OSD3358-512M-BAS
OSD3358-512M-BAS
    OCTAVOSYSTEMSLLC
    IC SIP BASED ON TI AM3358 400BGA
OSD3358-512M-BAS 数据手册
OSD335x BAS/IND Datasheet Rev. 17 4/1/2022 Introduction The OSD335x Family of System-InPackage (SIP) products are building blocks designed to allow easy and cost-effective implementation of systems based on Texas Instruments’ powerful Sitara™ AM335x line of processors. The OSD335x integrates the AM335x along with the TI TPS65217C PMIC, the TI TL5209 LDO, up to 1 Gigabyte of DDR3 Memory, and resistors, capacitors, and inductors all into a single 27mm x 27mm design-in-ready package. With this level of integration, the OSD335x Family of SIPs allows designers to focus on the key aspects of their system without spending time on the complicated highspeed design of the processor/DDR3 interface or the PMIC power distribution. It also reduces the overall size and complexity of the design and the supply chain. The OSD335x can significantly decrease the time to market for AM335x-based products. Features • • • • • OSD335x Block Diagram • • Benefits • • TI AM335x, TPS65217C, TL5209, DDR3, and over 140 Passive components integrated into a single package TI AM335x Features: o ARM® Cortex®-A8 up to 1GHz o 8 channel 12-bit SAR ADC o Ethernet 10/100/1000 x2 o USB 2.0 HS OTG + PHY x2 o MMC, SD and SDIO x2 o LCD Controller o SGX 3D Graphics Engine o PRU Subsystem Access to All AM335x Peripherals: CAN, SPI, UART, I2C, GPIO, etc. Up to 1GB DDR3 PWR In: AC Adapter, USB or Single cell (1S) Li-Ion / Li-Po Battery PWR Out: 1.8V, 3.3V and SYS AM335x I/O Voltage: 3.3V • • • • • Integrates over 100 components into one package Compatible with AM335x development tools and software Wide BGA ball pitch allows for lowcost assembly. Significantly reduces design time Decreases layout complexity 35% reduction in board space vs discrete implementation Increased reliability through reduced number of components Package • • • Octavo Systems LLC Copyright 2016-2022 400 Ball BGA (27mm X 27mm) 20 X 20 grid, 1.27mm pitch Temp Range: 0 to 85°C, -40 to 85°C 2 OSD335x BAS/IND Datasheet Rev. 17 4/1/2022 Table of Contents 1 Revision History ....................................................................................... 4 2 Block Diagram ......................................................................................... 5 2.1 Passives ........................................................................................... 6 2.1.1 Additional Required Bulk Capacitance .................................................. 6 2.1.2 Integrated Bulk Capacitance ............................................................. 6 2.1.3 Integrated Resistors........................................................................ 7 3 Product Number Information ........................................................................ 8 4 Reference Documents ............................................................................... 10 5 6 4.1 Data Sheets ...................................................................................... 10 4.2 Other Reference ................................................................................ 10 Ball Map ............................................................................................... 11 5.1 Ball Description ................................................................................. 17 5.2 AM335x Relocated Signals ..................................................................... 20 5.3 Not Connected Balls ............................................................................ 20 5.4 Reserved Signals ................................................................................ 21 OSD335x Components ............................................................................... 22 6.1 AM335x Processor ............................................................................... 22 6.1.1 6.2 7 I/O Voltages ................................................................................ 22 DDR3 Memory.................................................................................... 22 Power Management .................................................................................. 24 7.1 Input Power...................................................................................... 24 7.1.1 VIN_AC ...................................................................................... 24 7.1.2 VIN_USB ..................................................................................... 24 7.1.3 VIN_BAT..................................................................................... 24 7.2 Output Power ................................................................................... 24 7.2.1 SYS_VOUT: Switched VIN_AC, VIN_USB, or VIN_BAT ................................. 24 7.2.2 SYS_VDD1_3P3V............................................................................ 25 7.2.3 SYS_VDD2_3P3V............................................................................ 25 7.2.4 SYS_RTC_1P8V ............................................................................. 25 7.2.5 SYS_VDD_1P8V ............................................................................. 25 7.2.6 SYS_ADC_1P8V ............................................................................. 25 Octavo Systems LLC Copyright 2016-2022 3 OSD335x BAS/IND Datasheet Rev. 17 4/1/2022 7.3 Internal Power .................................................................................. 