AOM-6545P-R
AOM-6545P-R
    PUIAUDIO
    MIC COND ANALOG OMNI -45DB
AOM-6545P-R 数据手册
SPECIFICATIONS PARAMETERS DIRECTIVITY SENSITIVTY STANDARD OPERATING VOLTAGE MAX OPERATING VOLTAGE CURRENT CONSUMPTION (MAX) IMPEDANCE SIGNAL TO NOISE RATIO (MIN.) TERMINAL INTERNAL CAPACITOR VALUES UNIT OMINI -45 2 4.5 10 0.5 1 60 SOLDER PADS N/A dB Vdc Vdc mA KOhm dB pF THIS DOCUMENT CONTAINS DATA PROPRIETARY TO PROJECTS UNLIMITED, INC. ANY USE OR REPRODUCTION, IN ANY FORM, WITHOUT PRIOR WRITTEN PERMISSION OF PROJECTS UNLIMITED, INC. IS PROHIBITED. LTR DESCRIPTION DATE APPROVED A B C D RELEASED FROM ENGINEERING ADDED TERMINAL POLARITY ADDED TERMINAL DIAMETER REVISED TO INVENTOR 3-D DRAWING TEMPLATE REVISED DIMENSIONS 1/30/2006 1/30/2007 6/23/2010 9/16/2010 2/14/2020 R.W. B.R. B.R. M.V. 2003, Projects Unlimited Inc. 5 9.4 REVISION HISTORY 6.5 2.5 0.2 0.1 0.1 0.4 0.02 (2) 2 TERM 1 (+) 0.25 0.1 TERM 2 (-) 0.1 NOTES: 1. ALL DIMENSIONS ARE IN MILLIMETERS. 2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL WITHOUT NOTICE. 3. THIS PART IS RoHS 2002/95/EC COMPLIANT. UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MILLIMETERS, TOLERANCES ARE 0.5 AND ANGLES ARE 3 . SIZE A3 AOM-6545P-R.idw Designed by Date Checked by Date Approved by J.A.F. 1/30/2006 E.P. 1/30/2006 B.R. Date Drawn Date 1/30/2006 9/16/2010 AOM-6545P-R Microphone Edition Sheet - 1/1
AOM-6545P-R 价格&库存
很抱歉,暂时无法提供与“AOM-6545P-R”相匹配的价格&库存,您可以联系我们找货
