Additional Resources:
Product Page
3D Model
date
08/05/2022
page 1 of 11
SERIES: CP60 | DESCRIPTION: PELTIER MODULE
FEATURES
• solid state device
• precise temperature control
• quiet operation
MODEL
input
voltage1
input
current2
internal
resistance3
max
(Vdc)
max
(A)
typ
(Ω±10%)
CP60133
3.8
6.0
CP60233
8.6
6.0
CP60333
15.4
CP60140
2.1
CP60240
CP60301540
CP60340
8.6
CP60440
15.4
Notes:
output
Qmax4
output
∆Tmax5
Th=27°C
(W)
Th=50°C
(W)
Th=27°C
(°C)
Th=50°C
(°C)
0.50
12.2
13.6
66
72
1.20
27.9
31.2
66
72
6.0
2.20
50.5
56.5
66
72
6.0
0.29
7.1
7.9
68
75
3.8
6.0
0.53
13.0
14.5
68
75
4.2
6.0
0.57
14.5
16.1
68
75
6.0
1.21
29.0
32.4
68
75
6.0
2.17
53.0
59.3
68
75
1. Maximum voltage at ΔT max and Th=27°C
2. Maximum current to achieve ΔT max
3. Measured by AC 4-terminal method at 25°C
4. Maximum heat absorbed at cold side occurs at Imax, Vmax, and ∆T=0°C
5. Maximum temperature difference occurs at Imax, Vmax, and Q=0W (ΔT max measured in a vacuum at 1.3 Pa)
cuidevices.com
Product Page
3D Model
CUI DEVICES | SERIES: CP60 | DESCRIPTION: PELTIER MODULE
date 08/05/2022 | page 2 of 11
SPECIFICATIONS
parameter
conditions/description
min
solder melting temperature
connection between thermoelectric pairs
CP60133, CP60233, CP60333, CP60301540
all other models
235
138
typ
units
°C
°C
assembly compression
hot side plate
RoHS
max
1
MPa
80
°C
yes
MECHANICAL DRAWING
units: mm
MATERIAL
HOT SIDE
0.05
THICKNESS
COLD SIDE
0.05
96% AL2O3
wire leads
20 AWG
sealer
silicon rubber 703 RTV (between cold and
hot side plates)
joint cover
marking
P/N & S/N printed on cold side surface
7 3.0
Red (+)
WIDTH
COLD SIDE
Black (-)
LENGTH
100.0 5.0
MODEL NO.
LENGTH
(mm)
WIDTH
(mm)
THICKNESS
(mm)
CP60133
15 ±0.3
15 ±0.3
3.22 ±0.1
CP60233
20 ±0.3
20 ±0.3
3.22 ±0.1
CP60333
30 ±0.3
30 ±0.3
3.22 ±0.1
CP60140
15 ±0.3
15 ±0.3
4.0 ±0.1
CP60240
20 ±0.3
20 ±0.3
4.0 ±0.1
CP60301540
30 ±0.3
15 ±0.3
4.0 ±0.1
CP60340
30 ±0.3
30 ±0.3
4.0 ±0.1
CP60440
40 ±0.3
40 ±0.3
4.0 ±0.1
cuidevices.com
PLATING
ceramic plate
tin
Product Page
3D Model
date 08/05/2022 | page 3 of 11
Input Voltage (V)
CP60133 PERFORMANCE (Th=27°C)
6.0 A
4.0
4.8 A
3.6 A
2.0
2.4 A
1.2 A
Heat Pumped, Q (W)
6.0 A
4.8 A
8.0
3.6 A
2.4 A
4.0
1.2 A
ΔT=Th-Tc (°C)
Input Voltage (V)
CP60133 PERFORMANCE (Th=50°C)
6.0 A
4.0
4.8 A
3.6 A
2.4 A
2.0
1.2 A
Heat Pumped, Q (W)
6.0 A
4.8 A
3.6 A
8.0
2.4 A
4.0
1.2 A
ΔT=Th-Tc (°C)
cuidevices.com
Product Page
3D Model
date 08/05/2022 | page 4 of 11
Input Voltage (V)
CP60233 PERFORMANCE (Th=27°C)
6.0 A
8.0
4.8 A
3.6 A
2.4 A
4.0
1.2 A
Heat Pumped, Q (W)
30.0
6.0 A
20.0
4.8 A
3.6 A
2.4 A
10.0
1.2 A
ΔT=Th-Tc (°C)
Input Voltage (V)
CP60233 PERFORMANCE (Th=50°C)
6.0 A
4.8 A
8.0
3.6 A
2.4 A
4.0
1.2 A
Heat Pumped, Q (W)
30.0
6.0 A
4.8 A
20.0
3.6 A
2.4 A
10.0
1.2 A
ΔT=Th-Tc (°C)
cuidevices.com
Product Page
3D Model
date 08/05/2022 | page 5 of 11
Input Voltage (V)
CP60333 PERFORMANCE (Th=27°C)
6.0 A
16.0
4.8 A
3.6 A
8.0
2.4 A
1.2 A
Heat Pumped, Q (W)
6.0 A
40.0
4.8 A
3.6 A
2.4 A
20.0
1.2 A
ΔT=Th-Tc (°C)
CP60333 PERFORMANCE (Th=50°C)
