ISD17120SYI
ISD17120SYI
    NUVOTON(新唐)
    SOIC28
    Voice Record/Playback IC Multiple Message 80 ~ 240 Sec Pushbutton, SPI 28-SOIC
ISD17120SYI 数据手册
ISD1700 ISD ChipCorder® ISD1700 Series Datasheet The information described in this document is the exclusive intellectual property of Nuvoton Technology Corporation and shall not be reproduced without permission from Nuvoton. Nuvoton is providing this document only for reference purposes of Audio Product Line based system design. Nuvoton assumes no responsibility for errors or omissions. All data and specifications are subject to change without notice. For additional information or questions, please contact: Nuvoton Technology Corporation. www.nuvoton.com Jun 28, 2021 Page 1 of 26 Rev2.3 ISD1700 TABLE OF CONTENTS 1 GENERAL DESCRIPTION .................................................................................. 3 2 FEATURES.......................................................................................................... 4 3 BLOCK DIAGRAM ............................................................................................... 6 4 PINOUT CONFIGURATION ................................................................................ 7 5 PIN DESCRIPTION ............................................................................................. 8 6 MODES OF OPERATIONS ................................................................................. 9 6.1 Standalone (Push-Button) Mode ................................................................... 9 6.2 SPI Mode....................................................................................................... 9 7 TIMING DIAGRAMS .......................................................................................... 10 7.1 Basic Operation ........................................................................................... 10 7.2 SPI Operation .............................................................................................. 14 8 ABSOLUTE MAXIMUM RATINGS .................................................................... 15 8.1 Operating Conditions ................................................................................... 16 9 ELECTRICAL CHARACTERISTICS .................................................................. 17 9.1 DC Parameters............................................................................................ 17 9.2 AC Parameters ............................................................................................ 18 10 TYPICAL APPLICATION CIRCUITS ................................................................. 19 11 PACKAGING ..................................................................................................... 22 11.1 28-Lead 300-Mil Plastic Small Outline Integrated Circuit (SOIC) ........... 22 11.2 28-Lead 600-Mil Plastic Dual Inline Package (PDIP) ............................. 23 12 ORDERING INFORMATION ............................................................................. 24 13 REVISION HISTORY ......................................................................................... 25 Important Notice ....................................................................................................... 