CP50341
CP50341
    CUIDEVICES
    PELTIER,30X30X4.05MM,5A,
CP50341 数据手册
Additional Resources: Product Page | 3D Model date 08/05/2022 page 1 of 9 SERIES: CP50 | DESCRIPTION: PELTIER MODULE FEATURES • arcTEC™ structure on select models • solid state device • precise temperature control • quiet operation MODEL input voltage1 input current2 internal resistance3 max (Vdc) max (A) typ (Ω±10%) CP50141 2.1 5.0 0.31 CP50241 3.8 5.0 0.56 CP50301541 4.2 5.0 0.63 CP50303956 11.8 5.0 1.74 CP50341 8.6 5.0 1.29 CP504416 15.4 5.0 2.3 6 Notes: 1. Maximum voltage at ΔT max and Th=27°C 2. Maximum current to achieve ΔT max 3. Measured by AC 4-terminal method at 25°C 4. Maximum heat absorbed at cold side occurs at Imax, Vmax, and ∆T=0°C 5. Maximum temperature difference occurs at Imax, Vmax, and Q=0W (ΔT max measured in a vacuum at 1.3 Pa) 6. Designed with arcTEC™ structure cuidevices.com output Qmax4 Th=27°C (W) output ∆Tmax5 Th=50°C (W) Th=27°C (°C) Th=50°C (°C) 5.5 6.1 68 75 10.0 11.1 68 75 11 12.3 68 75 35.0 38.0 70 77 23.0 25.7 70 77 41.0 45.8 70 77 Additional Resources: Product Page | 3D Model CUI DEVICES | SERIES: CP50 | DESCRIPTION: PELTIER MODULE date 08/05/2022 | page 2 of 9 SPECIFICATIONS parameter conditions/description min solder melting temperature connection between thermoelectric pairs 235 typ max °C assembly compression 1 RoHS units MPa yes MECHANICAL DRAWING units: mm MATERIAL HOT SIDE 0.05 THICKNESS COLD SIDE 0.05 ceramic plate 96% AL2O3 wire leads 20 AWG sealer silicon rubber 703 RTV (between cold and hot side plates) joint cover silicon rubber 703 RTV marking P/N & S/N printed on cold side surface 7 3.0 Red (+) WIDTH COLD SIDE Black (-) LENGTH 100.0 5.0 MODEL NO. LENGTH (mm) WIDTH (mm) THICKNESS (mm) CP50141 15 ±0.3 15 ±0.3 4.0 ±0.1 CP50241 20 ±0.3 20 ±0.3 4.0 ±0.1 CP50301541 30 ±0.3 15 ±0.3 4.0 ±0.1 CP5030395 30 ±0.3 30 ±0.3 3.95 ±0.025 CP503411 30 ±0.3 30 ±0.3 4.0 ±0.1 CP504411 40 ±0.3 40 ±0.3 4.0 ±0.1 Notes: 1. Wire lead strip length on models CP50341 & CP50441 is 10 ±3.0 mm. cuidevices.com PLATING tin Additional Resources: Product Page | 3D Model CUI DEVICES | SERIES: CP50 | DESCRIPTION: PELTIER MODULE date 08/05/2022 | page 3 of 9 Input Voltage (V) CP50141 PERFORMANCE (Th=27°C) 3.0 5A 2.0 4A 3A 2A 1.0 1A Heat Pumped, Q (W) 0 6.0 5A 4.0 4A 3A 2A 2.0 1A 0 70 60 50 40 30 20 10 0 ΔT=Th-Tc (°C) Input Voltage (V) CP50141 PERFORMANCE (Th=50°C) 3.0 5A 2.0 4A 3A 2A 1.0 1A Heat Pumped, Q (W) 0 5A 6.0 4A 3A 4.0 2A 1A 2.0 0 70 60 50 40 ΔT=Th-Tc (°C) cuidevices.com 30 20 10 0 Additional Resources: Product Page | 3D Model CUI DEVICES | SERIES: CP50 | DESCRIPTION: PELTIER MODULE date 08/05/2022 | page 4 of 9 Input Voltage (V) CP50241 PERFORMANCE (Th=27°C) 4.5 5A 4A 3.0 3A 2A 1.5 1A Heat Pumped, Q (W) 0 5A 9.0 4A 3A 6.0 2A 1A 3.0 0 70 60 50 40 30 20 10 0 ΔT=Th-Tc (°C) Input Voltage (V) CP50241 PERFORMANCE (Th=50°C) 5A 4.5 4A 3A 3.0 2A 1.5 1A Heat Pumped, Q (W) 0 5A 4A 9.0 3A 2A 6.0 1A 3.0 0 70 60 50 40 ΔT=Th-Tc (°C) cuidevices.com 30 