W83116WG-511
W83116WG-511
    NUVOTON(新唐)
    ICCLOCKGENERATOR56-TSSOP
W83116WG-511 数据手册
Clock Generator Page 1 of 1 Clock Generator Part No. Datasheet W83116WG-511 Request The W83116WG-511 is a low power clock synthesizer for Intel® Broadwater series chipsets, which has low power differential outputs, an integrated Voltage regulator, as well as an integrated 33Ω series resistor. It also provides all of the clocks required for the high-speed microprocessor, and step-less frequency programming. Description The W83116WG-511 supports 32 different frequencies of CPU, PCI, PCIEX clock setting, as well as SATA and DOT clock outputs. All clocks are externally selectable with smooth transitions. Programming the registers through I2C serial bus interface can enable or disable each clock output, reduce EMI by -0.5% down type spread spectrum or programmable S.S.T. scale. Dynamic over-clocking is also available. The W83116WG-511 accepts a 14.318 MHz reference crystal as its input and runs on a 3.3V power supply. 3 Differential pairs of CPU clock outputs 4x 3V66 clock outputs, and 10x PCI synchronous clocks 24_48Mhz clock output for super I/O, and 48 MHz clock output for USB. Skew form CPU to PCI clock 1 to 4 ns, center 2.6 ns Smooth frequency switch with selections from 66.8 to 200MHz Step-less frequency programming I2C 2-Wire serial interface and support byte read/write and block read/write. -0.5% and +/- 0.25% center type spread spectrum or programmable S.S.T. scale to reduce EMI Programmable registers to enable/stop each output and select modes Watch Dog Timer and RESET# output pins Features Diagram N/A Package W83116WG-511: TSSOP 64 Pb-free package Other Files N/A Development Tools N/A Others N/A Contact us:ComputerIC@nuvoton.com http://www.nuvoton.com/nuvotonmoss/community/productinfo.aspx?tp_guid=a1293383-01c9-4480-94bd-1fba2... 8/27/2013
W83116WG-511 价格&库存
很抱歉,暂时无法提供与“W83116WG-511”相匹配的价格&库存,您可以联系我们找货