Input Voltage (V)
6.0 A
16.0
4.8 A
3.6 A
2.4 A
8.0
1.2 A
Heat Pumped, Q (W)
6.0 A
40.0
4.8 A
3.6 A
2.4 A
20.0
1.2 A
ΔT=Th-Tc (°C)
cuidevices.com
Product Page
3D Model
date 08/05/2022 | page 6 of 11
Input Voltage (V)
CP60140 PERFORMANCE (Th=27°C)
6.0 A
2.0
4.8 A
3.6 A
2.4 A
1.0
1.2 A
Heat Pumped, Q (W)
6.0 A
4.8 A
3.6 A
4.0
2.4 A
2.0
1.2 A
ΔT=Th-Tc (°C)
CP60140 PERFORMANCE (Th=50°C)
Input Voltage (V)
6.0 A
4.8 A
2.0
3.6 A
2.4 A
1.0
1.2 A
Heat Pumped, Q (W)
6.0 A
6.0
4.8 A
3.6 A
4.0
2.4 A
2.0
1.2 A
ΔT=Th-Tc (°C)
cuidevices.com
Product Page
3D Model
date 08/05/2022 | page 7 of 11
Input Voltage (V)
CP60240 PERFORMANCE (Th=27°C)
6.0 A
4.0
4.8 A
3.6 A
2.0
2.4 A
1.2 A
Heat Pumped, Q (W)
6.0 A
4.8 A
8.0
3.6 A
2.4 A
4.0
1.2 A
ΔT=Th-Tc (°C)
Input Voltage (V)
CP60240 PERFORMANCE (Th=50°C)
6.0 A
4.0
4.8 A
3.6 A
2.4 A
2.0
1.2 A
Heat Pumped, Q (W)
6.0 A
12.0
4.8 A
3.6 A
8.0
2.4 A
4.0
1.2 A
ΔT=Th-Tc (°C)
cuidevices.com
Product Page
3D Model
date 08/05/2022 | page 8 of 11
Input Voltage (V)
CP60301540 PERFORMANCE (Th=27°C)
8.0
6.0
6A
4.0
4.8 A
3.6 A
2.4 A
2.0
1.2 A
Heat Pumped, Q (W)
6A
12
3.6
8.0
4.8 A
A
2.4 A
1.2 A
4.0
60
50
40
30
ΔT=Th-Tc (°C)
Input Voltage (V)
CP60301540 PERFORMANCE (Th=50°C)
8.0
6.0
4.0
6A
4.8 A
3.6 A
2.4 A
2.0
1.2 A
Heat Pumped, Q (W)
4.8 A
16
6A
3.6
12
2.4 A
8.0
1.2 A
4.0
A
70
60
50
40
ΔT=Th-Tc (°C)
cuidevices.com
30
Product Page
3D Model
date 08/05/2022 | page 9 of 11
Input Voltage (V)
CP60340 PERFORMANCE (Th=27°C)
6.0 A
8.0
4.8 A
3.6 A
2.4 A
4.0
1.2 A
Heat Pumped, Q (W)
30
6.0 A
4.8 A
3.6 A
2.4 A
10
1.2 A
60
50
40
ΔT=Th-Tc (°C)
30
Input Voltage (V)
CP60340 PERFORMANCE (Th=50°C)
6.0 A
4.8 A
8.0
3.6 A
2.4 A
4.0
1.2 A
Heat Pumped, Q (W)
30.0
6.0 A
4.8 A
20.0
3.6 A
2.4 A
10.0
1.2 A
60
50
40
ΔT=Th-Tc (°C)
cuidevices.com
30
Product Page
3D Model
date 08/05/2022 | page 10 of 11
Input Voltage (V)
CP60440 PERFORMANCE (Th=27°C)
6.0 A
16.0
4.8 A
3.6 A
8.0
2.4 A
1.2 A
Heat Pumped, Q (W)
6.0 A
40.0
4.8 A
3.6 A
2.4 A
20.0
1.2 A
ΔT=Th-Tc (°C)
CP60440 PERFORMANCE (Th=50°C)
Input Voltage (V)
6.0 A
16.0
4.8 A
3.6 A
2.4 A
8.0
1.2 A
Heat Pumped, Q (W)
6.0 A
4.8 A
40.0
3.6 A
2.4 A
20.0
1.2 A
ΔT=Th-Tc (°C)
cuidevices.com
Product Page
3D Model
date 08/05/2022 | page 11 of 11
REVISION HISTORY
rev.
description
date
1.0
initial release
09/03/2009
1.01
applied new template
05/08/2012
1.02
added new models
09/09/2016
1.03
changed thickness of CP60133, CP60233, CP60333, CP60301540
models
09/20/2018
1.04
brand update
10/28/2019
logo, datasheet style update
08/05/2022
1.05
The revision history provided is for informational purposes only and is believed to be accurate.
CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate
and reliable. However, no responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may
result from its use.
CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A
critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life
support device or system, or to affect its safety or effectiveness.
cuidevices.com
Product Page
3D Model
很抱歉,暂时无法提供与“CP60340”相匹配的价格&库存,您可以联系我们找货
