XLT2419-08AC
XLT2419-08AC
    MARLOWINDUSTRIES,INC.
    TEMTHERMOCYCLER30X29.59X2.34MM
XLT2419-08AC 数据手册
Technical Data Sheet for XLT2419 Single-Stage Thermoelectric Module NOMINAL PERFORMANCE IN NITROGEN Hot Side Temperature (°C) Δ Tmax (°C): Qmax (watts): Imax (amps): Vmax (vdc): AC Resistance (ohms): PRODUCT FEATURES             27 56.5 72 13.9 8.0 0.47 50 64.0 79 13.8 8.8 --- ORDERING OPTIONS RoHS EU Compliant Rated operating temperature of 125°C. Ceramic Material: Aluminum Oxide Designed for temperature cycling applications. Capable of rapid heating and cooling rates. Porch configuration for high strength leadwire connection. Superior nickel diffusion barriers on elements. High strength for rugged environment. RTV sealing option available. Lapped for multiple module applications. Diced option for further mechanical stress relief. Set of modules ACR matched available. Model Number Description XLT2419-03AC XLT2419-04AC XLT2419-05AC XLT2419-07AC XLT2419-08AC Leadwires No Leadwires Leadwires, Diced Leadwires, Sealed Leadwires 8 inches long Leadwires, Diced, Conformal Parylene Coating Leadwires, Braided, ACR and Height Matched Set of 6 Leadwires, Sealed, Leadwire Sealed, ACR and Height Matched Set of 6 XLT2419-09AC XLT2419-16AC XLT2419-26AC OPERATION CAUTIONS INSTALLATION For maximum reliability, storage and operation below 125°C in a non-condensing environment is recommended. To minimize thermal stress, use linear/proportional temperature control or a similar method rather than an ON/OFF method. Recommended mounting method: Clamp with uniform pressure to a flat surface with thermal interface material. For additional information, please refer to our TEC Installation Guide. II-VI Marlow – Dallas, TX USA 214-340-4900 877-627-5691 marlow.sales@ii-vi.com Marlow Industries Europe GmbH - Germany +49 (0) 6150 5439 - 403 info@marlow-europe.eu II-VI Japan Inc. 81 43 297 2693 (tel) center@ii-vi.co.jp www.ii-vi.co.jp MI Form 005-0692 Rev. 4 II-VI Singapore Pte., Ltd. (65) 6481 8215 (tel) info@ii-vi.com.sg Marlow Industries China, II-VI Technologies Beijing 86-10-643 98226 info@iivibj.com DOC # 102-0309 REV M - PAGE 1 OF 2 www.marlow.com T AHot = 27°C - Nitrogen (1 ATM) Side Temperature 27°C T A Hot = 50°C Nitrogen (150°C ATM) Side-Temperature 60 T (°C) 40 30 20 10 0 11 0 4 8 12 16 50 40 30 20 10 0 11 0 20 10 10 9 9 8 6 Voltage (VDC) Q=0 7 T = 0 5 Heat Load (W) 0 5 10 15 20 25 30 35 40 45 50 55 60 60 T (°C) Heat Load (W) 0 5 10 15 20 25 30 35 40 45 50 55 50 Voltage (VDC) TYPICAL PERFORMANCE CURVES ENVIRONMENT: ONE ATMOSPHERE DRY NITROGEN 4 8 12 16 20 Q=0 8 7 T = 0 6 5 4 3 3 2 2 1 1 0 4 0 0 4 8 12 16 20 0 4 8 Current (amps) 12 16 20 Current (amps) MECHANICAL CHARACTERISTICS For performance information in a vacuum or with hot side temperatures other than 27°C or 50°C, contact one of our Applications Engineers at 877-627-5691. TYPICAL PERFORMANCE Environment : Nitrogen 1.339 [34.01] (1 ATM) TA1.165 (C) [29.59] : 27 VMAX (VDC) : 8.0  TMAX (C) : 56.5 IMAX (amps) : 13.9 QMAX (W) : 72 ACR () : 0.47 1.181 [30.00] -16AC: 1.181 +0/- .020 TYPICAL PERFORMANCE [30.00 +0/- .051] Environment : Nitrogen (1 ATM) Standard: 4.0±.5 [102±13] TA (C) : 50 .30±.10 [7.6±2.5] VMAX (VDC) :  TMAX (C) : IMAX (amps) : (+), WHITE QMAX (W) : ACR () : 8.8 64.0 13.8 79 - LEADWIRES: STANDARD: 20 AWG, 19/32 STRANDING TEFLON INSULATED -16AC: BRAIDED 1.159 [29.44] (-), BLACK .30±.10 [7.6±2.5] COLD SIDE, Tc .092 ± .001 [2.34 ± 0.03] .002 [0.05] A .001 [0.03] .001 [0.03] HOT SIDE, Th Dimensions in [ ] are millimeters A For customer support or general questions please contact a local office or visit our website at www.marlow.com. Marlow reserves the right to make product changes without notice. MI Form 005-0692 Rev. 4 DOC # 102-0309 REV M - PAGE 2 OF 2 www.marlow.com
XLT2419-08AC 价格&库存
很抱歉,暂时无法提供与“XLT2419-08AC”相匹配的价格&库存,您可以联系我们找货
