NAU8502YG
NAU8502YG
    NUVOTON(新唐)
    WFQFN32_EP
    ADC, Audio 24 bit Serial 32-QFN (5x5)
NAU8502YG 数据手册
NAU8502 24-bit Stereo Audio ADC with Differential Microphone Inputs 1. GENERAL DESCRIPTION The NAU8502 is a low power, high quality audio input system for portable applications. In addition to precision 24-bit stereo ADCs, this device integrates a broad range of additional functions to simplify implementation of complete audio systems. The NAU8502 includes low-noise stereo differential high gain microphone inputs with wide range programmable amplifiers, separate line inputs, and an analog bypass/side tone line level stereo output. Advanced on-chip digital signal processing includes a limiter/ALC (Automatic Level Control), 5-band equalizer, notch filter, and a high-pass filter for speech optimization and wind noise reduction. The digital interface can operate as either a master or a slave. Additionally, an internal Fractional-N PLL is available to accurately generate any audio sample rate clock for the ADCs derived using any available system clock from 8MHz through 33MHz. The NAU8502 operates with analog supply voltages from 2.7V to 3.6V, while the digital core can operate as low as 1.71V to conserve power. Internal control registers enable flexible power conserving modes, shutting down or reducing power in sub-sections of the chip under software control. The NAU8502 is specified for operation from -40°C to +85°C, and is available with full automotive AEC-Q100 and TS16949 compliant device is available upon request. 2. FEATURES 24-bit signal processing linear Audio ADC  ADC: 90dB SNR and -80dB THD (“A” weighted)  Supports any sample rates from 8KHz - 48kHz Analog I/O  Very wide range programmable input amplifier  Stereo line inputs with gain options and mixing  Stereo differential input microphone amplifiers Interfaces  Standard audio interfaces: PCM and I2S  Serial control interfaces with read/write capability) Additional features  5-band Graphic Equalizer  Automatic level control / limiter  Programmable Notch Filter  High Pass Filter/ Wind Noise Reduction Applications  Audio Recording Devices  Security Systems  Video and Still Cameras  Enhanced Audio Inputs for SOC products  Audio Input Accessory Products  Gaming Systems New Features  Passive LINE OUT  On-Chip LDO  On-chip high resolution Fractional-N PLL NAU8502 Datasheet Rev2.5 Page 1 of 93 Aug, 2018 P1OUT LLINOUT MIC1N MIC1P MIC2P MIC2N RLINOUT P2OUT 24 23 22 21 20 19 18 17 PIN CONFIGURATION P1IN 25 16 P2IN VMID 26 15 VDDA/LDOVOUT VREF 27 14 LDOVIN GPIO/SO 28 13 MICBIAS Stereo ADC QFN32 8 BCLK ADCOUT 7 9 MCLK 32 6 SDIO MODE FS 5 10 VSSD 31 4 LDOENABLE CSb VDDC 11 3 30 VDDB VSSA1 2 12 SCLK 29 1 GPIO GPIO 3. VSSA2 Figure 1: 32-Pin QFN Package NAU8502 Datasheet Rev2.5 Page 2 of 93 Aug, 2018 4. PIN DESCRIPTION Pin Name Pin No Functionality Pin Type GPIO SCLK VDDB VDDC VSSD MODE MCLK BCLK ADCOUT FS LDOENABLE VSSA2 MICBIAS LDOVIN VDDA /LDOVOUT P2IN P2OUT RLINOUT MIC2N MIC2P MIC1P MIC1N LLINOUT P1OUT P1IN VMID VREF GPIO/SO GPIO VSSA1 CSb SDIO 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 I/O I PI PI PI I I I/O O I/O I PI AO PI PI /PO AI AO AO AI AI AI, I AI, O AO AO AI AO AO I/O I/O PI I I/O 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 General Purpose IO Number One SPI or 2-Wire Serial Clock Digital Supply Buffer Digital Supply Core Digital Ground Interface Select (2-Wire:low or SPI:high) Master Clock Bit Clock Digital Audio Data Output Frame Sync Enable Internal LDO, 5V Tolerant Analog Ground Microphone Bias LDO Input Voltage (4.5V ~ 5.5V) Analog Supply, LDOVOUT when LDOENABLE > 1.8V Right Channel Stage 2 Input Right Channel Stage 1 Output Right Channel High Impedance Output Right Channel Microphone Negative Input Right Channel Microphone Positive Input Left Channel Microphone Positive Input/DM_IN Left Channel Microphone Negative Input/DM_CLK Left Channel High Impedance Output Left Channel Stage 1 Output Left Channel Stage 2 Input Decoupling internal analog mid supply reference Buffer Mid supply reference General Purpose IO Number Three, 4 Wire SPI General Purpose IO Number Two Analog Ground SPI Chip Select SPI Data In or 2-Wire I/O Table 1: Pin Description TYPE PI: Power In, PO: Power Out, AI: Analog input, AO: Analog output, I: input, O: output, I/O: bi-directional. 1. The QFN32 package includes a bulk ground connection pad on the underside of the chip. This bulk 2. Unused analog input pins should be left as no-connection. 3. Unused digital input pins should be tied to ground. ground should be thermally tied to the PCB, and electrically tied to the analog ground. NAU8502 Datasheet Rev2.5 Page 3 of 93 Aug, 2018 5. BLOCK DIAGRAM VDDB +13/+18/+28/+33dB P1OUT -12dB through +35dB gain in 0.75dB Steps in both mixing paths. VDDC LDOVIN +4.5V to +5.5V LDO Resistive Analog Mixing VDDALDOVOUT BVref MIC1N - MIC1P + S LDOENABLE ADC1 LLINOUT P1IN P2OUT BVref MIC2N - MIC2P + S RLINOUT ADC2 Optional Digital Features: ALC Mixing High-Pass Notch Filter Equalization Amplitude Peak-Detect Interrupts Out On Prescribed Conditions P2IN VMID VREF + MICROPHONE BIAS NAU8502 MICBIAS VDDA R PLL AUDIO INTERFACE (PCM/IIS) GPIO1 GPIO2 GPIO3/SO BCLK FS ADCOUT VMID CONTROL INTERFACE (2-, 3- and 4-wire) MCLK SCLK SDIO CSB/ R MODE VSSD VSSA1 VSSA2 Figure 2: NAU8502 General Block Diagram NAU8502 Datasheet Rev2.5 Page 4 of 93 Aug, 2018 6. Table of Contents 1. GENERAL DESCRIPTION .................................................................................................................................1 2. FEATURES .........................................................................................................................................................1 3. PIN CONFIGURATION .......................................................................................................................................2 4. PIN DESCRIPTION .............................................................................................................................................3 5. BLOCK DIAGRAM .............................................................................................................................................4 6. TABLE OF CONTENTS ......................................................................................................................................5 7. LIST OF FIGURES ..............................................................................................................................................9 8. LIST OF TABLES ............................................................................................................................................. 11 9. ABSOLUTE MAXIMUM RATINGS ................................................................................................................... 12 10. OPERATING CONDITIONS.............................................................................................................................. 12 11. FUNCTIONAL DESCRIPTION .......................................................................................................................... 16 11.1 SIGNAL PATH ........................................................................................................................................... 16 11.1.1 Positive Microphone Inputs (MIC1P MIC2P) ................................................................................... 17 11.1.2 Negative Microphone Inputs (MIC1N MIC2N).................................................................................. 18 11.1.3 The Single Ended Auxiliary Input (P1IN P2IN) ................................................................................ 19 11.1.4 PGA Gain Control.............................................................................................................................. 20 11.2 MICROPHONE BIASING ........................................................................................................................... 21 11.3 UNUSED ANALOG I/O AND VMID SELECTION ...................................................................................... 22 11.4 DIGITAL MICROPHONE ........................................................................................................................... 24 11.5 ADC DIGITAL FILTER BLOCK ................................................................................................................. 25 11.5.1 Programmable High Pass Filter (HPF) ............................................................................................ 26 11.5.2 Programmable Notch Filter (NF) ...................................................................................................... 26 11.5.3 Digital ADC Gain Control .................................................................................................................. 27 11.6 EQUALIZER .............................................................................................................................................. 27 11.7 PROGRAMMABLE GAIN AMPLIFIER (PGA) .......................................................................................... 28 11.7.1 Automatic level control (ALC) .......................................................................................................... 28 11.7.1.1 Normal Mode ............................................................................................................................. 31 11.7.1.2 ALC Hold Time (Normal mode Only) .......................................................................................... 31 11.7.1.3 Peak Limiter Mode ............................................................................................................................ 32 11.7.1.4 Attack Time ........................................................................................................................................ 33 11.7.1.5 Decay Times ...................................................................................................................................... 33 11.7.1.6 Noise gate (normal mode only):....................................................................................................... 33 11.7.2 Zero Crossing .................................................................................................................................... 34 11.8 GPIO .......................................................................................................................................................... 35 11.9 Clock Generation Circuit ......................................................................................................................... 37 11.9.1 Phase Locked Loop (PLL) General Description ............................................................................. 38 11.10 Serial Control Interface ............................................................................................................................ 41 11.10.1 SPI Serial Control .............................................................................................................................. 41 11.10.1.1 16-bit Write Operation (SPI 3 Wire Write) ........................................................................... 41 11.10.1.2 24-bit Write Operation (SPI 4 Wire Write) ........................................................................... 42 11.10.1.3 32-bit Read Operation (SPI 4 Wire Read) ........................................................................................ 42 11.10.2 11.10.2.1 2-Wire Serial Control Mode (I2C style Interface) .................................................................... 43 2-Wire Protocol Convention ................................................................................................ 43 NAU8502 Datasheet Rev2.5 Page 5 of 93 Aug, 2018 11.10.2.2 2-WIRE Write Operation....................................................................................................... 44 11.10.2.3 2-WIRE Read Operation ...................................................................................................... 44 11.11 DIGITAL AUDIO INTERFACES ................................................................................................................ 46 11.11.1 Right Justified audio data ................................................................................................................ 48 11.11.2 Left Justified audio data ................................................................................................................... 48 11.11.3 I2S audio data .................................................................................................................................... 49 11.11.4 PCM audio data ................................................................................................................................. 49 11.11.5 PCM Time Slot audio data ................................................................................................................ 50 11.11.6 Companding ...................................................................................................................................... 51 11.12 POWER SUPPLY ...................................................................................................................................... 52 11.12.1 Power-On Reset ................................................................................................................................ 52 11.12.2 Power Related Software Considerations ........................................................................................ 52 11.12.3 Software Reset .................................................................................................................................. 53 11.12.4 Power Up/Down Sequencing............................................................................................................ 53 11.12.5 Reference Impedance (REFIMP) and Analog Bias ......................................................................... 54 11.12.6 Power Saving..................................................................................................................................... 54 11.12.7 Estimated Supply Currents .............................................................................................................. 55 12 REGISTER DESCRIPTION............................................................................................................................... 56 12.1 Registers 0x00 0x01 2nd stage pga gain .................................................................................................... 60 12.2 Registers 0x02 0x03 audio path ................................................................................................................. 61 12.3 Register 0x04 ............................................................................................................................................. 61 12.4 Register 0x05 ADC..................................................................................................................................... 61 12.5 Register 0x06 power management ............................................................................................................ 61 ADL/ADR mapping ............................................................................................................................................. 