CENGLH79524-10-450HC
    BEACONEMBEDDEDWORKS
    CARD ENGINE 64MB FLASH 32MB RAM
CENGLH79524-10-450HC 数据手册
WWW.LOGICPD.COM LH79524 CARD ENGINE The LH79524 Card Engine is a compact, product-ready hardware and software solution for developing embedded products with less time, less cost, less risk ... more innovation. CARD ENGINE ADVANTAGE Reduce TIme to Market → 6 to 9 month savings typical Product-Ready Hardware Platform Production Quality Software - Bootloader/Monitor The LH79524 Card Engine is a complete single board computer offering essential features for handheld and embedded networking applications in the industrial, consumer, and medical markets. The use of custom base boards makes the Card Engine the ideal foundation for OEMs developing handheld and compact products. The Card Engine provides a common reference pin-out on its expansion connectors, which enables customers to easily scale to next generation microcontroller Card Engines when new functionality or performance is required. - Board Support Packages - Supports other operating systems Engineering Support LH79524 Card Engine Custom Base Board Final Product Actual Size (2.37” x 2.67”) ORDERING INFORMATION Zoom Starter Development Kit (Model # SDK-LH79524-10-3216) TM CUSTOMER SUPPORT Logic provides technical support for Application Development Kits. Various support packages are available; contact us for more information. CONTACT For more information on our EmbeddedProduct Solutions, please contact Logic Sales at www.logicpd.com or 612.672.9495. APPLICATION DEVELOPMENT KITS Processor Sharp LH79524 32 bit ARM720T RISC processor running up to 77.414 MHz SDRAM Memory Up to 64 Mbytes Flash Memory NOR or NAND - 0 or 16 Mbytes NOR - 0, 64, or 128 Mbytes NAND Display Programmable color LCD controller - Built in driver supports up to 800 x 600 x 16 bit color - Supports STN, Color STN, HR-TFT, AD-TFT, TFT Touch Screen Processor Integrated Network Support 10/100 BASE-T Ethernet controller (application/debug) Audio Stereo Output Audio CODEC (TI TLV320DAC23) PC Card Expansion Compact Flash type 1 card (memory mode only) Serial Ports 2 X 16C550 like, standard UARTS IrDA SIR supports up to 115.2 Kbps GPIO Programmable depending on peripheral requirements SSP Supports either Motorola SPITM, National Semiconductor MICROWIRETM, TI SSI USB 2.0 Full Speed One Device Software - LogicLoaderTM (bootloader/monitor) Mechanical - Compact Size: 2.37”(60.2 mm) long x 2.67”(67.8 mm) wide x 0.17”(4.4 mm) high - 144 pin SODIMM connector for connection to custom peripheral board - Two high density 80-pin expansion connectors for peripheral access Application Development Kits - ZoomTM Starter Development Kit (Model # SDK-LH79524-10-3216) BSPS & SOFTWARE SYSTEM ON MODULES PRODUCT DEVELOPMENT SERVICES © 2004 LOGIC PRODUCT DEVELOPMENT 411 WASHINGTON AVE N SUITE 101 MINNEAPOLIS MN 55401 TEL:612.672.9495 FAX: 612.672.9489 WWW.LOGICPD.COM PN: 1000990 Rev B WWW.LOGICPD.COM System on Module Block Diagram EXP CONNECTOR #1 The Card Engine CPLD provides the following functionality: EXP CONNECTOR #2 - SPI interface to onboard EEPROMS and Audio Codec - CF Card Support (memory mode only) - ISA-like bus interface - Buffer control logic - Chip select decoder logic - Interrupt encoder logic - Flash program control logic - Processor mode control logic - IC code revision register - Additional GPIO - Status indicator signals - On-board power management signals - Memory mapped NAND flash controller CONFIG J TA G CONTROLLER UART LH79524 ASYNC/SYNC BUS INTERFACE CPLD POWER IN AUDIO CODEC DMA TOUCHSCREEN INT PERIPHERALS (optional) RES ETS & POWER MONITORING 16-64Mb SDRAM BUFFERS The CPLD code is available free of charge for customers designing the Card Engine into their final product or for purchase if implementing in a custom board solution. ETHERNET 0-32Mb FLASH 10/100 Base -T (optional) Please contact Logic Sales at product.sales@logicpd.com for more information. 144 Pin SODIMM CONNECTOR Actual size (60.2mm x 67.8 mm) Standard Configurations for LH79524 Logic Model Number SDRAM Nor Flash (MB) NAND Flash (MB) Ethernet Audio Touch Temp. Rating CENGLH79524-10-403HC 32 16 - Y Y Y 0-70 deg C CENGLH79524-10-402HC 32 8 - Y Y Y 0-70 deg C CENGLH79524-10-450HC* 32 - 64 Y Y Y 0-70 deg C *Please contact Logic for custom configurations and availability System on Module Advantage: Less time, less cost, less risk ... More Innovation Zoom™ Starter Development Kit (SDK) SDKs simplify: Application specific code development Evaluation of the MCU / System on Module The transfer of application code, OS and BSPs into production APPLICATION DEVELOPMENT KITS Card Engine (with common footprint) Card Engine complete with: Board Support Packages (Windows CE, Linux, and other RTOS) Custom Baseboard (with Card Engine) Baseboard provides: Power Connectors Custom peripherals Custom form factor Final Product Final Product results: Accelerated time to market Reduced development cost Customer focuses on core competencies Bootloader provides infield device management, manufacturing, and test capabilities BSPS & SOFTWARE SYSTEM ON MODULES PRODUCT DEVELOPMENT SERVICES © 2004 LOGIC PRODUCT DEVELOPMENT 411 WASHINGTON AVE N SUITE 101 MINNEAPOLIS MN 55401 TEL:612.672.9495 FAX: 612.672.9489 WWW.LOGICPD.COM PN: 1000990 Rev B
CENGLH79524-10-450HC 价格&库存
很抱歉,暂时无法提供与“CENGLH79524-10-450HC”相匹配的价格&库存,您可以联系我们找货
