ISD15116FYI
ISD15116FYI
    NUVOTON(新唐)
    LQFP48
    Voice Record/Playback IC Multiple Message 16 Min SPI 48-LQFP (7x7)
ISD15116FYI 数据手册
ISD15100 ISD ChipCorder® ISD15100 Series Datasheet The information described in this document is the exclusive intellectual property of Nuvoton Technology Corporation and shall not be reproduced without permission from Nuvoton. Nuvoton is providing this document only for reference purposes of Audio Product Line based system design. Nuvoton assumes no responsibility for errors or omissions. All data and specifications are subject to change without notice. For additional information or questions, please contact: Nuvoton Technology Corporation. www.nuvoton.com Jun 15, 2021 Page 1 of 21 Rev 1.6 ISD15100 TABLE OF CONTENTS 1 GENERAL DESCRIPTION .............................................................................................................. 3 2 FEATURES ...................................................................................................................................... 3 3 BLOCK DIAGRAM ........................................................................................................................... 5 4 PINOUT CONFIGURATION ............................................................................................................ 7 5 PIN DESCRIPTION .......................................................................................................................... 8 6 ELECTRICAL CHARACTERISTICS .............................................................................................. 11 6.1 ABSOLUTE MAXIMUM RATINGS ............................................................................................................. 11 6.2 OPERATING CONDITIONS ........................................................................................................................ 11 6.3 DC PARAMETERS ................................................................................................................................... 12 6.4 AC PARAMETERS ................................................................................................................................... 12 6.4.1 Internal Oscillator ......................................................................................................................... 12 6.4.2 Inputs ............................................................................................................................................. 12 6.4.3 Outputs ........................................................................................................................................... 13 6.4.4 SPI Timing ..................................................................................................................................... 15 6.4.5 I2S Timing ...................................................................................................................................... 16 7 APPLICATION DIAGRAM .............................................................................................................. 17 8 PACKAGE SPECIFICATION ......................................................................................................... 18 8.1 9 10 48 LEAD LQFP(7X7X1.4MM FOOTPRINT 2.0MM).................................................................................... 18 ORDERING INFORMATION .......................................................................................................... 19 REVISION HISTORY.................................................................................................................. 20 IMPORTANT NOTICE........................................................................................................................... 