Technical Data Sheet for LCC12-8
Single-Stage Thermoelectric Module
NOMINAL PERFORMANCE IN NITROGEN
Hot Side Temperature (°C)
Δ Tmax (°C):
Qmax (watts):
Imax (amps):
Vmax (vdc):
AC Resistance (ohms):
PRODUCT FEATURES
27
66
71
7.4
14.7
1.6
50
74
78
7.4
16.4
ORDERING OPTIONS
RoHS EU Compliant
Rated operating temperature of 130°C.
Ceramic Material: Aluminum Oxide
Designed for temperature cycling applications.
Porchless configuration for reduced footprint.
Superior nickel diffusion barriers on elements.
High strength for rugged environment.
RTV sealing option available.
Lapped option available for multiple module applications.
ACR Matched Set using Alphanumeric code available (see
page 3).
Model Number
LCC12-8-01
LCC12-8-01L
LCC12-8-01S
LCC12-8-01LS
LCC12-8-16LS
Description
Leadwires
Leadwires, Lapped
Leadwires, Sealed
Leadwires, Lapped, Sealed
Leadwires, Lapped, Sealed, ACR
Matched set of 6
OPERATION CAUTIONS
INSTALLATION
For maximum reliability, storage and operation below
130°C in a non-condensing environment is recommended.
To minimize thermal stress, use linear/proportional
temperature control or a similar method rather than an
ON/OFF method.
Recommended mounting methods: Clamp with uniform
pressure to a flat surface with thermal interface material. For
additional information, please refer to our TEC Installation
Guide.
II-VI Marlow – Dallas, TX USA
214-340-4900
877-627-5691
marlow.sales@ii-vi.com
Marlow Industries Europe
GmbH - Germany
+49 (0) 6150 5439 - 403
info@marlow-europe.eu
II-VI Japan Inc.
81 43 297 2693 (tel)
center@ii-vi.co.jp
www.ii-vi.co.jp
MI Form 005-0688 Rev. 4
www.marlow.com
II-VI Singapore Pte., Ltd.
(65) 6481 8215 (tel)
info@ii-vi.com.sg
Marlow Industries China, II-VI
Technologies Beijing
86-10-643 98226
info@iivibj.com
DOC # 102-0412 REV G - PAGE 1 OF 3
Hot Side Temperature 27°C
Hot Side Temperature 50°C
T (C)
40.0
20.0
0.0
60.0
T (C)
HEAT
LOAD
(WATTS)
0.00
5.00
10.0
15.0
20.0
25.0
30.0
35.0
40.0
45.0
50.0
55.0
60.0
70.0
60.0
40.0
20.0
0.0
16.0
12.0
8.0
Q=0
T=0
4.0
2.0
4.0
6.0
8.0
VOLTAGE (VDC)
16.0
0.0
0.0
HEAT
LOAD
(WATTS)
0.00
5.00
10.0
15.0
20.0
25.0
30.0
35.0
40.0
45.0
50.0
55.0
60.0
65.0
80.0
80.0
VOLTAGE (VDC)
TYPICAL PERFORMANCE CURVES
ENVIRONMENT: ONE ATMOSPHERE DRY NITROGEN
12.0
4.0
0.0
0.0
10.0
Q=0
T=0
8.0
2.0
4.0
6.0
8.0
10.0
CURRENT (AMPS)
CURRENT (AMPS)
MECHANICAL CHARACTERISTICS
For performance information in a vacuum or with hot side temperatures other than 27°C or 50°C, contact one of our Applications Engineers at 877-627-5691.
All dimensions are in millimeters unless otherwise stated.
For customer support or general questions please contact a local office or visit our website at www.marlow.com.
www.marlow.com
DOC # 102-0412 REV G - PAGE 2 OF 3
ACR Specification @ 23°C
Min
(ohms)
Max
(ohms)
1.450
1.780
Matching
Range
(max - min)
0.010
LCC12-8 ACR Matching Table
ACR (ohms)
Alphanumeric
Less than or
Code
Greater than
equal to
A0
A1
A2
A3
A4
A5
A6
A7
A8
A9
B0
B1
B2
B3
B4
B5
B6
B7
B8
B9
C0
C1
C2
C3
C4
C5
C6
C7
C8
C9
D1
D2
D3
1.450
1.460
1.470
1.480
1.490
1.500
1.510
1.520
1.530
1.540
1.550
1.560
1.570
1.580
1.590
1.600
1.610
1.620
1.630
1.640
1.650
1.660
1.670
1.680
1.690
1.700
1.710
1.720
1.730
1.740
1.750
1.760
1.770
1.460
1.470
1.480
1.490
1.500
1.510
1.520
1.530
1.540
1.550
1.560
1.570
1.580
1.590
1.600
1.610
1.620
1.630
1.640
1.650
1.660
1.670
1.680
1.690
1.700
1.710
1.720
1.730
1.740
1.750
1.760
1.770
1.780
www.marlow.com
Matching
Range
(max - min)
0.010
0.010
0.010
0.010
0.010
0.010
0.010
0.010
0.010
0.010
0.010
0.010
0.010
0.010
0.010
0.010
0.010
0.010
0.010
0.010
0.010
0.010
0.010
0.010
0.010
0.010
0.010
0.010
0.010
0.010
0.010
0.010
0.010
DOC # 102-0412 REV G - PAGE 3 OF 3
很抱歉,暂时无法提供与“LCC12-8-16LS”相匹配的价格&库存,您可以联系我们找货
