74LVC1G125
Bus buffer/line driver; 3-state
Rev. 12 — 2 December 2016
Product data sheet
1. General description
The 74LVC1G125 provides one non-inverting buffer/line driver with 3-state output.
The 3-state output is controlled by the output enable input (OE). A HIGH-level at pin OE
causes the output to assume a high-impedance OFF-state.
The input can be driven from either 3.3 V or 5 V devices. This feature allows the use of
this device in a mixed 3.3 V and 5 V environment.
This device is fully specified for partial power-down applications using IOFF. The IOFF
circuitry disables the output, preventing the damaging backflow current through the device
when it is powered down.
2. Features and benefits
Wide supply voltage range from 1.65 V to 5.5 V
High noise immunity
Complies with JEDEC standard:
JESD8-7 (1.65 V to 1.95 V)
JESD8-5 (2.3 V to 2.7 V)
JESD8-B/JESD36 (2.7 V to 3.6 V)
24 mA output drive (VCC = 3.0 V)
ESD protection:
HBM JESD22-A114F exceeds 2000 V
MM JESD22-A115-A exceeds 200 V
CMOS low power consumption
Inputs accept voltages up to 5 V
Latch-up performance exceeds 250 mA
Direct interface with TTL levels
Multiple package options
Specified from 40 C to +85 C and 40 C to +125 C
74LVC1G125
Nexperia
3. Ordering information
Table 1.
Type number
Package
Temperature range
Name
Description
Version
74LVC1G125GW
40 C to +125 C
TSSOP5
plastic thin shrink small outline package; 5 leads;
body width 1.25 mm
SOT353-1
74LVC1G125GV
40 C to +125 C
SC-74A
plastic surface-mounted package; 5 leads
SOT753
74LVC1G125GM
40 C to +125 C
XSON6
plastic extremely thin small outline package;
no leads; 6 terminals; body 1 1.45 0.5 mm
SOT886
74LVC1G125GF
40 C to +125 C
XSON6
no leads; 6 terminals; body 1 1 0.5 mm
SOT891
74LVC1G125GN
40 C to +125 C
XSON6
extremely thin small outline package; no leads;
6 terminals; body 0.9 1.0 0.35 mm
SOT1115
74LVC1G125GS
40 C to +125 C
XSON6
6 terminals; body 1.0 1.0 0.35 mm
SOT1202
74LVC1G125GX
40 C to +125 C
X2SON5
X2SON5: plastic thermal enhanced extremely thin SOT1226
small outline package; no leads; 5 terminals;
body 0.8 0.8 0.35 mm
4. Marking
Table 2.
Marking
Type number
Marking code[1]
74LVC1G125GW
VM
74LVC1G125GV
V25
74LVC1G125GM
VM
74LVC1G125GF
VM
74LVC1G125GN
VM
74LVC1G125GS
VM
74LVC1G125GX
VM
[1]
The pin 1 indicator is located on the lower left corner of the device, below the marking code.
5. Functional diagram
2(
Fig 1.
Logic symbol
74LVC1G125
Product data sheet
(1
2(
PQD
PQD
Fig 2.
IEC logic symbol
All information provided in this document is subject to legal disclaimers.
PQD
Fig 3.
Logic diagram
Nexperia B.V. 2017. All rights reserved
2 of 20
74LVC1G125
Nexperia
6. Pinning information
6.1 Pinning
/9&*
/9&*
2(
*1'
9&&
2(
9&&
QF
*1'
DDI
7UDQVSDUHQWWRSYLHZ
DDI
Fig 4.
Pin configuration SOT353-1 and SOT753
Fig 5.
Pin configuration SOT886
/9&*
/9&*
2(
2(
9&&
QF
*1'
9&&
*1'
DDI
DDD
7UDQVSDUHQWWRSYLHZ
7UDQVSDUHQWWRSYLHZ
Fig 6.
Pin configuration SOT891, SOT1115 and
SOT1202
Fig 7.
Pin configuration SOT1226 (X2SON5)
6.2 Pin description
Table 3.
Pin description
Symbol
Pin
Description
TSSOP5 and X2SON5
XSON6
OE
1
1
output enable input
A
2
2
data input
GND
3
3
ground (0 V)
Y
4
4
data output
n.c.
5
not connected
VCC
5
6
supply voltage
74LVC1G125
Product data sheet
3 of 20
74LVC1G125
Nexperia
7. Functional description
Table 4.
Function table[1]
Input
Output
OE
A
Y
L
L
L
L
H
H
H
X
Z
[1]
H = HIGH voltage level;
L = LOW voltage level;
X = don’t care;
Z = high-impedance OFF-state.
8. Limiting values
Table 5.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
IIK
input clamping current
VI
input voltage
IOK
output clamping current
output voltage
VO
IO
output current
ICC
supply current
IGND
ground current
Ptot
total power dissipation
Tstg
storage temperature
Conditions
VI < 0 V
[1]
Min
Max
Unit
0.5
+6.5
V
50
0.5
+6.5
V
mA
50
Active mode
[1][2]
0.5
VCC + 0.5
V
Power-down mode
[1][2]
0.5
+6.5
V
50
mA
100
mA
100
mA
250
mW
65
+150
C
VO > VCC or VO < 0 V
VO = 0 V to VCC
Tamb = 40 C to +125 C
[3]
[1]
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
[2]
When VCC = 0 V (Power-down mode), the output voltage can be 5.5 V in normal operation.
[3]
mA
For TSSOP5 and SC-74A packages: above 87.5 C the value of Ptot derates linearly with 4.0 mW/K.
For XSON6 and X2SON5 package: above 118 C the value of Ptot derates linearly with 7.8 mW/K.
