F251R-05LLB
F251R-05LLB
    NIDEC(尼得科)
    FAN AXIAL 25X10MM 5VDC WIRE
F251R-05LLB 数据手册
F251R BRUSHLESS DC FANS ■ FEATURES RoHS compliant ● Low noise, 11 dB (A) type by the correct application of hydrodynamic design of impeller and frame ● Light weight (approx. 7 g) ■ STRUCTURE ● Frame and impeller ABS/PBT alloy ● Bearing 1 sleeve bearing ■ PART NUMBER DESIGNATION F251R - 12 L C Series name Bearing 1 sleeve bearing Power supply 05:DC5 V 12:DC12 V Air flow LL:0.04 m3/min L:0.05 m3/min ■ LIST OF PART NUMBERS Power supply DC5 V Part number F251R-05LLC F251R-05LC ※ Verify the above part numbers when placing orders. Power supply DC12 V Part number F251R-12LLC F251R-12LC F251R BRUSHLESS DC FANS ■ STANDARD SPECIFICATIONS F251R-05LC Item F251R-05LLC F251R-12LC F251R-12LLC Rated voltage DC5 V DC12 V Voltage range 4.2 ~ 5.7 V 10.2 ~ 13.8 V Rated current 0.08 A 0.06 A 0.05 A 0.04 A Rotating speed 8000 min-1 6500 min-1 8000 min-1 6500 min-1 0.05 m3/min 0.04 m3/min 0.05 m3/min 0.04 m3/min 30 Pa 20 Pa 30 Pa 20 Pa 15 dB (A) 11 dB (A) 15 dB (A) 11 dB (A) Air flow Static pressure Noise Use environment –10 ~ +60 °C (35 ~ 85 %RH) Storage environment –20 ~ +70 °C (35 ~ 85 %RH) Approx. 7 g Net weight ■ AIR FLOW PERFORMANCE CURVES ※ The specifications above are typical values measured on the conditions of no-loading running with rated voltage in the circumstances of 25 °C ± 2 °C, 35~ 85 %RH. Please contact us if you would liketo check the specifications in different circumstances. 50 45 40 Static pressure (Pa) 35 30 F251R-XXL 25 20 F251R-XXLL 15 10 5 0 0.02 0.04 0.06 3 Air flow (m /min) 10 ± 0.5 Lead wire : UL1061 AWG28 Black : GND Dimension of mounting hole for recommendation Red : VOLTAGE 4 – φ 2.8 20 ± 0.5 □25 ± 0.5 φ .6 23 20 ± 0.5 Air flow (Unit: mm) 20 ± 0.5 150 ± 20 ■ OUTLINE DIMENSIONS 4 – φ 2.8 4 – C2 20 ± 0.5
F251R-05LLB 价格&库存
很抱歉,暂时无法提供与“F251R-05LLB”相匹配的价格&库存,您可以联系我们找货
