RM24C32C
32Kbit 2.7V Minimum
Non-volatile Serial Memory
I2C Bus
Features
z Memory array: 32Kbit EEPROM-compatible serial memory
z Single supply voltage: 2.7V - 3.6V
z 2-wire I2C interface
z Compatible with I2C bus modes:
z
z
z
z
z
z
z
z
z
z
z
z
-100kHz
-400kHz
Page size: 32 byte
-Byte and Page Write from 1 to 32 bytes
Low Energy Byte Write
-Byte Write consuming 60nJ
Low power consumption
-1mA active Read current
-1.5mA active Write current
-5μA Standby current
Fast Page and Byte Write
-Page Write in 1ms
-Byte Write in 5μs
Random and sequential Read modes
Write protect of the whole memory array
8-lead SOIC and TSSOP packages
RoHS-compliant and halogen-free packaging
Based on Adesto's proprietary CBRAM® technology
Data Retention: 10 years
Endurance: 25,000 Write Cycles
Unlimited Read Cycles
Description
The Mavriq™ RM24C32C is an EEPROM-compatible, 32Kbit non-volatile serial
memory utilizing Adesto's CBRAM resistive memory technology. The memory devices
use a single low-voltage supply ranging from 2.7V to 3.6V. The Adesto® I2C device is
accessed through a 2-wire I2C compatible interface consisting of a Serial Data (SDA)
and Serial Clock (SCL). The maximum clock (SCL) frequency is 400KHz. The devices
have both byte write and page write capability. Page write is up to 32 bytes. The Byte
Write operation of Mavriq serial memory consumes only 10% of the energy consumed
by a Byte Write operation of EEPROM devices of similar size.
The Page Write operation of Mavriq memory is 4-6 times faster than the Page Write
operation of similar EEPROM devices. Both random and sequential reads are
available. Sequential reads are capable of reading the entire memory in one
operation. External address pins permit up to eight devices on the same data bus. The
devices are available in standard 8-pin SOIC and TSSOP packages.
DS-RM24C32C–056E–9/2015
1.
Block Diagram
Figure 1-1. Block Diagram
RM24C32C
2
2.
Pin/Signal Descriptions
Table 2-1.
Symbol
Pin #
Name/Function
Description
LSB - Least Significant Bit,
External Enable
LSB of the three external enable bits (E0, E1 and E2). The levels of
the external enable bits are compared with three enable bits in the
received control byte to provide device selection. The device is
selected if the comparison is true. Up to eight devices may be
connected to the same bus by using different E0, E1, E2
combinations.
2
External Enable
The middle of the three external enable bits (E0, E1 and E2). The
levels of the enable bits are compared with three enable bits in the
received control byte to provide device selection. Also see the E0,
E2 pin.
E2
3
MSB - Most Significant Bit,
External Enable
MSB of the three external enable bits (E0, E1 and E2). The levels
E1 pin.
GND
4
Ground
E0
E1
SDA
1
5
Serial Data
Bidirectional pin used to transfer addresses and data into and data
out of the device. It is an open-drain terminal, and therefore
requires a pull-up resistor to VCC. Typical pull-up resistors are:
10K for 100KHz, and 2K for 400KHz and 1MHz.
For normal data transfer, SDA is allowed to change only during SCL
low. Changes during SCL high are reserved for indicating the
START and STOP conditions.
2.1
SCL
6
Serial Clock
This input is used to synchronize the data transfer from and to the
device. SCL is an input only, since it is a slave-only device.
WP
7
Write Protect
Connect to either VCC or GND. If pulled low, write operations are
enabled. If pulled high, write operations are inhibited, but read
operations are not affected.
Vcc
8
Power
Power supply pin
Pin Out Diagram
RM24C32C
3
3.
I2C Bus Protocol
I2C is a 2-wire serial bus architecture with a clock pin (SCL) for synchronization, and a data pin (SDA) for data transfer.
On the device the SDA pin is bi-directional. The SCL pin is an input only, because the device is slave-only. The SCL and
SDA pins are both externally connected to a positive supply voltage via a current source or pull-up resistor. When the
bus is free, both lines are high. The output stages of devices connected to the bus must have an open drain or open
collector to perform a wired-AND function. Data on the I2C bus can be transferred at rates of up to 400Kbits/s. The
number of interfaces that may be connected to the bus is solely dependent on the bus capacitance limit of 400pF.
