74HC4316; 74HCT4316
Quad single-pole single-throw analog switch
Rev. 6 — 10 September 2021
Product data sheet
1. General description
The 74HC4316; 74HCT4316 is a quad single pole, single throw analog switch (SPST). Each switch
features two input/output terminals (nY and nZ) and an active HIGH enable input (nS). When nS
is LOW, the analog switch is turned off. When E is HIGH all four analog switches are turned off.
Inputs include clamp diodes. This enables the use of current limiting resistors to interface inputs to
voltages in excess of VCC.
2. Features and benefits
CMOS low power dissipation
High noise immunity
Input levels E and nS inputs:
• For 74HC4316: CMOS level
• For 74HCT4316: TTL level
Low ON resistance:
• 160 Ω (typical) at VCC - VEE = 4.5 V
• 120 Ω (typical) at VCC - VEE = 6.0 V
• 80 Ω (typical) at VCC - VEE = 9.0 V
Logic level translation:
• To enable 5 V logic to communicate with ±5 V analog signals
Typical break-before-make built in
Latch-up performance exceeds 100 mA per JESD 78 Class II Level B
Complies with JEDEC standards:
• JESD8C (2.7 V to 3.6 V)
• JESD7A (2.0 V to 6.0 V)
ESD protection:
• HBM JESD22-A114F exceeds 2000 V
• MM JESD22-A115-A exceeds 200 V
Specified from -40 °C to +85 °C and -40 °C to +125 °C
3. Applications
Signal gating
Modulation
Demodulation
Chopper
74HC4316; 74HCT4316
Nexperia
4. Ordering information
Table 1. Ordering information
Type number Package
74HC4316D
Temperature range Name
Description
Version
-40 °C to +125 °C
SO16
plastic small outline package; 16 leads; body width 3.9 mm SOT109-1
-40 °C to +125 °C
TSSOP16 plastic thin shrink small outline package; 16 leads;
body width 4.4 mm
74HCT4316D
74HC4316PW
74HCT4316PW
SOT403-1
5. Functional diagram
7
7
G1
2
15
5
6
14
1Y
1Z
1S
2Y
2S
2Z
3Y
3S
3Z
4S
4Y
4Z
E
2
1
15 #
1
1
3
3
4
5#
4
1
10
6#
10
12
12
13
14 #
2
1X2
3
4
11
10
13
12
13
14 #
1
(a)
(b)
aaa-024847
aaa-024846
Fig. 1.
1
6#
1
7
2
5#
11
11
2
15 #
G1
Logic symbol
Fig. 2.
IEC logic symbol
VCC
16
1 1Z
1S 15
2 1Y
4 2Z
2S 5
3 2Y
3S 6
LOGIC LEVEL
CONVERSION
AND CONTROL
10 3Z
11 3Y
13 4Z
4S 14
12 4Y
E 7
Fig. 3.
8
9
GND
VEE
aaa-024848
Functional diagram
74HC_HCT4316
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2021. All rights reserved
2 / 23
74HC4316; 74HCT4316
Nexperia
nY
VCC
E
LOGIC LEVEL
CONVERSION
nS
LOGIC LEVEL
CONVERSION
VEE
VEE
VCC
VCC
VEE
nZ
Fig. 4.
aaa-024850
Schematic diagram (one switch)
6. Pinning information
6.1. Pinning
74HC4316
74HCT4316
1Z
1
16 VCC
1Y
2
15 1S
2Y
3
14 4S
2Z
4
13 4Z
2S
5
12 4Y
3S
6
11 3Y
E
7
10 3Z
GND
8
9
74HC4316
74HCT4316
VEE
1Z
1
1Y
2
16 VCC
15 1S
2Y
3
14 4S
2Z
4
13 4Z
2S
5
12 4Y
3S
6
11 3Y
E
7
10 3Z
GND
8
9
aaa-024851
Fig. 5.
VEE
aaa-024852
Pin configuration SOT109-1 (SO16)
Fig. 6.