74LVC1G125
Product data sheet
4 of 20
74LVC1G125
Nexperia
9. Recommended operating conditions
Table 6.
Symbol
Parameter
VCC
supply voltage
VI
input voltage
VO
output voltage
Conditions
Tamb
ambient temperature
t/V
input transition rise and fall rate
Min
Typ
Max
Unit
1.65
5.5
V
V
Active mode
VCC
V
VCC = 0 V; Power-down mode
V
40
+125
C
VCC = 1.65 V to 2.7 V
ns/V
VCC = 2.7 V to 5.5 V
10
ns/V
10. Static characteristics
Table 7.
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Conditions
Min
Typ[1]
Max
0.65 VCC
V
Unit
Tamb = 40 C to +85 C
VIH
VIL
VOL
VOH
HIGH-level input voltage
LOW-level input voltage
LOW-level output voltage
VCC = 1.65 V to 1.95 V
VCC = 2.3 V to 2.7 V
1.7
V
VCC = 2.7 V to 3.6 V
2.0
V
VCC = 4.5 V to 5.5 V
0.7 VCC
V
0.7
V
0.8
V
0.35 VCC V
0.3 VCC V
VI = VIH or VIL
VCC = 1.65 V to 5.5 V; IO = 100 A
0.1
V
VCC = 1.65 V; IO = 4 mA
0.45
V
VCC = 2.3 V; IO = 8 mA
0.3
V
VCC = 2.7 V; IO = 12 mA
0.4
V
VCC = 3.0 V; IO = 24 mA
0.55
V
VCC = 4.5 V; IO = 32 mA
0.55
V
VCC 0.1
V
HIGH-level output voltage VI = VIH or VIL
1.2
V
1.9
V
2.2
V
2.3
V
3.8
V
II
input leakage current
VCC = 0 V to 5.5 V; VI = 5.5 V or GND
0.1
1
A
IOZ
OFF-state output current
VCC = 3.6 V; VI = VIH or VIL;
VO = 5.5 V or GND
0.1
2
A
74LVC1G125
Product data sheet
5 of 20
74LVC1G125
Nexperia
Table 7.
Static characteristics …continued
Symbol Parameter
Conditions
Min
Typ[1]
Max
Unit
IOFF
power-off leakage current VCC = 0 V; VI or VO = 5.5 V
0.1
2
A
ICC
supply current
VI = 5.5 V or GND;
VCC = 1.65 V to 5.5 V; IO = 0 A
0.1
4
A
ICC
additional supply current
per pin; VCC = 2.3 V to 5.5 V;
VI = VCC 0.6 V; IO = 0 A
5
500
A
CI
input capacitance
5
pF
0.65 VCC
V
1.7
V
2.0
V
V
VIH
VIL
VOL
VOH
0.7 VCC
0.7
V
0.8
V
0.1
V
0.70
V
0.35 VCC V
0.3 VCC V
VI = VIH or VIL
0.45
V
0.60
V
0.80
V
0.80
V
VCC 0.1
V
0.95
V
1.7
V
1.9
V
2.0
V
3.4
V
II
1
A
IOZ
VO = 5.5 V or GND
2
A
IOFF
2
A
ICC
supply current
VI = 5.5 V or GND;
4
A
ICC
500
A
[1]
All typical values are measured at VCC = 3.3 V and Tamb = 25 C.
74LVC1G125
Product data sheet
6 of 20
74LVC1G125
Nexperia
11. Dynamic characteristics
Table 8.
Voltages are referenced to GND (ground = 0 V). For test circuit see Figure 10.
Symbol Parameter
40 C to +85 C
Conditions
Min
Max
Min
Max
1.0
3.3
8.0
1.0
10.5
ns
0.5
2.2
5.5
0.5
7
ns
VCC = 2.7 V
0.5
2.5
5.5
0.5
7
ns
VCC = 3.0 V to 3.6 V
0.5
2.1
4.5
0.5
6
ns
0.5
1.7
4.0
0.5
5.5
ns
1.0
4.1
9.4
1.0
12
ns
propagation delay A to Y; see Figure 8
tpd
enable time
ten
OE to Y; see Figure 9
[2]
[3]
0.5
2.8
6.6
0.5
8.5
ns
VCC = 2.7 V
0.5
3.3
6.6
0.5
8.5
ns
0.5
2.4
5.3
0.5
7
ns
0.5
2.1
5.0
0.5
6.5
ns
1.0
4.3
9.2
1.0
12
ns
0.5
2.7
5.0
0.5
6.5
ns
VCC = 2.7 V
0.5
3.0
5.0
0.5
6.5
ns
0.5
3.1
5.0
0.5
6.5
ns
0.5
2.2
4.2
0.5
5.5
ns
output enabled
25
pF
output disabled
6
pF
disable time
tdis
power dissipation
capacitance
CPD
40 C to +125 C Unit
Typ[1]
per buffer; VI = GND to VCC
[4]
[5]
[1]
Typical values are measured at Tamb = 25 C and VCC = 1.8 V, 2.5 V, 2.7 V, 3.3 V and 5.0 V respectively.
[2]
tpd is the same as tPLH and tPHL
[3]
ten is the same as tPZH and tPZL
[4]
tdis is the same as tPLZ and tPHZ
[5]
CPD is used to determine the dynamic power dissipation (PD in W).
PD = CPD VCC2 fi N + (CL VCC2 fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
(CL VCC2 fo) = sum of outputs.
74LVC1G125
Product data sheet
7 of 20
74LVC1G125
Nexperia
12. Waveforms
9,
90
$LQSXW
*1'
W 3+/
W 3/+
92+
90
很抱歉,暂时无法提供与“74LVC1G125GW,165”相匹配的价格&库存,您可以联系我们找货