26 Jun 28, 2021 Page 2 of 26 Rev2.3 ISD1700 1 GENERAL DESCRIPTION The Nuvoton® ISD1700 ChipCorder® Series is a high quality, fully integrated, singlechip multi-message voice record and playback device ideally suited to a variety of electronic systems. The message duration is user selectable in ranges from 26 seconds to 120 seconds, depending on the specific device. The sampling frequency of each device can also be adjusted from 4 kHz to 12 kHz with an external resistor, giving the user greater flexibility in duration versus recording quality for each application. Operating voltage spans a range from 2.4 V to 5.5 V to ensure that the ISD1700 devices are optimized for a wide range of battery or line-powered applications. The ISD1700 is designed for operation in either standalone or microcontroller (SPI) mode. The device incorporates a proprietary message management system that allows the chip to self-manage address locations for multiple messages. This unique feature provides sophisticated messaging flexibility in a simple push-button environment. The devices include an on-chip oscillator (with external resistor control), microphone preamplifier with Automatic Gain Control (AGC), an auxiliary analog input, anti-aliasing filter, Multi-Level Storage (MLS) array, smoothing filter, volume control, Pulse Width Modulation (PWM) Class D speaker driver, and current/voltage output. The ISD1700 devices also support an optional “vAlert” (voiceAlert) feature that can be used as a new message indicator. With vAlert, the device flashes an external LED to indicate that a new message is present. Besides, four special sound effects are reserved for audio confirmation of operations, such as “Start Record”, “Stop Record”, “Erase”, “Forward”, “Global Erase”, and etc. Recordings are stored into on-chip Flash memory, providing zero-power message storage. This unique single-chip solution is made possible through Nuvoton’s patented Multi-Level Storage (MLS) technology. Audio data are stored directly in solid-state memory without digital compression, providing superior quality voice and music reproduction. Voice signals can be fed into the chip through two independent paths: a differential microphone input and a single-ended analog input. For outputs, the ISD1700 provides a Pulse Width Modulation (PWM) Class D speaker driver and a separate analog output simultaneously. The PWM can directly drive a standard 8Ω speaker or typical buzzer, while the separate analog output can be configured as a single-ended current or voltage output to drive an external amplifier. While in Standalone mode, the ISD1700 devices automatically enter into power down mode for power conservation after an operation is completed. In the SPI mode, the user has full control via the serial interface in operating the device. This includes random access to any location inside the memory array by specifying the start address and end address of operations. SPI mode also allows access to the Jun 28, 2021 Page 3 of 26 Rev2.3 ISD1700 Analog Path Configuration (APC) register. This register allows flexible configuration of audio paths, inputs, outputs and mixing. The APC default configuration for standalone mode can also be modified by storing the APC data into a non-volatile register (NVCFG) that is loaded at initialization. Utilizing the capabilities of ISD1700 Series, designers have the control and flexibility to implement voice functionality into the highend products. 