HEF4052BT,013
HEF4052BT,013
    NEXPERIA(安世)
    SO16_9.9X3.9MM
    IC MUX/DEMUX DUAL 4CH 16SOIC
HEF4052BT,013 数据手册
HEF4052B Dual 4-channel analog multiplexer/demultiplexer Rev. 11 — 15 December 2021 Product data sheet 1. General description The HEF4052B is a dual single-pole quad-throw analog switch (2x SP4T) suitable for use in analog or digital 4:1 multiplexer/demultiplexer applications. Each switch features four independent inputs/outputs (nY0, nY1, nY2 and nY3) and a common input/output (nZ). A digital enable input (E) and two digital select inputs (S1 and S2) are common to both switches. When E is HIGH, the switches are turned off. Inputs include clamp diodes. This enables the use of current limiting resistors to interface inputs to voltages in excess of VDD. 2. Features and benefits • • • • • • • • • Wide supply voltage range from 3.0 V to 15.0 V CMOS low power dissipation High noise immunity Fully static operation 5 V, 10 V, and 15 V parametric ratings Standardized symmetrical output characteristics Complies with JEDEC standard JESD 13-B ESD protection: • HBM JESD22-A114F exceeds 2000 V • MM JESD22-A115-B exceeds 200 V Specified from -40 °C to +85 °C and -40 °C to +125 °C 3. Applications • • • Analog multiplexing and demultiplexing Digital multiplexing and demultiplexing Signal gating 4. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version HEF4052BT -40 °C to +125 °C SO16 plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 HEF4052BTT -40 °C to +125 °C TSSOP16 plastic thin shrink small outline package; 16 leads; body width 4.4 mm SOT403-1 HEF4052B Nexperia Dual 4-channel analog multiplexer/demultiplexer 5. Functional diagram VDD 16 13 12 14 S1 15 10 11 S2 9 LOGIC LEVEL CONVERSION 1 - OF - 4 DECODER 1 5 E 6 2 4 Fig. 1. 8 7 VSS VEE 3 1Z 1Y0 1Y1 1Y2 1Y3 2Y0 2Y1 2Y2 2Y3 2Z mnb042 Functional diagram nYn VDD VDD nZ VEE 001aak604 Fig. 2. Schematic diagram (one switch) HEF4052B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 11 — 15 December 2021 © Nexperia B.V. 2021. All rights reserved 2 / 18 HEF4052B Nexperia Dual 4-channel analog multiplexer/demultiplexer 10 9 13 1Z 0 3 G4 MDX 1Y1 14 9 S2 1Y2 15 1Y3 11 2 2Y0 1 3 2Y1 5 2Y2 2 2Y3 4 Logic symbol Product data sheet 12 4× S1 E 2Z 3 HEF4052B 1Y0 1 10 6 Fig. 3. 6 0 3 1 0 5 1 2 4 12 14 13 15 11 001aak605 mnb041 Fig. 4. IEC logic symbol All information provided in this document is subject to legal disclaimers. Rev. 11 — 15 December 2021 © Nexperia B.V. 2021. All rights reserved 3 / 18 HEF4052B Nexperia Dual 4-channel analog multiplexer/demultiplexer 1Z 1Y0 S1 LEVEL CONVERTER 1Y1 S2 LEVEL CONVERTER 1Y2 E LEVEL CONVERTER 1Y3 2Y0 2Y1 2Y2 2Y3 2Z 001aak634 Fig. 5. Logic diagram HEF4052B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 11 — 15 December 2021 © Nexperia B.V. 2021. All rights reserved 4 / 18 HEF4052B Nexperia Dual 4-channel analog multiplexer/demultiplexer 6. Pinning information 6.1. Pinning HEF4052B 2Y0 1 16 VDD 2Y2 2 15 1Y2 2Z 3 14 1Y1 2Y3 4 13 1Z 2Y1 5 12 1Y0 E 6 11 1Y3 VEE 7 10 S1 VSS 8 9 HEF4052B S2 2Y0 1 16 VDD 2Y2 2 15 1Y2 2Z 3 14 1Y1 2Y3 4 13 1Z 2Y1 5 12 1Y0 E 6 11 1Y3 VEE 7 10 S1 VSS 8 9 001aak606 001aag215 Fig. 6. S2 Pin configuration SOT109-1 (SO16) Fig. 7. Pin configuration SOT403-1 (TSSOP16) 6.2. Pin description Table 