CT40-5
CT40-5
    CHEMTRONICS
    SILICONE GREASE 5 0Z TUBE
CT40-5 数据手册
CHEMTRONICS TDS # CT40 Technical Data Sheet CircuitWorks Heat Sink Grease PRODUCT DESCRIPTION CircuitWorks Heat Sink Grease silicone compound facilitates heat transfer away from electrical/electronic components. This heavy consistency material is thickened with a heat conductive metal oxide filler to maintain a positive heat sink seal in electrical/electronic equipment.        Excellent conductivity Meets MIL-C-47113 Noncorrosive High dielectric strength Low bleed Stable from -15C to 200C Nonflammable TYPICAL PRODUCT DATA AND PHYSICAL PROPERTIES Color Specific Gravity @ 25C (77F) 2.6 Usable Temperature Range -52º F (-46º C) to 603º F (317º C) Dielectric Strength, v/mil 500 Dielectric Constant @ 100 Hz 4.4 Dissipation Factor @ 100 Hz 0.005 Volume Resistivity, ohm-cm 1 x 1014 Arc Resistance, seconds TYPICAL APPLICATIONS CircuitWorks Heat Sink Grease may be used for electronics and applications including:  Effective Thermal Coupler For Any Heat Sink Device  Nonflammable Coating Protection  High Voltage Corona Protection  Excellent for Improving Readings on Contact Type Thermocouples White 120 Thermal Conductivity, Cal-cm/sec-cm2 -C BTU-in/hr-ft2 -F W/mK 1.5 x 10-3 4.35 0.63 Shelflife 5 years COMPATIBILITY CircuitWorks Heat Sink Grease is generally compatible with most materials used in printed circuit board fabrication. As with any silicone compound, compatibility with substrate must be determined on a noncritical area prior to use. Material Ceramic Clean Metals Glass Natural Fibers Silicone Resins Painted Surfaces Plastic Surfaces Synthetic Fibers Vulcanized Silicone Rubber Wood Compatibility Good Good Good Good Good Good Good Good Good Good USAGE INSTRUCTIONS For industrial use only. Read MSDS carefully prior to use. Contact Chemtronics for complete usage and application instructions. When using CircuitWorks Heat Sink Grease, follow these guidelines: Apply to all mounting and threaded surfaces of the device and the chassis. Apply by pushing product ahead of neck. Dispensing: CircuitWorks Heat Sink Grease is a ready-to-use one-component material. Collapsible tubes may be squeezed by hand or with the aid of mechanical wringers. AVAILABILITY CT40-5 5 oz. Tube TECHNICAL & APPLICATION ASSISTANCE Chemtronics provides a technical hotline to answer your technical and application related questions. The toll free number is: 1-800-TECH-401. ENVIRONMENTAL IMPACT DATA ENVIRONMENTAL IMPACT DATA CFC 0.0% VOC 0.0% HCFC 0.0% HFC 0.0% Cl. Solv. 0.0% ODP 0.00 CFC, HCFC, CL. SOLV., VOC, and HFC numbers shown are the content by weight. Ozone depletion potential (ODP) is determined in accordance with the Montreal Protocol and U.S. Clean Air Act of 1990. NOTE: This information is believed to be accurate. It is intended for professional end users having the skills to evaluate and use the data properly. CHEMTRONICS does not guarantee the accuracy of the data and assumes no liability in connection with damages incurred while using it. CHEMTRONICS 8125 COBB CENTER DRIVE KENNESAW, GA 30152 1-770-424-4888 REV. B (07/15) Chemtronics and CircuitWorks are registered trademarks of Chemtronics. All rights reserved. DISTRIBUTED BY:
CT40-5 价格&库存
很抱歉,暂时无法提供与“CT40-5”相匹配的价格&库存,您可以联系我们找货