2 FEATURES  Integrated message management systems for single-chip, push-button applications o REC : level-trigger for recording o PLAY : edge-trigger for individual message or level-trigger for looping playback sequentially o ERASE : edge-triggered erase for first or last message or level-triggered erase for all messages o FWD : edge-trigger to advance to the next message or fast message scan during the playback o VOL : 8 levels output volume control o RDY INT : ready or busy status indication o RESET : return to the default state o Automatic power-down after each operation cycle  Selectable sampling frequency controlled by an external oscillator resistor Sampling Frequency Rosc 12 kHz 53 kΩ 8 kHz 80 kΩ 6.4 kHz 100 kΩ 5.3 kHz 120 kΩ 4 kHz 160 kΩ  Selectable message duration o A wide range selection from 20 secs to 480 secs pending upon sampling frequency chosen Sample Freq. 12 kHz 8 kHz 6.4 kHz 5.3 kHz 4 kHz ISD1730 20 secs ISD1760 40 secs ISD17120 80 secs ISD17240 160 secs 30 secs 37 secs 45 secs 60 secs 60 secs 75 secs 90 secs 120 secs 120 secs 150 secs 181 secs 240 secs 240 secs 300 secs 362 secs 480 secs  Message and operation indicators o Four customizable Sound Effects (SEs) for audible indication o Optional vAlert (voiceAlert) to indicate the presence of new messages o LED: stay on during recording, blink during playback, forward and erase operations  Dual operating modes o Standalone mode:  Integrated message management techniques  Automatic power-down after each operation cycle o SPI mode: Jun 28, 2021 Page 4 of 26 Rev2.3 ISD1700        Fully user selectable and controllable options via APC register and various SPI commands Two individual input channels o MIC+/MIC-: differential microphone inputs with AGC (Automatic Gain Control) o AnaIn: single-ended auxiliary analog input for recording or feed-through Dual output channels o Differential PWM Class D speaker outputs directly drives an 8 Ω speaker or a typical buzzer o Configurable AUD (current) or AUX (voltage) single-ended output drives external audio amplifier ChipCorder standard features o High-quality, natural voice and audio reproduction o 2.4V to 5.5V operating voltage o 100-year message retention (typical) o 100,000 record cycles (typical) Temperature options: o Commercial: 0°C to +50°C (die); 0°C to +70°C (packaged units) o Industrial: -40°C to +85°C (packaged units) Packaging types: available in Die, PDIP and SOIC Package option: Lead-free packaged units Jun 28, 2021 Page 5 of 26 Rev2.3 ISD1700 3 BLOCK DIAGRAM Jun 28, 2021 Page 6 of 26 Rev2.3 ISD1700 4 PINOUT CONFIGURATION Refer to Design Guide for details before performing any design or PCB layout. Jun 28, 2021 Page 7 of 26 Rev2.3 ISD1700 5 PIN DESCRIPTION Refer to Design Guide for details before performing any design or PCB layout. PIN NAME VCCD LED RESET FUNCTIONS Digital Power Supply: Power supply for digital circuitry. LED: An LED output. RESET: When active, the device enters into a known state. MISO Master In Slave Out: Data is shifted out on the falling edge of SCLK. When the SPI is inactive ( SS = high), it’s tri-state. MOSI Master Out Slave In: Data input of the SPI interface when ISD1700 is a slave. Data is latched into the device on the rising edge of SCLK. Serial Clock: Clock of the SPI interface. Slave Select: Selects as a slave device and enables the SPI interface. SCLK SS VSSA AnaIn MIC+ MICVSSP2 SPVCCP SP+ VSSP1 AUD/AUX AGC VOL ROSC VCCA FT PLAY REC ERASE FWD RDY INT VSSD Jun 28, 2021 Analog Ground: Ground path for analog circuitry. AnaIn: Auxiliary analog input to the device for recording or feed-through. MIC+: Non-inverting input of the differential microphone signal. MIC-: Inverting input of the differential