2. Pin description Symbol Pin Description E 6 enable input (active LOW) VEE 7 supply voltage VSS 8 ground supply voltage S1, S2 10, 9 select input 1Y0, 1Y1, 1Y2, 1Y3, 2Y0, 2Y1, 2Y2, 2Y3 12, 14, 15, 11, 1, 5, 2, 4 independent input or output 1Z, 2Z 13, 3 common output or input VDD 16 supply voltage 7. Function table Table 3. Function table H = HIGH voltage level; L = LOW voltage level; X = don’t care. Input Channel on E S2 S1 L L L nY0 to nZ L L H nY1 to nZ L H L nY2 to nZ L H H nY3 to nZ H X X switches off HEF4052B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 11 — 15 December 2021 © Nexperia B.V. 2021. All rights reserved 5 / 18 HEF4052B Nexperia Dual 4-channel analog multiplexer/demultiplexer 8. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to VSS = 0 V (ground). Symbol Parameter Min Max Unit VDD supply voltage -0.5 +18 V VEE supply voltage referenced to VDD -18 +0.5 V IIK input clamping current pins Sn and E; VI < -0.5 V, or VI > VDD + 0.5 V - ±10 mA VI input voltage -0.5 VDD + 0.5 II/O input/output current - ±10 mA IDD supply current - 50 mA Tstg storage temperature -65 +150 °C Tamb ambient temperature -40 +125 °C Ptot total power dissipation Tamb = -40 °C to +125 °C - 500 mW P power dissipation per output - 100 mW [1] [2] Conditions [1] [2] V To avoid drawing VDD current out of terminal Z, when switch current flows into terminals Y, the voltage drop across the bidirectional switch must not exceed 0.4 V. If the switch current flows into terminal Z, no VDD current will flow out of terminals Y, and in this case there is no limit for the voltage drop across the switch, but the voltages at Y and Z may not exceed VDD or VEE. For SOT109-1 (SO16) package: Ptot derates linearly with 12.4 mW/K above 110 °C. For SOT403-1 (TSSOP16) package: Ptot derates linearly with 8.5 mW/K above 91 °C. 9. Recommended operating conditions Table 5. Recommended operating conditions Symbol Parameter Conditions Min Typ Max Unit see Fig. 8 3 - 15 V VDD supply voltage VI input voltage 0 - VDD V Tamb ambient temperature in free air -40 - +125 °C Δt/ΔV input transition rise and fall rate VDD = 5 V - - 3.75 μs/V VDD = 10 V - - 0.5 μs/V VDD = 15 V - - 0.08 μs/V 001aac285 15 VDD - VSS (V) 10 operating area 5 0 Fig. 8. 0 5 10 VDD - VEE (V) 15 Operating area as a function of the supply voltages HEF4052B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 11 — 15 December 2021 © Nexperia B.V. 2021. All rights reserved 6 / 18 HEF4052B Nexperia Dual 4-channel analog multiplexer/demultiplexer 10. Static characteristics Table 6. Static characteristics VSS = VEE = 0 V; VI = VSS or VDD, unless otherwise specified. Symbol Parameter VIH VIL HIGH-level input voltage LOW-level input voltage II input leakage current IS(OFF) OFF-state leakage current IDD CI Conditions Tamb = -40 °C Tamb = +25 °C Tamb = +85 °C Tamb = +125 °C Unit Min Max Min Max Min Max Min Max 3.5 - 3.5 - 3.5 - 3.5 - V 10 V 7.0 - 7.0 - 7.0 - 7.0 - V 15 V 11.0 - 11.0 - 11.0 - 11.0 - V 5V - 1.5 - 1.5 - 1.5 - 1.5 V 10 V - 3.0 - 3.0 - 3.0 - 3.0 V 15 V - 4.0 - 4.0 - 4.0 - 4.0 V 15 V - ±0.1 - ±0.1 - ±1.0 - ±1.0 μA Z port; 15 V all channels OFF; see Fig. 9 - - - 1000 - - - - nA Y port; per channel; see Fig. 10 15 V - - - 200 - - - - nA 5V - 5 - 5 - 150 - 150 μA 10 V - 10 - 10 - 