Pin configuration SOT403-1 (TSSOP16)
6.2. Pin description
Table 2. Pin description
Symbol
Pin
Description
1Z, 2Z, 3Z, 4Z
1, 4, 10, 13
independent input or output
1Y, 2Y, 3Y, 4Y
2, 3, 11, 12
E
7
enable input (active LOW)
GND
8
ground (0 V)
VEE
9
negative supply voltage
1S, 2S, 3S, 4S
15, 5, 6, 14
select input (active HIGH)
VCC
14
positive supply voltage
74HC_HCT4316
Product data sheet
3 / 23
74HC4316; 74HCT4316
Nexperia
7. Functional description
Table 3. Function table
H = HIGH voltage level; L = LOW voltage level; X = don’t care.
Input
Switch
E
nS
L
L
OFF
L
H
ON
H
X
OFF
8. Limiting values
Table 4. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
Min
Max
Unit
VCC
supply voltage
IIK
input clamping current
VI < -0.5 V or VI > VCC + 0.5 V
-0.5
+11.0
V
±20
mA
ISK
switch clamping current
VSW < -0.5 V or VSW > VCC + 0.5 V
±20
mA
ISW
switch current
VSW = -0.5 V to VCC + 0.5 V
±25
mA
IEE
supply current
mA
ICC
IGND
supply current
50
mA
ground current
-50
mA
Tstg
storage temperature
-65
+150
°C
Ptot
total power dissipation
Tamb = -40 °C to +125 °C
500
mW
P
power dissipation
per switch
100
mW
[1]
[2]
Conditions
[1]
[2]
To avoid drawing VCC current out of terminal nZ, when switch current flows in terminals nY, the voltage drop across the bidirectional
switch must not exceed 0.4 V. If the switch current flows into terminal nZ, no VCC current will flow out of terminals nY. In this case there
is no limit for the voltage drop across the switch, but the voltages at nY and nZ may not exceed VCC or VEE.
For SOT109-1 (SO16) package: Ptot derates linearly with 12.4 mW/K above 110 °C.
For SOT403-1 (TSSOP16) package: Ptot derates linearly with 8.5 mW/K above 91 °C.
9. Recommended operating conditions
Table 5. Recommended operating conditions
Symbol Parameter
Conditions
VCC
supply voltage
74HC4316
74HCT4316
Unit
Min
Typ
Max
Min
Typ
Max
VCC - GND
2.0
5.0
10.0
4.5
5.0
5.5
V
VEE - GND
2.0
5.0
10.0
2.0
5.0
10.0
V
VCC
GND
VCC
V
see Fig. 7 and Fig. 8
VI
input voltage
GND
VSW
switch voltage
VEE
VCC
VEE
VCC
V
Tamb
ambient temperature
-40
+25
+125
-40
+25
+125
°C
Δt/ΔV
input transition rise
and fall rate
VCC = 2.0 V
625
ns/V
VCC = 4.5 V
1.67
139
1.67
139
ns/V
VCC = 6.0 V
83
ns/V
VCC = 10.0 V
35
ns/V
74HC_HCT4316
Product data sheet
4 / 23
74HC4316; 74HCT4316
Nexperia
001aad545
10
VCC - GND
(V)
001aad546
10
VCC - GND
(V)
8
8
6
6
operating area
operating area
4
4
2
2
Fig. 7.
4
6
Guaranteed operating area as a function of the
supply voltages for 74HC4316
74HC_HCT4316
Product data sheet
10
VCC - VEE (V)
Fig. 8.
4
6
8
10
VCC - VEE (V)
supply voltages for 74HCT4316
5 / 23
74HC4316; 74HCT4316
Nexperia
10. Static characteristics
Table 6. RON resistance per switch for types 74HC4316 and 74HCT4316
VI = VIH or VIL; for test circuit see Fig. 9.
Vis is the input voltage at a nY or nZ terminal, whichever is assigned as an input.
