 output value. 7.2.45 Close-Loop Fan Control RPM mode Register Location : Index 63h Type : Read/Write Power on default value : 00h BIT 7 5 4 TwoDim ension RSV NAME FUNC. 6 RPM_HI GH_EN RSV RSV TwoDimension : Close_Loop Fan Control Enable Bit5 : 1 indicated the FAN1 group enables Close-Loop Fan Control RPM mode RPM_HIGH_EN : Changing default unit of all RPM setting from 50 RPMs to 100 RPMs. It benefits to control ultra high RPM fan Bit2 : 1 indicated the FAN1 group support ultra high RPM fan 7.2.46 Temperature to Fan mapping Relationships Register Location : Index 64h Type : Read/Write Power on default value : 00h BIT 7 NAME RSV FUNC. 6 5 4 3 Temp2FanSelect RSV 2 1 0 Temp1FanSelect Temp2FanSelect , Confidential - 27 - July, 2012 Version: 1.0 NCT7511Y Temp1FanSelect : Enable FANCTL3 – FANCTL1 Smart Fan. 0 = FANCTL has no relation with this temperature source. FANCTL is controlled by Manual mode. (Default) TM 1 = Applies SmartFan control for SMART FAN IV on FANCTL and this temperature. 7.2.47 Temperature to Fan mapping Relationships Register Location : Index 65h Type : Read/Write Power on default value : 00h BIT 7 6 NAME 4 3 2 1 RSV Temp3FanSelect : FUNC. 5 0 Temp3FanSelect Enable FANCTL3 – FANCTL1 Smart Fan. 0 = FANCTL has no relation with this temperature source. FANCTL is controlled by Manual mode. (Default) TM 1 = Applies SmartFan control for SMART FAN IV on FANCTL and this temperature. 7.2.48 Fan Control Configuration Register 1 Location : Index 66h Type : Read/Write Power on default value : 00h BIT 7 6 NAME Temp2_Sh are_En 5 4 3 2 Temp1_ Share_E n Temp2_Share_Sel 1 0 Temp1_Share_Sel Temp2_Share_En : Enable temperature2 sharing table function. Temp2_Share_Sel : Select which temperature2 source could share control table in TM SMART FAN IV FUNC. Temp1_Share_En : Enable temperature1 sharing table function. Temp1_Share_Sel : Select which temperature1 source could share control table in TM SMART FAN IV Refer to the Sharing Table. Sharing Table. BIT [2-0] Share_Sel Condition 000BIN Mapping to Remote 1 temperature. 001BIN Mapping to Remote 2 temperature. 011BIN Mapping to Local temperature. 110BIN Mapping to Programmable temperature 1. 111BIN Mapping to Programmable temperature 2. Confidential - 28 - July, 2012 Version: 1.0 NCT7511Y 7.2.49 Fan Control Configuration Register 2 Location : Index 67h Type : Read/Write Power on default value : 00h BIT 7 6 5 4 3 RSV NAME 2 Temp3_ Share_E n 1 0 Temp3_Share_Sel Temp3_Share_En : Enable temperature3 sharing table function. FUNC. Temp3_Share_Sel : Select which temperature3 source could share control table in TM SMART FAN IV Refer to the Sharing Table. 7.2.50 Fan Control Configuration Register 3 Location : Index 68h Type : Read/Write Power on default value : 00h BIT 7 NAME RSV 6 5 4 3 Temp2_Source_Sel 2 RSV 1 0 Temp1_Source_Sel Temp2_Source_Sel : Temperature 2 source selection. FUNC. Temp1_Source_Sel : Temperature 1 source selection. Refer to the Sharing Table. 7.2.51 Fan Control Configuration Register 4 Location : Index 69h Type : Read/Write Power on default value : 00h BIT 7 6 NAME FUNC. 5 4 3 2 RSV 1 0 Temp3_Source_Sel Temp3_Source_Sel : Temperature 3 source selection. Refer to the Sharing Table. 