21 Jun 15, 2021 Page 2 of 21 Rev 1.6 ISD15100 1 GENERAL DESCRIPTION The ISD15100 series is a multi-message ChipCorder® featuring digital compression, comprehensive memory management, flash storage, and integrated analog/digital audio signal paths. The message management feature is designed to make message recording simple and address-free as well as make code development easier for playback-only applications. This family utilizes flash memory to provide non-volatile audio record/playback with durations up to 8 minutes for a single-chip solution. Unlike other ChipCorder series, the ISD15100 series provides an I2S digital audio interface, faster digital recording, higher sampling frequency, and a signal path with SNR equivalent to 12bit resolution. The ISD15100 series can take digital audio data via I2S or SPI interface. When I2S input is selected, it will replace the analog audio inputs and will support sample rates of 32, 44.1 or 48 kHz depending upon clock configuration. When SPI interface is chosen, the sample rate of the audio data sent must be one of the ISD15100 supported sample rates. The ISD15100 series has built-in analog audio inputs, analog audio line driver, and speaker driver output. The two analog audio inputs to the device are: (1) AUXIN has a fixed gain configured by SPI command, and (2) ANAIN/ANAOUT has a fixed gain amplifier with the gain set by two external resistors. ANAIN/ANAOUT can also be used as a microphone differential input (ANAIN/ANAOUT becomes MIC+/MIC-) in conjunction with an automatic gain control (AGC) circuit configured by SPI command. Analog outputs are available in three forms: (1) AUXOUT is a single-ended voltage output; (2) AUDOUT can be configured as either a single-ended voltage output or a single-ended current output; (3) BTL (bridge-tied-load) is a differential voltage output. 2 • • • • • FEATURES Fast Digital Programming o Programming rate can go up to 1Mbits/second mainly limited by the flash memory write rate. Duration o 2 to 8 minutes based on 8kHz/4bit ADPCM Message Management o Perform address-free recording: The ISD15100 allocates memory for new recording requests and upon completion, returns a start address to the host via SPI interface o Store pre-recorded audio (Voice Prompts) using high quality digital compression o Use a simple index based command for playback o Execute pre-programmed macro scripts (Voice Macros) designed to control the configuration of the device and play back Voice Prompts sequences and message recordings. Sample Rate o Seven record and playback sampling frequencies are available for a given master sample rate. For example, the record and playback sampling frequencies of 4, 5.3, 6.4, 8, 12.8, 16 and 32kHz* are available when the device is clocked at a 32kHz master sample rate. o For I2S operation, 32, 44.1 and 48kHz master sample rates are available with record and playback sampling frequencies scaling accordingly. Compression Algorithms o For recording  ADPCM: 2, 3, 4 or 5 bits per sample  µ-Law: 6, 7 or 8 bits per sample  Differential µ-Law: 6, 7 or 8 bits per sample  PCM: 8, 10 or 12 bits per sample. Each sampled value is stored as a code, offering no compression but preserving maximum resolution o For Pre-Recorded Voice Prompts  µ-Law: 6, 7 or 8 bits per sample  Differential µ-Law: 6, 7 or 8 bits per sample  PCM: 8, 10 or 12 bits per sample  Enhanced ADPCM: 2, 3, 4 or 5 bits per sample  Variable-bit-rate optimized compression. This allows best possible compression given a Jun 15, 2021 Page 3 of 21 Rev 1.6 ISD15100 • • • • • • • • • metric of SNR and background noise levels. Oscillator o Internal oscillator with internal reference: 2.048 MHz with ±10% deviation o Internal oscillator with external resistor: 2.048 MHz with ±5% deviation when Rosc is 80k-ohm o External crystal or clock input o I2S bit clock input o Crystals and resonators