2
3
4
5
6
Description:
Heat transfer, cold side:
Heat transfer, warm side:
Cascade:
A
B
A
A
8
Specification: (Ta=35°C, dT=0°C)
Air
Air
No
A
Cooling power: [W]
060
58 W (Calculated. Tolerance: ±10%.)
TEA Voltage, nominal: [VDC]
TEM Voltage: [VDC]
TEM Current: [A]
24
24 VDC
Nominal: 24 VDC (Max: 30 VDC)
Nominal: 2.7 A, Initial: 3.3 A (Calculated. Tolerance: ±10%.)
Fan(s), cold side:
Fan(s), warm side:
2
3
Nominal current: 0.14 A. Voltage: 24 VDC ±10%. L10: 50,000 hrs. at 25°C.
Nominal current: 0.15 A. Voltage: 24 VDC ±10%. L10: 50,000 hrs. at 25°C. IP55
Temperature controller, sensor:
Temperature control settings, trim options:
None
Temperature control position:
Additional controller information:
1
Connection board on coldside fan bracket.
Overheating thermostat:
Operating temperature:
TE-Module(s) temperature specification:
Enclosed:
Packing:
C
7
Code:
B
75°C ±5°C Internally on hot side heat sink surface.
-10°C to +51°C at nominal voltage.
Max. surface temperature: 80°C.
Individual cardboard box.
C
D
This drawing is the property of Laird Technologies, Inc. Protected in accordance with prevailing law.
1
D
E
E
General tolerances:
SS-ISO 2768-1 v
First angle
projection:
Dimension units:
Metric: [mm]
Comment/Treating:
Warm side of unit designed to comply with IP54. Hipot tested at 750VDC.
Designed by:
F
A. Kim
Checked by:
Approved by:
M. Nyman
H. Höjer
Release date:
2014-10-15
Project:
Title:
TE ASSEMBLY 24 VDC, AIR - AIR
Part nr:
1
2
3
E-mail: info.gothenburg@lairdtech.com,
6
Web: www.lairdtech.com
F
Standard
AA-060-24-23-00-10
7
Rev.
04
Scale: Size, sheet
8
- A3, 1(5)
1
2
3
4
5
6
7
Slit sealed with adhesive sealant
170
q 92
A
122
25
Adapted to meet
IP54
from this sealing
plane.
37
HOT SIDE
68
A
8
B
53
COLD SIDE
79
47
3
B
C
q 92
Electrical connections:
180
"+": + TEM
"-": - TEM
"F+": + Fan(s)
"F-": - Fan(s)
Jumpers
D
D
122
To use single supply:
Lift the jumpers and rotate 90° to short-cut the pin pairs.
Connect the unit to "+" & "-".
Warning: Single supply not applicable in heating mode o
r with PWM-regulation.
E
General tolerances:
SS-ISO 2768-1 v
230
First angle
projection:
Dimension units:
Metric: [mm]
Comment/Treating:
Designed by:
F
A. Kim
Checked by:
Approved by:
M. Nyman
H. Höjer
Release date:
2014-10-15
Project:
Title:
1
2
3
6
AA-060-24-23-00-10
7
E
F
Standard
Part nr:
C
Rev.
04
Scale: Size, sheet
8
- A3, 2(5)
1
2
3
4
5
6
7
8
2xO5
(Optional mounting holes)
A
4xM4`8
(Holes used to mount the unit.)
Installation and Service manual
A
Installation:
1. The TE assembly must be mounted in a cabinet with “Hot side”
mounted externally.
2. Suitable cabinet cutout is 105x182 mm.
B
3. Recommended for general purposes: the TE assembly should be fastened
according to picture below so that the gasket material will seal off around
the flange of the assembly.
B
4. The TE assembly must be positioned in vertical direction with wires facing
downwards (heat sink fins in vertical direction).
5. Note that condensation may occure. Standing water on the heat sink
should be avoided and drip tray may be required.
6. The TE assembly must be protected from external force or violence.
7. The power line to the assembly needs to be protected by a fuse. The fuse rating
should be of at least the nominal current of the assembly. It must withstand
150% of rated current for at least 60 seconds.
This is valid at Ta=35°C. Fuse ratings for other ambient temperatures (x°C) can
be calculated with the formula I[x°C]=I[35°C]/(1+0.005*(x-35)).
This is valid when regulating with an ON/OFF regulation. At rapid temperature
cycling where this is applicable, there can be need for even higher fuse ratings.
216
180
C
C
9. Switching power to TEM:s at frequencies between 0.01 Hz to 5 kHz will render
premature failure of modules and must be avoided.
D
8. Max ripple on supplied power =5%.
D
Service:
Fan impellers and heat sinks must be cleaned on regular intervals to reduce
risk for overheating and reduction of cooling function. The interval may vary
depending on environment.
Cabinet wall
E
TE-unit
E
103
Machine screw
112
General tolerances:
SS-ISO 2768-1 v
First angle
projection:
Dimension units:
Metric: [mm]
Comment/Treating:
Designed by:
F
A. Kim
Flat washer
Checked by:
Approved by:
M. Nyman
H. Höjer
Release date:
2014-10-15
Project:
Title:
Part nr:
1
2
3
6
F
Standard
AA-060-24-23-00-10
7
Rev.
04
Scale: Size, sheet
8
- A3, 3(5)
很抱歉,暂时无法提供与“AA-060-24-23-00-10”相匹配的价格&库存,您可以联系我们找货