microphone signal. Ground: Ground path for negative PWM speaker drive. SP-: The negative Class D PWM speaker output. Power Supply for PWM Speaker Driver: Power for PWM speaker drive. SP+: The positive Class D PWM speaker output. Ground: Ground path for positive PWM speaker drive. Auxiliary Output: Either an AUD (current) or AUX (voltage) output. Automatic Gain Control (AGC): The AGC adjusts the gain of the microphone preamplifier circuitry. Volume: This control has 8 levels of volume adjustment. Oscillator Resistor: A resistor determines the sample frequency of the device, which sets the duration. Analog Power Supply. Power supply for analog circuitry. Feed-through: Enable the feed-through path for AnaIn signal to the outputs. Playback: Plays the recorded message individually, or plays messages sequential in a looping mode. Record: When active, starts recording message. Erase: When active, can erase individual message or do global erase. Forward: Advances to the next message from the current location. An open drain output. Can review ready or interrupt status. Digital Ground: Ground path for digital circuitry Page 8 of 26 Rev2.3 ISD1700 6 MODES OF OPERATIONS The ISD1700 Series can operate in either Standalone (Push-Button) or microcontroller (SPI) mode. 6.1 STANDALONE (PUSH-BUTTON) MODE One can utilize the REC , PLAY , FT , FWD , ERASE , VOL or RESET control to initiate a desired operation. As completed, the device automatically enters into the powerdown state. 6.2 SPI MODE In SPI mode, control of the device is achieved through the 4-wire serial interface via SPI commands. For technical details, please refer to the design guide. Jun 28, 2021 Page 9 of 26 Rev2.3 ISD1700 7 TIMING DIAGRAMS The following estimated timing diagrams are not in proper scale. 7.1 BASIC OPERATION Tr Tf REC TDeb RDY TSc1 TRU TER TRD TSet1 LED Mic+/-, AnaIn Figure 12.1: Record Operation with No Sound Effect > TDeb Tr Tf TDeb PLAY TDeb TRDTSet1 RDY TSc1 TSc2 TRU TLH TCyc LED Sp+, Sp- Figure 12.2: Start and Stop Playback Operation Jun 28, 2021 Page 10 of 26 Rev2.3 ISD1700 > TDeb Tr Tf ERASE TDeb TRD RDY TSc1 TSc2 TE TLS2 TSc2 LED Figure 12.3: Single Erase Operation with No Sound Effect > T Deb Tr Tf FWD TDeb TRD RDY TSc1 TSc2 TLS1 or T LS2 LED Figure 12.4: Forward Operation with No Sound Effect Jun 28, 2021 Page 11 of 26 Rev2.3 ISD1700 Tf Tr ERASE TDeb TRD RDY TSc1 TSc2 TGE1 or (TE + TLS2 or TSE2) 3x(T LS1 or TSE1) TGE2 TLS4 or TSE4 LED Sp+, SpNote: If SEs are recorded, then Sp+/- will have output. Figure 12.5: Global Erase Operation with or without Sound Effects Tr Tf RESET TReset TSet2 Device returns to Power Down state RDY LED Figure 12.6: Reset Operation Jun 28, 2021 Page 12 of 26 Rev2.3 ISD1700 > T Deb Tr Tf PLAY TDeb TRD RDY TSc1 TSc2 TRU TLH TCyc LED TRU TRD AUD Figure 12.7: Playback Operation with ramp up and ramp down effect at AUD output Jun 28, 2021 Page 13 of 26 Rev2.3 ISD1700 7.2 SPI OPERATION TSSmin TSSH SS TSCKlow TSSS TSCKhi SCLK TDIS TDIH LSB MOSI MSB TPD TDF (TRISTATE) MISO MSB LSB Figure 12.8: SPI Operation PARAMETER SYMBOL MIN TYP MAX UNITS TSSS 500 nsec TSSH 500 nsec Data in Setup Time TDIS 200 nsec Data in Hold Time TDIH 200 nsec SS Setup Time SS Hold Time Output Delay TPD 500 nsec Output Delay to HighZ TDF 500 nsec SS TSSmin HIGH 1 µsec SCLK High Time TSCKhi 400 nsec SCLK Low Time TSCKlow 400 nsec CLK Frequency Power-Up Delay Notes: [1] Jun 28, 2021 F0 [1] TPUD 1,000 50 KHz msec The value shown is based upon 8 kHz sampling