COVENTRY™
Clean Room Products
Division of ITW Chemtronics ® Inc.
Econowipes™ Non-Woven Wipes
PRODUCT DESCRIPTION
Econowipes™ consist of 55/45 cellulose/
polyester nonwoven fabric. These wipes have
excellent
absorbency,
and
contamination
entrapment,
as
well
as
high
strength.
Econowipes™ are ideal as an economical utility
wipe for any clean area.
Excellent solvent and dilute acid resistance
Economical
Excellent durability
Excellent particle entrapment
High absorbency capacity and rate
Low ion contamination
Packaged in a Class 100 environment
Low linting compared to cotton
Quarter fold on 6713 improves handling
Creped pattern on 6713 improves softness and
absorbency
TYPICAL APPLICATIONS
Econowipes™ can be used to:
Clean Water Processing Areas
Clean-up Acids and other Chemical Spills
Wipe Down of Machinery, and Instrumentation
Clean Photo-Mask Areas
Clean Laminar Flow Benches
Clean Quartzware
General Purpose Wiping in Cleanrooms
COMPATIBILITY
Econowipes™ are compatible with most
TDS # 6700
AVAILABILITY
Econowipes™
6704
4" x 4" (10.2cm x 10.2cm)
Cellulose/Polyester nonwoven wipe,
1200/bag (12 x 100/inner bag)
6709
9" x 9" (22.9cm x 22.9cm)
3600 wipes/case (12 x 300/bag)
6713
12" x 13" (30.5cm x 33.0cm)
Embossed crepe pattern, quarter folded
500 wipes/case (10 x 50/bag)
6736
36” x 36” (91.4 cm x 91.4 cm)
quarter folded
250 wipes/case (10 x 25/bag)
RoHS/WEEE
Status
MANUFACTURED BY:
COVENTRY™ Clean Room Products
Division of ITW Chemtronics®
8125 Cobb Center Drive
Kennesaw, GA 30152 USA
1-770-424-4888
REV. (06/06)
common solvents such as isopropyl alcohol,
methanol and ketones such as acetone or methyl
ethyl ketone. These wipes are generally compatible
with dilute or weak acids.
TECHNICAL HOT LINE 1-800-TECH-401
Econowipes™ Test Data
Wipe Material
Wipe
Cellulose/Polyester
Nonwoven Fabric
6700
4" x 4" (6704)
Available Dimensions
9" x 9" (6709)
12" x 13" (6713)
Basis Weight
Particle Counts
>/= 100 microns
64-75 g/m2
7.3 million/m2
Chloride Ions
25 ppm
Sodium Ions
60 ppm
Potassium
6 ppm
Phosphate Ions
NVR extracted in isopropanol
NVR extracted in deionized water
Absorbency
Capacity
TECHNICAL AND APPLICATION
ASSISTANCE
None dectected
0.05 g/m2
0.08 g/m2
234 ml/m2
300 %
DISTRIBUTED BY:
Coventry™ Clean Room Products provides a
technical hotline to answer your technical and
application related questions. The toll free number
is: 1-800-TECH-401.
Chemtronics® is a registered trademark of ITW Chemtronics.
All rights reserved. Coventry™ and Econowipes™ are
trademarks of ITW Chemtronics. All rights reserved.
很抱歉,暂时无法提供与“6709”相匹配的价格&库存,您可以联系我们找货