300 - 300 μA 15 V - 20 - 20 - 600 - 600 μA - - - - 7.5 - - - - pF 5V |IO| < 1 μA |IO| < 1 μA supply current IO = 0 A input capacitance VDD Sn, E inputs 10.1. Test circuits VDD S1 and S2 VDD or VSS nZ nYn E IS VSS = VEE VDD VO VI 001aak635 Fig. 9. Test circuit for measuring OFF-state leakage current Z port HEF4052B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 11 — 15 December 2021 © Nexperia B.V. 2021. All rights reserved 7 / 18 HEF4052B Nexperia Dual 4-channel analog multiplexer/demultiplexer VDD VDD or VSS S1 and S2 nY0 1 nZ nYn 2 switch IS E VSS = VEE VSS VI VO 001aak636 Fig. 10. Test circuit for measuring OFF-state leakage current nYn port 10.2. On resistance Table 7. ON resistance Tamb = 25 °C; ISW = 200 μA; VSS = VEE = 0 V. Symbol Parameter Conditions VDD - VEE Typ Max Unit RON(peak) ON resistance (peak) VI = 0 V to VDD - VEE; see Fig. 11 and Fig. 12 5V 350 2500 Ω 10 V 80 245 Ω 15 V 60 175 Ω 5V 115 340 Ω 10 V 50 160 Ω 15 V 40 115 Ω 5V 120 365 Ω 10 V 65 200 Ω 15 V 50 155 Ω 5V 25 - Ω 10 V 10 - Ω 15 V 5 - Ω RON(rail) ON resistance (rail) VI = 0 V; see Fig. 11 and Fig. 12 VI = VDD - VEE; see Fig. 11 and Fig. 12 ΔRON ON resistance mismatch between channels VI = 0 V to VDD - VEE; see Fig. 11 10.2.1. On resistance waveform and test circuit V VDD VDD or VSS VSW S1 and S2 nZ nYn E VSS = VEE VSS ISW VI 001aak637 RON = VSW / ISW. Fig. 11. Test circuit for measuring RON HEF4052B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 11 — 15 December 2021 © Nexperia B.V. 2021. All rights reserved 8 / 18 HEF4052B Nexperia Dual 4-channel analog multiplexer/demultiplexer 001aae648 400 RON (Ω) VDD = 5 V 300 200 10 V 100 0 15 V 0 5 10 VI (V) 15 Fig. 12. Typical RON as a function of input voltage 11. Dynamic characteristics Table 8. Dynamic characteristics Tamb = 25 °C; VSS = VEE = 0 V; for test circuit see Fig. 16. Symbol Parameter Conditions tPHL HIGH to LOW propagation delay nYn, nZ to nZ, nYn; see Fig. 13 Sn to nYn, nZ; see Fig. 14 tPLH LOW to HIGH propagation delay Yn, nZ to nZ, nYn; see Fig. 13 Sn to nYn, nZ; see Fig. 14 tPHZ tPZH tPLZ tPZL HIGH to OFF-state propagation delay OFF-state to HIGH propagation delay LOW to OFF-state propagation delay OFF-state to LOW propagation delay HEF4052B Product data sheet E to nYn, nZ; see Fig. 15 E to nYn, nZ; see Fig. 15 E to nYn, nZ; see Fig. 15 E to nYn, nZ; see Fig. 15 All information provided in this document is subject to legal disclaimers. Rev. 11 — 15 December 2021 VDD Typ Max 5V 10 20 ns 10 V 5 10 ns 15 V 5 10 ns 5V 150 305 ns 10 V 65 135 ns 15 V 50 100 ns 5V 10 20 ns 10 V 5 10 ns 15 V 5 10 ns 5V 150 300 ns 10 V 75 150 ns 15 V 50 100 ns 5V 95 190 ns 10 V 90 180 ns 15 V 85 180 ns 5V 130 260 ns 10 V 55 115 ns 15 V 45 85 ns 5V 100 205 ns 10 V 90 180 ns 15 V 90 180 ns 5V 120 240 ns 10 V 50 100 ns 15 V 35 75 ns © Unit Nexperia B.V. 2021. All rights reserved 9 / 18 HEF4052B Nexperia Dual 4-channel analog multiplexer/demultiplexer 11.1. Waveforms and test circuit VDD nYn or nZ input VM VDD Sn input VEE tPLH tPHL VO nZ or nYn output nYn or nZ output VM VEE VM VSS tPLH VO 90 % 10 % VEE switch OFF 001aac290 Measurement points are given in Table 9. tPHL switch ON switch OFF 001aac291 Measurement points are given in Table 9. Fig. 13. nYn, nZ to nZ, nYn propagation delays