SPECIFICATIONS
PARAMETERS
RATED INPUT POWER
MAX INPUT POWER
IMPEDANCE
AVG. SPL 1W/0.1M ON 4MM
THICK PLA PANEL
(AT 0.5, 1.0, 2.0, 5.0 kHz)
RESONANT FREQUENCY
FREQUENCY RANGE
MAGNET MATERIAL
OPERATING TEMPERATURE
WEIGHT
VALUES
UNITS
1.5
3
4 15%
W
W
OHM
85
dBA
650 20%
Fo~ 10,500
NdFeB
-20~ +60
10
Hz
Hz
THIS DOCUMENT CONTAINS DATA PROPRIETARY TO
PROJECTS UNLIMITED, INC. ANY USE OR
REPRODUCTION, IN ANY FORM, WITHOUT PRIOR
WRITTEN PERMISSION OF PROJECTS UNLIMITED,
INC. IS PROHIBITED.
2003, Projects Unlimited Inc.
REVISION HISTORY
LTR
DESCRIPTION
DATE
APPROVED
A
B
RELEASED FROM ENGINEERING
ADDED NOTE 4
UPDATED MAGNET DIAMETER TOLERANCE
5/18/16
6/27/16
7/21/17
B.R.
M.V.
C
grams
9.5
16.8
0.5
26.5
0.15
15.7
32
9
3M
VHB
MOUNTING RING
DOUBLE-SIDED TAPE
NOTES:
1. ALL DIMENSIONS ARE IN MILLIMETERS.
2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL
WITHOUT NOTICE.
3. THIS PART IS RoHS 2011/65/EU COMPLIANT.
4. FOR APPLICATIONS THAT ARE TO BE SUBJECTED TO
EXTERNAL FORCE, SHOCK, OR VIBRATION, PUI AUDIO
RECOMMENDS SOLID MECHANICAL
REINFORCEMENT TO ENSURE RIGID COUPLING BEYOND
THAT PROVIDED BY THE
3M VHB F-9473PC DOUBLE-SIDED TAPE.
UNLESS OTHERWISE
SPECIFIED:
DIMENSIONS ARE IN
MILLIMETERS,
TOLERANCES
ARE 0.5 AND
ANGLES ARE 3 .
SIZE
A3
ASX02604-R.idw
Designed by
Date
Checked by
Date
Approved by
M.V.
5/18/2016
M.V.
5/18/2016
B.R.
Date
Drawn Date
5/18/2016 5/18/2016
ASX02604-R
Exciter
Edition
Sheet
1/1
很抱歉,暂时无法提供与“ASX02604-R”相匹配的价格&库存,您可以联系我们找货