25 7.3.1 VDDSHV_3P3V .............................................................................. 25 7.3.2 VDDS_DDR .................................................................................. 25 7.3.3 VDD_MPU ................................................................................... 26 7.3.4 VDD_CORE .................................................................................. 26 7.3.5 VDDS_PLL ................................................................................... 26 7.4 Total Current Consideration .................................................................. 26 7.5 Control and Status .............................................................................. 27 7.5.1 Minimum Processor-PMIC interface Connections ..................................... 27 7.5.2 Minimum RTC Power Connections....................................................... 29 8 Electrical & Thermal Characteristics .............................................................. 30 9 Packaging Information............................................................................... 31 9.1 Mechanical Dimensions ........................................................................ 31 9.1.1 Land Pad Sizing ............................................................................ 32 9.2 Reflow Instructions ............................................................................. 32 9.3 Storage Requirements.......................................................................... 32 Octavo Systems LLC Copyright 2016-2022 4 OSD335x BAS/IND Datasheet Rev. 17 4/1/2022 1 Revision History Revision Number Revision Date Changes Author 1 5/6/2016 Initial Release 2 5/15/2016 3 5/19/2016 Updated Misprint on ADC Specs on first page Added Information on the MSL Rating Greg Sheridan, Kevin Troy Greg Sheridan 4 6/12/16 5 12/5/16 6 2/15/17 7 6/19/2017 8 6/30/2017 9 7/21/2017 10 11 08/23/2017 10/12/2017 12 11/21/2017 13 1/27/2018 14 15 02/16/2018 03/19/2019 16 17 1/1/2021 4/1/2022 Added reference to TI Handling Recommendations to Handling Section. Fixed Link Updated Electrical Characteristics add Thermal information. Also changed operating temperature from junction to case Updated Max Current and Voltage in Output Power and Electrical & Thermal Characterization Sections Updated Block Diagram. Highlighted that the processor I/Os are tied to 3.3V Updated Block Diagrams. Updated Bake Time in the Package Section. Updated to include discussion around the functionality of the TL5209 when the OSD335x is powered from VBAT Added Industrial Temperature. Added requirements for input voltage rise time and minimum interface connections Updated SYS_VDD2_3P3V current limit Updated page numbers to match PDF page numbers Updated voltage measurements Updated VIN_BAT information; Passive Tables Several Clean Up Items Updated Storage Temperature. Added in-rush current and rise time requirements. Octavo Systems LLC Copyright 2016-2022 Greg Sheridan Greg Sheridan Neeraj Dantu, Greg Sheridan Neeraj Dantu Greg Sheridan Greg Sheridan Neeraj Dantu Erik Welsh Neeraj Dantu Greg Sheridan Greg Sheridan Neeraj Dantu Erik Welsh Gene Frantz Greg Sheridan 5 OSD335x BAS/IND Datasheet Rev. 17 4/1/2022 2 Block Diagram The OSD335x family of devices consist of 4 main components serving 3 different functions. The main processor is a Texas Instruments Sitara™ AM335x ARM® Cortex®-A8. The power system has 2 devices from Texas Instruments, the TPS65217C Power Management IC (PMIC) and the TL5209 LDO. The last main component is up to 1GB DDR3 system memory. Figure 2.1 shows a detailed block diagram of the OSD335x and breaks out the key functions of the AM335x processor. Figure 2.1. OSD335x Detailed Block Diagram Octavo Systems LLC Copyright 2016-2022 6 OSD335x BAS/IND Datasheet Rev. 17 4/1/2022 2.1 Passives Besides the four major components, the OSD335x also integrates over 140 capacitors, resistors, inductors, and ferrite beads (Passives). Table 2-2 and Table 2-3 lists the equivalent capacitance and resistance integrated into the OSD335x. This includes the approximate bulk capacitance on input and output power rails as well as all pull-up resistor locations and values. The OSD335x does not require any external decoupling / bypass capacitors in most applications. However, it does require additional bulk capacitance on one of the output power rails. 2.1.1 Additional Required Bulk Capacitance The following output power rails require additional bulk capacitance to avoid in-rush / power up issues. Table 2-1 - OSD335x Required Additional Capacitors (Approximate Bulk Capacitance) From SYS_VOUT To DGND Device TPS65217C Description SYS_VOUT output capacitance Type C Value ~50uF 2.1.2 Integrated Bulk Capacitance The following input and output power rails have bulk capacitance integrated within the SiP. This table is for informative purposes only. Table 2-2 - OSD335x Capacitors (Approximate Bulk Capacitance) From To Device Description Type Value VIN_AC VIN_USB VIN_BAT VSS VSS VSS TPS65217C TPS65217C TPS65217C VIN_AC input capacitance VIN_USB input capacitance VIN_BAT input capacitance C C C 10uF 10uF 10uF SYS_VOUT SYS_VDD1_3P3V SYS_VDD2_3P3V VDDSHV_3P3V SYS_VDD_1P8V SYS_RTC_1P8V VSS VSS VSS VSS VSS VSS TPS65217C TL5209 TPS65217C TPS65217C TPS65217C TPS65217C SYS_VOUT output capacitance SYS_VDD1_3P3V output capacitance SYS_VDD2_3P3V output capacitance VDDSHV_3P3V output