Fig. 14. Sn to nYn, nZ propagation delays VDD E input VM VSS tPLZ nYn or nZ output LOW-to-OFF OFF-to-LOW tPZL VO 90 % 10 % VEE tPHZ nYn or nZ output HIGH-to-OFF OFF-to-HIGH VO tPZH 90 % 10 % VEE switch ON switch OFF switch ON 001aac292 Measurement points are given in Table 9. Fig. 15. Enable and disable times Table 9. Measurement points Supply voltage Input Output VDD VM VM 5 V to 15 V 0.5VDD 0.5VDD HEF4052B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 11 — 15 December 2021 © Nexperia B.V. 2021. All rights reserved 10 / 18 HEF4052B Nexperia Dual 4-channel analog multiplexer/demultiplexer VI negative pulse 0V tW 90 % VI positive pulse 0V 10 % VM 10 % VM tf tr tr tf 90 % VM VM tW VDD VDD VI PULSE GENERATOR VI DUT VO RT RL S1 open CL VSS VEE 001aaj903 Test data is given in Table 10. Definitions: RT = Termination resistance should be equal to output impedance Zo of the pulse generator; CL = Load capacitance including test jig and probe; RL = Load resistance. Fig. 16. Test circuit for measuring switching times Table 10. Test data Input nYn, nZ Sn and E Load tr, tf VDD or VEE VDD or VSS ≤ 20 ns [1] S1 position VM CL RL tPHL [1] tPLH 0.5VDD 50 pF 10 kΩ VDD or VEE VEE tPZH, tPHZ tPZL, tPLZ other VEE VDD VEE For nYn to nZ propagation delays use VEE. For Sn to nYn or nZ propagation delays use VDD. 11.2. Additional dynamic parameters Table 11. Additional dynamic characteristics VSS = VEE = 0 V; Tamb = 25 °C. Symbol Parameter Conditions THD total harmonic distortion see Fig. 17; RL = 10 kΩ; CL = 15 pF; channel ON; VI = 0.5VDD (p-p); fi = 1 kHz f(-3dB) -3 dB frequency response see Fig. 18; RL = 1 kΩ; CL = 5 pF; channel ON; VI = 0.5VDD (p-p) αiso isolation (OFF-state) see Fig. 19; fi = 1 MHz; RL = 1 kΩ; CL = 5 pF; channel OFF; VI = 0.5VDD (p-p) Vct crosstalk voltage digital inputs to switch; see Fig. 20; RL = 10 kΩ; CL = 15 pF; E or Sn = VDD (square-wave) Xtalk crosstalk between switches; see Fig. 21; fi = 1 MHz; RL = 1 kΩ; VI = 0.5VDD (p-p) [1] VDD Typ Max [1] 5 V 0.25 - % 10 V 0.04 - % 15 V 0.04 - % 13 - MHz 10 V 40 - MHz 15 V 70 - MHz [1] 10 V -50 - dB 10 V 50 - mV [1] 10 V -50 - dB [1] 5 V Unit fi is biased at 0.5 VDD; VI = 0.5VDD (p-p). HEF4052B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 11 — 15 December 2021 © Nexperia B.V. 2021. All rights reserved 11 / 18 HEF4052B Nexperia Dual 4-channel analog multiplexer/demultiplexer Table 12. Dynamic power dissipation PD can be calculated from the formulas shown; VEE = VSS = 0 V; tr = tf ≤ 20 ns; Tamb = 25 °C. Symbol PD Parameter dynamic power dissipation VDD Typical formula for PD (μW) where: 5V PD = 1300 × fi + Σ(fo × CL) × VDD 10 V PD = 6100 × fi + Σ(fo × CL) × VDD 15 V PD = 15600 × fi + Σ(fo × CL) × VDD 2 fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VDD = supply voltage in V; Σ(CL × fo) = sum of the outputs. 