A.
B.
C.
D.
Outer conductive layer (10^5 RTT)
Inner non-marking neoprene layer
Reinforced with 4.3 oz. polyester mesh scrim layer
.060” thick, 1 ¼” wide contact area
E.
30” long, 3/8” wide, 8 string black conductive ribbon
F, G. 3/4”, double sided hook and loop material, for quick and easy attachment to
foot.
Inner (Rust) Layer
Outside (Black)
Layer
Test Method
Electrical
Characteristics:
Charge Decay
Conductivity
RTG w/1 megohm resistor
RTG w/2 megohm resistor
RTT
Less than 0.01 sec.
8x103 Ohms/sq.
FTMS-1018, Method 4046
1.3x106 Ohms max.
2.3x106 Ohms max.
2 x105 Ohms max.
EOS/ESD-S4.1 @ 100V
RMA-808
EOS/ESD-S4.1 @ 100V
EOS/ESD-S4.1 @ 100V
Specifications:
Abrasion
800 cycles
3000 cycles
ASTM-D3389 Method B
Hardness
70 Shore A
70 Shore A
ASTM-D2240
Elongation
600%
400%
ASTM-D412
Tensile
900lbs.
2500lbs.
ASTM-D412
Note:
One heel grounder on each foot is recommended for proper grounding.
Operator is grounded when heel is in contact with grounded dissipative or conductive flooring.
Desco recommends the use of foot ground tester 19252. Ask for Technical Bulletin TB-2040.
For additional information on the use and maintenance of heel grounders please ask for Technical
Bulletin TB-2020.
Meets the requirements of JEDEC-108/9, MIL-HDBK-263A, MIL-STD-1686,DOD-STD-2000.
07560 with 1 megohm resistor
Specifications and procedures subject to change without notice.
FOOT GROUND, HEEL, ADJUSTABLE
DESCO WEST:3651 WALNUT AVE., CHINO, CA 91710 WEB SITE: Desco.com
PHONE (909) 627-8178 FAX (909) 627-7449 FAX REQUEST (909) 627-7126
DESCO EAST: ONE COLGATE WAY, CANTON, MA 02021-1407
PHONE (781) 821-8370 FAX (781) 575-0172
© 2010 DESCO INDUSTRIES INC.
Employee Owned
DRAWING NUMBER
07560
DATE:
March
2010
很抱歉,暂时无法提供与“07560”相匹配的价格&库存,您可以联系我们找货
