Technical Data Sheet for NL1015T
Single-Stage Thermoelectric Module
NOMINAL PERFORMANCE IN NITROGEN
Hot Side Temperature (°C)
Δ Tmax (°C):
Qmax (watts):
Imax (amps):
Vmax (vdc):
AC Resistance (ohms):
Device ZT
PRODUCT FEATURES
27
61
2.6
1.0
4.6
4.07
0.77
50
69
3.0
1.0
5.3
ORDERING OPTIONS
RoHS EU Compliant
Rated operating temperature of 85°C
Maximum process temperature is 120°C
Ceramic Material: Aluminum Oxide
-01AC, -02AC: External Metallization is Au flash, suitable
for soldering.
Model Number
NL1015T-01AC
NL1015T-02AC
NL1015T-03AC
Description
Both Surfaces are Metallized
Hot Side Exterior is Metallized
No Metallization
OPERATION CAUTIONS
INSTALLATION
For maximum reliability, storage and operation below
85°C in a non-condensing environment is recommended.
To minimize thermal stress when operating in cooling
mode, use linear/proportional temperature control or a
similar method rather than an ON/OFF method.
Recommended mounting methods: Bonding with thermal
epoxy or soldering with metallized ceramics. For additional
information, please refer to our TEC Installation Guide.
II-VI Marlow – Dallas, TX USA
214-340-4900
877-627-5691
marlow.sales@ii-vi.com
Marlow Industries Europe
GmbH - Germany
+49 (0) 6150 5439 - 403
info@marlow-europe.eu
II-VI Japan Inc.
81 43 297 2693 (tel)
center@ii-vi.co.jp
www.ii-vi.co.jp
MI Form 005-0808 Rev. A
II-VI Singapore Pte., Ltd.
(65) 6481 8215 (tel)
info@ii-vi.com.sg
Marlow Industries China, II-VI
Technologies Beijing
86-10-643 98226
info@iivibj.com
DOC # 102-0293 REV J - PAGE 1 OF 3
www.marlow.com
ENVIRONMENT: ONE ATMOSPHERE DRY NITROGEN
Hot Side Temperature 27°C
0.00
0.25
0.50
0.75
1.00
1.25
1.50
1.75
2.00
2.25
2.50
40.0
20.0
0.0
80.0
40.0
20.0
VOLTAGE (VDC)
VOLTAGE (VDC)
3.0
2.0
1.0
Q=0
T=0
0.0
0.0
0.2
0.4
0.6
0.8
CURRENT (AMPS)
5.0
4.0
3.0
2.0
1.0
Q=0
T=0
0.0
0.0
1.0
0.2
0.4
0.6
0.8
CURRENT (AMPS)
1.0
POWER GENERATION PERFORMANCE CURVES
35
40
45
50
55
65
75
85
Tc=27°C
0.6
0.5
0.4
0.3
0.2
0.1
Power
Voltage
0.3
0.5
0.7
0.9 1.1
Heat (W)
1.3
1.5
1.7
0.02
0.018
0.016
0.014
0.012
0.01
0.008
0.006
0.004
0.002
60
65
70
75
80
85
0.4
0.35
Tc=50°C
0.3
0.25
0.2
0.15
0.1
Power
Voltage
Opt Voltage (V)
30
Opt Voltage (V)
0.05
0.045
0.04
0.035
0.03
0.025
0.02
0.015
0.01
0.005
Opt Power (W)
Opt Power (W)
TYPICAL PERFORMANCE CURVES
0.0
4.0
HEAT
LOAD
(WATTS)
0.00
0.25
0.50
0.75
1.00
1.25
1.50
1.75
2.00
2.25
2.50
2.75
60.0
T (C)
60.0
T (C)
Hot Side Temperature 50°C
HEAT
LOAD
(WATTS)
80.0
0.05
0.4
0.6
0.8
Heat (W)
1.0
Efficiency
2
3
4
5
6
7
Load Resistance Ratio
8
1
0.9
0.8
0.7
0.6
0.5
0.4
0.3
0.2
Voltage 0.1
10
Voltage / VOC
η / Opt η
Normalized Off-Peak Performance
1
0.9
0.8
0.7
0.6
0.5
0.4
0.3
0.2
0.1
Cold Side Temperature (°C)
Optimum Efficiency, η (%)
Optimum Power (W)
Optimum Voltage (V)
Load Resistance for Opt η (Ω)
Open Circuit Voltage, VOC (V)
Short Circuit Current (A)
Thermal Resistance (°C/W)
85
55
35
27
27
27
2.52 1.28 0.37
0.048 0.012 0.001
0.561 0.268 0.076
6.59 6.15 5.85
0.98 0.47 0.13
0.20 0.10 0.03
30.64 30.68 30.63
For performance information in a vacuum or with hot side temperatures other than 27°C or 50°C, contact one of our Applications Engineers at 877-627-5691.
DOC # 102-0293 REV J - PAGE 2 OF 3
www.marlow.com
MECHANICAL CHARACTERISTICS
Dimensions are in inches, and millimeters are in [ ].
*NOTE: Cold side, hot side and positive and negative leads are valid only for thermoelectric cooling. For power
generation, refer to figure below.
For customer support or general questions please contact a local office or visit our website at www.marlow.com.
Marlow reserves the right to make product changes without notice.
Power Generation performance information is given in a nitrogen environment and cold side temperatures of 27°C and 50°C.
Module temperature does not include thermal resistance of heat sinks. For performance information in vacuum, other cold side
temperatures, or specific heat sinks, consult one of our applications engineers.
TYPICAL POWER GENERATION CONFIGURATION
EXAMPLE:
Hot Side, Th
Cold Side, Tc
DOC # 102-0293 REV J - PAGE 3 OF 3
www.marlow.com
很抱歉,暂时无法提供与“NL1015T-01AC”相匹配的价格&库存,您可以联系我们找货
