CP70337
CP70337
    CUIDEVICES
    PELTIER,30X30X3.8MM,7A,
CP70337 数据手册
Additional Resources: Product Page date 08/05/2022 page 1 of 8 SERIES: CP70 | DESCRIPTION: PELTIER MODULE FEATURES • arcTEC™ structure on select models • solid state device • precise temperature control • quiet operation MODEL input voltage1 input current2 internal resistance3 max (Vdc) max (A) typ (Ω±10%) CP70137 2.1 7.0 0.24 CP70237 3.8 7.0 0.42 CP70301537 4.2 7.0 0.48 CP703376 8.6 7.0 1.0 CP70437 15.4 7.0 1.75 55.0 6 Notes: 1. Maximum voltage at ΔT max and Th=27°C 2. Maximum current to achieve ΔT max 3. Measured by AC 4-terminal method at 25°C 4. Maximum heat absorbed at cold side occurs at Imax, Vmax, and ∆T=0°C 5. Maximum temperature difference occurs at Imax, Vmax, and Q=0W (ΔT max measured in a vacuum at 1.3 Pa) 6. Designed with arcTEC™ structure cuidevices.com output Qmax4 Th=27°C (W) output ∆Tmax5 Th=50°C (W) Th=27°C (°C) Th=50°C (°C) 7.5 8.3 68 75 13.6 15.1 68 75 15.4 17.1 68 75 31.0 34.6 70 77 60.5 70 77 Additional Resources: Product Page CUI DEVICES | SERIES: CP70 | DESCRIPTION: PELTIER MODULE date 08/05/2022 | page 2 of 8 SPECIFICATIONS parameter conditions/description min solder melting temperature connection between thermoelectric pairs 235 typ units °C assembly compression hot side plate RoHS max 1 MPa 80 °C yes MECHANICAL DRAWING units: mm MATERIAL HOT SIDE 0.05 THICKNESS COLD SIDE 0.05 96% AL2O3 wire leads 20 AWG sealer silicon rubber 703 RTV (between cold and hot side plates) joint cover silicon rubber 703 RTV marking P/N & S/N printed on cold side surface 7 3.0 Red (+) WIDTH COLD SIDE Black (-) LENGTH 100.0 5.0 MODEL NO. LENGTH (mm) WIDTH (mm) THICKNESS (mm) CP70137 15 ±0.3 15 ±0.3 3.7 ±0.1 CP70237 20 ±0.3 20 ±0.3 3.7 ±0.1 CP70301537 30 ±0.3 15 ±0.3 3.7 ±0.1 1 CP70337 30 ±0.3 30 ±0.3 3.7 ±0.1 CP704371 40 ±0.3 40 ±0.3 3.7 ±0.1 Notes: 1. Wire lead strip length on models CP70337 & CP70437 is 10 ±3.0 mm. cuidevices.com PLATING ceramic plate tin Additional Resources: Product Page CUI DEVICES | SERIES: CP70 | DESCRIPTION: PELTIER MODULE date 08/05/2022 | page 3 of 8 CP70137 PERFORMANCE (Th=27°C) Input Voltage (V) 7A 2.0 5.6 A 4.2 A 1.5 2.8 A 1.0 1.4 A 0.5 Heat Pumped, Q (W) 0 8.0 7A 5.6 A 6.0 4.2 4.0 A 2.8 A 1.4 A 2.0 0 70 60 50 40 30 20 10 0 ΔT=Th-Tc (°C) CP70137 PERFORMANCE (Th=50°C) Input Voltage (V) 7A 5.6 A 2.0 4.2 A 1.5 2.8 A 1.0 1.4 A 0.5 Heat Pumped, Q (W) 0 7A 8.0 5.6 A A 4.2 6.0 2.8 A 4.0 1.4 A 2.0 0 70 60 50 40 ΔT=Th-Tc (°C) cuidevices.com 30 20 10 0 Additional Resources: Product Page CUI DEVICES | SERIES: CP70 | DESCRIPTION: PELTIER MODULE date 08/05/2022 | page 4 of 8 Input Voltage (V) CP70237 PERFORMANCE (Th=27°C) 7A 4.0 5.6 A 3.0 4.2 A 2.8 A 2.0 1.4 A 1.0 Heat Pumped, Q (W) 0 16 7A 12 4.2 8.0 5.6 A A 2.8 A 1.4 A 4.0 0 70 60 50 40 30 20 10 0 ΔT=Th-Tc (°C) Input Voltage (V) CP70237 PERFORMANCE (Th=50°C) 4.0 7A 5.6 A 4.2 A 3.0 2.8 A 2.0 1.4 A 1.0 Heat Pumped, Q (W) 0 5.6 A 16 7A 12 4.2 8.0 A 2.8 A 1.4 A 4.0 0 70 60 50 40 ΔT=Th-Tc (°C) cuidevices.com 30 20 10 0 Additional Resources: Product Page CUI DEVICES | SERIES: CP70 | DESCRIPTION: PELTIER MODULE date 08/05/2022 | page 5 of 8 Input Voltage (V) CP70301537 PERFORMANCE (Th=27°C) 8.0 6.0 7A 4.0 5.6 A 4.2 A 2.8 A 2.0 1.4 A Heat Pumped, Q (W) 0 5.6 A 16 7A 12 4.2 8.0 A 2.8 A 1.4 A 4.0 0 70 60 50 40 30 20 10 0 ΔT=Th-Tc (°C) Input Voltage (V) CP70301537 PERFORMANCE (Th=50°C) 8.0 6.0 7A 4.0 5.6 A 4.2 A 2.8 A 2.0 1.4 A Heat Pumped, Q (W) 0 7A 16 5.6 A A 4.2 12 2.8 A 8.0 1.4 A 4.0 0 70 60 50 40 ΔT=Th-Tc (°C) cuidevices.com 30 20 10 0 Additional Resources: Product Page CUI DEVICES | SERIES: CP70 | DESCRIPTION: PELTIER MODULE date 08/05/2022 | page 6 of 8 CP70337 PERFORMANCE (Th=27°C) Input Voltage (V) 7A 8.0 5.6 A 4.2 A 6.0 2.8 A 4.0 1.4 A 2.0 Heat Pumped, Q (W) 0 32 7A 5.6 A 24 4.2 A 16 2.8 A 1.4 A 8.0 0 70 60 50 40 30 20 10 0 ΔT=Th-Tc (°C) CP70337 PERFORMANCE (Th=50°C) Input Voltage (V) 7A 5.6 A 8.0 4.2 A 6.0 2.8 A 4.0 1.4 A 2.0 Heat Pumped, Q (W) 0 7A 32 5.6 A 24 4.2 A 2.8 A 16 1.4 A 8.0 0 70 60 50 40 ΔT=Th-Tc (°C) cuidevices.com 30 20 10 0 Additional Resources: Product Page CUI DEVICES | SERIES: CP70 | DESCRIPTION: PELTIER MODULE date 08/05/2022 | page 7 of 8 Input Voltage (V) CP70437 PERFORMANCE (Th=27°C) 7A 16 5.6 A 12 4.2 A 8.0 2.8 A 1.4 A 4.0 Heat Pumped, Q (W) 0 60 7A 5.6 A 4.2 A 2.8 A 40 20 1.4 A 0 70 60 50 40 30 20 10 0 ΔT=Th-Tc (°C) CP70437 PERFORMANCE (Th=50°C) Input Voltage (V) 7A 16 5.6 A 4.2 A 12 2.8 A 8.0 1.4 A 4.0 Heat Pumped, Q (W) 0 7A 60 5.6 A 4.2 A 40 2.8 A 1.4 A 20 0 70 60 50 40 ΔT=Th-Tc (°C) cuidevices.com 30 20 10 0 Additional Resources: Product Page CUI DEVICES | SERIES: CP70 | DESCRIPTION: PELTIER MODULE date 08/05/2022 | page 8 of 8 REVISION HISTORY rev. description date 1.0 initial release 09/08/2016 1.01 changed models CP70337 & CP70437 to arcTEC™ structure 12/01/2017 1.02 changed thickness of CP70137, CP70237, CP70301537 models 09/19/2018 1.03 brand update 10/30/2019 1.04 logo, datasheet style update 08/05/2022 The revision history provided is for informational purposes only and is believed to be accurate. CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website. CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate and reliable. However, no responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may result from its use. CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness. cuidevices.com
CP70337 价格&库存
很抱歉,暂时无法提供与“CP70337”相匹配的价格&库存,您可以联系我们找货