The data on the SDA line must be stable during the high period of the clock. The high or low state of the data line can
only change when the clock signal on the SCL line is low (see Figure 3-1).
Figure 3-1. Bit Transfer on the I2C bus
A high-to-low transition on the SDA line while SCL is high indicates a START condition. A low-to-high transition on the
SDA line while SCL is high defines a STOP condition.
START and STOP conditions are always generated by the master. The bus is considered to be busy after the START
condition. The bus is considered to be free again a certain time after the STOP condition (see Figure 3-2).
Figure 3-2. START and STOP conditions
Every byte put on the SDA line must be 8 bits long. The number of bytes that can be transmitted per transfer is
unrestricted. Each byte must be followed by an acknowledge bit; therefore, the number of clock cycles to transfer one
byte is nine. Data is transferred with the most significant bit (MSB) first.
RM24C32C
4
3.1
I2C Master and Slave Configuration
ThedevicehasatwoͲpinindustryͲstandardI2Cinterface.ItisconfiguredasaslaveͲonlydeviceandthereforedoesnot
generateaclock.ByconnectingtheE0,E1andE2enablepinsintheconfigurationshownFigure3Ͳ3,uptoeightdevicescan
beconnectedontoanI2CInterfacebuscontrolledbyanI2Cmasterdevice,suchasamicrocontroller.
Figure 3-3. Connection between I2C Master and Slaves
4.
Device Timing
Figure 4-1. Bus Timing Data
Figure 4-2. Power-up Timing
Power up delay tPUD is based on VCCi which is the voltage level at which the internal reset circuit releases and signals the
controller to initiate the power-on reset condition for a 75μs maximum period.
VCC
VCCmax
Program, Read, Erase and Write Commands Rejected
VCCmin
VVCCI
Device Fully
Accessible
Device in Reset
tPUD
TIME
RM24C32C
5
5.
Device Addressing
The first byte sent from the master device to the EEPROM following the START condition is the control byte (See Figure
5-1). The first four bits of the control byte is the control code. The control code is “1010” both for read and for write
operations. The next three bits of the control byte are the enable bits (E2, E1 and E0), which are compared to the levels
set on the E0, E1 and E2 pins. The E0, E1 and E2 bits sent in the control byte must correspond to the logic levels set on
the corresponding E0, E1 and E2 pins for a device to be selected. In effect, the E0, E1 and E2 bits in the control register
act as the three MSB bits of a word address. These three bits allow the use of up to eight devices on the same bus. The
last bit of the control byte (R/W) defines the operation to be performed, read or write: if set to a one, a read operation is
selected; if set to a zero, a write operation is selected.
Figure 5-1. Control Byte
Upon receiving a "1010", the chip enable bits, and the R/W bit, the device performs an acknowledge by pulling the SDA
line low during the 9th clock pulse. As stated above, the device will now be set for either a read or a write operation by the
R/W bit.
After the device acknowledges the control byte, two additional bytes are sent by the master to the slave. These define the
target address of the byte in the device to be written. The bit assignment for the address is shown in Figure 5-2.
It should be noted that not all the address bits are used. For the 32Kbit device, only address A0 to A11 are used; the rest
are don't cares and must be set to "0".
Figure 5-2. Address sequence bit assignment
The device will acknowledge each byte of data that is received by pulling the SDA line low during the 9th clock pulse. If
the device does not provide an acknowledge, it has not received the data; consequently the entire sequence, starting
with the control byte, must be resent.
RM24C32C
6
6.
Byte Write Operation
If the R/W bit in the control byte is set to zero, the device will be in write mode. Once the control byte is received, the
device will perform an acknowledge; it will then be ready to receive the Address High Byte (see Figure 6-1). After
receiving the Address High Byte, the device acknowledges and then is ready to receive the Address Low Byte. After
receiving the Address Low Byte, the device will acknowledge and then write the address (expressed by the high and low
address bytes) into its address pointer. The device is then ready to receive a byte of data to be written into the
addressed memory location. After the device receives the data, it performs an acknowledge. After the master has
received the last acknowledge (after the data byte) the master should send a STOP condition. The STOP condition
initiates the internal write cycle in the device. If the master does not send a STOP, the device will not write the data into
the addressed memory location.