7.2.52 Fan 1 Target Register Location : Index 6Ah Type : Read only Power on default value : 8Ch BIT 7 5 4 3 2 1 0 Fan1_Target NAME FUNC. 6 Fan1_Target : RPM mode FANCTL1 Target Register Confidential - 29 - July, 2012 Version: 1.0 NCT7511Y 7.2.53 Close-Loop Fan Control RPM Mode Tolerance Register Location : Index 6Dh Type : Read/Write Power on default value : 0Ah BIT 7 6 NAME FUNC. 5 4 3 2 RSV 1 0 Generic_Tol_RPM Generic_Tol_RPM : Tolerance of RPM mode, unit 50 RPM. 7.2.54 FANCTL Step Up Time Register Location : Index 6Eh Type : Read/Write Power on default value : 0Ah BIT 7 6 5 4 NAME 3 2 1 0 UpTime TM FUNC. UpTime : In SMART FAN IV mode, this register determines the amount of time FANOUT takes to increase its value by one step. The units are intervals of 0.1 second. The default time is 1 second. 7.2.55 FANCTL Step Down Time Register Location : Index 6Fh Type : Read/Write Power on default value : 0Ah BIT 7 6 5 4 3 2 1 0 DownTime NAME TM FUNC. DownTime : In SMART FAN IV mode, this register determines the amount of time FANOUT takes to decrease its value by one step. The units are intervals of 0.1 second. The default time is 1 second. 7.2.56 Default Fan Speed Register Location : Index 70h Type : Read/Write Power on default value : 7Fh BIT 7 5 4 3 2 1 0 DefaultFanSpeed NAME FUNC. 6 DefaultFanSpeed : (Default Fan Speed at Power-on). Specifies the fan duty at next power on. Confidential - 30 - July, 2012 Version: 1.0 NCT7511Y 7.2.57 FANCTL1 PWM Prescalar Register Location : Index 71h Type : Read/Write Power on default value : 84h BIT 7 6 NAME CLKSEL 5 4 3 2 1 0 Divisor[6:0] CLKSEL : Clock source select. FUNC. Divisor : Clock frequency Divisor. Refer the Divisor table. The clock source selected by CLKSEL will be divided by the divisor and used as a fan PWM output frequency. If CLKSEL equals 1, then the output clock is simply equal to 125/ (Divisor[6:0]+1) KHz MappedDivisor depends on Divisor[6:0] and is described in the table below. Divisor[6:0] Mapped Divisor Output Frequency Divisor[6:0] Mapped Divisor Output Frequency 0000000 1 125KHz 0000001 2 62.5KHz 0000010 3 41.6KHz 0000011 4 31.2KHz 0000100 5 25KHz 0001111 16 7.8KHz 0000101 6 20.8KHz 0011111 32 3.9KHz 0000110 7 17.8KHz 0111111 64 1.9KHz 0000111 8 15.6KHz 1111111 128 976Hz ………………………………………….. If CLKSEL equals 0, then the output clock is simply equal to 1000/ Mapped Divisor Hz MappedDivisor depends on Divisor[3:0] and is described in the table below. Divisor[3:0] Mapped Divisor Output Frequency Divisor[3:0] Mapped Divisor Output Frequency 0000 1 1000Hz 1000 12 83Hz 0001 2 500Hz 1001 16 62.5Hz 0010 3 333Hz 1010 32 31.25Hz 0011 4 250Hz 1011 64 15.6Hz 0100 5 200Hz 1100 128 7.8Hz 0101 6 166Hz 1101 256 3.9Hz 0110 7 142Hz 1110 512 1.9Hz 0111 8 125Hz 1111 1024 0.97Hz Confidential - 31 - July, 2012 Version: 1.0 NCT7511Y 7.2.58 Temperature1 Hysteresis Register Location : Index 74h Type : Read/Write Power on default value : 53h BIT 7 NAME RSV FUNC. 6 5 4 3 Criti_HysT1 2 RSV Criti_HysT1 : Hysteresis value of SMART FAN TM Oper_HysT1 : Hysteresis value of SMART FAN 1 0 Oper_HysT1 IV Critical Temperature TM IV Operating Temperature 7.2.59 Temperature 2 Hysteresis Register Location : Index 75h Type : Read/Write Power on default value : 53h BIT 7 NAME RSV FUNC. 6 5 4 3 Criti_HysT2 2 RSV Criti_HysT2 : Hysteresis value of SMART FAN TM Oper_HysT2 : Hysteresis value of SMART FAN 1 0 Oper_HysT2 IV Critical Temperature TM IV Operating Temperature 7.2.60 Temperature 3 Hysteresis Register Location : Index 76h Type : Read/Write Power on default value : 53h BIT 7 NAME RSV FUNC. 6 5 4 3 Criti_HysT3 2 RSV Criti_HysT3 : Hysteresis value of SMART FAN TM Oper_HysT3 : Hysteresis value of SMART