Gemini-ESD Mat
Static Dissipative Work Surface Material
The Gemini ESD Mat is a dual-layer, static dissipative, polymer-based
material made for bench tops and other grounded workbench surfaces. Polymers used in this material are homogeneously dispersed
with an anti-static formula, leaving a permanent surface and volume
resistance that will conform to the most stringent ESD requirements.
With a dissipative upper layer and a conductive base, this material is
as durable as rigid laminates, and as comfortable and appealing as
rubber. It is suitable for use with constant monitor systems.
The extrusion process used in manufacturing allows for low outgassing and high durability. Layers are laminated during the molten
stage of manufacturing to ensure a successful bond and long life.
The electrical properties will not wear away or exudate.
Color shown is a representation and may vary
Maintenance:
To keep mats clean and avoid insulative
electrical readings, use a neutral cleaner
such as the 6001 Mat and Table Top
Cleaner. The low alcohol, high surfactant
formula will allow deep cleaning without
damaging the structural integrity of the
Gemini-ESD mat.
Gemini-ESD Mat roll
58200 Light Gray 24” x 50’
58400 Light Gray 30” x 50’
58600 Light Gray 36” x 50’
59100 Royal Blue 24” x 50’
59300 Royal Blue 30” x 50’
59500 Royal Blue 36” x 50’
The Gemini-ESD Mat will deliver a typical resistance-to-ground measurement of 10e6 -10e8 ohms per ANSI/ESDA S4.1. This material
complies with industry standards including EN 61340-5-1: Protection
of Electronic Devices from Electrostatic Phenomena and ANSI / ESDA
S20.20: Protection of Electrical and Electronic Parts, Assemblies and
Equipment.
0.065” (1.65 mm) thickness
106 - 108 ohms, ohm per cm RTG, RTT, Vol R
Can be custom-cut with sharp blade; scraps are recyclable
Embossed finish reduces light glare and parts slippage
Durable surface withstands high temperatures, solder, flux, and
harsh chemicals
Low outgassing and VOC are ideal for controlled environments
Gemini-ESD cut mats are available in various
sizes. Each mat includes two 10mm female
ground snaps. Ground cords sold separately.
Passes weathering ozone resistance per ASTM D178-01
Passes and exceeds minimum standards for NFPA fire and
smoke safety
UV additives to protect color and eliminate fading
The components used to manufacture this
product, including smoke and flame inhibitors,
are RoHS compliant and are not listed on the
REACH SvHC list.
Rolls and cut mats are made in the U.S.A. and
can be shipped under NAFTA rules.
Warranty:
ACL Inc., offers an exclusive lifetime warranty on the electrical resistance
(106 – 108 ohms) properties of our Gemini table mats. If the electrical
properties should fail (when tested to ANSI / ESD S20.20) on any of our table
mats during the lifetime of the mat due to manufacturing or physical defects,
we will replace the mat free of charge.
This warranty does not apply to mats that are abused, improperl used, or
cleaned with mat cleaners not tested and approved by ACL Inc.
840 W. 49th Place · Chicago, IL 60609
800.782.8420 · 847.981.9212 · fax 847.981.9278
info@aclstaticide.com · www.aclstaticide.com
ACL Inc. registered to
ISO-9001 : 2008
Certificate N0. 10002746
rev. September 25, 2014 mkb
很抱歉,暂时无法提供与“5843072”相匹配的价格&库存,您可以联系我们找货
