DESCO INDUSTRIES INC TECHNICAL BULLETIN TB-7001
Statguard® Conductive Acrylic Paint
Application Instructions
PMS 432
PMS 429
Figure 1. Statguard® Conductive Acrylic paint.
Test Patch Requirement
A test patch on new applications is required to receive a
full product warranty.
Prior to the shipment of your Statguard® Conductive
Acrylic Paint, Desco Industries Inc (DII) will provide
samples and technical documentation for installing
the test patch. The test patch will allow for a full
evaluation of the floor preparation and of our Statguard®
Conductive Acrylic Paint, performance features to
include color, adhesion, physical properties and
electrical resistance.
Test Patch application instructions are located in the
Surface Preparation section. Please contact your
customer service representative to organize a test patch
kit.
Made in the
United States of America
Allow newly applied paint to dry a minimum of 48 hours
before proceeding with the test. At humidity levels over
55% RH, allow 72 hours of drying time before testing.
Use a razor to cut a cross or a few perpendicular lines
over a 3” by 3” (75 mm by 75 mm) area on several
spots of the thoroughly dried area. (See Figure 2).
Use a piece of masking tape to cover the marked area.
Make sure the tape is thoroughly adhered to the test
area. Pull the tape off the surface and examine the
amount of paint which has peeled off during the test.
If any significant portion is transferred to the tape,
better surface preparation (acid etching, cleaning or
sanding) should be done on the substrate to enhance
the adhesion.
If your test patch is on a bare or prepped concrete we
recommend Bulls Eye® Water-Base Primer and Sealer
to achieve proper performance of the Statguard®
Conductive Acrylic Paint properties. Please contact
Rust-Oleum for additional product details.
Description
Statguard® Conductive Acrylic Paint is a one part floor
coating formulated to produce controlled dissipation of
static electrical charges. Statguard® Conductive Acrylic
Paint is very effective as a static control floor coating
for electronics manufacturing, assembly, and storage.
It is available in grey (similar to PMS 432) in 5 gallon
(19 liters) containers; and in light grey (similar to PMS
429) in 5 gallon (19 liters) containers. The color may
vary between production lots.
NOTE: Statguard® Conductive Acrylic Paint should
not be allowed to freeze. Store at temperatures above
34°F (1°C) as stated in the Safety Data Sheet. We
recommend that these products be stored in their
original containers and be sealed when not in use. We
cannot guarantee performance if not properly mixed or
used within 3 months from date of sale.
Surface Preparation
1. Use a razor to cut into a
painted, dried floor.
2. Apply tape on the precut
area.
3. Pull the tape off.
4. Examine the degree of paint
separation from the concrete.
The two most important characteristics for successful
application of Statguard® Conductive Acrylic Paint
applications are:
1. The surface must be clean, dry, dull, and smooth.
Heavy dirt or grease build-up should be removed
with a stripper or degreaser. Cleaning methods
range from: sweeping, vacuuming, wire brush,
air-blasting, water jet, steam cleaning, or stripping.
2. If the surface is concrete, it must be in good
condition.
Figure 2. Adhesion test on the painted floor.
DESCO INDUSTRIES INC - 3651 Walnut Avenue, Chino, CA 91710 • (909) 627-8178 • Website: DescoIndustries.com
TB-7001 Page 1 of 5
February 2021
© 2021 DESCO INDUSTRIES INC
Employee Owned
CONCRETE:
New concrete should cure for a minimum of 28 days
before coating with Statguard® Conductive Acrylic Paint.
Not all concrete is created equal -- concrete surfaces
vary widely in physical and chemical qualities due to the
way the concrete was formulated, poured, or finished.
UNPAINTED SURFACES:
Adhesion can be improved by using a standard
industrial type primer. Metal should be primed with red
oxide primer. Concrete, wood, plastics, and most other
surfaces should be properly cleaned. Let dry and then
apply Statguard® Conductive Acrylic Paint.
There are several methods to prepare problem
concrete. Each method depends on the condition of
the concrete. Adhesion properties can be increased by
profiling or roughing the surface through acid etching,
rotary drum sanding, scarifying, or mechanically
scratching the surface.
COVERAGE:
Statguard® Conductive Acrylic Paint will cover 300 to
400 square feet (27.87 to 37.16 square meters) at a
1 to 1.5 mil (0.0254 to 0.0381 mm) thick dry film per
gallon (3.87 liters) on a smooth surface. Coverage is
less on coarse or textured surfaces. Two coats are
recommended to achieve maximum performance from
the paint.
You must test for moisture in the concrete. If moisture is
present, the floor should not be coated until the source
of the moisture is determined and eliminated.
Limitations
Below criteria is generally accepted for concrete and
other porous substrates:
• Do not install when the moisture vapor emission
rate (MVER) exceeds 6lbs. per 1,000 sq. ft. (2.72
kg per 92.9 m2) per 24 hours, Measure the MVTR
of the concrete prior to tile installation, using the
industrial standard test probes per ASTM F2170.Do
not install with relative humidity of concrete slabs
exceeds 75% (ASTM F2170)
• Use only when the substrate temperature is
between 65°F and 85°F (18°C and 29°C)
Warning: Moisture levels greater than above mentioned
may negatively affect the drying/curing process, bond
strength to substrate, as well as hardness of the finished
film.
