CP40347
CP40347
    CUIDEVICES
    PELTIER,30X30X4.7MM,4A,
CP40347 数据手册
Additional Resources: Product Page | 3D Model date 08/05/2022 page 1 of 15 SERIES: CP40 | DESCRIPTION: PELTIER MODULE FEATURES • arcTEC™ structure on select models • solid state device • precise temperature control • quiet operation MODEL input voltage1 input current2 internal resistance3 max (Vdc) max (A) typ (Ω±10%) CP40136 3.8 4.0 0.80 CP40236 8.6 4.0 2.0 CP40336 15.4 4.0 3.5 33.4 37.3 66 72 CP40147 2.1 4.0 0.42 4.2 4.6 68 75 CP40247 3.8 4.0 0.77 7.5 8.3 68 75 CP4025336 15.4 4.0 2.88 35.2 39.0 68 75 CP40301547 4.2 4.0 0.87 8.4 9.2 68 75 CP403476 8.6 4.0 1.76 19.6 21.6 70 77 CP40439 19.5 4.0 4.18 45.0 49.5 68 75 CP4040466 24.1 4.0 4.94 55.7 61.2 68 75 CP40447 15.4 4.0 3.15 32.0 35.2 70 77 CP40554856 29.8 4.0 5.97 63.0 69.0 70 77 6 6 Notes: 1. Maximum voltage at ΔT max and Th=27°C 2. Maximum current to achieve ΔT max 3. Measured by AC 4-terminal method at 25°C 4. Maximum heat absorbed at cold side occurs at Imax, Vmax, and ∆T=0°C 5. Maximum temperature difference occurs at Imax, Vmax, and Q=0W (ΔT max measured in a vacuum at 1.3 Pa) 6. Designed with arcTEC™ structure. cuidevices.com output Qmax4 Th=27°C (W) output ∆Tmax5 Th=50°C (W) Th=27°C (°C) Th=50°C (°C) 8.1 9.0 66 72 18.7 21.8 66 72 Additional Resources: Product Page | 3D Model CUI DEVICES | SERIES: CP40 | DESCRIPTION: PELTIER MODULE date 08/05/2022 | page 2 of 15 SPECIFICATIONS parameter conditions/description min solder melting temperature connection between thermoelectric pairs CP40347, CP40447, CP40147, CP40247, CP402533 CP40301547, CP404046, CP40439, CP4055485 all other models 235 138 typ max °C °C assembly compression 1 RoHS units MPa yes MECHANICAL DRAWING units: mm MATERIAL HOT SIDE 0.05 THICKNESS COLD SIDE 0.05 ceramic plate 96% AL2O3 wire leads (3.3 & 3.6 mm models) 22 AWG tin wire leads (all other els) 20 AWG tin mod- sealer silicon rubber 703 RTV (between cold and hot side plates) joint cover silicon rubber 703 RTV marking P/N & S/N printed on cold side surface 7 3.0 Red (+) WIDTH COLD SIDE Black (-) LENGTH 100.0 5.0 LENGTH (mm) MODEL NO. WIDTH (mm) THICKNESS (mm) CP40136 15 ±0.3 15 ±0.3 3.6 ±0.1 CP40236 20 ±0.3 20 ±0.3 3.6 ±0.1 CP40336 30 ±0.3 30 ±0.3 3.6 ±0.1 CP40147 15 ±0.3 15 ±0.3 4.6 ±0.1 CP40247 20 ±0.3 20 ±0.3 4.6 ±0.1 CP4025331 25 ±0.3 25 ±0.3 3.3 ±0.1 CP40301547 30 ±0.3 15 ±0.3 4.6 ±0.1 CP403471 30 ±0.3 30 ±0.3 4.6 ±0.1 CP40439 40 ±0.3 40 ±0.3 3.9 ±0.1 CP404046 40 ±0.3 40 ±0.3 4.6 ±0.1 40 ±0.3 40 ±0.3 4.6 ±0.1 55 ±0.3 55 ±0.3 4.85 ±0.1 1 CP404471 CP4055485 1 Notes: 1. Wire lead strip length on models CP40347, CP40447, CP40439, CP402533, & CP4055485 is 10 ±3.0 mm. cuidevices.com PLATING Additional Resources: Product Page | 3D Model CUI DEVICES | SERIES: CP40 | DESCRIPTION: PELTIER MODULE date 08/05/2022 | page 3 of 15 Input Voltage (V) CP40136 PERFORMANCE (Th=27°C) 3.9 A 4.0 3.12 A 2.34 A 2.0 1.56 A 0.78 A 0 Heat Pumped, Q (W) 8.0 A 2A 3.1 4A 2.3 3.9 6.0 6A 1.5 4.0 0.78 2.0 A 0         ΔT=Th-Tc (°C) Input Voltage (V) CP40136 PERFORMANCE (Th=50°C) 3.9 A 4.0 3.12 A 2.34 A 1.56 A 2.0 0.78 A 0 3.9 Heat Pumped, Q (W) 8.0 A 2A 3.1 4A 2.3 6.0 6A 1.5 4.0 0.78 2.0 A 0     ΔT=Th-Tc (°C) cuidevices.com     Additional Resources: Product Page | 3D Model CUI DEVICES | SERIES: CP40 | DESCRIPTION: PELTIER MODULE date 08/05/2022 | page 4 of 15 Input Voltage (V) CP40236 PERFORMANCE (Th=27°C) 3.9 A 8.0 3.12 A 2.34 A 1.56 A 4.0 0.78 A Heat Pumped, Q (W) 0 20.0 3.9 A 3.12 2.34 10.0 A A 1.56 A 0.78 A 0         ΔT=Th-Tc (°C) CP40236 PERFORMANCE (Th=50°C) Input Voltage (V) 3.9 A 3.12 A 8.0 2.34 A 1.56 A 4.0 0.78 A Heat Pumped, Q (W) 0 3.9 20.0 3.12 A A 2.34 A 1.56 A 10.0 0.78 A 0     ΔT=Th-Tc (°C) cuidevices.com     Additional Resources: Product Page | 3D Model CUI DEVICES | SERIES: CP40 | DESCRIPTION: PELTIER MODULE date 08/05/2022 | page 5 of 15 Input Voltage (V) CP40336 PERFORMANCE (Th=27°C) 3.9 A 16.0 3.12 A 2.34 A 1.56 A 8.0 0.78 A 0 A Heat Pumped, Q (W) 3.9 30.0 2A 3.1 4A 20.0 2.3 6A 1.5 0.78 10.0 A 0         ΔT=Th-Tc (°C) Input Voltage (V) CP40336 PERFORMANCE (Th=50°C) 3.9 A 16.0 3.12 A 2.34 A 1.56 A 8.0 0.78 A 0 A 3.9 2A Heat Pumped, Q (W) 3.1 30.0 4A 2.3 6A 1.5 20.0 0.78 10.0 A 0     ΔT=Th-Tc (°C) cuidevices.com     Additional Resources: Product Page | 3D Model CUI DEVICES | SERIES: CP40 | DESCRIPTION: PELTIER MODULE date 08/05/2022 | page 6 of 15 Input Voltage (V) CP40147 PERFORMANCE (Th=27°C) 4.0 3.0 4A 2.0 3.2 A 2.4 A 1.6 A 1.0 0.8 A Heat Pumped, Q (W) 0 4A 4.0 3.2 A 3.0 2.4 A 1.6 A 2.0 0.8 A 1.0 0 70 60 50 40 30 20 10 0 ΔT=Th-Tc (°C) Input Voltage (V) CP40147 PERFORMANCE (Th=50°C) 4.0 3.0 2.0 4A 3.2 A 2.4 A 1.6 A 1.0 0.8 A Heat Pumped, Q (W) 0 4A 4.0 2.4 3.0 3.2 A A 1.6 A 2.0 0.8 A 1.0 0 70 60 50 40 ΔT=Th-Tc (°C) cuidevices.com 30 20 10 0 Additional Resources: Product Page | 3D Model CUI DEVICES | SERIES: CP40 | DESCRIPTION: PELTIER MODULE date 08/05/2022 | page 7 of 15 Input Voltage (V) CP40247 PERFORMANCE (Th=27°C) 4A 4.0 3.2 A 3.0 2.4 A 2.0 1.6 A 0.8 A 1.0 0 Heat Pumped, Q (W) 8.0 4A 6.0 3.2 A 2.4 