capacitance SYS_VDD_1P8V output capacitance SYS_RTC_1P8V output capacitance C C C C C C 60uF 2.2uF 2.2uF 10uF 10uF 2.2uF CAP_VDD_RTC VSS AM335x CAP_VDD_RTC capacitance C 1uF Octavo Systems LLC Copyright 2016-2022 7 OSD335x BAS/IND Datasheet Rev. 17 4/1/2022 2.1.3 Integrated Resistors The following pins have pull-up or pull-down resistors integrated within the SiP. This table is for informative purposes only. Table 2-3 - OSD335x Resistors (Pull-ups / Pull-downs) From To PMIC_OUT_ PWR_EN PMIC_IN_I2C_SCL PMIC_IN_I2C_SDA SYS_RTC_1P8V VDDSHV_3P3V VDDSHV_3P3V TPS65217C TPS65217C TPS65217C Device PWR_EN pull-up SCL pull-up SDA pull-up Description R R R 10K Ohm 4.7K Ohm 4.7K Ohm EXT_WAKEUP EXTINTN SYS_RTC_1P8V VDDSHV_3P3V AM335x AM335x EXT_WAKEUP input pull-up nNMI pull-up R R 10K Ohm 10K Ohm Octavo Systems LLC Copyright 2016-2022 Type Value 8 OSD335x BAS/IND Datasheet Rev. 17 4/1/2022 3 Product Number Information Figure 3.1 shows an example of an orderable product number for the OSD335X family. This section explains the different sections of the product number. It will also list the valid entries and their meaning for each designator. OSD3358-512M-BAS Family Designator Processor Designator Memory Designator Trim Designator Figure 3.1. Example Product Number Family Designator – Three letters that designate the family of device. Processor Designator – A set of letters and numbers that designate the specific processor in the device. Table 3.1 shows the valid values for the Processor Designator. Table 3.1. Processor Designators Processor Designator Processor 3358 Texas Instruments AM3358 Memory Designator – A set of letters and numbers that designate the DDR3 memory size in the device. Table 3.2 shows the valid values for the Memory Designator. Table 3.2. Memory Designator Memory Designator DDR Memory Size 512M 512 MB DDR3 Octavo Systems LLC Copyright 2016-2022 9 OSD335x BAS/IND Datasheet Rev. 17 4/1/2022 Trim Designator – A set of letters and numbers that designate a set additional features in the device. Table 3.3 shows the valid values for the Trim Designator. Table 3.3. Trim Designator Trim Designator Device Options BAS Base Model containing Processer, DDR Memory, PMIC, and LDO. Commercial: 0 to 85°C IND Base Model containing Processer, DDR Memory, PMIC, and LDO. Industrial: -40 to 85°C Octavo Systems LLC Copyright 2016-2022 10 OSD335x BAS/IND Datasheet Rev. 17 4/1/2022 4 Reference Documents 4.1 Data Sheets Below are links to the data sheets for the key devices used in the OSD335X. Please refer to them for specifics on that device. The remainder of this document will describe how the devices are used in the OSD335X system. It will also highlight any differences between the performance stated in the device specific datasheet and what should be expected from its operation in the OSD335X. • • • Processor PMIC LDO AM335X TPS62517C TL509 http://www.ti.com/product/AM3358/datasheet http://www.ti.com/product/TPS65217/datasheet http://www.ti.com/product/TL5209/datasheet 4.2 Other Reference This section contains links to other reference documents that could be helpful when using the OSD335x device. Some are referenced in this document. • • • • • • • TI AN-2029 – Handling & Process recommendations http://www.ti.com/lit/snoa550 AN1002 – Pin Assignments and Application Differences From TI AM3358 http://octavosystems.com/docs/AN1002.pdf AM335x DR PHY register configuration for DDR3 using Software Leveling http://processors.wiki.ti.com/index.php/AM335x_DDR_PHY_register_configuratio n_for_DDR3_using_Software_Leveling AM335x Power Estimation Tool http://processors.wiki.ti.com/index.php/AM335x_Power_Estimation_Tool Powering the AM335x with the TPS65217x http://www.ti.com/lit/slvu551 Powering the AM335x, AM335x, with LiPo and Li-Ion Batteries: https://octavosystems.com/app_notes/am335x-battery-applications-withosd335x-sip/ OSD335x RTC Use Cases https://octavosystems.com/app_notes/osd335x-rtc-use-cases/ Octavo Systems LLC Copyright 2016-2022 11 OSD335x BAS/IND Datasheet Rev. 17 4/1/2022 5 Ball Map The pins on the OSD335x belong to 4 distinct categories, AM335x Signals, TPS65217C signals, Oscillators and Power Domains. With a few exceptions, the ball assignments for the OSD335x are a superset of the ball assignments for the AM335x. Table 5.1 through Table 5.5 show the ball map for the OSD335x. Octavo Systems LLC Copyright 2016-2022 12 OSD335x BAS/IND Datasheet Rev. 17 4/1/2022 Table 5.1. OSD335x Ball Map Top View (Columns A - D) A B C D 20 PMIC_OUT_PGOOD PMIC_OUT_LDO_PGOOD PMIC_IN_I2C_SCL PMIC_IN_PB_IN 19 PMIC_OUT_NWAKEUP PMIC_OUT_NINT PMIC_IN_I2C_SDA PMIC_IN_PWR_EN 18 VSS EXTINTN ECAP0_IN_PWM0_OUT UART1_CTSN 17 SPI0_SCLK SPI0_D0 I2C0_SDA UART1_RTSN 16 SPI0_CS0 SPI0_D1 I2C0_SCL UART1_RXD 15 XDMA_EVENT_INTR0 PWRONRSTN SPI0_CS1 UART1_TXD 14 MCASP0_AHCLKX EMU1 EMU0 XDMA_EVENT_INTR1 13 MCASP0_ACLKX MCASP0_FSX MCASP0_FSR MCASP0_AXR1 12 TCK MCASP0_ACLKR MCASP0_AHCLKR MCASP0_AXR0 11 TDO TDI TMS CAP_VDD_SRAM_MPU 10 WARMRSTN TRSTN CAP_VBB_MPU SYS_VDD_1P8V 9 VSSA_ADC VREFP AIN7 CAP_VDD_SRAM_CORE 8 AIN6 AIN5 AIN4 SYS_ADC_1P8V 7 AIN3 AIN2 AIN1 SYS_RTC_1P8V 6 VSSA_ADC AIN0 PMIC_POWER_EN CAP_VDD_RTC 5 SYS_ADC_1P8V RTC_PWRONRSTN EXT_WAKEUP NC 4 SYS_ADC_1P8V RTC_KALDO_ENN NC NC 3 TESTOUT NC NC NC 2 VDD_MPU_MON NC NC NC 1 VSS NC NC NC Octavo Systems LLC Copyright 2016-2022 13 OSD335x BAS/IND Datasheet Rev. 17 4/1/2022 Table 5.2. OSD335x Ball Map Top View (Columns E - H) E F G H 20 VSS OSC1_OUT OSC1_GND