While the device is in the write cycle it will not generate an acknowledge signal. Meanwhile, the master can poll the
device to determine when the write cycle is complete by sending it a control byte and looking for an acknowledge. Once
the write cycle has completed, the device will acknowledge a control byte sent to it.
After the data byte has been written, the internal address pointer will be incremented by one. If, in the RM24C32C, the
byte written is the last byte in a 32-byte page, the address will wrap around to the beginning of the same page. For
instance, if the byte is written to address 001Fh, the incremented address will be 0000h. If the byte is written to address
07FFh, the incremented address will be 07E0h.
If a write cycle is attempted with the WP (write protect) pin held high, the device will acknowledge the command, address,
and data, but no write cycle will occur following the STOP command. The data will not be written, and the device will
immediately be available to accept a new command. However, the internal address pointer will be written; so after the
data byte is transmitted to the device and the STOP command issued by the master, the internal address pointer will
again be incremented by one.
Figure 6-1. Byte Write Cycle
7.
Page Write Operation
Product
Density
Page Size (byte)
RM24C32
32Kbit
32
During a Page Write cycle, a Page with up to 32 bytes of data can be written in one continuous write command. The
Page Write starts in the same manner as the Byte Write. In a Page Write, after the acknowledge following the first data
byte, the master does not send a STOP, but continues to send additional data bytes (See Figure 7-1). At the end of the
number of bytes to be written, the master sends a STOP command. Once the STOP command is sent, the device will
write all the data bytes into memory, starting at the address location given in the address bytes.
If the master should transmit more than 32 bytes prior to generating the STOP command, the internal 32-byte data buffer
in the device will wrap around and the first data bytes transmitted will be overwritten.
RM24C32C
7
The internal address pointer will not increment beyond a page boundary but will instead wrap around to the first byte of
the addressed page. For instance, in the RM24C32C, if the address given is 087Ah and ten data bytes are transmitted by
the master before the STOP command occurs, the last data byte received will be written in address location 0863h.
As with the Byte Write cycle, once the STOP command is received the device enters a write cycle. During the write cycle,
the device will not generate an acknowledge signal. Meanwhile, the master can poll the device to determine when the
write cycle is complete by sending it a control byte and looking for an acknowledge. Once the write cycle has completed,
During the Page Write cycle, the first byte in the data byte buffer will be written in the address location indicated by the
address bytes transmitted to the device. Each successive data byte will be written in the successive address locations.
If a Page Write cycle is attempted with the WP pin held high, the device will acknowledge the command, address and
data bytes, but will not enter a write cycle after the STOP command is issued. No data will be written, and the device will
Page Write data bytes are transmitted to the device and the STOP command issued by the master, the internal address
pointer will be incremented by the number of data bytes sent (but only within the page addressed).
Note that the Page Write operation is internally executed by sequentially writing the words in the Page Buffer. Therefore
the Page Write time can be estimated as Byte Write time multiplied by the Number of Words to be written.
Figure 7-1. Page Write Cycle
8.
Write Protection
The WP pin allows the user to write-protect the entire memory array when the pin is tied to VCC. If the WP pin is tied to
GND, write protection is disabled. The WP pin is sampled at the STOP command for every Write command. Toggling the
WP pin after the STOP command will have no effect on the execution of the write cycle.
9.
Polling
The fact that the device will not acknowledge during a write cycle can be used to determine when the write cycle is
complete. By polling the device during the write cycle, bus throughput can be maximized.
Once the STOP command for the write cycle is sent by the master, the device initiates the internally timed write cycle.
Acknowledge polling, by the master, can be initiated immediately. Acknowledge polling involves the master sending a
START command, followed by the control byte for a write command (R/W=0). If the device is still busy with the write
cycle, no acknowledge is returned. If no acknowledge is returned, the START command and control byte can be retransmitted. If the write cycle is complete, the device will return an acknowledge. The master can then proceed with the
next read or write command. See Figure 9-1 for a flow diagram.
NOTE: Care must be taken when polling the device. The control byte that was used to initiate the write must match the
control byte used for polling.
RM24C32C
8
Figure 9-1. Acknowledge Polling Flow
10.