A 1.6 A 4.0 0.8 A 2.0 0 70 60 50 40 30 20 10 0 ΔT=Th-Tc (°C) Input Voltage (V) CP40247 PERFORMANCE (Th=50°C) 4A 4.0 3.2 A 2.4 A 3.0 1.6 A 2.0 0.8 A 1.0 0 Heat Pumped, Q (W) 8.0 4A 3.2 2.4 6.0 A A 1.6 A 4.0 0.8 A 2.0 0 70 60 50 40 ΔT=Th-Tc (°C) cuidevices.com 30 20 10 0 Additional Resources: Product Page | 3D Model CUI DEVICES | SERIES: CP40 | DESCRIPTION: PELTIER MODULE date 08/05/2022 | page 8 of 15 Input Voltage (V) CP402533 PERFORMANCE (Th=27°C) 16 4A 3.2 A 12 2.4 A 8.0 1.6 A 4.0 0.8 A Heat Pumped, Q (W) 0 40 4A 2A 3. 30 2.4 A 20 1.6 A 10 0.8 A 0 70 60 50 40 30 20 10 0 ΔT=Th-Tc (°C) CP402533 PERFORMANCE (Th=50°C) Input Voltage (V) 4A 16 3.2 A 2.4 A 12 1.6 A 8.0 0.8 A 4.0 Heat Pumped, Q (W) 0 40 4A 30 2.4 A 3.2 A 1.6 A 20 0.8 A 10 0 70 60 50 40 ΔT=Th-Tc (°C) cuidevices.com 30 20 10 0 Additional Resources: Product Page | 3D Model CUI DEVICES | SERIES: CP40 | DESCRIPTION: PELTIER MODULE date 08/05/2022 | page 9 of 15 Input Voltage (V) CP40301547 PERFORMANCE (Th=27°C) 8.0 6.0 4.0 4A 3.2 A 2.4 A 1.6 A 2.0 0.8 A Heat Pumped, Q (W) 0 4A 8.0 A 3.2 A 2.4 6.0 1.6 A 4.0 0.8 A 2.0 0 70 60 50 40 30 20 10 0 ΔT=Th-Tc (°C) Input Voltage (V) CP40301547 PERFORMANCE (Th=50°C) 8.0 6.0 4A 3.2 A 4.0 2.4 A 1.6 A 2.0 0.8 A Heat Pumped, Q (W) 0 4A 8.0 2.4 6.0 3.2 A A 1.6 A 4.0 0.8 A 2.0 0 70 60 50 40 ΔT=Th-Tc (°C) cuidevices.com 30 20 10 0 Additional Resources: Product Page | 3D Model CUI DEVICES | SERIES: CP40 | DESCRIPTION: PELTIER MODULE date 08/05/2022 | page 10 of 15 Input Voltage (V) CP40347 PERFORMANCE (Th=27°C) 20 15 10 3.6 A 4A 2.4 A 5.0 1.6 A 0.8 A Heat Pumped, Q (W) 0 20 4A 15 2.4 10 3.2 A A 1.6 A 0.8 A 5.0 0 70 60 50 40 30 20 10 0 ΔT=Th-Tc (°C) Input Voltage (V) CP40347 PERFORMANCE (Th=50°C) 20 15 10 4A 3.2 A 2.4 A 1.6 A 5.0 0.8 A Heat Pumped, Q (W) 0 4A 20 3.2 A 15 2.4 A 1.6 A 10 0.8 A 5.0 0 70 60 50 40 ΔT=Th-Tc (°C) cuidevices.com 30 20 10 0 Additional Resources: Product Page | 3D Model CUI DEVICES | SERIES: CP40 | DESCRIPTION: PELTIER MODULE date 08/05/2022 | page 11 of 15 Input Voltage (V) CP40439 PERFORMANCE (Th=27°C) 24 4A 18 3.2 A 2.4 A 12 1.6 A 6 0.8 A Heat Pumped, Q (W) 0 4A 40 3.2 A 2.4 A 30 1.56 20 A 0.8 A 10 0 70 60 50 40 ΔT=Th-Tc (°C) 30 20 10 0 Input Voltage (V) CP40439 PERFORMANCE (Th=50°C) 24 18 4A 3.2 A 2.4 A 12 1.6 A 0.8 A 6 Heat Pumped, Q (W) 0 4A 40 A 2.4 A 30 1.56 20 A 0.8 A 10 0 3.2 70 60 50 40 ΔT=Th-Tc (°C) cuidevices.com 30 20 10 0 Additional Resources: Product Page | 3D Model CUI DEVICES | SERIES: CP40 | DESCRIPTION: PELTIER MODULE date 08/05/2022 | page 