OSC1_IN 19 VSS VSS VSS VSS 18 UART0_CTSN MMC0_DAT2 MMC0_CMD RMII1_REF_CLK 17 UART0_RTSN MMC0_DAT3 MMC0_CLK MII1_CRS 16 UART0_TXD USB0_DRVVBUS MMC0_DAT0 MII1_COL 15 UART0_RXD USB1_DRVVBUS MMC0_DAT1 VDDS_PLL 14 SYS_RTC_1P8V VDDSHV_3P3V VDDSHV_3P3V VDDSHV_3P3V 13 VDDSHV_3P3V VDD_MPU VDD_MPU VDD_MPU 12 VDDSHV_3P3V VDD_MPU VSS VSS 11 VDDSHV_3P3V VDD_MPU VSS VDD_CORE 10 VDDSHV_3P3V VDD_MPU VDD_CORE VSS 9 SYS_VDD_1P8V SYS_RTC_1P8V VSS VSS 8 VSSA_ADC VSS VSS VSS 7 VDDS_PLL VDD_CORE VDD_CORE VSS 6 SYS_RTC_1P8V VDD_CORE VDD_CORE VSS 5 VDDS_DDR VDDS_DDR VDDS_DDR VDDS_DDR 4 NC NC NC NC 3 NC NC NC NC 2 NC NC NC NC 1 NC NC NC NC Octavo Systems LLC Copyright 2016-2022 14 OSD335x BAS/IND Datasheet Rev. 17 4/1/2022 Table 5.3. OSD335x Ball Map Top View (Columns J - M) J K L M 20 VSS OSC0_OUT OSC0_GND OSC0_IN 19 VSS VSS VSS VSS 18 MII1_TXD3 MII1_TX_CLK MII1_RX_CLK MDC 17 MII1_RX_DV MII1_TXD0 MII1_RXD3 MDIO 16 MII1_TX_EN MII1_TXD1 MII1_RXD2 MII1_RXD0 15 MII1_RX_ER MII1_TXD2 MII1_RXD1 USB0_CE 14 VDDSHV_3P3V VDDSHV_3P3V VDDSHV_3P3V VSS 13 VDD_MPU SYS_RTC_1P8V VSS VDD_CORE 12 VDD_CORE VDD_CORE VSS VSS 11 VSS VSS VSS VDD_CORE 10 VSS VSS VSS VSS 9 VSS VSS VDD_CORE VSS 8 VSS VDD_CORE VDD_CORE VSS 7 VSS VSS VDD_CORE VSS 6 VSS VDD_CORE VDD_CORE VSS 5 VDDS_DDR VDDS_DDR VDDS_DDR VPP 4 NC NC NC NC 3 NC NC NC NC 2 NC NC NC NC 1 NC NC NC NC Octavo Systems LLC Copyright 2016-2022 15 OSD335x BAS/IND Datasheet Rev. 17 4/1/2022 Table 5.4. OSD335x Ball Map Top View (Columns N - T) N P R T 20 VSS VSS VSS VSS 19 VSS VSS VSS VSS 18 USB0_DM USB1_CE USB1_DM USB1_VBUS 17 USB0_DP USB1_ID USB1_DP GPMC_WAIT0 16 SYS_VDD_1P8V USB0_ID SYS_VDD_1P8V GPMC_A10 15 VDDSHV_3P3V USB0_VBUS VDDSHV_3P3V GPMC_A07 14 VSS SYS_RTC_1P8V GPMC_A04 GPMC_A03 13 VDD_CORE VDDSHV_3P3V GPMC_A00 GPMC_CSN3 12 VDD_CORE VDDSHV_3P3V GPMC_AD13 GPMC_AD12 11 VSS VDDSHV_3P3V VDDS_PLL GPMC_AD10 10 VSS VDDSHV_3P3V VDDS_PLL GPMC_AD09 9 VDD_CORE SYS_RTC_1P8V GPMC_AD06 GPMC_AD07 8 VDD_CORE VDDSHV_3P3V GPMC_AD02 GPMC_AD03 7 VSS VDDSHV_3P3V GPMC_ADVN_ALE GPMC_OEN_REN 6 SYS_RTC_1P8V VDDSHV_3P3V LCD_AC_BIAS_EN GPMC_BEN0_CLE 5 VDDSHV_3P3V VDDSHV_3P3V LCD_HSYNC LCD_DATA15 4 NC NC LCD_DATA03 LCD_DATA07 3 NC NC LCD_DATA02 LCD_DATA06 2 NC NC LCD_DATA01 LCD_DATA05 1 NC NC LCD_DATA00 LCD_DATA04 Octavo Systems LLC Copyright 2016-2022 16 OSD335x BAS/IND Datasheet Rev. 17 4/1/2022 Table 5.5. OSD335x Ball Map Top View (Columns U - Y) U V W Y 20 SYS_VDD1_3P3V SYS_VDD1_3P3V VSS EXTL3B 19 VSS VSS VSS EXTL3A 18 GPMC_BEN1 VSS VSS VSS 17 GPMC_WPN GPMC_A11 VSS EXTL2B 16 GPMC_A09 GPMC_A08 VSS EXTL2A 15 GPMC_A06 GPMC_A05 VSS VSS 14 GPMC_A02 GPMC_A01 VSS EXTL1B 13 GPMC_AD15 GPMC_AD14 VSS EXTL1A 12 GPMC_AD11 GPMC_CLK VSS VSS 11 NC NC VSS SYS_VDD2_3P3V 10 GPMC_AD08 NC VSS VSS 9 GPMC_CSN1 GPMC_CSN2 VSS VIN_USB 8 GPMC_AD04 GPMC_AD05 VSS VIN_USB 7 GPMC_AD00 GPMC_AD01 VSS VSS 6 GPMC_WEN GPMC_CSN0 VSS VIN_AC 5 LCD_VSYNC LCD_PCLK VSS VIN_AC 4 LCD_DATA11 LCD_DATA14 SYS_VOUT SYS_VOUT 3 LCD_DATA10 LCD_DATA13 VSS VIN_BAT 2 LCD_DATA09 LCD_DATA12 VSS VIN_BAT 1 LCD_DATA08 VSS BAT_TEMP BAT_VOLT Octavo Systems LLC Copyright 2016-2022 17 OSD335x BAS/IND Datasheet Rev. 17 4/1/2022 5.1 Ball Description Table 5.6 lists all of the unique balls of the OSD335x and gives a brief explanation of their function. For more detail please refer to the datasheet in section 4.1 for the individual device that ball is associated with. Table 5.6 OSD335x Ball Descriptions Pin Name Description AIN0 AIN1 AIN2 AIN3 AIN4 AIN5 AIN6 AIN7 BAT_TEMP BAT_VOLT CAP_VBB_MPU CAP_VDD_RTC CAP_VDD_SRAM_CORE CAP_VDD_SRAM_MPU ECAP0_IN_PWM0_OUT EMU0 EMU1 EXT_WAKEUP EXTINTN EXTL1A EXTL1B EXTL2A EXTL2B EXTL3A EXTL3B GPMC_A00 GPMC_A01 GPMC_A02 GPMC_A03 GPMC_A04 GPMC_A05 GPMC_A06 GPMC_A07 GPMC_A08 GPMC_A09 GPMC_A10 GPMC_A11 GPMC_AD00 GPMC_AD01 GPMC_AD02 GPMC_AD03 GPMC_AD04 GPMC_AD05 GPMC_AD06 GPMC_AD07 GPMC_AD08 GPMC_AD09 GPMC_AD10 GPMC_AD11 GPMC_AD12 GPMC_AD13 GPMC_AD14 Analog Input / Output Analog Input / Output Analog Input / Output Analog Input / Output Analog Input / Output Analog Input Analog Input Analog Input TPS65217C TS Input TPS65217C BAT_SENSE Input Internal Voltage Test Point Internal Voltage Test Point, RTC Supply Voltage Input Internal Voltage Test Point Internal Voltage Test Point Enhanced Capture 0 Input or PWM0 Output Miscellaneous Emulation Pin Miscellaneous Emulation Pin AM335x EXT_WAKEUP Input AM335x External Interrupt to ARM Cortex-A8 RESERVED RESERVED RESERVED RESERVED RESERVED RESERVED GPMC Address GPMC Address GPMC Address GPMC Address GPMC Address GPMC Address GPMC Address GPMC Address GPMC Address GPMC Address GPMC Address GPMC Address GPMC Address and Data GPMC Address and Data GPMC Address and Data GPMC Address and Data GPMC Address and Data GPMC Address and Data GPMC Address and Data GPMC Address and Data GPMC Address and Data GPMC Address and Data GPMC Address and Data GPMC Address and Data GPMC Address and Data GPMC Address and Data GPMC Address and Data Octavo Systems LLC Copyright 2016-2022 18 OSD335x BAS/IND Datasheet Rev. 17 4/1/2022 GPMC_AD15 GPMC_ADVN_ALE GPMC_BEN0_CLE GPMC_BEN1 GPMC_CLK GPMC_CSN0 GPMC_CSN1 GPMC_CSN2 GPMC_CSN3 GPMC_OEN_REN GPMC_WAIT0 GPMC_WEN GPMC_WPN I2C0_SCL I2C0_SDA LCD_AC_BIAS_EN LCD_DATA00 LCD_DATA01 LCD_DATA02 LCD_DATA03 LCD_DATA04 LCD_DATA05 LCD_DATA06 LCD_DATA07 LCD_DATA08 LCD_DATA09 LCD_DATA10 LCD_DATA11 LCD_DATA12 LCD_DATA13 LCD_DATA14 LCD_DATA15 LCD_HSYNC LCD_PCLK LCD_VSYNC MCASP0_ACLKR MCASP0_ACLKX MCASP0_AHCLKR MCASP0_AHCLKX MCASP0_AXR0 MCASP0_AXR1 MCASP0_FSR