T69-305-305-0.017-1A 数据手册
T69
Graphite Sheets
Features
Highly oriented pyrolytic graphite sheet with high thermal
conductivity
It is flexible and has features of ultra-thin and high EMI
shielding effect
Excellent thermal conductivity: 1600 W/ mK (4x as high as
copper, 7x as high as aluminium)
Light weight: Specific gravity: 2.3 g/cm³
Flexible and easy to be cut or trimmed
Low thermal resistance
Low moisture content: < 1%
Applications
Electronic components: IC – CPU – MOS
LED - M/B – P/S – Heat Sink
LCD – TV – Notebook PC – PC Telecom Device – Wireless
Hub… etc.
DDR II Module – DVD Applications – Hand-set applications…
etc. Thermal Resistance Vs Pressure Vs Deflect
Properties
Property
Test Methods
Thickness (µm)
Thermal conductivity (W/m.k)
Micrometer
XY axis
Zaxis
AC calorimeter
Laser flash
Thermal diffusivity (cm²/S)
AC calorimeter
Density (g/cm³)
Archimedes law
Electrical conductivity (S/cm)
JISK7194
Flexibility
MIT
Tel: +44 (0) 1455 553 510 Email: sales@tglobaltechnology.com Web: www.tglobaltechnology.com Skype: tglobal.technology
Property
Thickness (mm)
Available Size (mm)
Thermal
X-YDirection
conductivity
Z Direction
(W/m.k)
Thermal diffusivity (cm²/s)
Density (g/cm³)
Specific heat (at 50ºC) (J/gk)
Heat resistance ºC
X-YDirection
Extensional
strength(Mpa)
Z Direction
Expansion
coefficient (1/K)
X-YDirection
Z Direction
Bending test (R5/180ºC) (Times)
T69-17
17um
T69-25
25um
T69-40
40um
T69-50
50um
T69-70
70um
T69-100
100um
0.017±0.005
305x305
1750
0.025±0.010
305x305
1500
0.040±0.012
295x295
1350
0.050±0.015
295x295
1300
0.070±0.017
295x295
1000
0.100±0.019
295x295
700
11
18
10 - 11
(0.0010.0011m²/s)
9 - 10
(0.00090.0010m²/s)
9 - 10
(0.0009.0010m²/s)
8 - 10
(0.0008.0010m²/s)
8 - 10
(0.0008.0010m²/s)
8 - 10
(0.0008.0010m²/s)
2.1
(2100 kg/m³)
0.85
(850J/kgk)
400
40
1.95
(1095 kg/m³)
0.85
(850J/kgk)
400
30
1.8
(1800 kg/m³)
0.85
(850J/kgk)
400
25
1.7
(1700 kg/m³)
0.85
(850J/kgk)
400
(1200 kg/m³)
0.85
(850J/kgk)
400
(850 kg/m³)
0.85
(850J/kgk)
400
9.3 x 10¯⁷
0.1
9.3 x 10¯⁷
0.4
9.3 x 10¯⁷
0.4
9.3 x 10¯⁷
0.4
9.3 x 10¯⁷
0.4
9.3 x 10¯⁷
3.2 x 10¯⁵
20000 or more
3.2 x 10¯⁵
20000 or more
3.2 x 10¯⁵
20000 or more
3.2 x 10¯⁵
20000 or more
3.2 x 10¯⁵
3.2 x 10¯⁵
20000 or more 20000 or more
Electric conductivity (S/cm)
20000
20000
20000
20000
20000
20000
Operating Temperature
-50 to 200 ⁰C
-50 to 200 ⁰C
-50 to 200 ⁰C
-50 to 200 ⁰C
-50 to 200 ⁰C
-50 to 200 ⁰C
Part Number
T69-120-120-0.017-1A
Product
Length
Width
Thickness
Adhesive
T69
120
120
0.017
1A
T69 product
Length of 120 mm
Width of 120 mm
Thickness of 0.017 mm
1 side adhesive
Product
Length
Width
Thickness
Adhesive
T69
120
120
0.017
T69 product
Length of 120 mm
Width of 120 mm
No adhesive
T69-120-120-0.017
*All measurements in mm
Data
Thermal Conductivity (Z axis)
(W/ m K )
Thermal Conductivity (W/ m K)
Thermal Conductivity T69 (X-Y axis)
2000
1500
1000
500
0.04
0.06
0.08
0.1
0.12
30
25
10
5
0.04
0.06
0.08
0.1
0.12
Thickness (mm)
Thickness (mm)
Part Number
*Data for design engineer guidance only. Observed performance varies in application. Engineers are reminded to test the material in application.
Application Guide
Without thermal interface material, the heat flow go through joint face slowly, and the thermal conductive
performance is bad (Thermal conductivity of air is 0.026 W/m K). Using T-Global Thermal Interface Material to link two
joint faces, the heat flow go through equally, and the thermal conductive performance is good.
Materials Needed
Clean lint-free cloth rag
Industrial solvent
Rubber gloves
For optimal performance, T-Global Technology recommends interface flatness of 0.001 in/in (0.025 mm/25 mm) to
0.002in/in (0.050 mm/25mm) maximum.