FAN 1 0 Oper_HysT3 IV Critical Temperature TM IV Operating Temperature 7.2.61 FANCTL Start Duty Cycle Register Location : Index 77h Type : Read/Write Power on default value :30h BIT 7 NAME FUNC. 6 5 4 3 2 1 0 StartDutyCycle StartDutyCycle : control the FANCTL1-FANCTL3 fan output start-up value. Confidential - 32 - July, 2012 Version: 1.0 NCT7511Y 7.2.62 FANCTL Stop Time Register Location : Index 78h Type : Read/Write Power on default value : FFh BIT 7 6 5 NAME 4 3 2 1 0 StopTime StopTime : control the FANCTL1-FANCTL3 fan stop time. FUNC. Unit in 0.1sec. Ranges from 0.1sec to 25.5sec. If set to 0, the fan will never stop. 7.2.63 SMART FANTM IV Temperature and PWM Registers Register Location : Table 1 Address 80h ~ 88h Location : Table 2 Address 90h ~ 98h Location : Table 3 Address A0h ~ A8h Type : Read/Write Power on default value: refer to below tables TABLE Table1 Table2 Table3 NAME ADDRESS DEFAULT TYPE Transition Point : T1 80HEX 19 HEX Read/Write Transition Point : T2 81HEX 23 HEX Read/Write Transition Point : T3 82HEX 23 HEX Read/Write Transition Point : T4 83HEX 37 HEX Read/Write Critical Point 84HEX 3C HEX Read/Write Y-axis Transition Point : PWM1 85HEX 8C HEX Read/Write Y-axis Transition Point : PWM2 86HEX 8C HEX Read/Write Y-axis Transition Point : PWM3 87HEX C8 HEX Read/Write Y-axis Transition Point : PWM4 88HEX E6 HEX Read/Write Transition Point : T1 90HEX 19 HEX Read/Write Transition Point : T2 91HEX 23 HEX Read/Write Transition Point : T3 92HEX 23 HEX Read/Write Transition Point : T4 93HEX 37 HEX Read/Write Critical Point 94HEX 3C HEX Read/Write Y-axis Transition Point : PWM1 95HEX 8C HEX Read/Write Y-axis Transition Point : PWM2 96HEX 8C HEX Read/Write Y-axis Transition Point : PWM3 97HEX C8 HEX Read/Write Y-axis Transition Point : PWM4 Transition Point : T1 98HEX E6 HEX Read/Write A0HEX 19 HEX Read/Write Transition Point : T2 A1HEX 23 HEX Read/Write Transition Point : T3 A2HEX 23 HEX Read/Write Confidential - 33 - July, 2012 Version: 1.0 NCT7511Y TABLE NAME ADDRESS DEFAULT TYPE Transition Point : T4 A3HEX 37 HEX Read/Write Critical Point A4HEX 3C HEX Read/Write Y-axis Transition Point : PWM1 A5HEX 8C HEX Read/Write Y-axis Transition Point : PWM2 A6HEX 8C HEX Read/Write Y-axis Transition Point : PWM3 A7HEX C8 HEX Read/Write Y-axis Transition Point : PWM4 A8HEX E6 HEX Read/Write 7.2.64 TD1 Offset Register Location : Index C1h Type : Read/Write Power on default value : 00h BIT 7 5 4 3 RSV NAME FUNC. 6 2 1 0 1 0 2 1 0 2 1 0 Offset_TD1 Offset_TD1 : TD1 function offset register . 7.2.65 TD2 Offset Register Location : Index C2h Type : Read/Write Power on default value : 00h BIT 7 5 4 3 RSV NAME FUNC. 6 2 Offset_TD2 Offset_TD2 : TD2 function offset register . 7.2.66 Soft Reset Register Location : Index FCh Type : Write Only Power on default value : FFh BIT 7 NAME INIT FUNC. 6 5 4 3 RSV INIT : Write 1 to reset the NCT7511Y. 7.2.67 Vendor ID Register Location : Index FDh Type : Ready Only Power on default value : 50h BIT 7 6 5 4 3 Confidential - 34 - July, 2012 Version: 1.0 NCT7511Y Vendor ID NAME FUNC. Vendor ID of NCT7511Y is 50h 7.2.68 Chip ID Register Location : Index FEh Type : Ready Only Power on default value : C3h BIT 7 6 5 4 2 1 0 3 2 1 0 Chip ID NAME FUNC. 3 Chip ID of NCT7511Y is C3h 7.2.69 Device ID Register Location : Index FFh Type : Ready Only Power on default value : 2xh BIT 7 5 4 Device ID NAME FUNC. 6 Device ID of NCT7511Y is 2xh (x=0,1,2…) Confidential - 35 - July, 2012 Version: 1.0 NCT7511Y 8. ELECTRICAL CHARACTERISTICS 8.1 Absolute Maximum Ratings PARAMETER RATING UNIT Power Supply Voltage 3.3V  5% V Input Voltage -0.3 to +3.6 V Operating Temperature -40 to +85 C Storage Temperature -55 to +150 C Note: Exposure to conditions beyond those listed under Absolute Maximum Ratings may adversely affect the life and reliability of the device. 