Vos is the output voltage at a nY or nZ terminal, whichever is assigned as an output.
For 74HC4316: VCC - GND or VCC - VEE = 2.0 V, 4.5 V, 6.0 V and 9.0 V.
For 74HCT4316: VCC - GND = 4.5 V and 5.5 V; VCC - VEE = 2.0 V, 4.5 V, 6.0 V and 9.0 V.
Symbol
Parameter
Conditions
25 °C
Max
Min
Max
Min
Max
Ω
VCC = 4.5 V; VEE = 0 V;
ISW = 1000 μA
160
320
400
480
Ω
VCC = 6.0 V; VEE = 0 V;
ISW = 1000 μA
120
240
300
360
Ω
VCC = 4.5 V; VEE = -4.5 V;
ISW = 1000 μA
85
170
215
255
Ω
160
Ω
ISW = 1000 μA
80
160
200
240
Ω
ISW = 1000 μA
70
140
175
210
Ω
ISW = 1000 μA
60
120
150
180
Ω
VCC = 2.0 V; VEE = 0 V;
ISW = 100 μA
170
Ω
ISW = 1000 μA
90
180
225
270
Ω
ISW = 1000 μA
80
160
200
240
Ω
ISW = 1000 μA
65
135
170
205
Ω
ON resistance Vis = VEE
(rail)
ISW = 100 μA
Vis = VCC
ΔRON
[1]
[1]
[1]
ON resistance Vis = VCC to VEE
mismatch
between
channels
[1]
-40 °C to +125 °C Unit
Typ
RON(peak) ON resistance Vis = VCC to VEE
(peak)
ISW = 100 μA
RON(rail)
-40 °C to +85 °C
[1]
Ω
16
Ω
9
Ω
6
Ω
When supply voltages (VCC - VEE) near 2.0 V the analog switch ON resistance becomes extremely non-linear. When using a supply of
2 V, it is recommended to use these devices only for transmitting digital signals.
74HC_HCT4316
Product data sheet
6 / 23
74HC4316; 74HCT4316
Nexperia
aaa-024854
200
RON
(Ω)
Vsw
VCC = 4.5 V
V
VCC
nS
VIH
VIL
nY
Vis
VCC = 6.0 V
100
E
VCC = 9.0 V
nZ
GND
VEE
Isw
aaa-024853
Vis = 0 V to (VCC - VEE)
Vis (V)
10
Fig. 9.
Test circuit for measuring RON
Fig. 10. Typical RON as a function of input voltage Vis
Table 7. Static characteristics 74HC4316
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Conditions
Min
Typ
Max
Unit
VCC = 2.0 V
1.5
1.2
V
VCC = 4.5 V
3.15
2.4
V
VCC = 6.0 V
4.2
3.2
V
VCC = 9.0 V
6.3
4.3
V
VCC = 2.0 V
0.8
0.5
V
VCC = 4.5 V
2.1
1.35
V
VCC = 6.0 V
2.8
1.8
V
VCC = 9.0 V
4.3
2.7
V
±0.1
μA
VCC = 10.0 V; VEE = 0 V
Tamb = 25 °C
VIH
VIL
II
HIGH-level input voltage
LOW-level input voltage
input leakage current
VI = VCC or GND
±0.2
μA
IS(OFF)
OFF-state leakage current
VCC = 10.0 V; VEE = 0 V; VI = VIH or VIL;
|VSW| = VCC - VEE; see Fig. 11
±0.1
μA
IS(ON)
ON-state leakage current
|VSW| = VCC - VEE; see Fig. 12
±0.1
μA
ICC
supply current
VI = VCC or GND; Vis = VEE or VCC;
Vos = VCC or VEE
8.0
μA
16.0
μA
CI
input capacitance
3.5
pF