62 12.6 Register 0x07 audio format and clocking ................................................................................................... 62 12.7 Register 0x08 audio format and clocking ................................................................................................... 63 Sample Rate register mapping ........................................................................................................................... 63 12.8 Register 0x09 analog power control ........................................................................................................... 63 12.9 Register 0x0A VMID impedance and input impedance selection ............................................................... 64 12.10 Register 0x0B Noise gate and ALC ............................................................................................................ 64 12.11 Register 0x0C ALC..................................................................................................................................... 64 12.12 Register 0x0D ALC..................................................................................................................................... 65 12.13 Register 0x0E ALC ..................................................................................................................................... 65 12.14 Register 0x0F Reset................................................................................................................................... 65 12.15 Register 0x1C ............................................................................................................................................ 65 12.16 Register 0x21 Additional power management registers (note: write-only).................................................. 66 12.17 Register 0x22 Additional audio path registers ............................................................................................ 66 12.18 Register 0x23 Additional audio path registers ............................................................................................ 66 12.19 Register 0x24 Left and Right channel select for ADCOUT ......................................................................... 66 12.20 Register 0x25 Audio format and clocking ................................................................................................... 67 12.21 Register 0x26 Clock source and division select and PLL enable ............................................................... 67 12.22 Register 0x27 Audio format and clocking ................................................................................................... 67 12.23 Register 0x28 RAM .................................................................................................................................... 68 12.24 Register 0x29 GPIO ................................................................................................................................... 68 12.25 Register 0x2A GPIO ................................................................................................................................... 68 12.26 Register 0x2C GPIO................................................................................................................................... 69 12.27 Register 0x2D GPIO................................................................................................................................... 69 NAU8502 Datasheet Rev2.5 Page 6 of 93 Aug, 2018 12.28 Register 0x2E ADC controls....................................................................................................................... 69 12.29 Register 0x2F ADC controls ....................................................................................................................... 70 12.30 Register 0x30 ADC controls ....................................................................................................................... 70 12.31 Register 0x32 Equalizer controls ................................................................................................................ 70 12.32 Register 0x33 Equalizer controls ................................................................................................................ 70 12.33 Register 0x34 Equalizer controls ................................................................................................................ 71 12.34 Register 0x35 Equalizer controls ................................................................................................................ 71 12.35 Register 0x36 Equalizer controls ................................................................................................................ 71 12.36 Register 0x37 Analog test modes .............................................................................................................. 71 12.37 Register 0x3B-0x3E Notch Filters controls ................................................................................................. 72 12.38 Register 0x44 PLL register A ..................................................................................................................... 72 12.39 Register 0x45 PLL register A ..................................................................................................................... 72 12.40 Register 0x46 PLL register A ..................................................................................................................... 72 12.41 Register 0x47 PLL register A ..................................................................................................................... 72 12.42 Register 0x4B Additional audio path registers............................................................................................ 72 12.43 Register 0x4C Additional audio path registers ........................................................................................... 73 12.44 Register 0x4D Additional audio path registers ........................................................................................... 73 12.45 Register 0x4E Additional audio path registers............................................................................................ 73 12.46 Register 0x4F PLL register B ..................................................................................................................... 73 12.47 Register 0x50 PLL register B ..................................................................................................................... 73 12.48 Register 0x51 PLL register B ..................................................................................................................... 74 12.49 Register 0x52 PLL register B ..................................................................................................................... 74 12.50 Register 0x59 ADC mixer ........................................................................................................................... 74 12.51 Register 0x5A Power management extra ................................................................................................... 74 12.52 Register 0x5B Left Channel PCM time slot Start Count ............................................................................. 75 12.53 Register 0x5C PCM and time slot Control .................................................................................................. 75 12.54 Register 0x5D Right Channel PCM time slot Start Count........................................................................... 75 12.55 Register 0x5E ID registers ......................................................................................................................... 75 12.56 Register 0x5F ID registers.......................................................................................................................... 75 12.57 Register 0x60 ID registers .......................................................................................................................... 76 12.58 Register 0x66 ALC interrupts features registers......................................................................................... 76 12.59 Register 0x67 ALC interrupts features registers......................................................................................... 76 12.60 Register 0x68 ADC and equalizer additional registers ............................................................................... 76 12.61 Register 0x69 ADC and equalizer additional registers ............................................................................... 77 12.62 Register 0x6A Tie-off registers ................................................................................................................... 77 12.63 Register 0x6B Tie-off registers ................................................................................................................... 77 12.64 Register 0x6C AGC readout registers ........................................................................................................ 77 12.65 Register 0x6D AGC readout registers ........................................................................................................ 78 12.66 Register 0x6E AGC readout registers ........................................................................................................ 78 12.67 Register 0x6F AGC readout registers ........................................................................................................ 78 12.68 Register 0x70 Noise gate readout registers ............................................................................................... 78 12.69 Register 0x71 Manual tie-off registers ........................................................................................................ 78 13 CONTROL INTERFACE TIMING DIAGRAM .................................................................................................... 79 13.1 SPI WRITE TIMING DIAGRAM .................................................................................................................. 79 13.2 2-WIRE TIMING DIAGRAM ....................................................................................................................... 80 14 AUDIO INTERFACE TIMING DIAGRAM .......................................................................................................... 81 14.1 AUDIO INTERFACE IN SLAVE MODE ...................................................................................................... 81 NAU8502 Datasheet Rev2.5 Page 7 of 93 Aug, 2018 14.2 AUDIO INTERFACE IN MASTER MODE .................................................................................................. 81 14.3 PCM AUDIO INTERFACE IN SLAVE MODE (PCM Audo Data)................................................................ 82 14.4 PCM AUDIO INTERFACE IN MASTER MODE (PCM Audo Data) ............................................................ 82 14.5 PCM AUDIO INTERFACE IN SLAVE MODE (PCM Time Slot Mode )....................................................... 83 14.6 PCM AUDIO INTERFACE IN MASTER MODE (PCM Time Slot Mode ) ................................................... 83 14.7 System Clock (MCLK) Timing Diagram ...................................................................................................... 84 14.8 µ-LAW ENCODE DECODE CHARACTERISTICS .................................................................................... 85 14.9 A-LAW ENCODE DECODE CHARACTERISTICS.................................................................................... 86 14.10 µ-LAW / A-LAW CODES FOR ZERO AND FULL SCALE ........................................................................ 87 14.11 µ-LAW / A-LAW OUTPUT CODES (DIGITAL MW) .................................................................................. 87 15 DIGITAL FILTER CHARACTERISTICS ........................................................................................................... 88 16 TYPICAL APPLICATION .................................................................................................................................. 89 PACKAGE SPECIFICATION....................................................................................................................................... 89 17 ORDERING INFORMATION ............................................................................................................................. 91 18 REVISION HISTORY ........................................................................................................................................ 92 IMPORTANT NOTICE ................................................................................................................................................. 93 NAU8502 Datasheet Rev2.5 Page 8 of 93 Aug, 2018 7. List of Figures Figure 1: 32-Pin QFN Package .....................................................................................................................................2 Figure 2: NAU8502 General Block Diagram .................................................................................................................4 Figure 3 Input path description ..................................................................................................................................... 16 Figure 4: Microphone Bias Schematic......................................................................................................................... 21 Figure 5 Tie-off Options ............................................................................................................................................... 23 Figure 6 Digital Microphone Waveforms ...................................................................................................................... 24 Figure 7: ADC Digital Filter Path Block Diagram ......................................................................................................... 25 Figure 8: ALC Block Diagram ...................................................................................................................................... 29 Figure 9: ALC Response Graph .................................................................................................................................. 29 Figure 10: ALC Normal Mode Operation ..................................................................................................................... 31 Figure 11: ALC Hold Time ........................................................................................................................................... 32 Figure 12: ALC Limiter Mode Operations .................................................................................................................... 32 Figure 13: ALC Operation with Noise Gate disabled ................................................................................................... 33 Figure 14: ALC Operation with Noise Gate Enabled ................................................................................................... 34 Figure 15: PLL and Clock Select Circuit...................................................................................................................... 