20 10 0 Additional Resources: Product Page | 3D Model CUI DEVICES | SERIES: CP50 | DESCRIPTION: PELTIER MODULE date 08/05/2022 | page 5 of 9 Input Voltage (V) CP50301541 PERFORMANCE (Th=27°C) 8.0 6.0 5A 4.0 4A 3A 2A 2.0 1A Heat Pumped, Q (W) 0 16 4A 12 5A 3A 8.0 2A 4.0 0 1A 70 60 50 40 30 20 10 0 ΔT=Th-Tc (°C) Input Voltage (V) CP50301541 PERFORMANCE (Th=50°C) 8.0 6.0 5A 4A 4.0 3A 2A 2.0 1A Heat Pumped, Q (W) 0 16 5A 12 3A 8.0 2A 1A 4.0 0 4A 70 60 50 40 ΔT=Th-Tc (°C) cuidevices.com 30 20 10 0 Additional Resources: Product Page | 3D Model CUI DEVICES | SERIES: CP50 | DESCRIPTION: PELTIER MODULE date 08/05/2022 | page 6 of 9 Input Voltage (V) CP5030395 PERFORMANCE (Th=27°C) 5.0 A 12 4.0 A 9.0 3.0 A 6.0 2.0 A 1.0 A 3.0 Heat Pumped, Q (W) 0 40 5.0 A 4.0 A 3.0 A 30 20 2.0 A 10 1.0 A 0 70 60 50 40 30 20 10 0 ΔT=Th-Tc (°C) Input Voltage (V) CP5030395 PERFORMANCE (Th=50°C) 5.0 A 12 4.0 A 3.0 A 9.0 2.0 A 6.0 1.0 A 3.0 Heat Pumped, Q (W) 0 40 5.0 A 4.0 A 30 3.0 A 20 2.0 A 1.0 A 10 0 70 60 50 40 ΔT=Th-Tc (°C) cuidevices.com 30 20 10 0 Additional Resources: Product Page | 3D Model CUI DEVICES | SERIES: CP50 | DESCRIPTION: PELTIER MODULE date 08/05/2022 | page 7 of 9 Input Voltage (V) CP50341 PERFORMANCE (Th=27°C) 5.0 A 9.0 4.0 A 3.0 A 6.0 2.0 A 3.0 1.0 A 0 Heat Pumped, Q (W) 25 A 5.0 A 0 4. 20 3.0 A 15 2.0 A 10 1.0 A 5.0 0 70 60 50 40 30 20 10 0 ΔT=Th-Tc (°C) Input Voltage (V) CP50341 PERFORMANCE (Th=50°C) 9.0 5.0 A 4.0 A 3.0 A 6.0 2.0 A 3.0 1.0 A Heat Pumped, Q (W) 0 5.0 25 A A 4.0 20 3.0 15 A 2.0 A 10 1.0 A 5.0 0 70 60 50 40 ΔT=Th-Tc (°C) cuidevices.com 30 20 10 0 Additional Resources: Product Page | 3D Model CUI DEVICES | SERIES: CP50 | DESCRIPTION: PELTIER MODULE date 08/05/2022 | page 8 of 9 Input Voltage (V) CP50441 PERFORMANCE (Th=27°C) 5A 16 4A 12 3A 2A 8.0 1A 4.0 Heat Pumped, Q (W) 0 5A 40 4A 3A 30 2A 20 1A 10 0 70 60 50 40 30 20 10 0 ΔT=Th-Tc (°C) Input Voltage (V) CP50441 PERFORMANCE (Th=50°C) 16 5A 4A 3A 12 2A 8.0 1A 4.0 Heat Pumped, Q (W) 0 5A 4A 40 3A 30 2A 20 1A 10 0 70 60 50 40 ΔT=Th-Tc (°C) cuidevices.com 30 20 10 0 Additional Resources: Product Page | 3D Model CUI DEVICES | SERIES: CP50 | DESCRIPTION: PELTIER MODULE date 08/05/2022 | page 9 of 9 REVISION HISTORY rev. description date 1.0 initial release 09/08/2016 1.01 changed models CP50341 & CP50441 to arcTEC™ structure 12/01/2017 1.02 changed thickness of CP50141, CP50241, CP50301541 models 09/20/2018 1.03 added model CP5030395, brand update 10/18/2019 1.04 logo, datasheet style update 08/05/2022 The revision history provided is for informational purposes only and is believed to be accurate. CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website. CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate and reliable. However, no responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may result from its use. CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness. cuidevices.com
CP50341 价格&库存
很抱歉,暂时无法提供与“CP50341”相匹配的价格&库存,您可以联系我们找货
CP50341
    • 1+20.21053