Csw
switch capacitance
5
pF
74HC_HCT4316
Product data sheet
7 / 23
74HC4316; 74HCT4316
Nexperia
Symbol Parameter
Conditions
Min
Typ
Max
Unit
VCC = 2.0 V
1.5
V
VCC = 4.5 V
3.15
V
VCC = 6.0 V
4.2
V
VCC = 9.0 V
6.3
V
VCC = 2.0 V
0.5
V
VCC = 4.5 V
1.35
V
VCC = 6.0 V
1.8
V
VCC = 9.0 V
2.7
V
±1.0
μA
±2.0
μA
Tamb = -40 °C to +85 °C
VIH
VIL
II
VI = VCC or GND
IS(OFF)
±1.0
μA
IS(ON)
±1.0
μA
ICC
supply current
Vos = VCC or VEE
80.0
μA
160.0 μA
VCC = 2.0 V
1.5
V
VCC = 4.5 V
3.15
V
VCC = 6.0 V
4.2
V
VCC = 9.0 V
6.3
V
VCC = 2.0 V
0.5
V
VCC = 4.5 V
1.35
V
VCC = 6.0 V
1.8
V
VCC = 9.0 V
2.7
V
±1.0
μA
VIH
VIL
II
VI = VCC or GND
±2.0
μA
IS(OFF)
±1.0
μA
IS(ON)
±1.0
μA
ICC
supply current
Vos = VCC or VEE
160
μA
320
μA
74HC_HCT4316
Product data sheet
8 / 23
74HC4316; 74HCT4316
Nexperia
Table 8. Static characteristics 74HCT4316
Symbol Parameter
Conditions
Min
Typ
Max
Unit
V
Tamb = 25 °C
VIH
VCC = 4.5 V to 5.5 V
2.0
1.6
VIL
1.2
0.8
V
II
VI = VCC or GND; VCC = 5.5 V; VEE = 0 V
±0.1
μA
IS(OFF)
VCC = 10 V; VEE = 0 V; VI = VIH or VIL;
±0.1
μA
IS(ON)
±0.1
μA
ICC
supply current
Vos = VCC or VEE
8.0
μA
VCC = 5.0 V; VEE = -5.0 V
16.0
μA
50
180
μA
ΔICC
additional supply current
nS and E; per input pin; VI = VCC - 2.1 V;
other inputs at VCC or GND;
VCC = 4.5 V to 5.5 V; VEE = 0 V
CI
input capacitance
3.5
pF
Csw
switch capacitance
5
pF
V
VIH
2.0
VIL
0.8
V
II
±1.0
μA
IS(OFF)
±1.0
μA
IS(ON)
±1.0
μA
ICC
supply current
Vos = VCC or VEE
80
μA
160
μA
225
μA
ΔICC
74HC_HCT4316
Product data sheet
9 / 23
74HC4316; 74HCT4316
Nexperia
Symbol Parameter
Conditions
Min
Typ
Max
Unit
V
VIH
2.0
VIL
0.8
V
II
±1.0
μA
IS(OFF)
±1.0
μA
IS(ON)
±1.0
μA
ICC
supply current
Vos = VCC or VEE
160
μA
320
μA
245
μA
ΔICC
nS
VIL
VIH
VCC
VIH
E
Isw
A
Vis
nS
nY
nZ
GND
VEE
VIL
Isw
A
E
Isw
A
Vos
VCC
Vis
nY
nZ
GND
aaa-024855
Vis = VCC and Vos = VEE
Vis = VEE and Vos = VCC
Product data sheet
VEE
aaa-024856
Vis = VCC and Vos = open
Vis = VEE and Vos = open
Fig. 11. Test circuit for measuring OFF-state leakage
current
74HC_HCT4316
Vos
Fig. 12. Test circuit for measuring ON-state leakage
current
10 / 23
74HC4316; 74HCT4316
Nexperia
11. Dynamic characteristics
Table 9. Dynamic characteristics
GND = 0 V; tr = tf = 6 ns; CL = 50 pF unless specified otherwise; for test circuit see Fig. 15.
