CP853345H
CP853345H
    CUIDEVICES
    PELTIER,30X30X3.45MM,8.5
CP853345H 数据手册
Additional Resources: Product Page | 3D Model date 08/05/2022 page 1 of 12 SERIES: CP85H | DESCRIPTION: PELTIER MODULE FEATURES • arcTEC™ structure on select models • enhanced reliability for high thermal cycling • superior thermal performance • silicon sealed • wide ΔT max • low profile • precise temperature control • solid state construction MODEL input voltage1 input current2 internal resistance3 max (Vdc) max (A) typ (Ω±10%) Th=27°C (W) Th=50°C (W) Th=27°C (°C) Th=50°C (°C) CP85134H 2.1 8.5 0.2 10.3 11.3 70 77 CP85153034H 4.2 8.5 0.47 21 23 70 77 CP85234H 3.8 8.5 0.35 18.8 20.8 70 77 CP852040345H6 7.6 8.5 0.75 38.2 42 70 77 CP85301534H 4.2 8.5 0.4 CP853345H6 8.8 8.5 0.85 CP8530345 11.8 8.5 CP854020345H6 7.6 8.5 CP854345H 15.7 8.5 1.5 6 6 Notes: output Qmax4 output ∆Tmax5 21 23 70 77 43.1 48 70 77 1.15 57.7 63.4 70 77 0.75 38.2 42 70 77 77.1 85 70 77 7 1. Maximum voltage at ΔT max and Th=27°C 2. Maximum current to achieve ΔT max 3. Measured by AC 4-terminal method at 25°C 4. Maximum heat absorbed at cold side occurs at Imax, Vmax, and ∆T=0°C 5. Maximum temperature difference occurs at Imax, Vmax, and Q=0W (ΔT max measured in a vacuum at 1.3 Pa) 6. Designed with arcTEC™ structure. 7. Internal resistance tolerance is ±12.5% cuidevices.com Additional Resources: Product Page | 3D Model CUI DEVICES | SERIES: CP85H | DESCRIPTION: PELTIER MODULE date 08/05/2022 | page 2 of 12 SPECIFICATIONS parameter conditions/description min solder melting temperature connection between thermoelectric pairs 235 typ max °C assembly compression 1 RoHS units MPa yes MECHANICAL DRAWING units: mm MATERIAL HOT SIDE 0.05 THICKNESS COLD SIDE 0.05 ceramic plate 96% AL2O3 wire leads 20 AWG sealer silicon rubber 703 RTV (between cold and hot side plates) joint cover silicon rubber 703 RTV marking P/N & S/N printed on cold side surface 10.0 3.0 Red (+) WIDTH COLD SIDE Black (-) LENGTH 100.0 5.0 MODEL NO. LENGTH (mm) WIDTH (mm) THICKNESS (mm) CP85134H 15 ±0.3 15 ±0.3 3.4 ±0.025 CP85153034H 15 ±0.3 30 ±0.3 3.4 ±0.025 CP85234H 20 ±0.3 20 ±0.3 3.4 ±0.025 CP852040345H 20 ±0.3 40 ±0.3 3.45 ±0.025 CP85301534H 30 ±0.3 15 ±0.3 3.4 ±0.025 CP853345H 30 ±0.3 30 ±0.3 3.45 ±0.025 CP8530345 30 ±0.3 30 ±0.3 3.45 ±0.025 CP854020345H 40 ±0.3 20 ±0.3 3.45 ±0.025 CP854345H 40 ±0.3 40 ±0.3 3.45 ±0.025 cuidevices.com PLATING tin Additional Resources: Product Page | 3D Model CUI DEVICES | SERIES: CP85H | DESCRIPTION: PELTIER MODULE date 08/05/2022 | page 3 of 12 Input Voltage (V) CP85134H PERFORMANCE (Th=27°C) 8.5 A 2.0 6.8 A 5.1 A 3.4 A 1.0 1.7 A Heat Pumped, Q (W) 0 8.0 8.5 A 5.1 A 6.8 A 3.4 A 4.0 0 1.7 A 70 60 50 40 