support standard audio sampling rates of 2.048, 4.096, 8.192, 12.288 and11.2896MHz Inputs o AUXIN: Analog input with 2-bit gain control configured by SPI command o ANAIN/ANAOUT:  Analog input with the gain set by two external resistors from ANAOUT to ANAIN, or  Microphone differential input (ANAIN/ANAOUT becomes MIC+/MIC-) o Digital AGC:  Automatic gain control of digitized data from the analog input Outputs o PWM: Class D speaker driver which can deliver typical output power:  8Ω load: 350mW @3.3v, 420mW @3.6v 8Ω load.  4Ω load: 520mW @3.3v, 620mW @3.6v 8Ω load. o AUDOUT: configurable as a current or voltage single-ended line driver o AUXOUT: a single-ended voltage output o BTL: differential voltage output which can deliver typical output power:  63mW for 8Ω load, 115mW for 4Ω load. I/Os o SPI interface: MISO, MOSI, SCLK, SSB for commands and digital audio data o I2S interface: I2S_CLK, I2S_WS, I2S_SDI, I2S_SDO for digital audio data o 8 GPIO pins (4 of the 8 GPIO pins share with I2S). Three 8-bit Volume Control set by SPI command for flexible mixing o VOLA: volume control for the digital audio data from I2S or analog inputs o VOLB: volume control for the digital audio data from decompression block or SPI o VOLC: master volume control for PWM, AUDOUT, AUXOUT and I2S outputs Operating Voltage: 2.7-3.6V Standby Current: 1uA typical Package: Green 48L-LQFP Temperature Options: o Industrial: -40°C to 85°C Jun 15, 2021 Page 4 of 21 Rev 1.6 ISD15100 3 BLOCK DIAGRAM Figure 3-1 ISD15100 Block Diagram, ANAIN Selected Jun 15, 2021 Page 5 of 21 Rev 1.6 ISD15100 Figure 3-2 ISD15100 Block Diagram, MICIN Selected Jun 15, 2021 Page 6 of 21 Rev 1.6 ISD15100 PINOUT CONFIGURATION NC AUXIN ANAIN/MIC+ ANAOUT/MICVSSA VCCA AUXOUT AUDOUT NC NC GPIO0 NC 4 48 47 46 45 44 43 42 41 40 39 38 37 36 35 2 3 34 33 4 32 5 31 6 30 7 29 8 28 9 27 10 26 11 1 ISD15100 XTALIN XTALOUT VCCD VCCD GPIO1 GPIO2 GPIO3 NC NC RESET RDY/BSYB INTB NC NC NC VSSD_PWM SPKVCCD_PWM VCCD_PWM SPK+ MISO 25 12 13 14 15 16 17 18 19 20 21 22 23 24 SCLK SSB MOSI NC NC NC 2 I S_SDI/GPIO7 I2S_SCK/GPIO6 I2S_WS/GPIO5 2 I S_SDO/GPIO4 VCCD VSSD VSSD VCCD VREG Figure 4-1 ISD15100 48-Lead LQFP Pin Configuration. Jun 15, 2021 Page 7 of 21 Rev 1.6 ISD15100 5 PIN DESCRIPTION Pin Number Pin Name I/O Function 1 NC This pin should be left unconnected. 2 NC This pin should be left unconnected. 3 NC This pin should be left unconnected. 4 I2S_SDI/ I Serial Data Input of the I2S interface (If I2S is not used, this pin should be grounded). Or, can be configured as a GPIO pin. GPIO7 5 I2S_SCK/ GPIO6 I/O Clock input in slave mode or clock output in master mode. This pin can be configured as an external clock buffer if I2S is not used (If I2S is not used, this pin should be grounded). Or, can be configured as a GPIO pin. 6 I2S_WS/ GPIO5 I/O Word Select (WS) input in slave mode or WS output in master mode (If I2S is not used, this pin should be grounded). Or, can be configured as a GPIO pin. 7 I2S_SDO/ GPIO4 O Serial Data Output of the I2S Interface (If I2S is not used, this pin should be left unconnected). Or, can be configured as a GPIO pin. 8 VCCD I Digital power supply. 9 VSSD I Digital Ground. 10 VSSD I Digital Ground. 11 VCCD I Digital power supply. 12 VREG O A 1.8V regulator to supply the internal logic. A 0.1uF capacitor should be connected to this pin for supply decoupling and stability. 13 MISO O Master-In-Slave-Out. Serial output from the ISD15100 to the host. This pin is in tri-state when SSB=1. 14 SCLK I Serial Clock input to the ISD15100 from the host. 15 SSB I Slave Select input to the ISD15100 from the host. When SSB is low device is selected and responds to commands on the SPI interface. 16 MOSI I Master-Out-Slave-In. Serial input to the ISD15100 from the host. 17 VCCD_PWM I Digital Power for the PWM Driver. 