37 Figure 16: Register write operation using a 16-bit SPI Interface ................................................................................. 42 Figure 17: Register Write operation using a 24-bit SPI Interface ................................................................................ 42 Figure 18: Register Read operation through a 32-bit SPI Interface ............................................................................ 43 Figure 19: Valid START Condition .............................................................................................................................. 44 Figure 20: Valid Acknowledge ..................................................................................................................................... 44 Figure 21: Valid STOP Condition ................................................................................................................................ 44 Figure 22: Slave Address Byte, Control Address Byte, and Data Byte ....................................................................... 44 Figure 23: Write Sequence(writing 1 register) ............................................................................................................. 44 Figure 24: Read Sequence (reading 1 register) .......................................................................................................... 45 Figure 25: Right Justified Audio Interface ................................................................................................................... 48 Figure 26: Left Justified Audio Interface ...................................................................................................................... 48 Figure 27: I2S Audio Interface..................................................................................................................................... 49 Figure 28: PCM Mode Audio Interface (Special mode) ............................................................................................... 49 Figure 29: PCM Time Slot Mode (Time slot = 0) (Special mode) ................................................................................ 50 Figure 30: SPI Write Timing Diagram.......................................................................................................................... 79 Figure 31: 2-Wire Timing Diagram .............................................................................................................................. 80 Figure 32: Audio Interface Slave Mode Timing Diagram ............................................................................................. 81 Figure 33: Audio Interface in Master Mode Timing Diagram ....................................................................................... 81 Figure 34: PCM Audio Interface Slave Mode Timing Diagram .................................................................................... 82 Figure 35: PCM Audio Interface Slave Mode Timing Diagram .................................................................................... 82 Figure 36: PCM Audio Interface Slave Mode (PCM Time Slot Mode )Timing Diagram.............................................. 83 NAU8502 Datasheet Rev2.5 Page 9 of 93 Aug, 2018 Figure 37: PCM Audio Interface Master Mode (PCM Time Slot Mode )Timing Diagram............................................. 83 Figure 38: MCLK Timing Diagram ............................................................................................................................... 84 Figure 39: Application Diagram For32 -Pin QFN ......................................................................................................... 89 NAU8502 Datasheet Rev2.5 Page 10 of 93 Aug, 2018 8. List of Tables Table 1: Pin Description ................................................................................................................................................3 Table 2: Register associated with Input PGA Control ................................................................................................. 17 Table 3: Microphone Non-Inverting Input Impedances................................................................................................. 18 Table 4: Microphone Inverting Input Impedances ....................................................................................................... 19 Table 5: Microphone Inverting Input Impedances ....................................................................................................... 20 Table 6: Registers associated with Input PGA Gain Control ....................................................................................... 20 Table 7: Register associated with Microphone Bias .................................................................................................... 22 Table 8: Microphone Bias Voltage Control .................................................................................................................. 22 Table 9: Register associated with ADC ....................................................................................................................... 26 Table 10: High Pass Filter Cut-off Frequencies (HPFAM=1)....................................................................................... 26 Table 11: Registers associated with Notch Filter Function.......................................................................................... 27 Table 12: Equations to Calculate Notch Filter Coefficients ......................................................................................... 27 Table 13: Register associated with ADC Gain ............................................................................................................ 27 Table 14: Equalizer Center/Cutoff Frequencies .......................................................................................................... 28 Table 15: Equalizer Gains ........................................................................................................................................... 28 Table 16: Registers associated with ALC Control ....................................................................................................... 30 Table 17: ALC Maximum and Minimum Gain Values .................................................................................................. 31 Table 18: General Purpose Control............................................................................................................................. 35 Table 19: General Purpose I/O Output Select .............................................................................................................. 36 Table 20: Registers associated with PLL .................................................................................................................... 38 Table 21: Registers associated with PLL .................................................................................................................... 39 Table 22: PLL Frequency Examples ........................................................................................................................... 40 Table 23: Control Interface Selection .......................................................................................................................... 41 Table 24: ADCOUT pin behavior selections ................................................................................................................. 46 Table 25: Standard Interface modes ........................................................................................................................... 47 Table 26: Audio Interface Control Registers ............................................................................................................... 47 Table 27: Companding Control ................................................................................................................................... 51 Table 28: Power up sequence..................................................................................................................................... 54 Table 29: Power down Sequence ............................................................................................................................... 54 Table 30: Registers associated with Power Saving..................................................................................................... 55 Table 31: VDDA 3.3V Supply Current ......................................................................................................................... 55 Table 32: SPI Timing Parameters ............................................................................................................................... 79 Table 33: 2-WireTiming Parameters ........................................................................................................................... 80 Table 34: Audio Interface Timing Parameters ............................................................................................................. 84 Table 35: MCLK Timing Parameter ............................................................................................................................. 84 NAU8502 Datasheet Rev2.5 Page 11 of 93 Aug, 2018 9. ABSOLUTE MAXIMUM RATINGS CONDITION MIN MAX Units VDDB, VDDC, VDDA supply voltages -0.3 +3.61 V LDOVIN -0.3 +5.5 V Core Digital Input Voltage range VSSD – 0.3 VDDC + 0.30 V Buffer Digital Input Voltage range VSSD – 0.3 VDDB + 0.30 V Analog Input Voltage range VSSA – 0.3 VDDA + 0.30 V Industrial operating temperature -40 +85 °C Storage temperature range -65 +150 °C CAUTION: Do not operate at or near the maximum ratings listed for extended period of time. Exposure to such conditions may adversely influence product reliability and result in failures not covered by warranty. These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. 10. OPERATING CONDITIONS Condition Symbol Min Value Analogue supplies range VDDA Digital supply range (Buffer) Digital supply range (Core) Typical Value Max Value Units 2.701 3.60 V VDDB 1.712 3.60 V VDDC 1.712 3.60 V LDO supply range LDOVIN 4.50 5.50 V Ground VSSD VSSA1 VSSA2 0 V Note 1 : VDDA ≥ VDDB Note 2 : VDDB ≥ VDDC Note3: When Using PLL, VDDA ≥ 2.7V and VDDC ≥ 1.9V NAU8502 Datasheet Rev2.5 Page 12 of 93 Aug, 2018 ELECTRICAL CHARACTERISTICS VDDC = +1.8V, VDDA = VDDB = 3.3V, LDOVIN = +5V, TA = +25oC, 1kHz signal, fs = 48kHz, 24-bit audio data unless otherwise stated. Parameter Symbol Comments/Conditions Min Typ Max Units Analog to Digital Converter (ADC) Full scale input signal 1 Signal-to-noise ratio Total harmonic distortion 2 Channel separation at 0dB gain VINFS PGABST = 0dB PGAGAIN = 0dB SNR Gain = 0dB, A-weighted THD+N tbd 1.0 0 Vrms dBV 90 dB Input = -3dB FS input -80 1kHz input signal 100 tbd dB dB Microphone Inputs (MIC1P, MIC1N, MIC2P, MIC2N, P1IN, P2IN) and Programmable Gain Amplifier (PGA) Programmable gain Programmable gain step size -12 Guaranteed Monotonic 35.25 dB 0.75 dB 110 dB 1.6 47 75 kΩ kΩ kΩ 10 pF 0 to 20kHz, Gain set to 35.25dB 120 µV First stage PGA gain (single ended on MIC1P MIC2P) Boost = 00 Boost = 01 Boost = 10 Boost = 11 13 18 28 33 dB dB dB dB First stage PGA input resistance (single ended on MIC1P MIC2P) LDC/RDC=1 LDC/RDC=0 500 kΩ kΩ PGA Gain=10.8dB Boost=00 5.4 kΩ PGA Gain=16.8dB Boost=01 3 kΩ PGA Gain=27.6dB Boost=10 955 Ω PGA Gain=32.8dB Boost=11 537 Ω 7 nV / √Hz 2.2 uV rms Mute Attenuation PGA Input resistance in single ended mode (P1IN P2IN) PGA Gain = 35.25dB PGA Gain = 0dB PGA Gain = -12dB Input capacitance PGA equivalent input noise First Stage PGA Amplifier First stage PGA Microphone Input resistance (differential mode MIC1/2P MIC1/2N) PGA1 equivalent input noise Input referred Noise voltage at 1KHz +28db At 20~20Khz, 28db NAU8502 Datasheet Rev2.5 Page 13 of 93 5000 Aug, 2018 Parameter Symbol PGA1 Signal to Noise ratio (Aweighted) Total Harmonic Distortion Comments/Conditions Min Typ Max Units At 20~20K, Vdda=2.7 28db 85 dB At 20~20K, Vdda=3.3 28db 94 dB Gain=13db, Vdda=3.3 -80 0.01 dB % Line Input to boost/mixer gain -12 Line Input step size to boost/mixer 6 dB 3 dB 0.50, 0.60,0.65, 0.70, 0.75, 0.85, or 0.90 VDDA VDDA 3 mA 1kHz to 20kHz 14 nV/√Hz LDOVIN=5V LDOENABLE>1.8V C=1uF ESR1.8V C=1uF ESR5000 18 500 >5000 28 500 >5000 33 500 >5000 Table 3: Microphone Non-Inverting Input Impedances When the associated control bit of LMICP2INPPGA, RMICP2INPPGA, LMICN2BVREF and RMICN2BVREF are set to logic = 0, the positive microphone input pins are connected to a resistor of approximately 40kΩ which is tied to VREF. The purpose of the tie to VREF is to reduce any pop or click sound by keeping the DC level of the MIC+ pin close to VREF at all times. 11.1.2 Negative Microphone Inputs (MIC1N MIC2N) The negative microphone inputs (MIC1N, MIC2N) have two distinctive configuration; differential input or single ended input. These inputs multiplex to the negative terminal of the PGA gain amplifier by setting LMICN2INPPGA1 (0x4B[1]) or RMICN2INPPGA1 (0x4C[1]) to HIGH. When the MIC1N, MIC2N are used as a single ended input, MIC1P MIC2P should be connected to VMID by setting LMICP2INPPGA, RMICP2INPPGA, LMICN2BVREF and RMICN2BVREF to LOW. The P1IN, P2IN input signals can also be mixed with the MIC1N MIC2N input signals by setting LMIC2_2INPPGA1 (0x4B[2]) and RMIC2_2INPPGA1 (0x4C[2]) to HIGH. By setting LMICN2INPPGA1 and RMICN2INPPGA1 to LOW, the pins of MIC1N and MIC2N internally connect to a resistor of approximately 30kΩ that’s tied to VREF. The purpose of the tie to VREF is to reduce any pop or click sound by keeping the DC level of the MICpin close to VREF at all times. It is important for a system designer to know that the MIC1N and MIC2N input impedances vary as a function of the selected PGA gain. This is normal and expected for a difference amplifier type NAU8502 Datasheet Rev2.5 Page 18 of 93 Aug, 2018 topology. The above table gives the nominal resistive impedance values for this input over the possible gain range. Impedance for specific gain values not listed in this table can be estimated through interpolation between listed values. In a differential configuration LMICN2INPPGA1 (0x4B[1]) or RMICN2INPPGA1 (0x4C[1]) and LMICP2INPPGA (0x4B[0]) or RMICP2INPPGA (0x4C[0]) are set to HIGH. The gain, listed in Table 4, is less than in the MIC1P MIC2P single-ended configuration explained in chapter 12.1.1. MICN to inverting PGA input MICN and MICP to inverting and non-inverting PGA inputs Nominal Input Impedance Gain (dB) Impedance (kΩ) 10.8 16.83 27.65 32.8 5.373 3.021 0.955 0.537 Table 4: Microphone Inverting Input Impedances 11.1.3 The Single Ended Auxiliary Input (P1IN P2IN) The single ended auxiliary inputs have two different paths. • Directly connected to the first stage Programmable Gain amplifier • Used in conjunction with P[1-2]OUT as AC coupled input to the second stage PGA The second-stage PGA gain ranges from -12dB to +35.25 dB with 0.75db step. The two paths above go through the ADC filters where the ALC loop may be used to control the amplitude of the input signal. The device also has an internal configurable biasing circuit for biasing the microphone, reducing external components. When LMIC2_2INPPGA2 and RMIC2_2INPPGA2 are