Symbol Parameter
Conditions
25 °C
-40 °C to +85 °C -40 °C to +125 °C Unit
Typ
Max
Min
Max
Min
Max
17
60
75
90
ns
6
12
15
18
ns
5
10
13
15
ns
4
8
10
12
ns
63
220
275
330
ns
23
44
55
66
ns
VCC = 5.0 V; VEE = 0 V;CL = 15 pF
ns
18
37
47
56
ns
21
39
49
59
ns
55
175
220
265
ns
44
53
ns
VCC = 5.0 V; VEE = 0 V; CL = 15 pF
16
ns
16
30
37
45
ns
18
36
45
54
ns
61
205
255
310
ns
22
41
51
62
ns
19
ns
18
35
43
53
ns
19
37
47
56
ns
52
175
220
265
ns
19
35
44
53
ns
16
ns
15
30
37
45
ns
17
34
43
51
ns
pF
74HC4316
tpd
toff
propagation nY to nZ or nZ to nY; RL = ∞ Ω;
see Fig. 13
delay
turn-off time E to nY or nZ; see Fig. 14
[1]
[2]
nS to nY or nZ; see Fig. 14
ton
turn-on time E to nY or nZ; see Fig. 14
CPD
power
per switch; VI = GND to VCC
dissipation
capacitance
74HC_HCT4316
Product data sheet
[2]
[3]
[3]
[4] 13
11 / 23
74HC4316; 74HCT4316
Nexperia
Symbol Parameter
Conditions
25 °C
Typ
Max
Min
Max
Min
Max
6
12
15
18
ns
4
8
10
12
ns
22
44
55
66
ns
19
ns
21
42
53
63
ns
53
60
ns
17
ns
17
34
43
51
ns
28
56
70
84
ns
24
ns
21
42
53
63
ns
25
50
63
75
ns
21
ns
17
34
43
51
ns
25
50
63
75
ns
21
ns
23
46
58
69
ns
22
44
55
66
ns
19
ns
50
60
ns
pF
74HCT4316
see Fig. 13
delay
tpd
tPZH
[1]
OFF-state
to HIGH
propagation
delay
OFF-state
to LOW
propagation
delay
tPZL
toff
CPD
[1]
[2]
[3]
[4]
power
per switch; VI = GND to (VCC - 1.5 V)
dissipation
capacitance
[2]
[2]
[4] 14
tpd is the same as tPHL and tPLH.
toff is the same as tPHZ and tPLZ.
ton is the same as tPZH and tPZL.
CPD is used to determine the dynamic power dissipation (PD in μW).
2
2
PD = CPD x VCC x fi + ∑((CL + Csw) x VCC x fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
2
∑((CL + Csw) x VCC x fo) = sum of outputs;
CL = output load capacitance in pF;
Csw = switch capacitance in pF;
VCC = supply voltage in V.
74HC_HCT4316
Product data sheet
12 / 23
74HC4316; 74HCT4316
Nexperia
11.1. Waveforms and test circuit
50 %
Vis input
tPLH
tPHL
50 %
Vos output
001aad555
Fig. 13. Input (Vis) to output (Vos) propagation delays
VI
VM
nS, E input
0V
tPLZ
tPZL
50 %
Vos output
10 %
tPHZ
tPZH
90 %
50 %
Vos output
switch ON
switch OFF
switch ON
aaa-024857
Measurement points are shown in Table 10.
Fig. 14. Turn-on and turn-off times
Table 10. Measurement points
Type
VI
VM
74HC4316
VCC
0.5VCC
74HCT4316
3.0 V
1.3 V
74HC_HCT4316
Product data sheet
13 / 23
74HC4316; 74HCT4316
Nexperia
tW
VI
90 %
negative
pulse
VM
VM
10 %
0V
VI
tf
tr
tr
tf
90 %
VM
positive
pulse
VM
10 %
0V
tW
VCC Vis
PULSE
GENERATOR
VI
DUT
VCC
Vos
RT
RL
S1
open
CL
GND
VEE
aaa-024858
Test data is given in Table 11.
