CP35147
CP35147
    CUIDEVICES
    PELTIER,15X15X4.7MM,3.5A
CP35147 数据手册
Additional Resources: Product Page | 3D Model date 08/05/2022 page 1 of 10 SERIES: CP35 | DESCRIPTION: PELTIER MODULE FEATURES • arcTEC™ structure on select models • solid state device • precise temperature control • quiet operation MODEL input voltage1 input current2 internal resistance3 max (Vdc) max (A) typ (Ω±10%) Th=27°C (W) Th=50°C (W) Th=27°C (°C) Th=50°C (°C) CP35147 2.1 3.5 0.44 3.9 4.3 68 75 CP35247 3.8 3.5 0.80 7.0 7.7 68 75 CP35301547 4.2 3.5 0.90 7.9 8.7 68 75 CP353476 8.6 3.5 1.93 16.0 17.8 70 77 CP353047 11.8 3.5 2.52 24.0 26.0 70 77 CP354476 15.4 3.5 3.3 29.0 32.0 70 77 24.1 3.5 5.17 49.0 53.0 70 77 6 CP354047 6 Notes: 1. Maximum voltage at ΔT max and Th=27°C 2. Maximum current to achieve ΔT max 3. Measured by AC 4-terminal method at 25°C 4. Maximum heat absorbed at cold side occurs at Imax, Vmax, and ∆T=0°C 5. Maximum temperature difference occurs at Imax, Vmax, and Q=0W (ΔT max measured in a vacuum at 1.3 Pa) 6. Designed with arcTEC™ structure. cuidevices.com output Qmax4 output ∆Tmax5 Additional Resources: Product Page | 3D Model CUI DEVICES | SERIES: CP35 | DESCRIPTION: PELTIER MODULE date 08/05/2022 | page 2 of 10 SPECIFICATIONS parameter conditions/description min solder melting temperature connection between thermoelectric pairs CP35347, CP353047, CP35447, CP354047 all other models 235 138 typ max °C °C assembly compression 1 RoHS units MPa yes MECHANICAL DRAWING units: mm MATERIAL HOT SIDE 0.05 THICKNESS COLD SIDE 0.05 ceramic plate 96% AL2O3 wire leads 20 AWG sealer silicon rubber 703 RTV (between cold and hot side plates) joint cover silicon rubber 703 RTV marking P/N & S/N printed on cold side surface 7 3.0 Red (+) WIDTH COLD SIDE Black (-) LENGTH 100.0 5.0 MODEL NO. LENGTH (mm) WIDTH (mm) THICKNESS (mm) CP35147 15 ±0.3 15 ±0.3 4.7 ±0.1 CP35247 20 ±0.3 20 ±0.3 4.7 ±0.1 CP35301547 30 ±0.3 15 ±0.3 4.7 ±0.1 CP353471 30 ±0.3 30 ±0.3 4.7 ±0.1 CP353047 30 ±0.3 30 ±0.3 4.7 ±0.1 CP35447 40 ±0.3 40 ±0.3 4.65 ±0.025 CP354047 40 ±0.3 40 ±0.3 4.7 ±0.1 Notes: 1. Wire lead strip length on model CP35347 is 10 ±3.0 mm. cuidevices.com PLATING tin Additional Resources: Product Page | 3D Model CUI DEVICES | SERIES: CP35 | DESCRIPTION: PELTIER MODULE date 08/05/2022 | page 3 of 10 Input Voltage (V) CP35147 PERFORMANCE (Th=27°C) 3.5 A 2.0 2.8 A 2.1 A 1.5 1.4 A 1.0 0.7 A 0.5 Heat Pumped, Q (W) 0 4.0 3.5 A 2.8 A A 2.1 1.4 A 3.0 2.0 0.7 A 1.0 0 70 60 50 40 30 20 10 0 ΔT=Th-Tc (°C) CP35147 PERFORMANCE (Th=50°C) Input Voltage (V) 3.5 A 2.8 A 2.0 2.1 A 1.5 1.4 A 1.0 0.7 A 0.5 Heat Pumped, Q (W) 0 3.5 A 2.8 A A 2.1 4.0 3.0 1.4 A 2.0 0.7 A 1.0 0 70 60 50 40 ΔT=Th-Tc (°C) cuidevices.com 30 20 10 0 Additional Resources: Product Page | 3D Model CUI DEVICES | SERIES: CP35 | DESCRIPTION: PELTIER MODULE date 08/05/2022 | page 4 of 10 Input Voltage (V) CP35247 PERFORMANCE (Th=27°C) 3.5 A 4.0 2.8 A 2.1 A 1.4 A 2.0 0.7 A Heat Pumped, Q (W) 0 3.5 6.0 A 2.8 2.1 1.4 4.0 A A A 0.7 A 2.0 0 70 60 50 40 30 20 10 0 ΔT=Th-Tc (°C) Input Voltage (V) CP35247 PERFORMANCE (Th=50°C) 4.0 3.5 A 2.8 A 2.1 A 1.4 A 2.0 0.7 A Heat Pumped, Q (W) 0 3.5 A 2.8 6.0 A 2.1 1.4 4.0 A A 0.7 A 2.0 0 70 60 50 40 ΔT=Th-Tc (°C) cuidevices.com 30 20 10 0 Additional Resources: Product Page | 3D Model CUI DEVICES | SERIES: CP35 | DESCRIPTION: PELTIER MODULE date 08/05/2022 | page 5 of 10 Input Voltage (V) CP35301547 PERFORMANCE (Th=27°C) 8.0 6.0 3.5 A 4.0 2.8 A 2.1 A 1.4 A 2.0 0.7 A Heat Pumped, Q (W) 0 8.0 3.5 A 2.8 A 6.0 2.1 4.0 A 1.4 A 0.7 A 2.0 0 70 60 50 40 30 20 10 0 ΔT=Th-Tc (°C) Input Voltage (V) CP35301547 PERFORMANCE (Th=50°C) 8.0 6.0 3.5 A 2.8 A 4.0 2.1 A 1.4 A 2.0 0.7 A Heat Pumped, Q (W) 0 3.5 A 8.0 2.8 A A 2.1 6.0 1.4 A 4.0 0.7 A 2.0 0 70 60 50 40 ΔT=Th-Tc (°C) cuidevices.com 30 20 10 0 Additional Resources: Product Page | 3D Model CUI DEVICES | SERIES: CP35 | DESCRIPTION: PELTIER MODULE date 08/05/2022 | page 6 of 10 Input Voltage (V) CP35347 PERFORMANCE (Th=27°C) 3.5 A 8.0 2.8 A 2.1 A 1.4 A 4.0 0.7 A 0 Heat Pumped, Q (W) 16 3.5 A A 2.8 2.1 12 1.4 8.0 A A 0.7 A 4.0 0 70 60 50 40 30 20 10 0 ΔT=Th-Tc (°C) Heat Pumped, Q (W) Input Voltage (V) CP35347 PERFORMANCE (Th=50°C) 8.0 3.5 A 2.8 A 2.1 A 1.4 A 4.0 0.7 A 0 3.5 16 2.8 A 2.1 12 A A 1.4 A 8.0 0.7 A 4.0 0 70 60 50 40 ΔT=Th-Tc (°C) cuidevices.com 30 20 10 0 Additional Resources: Product Page | 3D Model CUI DEVICES | SERIES: CP35 | DESCRIPTION: PELTIER MODULE date 08/05/2022 | page 7 of 10 Input Voltage (V) CP353047 PERFORMANCE (Th=27°C) 3.5 A 12 2.8 A 9.0 2.1 A 6.0 1.4 A 0.7 A 3.0 Heat Pumped, Q (W) 0 24 2.8 A 3.5 A 18 2.1 12 A 1.4 A 0.7 A 6.0 0 70 60 50 40 30 20 10 0 ΔT=Th-Tc (°C) Input Voltage (V) CP353047 PERFORMANCE (Th=50°C) 12 3.5 A 2.8 A 2.1 A 9.0 1.4 A 6.0 0.7 A 3.0 Heat Pumped, Q (W) 0 3.5 A 2.8 A A 2.1 24 18 1.4 A 12 0.7 A 6.0 0 70 60 50 40 ΔT=Th-Tc (°C) cuidevices.com 30 20 10 0 Additional Resources: Product Page | 3D Model CUI DEVICES | SERIES: CP35 | DESCRIPTION: PELTIER MODULE date 08/05/2022 | page 8 of 10 Input Voltage (V) CP35447 PERFORMANCE (Th=27°C) 3.5 A 16 2.8 A 2.1 A 1.4 A 8.0 0.7 A Heat Pumped, Q (W) 0 A 3.5 A 2.8 24 2.1 A 1.4 16 A 0.7 A 8.0 0 70 60 50 40 30 20 10 0 ΔT=Th-Tc (°C) Input Voltage (V) CP35447 PERFORMANCE (Th=50°C) 3.5 A 16 2.8 A 2.1 A 1.4 A 8.0 0.7 A Heat Pumped, Q (W) 0 3.5 24 A 2.8 A 2.1 A 1.4 16 A 0.7 A 8.0 0 70 60 50 40 ΔT=Th-Tc (°C) cuidevices.com 30 20 10 0 Additional Resources: Product Page | 3D Model CUI DEVICES | SERIES: CP35 | DESCRIPTION: PELTIER MODULE date 08/05/2022 | page 9 of 10 Input Voltage (V) CP354047 PERFORMANCE (Th=27°C) 3.5 A 24 2.8 A 18 2.1 A 1.4 A 12 0.7 A 6.0 Heat Pumped, Q (W) 0 80 60 2.8 A 3.5 A 40 2.1 A 1.4 A 20 0.7 A 0 70 60 50 40 30 20 10 0 ΔT=Th-Tc (°C) Input Voltage (V) CP354047 PERFORMANCE (Th=50°C) 3.5 A 24 2.8 A 2.1 A 18 1.4 A 12 0.7 A 6.0 Heat Pumped, Q (W) 0 80 2.8 A 60 3.5 A 40 20 0 2.1 A 1.4 A 0.7 A 70 60 50 40 30 ΔT=Th-Tc (°C) cuidevices.com 20 10 0 Additional Resources: Product Page | 3D Model CUI DEVICES | SERIES: CP35 | DESCRIPTION: PELTIER MODULE date 08/05/2022 | page 10 of 10 REVISION HISTORY rev. description date 1.0 initial release 09/08/2016 1.01 changed models CP35347 & CP35447 to arcTEC™ structure 12/01/2017 1.02 added models CP353047 & CP354047, brand update 10/18/2019 logo, datasheet style update 08/05/2022 1.03 The revision history provided is for informational purposes only and is believed to be accurate. CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website. CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate and reliable. However, no responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may result from its use. CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness. cuidevices.com
CP35147 价格&库存
很抱歉,暂时无法提供与“CP35147”相匹配的价格&库存,您可以联系我们找货
CP35147
    • 1+14.51156
