TG-CJ-60-60-15-PF
TG-CJ-60-60-15-PF
    T-GLOBAL
    HEATSINKCER60X60X15MM
TG-CJ-60-60-15-PF 数据手册
TG-CJ-60-60-15-PF Ceramic Heatsink Version 1.220917 Ceramic Heatsink T-Global’s range of ceramic heatsinks have been designed from a proprietary blend of engineering ceramics to offer superior thermal management for the most demanding of applications. Compared to aluminium, ceramics confer additional benefits such as electrically isolating, resistant to corrosion, low weight and does not act like an antenna. The addition of a pre-applied thermal tape further reduces the manufacturing complexity when compared to aluminum heatsinks. Features Large contact area Low weight High breakdown voltage Excellent heat spreader Custom shapes possible Applications LED, M/B, P/S, LCD, TV, Notebook, PC, PC Telecom Device, Wireless Hub, Power transistor, Power module, CPU, Chip IC Properties REACH Compliant ROHS Compliant Main Component Property Physical Property Unit Density g/cm3 3.66 Water Absorption % 0.002 Sinter Temperature °C Acid Resistance mg/cm Alkali mg/cm Mechanical Property Thermal Property Electrical Property Technical Ceramic Property 1700 3 Mohs Hardness HV Bend Strength Mpa 3 ≦0.2 ≦0.2 9 Compression Intensity Mpa ≧ 610 Maximum Working Temperature °C 1400 Thermal Expansion Coefficient (1x10 ) mm/°C 7.8~8.3 Thermal Shock Resistance T (°C) 200 Thermal Conductivity W/m.k. 40~51 ≧ 620 -6 Resisting Rate of Volume Ω °C 1016 DC Breakdown Strength KV/mm 15.2~16.7 Insulation Breakdown Intensity KV/mm 18 Dielectric Constant (1MHz) (E) 10 Dielectric Dissipation (tg o) 0.4*10-3 Part Number Information TG-CJ-60-60-15-PF Product Length Width Depth Adhesive TG-CJ-60-60-15-PF 60 60 15 - * All measurements in mm T-Global Technology Limited 1 & 2 Cosford Business Park, Central Park, Lutterworth, Leicestershire LE17 4QU U.K. Tel: +44 (0)1455 553 510 Email: sales@tglobaltechnology.com Web: www.tglobaltechnology.com Skype: tglobal.technology VAT #: GB 116 662 714 NOTICE: The information contained herein is to the best of our knowledge true and accurate. However, since the varied conditions of potential use are beyond our control, all recommendations or suggestions are presented without guarantee or responsibility on our part and users should make their own test to determine the suitability of our products in any specific situation. This product is sold without warranty either expressed or implied, of fitness for a particular purpose or otherwise, except that this product shall be of standard quality, and except to the extent otherwise stated TGlobal Technology Europe and North America’s invoice, quotation, or order acknowledgment. We disclaim any and liability incurred in connection with the use of information contained herein, or otherwise. All risks of such are assumed by the user. Furthermore, nothing contained herein shall be construed as a recommendation to use any process or to manufacture or to use any product in conflict with existing future patents covering any product or material or its use.
TG-CJ-60-60-15-PF 价格&库存
很抱歉,暂时无法提供与“TG-CJ-60-60-15-PF”相匹配的价格&库存,您可以联系我们找货