MCASP0_FSX MDC MDIO MII1_COL MII1_CRS MII1_RX_CLK MII1_RX_DV MII1_RX_ER MII1_RXD0 MII1_RXD1 MII1_RXD2 MII1_RXD3 MII1_TX_CLK MII1_TX_EN MII1_TXD0 MII1_TXD1 MII1_TXD2 MII1_TXD3 MMC0_CLK MMC0_CMD MMC0_DAT0 GPMC Address and Data GPMC Address Valid / Address Latch Enable GPMC Byte Enable 0 / Command Latch Enable GPMC Byte Enable 1 GPMC Clock GPMC Chip Select GPMC Chip Select GPMC Chip Select GPMC Chip Select GPMC Output Enable / Read Enable GPMC Wait 0 GPMC Write Enable GPMC Write Protect I2C Clock I2C Data LCD AC Bias Enable Chip Select LCD Data Bus LCD Data Bus LCD Data Bus LCD Data Bus LCD Data Bus LCD Data Bus LCD Data Bus LCD Data Bus LCD Data Bus LCD Data Bus LCD Data Bus LCD Data Bus LCD Data Bus LCD Data Bus LCD Data Bus LCD Data Bus LCD Horizontal Sync LCD Pixel Clock LCD Vertical Sync McASP0 Receive Bit Clock McASP0 Transmit Bit Clock McASP0 Receive Master Clock McASP0 Transmit Master Clock McASP0 Serial Data McASP0 Serial Data McASP0 Receive Frame Sync McASP0 Transmit Frame Sync MDIO Clock MDIO Data MII Collision MII Carrier Sense MII Receive Clock MII Receive Data Valid MII Receive Data Error MII Receive Data MII Receive Data MII Receive Data MII Receive Data MII Transmit Clock MII Transmit Enable MII Transmit Data MII Transmit Data MII Transmit Data MII Transmit Data MMC/SD/SDIO Clock MMC/SD/SDIO Command MMC/SD/SDIO Data Octavo Systems LLC Copyright 2016-2022 19 OSD335x BAS/IND Datasheet Rev. 17 4/1/2022 MMC0_DAT1 MMC0_DAT2 MMC0_DAT3 NC OSC0_GND OSC0_IN OSC0_OUT OSC1_GND OSC1_IN OSC1_OUT PMIC_IN_I2C_SCL PMIC_IN_I2C_SDA PMIC_IN_PB_IN PMIC_IN_PWR_EN PMIC_OUT_LDO_PGOOD PMIC_OUT_NINT PMIC_OUT_NWAKEUP PMIC_OUT_PGOOD PMIC_POWER_EN PWRONRSTN RMII1_REF_CLK RTC_KALDO_ENN RTC_PWRONRSTN SPI0_CS0 SPI0_CS1 SPI0_D0 SPI0_D1 SPI0_SCLK SYS_ADC_1P8V SYS_RTC_1P8V SYS_VDD_1P8V SYS_VDD1_3P3V SYS_VDD2_3P3V SYS_VOUT TCK TDI TDO TESTOUT TMS TRSTN UART0_CTSN UART0_RTSN UART0_RXD UART0_TXD UART1_CTSN UART1_RTSN UART1_RXD UART1_TXD USB0_CE USB0_DM USB0_DP USB0_DRVVBUS USB0_ID USB0_VBUS USB1_CE USB1_DM USB1_DP USB1_DRVVBUS USB1_ID MMC/SD/SDIO Data MMC/SD/SDIO Data MMC/SD/SDIO Data No Connect High Frequency Oscillator Ground High Frequency Oscillator Input High Frequency Oscillator Output Real Time Clock Oscillator Ground Real Time Clock Oscillator Input Real Time Clock Oscillator Output TPS65217C SCL Input TPS65217C SDA Input / Output TPS65217C PB_IN Input TPS65217C PWR_EN Input TPS65217C LDO_PGOOD Output TPS65217C NINT Output TPS65217C NWAKEUP Output TPS65217C PGOOD Output AM335x PMIC_POWER_EN Output Power On Reset Input (Active Low) RMII Reference Clock Enable input for internal CAP_VDD_RTC voltage regulator (Active Low) RTC Reset Input (Active Low) SPI Chip Select SPI Chip Select SPI Data SPI Data SPI Clock Output Power Supply, Analog, 1.8VDC Output Power Supply, RTC Voltage Domain, 1.8VDC Output Power Supply, Digital, 1.8VDC Output Power Supply, Primary, 3.3VDC Output Power Supply, Secondary, 3.3VDC TPS65217C SYS Output JTAG Test Clock JTAG Test Data Input JTAG Test Data Output RESERVED JTAG Test Mode Select JTAG Test Reset UART Clear to Send UART Request to Send UART Receive Data UART Transmit Data UART Clear to Send UART Request to Send UART Receive Data UART Transmit Data USB0 Charger Enable Output USB0 Data (-) USB0 Data (+) USB0 VBUS Control Output. Driven high to enable external power logic in Host mode. Requires valid input on USB0_VBUS. Checks USB0_VBUS every 100ms and generates VBUS error interrupt if USB0_VBUS VBUS is not valid. USB0 OTG ID USB0 VBUS USB1 Charger Enable Output USB1 Data (-) USB1 Data (+) USB1 VBUS Control Output. Driven high to enable external power logic in Host mode. Requires valid input on USB1_VBUS. Checks USB1_VBUS every 100ms and generates VBUS error interrupt if USB1_VBUS is not valid. USB1 OTG ID Octavo Systems LLC Copyright 2016-2022 20 OSD335x BAS/IND Datasheet Rev. 17 4/1/2022 USB1_VBUS VDD_CORE VDD_MPU VDD_MPU_MON VDDS_DDR VDDS_PLL VDDSHV_3P3V VIN_AC VIN_BAT VIN_USB VPP VREFP VSS VSSA_ADC WARMRSTN XDMA_EVENT_INTR0 XDMA_EVENT_INTR1 USB1 VBUS Internal Power Supply Test Point Internal Power Supply Test Point AM335x VDD_MPU_MON Signal Internal Power Supply Test Point Internal Power Supply Test Point Internal Power Supply Test Point TPS65217C AC Input TPS65217C BAT Input / Output TPS65217C USB Input RESERVED Analog Positive Reference Input Digital Ground Analog Ground, Analog Negative Reference Input Warm Reset (Active Low) External DMA Event or Interrupt 0 External DMA Event or Interrupt 1 5.2 AM335x Relocated Signals A small number of signals from the AM335x have been moved to a different location on the OSD335x. For more information on these signals please refer to AN1002. A link to it is provided in the Reference Documents section of this document. 