AS05008PR-WR-R
AS05008PR-WR-R
    PUIAUDIO
    SPEAKER 8OHM 1W TOP PORT 84DB
AS05008PR-WR-R 数据手册
SPECIFICATIONS PARAMETERS RATED INPUT POWER MAX INPUT POWER IMPEDANCE OUTPUT SPL @ 1W/1M (AT 0.6, 0.8, 1.0, 1.2 kHz) DISTORTION (MAX.) RESONANT FREQUENCY FREQUENCY RANGE HOUSING MATERIAL CONE MATERIAL MAGNET MATERIAL OPERATING TEMPERATURE WEIGHT VALUES UNITS 1 1.5 8 15% W W OHM 84 3 5% 550 20% 550 ~ 5000 METAL TREATED PAPER Nd-Fe-B -30 ~ +55 14.8 THIS DOCUMENT CONTAINS DATA PROPRIETARY TO PROJECTS UNLIMITED, INC. ANY USE OR REPRODUCTION, IN ANY FORM, WITHOUT PRIOR WRITTEN PERMISSION OF PROJECTS UNLIMITED, INC. IS PROHIBITED. REVISION HISTORY LTR DESCRIPTION DATE APPROVED A B RELEASED FROM ENGINEERING REVISED TO INVENTOR 3-D DRAWING TEMPLATE REVISED SPECS. AND DIMENSIONS OF PART, ADDED NOTE 5 5/8/2006 9/25/2007 8/3/2011 B.R. B.R. 2003, Projects Unlimited Inc. dBA Hz Hz - 12 2.3 C grams 0.3 50 18 0.3 NOTES: 1. ALL DIMENSIONS ARE IN MILLIMETERS. 2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL WITHOUT NOTICE. 3. THIS PART IS RoHS 2002/95/EC COMPLIANT. 4. CONE HAS BEEN TREATED FOR WATER RESISTANCE. 5. BASE SPEAKER PUI# AS05008PR-A-R UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MILLIMETERS, TOLERANCES ARE 0.5 AND ANGLES ARE 3 . SIZE A3 AS05008PR-WR-R.idw Designed by Date Checked by Date Approved by Date Drawn Date J.D. 5/8/2006 E.P. 5/9/2006 B.R. 5/9/2006 9/25/2007 AS05008PR-WR-R Speaker Edition Sheet - 1/1
AS05008PR-WR-R 价格&库存
很抱歉,暂时无法提供与“AS05008PR-WR-R”相匹配的价格&库存,您可以联系我们找货