12 of 15 Input Voltage (V) CP404046 PERFORMANCE (Th=27°C) 4A 24 3.2 A 18 2.4 A 1.6 A 12 0.8 A 6 Heat Pumped, Q (W) 0 80 3.2 A 60 4A 40 2.4 A 1.6 A 20 0.8 A 0 70 60 50 40 ΔT=Th-Tc (°C) 30 10 20 0 CP404046 PERFORMANCE (Th=50°C) Input Voltage (V) 4A 24 3.2 A 2.4 A 18 1.6 A 12 0.8 A 6 Heat Pumped, Q (W) 0 80 3.2 A 60 4A 40 2.4 A 1.6 A 20 0.8 A 0 70 60 50 40 ΔT=Th-Tc (°C) cuidevices.com 30 20 10 0 Additional Resources: Product Page | 3D Model CUI DEVICES | SERIES: CP40 | DESCRIPTION: PELTIER MODULE date 08/05/2022 | page 13 of 15 Input Voltage (V) CP40447 PERFORMANCE (Th=27°C) 4.0 A 16 3.2 A 12 2.4 A 1.6 A 8.0 0.8 A 4.0 Heat Pumped, Q (W) 0 4.0 28 A 20 3.2 A 2.4 A 1.6 12 A 0.8 A 4.0 0 70 60 50 40 30 20 10 0 ΔT=Th-Tc (°C) Heat Pumped, Q (W) Input Voltage (V) CP40447 PERFORMANCE (Th=50°C) 4.0 A 16 3.2 A 2.4 A 12 1.6 A 8.0 0.8 A 4.0 0 4.0 A .2 A 3 28 2.4 A 1.6 20 12 A 0.8 A 4.0 0 70 60 50 40 ΔT=Th-Tc (°C) cuidevices.com 30 20 10 0 Additional Resources: Product Page | 3D Model CUI DEVICES | SERIES: CP40 | DESCRIPTION: PELTIER MODULE date 08/05/2022 | page 14 of 15 Input Voltage (V) CP4055485 PERFORMANCE (Th=27°C) 32 4A 3.2 A 24 2.4 A 16 1.6 A 0.8 A Heat Pumped, Q (W) 8 0 4A A 2 . 3 2.4 A 60 40 1.6 A 20 0.8 A 0 70 60 50 40 ΔT=Th-Tc (°C) 30 10 20 0 Input Voltage (V) CP4055485 PERFORMANCE (Th=50°C) 32 4A 3.2 A 24 2.4 A 1.6 A 16 0.8 A 8 Heat Pumped, Q (W) 0 4A 3.2 A 4 . 2 A 60 40 1.6 A 0.8 A 20 0 70 60 50 40 ΔT=Th-Tc (°C) cuidevices.com 30 20 10 0 Additional Resources: Product Page | 3D Model CUI DEVICES | SERIES: CP40 | DESCRIPTION: PELTIER MODULE date 08/05/2022 | page 15 of 15 REVISION HISTORY rev. description date 1.0 initial release 09/03/2009 1.01 applied new template 05/08/2012 1.02 added new models 09/08/2016 1.03 changed models CP40347 & CP40447 to arcTEC™ structure 12/01/2017 1.04 changed thickness of CP40147, CP40247, CP40301547 models 09/19/2018 1.05 added models CP40439, CP404046, CP4055485, brand update 10/18/2019 1.06 added model CP402533 11/17/2020 1.07 logo, datasheet style update 08/05/2022 The revision history provided is for informational purposes only and is believed to be accurate. CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website. CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate and reliable. However, no responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may result from its use. CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness. cuidevices.com
CP40347 价格&库存
很抱歉,暂时无法提供与“CP40347”相匹配的价格&库存,您可以联系我们找货
CP40347
    • 1+85.50758
