PUM-3046L-R
PUM-3046L-R
    PUIAUDIO
    MIC COND ANALOG UNI -46DB
PUM-3046L-R 数据手册
SPECIFICATIONS PARAMETERS DIRECTIVITY SENSITIVTY STANDARD OPERATING VOLTAGE MAX OPERATING VOLTAGE CURRENT CONSUMPTION (MAX) IMPEDANCE SIGNAL TO NOISE RATIO (MIN.) TERMINAL INTERNAL CAPACITOR VALUES UNIT UNI -46 4 2 10 0.5 2.2 50 SOLDER PADS - - THIS DOCUMENT CONTAINS DATA PROPRIETARY TO PROJECTS UNLIMITED, INC. ANY USE OR REPRODUCTION, IN ANY FORM, WITHOUT PRIOR WRITTEN PERMISSION OF PROJECTS UNLIMITED, INC. IS PROHIBITED. 2003, Projects Unlimited Inc. LTR DESCRIPTION DATE APPROVED A B C D RELEASED FROM ENGINEERING ADDED TERMINAL POLARITY REVISED TO INVENTOR 3-D DRAWING TEMPLATE REVISED SPECIFICATIONS AND TERMINALS REVISED SIGNAL TO NOISE RATIO 1/31/2006 2/5/2007 10/25/2010 9/1/2011 2/21/2020 D.F. B.R. M.L. M.V. dB Vdc Vdc mA KOhm dB pF 3 6 REVISION HISTORY 0.2 0.1 TERM 1 (+) TERM 2 (-) 0.2 0.1 NOTES: 1. ALL DIMENSIONS ARE IN MILLIMETERS. 2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL WITHOUT NOTICE. 3. THIS PART IS RoHS 2011/65/EU COMPLIANT. UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MILLIMETERS, TOLERANCES ARE 0.5 AND ANGLES ARE 3 . SIZE A3 PUM-3046L-R.idw Designed by Date Checked by Date Approved by J.A.F. 1/31/2006 E.P. 1/31/2006 B.R. Date Drawn Date 1/31/2006 10/25/2010 PUM-3046L-R Microphone Edition Sheet - 1/1
PUM-3046L-R 价格&库存
很抱歉,暂时无法提供与“PUM-3046L-R”相匹配的价格&库存,您可以联系我们找货