PRIMING:
Statguard® Conductive Acrylic Paint bonds well to
primed/sealed clean, dry concrete. However if the
sub floor is bare or prepped concrete we recommend
using the Bulls Eye® Water-Base Primer and Sealer
Installing Statguard Conductive Acrylic Paint on
improperly prepared surfaces will void product warranty
and cause product failure.
PREVIOUSLY PAINTED SURFACES:
The surface should be clean and free of dust, grease,
wax, and soap residue. Wash with ordinary detergent
and water. Rinse thoroughly with clean water and let
dry. Glossy surfaces can be dulled by lightly sanding
and then vacuuming and cleaning. Cracks and holes
should be repaired before applying the Statguard®
Conductive Acrylic Paint. Adhesion can be improved by
using a standard industrial type primer.
Application
Always use in a well ventilated area or wear a suitable
respirator. Wear appropriate eye protection such as
splash goggles and impervious type protection gloves to
protect hands.
MIXING
1. Mix paint thoroughly before use (See Figure 3)
using a 500-1500 RPM variable speed drill and
paint mixing attachment or a paint mixer.
2. If the paint, after properly mixing, is not freely
transferring from the roller to the floor, the
Statguard® ESD paint can be thinned with water up
to 10% max by volume.
a. Start by slowly mixing 5% water into the master
container and apply again.
b. Do not add more than 10% of water to the mix.
1. Mix any settled solids to
2. Combine separate cans
produce a uniform grey color. into a larger container.
3. Separate a 1/4" fine nap
roller with paint, remove excess paint and trapped air.
4. A minimum number of
strokes from the applicator is
recommended.
Figure 3. Paint application with roller.
TB-7001 Page 2 of 5
Employee Owned
APPLICATION BY ROLLER
1. Stir paint thoroughly to mix any settled solids to
produce uniform grey color.
2. Combine separate cans of paint into one
container to ensure uniform color distribution. It is
recommended that a test area be coated to ensure
that the adhesion and electrical performance of the
paint is acceptable. (See Adhesion Testing, Figure
2.) If the test areas show inadequate adhesion, use
an industrial floor primer/sealer.
3. Saturate a 1/4” (6.35 mm) fine nap roller or an
industrial brush with paint. Remove excess paint
and trapped air from the applicator by moving
applicator several times in the paint tray.
4. A minimum number of strokes from the applicator
on the substrate is recommended to minimize air
bubbles.
APPLICATION BY SPRAY
Conventional Spray Gun:
“E” fluid tip and needle and
#704, 765 or 78 air gap.
Airless Spray: Spray gun
and spray cap or suitable
orifice diameter 0.020-0.025”
(0.508-0.635 mm).
before using and stir
occasionally when applying.
No thinning necessary for
Figure 4. Spray paint
spray applications. Room
temperature must be above application.
50°F (10°C).
A minimum of two coats of Statguard® Conductive
Acrylic Paint is recommended for appropriate static
protection.
Grounding
Conventional grounding practices like connecting coated
surfaces to equipment or earth ground is recommended
for meeting ANSI/ESD S20.20, EN 61340-5-1 and ISO
9000 recommendations for verifying grounds. However
the following is also true of conductive Acrylic Paint
flooring “Floor finishes … function by two separate
mechanisms. First, they reduce the surface’s tendency
to generate a static charge.
Second, they provide a path for the dissipation of
charge. The charge may dissipate over the surface of
the finish or it may dissipate to ground if the floor finish
is grounded.” [Per ESD Handbook ESD TR20.20 section
5.3.4.2]
Figure 5. ESD Floor Ground Strip.
Four examples on how to achieve connection to
the Conductive Acrylic Paint surface are:
1. Install a Statguard® ESD Floor Ground
Strip per 1,000 square feet throughout the
installation.
2. Bring Conductive Acrylic Paint coating in
contact with a building ground rod.
3. Install a grounded lag bolt to the floor so the
bolt comes in contact with the Conductive
Acrylic Paint when screwed in place.
4. Bolt a grounded metal plate to the Conductive
Acrylic Paint surface.
Statguard® Conductive Acrylic Paint applied in
excess of 50 square feet (4.6 square meters)
enable the surface to dissipate 5000 volts to zero
in less than 0.01 seconds per FTMS 101C, Method
4046 without conventional grounding grids or wires.
The conductive coating becomes a capacitive
reservoir that effectively drains static charges.
ESD footwear must be used in conjunction with
Statguard® Conductive Acrylic Paint to ground
personnel.
If footwear/flooring is being used as a primary
ground to meet the personnel grounding
requirements of ANSI/ESD S20.20 then we would
advise to ground the Conductive Acrylic Paint for
testing and verification of a ground point. If the
footwear/flooring are being used as a secondary
or back up grounding for personnel then grounding
practices like electrically connecting Statguard®
Dissipative Floor Finish to ground is only required
for applications of Conductive Acrylic Paint that
are less than 50 square feet. For applications that
are greater than 50 square feet, the capacitance of
Conductive Acrylic Paint is several hundred times
greater than the capacitance of the human body
model at 100pF. The difference in capacitance
is so great that the Statguard® treated floor
acts as a second capacitor in series with the
person and a human body charge even as great
as 5,000 volts will have a resulting voltage well
below the 100V limit peak of ANSI/ESD S20.20.