set to LOW, the single ended auxiliary input pins are connected to a resistor of approximately 30kΩ which is tied to VREF. The purpose of the tie to VREF is to reduce any pop or click sound by keeping the DC level of the P[1-2]IN pin close to VREF at all times. MICN PIN to inverting PGA input Nominal Input Impedance NAU8502 Datasheet Rev2.5 Gain (dB) Impedance (kΩ) -12 -9 -6 -3 0 3 6 9 75 69 63 55 47 39 31 25 Page 19 of 93 Aug, 2018 MICN PIN to inverting PGA input Nominal Input Impedance Gain (dB) Impedance (kΩ) 12 18 30 35.25 19 11 2.9 1.6 Table 5: Microphone Inverting Input Impedances 11.1.4 PGA Gain Control The two stages of PGA amplification have independent gain settings. The first stage PGA, also called mic pre-amp or boost, is enabled by LMBE and RMBE (0x02[4] 0x03[4]). The first stage PGA has four fixed gain settings +13dB, +18dB. +28dB, +33dB controlled by LMICBOOST (0x2[6:5]) and RMICBOOST (0x3[6:5]). The mute registers LMBMUTE and RMBMUTE are reserved and cannot be used. When LMBE and RMBE are disabled, the first stage PGA is automatically bypassed and routed to the input of the second stage PGA. The second stage PGA has a range of -12dB to +35.25dB in 0.75dB steps, controlled by INPPGALVOL (0x4D) INPPGARVOL (0x4E). Registers LINVOL 99i and RINVOL 0x01 may also be used to set the second stage PGA gain that are eventually mapped to INPPGALVOL and INPPGARVOL. Second stage Input PGA gain will not take effect when ALC is enabled using register ALCEN (0xC[8:7]). Zero crossing on the first stage PGA is enabled with LMZC (0x2[3]) and RMZC(0x3[3]). Zero crossing on the second stage PGA is enabled with LPZC (0x2[2]) and RPZC (0x3[2]). Addr Bit 8 0x02 0 0x03 0 0x4D 0 0x4E 0 Bit 7 Bit 6 Bit5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Default LMICBOOST LMBE LMZC LPZC 0x007 RMICBOOST RMBE RMZC RPZC 0x007 LMBMUTE INPPGALVOL 0x010 RMBMUTE INPPGARVOL 0x010 Table 6: Registers associated with Input PGA Gain Control NAU8502 Datasheet Rev2.5 Page 20 of 93 Aug, 2018 11.2 MICROPHONE BIASING Figure 4: Microphone Bias Schematic The MICBIAS pin is a low-noise microphone bias source for an external microphone, which can provide a maximum of 3mA of bias current. This DC bias voltage is suitable for powering either traditional ECM (electret) type microphones, or for MEMS types microphones with an independent power supply pin. Seven different bias voltages are available for optimum system performance, depending on the specific application. The microphone bias pin normally requires an external filtering capacitor as shown on the schematic in the Application section. It has various voltage values selected by a combination of bits MICBIASM[4] address (0x5A) and MICBIASV[1:0] address (0x06). NAU8502 Datasheet Rev2.5 Page 21 of 93 Aug, 2018 When MICBIASM[4] is set to HIGH, low-noise is achieved by an internal resistor of approximately 200-ohms in series with the output pin. This creates a low pass filter in conjunction with the external microphone-bias filter capacitor, but without any additional external components. Bit(s) Addr Parameter MICBIASM 0x05A[4] Microphone bias mode selection MICBIASV 0x06[1:0] Microphone bias voltage selection Programmable Range 0=default larger cap on micbias 1=lower cap on micbias 00 off 01 0.75*VDDA 10 0.9*VDDA 11 0.5*VDDA Table 7: Register associated with Microphone Bias Below are the unloaded values when MICBIASM[4] is set to 1 and 0. When loaded, the series resistor will cause the voltage to drop, depending on the load current. Microphone Bias Voltage Control MICBIASV[1:0] MICBIASM[4] = 0 MICBIASM[4]= 1 off 0 0 off 0 1 0.75* VDDA 0.70* VDDA 1 0 0.9* VDDA 0.85* VDDA 1 1 0.50* VDDA 0.50* VDDA Table 8: Microphone Bias Voltage Control 11.3 UNUSED ANALOG I/O AND VMID SELECTION NAU8502 Datasheet Rev2.5 Page 22 of 93 Aug, 2018 TIEOFF[5] (0x71) P1IN 30k 1K LMIC2_2INPPGA2[6] (0x4B) MIC1N 30k LMICN2INPPGA1[1] (0x4B) MIC1P 40k LMICP2INPPGA[0] (0x4B) 500k LDC[1] (0x0A) VMID[8] (0x06) VREF VMID R BUFIOEN[3] (0x21) VMIDSEL[3:2] (0x0A) VREF[7] (0x06) R SHORTBUFL[6] (0x71) VMID[8] (0x06) 0x6A[8] 0x6B[2:0] Figure 5 Tie-off Options In audio and voice systems, any time there is a sudden change in voltage to an audio signal, an audible pop or click sound may be the result. Systems that change input and output configurations dynamically, or which are required to manage low power operation, need special attention to possible pop and click situations. The NAU8502 includes many features which may be used to greatly reduce or eliminate pop and click sounds. The most common cause of a pop or click signal is a sudden change to an input or output voltage. This may happen in either a DC coupled system, or in an AC coupled system. The strategy to control pops and clicks is similar for either a DC coupled system, or an AC coupled system. The case of the AC coupled system is the most common and the more difficult situation, and therefore, the AC coupled case will be the focus for this information section. When an input or output pin is being used, the DC level of that pin will be very close to half of the VDDA voltage that is present on the VMID pin. In all cases, any input or output capacitors will become charged to the operating voltage of the used input or output pin. The goal to reduce pops and clicks is to insure that the charge voltage on these capacitors does not change suddenly at any time. In order to use the tie-off on the VREF buffer REGENABLE[8] 0x71 must be set to 1. When an input or output is in a not-used operating condition, it is desirable to keep the DC voltage on that pin at the same voltage level as the DC level of the used operating condition. This is accomplished using special internal DC NAU8502 Datasheet Rev2.5 Page 23 of 93 Aug, 2018 voltage sources that are at the required DC values. When an input or output is in the not-used condition, it is connected to the correct internal DC voltage as not to have a pop or click. This type of connection is known as a “tie-off” condition. Outputs will automatically be tied to the VMID voltage value. The input pullups are connected to BUFIOEN[3] address (0x21) buffer with a voltage source (VMID). The output pullups can be connected to the same buffer. Automatic internal logic determines whether an input or output pin is in the used or un-used condition. This logic function is always active. An output is determined to be in the un-used condition when it is in the disabled unpowered condition, as determined by the power management registers. An input is determined to be in the un-used condition when all internal switches connected to that input are in the “open” condition. 11.4 DIGITAL MICROPHONE The digital microphone interface is enabled by setting register EN_DIG_MIC_L (0x68[4]) or EN_DIG_MIC_R (0x68[5]). NAU8502 can support up to two digital microphones through pin MIC1P. When pin MIC1N is configured as DM_CLK output, NAU8502 will generate a clock signal in the range of 1-4Mhz to support the digital microphone operation. Volume control for the digital microphone can be set in two ways. If ALCEN (0xC) is off, volume control for the digital microphone is provided by ADCVOLL (0x2f) and ADCVOLR(0x30). If ALCEN is on, volume control is set by the ALC registers in address 0xC. MCLK DM_CLK DMIC1 (Left Channel) DATA1 HI-Z DATA1 DMIC2 (Right Channel) HI-Z DATA2 HI-Z DM_IN (swap_dm_dfe (0x68[6] = 0) DATA1 DATA2 DATA1 DATA1 DATA2 DM_IN (swap_dm_dfe (0x68[6] = 1) DATA2 Figure 6 Digital Microphone Waveforms NAU8502 Datasheet Rev2.5 Page 24 of 93 Aug, 2018 11.5 ADC DIGITAL FILTER BLOCK ADC Digital Filters ADC Digital Decimator Digital Filter / Gain High Pass Filter Notch Filter Digital Audio Interface Figure 7: ADC Digital Filter Path Block Diagram The ADC digital filter block performs a 24-bit signal processing. The block consists of an oversampled analog sigmadelta modulator, digital decimator, digital filter, high pass filter, and a notch filter. The oversampled analog sigma-delta modulator provides a bit stream to the decimation stages and filter. The ADC coding scheme is in twos-complement format and the full-scale input level is proportional to VDDA. With a 3.3V supply voltage, the full-scale level is 1.0VRMS and any voltage greater than full scale may overload the ADC and cause distortion. The ADC is enabled by setting ADL[3] and ADR[2] in address (0x06) to HIGH. Polarity and oversampling rate of the ADC output signal can be changed by POLARITY[6:5] address (0x05) and ADCOSR[3] address (0x2E) respectively. Bit(s) Addr Parameter POLARITY[6:5] 0x05 ADC Polarity ADCOSR[3] 0x2E ADC Over Sample Rate Programmable Range 00 no inversion on ADC data 01 Left (1) inverted 10 Right (2) inverted 11 both inverted 0=64x (Lowest power) 1=128x (best SNR at typical condition) ADCHPD[0] 0x05 High Pass Filter Disable 0 = Enable 1 = Disable HPFAPP[7] 0x2E Audio or Application Mode 0 = Audio (1st order, fc ~ 3.7 Hz) 1 = Application (2nd order, fc = HPFCUT) HPFCUT[6:4] 0x2E High Pass Filter frequencies 82 Hz to 612 Hz dependant on the sample rate ADL[3] 0x02 Enable Left Channel ADC 0 = Disable 1 = Enable ADR[2] 0x02 Enable Right Channel ADC 0 = Disable 1 = Enable SMPLR[3:1] 0x27 Sample rate 8k Hz to 48 kHz NAU8502 Datasheet Rev2.5 Page 25 of 93 Aug, 2018 Table 9: Register associated with ADC 11.5.1 Programmable High Pass Filter (HPF) The high pass filter (HPF) has two different modes that it can operate in either Audio or Application mode HPFAPP[7] address (0x2E). In Audio Mode (HPFAPP=0) the filter is first order, with a cut-off frequency of 3.7kHz. In Application mode (HPFAPP=1) the filter is second order, with a cut-off frequency selectable via the HPFCUT[6:4] register bits. Cut-off frequency of the HPF depends on sample frequency selected by SMPLR[3:1] address (0x27). The HPF is enabled by setting ADCHPD[0] address (0x05) to LOW. Table below shows the cut-off frequencies with different sampling rate. HPFCUT[6:4] SMPLR=101/100 11.025 12 8 fs (kHz) SMPLR=011/010 16 22.05 24 SMPLR=001/000 32 44.1 48 000 82 113 122 82 113 122 82 113 122 001 102 141 153 102 141 153 102 141 153 010 131 180 156 131 180 156 131 180 156 011 163 225 245 163 225 245 163 225 245 100 204 281 306 204 281 306 204 281 306 101 261 360 392 261 360 392 261 360 392 110 327 450 490 327 450 490 327 450 490 111 408 563 612 408 563 612 408 563 612 Table 10: High Pass Filter Cut-off Frequencies (HPFAM=1) 11.5.2 Programmable Notch Filter (NF) Each ADC is optionally supported by a notch filter in the digital output path. Filter operation and settings are always the same for both left and right channels. A notch filter is useful to filter out a very narrow band of audio frequencies in a stop band around a given center frequency. The notch filter is enabled by setting NFCEN (0x3B[7]) to 1. The center frequency is programmed by setting registers 0x3B, 0x3C, 0x3D, and 0x3E, bits 0 to 6 (NFA0[13:7], NFA0[6:0], NFA1[13:7], NFA1[6:0]), with two’s complement coefficient values calculated using Table 12. Registers that affect operation of the notch filter are: 0x3B Notch filter enable/disable 0x3B Notch filter a0 coefficient high order bits and update bit 0x3C Notch filter a0 coefficient low order bits and update bit 0x3D Notch filter a1 coefficient high order bits and update bit 0x3E Notch filter a1 coefficient low order bits and update bit Important: The register update bits are write-only bits. The update bit function is important so that all filter coefficients actively being used are changed simultaneously, even though these register values must be written sequentially. When there is a write operation to any of the filter coefficient settings, but the update bit is not set (value = 0), the value is NAU8502 Datasheet Rev2.5 Page 26 of 93 Aug, 2018 stored as pending for the future, but does not go into effect. When there is a write operation to any coefficient register, and the update bit is set (value = 1), then the new value in the register being written is immediately put into effect, and any pending coefficient value is put into effect at the same time. Coefficient values are in the form of 2’s-complement integer values, and must be calculated based upon the desired filter properties. The mathematical operations for calculating these coefficients are detailed in the following table. Addr Bit 8 Bit 7 Bit 6 Bit5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Default 0x3B NFCU NFCEN NFCA0[13:7] 0x000 0x3C NFCU 0 NFCA0[6:0] 0x000 0x3D NFCU 0 NFCA1[13:7] 0x000 0x3E NFCU 0 NFCA1[6:0] 0x000 Table 11: Registers associated with Notch Filter Function A0 Coefficient A1  2 π fb 1 − tan   2 fs   2 π fb 1 + tan   2 fs          − (1 + A0 )  2 π fc   x cos    fs   Notation Register Value (DEC) fc = center frequency (Hz) fb = -3dB bandwidth (Hz) fs = sample frequency (Hz) NFCA0 = -A0 x 213 NFCA1 = -A1 x 212 (then convert to 2’s complement) Table 12: Equations to Calculate Notch Filter Coefficients 11.5.3 Digital ADC Gain Control The digital ADC can be muted by setting “0000 0000” to ADCVOLL[7:0] address (0x2F) for the left channel or ADCVOLR[7:0] address (0x30) for the right channel. Any other combination digitally attenuates the ADC output signal in the range -127dB to 0dB in 0.5dB increments]. The gain setting takes effect only when the update bit in the MSB of the gain register is set. Addr Name Bit 8 Bit 7 Bit 6 Bit5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Default 0x2F ADCG ADCVU ADCVOLL 0x0FF 0x30 ADCG ADCVU ADCVOLR 0x0FF Table 13: Register associated with ADC Gain 11.6 EQUALIZER The NAU8502 includes a 5-band graphic equalizer with low distortion, low noise, and wide dynamic range. The equalizer is applied to both left and right channels. Registers that affect operation of the 5-Band Equalizer are: 0x32 Band 1 gain control and cut-off frequency 0x33 Band 2 gain control, center cut-off frequency, and bandwidth 0x34 Band 3 gain control, center cut-off frequency, and bandwidth 0x35 Band 4 gain control, center cut-off frequency, and bandwidth 0x36 Band 5 gain control and cut-off frequency NAU8502 Datasheet Rev2.5 Page 27 of 93 Aug, 2018 Each of the five equalizer bands is independently adjustable for maximum system flexibility, and each offers up to 12dB of boost and 12dB of cut with 1dB resolution. The high and the low bands are shelving filters (high-pass and low-pass, respectively), and the middle three bands are peaking filters. Details of the register value settings are described below. Response curve examples are provided in the Appendix of this document. Register Value 00 01 10 11 1 (High Pass) Register 18 Bits 5 & 6 EQ1CF 80Hz 105Hz 135Hz 175Hz Equalizer Band 3 (Band Pass) Register 20 Bits 5 & 6 EQ3CF 650Hz 850Hz 1.1kHz 1.4kHz 2 (Band Pass) Register 19 Bits 5 & 6 EQ2CF 230Hz 300Hz 385Hz 500Hz 4 (Band Pass) Register 21 Bits 5 & 6 EQ4CF 1.8kHz 2.4kHz 3.2kHz 4.1kHz 5 (Low Pass) Register 22 Bits 5 & 6 EQ5CF 5.3kHz 6.9kHz 9.0kHz 11.7kHz Table 14: Equalizer Center/Cutoff Frequencies Register Value Binary Hex 00000 00h 00001 01h 00010 02h ---01100 0Ch 01101 17h ---11000 18h 11001 to 11111 19h to 1Fh Gain Registers +12db +11dB +10dB Increments 1dB per step 0dB -11dB Increments 1dB per step -12dB Reserved Bits 0 to 4 in registers 18 (EQ1GC) 19 (EQ2GC) 20 (EQ3GC) 21 (EQ4GC) 22 (EQ5GC) Table 15: Equalizer Gains 11.7 PROGRAMMABLE GAIN AMPLIFIER (PGA) The NAU8502 has a programmable gain amplifier (PGA) which controls the gain such that the signal level of the PGA remains substantially constant as the input signal level varies within a specified dynamic range. The Automatic Level Control (ALC) can operate in either normal mode or limiter mode. The Automatic Level Control (ALC) seeks to control the PGA gain in response to the amplitude of the input signal such that the PGA output maintains a constant envelope. A digital peak detector monitors the input signal amplitude and compares it to a register defined threshold level ALCSL[3:0] address (0x0C). 