XLT2422-01LS
XLT2422-01LS
    MARLOWINDUSTRIES,INC.
    TEMTHERMOCYCLER30X30X3.33MM
XLT2422-01LS 数据手册
Technical Data Sheet for XLT2422 Single-Stage Thermoelectric Module NOMINAL PERFORMANCE IN NITROGEN Hot Side Temperature (°C) Δ Tmax (°C): Qmax (watts): Imax (amps): Vmax (vdc): AC Resistance (ohms): PRODUCT FEATURES • • • • • • • • • • • 27 66 36 3.7 14.7 3.2 50 74 39 3.7 16.4 --- ORDERING OPTIONS RoHS EU Compliant Rated operating temperature of 125°C. Ceramic Material: Aluminum Oxide Designed for temperature cycling applications. Capable of rapid heating and cooling rates. Porch configuration for high strength leadwire connection. Superior nickel diffusion barriers on elements. High strength for rugged environment. RTV sealing option available. Lapped option available for multiple module applications. Set of modules ACR matched available. Model Number XLT2422-00L XLT2422-00LS XLT2422-01L XLT2422-01LS XLT2422-02LS XLT2422-14LS XLT2422-16LS Description Lapped Lapped, Sealed Leadwires, Lapped Leadwires, Lapped, Sealed Leadwires, Lapped, Sealed Leadwires, Lapped, Sealed, Set of 4 ACR Matched Leadwires, Lapped, Sealed, Set of 6 ACR Matched OPERATION CAUTIONS INSTALLATION For maximum reliability, storage and operation below 125°C in a non-condensing environment is recommended. To minimize thermal stress, use linear/proportional temperature control or a similar method rather than an ON/OFF method. Recommended mounting method: Clamp with uniform pressure to a flat surface with thermal interface material. For additional information, please refer to our TEC Installation Guide. II-VI Marlow – Dallas, TX USA 214-340-4900 877-627-5691 marlow.sales@ii-vi.com Marlow Industries Europe GmbH - Germany +49 (0) 6150 5439 - 403 info@marlow-europe.eu II-VI Japan Inc. 81 43 297 2693 (tel) center@ii-vi.co.jp www.ii-vi.co.jp MI Form 005-0692 Rev. 4 www.marlow.com II-VI Singapore Pte., Ltd. (65) 6481 8215 (tel) info@ii-vi.com.sg Marlow Industries China, II-VI Technologies Beijing 86-10-643 98226 info@iivibj.com DOC # 102-0322 REV L - PAGE 1 OF 2 Hot Side Temperature 50°C Hot Side Temperature 27°C HEAT LOAD (WATTS) 0.00 2.50 5.00 7.50 10.0 12.5 15.0 17.5 20.0 22.5 25.0 27.5 30.0 35.0 40.0 20.0 0.0 60.0 T (C) 60.0 T (C) HEAT LOAD (WATTS) 0.00 2.50 5.00 7.50 10.0 12.5 15.0 17.5 20.0 22.5 25.0 27.5 30.0 32.5 80.0 80.0 40.0 20.0 0.0 16.0 VOLTAGE (VDC) 16.0 VOLTAGE (VDC) TYPICAL PERFORMANCE CURVES ENVIRONMENT: ONE ATMOSPHERE DRY NITROGEN 12.0 8.0 Q=0 T=0 4.0 0.0 0.0 1.0 2.0 3.0 4.0 12.0 Q=0 T=0 8.0 4.0 0.0 0.0 5.0 1.0 CURRENT (AMPS) 2.0 3.0 4.0 5.0 CURRENT (AMPS) MECHANICAL CHARACTERISTICS For performance information in a vacuum or with hot side temperatures other than 27°C or 50°C, contact one of our Applications Engineers at 877-627-5691. (+), WHITE .80±.25 [20.32±6.35] 1.181 [30.00] LEADWIRES: 20 AWG 19/32 STRANDING TEFLON INSULATED (-), BLACK SEE TABLE 1 1.181 [30.00] TOTAL WIRE LENGTH POS & NEG 1.339 [34.01] -01L: -01LS: -02LS: -14LS, -16LS: 4.0 ± .50" 4.0 ± .50" 6.0 ± .50" 4.0 ± .50" TABLE 1 COLD SIDE, Tc .001 [0.025] .001 [0.025] A .001 [0.025] .131±.001 [3.33±0.025] HOT SIDE, Th A Dimensions in [ ] are millimeters For customer support or general questions please contact a local office or visit our website at www.marlow.com. MI Form 005-0692 Rev. 4 www.marlow.com DOC # 102-0322 REV L - PAGE 2 OF 2
XLT2422-01LS 价格&库存
很抱歉,暂时无法提供与“XLT2422-01LS”相匹配的价格&库存,您可以联系我们找货