5.3 Not Connected Balls The OSD335x ball map contains a number of balls which are marked NC (No Connect). These balls must be left unconnected on the system PCB since they may be used for other purposes in future versions of the OSD335x. Most of these balls are from the AM335x pins associated with the DDR3 interface. They are not brought out because they are exclusively used internally to connect the AM335x with the DDR Memory. Several other balls in the ball map are also NC due to other functions handled internal to the OSD335x. Octavo Systems LLC Copyright 2016-2022 21 OSD335x BAS/IND Datasheet Rev. 17 4/1/2022 5.4 Reserved Signals There is a subset of signals that are available on the OSD335x ball map but should not be used externally to the device. These signals are used internally to the OSD335x and using them could significantly affect the performance of the device. They are provided for test purposes only. The list of signals that should not be used can be found in Table 5.7. Table 5.7. Reserved Signals Reserved Signals TESTOUT CAP_VBB_MPU CAP_VDD_SRAM_CORE CAP_VDD_SRAM_MPU VPP EXTL1A EXTL1B EXTL2A EXTL2B EXTL3A EXTL3B Octavo Systems LLC Copyright 2016-2022 22 OSD335x BAS/IND Datasheet Rev. 17 4/1/2022 6 OSD335x Components The OSD335x integrates the Texas Instruments ARM® Cortex®-A8 Sitara™ AM335x processor along with the TI TPS65217C PMIC, the TI TL5209 LDO, up to 1 GB of DDR3 Memory, and the resistors, capacitors, and inductors into a single design-in-ready package. The following section contains any specific device information needed for the integrated components to design your system with the OSD335x. 6.1 AM335x Processor The heart of the OSD335x is the Texas Instruments ARM® Cortex®-A8 Sitara™ AM335x processor. The processor in the OSD335x is configured to perform identically to a standalone device. Please refer to the data sheet in the Reference Documents section for details on using the AM335x processor. 6.1.1 I/O Voltages The OSD335x fixes the I/O voltage domains (VDDSHVx) of the AM335x to 3.3V for all dual voltage I/Os. This cannot be adjusted and means all of the signal I/O pins associated with the AM335x operate at 3.3V. 6.2 DDR3 Memory The OSD335x integrates a DDR3 memory into the device and handles all of the connections needed between the AM335x and the DDR3. You will still have to set the proper registers to configure the AM335x DDR PHY to work correctly with the memory included in the OSD335x. Typically, this would require you to run through the procedure outlined in the AM335x DDR PHY register configuration for DDR3 using Software Leveling referred to in the Reference Documents section of this document. We have already run this procedure for the OSD335x and have provided a list of the recommended values for the registers in Table 6.1. It is recommended that you use this set of values for optimal performance. Octavo Systems LLC Copyright 2016-2022 23 OSD335x BAS/IND Datasheet Rev. 17 4/1/2022 Table 6.1 AM335x DDR PHY Register Settings Register Name Peripheral Recommended Value DDR_CMDx_IOCTRL(1) Control Module 0x0000018B DDR_DATAx_IOCTRL(2) Control Module 0x0000018B EMIF EMIF EMIF EMIF EMIF EMIF EMIF EMIF 0x61C05332 0x00000000 0x00000C30 0x0AAAD4DB 0x266B7FDA 0x501F867F 0x50074BE4 0x00100007 CMDx_REG_PHY_CTRL_SLAVE_RATIO_0(1) DDR PHY 0x00000080 CMDx_REG_PHY_INVERT_CLKOUT_0(1) DDR PHY 0x00000000 DATAx_REG_PHY_RD_DQS_SLAVE_RATIO_0(2) DDR PHY 0x0000003A DATAx_REG_PHY_WR_DQS_SLAVE_RATIO_0(2) DDR PHY 0x00000045 DATAx_REG_PHY_FIFO_WE_SLAVE_RATIO_0(2) DDR PHY 0x00000095 DATAx_REG_PHY_WR_DATA_SLAVE_RATIO_0(2) DDR PHY 0x0000007F SDRAM_CONFIG SDRAM_CONFIG_2 SDRAM_REF_CTRL SDRAM_TIM_1 SDRAM_TIM_2 SDRAM_TIM_3 ZQ_CONFIG DDR_PHY_CTRL_1 (1) (2) “CMDx” refers to registers where x is in [0, 1, 2] “DATAx” refers to registers where x is in [0, 1] Settings in Table 6.1 are recommended and supported. Other values may work but are not guaranteed. If you want to rerun the calibration yourself the seed values provided in Table 6.2 should be used. Table 6.2 AM335x DDR PHY Calibration Seed Values DATAx_PHY_RD_DQS_SLAVE_RATIO DATAx_PHY_FIFO_WE_SLAVE_RATIO DATAx_PHY_WR_DQS_SLAVE_RATIO 40 64 0 Octavo Systems LLC Copyright 2016-2022 24 OSD335x BAS/IND Datasheet Rev. 17 4/1/2022 7 Power Management The power management portion of the OSD335x consists of two devices, the TPS65217C (PMIC) and the TL5209 (LDO). The PMIC provides the necessary power rails to the AM335x and the DDR3 while the LDO is not used inside the SiP. Both devices provide power supply outputs that may be used to power circuitry external to the OSD335x. This section describes how to power the OSD335x in a system and the outputs that can be used. 7.1 Input Power The OSD335x may be powered by any combination of the following input power supplies. Please refer to the TPS65217C datasheet for details. The maximum risetime for input rails VIN_AC and VIN_USB (defined as time for the input voltage to rise from 100 mV to 4.5 V) is 50 ms. The device may fail to power up properly if this requirement is not met. 7.1.1 VIN_AC The OSD335x may be powered by an external AC Adaptor at 5.0 VDC. If input is unused, it should be connected to VSS. 7.1.2 VIN_USB The OSD335x may be powered by a USB port at 5.0 VDC. If input is unused, it should be connected to VSS. 7.1.3 VIN_BAT The OSD335x may be powered by a single cell (1S) Li-Ion or Li-Polymer Battery nominally at 3.7 VDC. Due to the dropout behavior of the LDO TL5209, the output voltage rail SYS_VDD1_3P3V cannot be used once VIN_BAT drops below 3.5V. Please refer to the TL5209 datasheet for details. When the VIN_BAT input is not used, it must be connected to BAT_VOLT. 7.2 Output Power The OSD335x produces the following output power supplies. 