11.7.1 Automatic level control (ALC) NAU8502 Datasheet Rev2.5 Page 28 of 93 Aug, 2018 The ALC seeks to control the PGA gain such that the PGA output maintains a constant envelope. This helps to prevent clipping at the input of the sigma delta ADC while maximizing the full dynamic range of the ADC. The ALC monitors the output of the ADC, measured after the digital decimator has converted it to 1.23 fixed-point formats. The ADC output is fed into a peak detector, which updates the measured peak value whenever the absolute value of the input signal is higher than the current measured peak. The measured peak gradually decays to zero unless a new peak is detected, allowing for an accurate measurement of the signal envelope. Based on a comparison between the measured peak value and the target value, the ALC block adjusts the gain control, which is fed back to the PGA. Rate Convert/ Decimator Input Pin PGA ADC Sinc Filter Digital Decimator Digital Filter ALC Figure 8: ALC Block Diagram The ALC is enabled by setting ALCEN[8:7] address (0x0C) bit HIGH. The ALC has two functional modes, which is set by ALCMODE[5] address (0x0D).  Normal mode (ALCMODE = LOW)  Peak Limiter mode (ALCMODE = HIGH) When the ALC is disabled, the input PGA remains at the last controlled value of the ALC. An input gain update must be made by writing to the PGAGAIN[5:0] address (0x4D). A digital peak detector monitors the input signal amplitude Output Level and compares it to a register defined threshold level ALCSL[3:0] address (0x0C). Input < noise gate threshold ALC operation range Target ALCSL -6dB Gain (Attenuation) Clipped at ALCMNGAIN -12dB +33 dB PGA Gain 0 dB -12 dB ALCNEN = 1 ALCNTH = -39dB MIC Boost Gain = 0dB ALCSL = -6dB ALCMNGAIN = -12dB ALCMXGAIN = +35.25dB -39dB -39dB -6dB +6dB Input Level Figure 9: ALC Response Graph NAU8502 Datasheet Rev2.5 Page 29 of 93 Aug, 2018 The registers listed in the following section allow configuration of ALC operation with respect to:  ALC target level  Gain increment and decrement rates  Minimum and maximum PGA gain values for ALC operating range  Hold time before gain increments in response to input signal  Inhibition of gain increment during noise inputs  Limiter mode operation Bit(s) Addr Parameter Programmable Range ALCMINGAIN[7:5] 0x0B Minimum Gain of PGA Range: -12dB to +30dB @ 6dB increment Range: ALCTABLESEL = 0: -28.5dB to -6dB @ 1.5dB increment ALCTABLESEL = 1 -22.5dB to -1.5dB @ 1.5dB increment ALCSL[3:0] 0x0C ALC Target ALCMAXGAIN[6:4] 0x0C Maximum Gain of PGA Range: -6.75dB to +35.25dB @ 6dB increment ALCEN[8:7] 0x0C Enable ALC function 00 = ALC disabled 01 = Right channel ALC enabled 10 = Left channel ALC enabled 11 = Both channels ALC enabled ALCHLD[3:0] 0x0D ALC Hold Time Range: 0ms to 1s, time doubles with every step) ALCZCE[4] 0x0D ALC Zero Crossing 0 = Disable 1 = Enable ALCMODE[5] 0x0D ALC Select ALCATK[3:0] 0x0E ALC Attack time ALCDCY[7:4] 0x0E ALC Decay time ALCTABLESEL[8] 0x66 ALCTABLESEL 0 = ALC mode 1 = Limiter mode ALCMODE =0 - Range: 125us to 128ms =1 - Range: 31us to 32ms (time doubles with every step) Note: parameters refer to time to update one 0.75 dB step ALCMODE =0 - Range: 500us to 512ms =1 - Range: 125us to 128ms (Both ALC time doubles with every step) Note: parameters refer to time to update one 0.75 dB step 0 = ALCSL range -28.5:-6dB 1 = ALCSL range -22.5:-1.5 dB Table 16: Registers associated with ALC Control The operating range of the ALC is set by ALCMAXGAIN[6:4] address (0x0C) and ALCMINGAIN[7:5] address (0x0B) bits such that the PGA gain generated by the ALC is between the programmed minimum and maximum levels. When the ALC is enabled, the PGA gain setting from INPPGAVOLL and INPPGAVOLR (0x4D and 0x4E) has no effect. NAU8502 Datasheet Rev2.5 Page 30 of 93 Aug, 2018 In Normal mode, the ALCMXGAIN bits set the maximum level for the PGA in the ALC mode but in the Limiter mode ALCMXGAIN has no effect because the maximum level is set by the initial PGA gain setting upon enabling of the ALC. ALCMAXGAIN Maximum Gain (dB) ALCMINGAIN Minimum Gain (dB) 111 110 35.25 29.25 000 001 -12 -6 ALC Max Gain Range 35.25dB to -6dB @ 6dB increments 001 000 ALC Min Gain Range -12dB to 30dB @ 6dB increments -0.75 -6.75 110 111 24 30 Table 17: ALC Maximum and Minimum Gain Values 11.7.1.1 Normal Mode Normal mode is selected when ALCMODE[5] address (0x0D) is set LOW and the ALC is enabled by setting either of the ALCEN[8:7] bits address (0x0C) HIGH. This block adjusts the PGA gain setting up and down in response to the input level. A peak detector circuit measures the envelope of the input signal and compares it to the target level set by ALCSL[3:0] address (0x0C). The ALC increases the gain when the measured envelope is less than (target – 1.5dB) and decreases the gain when the measured envelope is greater than the target. The following waveform illustrates the behavior of the ALC. PGA Input PGA Output PGA Gain Figure 10: ALC Normal Mode Operation 11.7.1.2 ALC Hold Time (Normal mode Only) The hold parameter ALCHT[3:0] address (0x0D) configures the time between detection of the input signal envelope being outside of the target range and the actual gain increase. NAU8502 Datasheet Rev2.5 Page 31 of 93 Aug, 2018 Input signals with different characteristics (e.g., voice vs. music) may require different settings for this parameter for optimal performance. Increasing the ALC hold time prevents the ALC from reacting too quickly to brief periods of silence such as those that may appear in music recordings; having a shorter hold time, on the other hand, may be useful in voice applications where a faster reaction time helps to adjust the volume setting for speakers with different volumes. The waveform below shows the operation of the ALCHT parameter. PGA Input PGA Output PGA Gain Hold Delay Change Figure 11: ALC Hold Time 11.7.1.3 Peak Limiter Mode Peak Limiter mode is selected when ALCMODE[5] address (0x0D) is set to HIGH and the ALC is enabled by setting ALCEN[8:7] address (0x0C). In limiter mode, the PGA gain is constrained to be less than or equal to the gain setting at the time the limiter mode is enabled. In addition, attack and decay times are faster in limiter mode than in normal mode as indicated by the different lookup tables for these parameters for limiter mode. The following waveform illustrates the behavior of the ALC in Limiter mode in response to changes in various ALC parameters. PGA Input PGA Output PGA Gain Limiter Enabled Figure 12: ALC Limiter Mode Operations NAU8502 Datasheet Rev2.5 Page 32 of 93 Aug, 2018 When the input signal exceeds 87.5% of full scale, the ALC block ramps down the PGA gain at the maximum attack rate (ALCATK=0000) regardless of the mode and attack rate settings until the ADC output level has been reduced below the threshold. This limits ADC clipping if there is a sudden increase in the input signal level. 11.7.1.4 Attack Time When the absolute value of the ADC output exceeds the level set by the ALC threshold, ALCSL[3:0] address (0x0C), attack mode is initiated at a rate controlled by the attack rate register ALCATK[3:0] address (0x0E). The peak detector in the ALC block loads the ADC output value when the absolute value of the ADC output exceeds the current measured peak; otherwise, the peak decays towards zero, until a new peak has been identified. This sequence is continuously running. If the peak is ever below the target threshold, then there is no gain decrease at the next attack timer time; if it is ever above the target-1.5dB, then there is no gain increase at the next decay timer time. 11.7.1.5 Decay Times The decay time ALCDCY[7:4] address (0x0E) is the time constant used when the gain is increasing. In limiter mode, the time constants are faster than in ALC mode. 11.7.1.6 Noise gate (normal mode only): A noise gate is used when there is no input signal or the noise level is below the noise gate threshold. The noise gate is enabled by setting NGAT[0] address (0x0B) to HIGH. It does not remove noise from the signal. The noise gate threshold NGTH[4:2] address (0x0B) is set to a desired level so when there is no signal or a very quiet signal (pause), which is composed mostly of noise, the ALC holds the gain constant instead of amplifying the signal towards the target threshold. The noise gate only operates in conjunction with the ALC (ALCEN[8:7] 0x0C) and ONLY in Normal mode. The noise gate flag is asserted when (Signal at ADC – PGA gain – MIC Boost gain) < ALCNTH (ALC Noise Gate Threshold) (dB) Levels at the extremes of the range may cause inappropriate operation, so care should be taken when setting up the function. PGA Input PGA Output PGA Gain Figure 13: ALC Operation with Noise Gate disabled NAU8502 Datasheet Rev2.5 Page 33 of 93 Aug, 2018 PGA Input Noise Gate Threshold PGA Output PGA Gain Figure 14: ALC Operation with Noise Gate Enabled 11.7.2 Zero Crossing The PGA gain comes from either the ALC block when it is enabled or from the PGA gain register setting when the ALC is disabled. Zero crossing detection may be enabled to cause PGA gain changes to occur only at an input zero crossing. Enabling zero crossing detection limits clicks and pops that may occur if the gain changes while the input signal has a high volume. There are two zero crossing detection enables:  Register ALCZCE[8] address (0x0D) – is only relevant when the ALC is enabled.  Register PGAZC[2] address (0x02, 0x03) – is only relevant when the ALC is disabled. If the zero crossing function is enabled (using either register) and SLOWCLKEN[0] address (0x27) is asserted, the zero cross timeout function may take effect. If the zero crossing flag does not change polarity within 0.25 seconds of a PGA gain update (either via ALC update or PGA gain register update), then the gain will update. This backup system prevents the gain from locking up if the input signal has a small swing and a DC offset that prevents the zero crossing flag from toggling. The slow clock timer at address 0x27[0] controls features that happen over a relatively long period of time. This enables the NAU8502 to implement long time-span features without any host/processor management or intervention. The Slow clock timer is initialized in the disabled state but is automatically asserted when zero crossing is enabled. NAU8502 Datasheet Rev2.5 Page 34 of 93 Aug, 2018 The slow clock timer rate is derived from MCLK using an integer divider that is compensated for the sample rate as indicated by the register address (0x08/0x27). If the sample rate register value precisely matches the actual sample rate, then the internal slow clock timer rate will be a constant value of 128ms. If the actual sample rate is, for example, 44.1kHz and the sample rate selected in register 0x27 is 48kHz, the rate of the slow clock timer will be approximately 10% slower in direct proportion of the actual vs. indicated sample rate. This scale of difference should not be important in relation to the dedicated end uses of the slow clock timer. 11.8 GPIO There are three GPIO pins can be used for; Addr D8 D7 D6 D5 D4 D3 0x29 GPIO_PS[2:0] GPIO_PE[2:0] 0x2A GPIO3_OUT_SEL[2:0] GPIO2_OUT_SEL[2:0] 0x2B 0x2C D2 D1 0x2D Default GPIO_OE[2:0] 0x000 GPIO1_OUT_SEL[2:0] 0x000 GPIO3_IN INT_POL D0 GPIO2_IN GPIO1_IN Clip2_INTE Clip1_INTE GPIO3_INTE GPIO2_INTE GPIO1_INTE Clip2_INT Clip1_INT GPIO3_INT GPIO2_INT GPIO1_INT 0x000 Table 18: General Purpose Control GPIO_OE[2:0] is used to configure the GPIO1, GPIO2, GPIO3 as input or output pins. If GPIO_OE[2]=1 GPIO3 is configured as output pin. If GPIO_OE[2]=0 GPIO3 is not configure as input or output pin. See register 0x5A[0] to configure as input pin. If GPIO_OE[1]=1 GPIO2 is configured as output pin. NAU8502 Datasheet Rev2.5 Page 35 of 93 Aug, 2018 If GPIO_OE[1]=0 GPIO2 is configure as input pin. If GPIO_OE[0]=1 GPIO1 is configured as output pin. If GPIO_OE[0]=0 GPIO1 is configure as input pin. GPIO_PE[2:0] is used for GPIO3, GPIO2, GPIO1 pull up/down enable. It is functional only when the GPIO is set to input pin. GPIO_PS[2:0] is used for GPIO3, GPIO2, GPIO1 pull up/down select. If a GPIO’s OE=0, PE=1, PS=1, it is weak pulled up. If a GPIO’s OE=0, PE=1, PS=0, it is weak pulled down. GPIOX_OUT_SEL[2:0] (where X=1,2,3 for GPIO1, GPIO2, GPIO3) is used as GPIO output function MUX select, when this GPIO is set as output pin. GPIOX_OUT_SEL 000 001 010 011 100 101 110 111 GPIO Output function Output 0 Output 1 Output PLL Clock Output PLL Lock Output MCLK_PIN Output INT/INTB(note) Output I2S Master FS Output I2S Master BCLK Table 19: General Purpose I/O Output Select Note: when INT_POL=1, output INTB (low active interrupt), when INT_POL=0, output INT (high active interrupt) GPIOX_INTE (where X=1,2,3 for GPIO1, GPIO2, GPIO3) is used as GPIO pin trigger interrupt enable. GPIOX_INT (where X=1,2,3 for GPIO1, GPIO2, GPIO3) is used as GPIO trigger interrupt flag. When GPIOX_INTE is 1 and GPIOX_OE=0, is a rising or falling edge happen, INT/INTB will be asserted (if one of GPIO out is set to select INT/INTB out), user should read REG0x2D (interrupt flags) to check which GPIO is generating Interrupt. Write 1 to corresponding interrupt flag bit will clear the interrupt. Then, the interrupt flag will be cleared and INT pin will be reset. REG0x2B bit 2, bit 1, bit 0, can be read through I2C or SPI to check the status the GPIO3, GPIO2, GPIO1 input level. NAU8502 Datasheet Rev2.5 Page 36 of 93 Aug, 2018 11.9 Clock Generation Circuit The PLL is fully programmable. PLLA Any frequencies from 8MHz to 27MHz Output frequency depends on the PLL registers setting below PLLB Choose frequency coefficient A or coefficient B with PLLREGSEL 0x4F[5] Figure 15: PLL and Clock Select Circuit ADCOSR[3] (0x2E) fPLL PLLMCLK[4] (0x44) f1 MCLK f/2 PLL1 R=f2/f1 f2 MCLKSEL[7:5] (0x26) f/ N f/4 f/ N IMCLK CLKM[8] (0x26) PLL BLOCK BCLKSEL[4:2] (0x26) … GPIO[3:1] GPIOX_OUT_SEL[8:6 or 5:3 or 2:0] (0x2A) where X=1,2,3 ADC f/ N GPIO_PLLDIV[5:4] (0x28) Digital Audio Interface IMCL K/N IMCL K/256 MS[6] (0x07) FS BCLK The 8502 has two clock modes that support the ADC converter. It can accept external clocks in the slave mode, or in the master mode, it can generate the required clocks from an external reference frequency using an internal PLL (Phase Locked Loop). The internal PLL is a fractional type scaling PLL, and therefore, a very wide range of external reference frequencies can be used to create accurate audio sample rates. Separate from this ADC clock subsystem, audio data are clocked to and from the 8502 by means of the control logic described in the Digital Audio Interfaces section. The Frame Sync (FS) and Bit Clock (BCLK) pins in the Digital Audio Interface manage the audio bit rate and audio sample rate for this data flow. NAU8502 Datasheet Rev2.5 Page 37 of 93 Aug, 2018 It is important to understand that the Digital Audio Interface does not