Read Operation
Read operations are initiated in the same way as the write operations, except that the R/W bit of the control byte is set to
one. There are three types of read operations: Current Address Read, Random Read, and Sequential Read.
10.1
The device internal address pointer maintains the address of the last word accessed, internally incremented by one.
Therefore, if the previous read access was to address n (any legal address), the next Current Address Read operation
would access data from address n+1. For the 32Kbit device the rollover occurs at 0FFFh.
If a Current Address Read is performed after a Byte Write or Page Write, care must be taken to understand that during
the page/byte write command, the address can wrap around within the same page.
Upon receipt of the control byte with the R/W bit set to one, the device issues an acknowledge and transmits the 8-bit
data word located at the address of the internal address pointer. The master will not acknowledge the transfer, but does
generate a STOP condition and the device discontinues transmission. See Figure 10-1.
Figure 10-1. Current Address Read
RM24C32C
9
10.2
Random Read
Random read operations allow the master to access any memory location in a random manner. To perform a Random
Read, first the address to be accessed must be set. This is done by sending the address to the device as part of a write
operation (R/W = 0). After the address is sent and acknowledged by the device, the master generates a START. This
terminates the write operation, but the address pointer will be set to the address sent. The master then issues the same
control byte as the write operation, but with the R/W bit set to 1. The device will acknowledge and transmit the 8-bit data
byte located at the address location written. The master will not acknowledge the transfer of the data byte, but will instead
generate a STOP condition, which causes the device to discontinue transmission. See Figure 10-2. After the Random
Read operation, the internal address counter will increment to the address location following the one that was just read.
Figure 10-2. Random Read
10.3
Sequential Read
Sequential read allows the whole memory contents to be serially read during one operation. Sequential Read is initiated
in the same way as a Random Read except that after the device transmits the first data byte, the master issues an
acknowledge instead of a STOP condition. This acknowledge from the master directs the device to transmit the next
sequentially addressed byte (See Figure 10-3). Following the final byte transmitted to the master, the master will not
generate an acknowledge, but will generate a STOP condition which causes the device to discontinue transmission.
To provide the Sequential Read, the device contains an internal address pointer which is incremented by one at each
acknowledge received by the master, and by the STOP condition.
Figure 10-3. Sequential Read
RM24C32C
10
11.
Electrical Specifications
11.1
Absolute Maximum Ratings
Table 11-1. Absolute Maximum Ratings*
Parameter
Specification
Temperature under Bias
0°C to +70° C
Storage Temperature
-20°C to +100°C
All Input voltages with respect to GND
- 0.3V to +3.6V
All Output voltages with respect to GND
-0.3V to (VCC + 0.3)
ESD protection on all pins (Human Body Model)
>2kV
Junction temperature
85°C
*NOTICE: Stresses beyond those listed under "Absolute Maximum Ratings" may cause permanent damage to the
device. This is a stress rating only and functional operation of the device at these, or any other conditions beyond those
indicated in the operational sections of this specification, is not implied. Exposure to absolute maximum rating conditions
for extended periods may affect device reliability.
11.2
DC Characteristics
Symbol
Parameter
Condition
Min
Typ
Max
Units
3.6
V
2.4
V
1
2
mA
1.5
3
mA
5
μA
SCL, SDA, VIN=0V to VCC
+1
μA
WP, E0, E1, E2, VIN=0V to VCC
+5
μA
SDA VIN=0V to VCC
+1
μA
-0.3
VCC x
0.3
V
VCC x 0.7
VCC +
0.3
V
0.4
V
TA=0°Cto+70°C,2.7Vto3.6V
VCC
Supply Range
2.7V to 3.6V
VVCCI
VCC Inhibit
ICC1
Supply Current, Read
VCC= 3.3V SCL at 400kHz
ICC2
Supply Current, Write
VCC= 3.3V
ICC3
Supply Current,
Standby
VCC= 3.3V. SCL=SDA=3.3V
IIL
Input Leakage
ILO
Output Leakage
VIL
Input Low Voltage
VIH
Input High Voltage
VOL
Output Low Voltage
SCL, SDA, WP, E0, E1, E2
SDA IOL = 3.0mA
2.7
RM24C32C
11
11.3
AC Characteristics
Applicable over recommended operating range:
TA = 0°C to +70° C, VCC = 2.7V to 3.6V, CL = CB