7.2.1 SYS_VOUT: Switched VIN_AC, VIN_USB, or VIN_BAT The OSD335x contains a shared supply to power the AM335x, DDR3, and TL5209 which is also used to power external circuitry. This is supplied by the TPS65217C SYS output. The SYS output is a switched connection to one of the input power supplies selected by the TPS65217C as described in the datasheet for that device. Octavo Systems LLC Copyright 2016-2022 25 OSD335x BAS/IND Datasheet Rev. 17 4/1/2022 7.2.2 SYS_VDD1_3P3V The OSD335x contains a dedicated 3.4 VDC supply1 to power external circuitry. This is supplied by the TL5209, powered by the TPS65217C SYS output, and enabled by the TPS65217C LDO4. Due to the dropout behavior of the LDO TL5209, the output voltage rail SYS_VDD1_3P3V cannot be used once VIN_BAT drops below 3.5V. Please refer to the TL5209 datasheet for details. 7.2.3 SYS_VDD2_3P3V The OSD335x contains a dedicated 3.3 VDC supply to power external circuitry. This is supplied by the TPS65217C LDO2. 7.2.4 SYS_RTC_1P8V The OSD335x contains a shared 1.8 VDC supply to power the AM335x RTC which may also be used to power external circuitry. This is supplied by the TPS65217C LDO1. Please note that the AM335x in the OSD335x is powered by TPS65217 PMIC version C which does not support RTC only mode. 7.2.5 SYS_VDD_1P8V The OSD335x contains a shared 1.8 VDC supply to power the AM335x SRAM, PLLs, and USB which may also be used to power external circuitry. This is supplied by the TPS65217C LDO3. 7.2.6 SYS_ADC_1P8V The OSD335x contains a shared 1.8 VDC supply to power the AM335x ADC which may also be used to power external analog circuitry. This is supplied by the TPS65217C LDO3 and filtered for analog applications. 7.3 Internal Power The OSD335x has internal power supplies that are not available to power external circuitry. To do so will prevent the OSD335x from functioning properly. The power supplies are accessible externally for monitoring purposes only. 7.3.1 VDDSHV_3P3V The OSD335x contains a dedicated 3.3 VDC supply to power the AM335x I/O domain. This is supplied by the TPS65217C LDO4. 7.3.2 VDDS_DDR The OSD335x contains a dedicated 1.5 VDC supply to power the AM335x DDR3 interface and the DDR3 device. 1 The LDO has an accuracy of 1 – 2% depending on the ambient temperature which will also affect the nominal voltage. See the TL5209 datasheet for more information. Octavo Systems LLC Copyright 2016-2022 26 OSD335x BAS/IND Datasheet Rev. 17 4/1/2022 7.3.3 VDD_MPU The OSD335x contains a dedicated 1.1 VDC supply to power the AM335x MPU domain. 7.3.4 VDD_CORE The OSD335x contains a dedicated 1.1 VDC supply to power the AM335x CORE domain. 7.3.5 VDDS_PLL The OSD335x contains a filtered 1.8 VDC supply to power the AM335x PLLs and oscillators. 7.4 Total Current Consideration The total current consumption of all power rails must not exceed the recommended input currents described in Table 8.2. This includes power consumption within the SiP from the AM335x and the DDR3, as well as all external loads on the output power rails from Section 7.2. The power consumed by the AM335x can be estimated using the AM335x Power Estimation Tool found in the Reference Documents section of this document. When estimating power consumption, the efficiencies and types of the OSD335x internal power supplies must be considered. Refer to the “Connections Diagram for TPS65217C and AM335x” section of Powering the AM335x with the TPS65217x found in the Reference Documents section of this document for more information on the power supplies providing power to the AM335x. Octavo Systems LLC Copyright 2016-2022 27 OSD335x BAS/IND Datasheet Rev. 17 4/1/2022 7.5 Control and Status The control and status connections for Processor-PMIC interface and RTC subsystem required to power the device are described in this section. 7.5.1 Minimum Processor-PMIC interface Connections Table 7.1 lists the signals required to coordinate the operation of the AM335x and TPS65217C. Figure 7.1 and Figure 7.2 illustrate the required connections between the AM335x and the TPS65217C with RTC subsystem enabled and disabled respectively. These connections are the minimum required to operate the device in the corresponding mode. The accessibility of these signals enables other uses of reset, power control, power status, interrupt, wakeup, and serial communication signals. The figures 7.1 and 7.2 only illustrate the interface between the AM335x and TPS65217C. . Table 7.1. AM335x and TPS65217C Signal Descriptions Signal PMIC_POWER_EN PMIC_IN_PWR_EN I2C0_SCL PMIC_IN_I2C_SCL I2C0_SDA PMIC_IN_I2C_SDA PMIC_OUT_PGOOD PWRONRSTN PMIC_OUT_LDO_PGOOD RTC_PWRONRSTN PMIC_OUT_NINT EXTINTN PMIC_OUT_NWAKEUP EXT_WAKEUP Description PMIC Power Enable from AM335x PMIC Power Enable to TPS65217C I2C0 SCL from AM335x I2C SCL to TPS65217C I2C0 SDA from AM335x I2C SDA to TPS65217C PGOOD from TPS65217C PWRONRSTN to AM335x LDO_PGOOD from TPS65217C RTC_ PWRONRSTN to AM335x NINT from TPS65217C EXTINTN to AM335x NWAKEUP from TPS65217C EXT_WAKEUP to AM335x 1. See Table 2-3 for pull up on this signal Octavo Systems LLC Copyright 2016-2022 Notes 1 1 1 1 1 28 OSD335x BAS/IND Datasheet Rev. 17 4/1/2022 Figure 7.1. OSD335x Minimum Signal Connections with RTC enabled Figure 7.2. OSD335x Minimum Signal Connections with RTC disabled Octavo Systems LLC Copyright 2016-2022 29 OSD335x BAS/IND Datasheet Rev. 17 4/1/2022 7.5.2 Minimum RTC Power Connections Table 7.2 lists RTC domain signals required to operate the OSD335x-SM. In addition to the required connections described in Section 7.5.1, Figure 7.3 and Figure 7.4 illustrate additional connections with RTC subsystem enabled and disabled respectively. These connections are also included in the minimum required circuitry to operate the device. Table 7.2. OSD335x-SM RTC Signal Descriptions Signal CAP_VDD_RTC RTC_KALDO_ENN RTC_PWRONRSTN PMIC_POWER_EN EXT_WAKEUP