Step 1: Ensure that the surface is free from oil, dust, or any contamination that may affect bonding. Using rubber
gloves, wipe surfaces with a cloth dampened with industrial solvents such as MEK, toluene, acetone or isopropyl
alcohol.
Step 2: Cut sheet to size and remove a liner or remove pre-cut sheet from roll.
Step 3: Apply to center of heat sink bonding area and smooth over entire surface using moderate hand pressure /
rubbing motion. A roller may be useful to help smooth the part to the surface by rolling from the center out to beyond
the edges of the part. This ensures optimal contact between T69 sheet and heat sink.
Step 4: Center heat sink onto component and apply using any one of the recommended temperature and pressure.
(Minimum: 10 psi at room temperature for 15 seconds. Preferred: 30 psi at room temperature for 5 seconds)
More pressure equals better wetting out of the adhesive to the contact surfaces. A twisting motion during assembly
of the substrates will typically improve wetting.
Note that typically 70% of the ultimate adhesive bond strength is achieved with initial application, and 80-90% is
reached within 15 minutes. Ultimate adhesive strength is achieved within 36 hours; however the next manufacturing
step can typically occur immediately following the initial application.
Digi-Key Part Number
1168-2112-ND
1168-2107-ND
1168-2109-ND
1168-2110-ND
1168-2106-ND
1168-2113-ND
1168-2108-ND
1168-2111-ND
1168-2105-ND
T69-225-225-0.025-ND
T69-225-225-0.040-ND
T69-225-225-0.025-1A-ND
T69-225-225-0.040-1A-ND
T69-225-225-0.050-ND
T69-225-225-0.017-ND
T69-225-225-0.070-ND
T69-225-225-0.10-ND
T69-225-225-0.017-1A-ND
Manufacturer Part Number
T69-305-305-0.070
T69-305-305-0.025
T69-305-305-0.040
T69-305-305-0.040-1A
T69-305-305-0.10
T69-305-305-0.025-1A
T69-305-305-0.050
T69-305-305-0.017
T69-225-225-0.025
T69-225-225-0.040
T69-225-225-0.050
T69-225-225-0.017
T69-225-225-0.070
T69-225-225-0.10
Description
GRAPHITE 305X305X0.070MM WO/ADH
GRAPHITE 305X305X0.025MM WO/ADH
GRAPHITE 305X305X0.040MM WO/ADH
GRAPHITE 305X305X0.040MM W/ADH
GRAPHITE 305X305X0.017MM W/ADH
GRAPHITE 305X305X0.10MM WO/ADH
GRAPHITE 305X305X0.025MM W/ADH
GRAPHITE 305X305X0.050MM WO/ADH
GRAPHITE 305X305X0.017MM WO/ADH
GRAPHITE 225X225X0.025MM WO/ADH
GRAPHITE 225X225X0.040MM WO/ADH
GRAPHITE 225X225X0.025MM W/ADH
GRAPHITE 225X225X0.040MM W/ADH
GRAPHITE 225X225X0.050MM WO/ADH
GRAPHITE 225X225X0.017MM WO/ADH
GRAPHITE 225X225X0.070MM WO/ADH
GRAPHITE 225X225X0.10MM WO/ADH
GRAPHITE 225X225X0.017MM W/ADH
Material
Graphite
Graphite
Graphite
Graphite
Graphite
Graphite
Graphite
Graphite
Graphite
Graphite
Graphite
Graphite
Graphite
Graphite
Graphite
Graphite
Graphite
Graphite
Adhesive
Adhesive - One Side
Adhesive - One Side
Adhesive - One Side
Adhesive - One Side
Adhesive - One Side
Adhesive - One Side
Backing, Carrier
Color
Grey
Grey
Grey
Grey
Grey
Grey
Grey
Grey
Grey
Grey
Grey
Grey
Grey
Grey
Grey
Grey
Grey
Grey
1600 W/m-K
1600 W/m-K
1600 W/m-K
1600 W/m-K
1600 W/m-K
1600 W/m-K
1600 W/m-K
1600 W/m-K
1600 W/m-K
1600 W/m-K
1600 W/m-K
1600 W/m-K
1600 W/m-K
1600 W/m-K
1600 W/m-K
1600 W/m-K
1600 W/m-K
1600 W/m-K
NOTICE: The information contained herein is to the best of our knowledge true and accurate. However, since the varied conditions of potential
use are beyond our control, all recommendations or suggestions are presented without guarantee or responsibility on our part and users should
make their own test to determine the suitability of our products in any specific situation. This product is sold without warranty either expressed
or implied, of fitness for a particular purpose or otherwise, except that this product shall be of standard quality, and except to the extent
otherwise stated T-Global Technology Europe and North America’s invoice, quotation, or order acknowledgment. We disclaim any and liability
incurred in connection with the use of information contained herein, or otherwise. All risks of such are assumed by the user. Furthermore,
nothing contained herein shall be construed as a recommendation to use any process or to manufacture or to use any product in conflict with
existing future patents covering any product or material or its use.
T69-305-305-0.017-1A 价格&库存
很抱歉,暂时无法提供与“T69-305-305-0.017-1A”相匹配的价格&库存,您可以联系我们找货