30 20 10 0 ΔT=Th-Tc (°C) CP85134H PERFORMANCE (Th=50°C) Input Voltage (V) 8.5 A 6.8 A 2.0 5.1 A 3.4 A 1.0 1.7 A 0 A A 6.8 Heat Pumped, Q (W) 8.5 5.1 8.0 A 3.4 A 4.0 0 1.7 A 70 60 50 40 ΔT=Th-Tc (°C) cuidevices.com 30 20 10 0 Additional Resources: Product Page | 3D Model CUI DEVICES | SERIES: CP85H | DESCRIPTION: PELTIER MODULE date 08/05/2022 | page 4 of 12 Input Voltage (V) CP85153034H PERFORMANCE (Th=27°C) 8.0 6.0 8.5 A 4.0 6.8 A 5.1 A 3.4 A 2.0 1.7 A Heat Pumped, Q (W) 0 24 8.5 A 18 5.1 A 12 3.4 A 6.0 0 6.8 A 1.7 A 70 60 50 40 ΔT=Th-Tc (°C) 30 10 20 0 Input Voltage (V) CP85153034H PERFORMANCE (Th=50°C) 8.0 6.0 4.0 8.5 A 6.8 A 5.1 A 3.4 A 2.0 1.7 A Heat Pumped, Q (W) 0 24 8.5 A 6.8 A 18 5.1 A 12 1.7 A 6.0 0 3.4 A 70 60 50 40 ΔT=Th-Tc (°C) cuidevices.com 30 20 10 0 Additional Resources: Product Page | 3D Model CUI DEVICES | SERIES: CP85H | DESCRIPTION: PELTIER MODULE date 08/05/2022 | page 5 of 12 Input Voltage (V) CP85234H PERFORMANCE (Th=27°C) 8.5 A 4.0 6.8 A 5.1 A 3.4 A 2.0 1.7 A 0 Heat Pumped, Q (W) 6.8 A A 8.5 16 5.1 A 3.4 A 8.0 0 1.7 A 70 60 50 40 30 20 10 0 ΔT=Th-Tc (°C) CP85234H PERFORMANCE (Th=50°C) Input Voltage (V) 8.5 A 4.0 6.8 A 5.1 A 3.4 A 2.0 1.7 A 0 Heat Pumped, Q (W) 8.5 A A 6.8 A 5.1 16 3.4 A 8.0 0 1.7 A 70 60 50 40 ΔT=Th-Tc (°C) cuidevices.com 30 20 10 0 Additional Resources: Product Page | 3D Model CUI DEVICES | SERIES: CP85H | DESCRIPTION: PELTIER MODULE date 08/05/2022 | page 6 of 12 Input Voltage (V) CP852040345H PERFORMANCE (Th=27°C) 8.0 8.5 A 6.8 A 6.0 5.1 A 4.0 3.4 A 1.7 A 2.0 Heat Pumped, Q (W) 0 40 8.5 A 6.8 A 30 5.1 A 20 3.4 A 1.7 A 10 0 70 60 50 40 ΔT=Th-Tc (°C) 30 20 10 0 Input Voltage (V) CP852040345H PERFORMANCE (Th=50°C) 8.0 8.5A 6.8A 5.1A 6.0 3.4A 4.0 1.7A 2.0 Heat Pumped, Q (W) 0 8.5A 40 6.8A 5.1A 30 3.4A 20 1.7A 10 0 70 60 50 40 ΔT=Th-Tc (°C) cuidevices.com 30 20 10 0 Additional Resources: Product Page | 3D Model CUI DEVICES | SERIES: CP85H | DESCRIPTION: PELTIER MODULE date 08/05/2022 | page 7 of 12 CP85301534H PERFORMANCE (Th=27°C) Input Voltage (V) 8.0 6.0 8.5 A 4.0 6.8 A 5.1 A 3.4 A 2.0 1.7 A Heat Pumped, Q (W) 0 24 8.5 A 6.8 A 5.1 A 18 12 3.4 A 6.0 1.7 A 0 70 60 50 40 ΔT=Th-Tc (°C) 30 10 20 0 Input Voltage (V) CP85301534H PERFORMANCE (Th=50°C) 8.0 6.0 4.0 8.5 A 6.8 A 5.1 A 3.4 A 2.0 1.7 A Heat Pumped, Q (W) 0 24 8.5 A 6.8 A 18 5.1 A 3.4 A 12 1.7 A 6.0 0 70 60 50 40 ΔT=Th-Tc (°C) cuidevices.com 30 20 10 0 Additional Resources: Product Page | 3D Model CUI DEVICES | SERIES: CP85H | DESCRIPTION: PELTIER MODULE date 08/05/2022 | page 8 of 12 Input Voltage (V) CP853345H PERFORMANCE (Th=27°C) 8.5 A 8.0 6.8 A 5.1 A 3.4 A 4.0 1.7 A 0 8.5 Heat Pumped, Q (W) 40 6.8 A 5.1 30 A A 3.4 A 20 1.7 A 10 0 70 60 50 40 30 