Definitions test circuit:
RT = Termination resistance should be equal to output impedance Zo of the pulse generator.
CL = Load capacitance including jig and probe capacitance.
RL = Load resistance.
S1 = Test selection switch.
Fig. 15. Test circuit for measuring switching times
Table 11. Test data
Test
Input
E
Output
nS
Switch nY (nZ) tr, tf
S1 position
Switch nZ (nY)
Vis
at fmax
other [1]
CL
RL
tPHL, tPLH [2]
GND to VCC
< 2 ns
6 ns
50 pF
open
tPHZ, tPZH [2]
VCC
< 2 ns
6 ns
50 pF, 15 pF
1 kΩ
VEE
tPLZ, tPZL [2]
VEE
< 2 ns
6 ns
50 pF, 15 pF
1 kΩ
VCC
VI
[1]
[2]
tr = tf = 6 ns; when measuring fmax, there is no constraint to tr and tf with 50 % duty factor.
VI values:
For 74HC4316: VI = VCC
For 74HCT4316: VI = 3 V
74HC_HCT4316
Product data sheet
14 / 23
74HC4316; 74HCT4316
Nexperia
11.2. Additional dynamic characteristics
Table 12. Additional dynamic characteristics
Recommended conditions and typical values; GND = 0 V; Tamb = 25 °C; CL = 50 pF.
Symbol Parameter
Conditions
THD
fi = 1 kHz; RL = 10 kΩ; see Fig. 16
total harmonic
distortion
Min
Typ
Max
Unit
Vis = 4.0 V (p-p); VCC = 2.25 V; VEE = -2.25 V
0.80
Vis = 8.0 V (p-p); VCC = 4.5 V; VEE = -4.5 V
0.40
2.40
1.20
150
MHz
160
MHz
-50
dB
-50
dB
110
mV
220
mV
-60
dB
-60
dB
fi = 10 kHz; RL = 10 kΩ; see Fig. 16
f(-3dB)
RL = 50 Ω; CL = 10 pF; see Fig. 17
[1]
isolation (OFF-state) RL = 600 Ω; fi = 1 MHz; see Fig. 18
αiso
Vct
crosstalk voltage
Xtalk
[1]
[2]
-3 dB frequency
response
crosstalk
[2]
between digital input and switch (peak to peak value);
RL = 600 Ω; fi = 1 MHz; E or nS square wave between
VCC and GND; tr = tf = 6 ns; see Fig. 19
between switches; RL = 600 Ω; fi = 1 MHz; see Fig. 20 [2]
Adjust input voltage Vis to 0 dBm level at Vos for 1 MHz (0 dBm = 1 mW into 50 Ω).
Adjust input voltage Vis to 0 dBm level (0 dBm = 1 mW into 600 Ω).
nS
VIH
E
VIL
10 µF
Vis
VCC
nYn/nZ
nZ/nYn
VEE
GND
Vos
RL
CL
dB
aaa-024860
Fig. 16. Test circuit for measuring total harmonic distortion
74HC_HCT4316
Product data sheet
15 / 23
74HC4316; 74HCT4316
Nexperia
nS
VIH
E
VIL
Vis
VCC
0.1 µF
nYn/nZ
nZ/nYn
VEE
GND
Vos
RL
CL
dB
aaa-024861
VCC = 4.5 V; GND = 0 V; VEE = -4.5 V; RL = 50 Ω; RS = 1 kΩ.
a. Test circuit
aaa-024862
5
(dB)
10
102
103
104
105
fi (kHz)
106
b. Typical -3 dB frequency response
Fig. 17. -3 dB frequency response
74HC_HCT4316
Product data sheet
16 / 23
74HC4316; 74HCT4316
Nexperia
E
VIL
0.1 µF
Vis
VCC
nS
VIH
nYn/nZ
nZ/nYn
VEE
GND
Vos
RL
CL
dB
aaa-024861
VCC = 4.5 V; GND = 0 V; VEE = -4.5 V; RL = 600 Ω; RS = 1 kΩ.