frequency. Delay increases proportionally for slower sampling frequency. Page 14 of 26 Rev2.3 ISD1700 8 ABSOLUTE MAXIMUM RATINGS ABSOLUTE MAXIMUM RATINGS (DIE) [1] CONDITIONS Junction temperature Storage temperature range Voltage Applied to any pads Power supply voltage to ground potential VALUES 1500C -650C to +1500C (VSS - 0.3V) to (VCC + 0.3V) -0.3V to +7.0V ABSOLUTE MAXIMUM RATINGS (PACKAGED PARTS) [1] CONDITIONS Junction temperature Storage temperature range Voltage Applied to any pins Voltage applied to any pin (Input current limited to +/-20 mA) Power supply voltage to ground potential [1] VALUES 1500C -650C to +1500C (VSS - 0.3V) to (VCC + 0.3V) (VSS – 1.0V) to (VCC + 1.0V) -0.3V to +7.0V Stresses above those listed may cause permanent damage to the device. Exposure to the absolute maximum ratings may affect device reliability. Functional operation is not implied at these conditions. Jun 28, 2021 Page 15 of 26 Rev2.3 ISD1700 8.1 OPERATING CONDITIONS OPERATING CONDITIONS (DIE) CONDITIONS VALUES Operating temperature range Supply voltage (VCC) [1] Ground voltage (VSS) [2] Input voltage (VCC) [1] Voltage applied to any pins 0°C to +50°C +2.4 V to +5.5 V 0V 0 V to 5.5 V (VSS –0.3 V) to (VCC +0.3 V) OPERATING CONDITIONS (PACKAGED PARTS) CONDITIONS VALUES Operating temperature range (Case temperature) Supply voltage (VDD) [1] Ground voltage (VSS) [2] Input voltage (VDD) [1] Voltage applied to any pins -40°C to +85°C +2.4V to +5.5V 0V 0V to 5.5V (VSS –0.3V) to (VDD +0.3V) [1] V CC [2] = VCCA = VCCD= VCCP VSS = VSSA = VSSD = VSSP1 VSSP2 Jun 28, 2021 Page 16 of 26 Rev2.3 ISD1700 9 ELECTRICAL CHARACTERISTICS 9.1 DC PARAMETERS PARAMETER SYMBOL Supply Voltage VDD Input Low Voltage VIL Input High Voltage VIH Output Low Voltage VOL Output High Voltage VOH Record Current IDD_Record Playback Current IDD_Playback Erase Current IDD_Erase Standby Current ISB Input Leakage Current IILPD1 Input Current Low IILPD2 Preamp Input Impedance RMIC+,RMICAnaIn Input Impedance RAnaIn MIC Differential Input VIN1 AnaIn Input Voltage VIN2 Gain from MIC to SP+/AMSP MIN 2.4 VSS-0.3 0.7xVDD VSS-0.3 0.7xVDD Speaker Output Load RSPK AUX Output Load RAux Speaker Output Power Pout 8 5 Speaker Output Voltage AUX Output Swing AUX Output DC Level AUD Volume Output [1] [2] [3] [4] [5] MAX 5.5 0.3xVDD VDD 0.3xVDD VDD 20 20 20 1 10 ±1 -10 -3 7 42 15 6 40 670 313 117 49 VDD 1 1.2 IAUD AVol V V -3.0 0 to -28 THD UNITS V V V V V mA mA mA µA µA µA kΩ kΩ 300 1 dB Ω kΩ VOUT1 VOUT2 VOUT3 Total Harmonic Distortion Notes: TYP [1] dB 1 CONDITIONS IOL = 4.0 mA[2] IOH = -1.6 mA[2] VDD = 5.5 V, No load, Sampling freq = 12 kHz [3] [4] Force VDD Force VSS , others at Vcc Power-up AGC When active mV Peak-to-Peak[5] V Peak-to-Peak VIN = 15~300 mV, AGC = 4.7 µF, VCC = 2.4V~5.5V Across both Speaker pins When active mW VDD = 5.5 V 1Vp-p, mW VDD = 4.4 V 1 kHz sine wave at mW VDD= 3 V AnaIn. RSPK mW VDD= 2.4 V = 8 Ω. RSPK = 8Ω (Speaker), V Typical buzzer Peak-to-Peak When active mA VDD =4.5 V, REXT= 390 Ω 8 steps of 4dB each reference to output 15 mV p-p 1 kHz sine % wave, Cmessage weighted Conditions: VCC = 4.5V, 8 kHz sampling frequency and TA = 25°C, unless otherwise stated. LED output during Record operation. VCCA, VCCD and VCCP are connected together. VSSA, VSSP1, VSSP2 and VSSD are connected together. REC , PLAY , FT , FWD , ERASE , VOL and RESET must be at VCCD. Balanced input signal applied between MIC+ and MIC- as shown in the applications example. Single-ended MIC+ or MIC- input is recommended no more than 150 mV p-p. Jun 28, 2021 Page 17 of 26 Rev2.3 ISD1700 9.2 AC PARAMETERS CHARACTERISTIC Sampling Frequency [2] Duration [3] SYMBOL FS TDur Rising Time Falling Time Debounce Time Ramp Up Time Ramp Down Time Initial Scan Time after power is applied Initial Scan Time from PD state End Recording Time LED High Time LED Flash Time for SE1 LED Flash Time for SE2 LED Flash Time for SE3 LED Flash Time for SE4 SE1 Recorded Duration SE2 Recorded Duration SE3 Recorded Duration SE4 Recorded Duration Erase Time Tr Tf TDeb TRU TRD TSc1 MIN 4 TYP [1] MAX 12 Refer to duration table 100 100 UNITS kHz sec CONDITIONS [2] [4] [3] DRN/8/FS nsec nsec msec msec msec msec TSc2 DRN/16/FS msec After a PB operation is run [4] TER TLH TLS1 TLS2 TLS3 TLS4 TSE1 TSE2 TSE3 TSE4 TE 32/FS 0.5K/FS msec msec sec sec sec sec sec sec sec sec sec [4] 192/FS 128/FS 128/FS 3.5K/FS 7.5K/FS 11.5K/FS 15.5K/FS 4K/FS 4K/FS 4K/FS 4K/FS 10MRN/FS [4] DRN= device row# [4] [4] SE1 not recorded [5] SE2 not recorded [5] SE3 not recorded [5] SE4 not recorded [5] [4] [5] [4] [5] [4] [5] [4] [5] MRN=message row # [4] Global Erase Wait Time Global Erase Time RESET Pulse TGE1 TGE2 TReset Settle Time Settle Time after Reset LED Error Time LED Cycle frequency TSet1 TSet2 TLErr TCyc Notes: 20K/FS 34/FS 1 1 128/FS 64/FS 27.5K/FS 4 sec sec µsec msec msec msec Hz [4] [5] All Fs [4] [4] [4] [4] [5] Pending upon FS [1] Typical values: VCC = 4.5 V, FS = 8 kHz and @ TA = 25°C, unless otherwise stated. Characterization data shows that sampling frequency resolution is ±5 percent across temperature and voltage ranges. [3] Characterization data shows that duration resolution is ±5 percent across temperature and voltage ranges. [4] Vcc=2.4 V~5.5V [5] K = 1024 [2] Jun 28, 2021 Page 18 of 26 Rev2.3 ISD1700 10 TYPICAL APPLICATION CIRCUITS The following typical applications examples on ISD1700 Series are for references only. They make no representation or warranty that such applications shall be suitable for the use specified. Each design has to be optimized in its own system for the best performance on voice quality, current consumption, functionalities and etc. The below notes apply to the following applications examples: * ** These capacitors may be needed in order to optimize for the best voice quality, which is also dependent upon the layout of the PCB. Depending on system requirements, they can be 10 µF, 4.7 µF or other values. Please refer to the applications notes or consult Nuvoton for layout advice. It is important to have a separate path for each ground and power back to the related terminals to minimize the noise. Also, the power supplies should be decoupled as close to the device as possible. Example #1: Recording using microphone input via push-button controls Reset 24 23 25 26 19 22 VCC 7 6 4.7 K Ω 5 4.7 µ F 4 3 REC PLAY ERASE RESET LED 0.1µ F 2 D1 1 KΩ FWD VCCD 1 VOL FT VSSD 28 SCLK MOSI ISD1700 ** VCCA VCCD VCCP VCCD 0.1 µF * Gnd Vcc ** VCCA VCCA 21 VSSA 8 SS vAlert 0.1µ F * VCCP VCCP 14 VSSP1 16 0.1µF * * 0.1 µ F VSSP2 12 MISO 4.7 K Ω 10 0.1 µ F 11 0.1 µ F Rosc *** AnaIn 20 ROSC 18 4.7 µ F 15 Speaker or Buzzer SP- 13 VCC Speaker MIC - 9 4.7 KΩ SP+ MIC+ AUD AUD/AUX 17 8050C VCCD INT/RDY 27 100 K Ω AUX 390 Ω 0.1 µ F Optional AGC Optional: based upon the applications *** At 8kHz sampling freq, Rosc = 80 K : Digital ground; Jun 28, 2021 : Analog ground; Page 19 of 26 : Ground for SP+; : Ground for SP- Rev2.3 ISD1700 Example #2: Recording