20 10 0 ΔT=Th-Tc (°C) Input Voltage (V) CP853345H PERFORMANCE (Th=50°C) 8.0 8.5 A 6.8 A 5.1 A 3.4 A 4.0 1.7 A 0 8.5 6.8 Heat Pumped, Q (W) 40 A A 5.1 30 A 3.4 A 20 1.7 A 10 0 70 60 50 40 ΔT=Th-Tc (°C) cuidevices.com 30 20 10 0 Additional Resources: Product Page | 3D Model CUI DEVICES | SERIES: CP85H | DESCRIPTION: PELTIER MODULE date 08/05/2022 | page 9 of 12 Input Voltage (V) CP8530345 PERFORMANCE (Th=27°C) 15 8.5 A 6.8 A 10 5.1 A 3.4 A 5 1.7 A Heat Pumped, Q (W) 0 60 8.5 A 6.8 A A 5.14 40 3.4 A 20 1.7 A 0 70 60 50 40 30 20 10 0 ΔT=Th-Tc (°C) Input Voltage (V) CP8530345 PERFORMANCE (Th=50°C) 15 8.5 A 6.8 A 10 5.1 A 3.4 A 5 1.7 A Heat Pumped, Q (W) 0 8.5 A 6.8 A A 5.14 60 40 3.4 A 20 1.7 A 0 70 60 50 40 ΔT=Th-Tc (°C) cuidevices.com 30 20 10 0 Additional Resources: Product Page | 3D Model CUI DEVICES | SERIES: CP85H | DESCRIPTION: PELTIER MODULE date 08/05/2022 | page 10 of 12 Input Voltage (V) CP854020345H PERFORMANCE (Th=27°C) 8.0 8.5 A 6.8 A 6.0 5.1 A 4.0 3.4 A 1.7 A 2.0 Heat Pumped, Q (W) 0 40 8.5 A 6.8 A 30 5.1 A 20 3.4 A 1.7 A 10 0 70 60 50 40 ΔT=Th-Tc (°C) 30 20 10 0 Input Voltage (V) CP854020345H PERFORMANCE (Th=50°C) 8.0 8.5 A 6.8 A 5.1 A 6.0 3.4 A 4.0 1.7 A 2.0 Heat Pumped, Q (W) 0 8.5 A 40 6.8 A 5.1 A 30 3.4 A 20 1.7 A 10 0 70 60 50 40 ΔT=Th-Tc (°C) cuidevices.com 30 20 10 0 Additional Resources: Product Page | 3D Model CUI DEVICES | SERIES: CP85H | DESCRIPTION: PELTIER MODULE date 08/05/2022 | page 11 of 12 Input Voltage (V) CP854345H PERFORMANCE (Th=27°C) 8.5 A 16 6.8 A 5.1 A 8.0 3.4 A 1.7 A 0 Heat Pumped, Q (W) 80 8.5 60 6.8 A 5.1 A A 3.4 40 A 1.7 A 20 0 70 60 50 40 30 20 10 0 ΔT=Th-Tc (°C) Input Voltage (V) CP854345H PERFORMANCE (Th=50°C) 8.5 A 16 6.8 A 5.1 A 3.4 A 8.0 1.7 A 0 8.5 Heat Pumped, Q (W) 80 6.8 A A A 5.1 60 3.4 40 A 1.7 A 20 0 70 60 50 40 ΔT=Th-Tc (°C) cuidevices.com 30 20 10 0 Additional Resources: Product Page | 3D Model CUI DEVICES | SERIES: CP85H | DESCRIPTION: PELTIER MODULE date 08/05/2022 | page 12 of 12 REVISION HISTORY rev. description date 1.0 initial release 09/08/2016 1.01 updated datasheet 09/25/2017 1.02 added new models 05/21/2018 1.03 added model CP8530345, brand update 10/18/2019 1.04 logo, datasheet style update 08/05/2022 The revision history provided is for informational purposes only and is believed to be accurate. CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website. CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate and reliable. However, no responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may result from its use. CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness. cuidevices.com
CP853345H 价格&库存
很抱歉,暂时无法提供与“CP853345H”相匹配的价格&库存,您可以联系我们找货
CP853345H
    • 1+132.00267