18 SPK+ O PWM driver positive output. This SPK+ output, together with SPK- pin, provide a differential output to drive 8Ω speaker. During power down this pin is in tri-state. Or, can be configured as BTL which, together with SPK- pin, provide a differential voltage output. Or, can independently switch to AUDOUT or AUXOUT. 19 VSSD_PWM I Digital Ground for the PWM Driver. 20 SPK- O PWM driver negative output. This SPK- output, together with SPK+ pin, provides a differential output to drive 8Ω speake. During power down this pin is tri-state. Jun 15, 2021 Page 8 of 21 Rev 1.6 ISD15100 Pin Number Pin Name I/O Function Or, can be configured as BTL which, together with SPK+ pin, provide a differential voltage output. Or, can independently switch to AUDOUT or AUXOUT. 21 VCCD_PWM 22 NC This pin should be left unconnected. 23 NC This pin should be left unconnected. 24 NC This pin should be left unconnected. 25 INTB O Active low interrupt request pin. This pin is an open-drain output. 26 RDY/BSYB O An output pin to report the status of data transfer on the SPI interface. “High” indicates that ISD15100 is ready to accept new SPI commands or data. 27 RESET I Applying power to this pin will reset the chip. (A high pulse of 50ms or more will reset the chip.) 28 NC This pin should be left unconnected. 29 NC This pin should be left unconnected. 30 GPIO3 I/O GPIO 31 GPIO2 I/O GPIO 32 GPIO1 I/O GPIO 33 VCCD I Digital power supply pin. 34 VCCD I Digital power supply pin. 35 XTALOUT O Crystal interface output pin. 36 XTALIN I The CLK_CFG register determines one of the following three configurations: (1) A crystal or resonator connected between the XTALOUT and XTALIN pins. (2) A resistor connected to GND as a reference current to the internal oscillator and left the XTALOUT unconnected. (3) An external clock input to the device and left the XTALOUT unconnected. 37 NC 38 GPIO0 39 NC This pin should be left unconnected. 40 NC This pin should be left unconnected. 41 AUDOUT O Audio Out. This pin can be either a voltage output or a current output configured by the internal registers via SPI command. If AUDOUT is not used, this pin should be left unconnected. 42 AUXOUT O Aux Out. This pin is an analog voltage output. If AUXOUT is not used, this pin should be left unconnected. 43 VCCA I Analog power supply pin. 44 VSSA I Analog ground pin. 45 ANAOUT/ O Variable gain analog output with the gain set by feedback resistance to Jun 15, 2021 I Digital Power for the PWM Driver. This pin should be left unconnected. I/O GPIO Page 9 of 21 Rev 1.6 ISD15100 Pin Number Pin Name I/O MIC- Function ANAIN. Or, can be configured as MIC- which, together with MIC+, provides a microphone differential input. If ANAIN/ANAOUT is not used, this pin should be left unconnected. 46 ANAIN/ MIC+ I Variable gain analog input. Or, can be configured as MIC+ which, together with MIC-, provides a microphone differential input. If ANAIN/ANAOUT is not used, this pin should be left unconnected. 47 AUXIN I Auxiliary input with the gain set by SPI command If AUXIN is not used, this pin should be left unconnected. 48 NC Jun 15, 2021 This pin should be left unconnected. Page 10 of 21 Rev 1.6 ISD15100 6 ELECTRICAL CHARACTERISTICS 6.1 ABSOLUTE MAXIMUM RATINGS ABSOLUTE MAXIMUM RATINGS (PACKAGED PARTS) [1] CONDITIONS VALUES Junction temperature Storage temperature range Voltage Applied to any pins Voltage applied to any pin (Input current limited to +/-20 mA) Power supply voltage to ground potential [1] 6.2 1300C -650C to +1500C (VSS - 0.3V) to (VCC + 0.3V) (VSS – 1.0V) to (VCC + 1.0V) -0.3V to +5.0V Stresses above those listed may cause permanent damage to the device. Exposure to the absolute maximum ratings may affect device reliability. Functional operation is not implied at these conditions. OPERATING CONDITIONS OPERATING CONDITIONS (INDUSTRIAL