using AnaIn input via push-button controls Jun 28, 2021 Page 20 of 26 Rev2.3 ISD1700 Example #3: Connecting the SPI Interface to a microcontroller 10.1 GOOD AUDIO DESIGN PRACTICES Nuvoton’s ChipCorder are very high-quality single-chip voice recording and playback devices. To ensure the highest quality voice reproduction, it is important that good audio design practices on layout and power supply decoupling are followed. See Application Information links below for details. • Design considerations for ISD1600B Series (AN-CC1001.pdf) • Good Audio Design Practices (apin11.pdf) • Single-Chip Board Layout Diagrams (apin12.pdf) Jun 28, 2021 Page 21 of 26 Rev2.3 ISD1700 11 PACKAGING 11.1 28-LEAD 300-MIL PLASTIC SMALL OUTLINE INTEGRATED CIRCUIT (SOIC) 28 27 26 25 24 23 22 21 20 19 18 17 16 15 2 3 4 5 1 6 7 8 9 10 11 12 13 14 A G C B D E H F Plastic Small Outline Integrated Circuit (SOIC) Dimensions INCHES MILLIMETERS Min Nom Max Min Nom Max A 0.701 0.706 0.711 17.81 17.93 18.06 B 0.097 0.101 0.104 2.46 2.56 2.64 C 0.292 0.296 0.299 7.42 7.52 7.59 D 0.005 0.009 0.0115 0.127 0.22 0.29 E 0.014 0.016 0.019 0.35 0.41 0.48 0.050 F 1.27 G 0.400 0.406 0.410 10.16 10.31 10.41 H 0.024 0.032 0.040 0.61 0.81 1.02 Note: Lead coplanarity to be within 0.004 inches. Jun 28, 2021 Page 22 of 26 Rev2.3 ISD1700 11.2 28-LEAD 600-MIL PLASTIC DUAL INLINE PACKAGE (PDIP) Plastic Dual Inline Package (PDIP) (P) Dimensions INCHES A B1 B2 C1 C2 D D1 E F G H J S 0 Jun 28, 2021 Min 1.445 0.065 0.600 0.530 0.015 0.125 0.015 0.055 0.008 0.070 0° Nom 1.450 0.150 0.070 0.540 0.018 0.060 0.100 0.010 0.075 MILLIMETERS Max 1.455 Min 36.70 0.075 0.625 0.550 0.19 1.65 15.24 13.46 0.135 0.022 0.065 0.38 3.18 0.38 1.40 0.012 0.080 15° 0.20 1.78 0° Page 23 of 26 Nom 36.83 3.81 1.78 13.72 0.46 1.52 2.54 0.25 1.91 Max 36.96 1.91 15.88 13.97 4.83 3.43 0.56 1.65 0.30 2.03 15° Rev2.3 ISD1700 12 ORDERING INFORMATION Jun 28, 2021 Page 24 of 26 Rev2.3 ISD1700 13 REVISION HISTORY VERSION DATE 1.0 Sep, 2006 Initial version 1.1 Nov, 2006 Revise Pinout Configuration & Pin Description sections 1.2 Jan, 2007 Revise Rosc resistor value Revise Selectable Message Duration section Update standby current, sampling frequency & duration parameters 1.3 Oct 31, 2008 Change logo. 2.0 Feb 4, 2010 Remove preliminary sign. 2.1 Mar, 2017 2.2 Apr 1, 2020 2.3 Jun 28, 2021 Jun 28, 2021 DESCRIPTION Removed TSOP pakage option (Not recommended for new Desig) Update Document Format Update Ordering Information Page 25 of 26 Rev2.3 ISD1700 Important Notice Nuvoton Products are neither intended nor warranted for usage in systems or equipment, any malfunction or failure of which may cause loss of human life, bodily injury or severe property damage. Such applications are deemed, “Insecure Usage”. Insecure usage includes, but is not limited to: equipment for surgical implementation, atomic energy control instruments, airplane or spaceship instruments, the control or operation of dynamic, brake or safety systems designed for vehicular use, traffic signal instruments, all types of safety devices, and other applications intended to support or sustain life. All Insecure Usage shall be made at customer’s risk, and in the event that third parties lay claims to Nuvoton as a result of customer’s Insecure Usage, customer shall indemnify the damages and liabilities thus incurred by Nuvoton. Jun 28, 2021 Page 26 of 26 Rev2.3
ISD17120SYI 价格&库存
很抱歉,暂时无法提供与“ISD17120SYI”相匹配的价格&库存,您可以联系我们找货
ISD17120SYI
    • 1+9.79860
    库存:3
