CENGPXA270-520-11-504HCR 数据手册
PRODUCT BRIEF:
Logic PD :: Marvell
PXA270 CARD ENGINE System on Module
The PXA270 Card Engine is a compact, product-ready
hardware and software solution that fast forwards your
embedded product design.
PXA270 CARD ENGINE ::
HIGHLIGHTS:
+ Product-ready
System on
Module with the Marvell PXA270
Applications Processor running at
416 or 520 MHz
The PXA270 Card Engine is a complete System on Module
(SOM) that offers essential features for handheld and embedded
networking applications. Use of custom baseboards makes the
Card Engine the ideal foundation for OEMs developing handheld
and compact products. The Card Engine provides a common
reference pin-out on its expansion connectors, which enables easy
scalability to next generation microprocessor Card Engines when
new functionality or performance is required.
Application development is performed right on the product-ready
PXA270 Card Engine and software Board Support Packages
(BSPs), which enables you to seamlessly transfer your application
code and hardware into production.
The PXA270 Card Engine is ideal for applications in the medical,
point-of-sale, industrial, and security markets. From patient
+ Compact
form factor
60.2 mm x 67.8 mm x 4.4 mm
+ Long
product lifecycle
+ 0
˚C to 70 ˚C (commercial temp) or
-25 ˚C to 85 ˚C (extended temp)
+ RoHS
compliant
PXA270 ZOOM ™ SDK ::
FEATURES:
+ Application
PXA270 CARD ENGINE
monitoring and medical imaging, to card payment
terminals and bar code readers, to CCTV
cameras and intruder alarms, the PXA270 Card
Engine allows for powerful versatility and long-life
products.
baseboard
+ PXA270
Card Engine
(CENGPXA270-520-10-504HCR)
+ Necessary
accessories to
immediately get up and running
+ Kit
available from Logic PD
(SDK-PXA270-520-10-6432R)
+ See
Zoom™ SDK product brief for
more information
Product Features
PXA270 Card Engine Block Diagram
EXP CONNECTOR #1
Processor
+ Marvell PXA270 Applications Processor
running at 416 or 520 MHz
EXP CONNECTOR #2
Flash Memory
+ 32 or 64 MB NOR standard
CONFIG
J TA G
MARVELL
PXA270
APPLICATIONS
PROCESSOR
U R AT
AC97 / I2S
TOUCHSCREEN
& AUDIO CODEC
SDRAM Memory
+ 64 MB SDRAM standard
DMA
INT
PERIPHERALS
ASYNC/SYNC BUS INTERFACE
POWER
IN
NOR or NAND
FLASH
Touch Screen
+ Integrated 4-wire touch screen controller
SDRAM
BUFFERS
CPLD
Display
+ Programmable color LCD controller
+ Built-in driver supports up to 800x600 with
16-bit LCD interface
RESETS
& POWER
MONITORING
ETHERNET
10/100 BASE-T
Network Support
+ 10/100 Base-T Ethernet controller for
application/debug (SMSC LAN 91C111)
SODIMM CONNECTOR
Audio
+ AC97audio codec
PXA270 Card Engine Ordering Information
Speed SDRAM
(MHz)
(MB)
NAND Flash NOR Flash
(MB)
(MB)
Touch
Audio Ethernet
CENGPXA270-416-11-505EXR
416
64
Y
Y
-25 – 85
CENGPXA270-416-11-505HXR
416
64
Y
Y
Y
-25 – 85
520
64
Y
Y
Y
0 – 70
Logic PD Model Number
Temp
(°C)
PXA270 ZOOM SDK Ordering Information
SOM Configuration
Recommended Resale
$499
IrDA
+ SIR supports up to 115.2 Kbps, multiplexed
IrDA/Bluetooth
GPIO
+ Programmable I/O depending on peripheral
requirements
1. The SDK contains a PXA270-10 Card Engine; quantities are limited.
LOGIC PD WEBSITE :: DESIGN RESOURCES:
+ Logic
PD Products : www.logicpd.com/products
+ Logic
PD Technical Support : www.logicpd.com/product-support
+ For
USB
+ USB 2.0 full-speed host and device interface
Serial Ports
+ Three 16C550 compatible UARTs, two I2C
1
PC Card Expansion
+ CompactFlash Type I card (memory-mapped
mode only)
+ Smart Card, MMC/SD, dual PCMCIA
interfaces
more information contact Logic PD Sales : product.sales@logicpd.com
Software
+ LogicLoader™ (bootloader/monitor)
+ Windows Embedded CE 5.0 BSP
Mechanical
+ 60.2 mm wide x 67.8 mm long x 4.4 mm high
RoHS Compliant
411 N. Washington Ave. Suite 400 Minneapolis, MN 55401
T : 612.672.9495 F : 612.672.9489 I : www.logicpd.com
© 2011 Logic Product Development Company. All rights reserved.
PN: 1001781 Rev E
CENGPXA270-520-11-504HCR 价格&库存
很抱歉,暂时无法提供与“CENGPXA270-520-11-504HCR”相匹配的价格&库存,您可以联系我们找货