The surface resistance of the Statguard® treated
floor will decay a 5000v charge to zero in .05 sec.
per FTMS 101B, Method 4046. Statguard® has
substantially less than the maximum static decay
time of 0.1 seconds.
TB-7001 Page 3 of 5
Employee Owned
Clean Up
Physical Properties
Wash applicators with water immediately after painting.
Remove paint spills promptly with a wet cloth. Close
container after each use. Keep container from freezing.
Type
Water base acrylic coating
Color
Grey, Light Grey
Finish/Sealer
Statguard® Conductive Acrylic Paint can be overcoated
or sealed with Statguard® Floor Finish static
dissipative coating to increase durability, enhance
shine, improve ease of maintenance, and seal out
dirt and debris. Because of the matte finish of
Statguard® Conductive Light Grey Acrylic Paint
it is recommended that Statguard® Floor Finish
be applied for gloss and ease of maintenance.
Statguard® Dissipative Floor Finish is a polymer base
floor finish/sealer that can be used as a top coat on
the Conductive Acrylic Paint. Surface Resistance will
then be in the 1 x 105 to < 1 x 108 ohm range. Two
coats are recommended. Three coats will improve
electrical properties, durability and reduce frequency of
maintenance. Apply Statguard® Floor Finish after 48-72
hours after last coat of paint. Paint becomes dry to the
touch, but is not fully cured to accept a finish coat until
this time. If you notice the paint color coming off when
finishing,it is too soon to apply. Please wait for the paint
to cure fully. Ask for Technical Bulletin TB-7042 for
more information on Statguard® Floor Finish.
Maintenance
Use sweeper, vacuum, or broom to remove dirt. Allow
two weeks drying time before using a damp mop to
clean the coated area. Do not use abrasive cleaners,
floor rinse, or scrubbing machine to clean the floor.
Drying Time
Vehicle Type Pure acrylic resin waterborne
Pigment
Type
Lead free, iron oxide, titanium dioxide
and extenders
Viscosity
Light Grey 26" #3 Zayn cup
Grey
Solids
23" #3 Zayn cup
Light Grey 24% by volume
Grey
20% by volume
Coating
Density
Light Grey 9.54 lbs per gallon
Gloss
Light Grey 2 @ 60° Gloss
Grey
Grey
Temperature Wet
Range
Dry
Electrical Properties
10.27 lbs per gallon
(1.0 kilograms per liter)
22 @ 60° Gloss
33°F - 110°F (1°C - 43°C)
33°F - 300°F (1°C - 149°C)
(300°F [149°C] not
continuous)
Static Charge Decay
< 0.01 sec. per FTMS B,
Method 4046
Charge Generation
Zero per AATCC Step Test,
Method 134-1979
Rtt
1 x 104 to < 1 x 107 ohms
per ANSI/ESD STM 7.1
Rtg
It is recommended that Statguard® Conductive Acrylic
Paint be allowed to dry at a temperature in excess
of 45°F (7°C) until dry. A minimum of 1 to 2 hours
drying time should be allowed before applying the
second coat. The 2nd coat should be allowed to cure
for 24 hours before taking electrical readings. After 24
hours readings taken will be reflective of the long term
electrical characteristics of the material.
TB-7001 Page 4 of 5
Employee Owned
Testing
Test patch areas should be tested for adhesion and
electrical performance of the paint before applying paint
to the entire floor. To best ensure consistent results, the
test should be done at various locations.
ELECTRICAL PROPERTIES:
Test the surface, point-to-point resistance, (Rtt) and
resistance-to-ground (Rtg) properties of coated area
per ANSI/ESD STM7.1 test method and/or ESD TR53.
For quick and easy verification of the paint’s electrical
properties, we recommend the use of our a Surface
Resistance Test Kit (Figure 6).
For more information contact any of the DESCO
INDUSTRIES INC. companies
RoHS 3, REACH, and Conflict Minerals Statement
See the Desco Industries RoHS 3, REACH, and
Conflict Minerals Statement:
Descoindustries.com/ROHS.aspx
Desco Industries Limited Warranty
See the Statguard Flooring Limited Warranty:
Statguard.descoindustries.com/Limited-Warranty.aspx
Statguard® Conductive Acrylic Paint is available
from these Desco Industries brands:
for service and support in North America
5 Gallons
Dark Grey
46041
5 Gallons
Light Grey
46051
for service and support in United Kingdom and Europe
19 Litres
Dark Grey
210221
19 Litres
Light Grey
210222
for service and support in Asia
19 Litres
Dark Grey
46041
19 Litres
Light Grey
46051
Figure 6. Electrical testing on the painted floor using
a Surface Resistance Test Kit.
TB-7001 Page 5 of 5
Employee Owned