determine the sampling rate for the ADC data converters, and instead, this rate is derived exclusively from the Internal Master Clock (IMCLK). It is therefore a requirement that the Digital Audio Interface and data converters be operated synchronously, and that the FS, BCLK, and IMCLK signals are all derived from a common reference frequency. If these three clock signals are not synchronous, audio quality will be reduced. The IMCLK is always exactly 256 times the sampling rate of the data converters. IMCLK is output from the Master Clock Prescaler. The prescaler reduces by an integer division factor the input frequency input clock. The source of this input frequency clock is either the external MCLK pin, or the output from the internal PLL Block. In Master Mode, the IMCLK signal is used to generate FS and BCLK signals that are driven onto the FS and BCLK pins and input to the Digital Audio Interface. FS is always IMCLK/256 and the duty cycle of FS is automatically adjusted to be correct for the mode selected in the Digital Audio Interface. The frequency of BCLK may optionally be divided to optimize the bit clock rate for the application scenario. In Slave Mode, there is no connection between IMCLK and the FS and BCLK pins. In this mode, FS and BCLK are strictly input pins, and it is the responsibility of the system designer to ensure that FS, BCLK, and IMCLK are synchronous and scaled appropriately for the application. Addr D8 0x07 0x26 CLKM D7 D6 SDODIS MS D5 D4 D3 FSP MCLKSEL[2:0] D2 D1 WLEN FORMAT BCLKSEL[2:0] 0x27 PLLEN SMPLR[3:1] 0x44 PLLMCLK 0x45 D0 Default 0A 0x140 SLOWCLKEN PLLN_A[3:0] 0x000 0x008 PLLK_A[23:18] 0x00C 0x46 PLLK_A[17:9] 0x093 0x47 PLLK_A[8:0] 0x0E9 0x44 PLLREGSEL PLLMCLK 0x45 PLLN_B[3:0] 0x008 PLLK_B[23:18] 0x00C 0x46 PLLK_B[17:9] 0x093 0x47 PLLK_B[8:0] 0x0E9 Table 20: Registers associated with PLL 11.9.1 Phase Locked Loop (PLL) General Description The PLL may be optionally used to multiply an external input clock reference frequency by a high resolution fractional number. To enable the use of the widest possible range of external reference clocks, the PLL block includes an optional divide-by-two prescaler for the input clock, a fixed divide-by-four scaler on the PLL output, and an additional programmable integer divider that is the Master Clock Prescaler. NAU8502 Datasheet Rev2.5 Page 38 of 93 Aug, 2018 The high resolution fraction for the PLL is the ratio of the desired PLL oscillator frequency (f2), and the reference frequency at the PLL input (f1). This can be represented as R = f2/f1, with R in the form of a decimal number: xy.abcdefgh. To program the NAU8502, this value is separated into an integer portion (“xy”), and a fractional portion, “abcdefgh”. The fractional portion of the multiplier is a value that when represented as a 24-bit binary number (stored in three 9-bit registers on the NAU8502), very closely matches the exact desired multiplier factor. To keep the PLL within its optimal operating range, the integer portion of the decimal number (“xy”), must be any of the following decimal values: 6, 7, 8, 9, 10, 11, or 12. The input and output dividers outside of the PLL are often helpful to scale frequencies as needed to keep the “xy” value within the required range. Also, the optimum PLL oscillator frequency is in the range between 90MHz and 100MHz, and thus, it is best to keep f2 within this range. In summary, for any given design, choose: Equations Description IMCLK = (256) * (desired codec sample rate) IMCLK = desired Master Clock f2 = (4 * P * IMCLK) where P is the divider ratio in register MCLKSEL[7:5] optimal f2: 90MHz< f2 600 uA 161k/595k < 100 uA 5.6K => 600 uA 161k/595k < 100 uA VMID[8] 0x06 VMIDSEL[1:0] 0x0A BUFIOEN[2] 0x21 100 uA BIASEN[3] 0x21 300 uA MICBIAS[1:0] 0x06 500 uA PLLEN[5] 0x26 1.4 mA Clocks Applied ADL[3] 0x06 ADR[2] 0x06 PGL[5] 0x06 200 uA PGR[4] 0x06 200 uA LMBE[4] 0x02 200 uA RMBE[4] 0x03 200 uA x64 --- 2.6mA ADCOSR= 0 =>lower current x128--- 4.9mA ADCOSR= 1 =>higher curren x64---2,6mA ADCOSR= 0 =>lower current x128---4.9mA ADCOSR= 1 =>higher curren Table 31: VDDA 3.3V Supply Current NAU8502 Datasheet Rev2.5 Page 55 of 93 Aug, 2018 12 REGISTER DESCRIPTION There are two dedicated register spaces: • 8737 space 0x00 to 0x0F and 0x1C • NAU8502 space from 0x21 and on The NAU8502 register map have a reserved space from register 0x00 to register 0x0F and 0x1C that mimic the 8737 registers.. Programming in this address space [0x00-0x0F:0x1C] will trigger the appropriate functions in the NAU8502 via mapping. NAU8502 Datasheet Rev2.5 Page 56 of 93 Aug, 2018 Register Address DEC HEX Register Bits D8 D7 D6 D5 D4 Default D3 D2 D1 D0 PGA volume 0 0 LVU LINVOL C3 1 1 RVU RINVOL C3 2 2 LMICBOOST LMBE LMZC LPZC 07 3 3 RMICBOOST RMBE RMZC RPZC 07 Audio path 3D 4 00 4 ADC control 5 5 POLARITY 0 LP ADL ADR ADC HPD 00 Power Management 6 6 VMID VREF AI PGL PGR MICBIAS 80 FORMAT 0A Audio Format and clocking 7 7 8 8 SDODIS MS FSP CLKDIV2 WLEN 00 SR Mic pre-amp and bias 9 9 10 A 0F MBCTRL VMIDSEL LIN DC EN RIN DC EN 03 Noise gate and ALC 11 B 12 C 13 D 14 E ALCMINGAIN NGTH ALCEN NGAT ALCMAXGAIN ALCMODE 00 ALCSL 7C HLD 00 ATK 32 ALCZCE DCY Reset 15 F 16 10 17 11 18 12 19 13 20 14 21 15 22 16 23 17 24 18 25 19 26 1A 27 1B 28 1C 29 1D 30 1E 31 1F 32 20 33 21 00 Software Reset 4 Power management BIASEN 00 BUFIOEN Audio path selection 34 22 LLINOUTEN RLINOUTEN SLEEP VINSEL Register Address DEC HEX 35 LMICN2BVREF RMICN2BVREF D1 D0 Register Bits D8 D7 D6 D5 D4 23 00 Default D3 D2 LINEOUTSELL LINEOUTSELR 00 Audio format and clocking 36 24 37 25 38 26 39 27 BCLKP ADC_R_MUX_SEL ADC_L_MUX_SEL ADCLRSWAP ADC_COMP CLKM MCLKSEL BCLKSEL SLOWCLKEN GPIO Page 57 of 93 00 08 PLLEN SMPLR NAU8502 Datasheet Rev2.5 MONO U_OFFSET Aug, 2018 01 RAM_TEST_FINISH RAM_TEST_FAIL 00 40 28 RAM_TEST_START 41 29 GPIO_PS GPIO_PLLDIV GPIO_PE GPIO_OE 00 42 2A GPIO3_OUT_SEL GPIO2_OUT_SEL GPIO1_OUT_SEL 00 GPIO interrupt 43 2B 44 2C 45 2D POL GPIO3_IN GPIO2_IN GPIO1_IN RO clip2_INTE clip1_INTE GPIO3_INTE GPIO2_INTE GPIO1_INTE 180 clip2_INT clip1_INT GPIO3_INT GPIO2_INT GPIO1_INT 00 ADC additional control HPFAPP HPFCUT 08 46 2E 47 2F ADCVU ADCVOLL ADCOSR ff 48 30 ADCVU ADCVOLR ff 49 31 50 32 51 33 52 Equalizer EQ1BW EQ1C EQ1G 12C EQ2BW EQ2C EQ2G 2C 34 EQ3BW EQ3C EQ3G 2C 53 35 EQ4BW EQ4C EQ4G 2C 54 36 EQ5BW EQ5C EQ5G 2C Analog test mode 55 37 56 38 00 ANA_TEST 57 39 58 3A 59 3B NFU NFA0[13:7] 00 60 3C NFU NFA0[6:0] 00 61 3D NFU NFA1[13:7] 00 62 3E NFU NFA1[6:0] 00 63 3F 64 40 65 41 66 42 67 43 68 44 69 45 70 46 PLLK_A[17:9] 93 71 47 PLLK_A[8:0] E9 72 48 Notch filter NFEN PLL registerA PLLMCLK 08 PLLN_A 0C PLLK_A[23:18] 73 49 74 4A 75 4B LMIC2_2INPPGA2 LMICN2INPPGA2 LMIC2_2INPPGA1 LMICN2INPPGA1 LMICP2INPPGA 00 76 4C RMIC2_2INPPGA2 RMICN2INPPGA2 RMIC2_2INPPGA1 RMICN2INPPGA1 RMICP2INPPGA 00 77 4D LMBMUTE INPPGALVOL 00 78 4E RMBMUTE INPPGARVOL 00 Audio path selection PLL registerB 79 4F 80 50 81 51 PLLREGSEL 82 52 83 53 84 54 85 55 86 56 87 57 08 PLLN_B 0C PLLK_B[23:18] 93 PLLK_B[17:9] Register Address DEC HEX PLLMCLK Register Bits D8 D7 D6 D5 D4 Default D3 D2 D1 E9 PLLK_B[8:0] NAU8502 Datasheet Rev2.5 Page 58 of 93 D0 Aug, 2018 88 58 89 59 ADC mixer MixerMap_ADC2 MixerMap_ADC1 21 Power management and additional GPIO3 control input enable 90 5A PGA_stage2_bias HALF_BIAS_ADC_buffer HALF_BIAS_SPARES MCBSMODE TRIM_REGULATOR_SV GPIO3_IE 00 PCM and time slot 91 5B 92 5C 93 5D 00 TSLOTL[8:0] PCMTSEN TRI PCM8BIT ADCDAT_OEN ADCDAT_PE ADCDAT_PS ADCDAT_OEN_SEL TSLOTR[9] TSLOTL[9] 20 20 TSLOTR[8:0] ID register 94 5E 95 5F 96 60 97 61 98 62 99 63 FD REG_SI_REV 1B/1A I2C_DEVID CA Additional nuvoton ID 100 64 101 65 ALC interrupt features 102 66 ALCTABLESEL ALCPKSEL ALCNGSEL ALCGAIN_L 10 103 67 ALCPKLIMENn PK_DET_CLR PK_DET_HOLD ALCGAIN_R 10 Additional ADC equalizer registers 104 68 LATCH_DLY SWAP_DM_DFE EN_DIG_MIC_R EN_DIG_MIC_L DM_DS ALCGRP EQON_TEST SKIP_DLY 06 Additional register SPI and notch filter 105 69 FORCE_4W_SPI FLUSH_ON_ERR IDSEL_MODE NOTCH_DLY_DIS 00 PLLOCK_BP Tie-Off control VMID 106 6A 00 MANU_IN_CTRL 107 6B 00 MANU_VMID_CTRL AGC readout 108 6C P2P_OUT_L RO 109 6D P2P_OUT_R RO 110 6E PEAK_OUT_L RO 111 6F PEAK_OUT_R 112 70 NOISE_OUT_R NOISE_OUT_L RO FAST_DEC_L FAST_DEC_R RO Tie-Off control buffer VMID 113 71 REGENABLE SHORTBUFL NAU8502 Datasheet Rev2.5 Tie-off buffered VREF Page 59 of 93 00 Aug, 2018 12.1 REGISTERS 0X00 0X01 2ND STAGE PGA GAIN The registers set the gain of the PGA stage 2. The settings are mapped to the register 0x4D and 0x4E for a complete range: -12dB to +35.25dB in 0.75dB gain steps. Bit(s) Addr Parameter Function [8] 0x00 LVU Volume update, setting this bit to one will update the gain [8] 0x01 LVU Volume update, setting this bit to one will update the gain [7:0] map to 0x4D[5:0] 0x00 LINVOL Set the gain from -12dB to 35.25dB [7:0] map to 0x4E[5:0] 0x01 RINVOL Set the gain from -12dB to 35.25dB Note: The register settings in LINVOL and RINVOL will take effect only when the MCLK is present The table below describes the mapping between registers 0x00/0x01 and 0x4D/0x4E. It shows that the NAU8502 can adjust the gain on the second stage PGA from -12dB to +35.25dB if the register 0x4D and 0x4E are programmed. However for dedicated gain setting like MUTE, +4dB and +29.5dB the user can program the register 0x00 and 0x01 the same it is done on the 8737 and the gain will mapped within 0.5dB. 0x00[7:0] 0x01[7:0] 0x4D[5:0] 0x4E[5:0] Effective Gain Settings (decimal) [dB] Settings (decimal) 8737 Gain [dB] 0 MUTE Assert INPPGAMUTE -- 1 to 171 -97 to -12 0 -12 172 -11.5 1 -11.25 173 -11 2 -10.5 … … … … 194 -0.5 16 0 … … … … 203 4 22 4.5 … … … … 254 29.5 56 30 NAU8502 Datasheet Rev2.5 Page 60 of 93 Aug, 2018 12.2 REGISTERS 0X02 0X03 AUDIO PATH The registers set the gain, enable the first stage PGA and enable/disable the zero crossing functions. Bit(s) Addr Parameter [6:5] 0x02 LMICBOOST [4] 0x02 LMBE [6:5] 0x03 RMICBOOST [4] 0x03 RMBE Function Set the gain 00 = +13dB 01 = +18dB 10 = +28dB 11 = +33dB Left (channel 1) 0: Disable PGA 1st stage 1: Enable PGA 1st stage Set the gain 00 = +13dB 01 = +18dB 10 = +28dB 11 = +33dB Right (channel 2) 0: Disable PGA 1st stage 1: Enable PGA 1st stage 12.3 REGISTER 0X04 Not supported. 12.4 REGISTER 0X05 ADC Bit(s) Addr Parameter [6:5] 0x05 POLARITY [2] 0x05 LP [0] 0x05 ADCHPD Function 00 no inversion on ADC data 01 Left (1) inverted 10 Right (2) inverted 11 both inverted 1 reduces ADC current by half 0 nominal ADC current 1 disable ADC high pass filter 0 enable 12.5 REGISTER 0X06 POWER MANAGEMENT Bit(s) Addr Parameter Function [8] 0x06 VMID 0 VMID reference turned off 1 VMID reference turned on [7] 0x06 VREF 0 VREF buffer turned on 1 VREF buffer turned off [6] 0x06 AI 0 audio interface off 1 audio interface on [5] 0x06 PGL 0 pga 2nd stage off 1 pga 2nd stage on [4] 0x06 PGR 0 pga 2nd stage off 1 pga 2nd stage on NAU8502 Datasheet Rev2.5 Page 61 of 93 Aug, 2018 0 ADC off 1 ADC on [3] 0x06 ADL [2] 0x06 ADR [1:0] 0x06 MICBIAS (if MICBMODE = 0) Note: 0 ADC off 1 ADC on 00 off 01 0.75*VDDA 10 0.9*VDDA 11 0.5*VDDA The register setting in ADL and ADR will take effect only when the MCLK is present ADL/ADR mapping When the ADCs are enabled by setting ADL or ADR high, a corresponding set of registers in the NAU8502 space are simultaneously and automatically configured. These registers may be overwritten at their locations in the NAU8502 space, and the most recent configuration will take effect. The mapped register values from ADL/ADR to NAU8502 space may be read from the NAU8502 space, but the mapping is uni-directional; writes in the NAU8502 space will not be reflected or mapped back to any overwrites of the 8737 space. When either ADL or ADR are set high, the following register changes are made in NAU8502 space: • BIASEN (0x21[3]) is enabled high • BUFIOEN (0x21[2]) is enabled high • L/RMICP2INPPGA (0x4B[0], 0x4C[0] are enabled high (corresponding to left and/or right channel ADL/ADR) • L/RMICN2BVREF (0x22[1:0]) are enabled high (corresponding to left and/or right channel ADL/ADR) • L/RMIC2_2INPPGA2 (0x4B[6], 0x4C[6]) are enabled high (corresponding to left and/or right channel ADL/ADR) • L/RMICN2INPPGA1 (0x4B[1], 0x4C[1]) are disabled low • L/RMIC2_2INPPGA1 (0x4B[2], 0x4C[2]) are disabled low • L/RMICN2INPPGA2 (0x4B[5], 0x4C[5]) are disabled low When ADL or ADR are subsequently cleared, L/RMICN2BVREF and L/RMIC2_2INPPGA2 are cleared along with other path selection bits, and BIASEN/BUFIOEN are set to the value at address 0x21. 12.6 REGISTER 0X07 AUDIO FORMAT AND CLOCKING Bit(s) Addr Parameter [7] 0x07 ADCOUTDIS [6] 0x07 MS [4] 0x07 FSP [3:2] 0x07 WLEN [1:0] 0x07 FORMAT NAU8502 Datasheet Rev2.5 Function Controls ADCOUT enable 0 ADCOUT enable 1 ADCOUT disable ADCDAT_OE_SEL 0x5C[2] must be set to 0 first 0 Slave PCM bus 1 Master PCM bus 0 frame sync clock non inverted 1 frame sync clock inverted (this bit is not applicable to FORMAT=11) 00 16 bits 01 20 bits 10 24 bits 11 32 bits (set to 24 bit if FORMAT=00 Right Justified) 00 Right justified 01 Left justified 10 I2S mode 11 DSP mode A when FSP (0x07[4]) = 0, DSP mode B when FSP (0x07[4]) = 1 Page 62 of 93 Aug, 2018 12.7 REGISTER 0X08 AUDIO FORMAT AND CLOCKING Bit(s) Addr Parameter [6] 0x08 CLKDIV2 [5:1] mapped to 0x27[3:1] 0x08 SR Function 0 Master clock not divided by 2 1 Master clock divided by 2 Sample rates supported are: MCLK=12.288MHz 00100 8KHz 01000 12KHz 01010 16KHZ 11100 24KHZ 01100 32KHZ 00000 48KHZ MCLK=11.2896MHz 11000 11.025KHz 11010 22.05KHz 10000 44.1KHz Sample Rate register mapping The SR (0x08[5:1]) and CLKDIV2 (0x08[6]) register bits map to the MCLKSEL (0x26[7:5]), BCLKSEL (0x26[4:2]), and SMPLR (0x27[3:1]) registers in NAU8502 space as in the following table: MCLK CLKDIV2=0 12.288 MHz SR MCLKSEL BCLKSEL SMPLR CLKDIV2=1 24.576 MHz 00100 101 (6) 01000 100 (4) 01010 011 (3) 11100 010 (2) 01100 001 (1.5) 00000 000 (1) 010 (4) 101 (8k) 010 (4) 100 (12k) 110 (192 BCLK per FS) 010 (4) 011 (16k) 010 (4) 001 (32k) 010 (4) 000 (48k) 010 (24k) 12.8 REGISTER 0X09 ANALOG POWER CONTROL Bit(s) Addr Parameter [1:0] 0x09 MBCTRL NAU8502 Datasheet Rev2.5 Function Master bias current setting 00 125% 01 85% 10 75% 11 nominal 100% Page 63 of 93 Aug, 2018 12.9 REGISTER 0X0A VMID IMPEDANCE AND INPUT IMPEDANCE SELECTION Bit(s) Addr Parameter [3:2] 0x0A VMIDSEL [1] 0x0A LDC [0] 0x0A RDC 12.10 0 500K disconnected from MIC2P 1 500K connected from MIC2P REGISTER 0X0B NOISE GATE AND ALC Bit(s) Addr Parameter [7:5] 0x0B ALCMINGAIN [4:2] 0x0B NGATH [0] 0x0B NGAT 12.11 Function VMID impedance selection 00 80K 01 300K 10 2.5K 11 reserved 0 500K disconnected from MIC1P 1 500K connected from MIC1P Function Minimum level for ALC operation 0 = -12dB 1 = -6dB 2 = 0dB 3 = +6dB … 7 = +30dB Noise gate threshold 000 = -78dB 001 = -72dB 010 = -66dB 011 = -60dB 100 = -54dB 101 = -48dB 110 = -42dB 111 = -30dB 0 Noise gate disabled 1 Noise gate enabled REGISTER 0X0C ALC Bit(s) Addr Parameter [8:7] 0x0C ALCEN [6:4] 0x0C ALCMAXGAIN [3:0] 0x0C ALCSL NAU8502 Datasheet Rev2.5 Function 00 = ALC disabled 01 = Right channel ALC enabled 10 = Left channel ALC enabled 11 = Both channels ALC enabled Maximum level for ALC operation 0 = -6.75 dB 1 = -.75 dB 2 = +5.25 dB 3 = +11.25 dB … 7 = +35.25 dB ALC target level ALCTABLESEL (0x66.8) = 0 0 = -28.5 dB Page 64 of 93 Aug, 2018 1 = -27 dB 2 = -25.5 dB … 14 = -7.5 dB 15 = -6 dB ALCTABLESEL (0x66.8) = 1 0 = -22.5 dB 1 = -21 dB 2 = -19.5 