8.2 DC Characteristics (Ta = 0 C to 70 C, VDD = 3.3V  5%, GND = 0V) PARAMETER SYM. MIN. TYP. MAX. UNIT CONDITIONS V IOL = 12 mA V IOL = 12 mA V IOH = -12 mA V VDD = 3.3V V VDD = 3.3V OD12 – Open-drain output pin with source-sink capability of 12 mA Output Low Voltage VOL 0.4 OUT12 - Output buffer pin with source-sink capability of 12 mA Output Low Voltage VOL Output High Voltage VOH INts - 0.4 2.4 TTL level Schmitt-triggered input pin Input Low Voltage VIL 0.8 Input High Voltage VIH Input High Leakage ILIH +10 A VIN=3.3V Input Low Leakage ILIL -10 A VIN=0V 2.0 Confidential - 36 - July, 2012 Version: 1.0 NCT7511Y 8.3 AC Characteristics SMBus Interface PARAMETER SCL clock period SYMBOL - MIN. MAX. UNIT t SCL 2.5 uS Start condition hold time tHD;SDA 1.5 uS Stop condition setup-up time tSU;STO 1 uS DATA to SCL setup time tSU;DAT 120 nS DATA to SCL hold time tHD;DAT 5 nS SCL and SDA rise time tR 1.0 uS SCL and SDA fall time tF 300 nS Confidential - 37 - July, 2012 Version: 1.0 NCT7511Y 9. ORDERING INFORMATION PART NUMBER PACKAGE NCT7511Y QFN16 SUPPLIED AS E shape: Tray T shape: 4,000 units/T&R PRODUCTION FLOW Commercial, 0°C to +70°C 10. TOP MARKING SPECIFICATION NCT7511Y 113TABA st 1 Line : Nuvoton Logo nd 2 Line : Part number- NCT7511Y rd 3 Line : Assembly tracking code 1 13: packages made in year 2011, week 13 T : Assembly house code A : IC version BA : Nuvoton internal use code Confidential - 38 - July, 2012 Version: 1.0 NCT7511Y 11. TAPING SPECIFICATION Confidential - 39 - July, 2012 Version: 1.0 NCT7511Y 12. PACKAGE DRAWING AND DIMENSIONS QFN16 4x4 MM2 SEATING PLANE 2 2 y Confidential - 40 - July, 2012 Version: 1.0 NCT7511Y 13. REVISION HISTORY VERSION DATE PAGE 0.1 05/2010 N.A. 0.3 07/2010 Add register definition and feature description 0.31 08/2010 Add Package information 0.32 12/2010 Add more feature description 0.33 01/2011 Modify the description and correct the typo 0.4 05/2011 Remote EEPROM function, and modify the description and correct the typo 0.5 01/2012 Add RPM mode 1.0 07/2012 38 DESCRIPTION Preliminary version. Add taping spec Important Notice Nuvoton Products are neither intended nor warranted for usage in systems or equipment, any malfunction or failure of which may cause loss of human life, bodily injury or severe property damage. Such applications are deemed, “Insecure Usage”. Insecure usage includes, but is not limited to: equipment for surgical implementation, atomic energy control instruments, airplane or spaceship instruments, the control or operation of dynamic, brake or safety systems designed for vehicular use, traffic signal instruments, all types of safety devices, and other applications intended to support or sustain life. All Insecure Usage shall be made at customer’s risk, and in the event that third parties lay claims to Nuvoton as a result of customer’s Insecure Usage, customer shall indemnify the damages and liabilities thus incurred by Nuvoton. Confidential - 41 - July, 2012 Version: 1.0
NCT7511YTR 价格&库存
很抱歉,暂时无法提供与“NCT7511YTR”相匹配的价格&库存,您可以联系我们找货
