65440R
65440R
    ECHELON
    模块
    IZOT U60 FT NETWORK INTERFACE MO
65440R 数据手册
® IzoTTM U60 FT Network Interface Module USB interface to LonTalk®/IP-FT and LonWorks®-FT free topology twisted pair networks IzoT U60 Key Features • Provides a USB 2.0 to LonTalk/IP-FT or LonWorks-FT interface for any controller or device • Compatible with hosts implementing the IzoT Device Stack EX or IzoT Device Stack DX • Source code is available as a free download for a Linux-compatible driver • Compact 72mm x 29mm (2.8” x 1.1”) board-level form-factor with 2.54mm (0.1”) center pin headers for simple integration • Pin-header USB interface to the host • Pin-header network connector • On-board transmit and receive indicators; signals provided for driving host indicators • On-board service indicator; signal provides for driving a host Service indicator • Powered by a 3.3VDC input USB Network Interface Add a LonTalk/IP-FT or LonWorks-FT interface to your controller. The IzoT U60 FT Network Interface Module is a compact 72mm x 29mm (2.8” x 1.1”) board-level module with USB interface that can be easily integrated into any controller or device. The U60 FT module is compatible with the LonTalk Device Stack DX and LonTalk Device Stack EX which provide source code for LonTalk/IP and native LonWorks compatible protocol stacks. On-board Tx and Rx LEDs provide an indication of FT packet transmission and reception. The Tx and Rx signals are provided on the U60 connector so that the host controller can provide transmit and receive indicators. An on-board Service LED provides an indication of the status of the U60 module. The Service signal is provided on the U60 connector so that the host controller can provide a network Service indicator. Three 2.54mm (0.1”) center pin-header connectors are provided by the FT network, USB, power input, transmit/receive signals, and service signal. Pin assignments are listed in the following tables. www.echelon.com ® • JP1 Pin Assignment • Pin Number • Signal Name • 1 • Do Not Connect • 2 • USB - • 3 • USB + • 4 • Ground • JP3 Pin Assignment • Pin Number • Signal Name • 1 • +3.3V In • 2 • Tx LED Out • 3 • Rx LED Out • 4 • Service • 5 • Ground • 6 • Reset • JPX5 Pin Assignment • Pin Number • Signal Name Specifications Temperature Hardware Platform -10°C to +70°C (operating and nonoperating) Dimensions Humidity 72mm x 29mm x 13mm (2.8” x 1.1” x 0.5”) 10% to 95% RH @ 50°C Processor EMC • 1 • FT Network B Echelon FT 6050 Smart Transceiver • 2 • FT Network A FCC Part 15 Class A compliant Processor System Clock • 3 • Do Not Connect EN55022 Class A and EN55024 compliant 80 MHz CISPR 22 Class A compliant • 4 • Do Not Connect Connectors LonTalk/IP-FT and LONWORKS-FT (ISO/ IEC 14908-2) network pin header USB 2.0 pin header Host Interface The interface to the host is provided via the USB interface. The host selects whether the interface is a Layer 2 or Layer 5 interface. Source code for a Linux-compatible driver is available as a free download. Service, Tx/RX signal, and +3.3V input pin header Indicators Service LED FT Tx/Rx LEDs Operating Input Voltage Software Platform Interface LonTalk/IP or LonWorks-FT with a Layer 2 or Layer 5 interface Driver Linux source code for a U60 network driver is available as a free download Ordering Information Model 65440R U60 FT Network Interface Module 3.3VDC Operating Input Current 110mA maximum © 2014 Echelon, LonWorks, LonTalk, and the Echelon logo are trademarks of Echelon Corporation registered in the United States and other countries. IzoT is a trademark of Echelon Corporation. www.echelon.com
65440R 价格&库存
很抱歉,暂时无法提供与“65440R”相匹配的价格&库存,您可以联系我们找货