dB … 13 = -3 dB 14 = -1.5 dB 15 = -1.5 dB 12.12 Bit(s) REGISTER 0X0D ALC Addr Parameter [5] 0x0D ALCMODE [4] 0x0D ALCZCE [3:0] 0x0D HLD 12.13 REGISTER 0X0E ALC Bit(s) Addr Parameter [7:4] 0x0E DCY [3:0] 0x0E ATK 12.14 Function 0 = ALC normal operation mode 1 = ALC limiter mode. ALC zero cross enable 0 = zero crossing disabled 1 = zero crossing enabled Range: 0ms to 1s, time doubles with every step) Function ALC decay time ALCMODE=0 Range: 500us to 512ms ALCMODE=1 Range: 125us to 128ms (Both ALC time doubles with every step) Note: parameters refer to time to update one 0.75 dB step ALC attack time ALCMODE=0 Range: 125us to 128ms ALCMODE=1 Range: 31us to 32ms (time doubles with every step) Note: parameters refer to time to update one 0.75 dB step REGISTER 0X0F RESET Bit(s) Addr Parameter Function [8:0] 0x0F Software Reset Program 0x000 to reset the registers 12.15 REGISTER 0X1C Natively supported, the maximum ADC code is 0x7FFFFF NAU8502 Datasheet Rev2.5 Page 65 of 93 Aug, 2018 12.16 REGISTER 0X21 ADDITIONAL POWER MANAGEMENT REGISTERS (NOTE: WRITE-ONLY) Bit(s) Addr Parameter [3] 0x21 BIASEN [2] 0x21 BUFIOEN 12.17 Function Register turning on the remaining of the analog circuitry like band gap and references 0 disable 1 enable Buffer enable for tie-off connections 0 disable 1 enable REGISTER 0X22 ADDITIONAL AUDIO PATH REGISTERS Bit(s) Addr Parameter Function [8] 0x22 LLINOUTEN Not used [7] 0x22 RLINOUTEN Not used [6] 0x22 SLEEP Stops the clock, same as PLLEN 0x26[2] [5] 0x22 VINSEL Not used [1] 0x22 LMICN2BVREF Connect MIC1N to reference for single ended operation [0] 0x22 RMICN2BVREF Connect MIC2N to reference for single ended operation 12.18 REGISTER 0X23 ADDITIONAL AUDIO PATH REGISTERS Bit(s) Addr Parameter [3:2] 0x23 LINOUTSELL [1:0] 0x23 LINOUTSELR 12.19 Function Mix the ADC input signal to LLINOUT pin 00 none 01 ADC signal left only 10 ADC signal right only 11 both ADC signal Mix the ADC input signal to RLINOUT pin 00 none 01 ADC signal left only 10 ADC signal right only 11 both ADC signal REGISTER 0X24 LEFT AND RIGHT CHANNEL SELECT FOR ADCOUT Bit(s) Addr Parameter [8] 0x24 BCLKP [4] 0x24 ADC_R_MUX_SEL NAU8502 Datasheet Rev2.5 Function BCLK polarity 0 = non-inverted BCLK 1 = inverted BCLK 0 = output Right Channel Data on Right Channel ADCOUT 1 = output Left Channel Data on Right Channel ADCOUT Page 66 of 93 Aug, 2018 [3] 0x24 ADC_L_MUX_SEL [1] 0x24 ADCLRSWAP [0] 0x24 MONO 12.20 REGISTER 0X25 AUDIO FORMAT AND CLOCKING Bit(s) Addr Parameter [2:1] 0x25 ADC_COMP [0] 0x25 U_OFFSET 12.21 Function ADC Companding Select 00 linear 01 reserved 10 Mu-law 11 A-law Mu-law 0 = input offset by 32 1 = input offset by 33 REGISTER 0X26 CLOCK SOURCE AND DIVISION SELECT AND PLL ENABLE Bit(s) Addr Parameter [8] 0x26 CLKM [7:5] 0x26 MCLKSEL [4:2] 0x26 BCLKSEL [1] 0x26 PLLEN 12.22 0 = output Left Channel Data on Left Channel ADCOUT 1 = output Right Channel Data on Left Channel ADCOUT 0 = no swap between the Left and Right Channel ADCOUT 1 = swap the Left and Right Channel ADCOUT Select audio data on one channel only 0 = both channel ADCOUT 1 = only Left channel ADCOUT if ADCLRSWAP=0 or only Right channel ADCOUT if ADCLRSWAP=1 Function 0 PLL is bypassed 1 PLL is used for MCLK Scale the MCLK or PLL ouput clock 000 = divide by 1 001 = divide by 1.5 010 = divide by 2.0 011 = divide by 3 100 = divide by 4 101 = divide by 6 110 = divide by 8 111 = divide by 12 Scale the bclk output frequency when used as master. 000 = divide by 1 001 = divide by 2 010 = divide by 4 011 = divide by 8 100 = divide by 16 101 = divide by 32 110 = reserved 111 = reserved 0 PLL off 1 PLL on REGISTER 0X27 AUDIO FORMAT AND CLOCKING Bit(s) Addr Parameter [3:1] 0x27 SMPLR NAU8502 Datasheet Rev2.5 Function Direct sample rate selection 000 = 48 kHz 001 = 32 kHz 010 = 24 kHz Page 67 of 93 Aug, 2018 [0] 0x27 12.23 SLOWCLKGEN 011 = 16 kHz 100 = 12 kHz 101 = 8 kHz 110 = reserved 111 = reserved 0 = Slow clock disabled 1 = Slow clock enabled. Slow clock needs to be enabled when zero crossing is enabled. When zero crossing is enabled in the 8737 address space, this register is automatically set. REGISTER 0X28 RAM Bit(s) Addr [8] 0x28 RAM_TEST_START RAM test start control [7] 0x28 RAM_TEST_FINISH RAM test finished status flag [6] 0x28 RAM_TEST_FAIL [5:4] Parameter 0x28 12.24 Bit(s) Function GPIO_PLLDIV RAM test failed status flag Scaled PLL output clock 00 = divide by 1 01 = divide by 2 10 = divide by 3 11 = divide by 4 REGISTER 0X29 GPIO Addr Function GPIO pull select enable [8:6] 0x29 GPIO_PS 000 pull low 111 pull high GPIO pull enable [5:3] 0x29 GPIO_PE 000 tri-stated input 111 pull enabled GPIO output enable [2:0] 0x29 GPIO_OE x00 disabled 111 enabled If GPIO_OE[2]=0 GPIO3 is not configure as input or output pin. See register 0x5A[0] to configure as input pin. 12.25 Parameter REGISTER 0X2A GPIO Bit(s) Addr [8:6] 0x2A GPIO3_OUT_SEL [5:3] 0x2A GPIO2_OUT_SEL [2:0] 0x2A GPIO1_OUT_SEL NAU8502 Datasheet Rev2.5 Parameter Page 68 of 93 Function GPIO output selection 000 = 0 001 = 1 010 = PLL clock 011 = PLL lock 100 = MCLK_PIN 101 = Interrupt 110 = Master FS 111 = Master BCLK GPIO output selection Same as above GPIO output selection Same as above Aug, 2018 Register 0x2B GPIO Bit(s) Addr Parameter Function [2] 0x2B GPIO3_IN GPIO3 input read out [1] 0x2B GPIO2_IN GPIO2 input read out [0] 0x2B GPIO1_IN GPIO1 input read out 12.26 REGISTER 0X2C GPIO Bit(s) Addr [7] 0x2C POL [4] 0x2C Clip2_IE Clip interrupt enable number 2 [3] 0x2C Clip1_IE Clip interrupt enable number 1 [2] 0x2C GPIO3_IE GPIO3 interrupt enable [1] 0x2C GPIO2_IE GPIO2 interrupt enable [0] 0x2C GPIO1_IE GPIO1 interrupt enable 12.27 Parameter Function 0 interrupt polarity, output will be 1 active high 1 interrupt polarity, output will be 0 active low REGISTER 0X2D GPIO Bit(s) Addr [4] 0x2D Clip2_INT Clip1 interrupt read status [3] 0x2D Clip1_INT Clip1 interrupt read status [2] 0x2D GPIO3_INT GPIO3 interrupt read status [1] 0x2D GPIO2_INT GPIO2 interrupt read status [0] 0x2D GPIO1_INT GPIO1 interrupt read status 12.28 Parameter Function REGISTER 0X2E ADC CONTROLS Bit(s) Addr [7] 0x2E HPFAPP [6:4] 0x2E HPFCUT High pass filter cutoff frequency [3] 0x2E ADCOSR 0 ADC OSR64 better operation at low V 1 ADC OSR128 lower noise NAU8502 Datasheet Rev2.5 Parameter Page 69 of 93 Function High pass filter application mode 0 audio 1st order fc=3.7Hz 1 2nd order, cutoff set by HPFCUT Aug, 2018 12.29 REGISTER 0X2F ADC CONTROLS Bit(s) Addr [8] 0x2F [7:0] Parameter ADCVU 0x2F 12.30 ADCVOLL Addr [8] 030 Parameter ADCVOLR ADC volume update bit Set the ADC volume right channel 0 = digital mute 1 = -127 dB 2 = -126.5 dB … 0.5 dB steps 255 = 0 dB REGISTER 0X32 EQUALIZER CONTROLS Bit(s) Addr [7] 0x32 EQ1BW [6:5] 0x32 EQ1CF [4:0] 0x32 EQ1GF 12.32 Set the ADC volume left channel 0 = digital mute 1 = -127 dB 2 = -126.5 dB … 0.5 dB steps 255 = 0 dB Function ADCVU 0x30 12.31 ADC volume update bit REGISTER 0X30 ADC CONTROLS Bit(s) [7:0] Function Parameter Function Bandwidth control 0 Narrow bandwidth 1 Wide bandwidth Cut-off frequencies 00 80Hz 01 105Hz 10 135Hz 11 175Hz Equalizer gain 00000 +12dB 11000 -12dB 11001 to 11111 reserved REGISTER 0X33 EQUALIZER CONTROLS Bit(s) Addr [8] 0x33 EQ2BW [6:5] 0x33 EQ2CF [4:0] 0x33 EQ2GF NAU8502 Datasheet Rev2.5 Parameter Page 70 of 93 Function Bandwidth control 0 Narrow bandwidth 1 Wide bandwidth Center frequencies 00 230Hz 01 300Hz 10 385Hz 11 500Hz Equalizer gain 00000 +12dB 11000 -12dB 11001 to 11111 reserved Aug, 2018 12.33 REGISTER 0X34 EQUALIZER CONTROLS Bit(s) Addr [8] 0x34 EQ3BW [6:5] 0x34 EQ3CF [4:0] 0x34 EQ3GF 12.34 Parameter REGISTER 0X35 EQUALIZER CONTROLS Bit(s) Addr [8] 0x35 EQ4BW [6:5] 0x35 EQ4CF [4:0] 0x35 EQ4GF 12.35 Parameter Function Bandwidth control 0 Narrow bandwidth 1 Wide bandwidth Center frequencies 00 1.8KHz 01 2.4KHz 10 3.2KHz 11 4.1KHz Equalizer gain 00000 +12dB 11000 -12dB 11001 to 11111 reserved REGISTER 0X36 EQUALIZER CONTROLS Bit(s) Addr [8] 0x36 EQ5BW [6:5] 0x36 EQ5CF [4:0] 0x36 EQ5GF 12.36 Function Bandwidth control 0 Narrow bandwidth 1 Wide bandwidth Center frequencies 00 650Hz 01 850Hz 10 1100Hz 11 1400Hz Equalizer gain 00000 +12dB 11000 -12dB 11001 to 11111 reserved Parameter Function Bandwidth control 0 Narrow bandwidth 1 Wide bandwidth Cut-off frequencies 00 5.3KHz 01 6.9KHz 10 9.0KHz 11 11.7KHz Equalizer gain 00000 +12dB 11000 -12dB 11001 to 11111 reserved REGISTER 0X37 ANALOG TEST MODES Bit(s) Addr [8:0] 0x37 NAU8502 Datasheet Rev2.5 Parameter ANA_TEST Page 71 of 93 Function 000000100 2nd stage PGA bypassed 000010000 1.8V logic supply to POUT pin 000100000 1.8V logic supply to VREF pin Aug, 2018 12.37 REGISTER 0X3B-0X3E NOTCH FILTERS CONTROLS Addr D8 D7 D6 D5 D4 D3 D2 D1 D0 Default 0x3B NFCU NFCEN NFCA0[13:7] 0x000 0x3C NFCU 0 NFCA0[6:0] 0x000 0x3D NFCU 0 NFCA1[13:7] 0x000 0x000 0x3E 0 NFCA1[6:0] NFCU The Notch Filter is enabled by setting NFCEN[7] address (0x3B) bit to HIGH. The coefficients, A0 and A1, should be converted to 2’s complement numbers to determine the register values. A0 and A1 are represented by the register bits NFCA0[13:0] and NFCA1[13:0]. Since there are four register of coefficients, a Notch Filter Update bit is provided so that the coefficients can be updated simultaneously. NFCU[8] is provided in all registers of the Notch Filter coefficients but only one bit needs to be toggled for LOW - HIGH - LOW for an update. If any of the NFCU[8] bits are left HIGH then the Notch Filter coefficients will continuously update. An example of how to calculate is provided in the Notch Filter section. 12.38 REGISTER 0X44 PLL REGISTER A Bit(s) Addr [4] 0x44 PLLMCLK [3:0] 0x44 PLLN_A 12.39 Addr [5:0] 0x45 Addr [8:0] 0x46 PLL coefficient N Parameter Function PLLK_A[23:18] PLL coefficient K, upper bits Parameter Function PLLK_A[17:9] PLL coefficient K, mid bits REGISTER 0X47 PLL REGISTER A Bit(s) Addr [8:0] 0x47 12.42 0=MCLK input not divided 1=MCLK input is divided by 2 REGISTER 0X46 PLL REGISTER A Bit(s) 12.41 Function REGISTER 0X45 PLL REGISTER A Bit(s) 12.40 Parameter Parameter Function PLLK_A[8:0] PLL coefficient K, lower bits REGISTER 0X4B ADDITIONAL AUDIO PATH REGISTERS Bit(s) Addr Parameter Function [6] 0x4B LMIC2_2INPPGA2 0 = P1IN not connected to input PGA stage2 1 = P1IN to input PGA stage 2 Negative terminal. [5] 0x4B LMICN2INPPGA2 0 = not connected to input PGA stage 2 1 = to input PGA stage 2 Negative terminal. [2] 0x4B LMIC2_2INPPGA1 0 = P1IN not connected to input PGA stage1 1 = P1IN to input PGA stage 1 Negative terminal. [1] 0x4B LMICN2INPPGA1 0 = MIC1N not connected to input PGA stage 1 1 = MIC1N to input PGA stage 1 Negative terminal. [0] 0x4B LMICP2INPPGA 0 = Input PGA stage 1 Positive terminal to VREF 1 = Input PGA stage 1 Positive terminal to MIC1P NAU8502 Datasheet Rev2.5 Page 72 of 93 Aug, 2018 12.43 REGISTER 0X4C ADDITIONAL AUDIO PATH REGISTERS Bit(s) Addr Parameter Function [6] 0x4C RMIC2_2INPPGA2 0 = P2IN not connected to input PGA stage2 1 = P2IN to input PGA stage 2 Negative terminal. [5] 0x4C RMICN2INPPGA2 0 = not connected to input PGA stage 2 1 = to input PGA stage 2 Negative terminal. [2] 0x4C RMIC2_2INPPGA1 0 = P2IN not connected to input PGA stage1 1 = P2IN to input PGA stage 1 Negative terminal. [1] 0x4C RMICN2INPPGA1 0 = MIC2N not connected to input PGA stage 1 1 = MIC2N to input PGA stage 1 Negative terminal. [0] 0x4C RMICP2INPPGA 0 = Input PGA stage 1 Positive terminal to VREF 1 = Input PGA stage 1 Positive terminal to MIC2P 12.44 REGISTER 0X4D ADDITIONAL AUDIO PATH REGISTERS Bit(s) Addr Parameter Function [6] 0x4D LMBMUTE Reserved/unused [5:0] 0x4D INPPGALVOL Left channel PGA stage 2 gain 12.45 REGISTER 0X4E ADDITIONAL AUDIO PATH REGISTERS Bit(s) Addr Parameter Function [6] 0x4E RMBMUTE Reserved/unused [5:0] 0x4E INPPGARVOL Right channel PGA stage 2 gain 12.46 Bit(s) REGISTER 0X4F PLL REGISTER B Addr Parameter [5] 0x4F PLLREGSEL [4] 0x4F PLLMCLK [3:0] 0x4F PLLN_B 12.47 Function 0 select PLL coefficients register A 1 select PLL coefficients register B 0=MCLK input not divided 1=MCLK input is divided by 2 PLL coefficient N REGISTER 0X50 PLL REGISTER B Bit(s) Addr [5:0] 0x50 NAU8502 Datasheet Rev2.5 Parameter Function PLLK_B[23:18] Page 73 of 93 PLL coefficient K, upper bits Aug, 2018 12.48 REGISTER 0X51 PLL REGISTER B Bit(s) Addr [8:0] 0x51 12.49 Function PLLK_B[17:9] Addr [8:0] 0x52 Parameter Function PLLK_B[8:0] PLL coefficient K, lower bits REGISTER 0X59 ADC MIXER Bit(s) Addr [5:4] 0x59 MixerMap_ADC2 [1:0] 0x59 MixerMap_ADC1 12.51 PLL coefficient K, mid bits REGISTER 0X52 PLL REGISTER B Bit(s) 12.50 Parameter Parameter Function ADC right channel digital mixer map Configure outputs routed out on to ADC right channel 00: zero 01: left channel input 10: right channel input (default) 11: left + right channel input ADC left channel digital mixer map Configure outputs routed out on to ADC left channel 00: zero 01: left channel input (default) 10: right channel input 11: left + right channel input REGISTER 0X5A POWER MANAGEMENT EXTRA Bit(s) Addr [8] 0x5A PGA_stage2_bias [7] 0x5A HALF_BIAS_ADC_buffer 0 ADC uses nominal bias 1 ADC uses half current bias [6] 0x5A HALF_BIAS_SPARES (no used) 0 ADC uses nominal bias 1 ADC uses half current bias [4] 0x5A MCBSMODE [3:2] 0x5A TRIM_REGULATOR_SV [0] 0x5A GPIO3_IE NAU8502 Datasheet Rev2.5 Parameter Function Page 74 of 93 0 PGA stage 2 uses nominal bias 1 PGA stage 2 uses half current bias 0 nominal mode requires large cap 1 lower noise mode requires small cap 00 nominal logic supply 1.8V 01 1.71V 10 1.6V 11 1.4V 0 Input disabled on GPIO3 1 Input enabled on GPIO3 Aug, 2018 12.52 REGISTER 0X5B LEFT CHANNEL PCM TIME SLOT START COUNT Bit(s) Addr [8:0] 0x5B 12.53 Parameter Function TSLOTL[8:0] Left Channel PCM Time Slot Start Count [8:0] REGISTER 0X5C PCM AND TIME SLOT CONTROL Bit(s) Addr Parameter [8] 0x5C PCMTSEN [7] 0x5C TRI [6] 0x5C PCM8BIT [5] 0x5C ADCDAT_OEN [4] 0x5C ADCDAT_PE [3] 0x5C ADCDAT_PS [2] 0x5C ADCDAT_OEN_SE L [1] 0x5C TSLOTR[9] Right Channel PCM Time Slot Start Count [9] [0] 0x5C TSLOTL[9] Left Channel PCM Time Slot Start Count [9] 12.54 Addr [8:0] 0x5D Addr [8:0] 0x5E Bit(s) Parameter Function TSLOTR[8:0] Right Channel PCM Time Slot Start Count [8:0] REGISTER 0X5E ID REGISTERS Bit(s) 12.56 0 = Only DSP MODE A or MODE B can be used when F 1 = PCM Time Slot Mode is enabled when FORMT=11 0 = not enabled 1 = when ADCDAT_OEN_SEL (0x5C[2])=1 and ADCDAT_OEN(0x5C[5)]=0, 2nd half of LSB will be Tri-State or pull up / down 0 = use WLEN to select the Word Length 1 = Word Length is 8 bit This bit is only effective when ADCDAT_OEN_SEL(0x5c[2]) = 0 0 = ADCOUT is tri-state or pull up/down before MSB and after LSB 1 = ADCOUT is always driven 1 or 0 by NAU8502 0 = no internal weak pull up / down on ADCOUT 1 = internal weak pull up / down on ADCOUT 0 = internal weak pull down on ADCOUT when ADCDAT_PE=1 1 = internal weak pull up on ADCOUT when ADCDAT_PE=1 0 = use ADCOUTDIS(0x07[7]) to enable or disable ADCOUT 1 = use ADCDAT_OEN(0x5C[5]) to control ADCOUT driver REGISTER 0X5D RIGHT CHANNEL PCM TIME SLOT START COUNT Bit(s) 12.55 Function Parameter Function REG_SI_REV Silicon revision set to 0xFE REGISTER 0X5F ID REGISTERS Addr NAU8502 Datasheet Rev2.5 Parameter Function Page 75 of 93 Aug, 2018 [8:0] 0x5F 12.57 Addr [8:0] 0x60 Parameter Function NTCA Addr [8] 0x66 ALCTABLESEL [7] 0x66 ALCPKSEL [6] 0x66 ALCNGSEL [5:0] 0x66 ALCGAIN_L Parameter Function 0 = ALCSL range -28.5:-6dB 1 = ALCSL range -22.5:-1.5 