SPECIFICATIONS
PARAMETERS
RATED INPUT POWER
MAX INPUT POWER
IMPEDANCE
OUTPUT SPL @ 1W/0.5M
(AT 0.8, 1.0, 1.2, 1.5 Hz)
DISTORTION (MAX.)
RESONANT FREQUENCY
FREQUENCY RANGE
HOUSING MATERIAL
CONE MATERIAL
MAGNET MATERIAL
OPERATING TEMPERATURE
WEIGHT
VALUES
UNITS
1
3
8 15%
W
W
OHM
80
3
THIS DOCUMENT CONTAINS DATA PROPRIETARY TO
PROJECTS UNLIMITED, INC. ANY USE OR
REPRODUCTION, IN ANY FORM, WITHOUT PRIOR
WRITTEN PERMISSION OF PROJECTS UNLIMITED,
INC. IS PROHIBITED.
REVISION HISTORY
LTR
DESCRIPTION
DATE
APPROVED
A
B
C
D
RELEASED FROM ENGINEERING
REVISED WIDTH DIMENSION
REVISED HEIGHT DIMENSION & RESONENT FREQUENCY
REVISED TO INVENTOR 3-D DRAWING TEMPLATE
REVISED OPERATING TEMPERATURE
REVISED HOLE TO HOLE DIMENSION AND RESONANT
FREQUENCY
5/17/2006
10/17/07
8/28/2008
10/7/2008
10/12/2011
C.W.
B.R.
M.L.
2/11/2015
M.L.
2003, Projects Unlimited Inc.
E
dBA
5%
750 20%
250 ~ 20,000
ABS
CLOTH
Nd-Fe-B
-30 ~ +60
4.5
Hz
Hz
C
grams
6
0.3
0.5
1.9
0.3
0.1
2.2 (4)
27
0.3
23
13.7
0.2
0.3
NOTES:
1. ALL DIMENSIONS ARE IN MILLIMETERS.
2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL
WITHOUT NOTICE.
3. THIS PART IS RoHS 2011/65/EU COMPLIANT.
UNLESS OTHERWISE
SPECIFIED:
DIMENSIONS ARE IN
MILLIMETERS,
TOLERANCES
ARE 0.5 AND
ANGLES ARE 3 .
SIZE
A3
AS02708CO-R.idw
Designed by
Date
Checked by
Date
Approved by
J.D.
5/17/2006
R.W.
5/17/2006
B.R.
Date
Drawn Date
5/17/2006 10/7/2008
AS02708CO-R
Speaker
Edition
Sheet
1/1
很抱歉,暂时无法提供与“AS02708CO-R”相匹配的价格&库存,您可以联系我们找货