Description Supply voltage for the RTC core domain Active low enable input for internal CAP_VDD_RTC voltage regulator RTC_PWRONRSTN to AM335x PMIC Power Enable from AM335x EXT_WAKEUP to AM335x Notes 1 1. See Table 2-3 for pull up on this signal Figure 7.3. Additional connections for OSD335x with RTC enabled Figure 7.4. Additional connections for OSD335x with RTC disabled Octavo Systems LLC Copyright 2016-2022 30 OSD335x BAS/IND Datasheet Rev. 17 4/1/2022 8 Electrical & Thermal Characteristics Table 8.1 lists electrical and thermal characteristic parameters of the OSD3358. Table 8.1. OSD335x Absolute Maximum Ratings over operating free-air temperature range (unless otherwise noted) (1) (2) Value Supply voltage range (with respect to VSS) Input/Output voltage range (with respect to VSS) Terminal current Tc Operating case temperature Tstg Storage temperature (2) -0.3 to 7 -0.3 to 7 -0.3 to 3.6 3000 0 to 85 -40 to 85 -55 to 125 ±2000 ±500 (HBM) Human body model (CDM) Charged device model ESD rating (1) VIN_BAT VIN_USB, VIN_AC All pins unless specified separately SYS_VOUT, VIN_USB, VIN_BAT Commercial (BAS) Industrial (IND) Unit V V mA °C °C °C V Stresses beyond those listed under Absolute Maximum Ratings may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated under Recommended Operating Conditions is not implied. Exposure to absolute maximum rated conditions for extended periods may affect device reliability. All voltage values are with respect to network ground terminal. Table 8.2. Recommended Operating Conditions over operating free-air temperature range (unless otherwise noted) Min Max Unit 5.8 V In-rush current, VIN_AC 2.1 A In-rush current, VIN_USB 500 mA Supply voltage Rise Time, VIN_USB, VIN_AC (100mV to 4.5V) 50 ms 5.5 V Input current from VIN_AC 2.0 A Input current from VIN_USB 1.3 A VIN_BAT current 2.0 A Supply voltage, VIN_USB, VIN_AC Nom 4.3 Supply voltage, VIN_BAT 2.75 Output voltage range for SYS_VDD1_3P3V 3.4 V Output voltage range for SYS_VDD2_3P3V 3.3 V Output voltage range for SYS_RTC_1P8V 1.8 V Output voltage range for SYS_VDD_1P8V 1.8 V Output voltage range for SYS_ADC_1P8V 1.8 V Output voltage range for VDDS_DDR1 1.5 V Output voltage range for VDD_MPU1 1.1 V Output voltage range for VDD_CORE1 1.1 V 1.8 V Output voltage range for VDDS_PLL 1 Output voltage range for VDDSHV_3P3V1 3.3 V Output current for SYS_VOUT2 0 500 mA Output current for SYS_VDD1_3P3V2 0 500 mA Output current for SYS_VDD2_3P3V 2 0 100 mA Output current for SYS_RTC_1P8V2 0 100 mA 2 0 250 mA 25 mA Output current for SYS_VDD_1P8V Output current for SYS_ADC_1P8V2 0 (1) These voltage rails are for reference only and should not be used to power anything on the PCB. Octavo Systems LLC Copyright 2016-2022 31 OSD335x BAS/IND Datasheet Rev. 17 4/1/2022 (2) Please note that the total input current on VIN_AC, VIN_USB or VIN_BAT must not exceed the recommended maximum value even if individual currents drawn from these power supply outputs are less than or equal to the maximum recommended operating output currents. See section 7.4 for more details. 9 Packaging Information The OSD335x is packaged in a 400 ball, Ball Grid Array (BGA). The package size is 27 X 27 millimeters with a ball pitch of 1.27mm. This section will give you the specifics on the package. 9.1 Mechanical Dimensions The mechanical drawings of the OSD335x show pin A1 in the lower left hand corner when looking at the top view of the device. Pin A1 is in the upper left hand corner if looking at the Octavo Systems LLC Copyright 2016-2022 32 OSD335x BAS/IND Datasheet Rev. 17 4/1/2022 balls from the bottom view of the package. The PCB layout should have pin A1 in the lower left hand corner when looking at the top side of the PCB where the OSD335x will be attached. 9.1.1 Land Pad Sizing For the nominal ball diameter of 0.75mm, specification IPC-7351A states that for NSMD pads, the nominal land diameter is 0.55mm with a land variation of 0.60mm to 0.50mm. Footprints provided by Octavo Systems generally use the minimum land pad size to enable lower cost routing. However, some applications may require a larger land pad size to enable a more robust structural connection to the circuit board or for other manufacturing constraints. Check the requirements of the application and manufacturer to determine the appropriate land pad size. 9.2 Reflow Instructions The reflow profile for this package should be in accordance with the Lead-free process for BGA. A peak reflow temperature is recommended to be 245°C. Texas Instruments provides a good overview of Handling & Process Recommendations in AN2029 for this type of device. A link to the document can be found in the Reference Documents section of this document. 9.3 Storage Requirements The OSD335x Family of devices are sensitive to moisture and need to be handled in specific ways to make sure they function properly during and after the manufacturing process. The OSD335x Family of devices are rated with a Moisture Sensitivity Level (MSL) of 4. This means that they are typically stored in a sealed Dry Pack. Once the sealed Dry Pack is opened the OSD335x needs to be used within 72 hours to avoid further processing. If the OSD335x has been exposed for more than 72 hours, then it is required that you bake the device for 34 hours at 125°C before using. Alternatively, the devices could be stored in a dry cabinet with humidity
OSD3358-512M-BAS 价格&库存
很抱歉,暂时无法提供与“OSD3358-512M-BAS”相匹配的价格&库存,您可以联系我们找货
