520
    ACLSTATICIDE
    HANDLE RND 0.312"DIA 1.50"H ALUM
520 数据手册
PROVEN EFFECTIVE IN ELIMINATING STATIC-RELATED PROBLEMS in industry, commercial and institutional facilities Static electricity, a natural phenomenon, is the primary cause of a myriad of problems affecting industry, business and personal life. These problems can be as simple – and yet as annoying – as the shock resulting from walking across a carpet; as costly as the destruction of sensitive electronic components or jamming of machinery; and as dangerous as the ignition of combustible vapors, powders or dust. Although there are many methods of dealing with static, most of them have serious shortcomings, such as limited effectiveness, high cost or short life. ACL’s Staticide®, an inexpensive, easy-to-use topical antistatic solution, is a highly-effective method for long-term static control. It is widely used in a broad range of industries, as well as in the office. Available in several different formulations, Staticide is packaged in gallons or ready-to-use quart bottles with sprayers. It is easily applied on walls, ceilings, floors, carpets, fixtures, work surfaces, tools and equipment, conveyor belts, clothing and other materials. On a hard surface, one gallon of Staticide will cover several thousand square feet, and last from weeks to months, depending on the application. • The key component in any total environmental static control program • Meets MIL-B-81705 and NFPA-56A electrostatic decay criteria • Easy, inexpensive to use and long-lasting • Effective on virtually any material • Can be applied as spray, wipe, dip or by transfer roller coating, gravure coating or flexographic printing • Non-toxic, non-flammable, safe to use • Non-staining, completely biodegradable • Effective on carpeting and tile floors • Available in ready-to-use or concentrated form • Effective in PC board solder fault reduction programs • Meets the requirements for topical antistats as listed in Military Handbook DOD-HDBK-263 • Proven effective in relative humidities below 15% • Used in highly sensitive electronic and EDP operations • Proven effective in eliminating EDP field service problems • Specified by many industrial users • Effective in all office environments where electronic equipment is located THESE ARE SOME OF THE TYPICAL PROBLEMS CAUSED BY STATIC... • The attraction of dirt, dust and bacteria to all environmental surfaces, as well as to products and product packages. • Damage or destruction of sensitive electronic components and subassemblies during manufacture, testing, packaging, shipping or receiving. • Data processing equipment memory loss, pre-triggering, changes in function, data errors, paper jams and other “glitches.” • Removes residues which can contaminate electronic components and/or inhibit conductivity. • Jamming or slipping of paper, plastics or other materials during printing, packaging or converting. • Ignition of combustible vapors, dust or solvents, causing fire or explosion. • Irregularities caused by static in quality printing, heat sealing, silk screening, lamination and other special applications. • Work benches and production surfaces in electronic manufacturing and repair facilities will triboelectric charge electronic components, assemblies, or their handling containers in contact and separation with a surface thereby creating a discharge. 1960 E. Devon Ave, Elk Grove Village, IL 60007 USA 1-800-782-8420 • (847) 981-9212 • fax (847) 981-9278 info@aclstaticide.com • www.aclstaticide.com ISO 9001:2000 Registered GENERAL PURPOSE STATICIDE® REGULAR HEAVY DUTY STATICIDE® STATICIDE® CONCENTRATE Gallons #2001 Gallons #2002 Gallons #3000G Quarts (with sprayer) #2003 Quarts (with sprayer) #2005 Quarts (with sprayer) #3000Q 50 Gallon Drum #3000D STATICIDE® CONCENTRATE Staticide Concentrate is available to save freight, handling and storage costs while offering greater flexibility in dilution. Staticide Concentrate can be diluted with tap water, Isopropyl Alcohol, Carbon Tetrachloride or Perchloroethylene, to meet various processing needs. Concentrate is packaged in quart, gallon and 50 gallon drum containers. Staticide Concentrate should be mixed with water or other solvents in the following concentrate solvent ratios to obtain these Staticide formulations: Regular Heavy Duty Staticide 1:39 General Purpose Staticide 1:99 EXPLANATION OF “GENERAL PURPOSE” VERSUS “REGULAR HEAVY DUTY STATICIDE” PERFORMANCE AND SPECIFICATIONS When properly applied, Staticide® complies with or exceeds all electrostatic decay criteria established for antistatic performance as set forth by NFPA and MIL B-81705, when tested in accordance with Federal Test Standard 101B, Method 4046. Staticide is a proprietary water-based formulation consisting of several quaternary compounds. The following specifications generally apply to Staticide in its ready-to-use form. Classification Antistatic Form Liquid Color Very slight amber/clear Approximate cloud point (oF) 30oF “General Purpose” - Light duty solution for low friction surfaces and clear high gloss materials. Used for all work surfaces, trays, tote bags, PC boards, plastics, dip tubes, components, storage bins, carriers, packaging, film and hard floors. Does not last as long as “Regular” Staticide. If material is non-porous, use “General Purpose.” Approximate solidification point (oF) Odor Slight floral “Regular” Heavy Duty - Long-lasting solution for high friction surfaces. Used for treating carpets, chairs, clothing, conveyor belts, totes and work surfaces with heavy use. If material is porous or absorbent, use “Regular” Heavy Duty. Taste Slightly bitter CONSULTATION ACL, Incorporated will provide reasonable phone consultation regarding application techniques and proper formulation compatible with the standards at no charge. Solubility in water Dilution compatibility +20oF Complete Water, hard or soft Density, lbs/gal 8.3 Specific Gravity 25oc/40oc .98 pH (approximate) 7-8 Irritation None Sensitivity None Toxicity None Surface tension reducing power Flammability Superior None Application Spray, dip, wipe, coat Freeze-Thaw capability Excellent, no adverse effects Shelf Life Indefinite Temperature Stability Withstands up to 30 minutes @ 250oF. SOLVENTS COMPATIBLE WITH STATICIDE CONCENTRATE Tap Water Isopropanol (Alcohol) Freon* Acetone Dioxane Perclene (Perchloroethylene) Mineral Oil** Stoddard Solvent** Methyl Ethyl Ketone Methyl Chloroform Trichloroethane * Mix 1 part Staticide Concentrate with 1 part IPA then add to freon. ** Add to cloud point, then back off. To avoid bubbling, add the concentrate to the solvent. Amount of Staticide Concentrate can be changed to obtain desired control. DILUTE STATICIDE CONCENTRATE AS FOLLOWS TO MAKE STATICIDE READY TO USE PRODUCT: General Purpose Staticide – 40 cc Staticide Concentrate per gallon of solvent Regular Heavy Duty Staticide – 100 cc Staticide Concentrate per gallon of solvent If further instructions are needed or should you have any questions, please contact ACL at 1-800-782-8420. TOXICITY AND MATERIAL SAFETY In ready to use form, Staticide is non-toxic by oral ingestion, inhalation or dermal application, and is not a primary skin or major eye irritant. Staticide is non-flammable, completely stable and will not deteriorate after long periods in storage. 1960 E. Devon Ave, Elk Grove Village, IL 60007 USA 1-800-782-8420 • (847) 981-9212 • fax (847) 981-9278 info@aclstaticide.com • www.aclstaticide.com
很抱歉,暂时无法提供与“520”相匹配的价格&库存,您可以联系我们找货