a. Test circuit
001aae332
α iso
(dB)
- 20
- 40
- 60
- 80
- 100
102
10
103
104
105
fi (kHz)
106
b. Isolation (OFF-state) as a function of frequency
Fig. 18. Isolation (OFF-state) as a function of frequency
2RL
2RL
VCC
Vct
nS, E
nY
G
2RL
nZ
VEE
GND
2RL
oscilloscope
aaa-024863
Fig. 19. Test circuit for measuring crosstalk voltage (between the digital input and the switch)
74HC_HCT4316
Product data sheet
17 / 23
74HC4316; 74HCT4316
Nexperia
nS
VIH
E
VIL
Vis
0.1 µF
VCC
RL
nY/nZ
nZ/nY
VEE
nS
VIL
GND
RL
CL
VCC
E
VIH
nY/nZ
RL
nZ/nY
VEE
GND
Vos
RL
CL
dB
aaa-024864
Fig. 20. Test circuit for measuring crosstalk (between the switches)
74HC_HCT4316
Product data sheet
18 / 23
74HC4316; 74HCT4316
Nexperia
12. Package outline
SO16: plastic small outline package; 16 leads; body width 3.9 mm
SOT109-1
D
E
A
X
c
y
HE
v M A
Z
16
9
Q
A2
A
(A 3)
A1
pin 1 index
θ
Lp
1
L
8
e
w M
bp
detail X
5 mm
scale
DIMENSIONS (inch dimensions are derived from the original mm dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (1)
e
HE
L
Lp
Q
v
w
y
Z (1)
mm
1.75
0.25
0.10
1.45
1.25
0.25
0.49
0.36
0.25
0.19
10.0
9.8
4.0
3.8
1.27
6.2
5.8
1.05
1.0
0.4
0.7
0.6
0.25
0.25
0.1
0.7
0.3
inches
0.069
0.010 0.057
0.004 0.049
0.01
0.019 0.0100 0.39
0.014 0.0075 0.38
0.16
0.15
0.05
0.039
0.016
0.028
0.020
0.01
0.01
0.004
0.028
0.012
0.244
0.041
0.228
θ
o
8
o
Note
1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
SOT109-1
076E07
MS-012
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
Fig. 21. Package outline SOT109-1 (SO16)
74HC_HCT4316
Product data sheet
19 / 23
74HC4316; 74HCT4316
Nexperia
TSSOP16: plastic thin shrink small outline package; 16 leads; body width 4.4 mm
D
SOT403-1
E
A
X
c
y
HE
v M A
Z
9
16
Q
A2
pin 1 index
(A 3 )
A1
A
θ
Lp
1
L
8
detail X
w M
bp
e
5 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (2)
e
HE
L
Lp
Q
v
w
y
Z (1)
θ
mm
1.1
0.15
0.05
0.95
0.80
0.25
0.30
0.19
0.2
0.1
5.1
4.9
4.5
4.3
0.65
6.6
6.2
1
0.75
0.50
0.4
0.3
0.2
0.13
0.1
0.40
0.06
8o
0o
Notes
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
2. Plastic interlead protrusions of 0.25 mm maximum per side are not included.
OUTLINE
VERSION
SOT403-1
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-18
MO-153
Fig. 22. Package outline SOT403-1 (TSSOP16)
74HC_HCT4316
Product data sheet
20 / 23
74HC4316; 74HCT4316
Nexperia
13. Abbreviations
Table 13. Abbreviations
Acronym
Description
CMOS
Complementary Metal-Oxide Semiconductor
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
MM
Machine Model
TTL
Transistor-Transistor Logic
14. Revision history
Table 14. Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74HC_HCT4316 v.6
20210910
Product data sheet
74HC_HCT4316 v.5
Modifications:
74HC_HCT4316 v.5
20210310
Modifications:
74HC_HCT4316 v.4
20181016
Modifications:
Type number 74HC4316DB (SOT338-1/SSOP16) removed.