dB 0 = use absolute peak value for ALC training 1 = use peak-to-peak value for ALC training 0 = use peak-to-peak value for noise gate threshold determination 1 = use absolute peak value for noise gate threshold determination Left channel ALC gain status REGISTER 0X67 ALC INTERRUPTS FEATURES REGISTERS Bit(s) Addr [8] 0x67 ALCPKLIMENn [7] 0x67 PK_DET_CLR [6] 0x67 PK_DET_HOLD [5:0] 0x67 ALCGAIN_R 12.60 Custom register is set to 0xCA REGISTER 0X66 ALC INTERRUPTS FEATURES REGISTERS Bit(s) 12.59 I2C device is set to 0x1A when CSB=0 I2C device is set to 0x1B when CSB=1 REGISTER 0X60 ID REGISTERS Bit(s) 12.58 I2C_DEVID Parameter Function 0 = enable fast decrement when signal exceeds 87.5% of full scale 1 = disable fast decrement when signal exceeds 87.5% of full scale When PK_DET_HOLD is asserted HIGH, writing a 1 to this bit clears the stored peak value 0 = Normal peak detection 1 = Hold peak value until PK_DET_CLR is written. This should only be used for signal level diagnostics and not for normal ALC operation Right channel ALC gain status REGISTER 0X68 ADC AND EQUALIZER ADDITIONAL REGISTERS Bit(s) Addr [8] 0x68 LATCH_DLY[1] [7] 0x68 LATCH_DLY[0] [6] 0x68 SWAP_DM_DFE [5] 0x68 EN_DIG_MIC_R NAU8502 Datasheet Rev2.5 Parameter Page 76 of 93 Function (test mode only) 0 = ADC data sampled on rising edge 1 = ADC data sampled on falling edge (test mode only) 0 = Normal phase for ADC clock 1 = Inverted phase for ADC clock 0: ch1=left dmic, ch2=right dmic 1: ch1=right dmic, ch2=left dmic 0=disable right digital mic 1=enable right digital mic Aug, 2018 [4] 0x68 EN_DIG_MIC_L [3] 0x68 DM_DS [2] 0x68 ALCGRP [1] 0x68 EQON_TEST [0] 0x68 SKIP_DLY 0=disable left digital mic 1=enable left digital mic 0=slower slew-rate for DM_CLK 1=faster slew-rate for DM_CLK 0 = Left and right channel ALCs train independently with separate gain settings for each channel 1 = Left and right channel ALCs train together with a single gain setting for both channels when both enabled (default) 0 = Bypass equalizer 1 = Enable equalizer (default) 0 = Align L/R sinc outputs with delay 1 = Bypass right channel sinc alignment delay REGISTER 0X69 ADC AND EQUALIZER ADDITIONAL REGISTERS 12.61 Bit(s) Addr [8] 0x69 FORCE_4W_SPI [5] 0x69 FLUSH_ON_ERR [4] 0x69 IDSEL_MODE [3] 0x69 NOTCH_DLY_DIS [1] 0x69 PLLOCK_BP 12.62 Parameter Function 0 = only I2C or SPI 3 wire mode can be used 1 = use SPI 4 wire mode no matter the MODE pin is 1 or 0 0 = Normal operation 1 = Flush digital filter memory when internal clocking error detected 0 = I2C Device ID selected by CSB on every transaction 1 = I2C Device ID selected by CSB state at reset 0 = Normal operation – notch filter output is delayed until stabilized 1 = Notch delay disabled – notch filter output is available immediately upon enabling 0 = PLL lock circuit normal operation 1 = PLL lock forced high REGISTER 0X6A TIE-OFF REGISTERS Bit(s) Addr [8] 0x6A 12.63 Parameter Function MANU_IN_CTRL 0 nominal control of the VMID tie off 1 manual control of the VMID tie off REGISTER 0X6B TIE-OFF REGISTERS Bit(s) Addr Parameter [2:0] 0x6B MANU_VMID_CTRL 12.64 Function Require to have 0x6A[8] set to 1 001 5.6K Ohm pull down resistor 010 161K Ohm pull down resistor 100 595K Ohm pull down resistor REGISTER 0X6C AGC READOUT REGISTERS Bit(s) Addr NAU8502 Datasheet Rev2.5 Parameter Page 77 of 93 Function Aug, 2018 [8:0] 12.65 P2P_OUT_L Left channel peak-to-peak value REGISTER 0X6D AGC READOUT REGISTERS Bit(s) Addr Parameter [8:0] 0x6D P2P_OUT_R 12.66 Function Right channel peak-to-peak value REGISTER 0X6E AGC READOUT REGISTERS Bit(s) Addr Parameter [8:0] 0x6E PEAK_OUT_L 12.67 Function Left channel absolute peak value REGISTER 0X6F AGC READOUT REGISTERS Bit(s) Addr Parameter [8:0] 0x6F PEAK_OUT_R 12.68 12.69 0x6C Function Right channel absolute peak value REGISTER 0X70 NOISE GATE READOUT REGISTERS Bit(s) Addr Parameter [5] 0x70 NOISE_OUT_R [4] 0x70 NOISE_OUT_L [1] 0x70 FAST_DEC_L [0] 0x70 FAST_DEC_R Function Right channel noise gate flag 0 = signal above noise gate threshold 1 = signal below noise gate threshold Left channel noise gate flag 0 = signal above noise gate threshold 1 = signal below noise gate threshold Left channel fast decrement flag 0 = signal below 87.5% of full scale 1 = signal above 87.5% of full scale Right channel fast decrement flag 0 = signal below 87.5% of full scale 1 = signal above 87.5% of full scale REGISTER 0X71 MANUAL TIE-OFF REGISTERS Bit(s) Addr Parameter Function [8] 0x71 REGENABLE 0 disabled 1 enable direct control on buffer tie off [6] 0x71 SHORTBUFL [5] 0x71 Tie-off buffered VREF NAU8502 Datasheet Rev2.5 Page 78 of 93 0 tie off buffer is used 1 bypass tie off buffer 0 disabled 1 enabled tie off voltage to VMID buffer when buffer is off Aug, 2018 13 CONTROL INTERFACE TIMING DIAGRAM 13.1 SPI WRITE TIMING DIAGRAM TCSBH TCSBL CSB TSCCSH TSCK TRISE TFALL SCLK TSCKH TSCKL SDIO TSDIOS TSDIOH Figure 30: SPI Write Timing Diagram SYMBOL DESCRIPTION MIN TYP MAX UNIT TSCK SCLK Cycle Time 80 --- --- ns TSCKH SCLK High Pulse Width 35 --- --- ns TSCKL SCLK Low Pulse Width 35 --- --- ns TRISE Rise Time for all SPI Signals --- --- 10 ns TFALL Fall Time for all SPI Signals --- --- 10 ns TCSSCS CSb Falling Edge to 1st SCLK Falling Edge Setup Time (4 wire SPI only) 30 --- --- ns TSCCSH Last SCLK Rising Edge to CSb Rising Edge Hold Time 30 --- --- ns TCSBL CSb Low Time 30 --- --- ns TCSBH CSb High Time between CSb Lows 30 --- --- ns TSDIOS SDIO to SCLK Rising Edge Setup Time 20 --- --- ns TSDIOH SCLK Rising Edge to SDIO Hold Time 20 --- --- ns Table 32: SPI Timing Parameters NAU8502 Datasheet Rev2.5 Page 79 of 93 Aug, 2018 13.2 2-WIRE TIMING DIAGRAM TSTAH TSDIOS TSDIOH TSTAH SDIO TSCKH TFALL SCLK TSCKL TRISE TSTAS TSTOS Figure 31: 2-Wire Timing Diagram SYMBOL DESCRIPTION MIN TYP MAX UNIT TSTAH START / Repeat START condition, SCLK falling edge to SDIO falling edge hold timing 600 --- --- ns TSTAS Repeat START condition, SDIO rising edge to SCLK falling edge setup timing 600 --- --- ns TSTOS STOP condition, SDIO rising edge to SCLK rising edge setup timing 600 --- --- ns TSCKH SCLK High Pulse Width 600 --- --- ns TSCKL SCLK Low Pulse Width 1.3 --- --- us TRISE Rise Time for all 2-Wire Signals --- --- 300 ns TFALL Fall Time for all 2-Wire Signals --- --- 300 ns TSDIOS SDIO to SCLK Rising Edge DATA Setup Time 400 --- --- ns TSDIOH SCLK falling Edge to SDIO DATA Hold Time 0 --- 600 ns Table 33: 2-WireTiming Parameters NAU8502 Datasheet Rev2.5 Page 80 of 93 Aug, 2018 14 AUDIO INTERFACE TIMING DIAGRAM 14.1 AUDIO INTERFACE IN SLAVE MODE TBCK BCLK (Slave) FS (Slave) TFALL TBCKH TFSH TFSS TRISE TFSH TBCKL TFSS TDOD ADCOUT Figure 32: Audio Interface Slave Mode Timing Diagram 14.2 AUDIO INTERFACE IN MASTER MODE BCLK (Master) TFSD TFSD FS (Master) TDOD ADCOUT Figure 33: Audio Interface in Master Mode Timing Diagram NAU8502 Datasheet Rev2.5 Page 81 of 93 Aug, 2018 14.3 PCM AUDIO INTERFACE IN SLAVE MODE (PCM Audo Data) TBCK BCLK (Slave) TFSH FS (Slave) TRISE TBCKH TFSH TFSS TFALL TBCKL TFSS TDOD ADCOUT MSB Figure 34: PCM Audio Interface Slave Mode Timing Diagram 14.4 PCM AUDIO INTERFACE IN MASTER MODE (PCM Audo Data) BCLK (Master) FS (Master) TFSD TFSD TFSD TDOD MSB ADCOUT Figure 35: PCM Audio Interface Slave Mode Timing Diagram NAU8502 Datasheet Rev2.5 Page 82 of 93 Aug, 2018 14.5 PCM AUDIO INTERFACE IN SLAVE MODE (PCM Time Slot Mode ) TBCK BCLK (Slave) TFSH TBCKH TFSH TFSS FS (Slave) TRISE TFALL TFSS TBCKL TDOD ADCOUT MSB Figure 36: PCM Audio Interface Slave Mode (PCM Time Slot Mode )Timing Diagram 14.6 PCM AUDIO INTERFACE IN MASTER MODE (PCM Time Slot Mode ) BCLK (Master) TFSD TFSD FS (Master) TDOD ADCOUT MSB Figure 37: PCM Audio Interface Master Mode (PCM Time Slot Mode )Timing Diagram NAU8502 Datasheet Rev2.5 Page 83 of 93 Aug, 2018 SYMBOL DESCRIPTION MIN TYP MAX UNIT TBCK BSCK Cycle Time (Slave Mode) 50 --- --- ns TBCKH BSCK High Pulse Width (Slave Mode) 20 --- --- ns TBCKL BSCK Low Pulse Width (Slave Mode) 20 --- --- ns TFSS fs to SCK Rising Edge Setup Time (Slave Mode) 20 --- --- ns TFSH SCK Rising Edge to fs Hold Time (Slave Mode) 20 --- --- ns TFSD fs to SCK falling to fs transition (Master Mode) --- --- 10 ns TRISE Rise Time for All Audio Interface Signals --- --- 0.135TBCK ns TFALL Fall Time for All Audio Interface Signals --- --- 0.135TBCK ns TDIS ADCIN to SCK Rising Edge Setup Time 15 --- --- ns TDIH SCK Rising Edge to ADCIN Hold Time 15 --- --- ns Table 34: Audio Interface Timing Parameters 14.7 System Clock (MCLK) Timing Diagram TMCLKH MCLK TMCLKL Figure 38: MCLK Timing Diagram PARAMETER MCLK Duty Cycle SYMBOL TMCLKDC TEST CONDITIONS MIN 60:40 TYP MAX 40:60 UNIT MCLK High Pulse Width TMCLKH 20 --- --- ns MCLK Low Pulse Width TMCLKL 20 --- --- ns Table 35: MCLK Timing Parameter NAU8502 Datasheet Rev2.5 Page 84 of 93 Aug, 2018 14.8 µ-LAW ENCODE DECODE CHARACTERISTICS Normalized Encode Decision Levels Digital Code D4 D3 D2 D1 D0 Step Step Step Step Normalized Decode Levels 0 0 0 0 0 8031 : : : : : : : 0 0 0 1 1 1 1 4191 : : : : : : : : : 1 0 0 1 1 1 1 1 2079 : : : : : : : : : 1 0 1 0 1 1 1 1 1023 : : : : : : : : : 1 0 1 1 1 1 1 1 495 : : : : : : : : : 1 1 0 0 1 1 1 1 231 : : : : : : : : : 1 1 0 1 1 1 1 1 99 : : : : : : : : : D7 D6 D5 Sign Chord Chord Chord 1 0 0 : : 1 8159 7903 : 4319 4063 : 2143 2015 : 1055 991 : 511 479 : 239 223 : 103 95 : 35 1 1 1 0 1 1 1 1 33 31 : 3 : : : : : : : : : 1 1 : 1 1 : 1 1 : 1 1 : 1 1 : 1 1 : 1 1 : 1 0 : 1 2 : 0 0 Notes: Sign bit = 0 for negative values, sign bit = 1 for positive values NAU8502 Datasheet Rev2.5 Page 85 of 93 Aug, 2018 14.9 A-LAW ENCODE DECODE CHARACTERISTICS Normalized Encode Decision Levels Digital Code D4 D3 D2 D1 D0 Step Step Step Step Normalized Decode Levels 0 1 0 1 0 4032 : : : : : : : 0 1 0 0 1 0 1 2112 : : : : : : : : : 1 0 1 1 0 1 0 1 1056 : : : : : : : : : 1 0 0 0 0 1 0 1 528 : : : : : : : : : 1 0 0 1 0 1 0 1 264 : : : : : : : : : 1 1 1 0 0 1 0 1 132 : : : : : : : : : 1 1 1 0 0 1 0 1 66 : : : : : : : : : 1 1 0 1 0 1 0 1 1 D7 D6 D5 Sign Chord Chord Chord 1 0 1 : : 1 4096 3968 : 2176 2048 : 1088 1024 : 544 512 : 272 256 : 136 128 : 68 64 : 2 0 Notes: 1. Sign bit = 0 for negative values, sign bit = 1 for positive values 2. Digital code includes inversion of all even number bits NAU8502 Datasheet Rev2.5 Page 86 of 93 Aug, 2018 14.10 µ-LAW / A-LAW CODES FOR ZERO AND FULL SCALE µ-Law Level A-Law Sign bit (D7) Chord bits (D6,D5,D4) Step bits (D3,D2,D1,D0) Sign bit (D7) Chord bits (D6,D5,D4) Step bits (D3,D2,D1,D0) + Full Scale 1 000 0000 1 010 1010 + Zero 1 111 1111 1 101 0101 - Zero 0 111 1111 0 101 0101 - Full Scale 0 000 0000 0 010 1010 14.11 µ-LAW / A-LAW OUTPUT CODES (DIGITAL MW) µ-Law Sample A-Law Sign bit (D7) Chord bits (D6,D5,D4) Step bits (D3,D2,D1,D0) Sign bit (D7) Chord bits (D6,D5,D4) Step bits (D3,D2,D1,D0) 1 0 001 1110 0 011 0100 2 0 000 1011 0 010 0001 3 0 000 1011 0 010 0001 4 0 001 1110 0 011 0100 5 1 001 1110 1 011 0100 6 1 000 1011 1 010 0001 7 1 000 1011 1 010 0001 8 1 001 1110 1 011 0100 NAU8502 Datasheet Rev2.5 Page 87 of 93 Aug, 2018 15 DIGITAL FILTER CHARACTERISTICS PARAMETER TEST CONDITIONS MIN +/- 0.025dB 0 TYP MAX UNIT ADC Filter 0.454*fs Passband -6dB 0.5*fs Passband Ripple +/-0.025 Stopband dB 0.546*fs Stopband Attenuation f > 0.546*fs -60 Group Delay dB 21/fs ADC High Pass Filter High Pass Filter Corner Frequency -3dB 3.7 -0.5dB 10.4 -0.1dB 21.6 Hz Table 57 Digital Filter Characteristics TERMINOLOGY 1. Stop Band Attenuation (dB) – the degree to which the frequency spectrum is attenuated (outside audio band) 2. Pass-band Ripple – any variation of the frequency response in the pass-band region 3. Note that this delay applies only to the filters and does not include NAU8502 Datasheet Rev2.5 Page 88 of 93 Aug, 2018 16 TYPICAL APPLICATION 2.2 K ohm 2.2 K ohm 1uF 1uF 4.7uF 1uF 1uF 2.2 K ohm 2.2 K ohm P1IN P2OUT RLINOUT 1uF 17 18 MIC2N 19 MIC2P 20 MIC1N MIC1P 21 23 24 1uF 22 P1OUT LLINOUT 1uF 1uF 25 16 26 15 27 14 P2IN 1uF VMID VDDA/ LDOVOUT 4.7uF VREF 4.7uF GPIO/SO GPIO VSSA1 CSb NAU8502 Stereo AUDIO ADC QFN 32-pin 28 29 13 12 30 11 31 10 32 9 LDOVIN MICBIAS 10 K ohm 4.7uF 5V 4.7uF VSSA2 LDOENABLE FS 200 Ohm SDIO ADCOUT 8 BCLK 7 MCLK 6 MODE 5 VSSD 4 VDDC 3 VDDB 2 SCLK GPIO 1 33PF 0 Ohm 33PF 200 Ohm 4.7uF Figure 39: Application Diagram for 32-Pin QFN Note 1: All non-polar capacitors are assumed to be low ESR type parts, such as with MLC construction or similar. If capacitors are not low ESR, additional 0.1uF and/or 0.01uF capacitors may be necessary in parallel with the bulk 4.7uF capacitors on the supply rails. Note 2: Load resistors to ground on outputs may be helpful in some applications to insure a DC path for the output capacitors to charge/discharge to the desired levels. If the output load is always present and the output load provides a suitable DC path to ground, then the additional load resistors may not be necessary. If needed, such load resistors are typically a high value, but a value dependent upon the application requirements. Note 3: To minimize pops and clicks, large polarized output capacitors should be a low leakage type. Note 4: Depending on the microphone device and PGA gain settings, common mode rejection can be improved by choosing the resistors on each node of the microphone such that the impedance presented to any noise on either microphone wire is equal. Note 5; SCLK and SDIO can use low pass filters to filter out glitch. The low pass filter corner frequency range is from 8MHz to 33MHz depending on PCB parasitic. NAU8502 Datasheet Rev2.5 Page 89 of 93 Aug, 2018 PACKAGE SPECIFICATION 32-lead plastic QFN 32L; 5X5mm2, 0.8mm thickness, 0.5mm lead pitch QFN32 Package NAU8502 Datasheet Rev2.5 Page 90 of 93 Aug, 2018 17 ORDERING INFORMATION Part Number Dimension Package NAU8502YG 5x5 mm QFN-32 Package Material Green NAU8502 _ _ Package Material: G = Pb-free Package Package Type: Y = 32-Pin QFN Package NAU8502 Datasheet Rev2.5 Page 91 of 93 Aug, 2018 18 REVISION HISTORY VERSION DATE 0.99 June 2011 1.0 January , 2012 2.0 September, 2012 2.1 October, 2013 2.2 March, 2014 PAGE 88, 90 DESCRIPTION Changed the package reference to 32 QFN from 24 Pin QFN 88 Corrected the 32QFN package diagram 79 Corrected 2 wire interface timing diagram 83 Corrected rising/fall time specification of I2S 88 Modified application circuit 2.3 Nov. 2014 79 I2C Isdios setup time 2.4 Jan 2015 1 Updated AECQ100 description 2.5 August 2018 88, 89 NAU8502 Datasheet Rev2.5 Low pass filters are added for I2C Page 92 of 93 Aug, 2018 Important Notice Nuvoton Products are neither intended nor warranted for usage in systems or equipment, any malfunction or failure of which may cause loss of human life, bodily injury or severe property damage. Such applications are deemed, “Insecure Usage”. Insecure usage includes, but is not limited to: equipment for surgical implementation, atomic energy control instruments, airplane or spaceship instruments, the control or operation of dynamic, brake or safety systems designed for vehicular use, traffic signal instruments, all types of safety devices, and other applications intended to support or sustain life. All Insecure Usage shall be made at customer’s risk, and in the event that third parties lay claims to Nuvoton as a result of customer’s Insecure Usage, customer shall indemnify the damages and liabilities thus incurred by Nuvoton. NAU8502 Datasheet Rev2.5 Page 93 of 93 Aug, 2018
NAU8502YG 价格&库存
很抱歉,暂时无法提供与“NAU8502YG”相匹配的价格&库存,您可以联系我们找货