2 2 11.2.1. Test circuits VDD VDD VDD or VSS S1 and S2 nZ S1 and S2 VDD or VSS nYn nZ E VSS = VEE VSS nYn E RL D CL VSS = VEE VSS fi RL CL dB fi 001aak638 001aak639 Fig. 17. Test circuit for measuring total harmonic distortion Fig. 18. Test circuit for measuring frequency response VDD VDD or VSS S1 and S2 nY0 1 nZ nYn 2 switch E VSS = VEE VSS RL CL dB fi 001aak657 Fig. 19. Test circuit for measuring isolation (OFF-state) HEF4052B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 11 — 15 December 2021 © Nexperia B.V. 2021. All rights reserved 12 / 18 HEF4052B Nexperia Dual 4-channel analog multiplexer/demultiplexer 0.5VDD VDD RL G 0.5VDD S1 and S2 nY0 1 nZ nYn 2 RL switch E VSS = VEE VDD or VSS V CL VO 001aak658 a. Test circuit logic input (Sn, E) off on off VO Vct 001aaj908 b. Input and output pulse definitions Fig. 20. Test circuit for measuring crosstalk voltage between digital inputs and switch VDD VDD VDD or VSS S1 and S2 nY0 nZ nYn VDD or VSS S1 and S2 nY0 nZ nYn E E VSS = VEE VSS RL VO RL VSS = VEE VSS RL VI RL VO 001aak660 001aak659 a. Switch closed condition VI b. Switch open condition Fig. 21. Test circuit for measuring crosstalk between switches HEF4052B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 11 — 15 December 2021 © Nexperia B.V. 2021. All rights reserved 13 / 18 HEF4052B Nexperia Dual 4-channel analog multiplexer/demultiplexer 12. Package outline SO16: plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 D E A X c y HE v M A Z 16 9 Q A2 A (A 3) A1 pin 1 index θ Lp 1 L 8 e w M bp 0 2.5 detail X 5 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) mm 1.75 0.25 0.10 1.45 1.25 0.25 0.49 0.36 0.25 0.19 10.0 9.8 4.0 3.8 1.27 6.2 5.8 1.05 1.0 0.4 0.7 0.6 0.25 0.25 0.1 0.7 0.3 inches 0.069 0.010 0.057 0.004 0.049 0.01 0.019 0.0100 0.39 0.014 0.0075 0.38 0.16 0.15 0.05 0.039 0.016 0.028 0.020 0.01 0.01 0.004 0.028 0.012 0.244 0.041 0.228 θ o 8 o 0 Note 1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included. REFERENCES OUTLINE VERSION IEC JEDEC SOT109-1 076E07 MS-012 JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 Fig. 22. Package outline SOT109-1 (SO16) HEF4052B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 11 — 15 December 2021 © Nexperia B.V. 2021. All rights reserved 14 / 18 HEF4052B Nexperia Dual 4-channel analog multiplexer/demultiplexer TSSOP16: plastic thin shrink small outline package; 16 leads; body width 4.4 mm D SOT403-1 E A X c y HE v M A Z 9 16 Q A2 pin 1 index (A 3 ) A1 A θ Lp 1 L 8 detail X w M bp e 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z (1) θ mm 1.1 0.15 0.05 0.95 0.80 0.25 0.30 0.19 0.2 0.1 5.1 4.9 4.5 4.3 0.65 6.6 6.2 1 0.75 0.50 0.4 0.3 0.2 0.13 0.1 0.40 0.06 8o 0o Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT403-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-18 MO-153 Fig. 23. Package outline SOT403-1 (TSSOP16) HEF4052B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 11 — 15 December 2021 © Nexperia B.V. 2021. All rights reserved 15 / 18 HEF4052B Nexperia Dual 4-channel analog multiplexer/demultiplexer 13. Abbreviations Table 13. Abbreviations Acronym Description CMOS Complementary Metal-Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model 14. Revision history Table 14. Revision history Document ID Release date Data sheet status Change notice Supersedes HEF4052B v.11 20211215 Product data sheet - HEF4052B v.10 Modifications: • • • • • The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. Legal texts have been adapted to the new company name where appropriate. Section 1 and Section 2 updated. Table 4: Derating values for Ptot total power dissipation updated. Table 13 updated. HEF4052B v.10 20160325 Modifications: • HEF4052B v.9 