PACKAGED PARTS) CONDITIONS VALUES Operating temperature range (Case temperature) -40°C to +85°C Supply voltage (VDD) [1] +2.7V to +3.6V Ground voltage (VSS) [2] 0V Input voltage (VDD) [1] 0V to 3.6V Voltage applied to any pins NOTES: Jun 15, 2021 (VSS –0.3V) to (VDD +0.3V) [1] V DD = VCCA = VCCD = VCCPWM [2] V SS = VSSA = VSSD = VSSPWM Page 11 of 21 Rev 1.6 ISD15100 6.3 DC PARAMETERS TYP [1] PARAMETER SYMBOL Supply Voltage VDD 2.7 3.6 V Input Low Voltage VIL VSS-0.3 0.3xVDD V Input High Voltage VIH 0.7xVDD VDD V Output Low Voltage VOL VSS-0.3 0.3xVDD V IOL = 1mA Output High Voltage VOH 0.7xVDD VDD V IOH = -1mA INTB Output Low Voltage VOH1 0.4 V IDD_Record 40 mA Playback Current IDD_Playback 30 mA Standby Current ISB 10 µA VDD= 3.6V Input Leakage Current IIL ±1 µA Force VDD Record Current Notes: [1] Conditions 6.4 AC PARAMETERS 6.4.1 Internal Oscillator MIN MAX 1 UNITS CONDITIONS VDD= 3.6V, No load, Sampling freq = 16 kHz VDD=3V, TA=25°C unless otherwise stated PARAMETER SYMBOL MIN TYP MAX UNITS CONDITIONS Internal Oscillator with internal reference FINT -10% 2.048 MHz +10 % MHz Vdd = 3V. At room temperature FExt -5% 2.048 MHz +5% MHz With 1% precision resistor, 80k-ohm. Vdd = 3V. At room temperature Internal Oscillator with external resistor [1] Notes: [1] Characterization data shows that frequency deviation is +/- 5% across temperature and voltage ranges. 6.4.2 Inputs ANAIN & MICIN PARAMETER SYMBOL ANAIN Input Voltage VANAIN ANAIN Feed Back Resistance RANA(FB) MICIN Input Voltage VMICIN Notes: TYP [1] MAX 10-1000 40 100 5-500 UNITS CONDITIONS mV Peak-to-Peak[2] KΩ mV Peak-to-Peak[2] [1] Conditions [2] Depends Jun 15, 2021 MIN VDD=3V, TAB=25°C unless otherwise stated on Gain Setting Page 12 of 21 Rev 1.6 ISD15100 AUXIN PARAMETER SYMBOL AUXIN Input Voltage VAUXIN Gain from AUXIN to AUXOUT/ANAOUT AAUXIN GAIN AUXIN Gain Accuracy AAUXIN (GA) MIN UNITS CONDITIONS 1000 mV Peak-to-Peak[2] 0 to 9 dB 4 Gain Steps of 3db each -0.5 MAX +0.5 dB KΩ 20-40 RAUXIN AUXIN Input Resistance TYP[1] Depending on AUXIN Gain Setting [1] Conditions Notes: [2] With VDD=3V, TA=25°C unless otherwise stated. 0db Gain setting. 6.4.3 Outputs AUXOUT MIN TYP[1] PARAMETER SYMBOL MAX SINAD, AUXIN to AUXOUT SINADAUXIN_AUXOUT 80 dB Load 5K[2][3] SINAD, ANAIN to AUXOUT SINADANAIN_AUXOUT 80 dB Load 5K[2][3] PSRR PSRRAUXOUT -40 dB [4] DC Bias VBIAS_AUXOUT Minimum Load Impedance RL(AUXOUT) Maximum Load Capacitance CL(AUXOUT) 1.2 UNITS CONDITIONS V KΩ 5 0.1 nF [1] Conditions Notes: VDD=3V, TA=25°C unless otherwise stated. Vpp 1KHz signal applied at AUXIN/ANAIN with 0db Gain setting. [3] All measurements are C-message weighted. [4] Measured with 1KHz, 100 mVpp sine wave applied to V CCA pins. [2] 1 OUT PARAMETER SYMBOL MIN TYP[1] MAX UNITS CONDITIONS AUDOUT[5] SINADAUXIN_AUDOUT 80 dB Load 5K[2][3] SINAD, ANAIN to AUDOUT[5] SINADANAIN_AUDOUT 80 dB Load 5K[2][3] PSRR[5] PSRRAUDOUT -40 dB [4] SINAD, AUXIN to DC Bias[5] Minimum Load VBIAS_AUDOUT Impedance[5] RL(AUDOUT) Capacitance[5] CL(AUDOUT) Maximum Load Output Current [6] Notes: IAUDOUT 1.2 KΩ 5 0 V 3 0.1 nF 6 mA [2][6] [1] Conditions Vcc=3V, TA=25°C unless otherwise stated. Vpp 1KHz signal applied at AUXIN/ANAIN with 0db Gain setting. [3] All measurements are C-message weighted. [4] Measured with 1Khz, 100 mVpp sine wave applied to V CCA pins. [5] Configured as AUDOUT(Voltage Output). [6] Configured as AUDOUT(Current Output). [2] 1 Jun 15, 2021 Page 13 of 21 Rev 1.6 ISD15100 SPEAKER OUTPUTS PARAMETER SYMBOL SNR, AUXIN to SPK+/SPK- SNRAUXIN_SPK SNR, ANAIN to SPK+/SPK- SNRANAIN_SPK Output Power POUT_SPK VCC=3.0 THD, AUXIN to SPK+/SPK- THD % Minimum Load Impedance RL(SPK) Notes: MIN TYP[1] MAX UNITS CONDITIONS 60 dB Load 150Ω [2][3] 60 dB Load 150Ω [2][3] mW Load 8Ω [2] 360 Load 8Ω [2]
ISD15116FYI 价格&库存
很抱歉,暂时无法提供与“ISD15116FYI”相匹配的价格&库存,您可以联系我们找货