Section 2 updated.
Modifications:
Product data sheet
74HC_HCT4316 v.3
Product data sheet
74HC_HCT4316_CNV v.2
The format of this data sheet has been redesigned to comply with the new identity
guidelines of NXP Semiconductors.
Legal texts have been adapted to the new company name where appropriate.
Type numbers 74HC4316N and 74HCT4316N removed.
74HC_HCT4316_CNV v.2 19930901
Product data sheet
74HC_HCT4316 v.4
The format of this data sheet has been redesigned to comply with the identity guidelines of
Nexperia.
20170102
74HC_HCT4316
Section 8: Derating values for Ptot total power dissipation have changed.
Type number 74HCT4316DB (SOT338-1/SSOP16) removed.
74HC_HCT4316 v.3
Product data sheet
Product specification
21 / 23
74HC4316; 74HCT4316
Nexperia
15. Legal information
injury, death or severe property or environmental damage. Nexperia and its
suppliers accept no liability for inclusion and/or use of Nexperia products in
such equipment or applications and therefore such inclusion and/or use is at
the customer’s own risk.
Data sheet status
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Document status
[1][2]
Product
status [3]
Definition
Objective [short]
data sheet
Development
This document contains data from
the objective specification for
product development.
Preliminary [short]
data sheet
Qualification
the preliminary specification.
Product [short]
data sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the internet at https://www.nexperia.com.
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the relevant
full data sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental, punitive,
special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards customer
for the products described herein shall be limited in accordance with the
Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use — Nexperia products are not designed, authorized or
warranted to be suitable for use in life support, life-critical or safety-critical
systems or equipment, nor in applications where failure or malfunction
of an Nexperia product can reasonably be expected to result in personal
74HC_HCT4316
Product data sheet
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia accepts no liability for
any assistance with applications or customer product design. It is customer’s
sole responsibility to determine whether the Nexperia product is suitable
and fit for the customer’s applications and products planned, as well as
for the planned application and use of customer’s third party customer(s).
Customers should provide appropriate design and operating safeguards to
minimize the risks associated with their applications and products.
Nexperia does not accept any liability related to any default, damage, costs
or problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party
customer(s). Customer is responsible for doing all necessary testing for the
customer’s applications and products using Nexperia products in order to
avoid a default of the applications and the products or of the application or
use by customer’s third party customer(s). Nexperia does not accept any
liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified, the
product is not suitable for automotive use. It is neither qualified nor tested in
accordance with automotive testing or application requirements. Nexperia
accepts no liability for inclusion and/or use of non-automotive qualified
products in automotive equipment or applications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards,
customer (a) shall use the product without Nexperia’s warranty of the
product for such automotive applications, use and specifications, and (b)
whenever customer uses the product for automotive applications beyond
Nexperia’s specifications such use shall be solely at customer’s own risk,
and (c) customer fully indemnifies Nexperia for any liability, damages or failed
product claims resulting from customer design and use of the product for
automotive applications beyond Nexperia’s standard warranty and Nexperia’s
product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
22 / 23
74HC4316; 74HCT4316
Nexperia
Contents
1. General description...................................................... 1
2. Features and benefits.................................................. 1
3. Applications.................................................................. 1
4. Ordering information....................................................2
5. Functional diagram.......................................................2
6. Pinning information......................................................3
6.1. Pinning.........................................................................3
6.2. Pin description............................................................. 3
7. Functional description................................................. 4
8. Limiting values............................................................. 4
9. Recommended operating conditions..........................4
10. Static characteristics..................................................6
11. Dynamic characteristics...........................................11
11.1. Waveforms and test circuit.......................................13
11.2. Additional dynamic characteristics........................... 15
12. Package outline........................................................ 19
13. Abbreviations............................................................ 21
14. Revision history........................................................21
15. Legal information......................................................22
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 10 September 2021
74HC_HCT4316
Product data sheet
23 / 23