20140911 Modifications: • HEF4052B v.8 20111117 Modifications: • • HEF4052B v.7 20100326 Product data sheet - HEF4052B v.6 HEF4052B v.6 20100308 Product data sheet - HEF4052B v.5 HEF4052B v.5 20091127 Product data sheet - HEF4052B v.4 HEF4052B v.4 20090924 Product data sheet - HEF4052B_CNV v.3 HEF4052B_CNV v.3 19950101 Product specification - HEF4052B_CNV v.2 HEF4052B_CNV v.2 19950101 Product specification - - HEF4052B Product data sheet Product data sheet - HEF4052B v.9 Type number HEF4052BP (SOT38-4) removed. Product data sheet - HEF4052B v.8 - HEF4052B v.7 Fig. 20: Test circuit modified Product data sheet Legal pages updated. Changes in Section 1, Section 2, and Section 3. All information provided in this document is subject to legal disclaimers. Rev. 11 — 15 December 2021 © Nexperia B.V. 2021. All rights reserved 16 / 18 HEF4052B Nexperia Dual 4-channel analog multiplexer/demultiplexer 15. Legal information injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Data sheet status Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal HEF4052B Product data sheet Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 11 — 15 December 2021 © Nexperia B.V. 2021. All rights reserved 17 / 18 HEF4052B Nexperia Dual 4-channel analog multiplexer/demultiplexer Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Applications.................................................................. 1 4. Ordering information....................................................1 5. Functional diagram.......................................................2 6. Pinning information......................................................5 6.1. Pinning.........................................................................5 6.2. Pin description............................................................. 5 7. Function table............................................................... 5 8. Limiting values............................................................. 6 9. Recommended operating conditions..........................6 10. Static characteristics..................................................7 10.1. Test circuits................................................................7 10.2. On resistance............................................................ 8 10.2.1. On resistance waveform and test circuit................. 8 11. Dynamic characteristics.............................................9 11.1. Waveforms and test circuit.......................................10 11.2. Additional dynamic parameters................................11 11.2.1. Test circuits........................................................... 12 12. Package outline........................................................ 14 13. Abbreviations............................................................ 16 14. Revision history........................................................16 15. Legal information......................................................17 © Nexperia B.V. 2021. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 15 December 2021 HEF4052B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 11 — 15 December 2021 © Nexperia B.V. 2021. All rights reserved 18 / 18
HEF4052BT,013 价格&库存
很抱歉,暂时无法提供与“HEF4052BT,013”相匹配的价格&库存,您可以联系我们找货
